  3. Scalers and Units - Problem With Parsing?
Scalers and units - problem with parsing?
By Mariusz Jędrzejewski , 21 February, 2022
we have two meters of the same type - L+G ZMD. This type uses Short Name referencing along with HDLC interface type. We want to read scalers and units for generic profile 1.0.99.1.0.255, the base short address for this profile is 25200 (decimal). So, we have to read attribute 3 of profile and we know what registers are inside the profile.
Than, we can ask first meter for scalers and units, request is combined with short names of simple registers readed from profile:
7E A0 2C 00 02 68 47 41 FA D4 CB E6 E6 00 05 09 02 48 B0 02 25 E8 02 1D A8 02 1E 50 02 1F 08 02 24 88 02 25 38 02 2E D0 02 2E 20 64 4C 7E
Decoded byte stream:
<HDLC len="43">
<TargetAddress Value="23075"/>
<SourceAddress Value="32"/>
<!--I frame.-->
<FrameType Value="FA"/>
<PDU>
<ReadRequest Qty="9">
<VariableName Value="18608"/>
<VariableName Value="9704"/>
<VariableName Value="7592"/>
<VariableName Value="7760"/>
<VariableName Value="7944"/>
<VariableName Value="9352"/>
<VariableName Value="9528"/>
<VariableName Value="11984"/>
<VariableName Value="11808"/>
</ReadRequest>
</PDU>
</HDLC>
Meter reply:
7E A0 50 41 00 02 68 47 DE 30 44 E6 E7 00 0C 09 00 02 02 0F 00 16 FF 00 02 02 0F FE 16 1E 00 02 02 0F FE 16 1E 00 02 02 0F FE 16 20 00 02 02 0F FE 16 20 00 02 02 0F FE 16 20 00 02 02 0F FE 16 20 00 02 02 0F FE 16 1E 00 02 02 0F FE 16 1E 24 CF 7E
<HDLC len="79">
<TargetAddress Value="32"/>
<SourceAddress Value="23075"/>
<!--I frame.-->
<FrameType Value="DE"/>
<PDU>
<ReadResponse Qty="9">
<Data>
<Structure Qty="2">
<Int8 Value="0"/>
<Enum Value="255"/>
</Structure>
</Data>
<Data>
<Structure Qty="2">
<Int8 Value="-2"/>
<Enum Value="30"/>
</Structure>
</Data>
<Data>
<Structure Qty="2">
<Int8 Value="-2"/>
<Enum Value="30"/>
</Structure>
</Data>
<Data>
<Structure Qty="2">
<Int8 Value="-2"/>
<Enum Value="32"/>
</Structure>
</Data>
<Data>
<Structure Qty="2">
<Int8 Value="-2"/>
<Enum Value="32"/>
</Structure>
</Data>
<Data>
<Structure Qty="2">
<Int8 Value="-2"/>
<Enum Value="32"/>
</Structure>
</Data>
<Data>
<Structure Qty="2">
<Int8 Value="-2"/>
<Enum Value="32"/>
</Structure>
</Data>
<Data>
<Structure Qty="2">
<Int8 Value="-2"/>
<Enum Value="30"/>
</Structure>
</Data>
<Data>
<Structure Qty="2">
<Int8 Value="-2"/>
<Enum Value="30"/>
</Structure>
</Data>
</ReadResponse>
</PDU>
</HDLC>
Looks good so far. When we read values from profile, all values are re-scaled based on above scalers and everything is ok.
Second meter - we ask for scalers:
TX: 7E A0 44 00 02 80 51 41 3A AF 75 E6 E6 00 05 11 02 48 B0 02 25 E8 02 1D A8 02 1E 50 02 1F 08 02 24 88 02 25 38 02 9A F8 02 9B 88 02 9C 18 02 9C A8 02 9D 38 02 9D C8 02 2C C0 02 2D 70 02 A8 78 02 AA B8 08 68 7E
<HDLC len="67">
<TargetAddress Value="24616"/>
<!--I frame.-->
<FrameType Value="3A"/>
<PDU>
<ReadRequest Qty="17">
<VariableName Value="39672"/>
<VariableName Value="39816"/>
<VariableName Value="39960"/>
<VariableName Value="40104"/>
<VariableName Value="40248"/>
<VariableName Value="40392"/>
<VariableName Value="11456"/>
<VariableName Value="11632"/>
<VariableName Value="43128"/>
<VariableName Value="43704"/>
</ReadRequest>
</PDU>
</HDLC>
Reply:
RX: 7E A8 50 41 00 02 80 51 D2 C2 AD E6 E7 00 0C 11 00 02 02 0F 00 16 FF 00 02 02 0F FE 16 1E 00 02 02 0F FE 16 1E 00 02 02 0F FE 16 20 00 02 02 0F FE 16 20 00 02 02 0F FE 16 20 00 02 02 0F FE 16 20 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 72 A9 7E
<HDLC len="79">
<SourceAddress Value="24616"/>
<!--I frame.-->
<FrameType Value="D2"/>
<NextFrame Value="0C110002020F0016FF0002020FFE161E0002020FFE161E0002020FFE16200002020FFE16200002020FFE16200002020FFE16200002020FFE16230002020FFE1623"/>
</HDLC>
TX: 7E A0 0A 00 02 80 51 41 51 5D E9 7E
<HDLC len="12">
<!--S frame.-->
<FrameType Value="51"/>
<Command Value="NextFrame"/>
</HDLC>
RX: 7E A0 44 41 00 02 80 51 D4 F7 3F 00 02 02 0F FE 16 23 00 02 02 0F FD 16 21 00 02 02 0F FD 16 21 00 02 02 0F FD 16 21 00 02 02 0F FE 16 1E 00 02 02 0F FE 16 1E 00 02 02 0F FD 16 FF 00 02 02 0F FD 16 FF C8 E4 7E
<HDLC len="67">
<!--I frame.-->
<FrameType Value="D4"/>
<NextFrame Value="0002020FFE16230002020FFD16210002020FFD16210002020FFD16210002020FFE161E0002020FFE161E0002020FFD16FF0002020FFD16FF"/>
</HDLC>
At first glance, the response data stream looks very similar to previous one, but frame types are different, something like RAW data stream. Regardless, the data looks similar. But, we have a problem right here: when we read profile values, the above scalers are not applied for register values. It looks like situation when scalers are not readed from attribute 3 before readout of values from attribute 2.
Can you check if second meter replies with proper scaler and unit data, or maybe this kind of data stream is not properly parsed by the GuruX Java library? If you want more data, we're ready.
Thank you in advance!
Best regards,
Mariusz
4 years 9 months ago
Dupicate of http://www.gurux
Duplicate of http://www.gurux.fi/node/19715 :)
The data looks correct. Are you using ReadList-method to read scalers and units from the meter?
We are using standard
We are using standard GXDLMSSecureClient class, and code is derived from your reference GXDLMSReader example.
void readScalerAndUnits(GXDLMSProfileGeneric profileGeneric) throws Exception {
GXDLMSObjectCollection collection = new GXDLMSObjectCollection();
profileGeneric.getCaptureObjects().stream()
.filter(entry -> !driverParameters.usesShortNameReferencing() || nonNull(dlmsClient.getObjects().findBySN(entry.getKey().getShortName())))
.forEach(entry -> collection.add(entry.getKey()));
readScalerAndUnits(collection);
void readScalerAndUnits(GXDLMSObjectCollection objectsToRead) throws Exception {
try {
if (dlmsClient.getNegotiatedConformance().contains(Conformance.MULTIPLE_REFERENCES)) {
List<Entry<GXDLMSObject, Integer>> list = new ArrayList<>();
for (GXDLMSObject it : objectsToRead) {
chooseInstanceOfGXDLMSObject(list, it);
readList(list);
} catch (Exception e) {
dlmsClient.getNegotiatedConformance().remove(Conformance.MULTIPLE_REFERENCES);
private void chooseInstanceOfGXDLMSObject(List<Entry<GXDLMSObject, Integer>> list, GXDLMSObject it) {
if (it instanceof GXDLMSRegister) {
list.add(new GXSimpleEntry<>(it, 3));
if (it instanceof GXDLMSDemandRegister) {
list.add(new GXSimpleEntry<>(it, 4));
and finally:
private void readList(List<Entry<GXDLMSObject, Integer>> list) throws Exception {
if (!list.isEmpty()) {
byte[][] data = dlmsClient.readList(list);
List<Object> values = new ArrayList<>(list.size());
for (byte[] it : data) {
readDataBlock(it, reply);
if (reply.getValue() != null) {
values.addAll((List<?>) reply.getValue());
reply.clear();
if (values.size() != list.size()) {
throw new MeterConnectionUnsuccessfulException("Invalid reply. Read items count do not match.");
dlmsClient.updateValues(list, values);
From my point of view it looks like this: when collection size of objects to read is short that meter can respond in just one packet with scalers and units data, everything is fine. When collection is longer, and meter need to respond within two or more packets (when client calls chunks with NextPacket frame type), scalers are not updated. For now, that only applies to SN referencing meters and HDLC interface.
Hi Mariusz,
Hi Mariusz,
The version 4.0.30 is released. There is one change for reading multiple values with the list method.
I hope it solves your problem.
lukasm
4 years 8 months ago
Hello Mikko,
Hello Mikko,
We have tried to read the scallers with newest (4.0.30) Gurux version and the result is still the same:
<HDLC len="79" >
<TargetAddress Value="32" />
<SourceAddress Value="22165" />
<!--I frame.-->
<FrameType Value="D2" />
<NextFrame Value="0C110002020F0016FF0002020FFF161E0002020FFF161E0002020FFF16200002020FFF16200002020FFF16200002020FFF16200002020FFE16230002020FFE1623" />
</HDLC>
<HDLC len="12" >
<TargetAddress Value="22165" />
<SourceAddress Value="32" />
<!--S frame.-->
<FrameType Value="51" />
<Command Value="NextFrame" />
</HDLC>
<HDLC len="67" >
<!--I frame.-->
<FrameType Value="D4" />
<NextFrame Value="0002020FFE16230002020FFE16210002020FFE16210002020FFE16210002020FFF161E0002020FFF161E0002020FFD16FF0002020FFD16FF" />
</HDLC>
Could You verify it?
Best Regards,
Lukasz
Hi Lukasz,
Hi Lukasz,
One line modification was added to parse your data. This modification was tested when I was told that you should be able to read your meter, but it was rejected before release.
Our clients are reading old Landis+Gyr E650 meters and this modification causes those meters were not able to read anymore using with readlist method.
Your meter is working like standard defines, but this modification can't be started to use before those E650 meters can be read. I'm thinking about how to read both meters, but there is no simple solution at the moment.
Modify readScalerAndUnits and remove readList part for now. The application will read scalers one by one, but you can read all scalers without problems.
  • Victorian | WA 083148835648
