  3. Invocation Counter
By Kurumi , 18 March, 2020
Getting started
Invocation counter
Invocation counter a.k.a Frame counter is a counter value that is increased every time when a message is ciphered. Increasing invocation counter causes that messages are encrypted differently, even the content is the same.
The invocation counter is not used non-ciphered messages. Invocation counter value is usually saved to the data-object. If invocation counter is not correct, the meter will not accept the message. There might be several invocation counters on the meter. There is usually one invocation counter for each secured association. With some meters, there might be own invocation counter for optical port connection and own invocation counter for TCP/IP connection.
Client side
Before starting the ciphered connection client must establish a normal connection (usually this is done without authentication) and read the invocation counter from the meter. After reading the counter value connection is closed. There is a -I parameter in client examples that is reading invocation counter from the meter. You can use parameter like this:
-I 0.0.43.1.0.255
  • Java
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
GXDLMSData client = new GXDLMSClient();
// Is used Logican Name or Short Name referencing.
client.setInterfaceType(InterfaceType.HDLC);
client.setClientAddress(16);
client.setServerAddress(1);
//Send SNRM request and parse UA response
//Send AARQ request and parse AARE response
//Read invocation counter.
GXDLMSData d = new GXDLMSData("OBIS_CODE");
read(d, 2);
client.getCiphering().setInvocationCounter(1 + ((Number)d.Value));
//Close the connection.
disconnect();
GXDLMSClient client = new GXDLMSClient();
client.UseLogicalNameReferencing = true;
// Is used HDLC or COSEM transport layers for IPv4 networks (IEC 62056-47)
client.InterfaceType = InterfaceType.Hdlc;
client.ClientAddress = 16;
client.ServerAddress = 1;
Read(d, 2);
Client.Ciphering.InvocationCounter = 1 + Convert.ToUInt32(d.Value);
Disconnect();
Client := TGXDLMSClient.Create(
    True,
  //Client ID
    16,
  //Server ID
    1,
  //Authentication Level.
    TAuthentication.None,
  //PassWord
    Nil,
  TInterfaceType.General);
d := TGXDLMSData.Create("OBIS_CODE");
Read(d, 2);
Client.Ciphering.InvocationCounter := 1 + d.Value.AsInteger;
FreeAndNil(d);
Disconnect();
CGXDLMSClient cl(
true,
//Client ID
16,
//Server ID
1,
GXDLMS_AUTHENTICATION_LOW,
//PassWord
"ABCDEFGH",
GXDLMS_INTERFACETYPE_HDLC);
CGXDLMSData d("OBIS_CODE");
Read(d, 2);
client.GetCiphering()->SetInvocationCounter(1 + d.GetValue().ToInteger());
Disconnect();
connection con;
//Support trace.
con_init(&con, 1);
//Initialize settings using Logican Name referencing and WRAPPER.
cl_init(&con.settings,
1,
//Client ID
16,
//Server ID
1,
DLMS_AUTHENTICATION_NONE,
//Password
NULL,
DLMS_INTERFACE_TYPE_HDLC);
gxData d;
const unsigned char ln[6] = { 0,0,43, 1, 0, 255};
cosem_init(BASE(d), DLMS_OBJECT_TYPE_DATA, ln);
if ((ret = com_read(&con, BASE(d), 2)) == 0)
    con.settings.cipher.invocationCounter = 1 + var_toInteger(&d.value);
com_disconnect(&con);
client = GXDLMSClient()
#Is used Logican Name or Short Name referencing.
client.useLogicalNameReferencing = True
#Is used HDLC or COSEM transport layers for IPv4 networks (IEC 62056-47)
client.interfaceType = InterfaceType.HDLC
client.clientAddress = 16
client.serverAddress = 1
d = GXDLMSData("OBIS_CODE")
read(d, 2)
client.ciphering.invocationCounter = 1 + d.value
Server side
There is no link from the Security Setup object to the invocation counter data object. This causes that this must add manually to the server side code. This is done adding association view and invocation counter object as normal.
  • Java
  • C#
  • ANSI C++
  • ANSI C
//Add logical name association object.
GXDLMSAssociationLogicalName ln = new GXDLMSAssociationLogicalName();
ln.setSecuritySetupReference("0.0.43.0.0.255");
getItems().add(ln);
//Add security setup object.
GXDLMSSecuritySetup ss = new GXDLMSSecuritySetup("0.0.43.0.0.255");
ss.setServerSystemTitle(getCiphering().getSystemTitle());
getItems().add(ss);
//Add invocation counter
GXDLMSData d = new GXDLMSData("0.0.43.1.0.255");
d.setDataType(2, DataType.UInt32);
//Set initial value for invocation counter.
d.setValue(100);
getItems().add(d);
ln.SecuritySetupReference = "0.0.43.0.0.255";
Items.Add(ln);
ss.ServerSystemTitle = this.Ciphering.SystemTitle;
Items.Add(ss);
d.SetDataType(2, DataType.UInt32);
d.Value = (UInt32)100;
Items.Add(d);
CGXDLMSAssociationLogicalName* ln = new CGXDLMSAssociationLogicalName();
ln->SetSecuritySetupReference("0.0.43.0.0.255");
GetItems().push_back(ln);
CGXDLMSSecuritySetup* ss = new CGXDLMSSecuritySetup("0.0.43.0.0.255");
ss->SetServerSystemTitle(GetCiphering()->GtSystemTitle());
GetItems().push_back(ss);
CGXDLMSData* d = new CGXDLMSData("0.0.43.1.0.255");
d->SetDataType(2, DLMS_DATA_TYPE_UINT32);
CGXDLMSVariant v = (unsigned short)100;
d->SetValue(v);
GetItems().push_back(d);
int ret;
//User list.
static gxUser USER_LIST[10] = { 0 };
//Dedicated key.
static unsigned char CYPHERING_INFO[20] = { 0 };
const unsigned char ln[6] = { 0, 0, 40, 0, 3, 255 };
if ((ret = INIT_OBJECT(highAssociation, DLMS_OBJECT_TYPE_ASSOCIATION_LOGICAL_NAME, ln)) == 0)
    highAssociation.authenticationMechanismName.mechanismId = DLMS_AUTHENTICATION_HIGH;
    OA_ATTACH(highAssociation.objectList, ALL_OBJECTS);
#ifndef DLMS_IGNORE_OBJECT_POINTERS
    highAssociation.securitySetup = &securitySetup;
#else
    memcpy(highAssociation.securitySetupReference, securitySetup.base.logicalName, 6);
#endif //DLMS_IGNORE_OBJECT_POINTERS
    BB_ATTACH(highAssociation.xDLMSContextInfo.cypheringInfo, CYPHERING_INFO, 0);
    //All objects are add for this Association View later.
    ARR_ATTACH(highAssociation.userList, USER_LIST, 0);
    highAssociation.clientSAP = 0x30;
    static char HLS_PASSWORD[20] = "Gurux";
    BB_ATTACH(highAssociation.secret, (unsigned char*)HLS_PASSWORD, (unsigned short)strlen(HLS_PASSWORD));
    cosem_init2(&frameCounterHigh.base, DLMS_OBJECT_TYPE_DATA, ln);
    var_setUInt32(&frameCounterHigh.value, 100);
Because there is no link from security setup to Invacation counter in the DLMS stadard it must update manually when client establish the connection.
  • Java
  • C#
  • ANSI C++
  • ANSI C
@Override
public final boolean isTarget(final int serverAddress, final int clientAddress) {
    //Update invocation counter.
    if (clientAddress == 1)
        getCiphering().setInvocationCounter(((Number) frameCounterHigh.getValue()).intValue());
    return true;
protected override bool IsTarget(int serverAddress, int clientAddress)
        Ciphering.InvocationCounter = Convert.ToUInt32(frameCounterHigh.Value);
    return true;
bool CGXDLMSBase::IsTarget(
    unsigned long int serverAddress,
    unsigned long clientAddress)
        GetCipher()->SetInvocationCounter(frameCounterHigh.GetValue().ToInteger());
    return true;
unsigned char svr_isTarget(
    dlmsSettings* settings,
    unsigned long serverAddress,
        settings->cipher.invocationCounter = frameCounterHigh.value.lVal;
Invocation counter is saved to the Flash, etc. memory after update. This can be done after the connection is closed. This debends from the used hardware, etc. There is no single solution for this.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv4 setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register activation
  • Register table
  • SAP assignment
  • Script table
  • Security setup
    • Invocation counter
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
