  3. Implementation ECDSA With Gurux Library For Java
Implementation ECDSA with Gurux library for Java
By wooreeinfo , 26 April, 2022
Regards gurux.
I have questions for implementation to authentication ECDSA with Gurux library for Java.
I wrote sample codes for server and client sides using ECDSA authentication.
In this time, I refered to initializeConnection() and generateCertificates() method in GXDLMSReader.java.
It seems to be connect successfully, but I encountered Invalid HDLC Frame error while read object.
gurux.dlms.GXDLMSSettings checkFrame
INFO: Invalid HDLC Frame: 78 Expected: 56
TX: 17:59:46.335 7E A8 86 03 2F 54 59 42 E6 E6 00 DD 08 00 00 00 00 00 00 00 02 08 47 58 41 41 41 41 41 41 08 41 42 43 44 45 46 47 48 00 00 01 02 01 01 81 80 0E AA 57 88 8A E5 1E F1 DF DC E9 14 28 77 72 0A 60 CF 35 90 D8 94 5F DE D0 F9 80 38 52 EE B4 73 DC A3 DE D4 65 C1 D0 62 B3 34 C7 14 90 B1 C6 E9 85 D4 D4 08 6A B0 90 95 5A D6 49 F1 0E 5A 03 A4 2A DA C0 B9 75 30 02 53 E9 AC 22 83 B2 41 8A F0 AC D5 4D 53 71 92 66 37 7E
RX: 17:59:46.335 7E A0 07 2F 03 71 08 73 7E
Do you have any examples or guidances for implementation ECDSA?
4 years 7 months ago
Have you tried to generate new certificates and then connect using the client example?
https://github.com/Gurux/gurux.dlms.java/tree/master/gurux.dlms.client…
You can generate new certificates with this:
-h YOUR_METER_IP -p 4049 -c HIGH_LEVEL:CLIENT_ADDRESS -a High -P YOUR_PASSWORD -t Verbose -T 4758436C69656E74 -N 0.0.43.0.1.255
Then try to connect with this:
-h YOUR_METER_IP -p 4059 -c 44 -a HighECDSA -t Verbose -T 4758436C69656E74 -M 4752580000000001 -K GeneralSigning -V Suite1 -C AuthenticationEncryption -v 0.0.43.1.1.255
ECDSA implementation for Java is quite slow and ECDSA is really complicated.
wooreeinfo
4 years 6 months ago
Thanks a lot.
Thanks a lot.
I'll ask if i have any new questions later.
by the way, is there any implementation examples or guidances for server side with ecdsa?
You don't need to do anything else than send a certificate for the meter. Meter will start to use it automatically when the client wants to use general signing.
  • Victorian | WA 083148835648
