  3. Writing GXDLMSCharge Object Using Java Library
Writing GXDLMSCharge object using Java library
By Vusi , 29 November, 2021
Known problems
Writing to the GXDLMSCharge causes an exception, "Value can't be enum. Give integer value." I have isolated the problem to the GXDLMSCharge.class file on line 555 where the ObjectType enum is returned instead if it's integer value. This is the bug:
GXCommon.setData(null, bb, DataType.UINT16, charge.getCommodity().getTarget().getObjectType());
Should be:
GXCommon.setData(null, bb, DataType.UINT16, charge.getCommodity().getTarget().getObjectType().getValue());
4 years 11 months ago
Thanks for pointing this out and you are right. This is fixed for the next release.
Vusi
Thank you for the prompt response, do you maybe know when the next release is coming?
Tests started last week and I hope that it's released during this week as soon as the tests are over.
  • Victorian | WA 083148835648
