  3. Reading Load Profile By Date Range or No of Entries
Reading load profile by date range or no of entries
By rahul.singh@ra… , 20 May, 2020
Gurux.DLMS.AMI
Hi Mikko ,
Greetings for the day, hope you are doing well and safe.
I need to understand few things related to reading load profile of meters.
1. We can successfully full meter load profile using AMI.
2. Now , once we read all data of read profile.
we need to read load profile data on incremental basis .
so , what we can pass in GXValue to read load profile data of that range .
6 years 6 months ago
Gurux.DLMS.AMI reads always all profile generic data from the meter and saves it to the DB. This data is retrieved using ListObjects method. If you want to get values using start and end time you call ListObjects and set Start and End time.
Targets: Tells information that is returned.,
DeviceId: Device ID.,
Objects: Objects to list.,
Start: Profile Generic start time. This is used only with Profile Generic objects.,
End: Profile Generic end time. This is used only with Profile Generic objects.,
Index: Profile Generic Index. This is used only with Profile Generic objects.,
Count: Profile Generic Count. This is used only with Profile Generic objects.,
Valeriy
6 years 5 months ago
Hello all!
Hello all!
Any examples of requests to read data by a request?
I mean the values for attributes (sort method, sort object, capture period)?
Tried to make a request by Director - but got a types error - GXDLMSMeter to DB.GXDevice.
And interested in making action requests - Reset and Capture.
In reply to Hello all! by Valeriy
Hi Valeriy,
Hi Valeriy,
Please, if you have a new question create a new topic. I'll answer for your question there.
  • Victorian | WA 083148835648
