  3. `Meter Expects Logical Name Referencing` Error
`Meter expects Logical Name referencing` error
By Yuriy Abdrakhimov , 15 January, 2022
U am trying to call Gurux java client with these parameters:
-h [host] -t Verbose -p 4059 -a Low -P [password] -C Authentication -s 1 -c 16 -r ln
but i receive this error:
The application context name is not supported. Meter expects Logical Name referencing.
The full log:
Connect using network connection gurux.net.GXNet@4c70fda8
Authentication: Low
ClientAddress: 0x10
Standard: DLMS
Security: AUTHENTICATION
System title: 41 42 43 44 45 46 47 48
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
Block cipher key 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
TX: 22:59:02.742 7E A0 07 03 21 93 0F 01 7E
RX: 22:59:03.300 7E A0 07 21 03 73 01 40 7E
TX: 22:59:03.370 7E A0 61 03 21 10 E2 65 E6 E6 00 60 53 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 08 80 06 52 65 61 64 65 72 BE 23 04 21 21 1F 10 00 00 00 00 01 00 00 00 06 5F 1F 04 00 22 1E 5D FF FF 06 92 9E 7C 2E 15 34 EC EE F0 0A 1A 48 23 7E
RX: 22:59:04.111 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 02 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 04 00 00 07 E5 00 7E
Connection is permanently rejected
4 years 10 months ago
You try to connect using a secured connection and meter expect connection without encryption. Remove -C Authentication parameter.
  • Victorian | WA 083148835648
