  3. Reading CLock
Reading CLock
By poojash , 27 May, 2021
Known problems
I can receive clock from meter and time is in hex format. I want to convert it into dd:mm:yyyy hh:mm:ss this format. what is the formula?
5 years 6 months ago
You can use GXDLMSClient.ChangeType to convert byte array to date-time.
Something like this:
GXDLMSClient.ChangeType((byte[])value, DataType.DateTime, useUtc);
Set useUtc to true, if your meter is using UTC time (Indian and Italy meters are using this and to false if your meter is from Europe.
  • Victorian | WA 083148835648
