  3. How To Specify Logical Server and Physical Server In GxSerial Java
How to specify logical server and physical server in GxSerial Java
By pramodahanya , 1 October, 2020
Hello, For our meter to connect via the serial interface (RS485/Optical) we would have to specify the logical server and physical server which is based on the serial number. We could successfully connect to the meter using GXDLMSDirector as there is an option for specifying for these but couldn't manage to connect using GXDLMS java serial interface. I have checked the code and the methods in GXSerial and GXDLMSClient but didn't find anything to mention these. Could you please do let me know how can I pass these parameters while establishing a connection? I have attached the GXDlmsDirector configuration screenshot.
Best Regards
Pramod
6 years 1 month ago
You can set server address using pfysical and logical address like this:
client.setServerAddress(GXDLMSClient.getServerAddress(16, 62);
Client example is updated and the command line parameter for client example is:
-s 62 -l 16
pramodahanya
6 years 1 month ago
Thank you, Mikko. It wokred
bayasgalan
6 years ago
how to set logical server
how to set logical server address on c client?
6 years ago
Hi bayasgalan,
Hi bayasgalan,
Please, create a new topic f you have a new question. We are testing cl_getServerAddress for ANSI C at the moment. We are releasing it the latest on Monday.
  • Victorian | WA 083148835648
