  3. Data To Xml Before Pass To Ami
Data to xml before pass to ami
By MNN , 16 June, 2020
Gurux.DLMS.AMI
Is there a library that can be used to pack data (data to xml) before transferring to 1 for writing to the device? Or is it possible to make the data transferred as is (in object GXObject), and the packaging (data to xml) was in ami?
6 years 5 months ago
Data must convert value to XML before sending it to the Gurux.DLMS.AMI. You can use GXDLMSTranslator.ValueToXml -method for that.
MNN
Thank you.
Thank you.
I am trying to use ami on a web. Tell me, please, can I use existing methods for packing the data before send it to write in ami, as well as for unpacking complex data (such as structures, arrays), which are receive as xml in ami?
As far as I understand method ValueToXml receive only symple type.
ValueToXML support also complex data types. Use it to convert value to XML format.
  • Victorian | WA 083148835648
