  3. Parse Exception During Load Association File
Parse Exception during load association file
By Akriti Tyagi , 3 December, 2020
When i am running the jar file to read the data from the meter and load association file then it throws exception . The exception is given below :
java.lang.IllegalArgumentException: java.text.ParseException: Unparseable date: "1/1/20 8:11:02 PM"
at gurux.dlms.GXDateTime.<init>(GXDateTime.java:339)
at gurux.dlms.objects.GXDLMSClock.load(GXDLMSClock.java:645)
at gurux.dlms.objects.GXDLMSObjectCollection.load(GXDLMSObjectCollection.java:200)
at gurux.dlms.objects.GXDLMSObjectCollection.load(GXDLMSObjectCollection.java:146)
5 years 11 months ago
This is tested and it worked without problems. The time should be in 24-hour format. How you have saved the clock object? Have you used GXDLMSObjectCollection.save -method?
What is your jar version?
  • Victorian | WA 083148835648
