  3. How Can I ReadRowsByRange For Itron SL7000 Profile Generic (0.0.99.1.0.255)
How can i ReadRowsByRange for Itron SL7000 Profile Generic (0.0.99.1.0.255)
By dlopezc4 , 8 June, 2022
hi, what datetime should i pass to method ReadRowsByRange to read just one hour?
4 years 5 months ago
Check this line from the client example. It reads data starting from midnight:
https://github.com/Gurux/gurux.dlms.java/blob/4a577e68f202e18dbce3798e7…
dlopezc4
Thanks mikko for your fast
Thanks mikko for your fast response, but My question is, if can i read just and specific hour?, for example just the 3 pm, because when the start date is not midnight inrecive a scope violation error
You can usually read for only one hour, but there are limitations with some meters. Now I have to say that I can't remember how Itron SL 7000 handles profile generic readings I know that there were some limitations like minutes and seconds must be zero. It might be that some of the meter firmware versions
can handle only midnight readings.
You need to try this by moving the start time from midnight to example 3 am. Most of the meters usually can handle one-hour reads.
  • Victorian | WA 083148835648
  • JOBS Billiard (Jakarta Online Billiard Store) | WA 083148835648
