  3. Parallel Working With Devices
Parallel working with devices
By Valeriy , 8 February, 2021
Gurux.DLMS.AMI
Hello!
Interesting to know if it is possible to work in parallel with devices using for example tcp network channel?
Are the tasks serve one after another or there is a way to work with several devices? (send request to the first, dont wait for the answer - due to possible long answers, ask another device, receiving the answer from the first and work with in).
5 years 9 months ago
If you are using a TCP/IP connection you can read several meters at the same time. You can change the number of concurrent reads modifying appsettings.json. Change the "Threads" number. In default, there are 10 threads and you can read 10 meters parallel.
  • Victorian | WA 083148835648
  • JOBS Billiard (Jakarta Online Billiard Store) | WA 083148835648
