  3. GXNet To UdpClient
GXNet to UdpClient
By SgmUsr , 13 January, 2020
Gurux.Net
I'm using a GXNet library to make tcp and udp connections, I have problems with a udp connection:
How is it possible GXNet.Send has its attribute 'socket' (being socket a IDisposable type) as UdpClient type? because, if I call back Send method (from GXNet), I'm using GXNet object, not UdpClient object, so the attribute socket will be null.
How do I can pass UdpClient as GXNet?
  • Victorian | WA 083148835648
