  3. Did Not Receive AARE From Meter
Did not receive AARE from meter
By Bhaumik , 15 November, 2019
Gurux.Net
Currently, we are trying to access the Meter (IS15959) using IPv6.
We read that IPv6 address from Meter using the Serial interface, and then Connect using the TCP interface using the IPv6 address that we have got.
Now since we are not able to properly Disconnect from Serial Interface, the later TCP communication using IPv6, did not receive AARE from the meter. Can you please provide any feedback for this.
And which interface (HDLC/Wrapper/WirelessMBus) should be used for TCP communication?
following are the logs from GXDLMSDirector:
17:45:33 Initializing serial connection.
05:45:34 PM Send SNRM request.
7E A0 07 03 61 93 69 47 7E
<HDLC len="9" >
<TargetAddress Value="1" />
<SourceAddress Value="30" />
<FrameType Value="93" />
<Snrm>
</Snrm>
</HDLC>
05:45:34 PM
7E A0 20 61 03 73 05 9E 81 80 14 05 02 00 FA 06 02 00 FA 07 04 00 00 00 01 08 04 00 00 00 01 1C 5A 7E
<HDLC len="1F" >
<TargetAddress Value="30" />
<SourceAddress Value="1" />
<FrameType Value="73" />
<PDU>
<Ua>
<MaxInfoTX Value="250" />
<MaxInfoRX Value="250" />
<WindowSizeTX Value="1" />
<WindowSizeRX Value="1" />
</Ua>
</PDU>
</HDLC>
17:45:34 Parsing UA reply succeeded.
05:45:34 PM Send AARQ request.
7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 5A 45 4E 30 30 30 37 35 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 08 01 11 6B 1A 71 2A 10 2D 49 3F 24 54 4A 70 14 BE 23 04 21 21 1F 30 00 00 00 00 4B 1F 34 0A 3B 6D FC 5F 3B 73 E2 16 D6 38 1F 56 84 79 D0 83 EE 18 83 9B DC C8 01 8D 7E
<HDLC len="6A" >
<FrameType Value="10" />
<PDU>
<AssociationRequest>
<CallingAPTitle Value="5A454E3030303735" />
<MechanismName Value="High" />
<CallingAuthentication Value="0801116B1A712A102D493F24544A7014" />
<glo_InitiateRequest Value="30000000004B1F340A3B6DFC5F3B73E216D6381F568479D083EE18839BDCC8" />
</AssociationRequest>
</PDU>
</HDLC>
05:45:35 PM
7E A0 0F 61 03 30 30 D3 E6 E7 00 D8 01 06 83 37 7E
<HDLC len="E" >
<FrameType Value="30" />
<PDU>
<Data="0106" />
</PDU>
</HDLC>
Gurux.DLMS.GXDLMSException: Meter returns Service not allowed exception.
6 years 11 months ago
Because you can read data, your settings are correct. I'm travelling and I can check the release method on Monday.
Bhaumik
Following are the release request logs from GXDLMSDirector. Can you please check to provide an update.
03:39:48 PM Release request
7E A0 36 03 61 54 93 A5 E6 E6 00 62 28 80 01 00 BE 23 04 21 21 1F 30 00 00 00 82 5C ED FB 80 FA ED D3 EF 44 41 B2 87 EA 1D 5D 1B 89 24 EF E8 C9 F9 2E 0C 2D 52 64 69 7E
<HDLC len="35" >
<FrameType Value="54" />
<PDU>
<ReleaseRequest>
<Reason Value="Normal" />
<glo_InitiateRequest Value="30000000825CEDFB80FAEDD3EF4441B287EA1D5D1B8924EFE8C9F92E0C2D52" />
</ReleaseRequest>
</PDU>
</HDLC>
<HDLC len="35" >
<PDU>
<ReleaseRequest>
</ReleaseRequest>
</PDU>
</HDLC>
03:39:53 PM Data send failed. Try to resend 1/3
<HDLC len="35" >
<PDU>
<ReleaseRequest>
</ReleaseRequest>
</PDU>
</HDLC>
03:39:58 PM Data send failed. Try to resend 2/3
<HDLC len="35" >
<PDU>
<ReleaseRequest>
</ReleaseRequest>
</PDU>
</HDLC>
03:40:04 PM Data send failed. Try to resend 3/3
<HDLC len="35" >
<PDU>
<ReleaseRequest>
</ReleaseRequest>
</PDU>
</HDLC>
03:40:09 PM Failed to receive reply from the device in given time.
7E A0 36 01 03 74 CC 67 E6 E7 00 63 28 80 01 00 BE 23 04 21 28 1F 30 00 00 0A 10 4A F0 AC 3B 64 2E 78 D1 25 B4 9A C0 D4 8F 36 FC 34 57 DE DE DB 48 F3 9E 87 C6 CD C3 7E 7E A0 07 01 03 1F 50 EA 7E 7E A0 07 01 03 1F 50 EA 7E 7E A0 07 01 03 1F 50 EA 7E
<HDLC len="35" >
<TargetAddress Value="0" />
<FrameType Value="74" />
<PDU>
<ReleaseResponse>
<glo_InitiateResponse Value="3000000A104AF0AC3B642E78D125B49AC0D48F36FC3457DEDEDB48F39E87C6" />
</ReleaseResponse>
</PDU>
</HDLC>
<HDLC len="9" >
<FrameType Value="1F" />
<DisconnectMode>
</DisconnectMode>
</HDLC>
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
03:40:09 PM
<HDLC len="35" >
<PDU>
<ReleaseResponse>
</ReleaseResponse>
</PDU>
</HDLC>
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
15:40:09 Disconnect request
03:40:09 PM Disconnect request
7E A0 07 03 61 53 65 81 7E
<HDLC len="9" >
<FrameType Value="53" />
<DisconnectRequest>
</DisconnectRequest>
</HDLC>
03:40:14 PM Data send failed. Try to resend 1/3
<HDLC len="9" >
<DisconnectRequest>
</HDLC>
03:40:19 PM Data send failed. Try to resend 2/3
<HDLC len="9" >
<DisconnectRequest>
</HDLC>
03:40:24 PM Data send failed. Try to resend 3/3
<HDLC len="9" >
<DisconnectRequest>
</HDLC>
03:40:29 PM Failed to receive reply from the device in given time.
7E A0 07 01 03 1F 50 EA 7E 7E A0 07 01 03 1F 50 EA 7E 7E A0 07 01 03 1F 50 EA 7E 7E A0 07 01 03 1F 50 EA 7E
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
03:40:29 PM
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
<HDLC len="9" >
<DisconnectMode>
</DisconnectMode>
</HDLC>
KhushbuBadheka
In reply to Hi Mikko, by Bhaumik
Can you please count this in highest priority list?
Thanks.
We have made one change and testing it at the moment.
KhushbuBadheka
When will you plan to release this update?
Thanks.
Update to the latest version from GXDLMSSDirector. Try to connect and disconnect. If it fails select "Advanced" tab from device settings.
Check "Use protected release" and try to reconnect.
Bhaumik
We have performed the following scenarios with an updated GXDLMSDirector application.
Scenario 1:
Connect - Disconnect - Connect device without a selection of Use protected release.
Still, It is not able to disconnect properly. we need to perform power cycle of a device.
Scenario 2:
Connect - Disconnect - Connect device with a selection of Use protected release.
Scenario 3:
Connect - Disconnect device without a selection of Use protected release - Reconnect with a selection of use protected release.
In any case, we were unable to reconnect the device without performing power cycle.
Some IS15959 meters can't handle protected release. For this reason, we added this. Now it seems that release-service is not implemented at all for the meter.
You need to ask the meter manufacturer to implement that.
KhushbuBadheka
We have already asked to the meter manufacturer for the same. However, they are able to perform connection sequence which we require to execute using other vender's DLMS stack but we are not able to perform the same using GURUX DLMS stack.
Thanks.
Bhaumik
Following are the logs from Meter manufacturer in which multiple time connect - disconnect happened.
Can you please check and provide update.
16 : 35 : 47 METER-2 SENDING HDLC FRAME
16 : 35 : 47 ====>Tx METER-2 7E A0 0A 00 02 04 01 41 93 22 D0 7E
16 : 35 : 48 METER-2 RECEIVED HDLC FRAME
16 : 35 : 48 <====Rx METER-2 7E A0 23 41 00 02 04 01 73 A5 31 81 80 14 05 02 00 FA 06 02 00 FA 07 04 00 00 00 01 08 04 00 00 00 01 1C 5A 7E
16 : 35 : 48 METER-2 COSEM OUT DATA
16 : 35 : 48 ====>Tx METER-2 60 00 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 5A 45 4E 31 32 33 34 35 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A
80 08 5A 45 4E 53 4D 41 52 54 BE 34 04 32 21 30 30 00 00 00 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 F9 8D B1 FD 0B C3 33 49 DD 3F 43 E9
16 : 35 : 48 METER-2 COSEM OUT DATA - CIPHERED
16 : 35 : 48 ====>Tx METER-2 60 66 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 5A 45 4E 31 32 33 34 35 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A
80 08 5A 45 4E 53 4D 41 52 54 BE 34 04 32 21 30 30 00 00 00 78 69 F8 E1 7A 19 83 FF 2E 1C CD 33 60 FD 08 62 0A 74 51 4F
88 EE 2A C2 E9 A6 33 C9 0B 99 5A 07 F9 8D B1 FD 0B C3 33 49 DD 3F 43 E9
16 : 35 : 48 METER-2 SERVICE = AARQ
16 : 35 : 48 METER-2 SENDING HDLC FRAME
16 : 35 : 48 ====>Tx METER-2 7E A0 77 00 02 04 01 41 10 B2 59 E6 E6 00 60 66 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 5A 45 4E 31 32 33 34 35 8A
02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 5A 45 4E 53 4D 41 52 54 BE 34 04 32 21 30 30 00 00 00 78 69 F8 E1 7A 19
83 FF 2E 1C CD 33 60 FD 08 62 0A 74 51 4F 88 EE 2A C2 E9 A6 33 C9 0B 99 5A 07 F9 8D B1 FD 0B C3 33 49 DD 3F 43 E9 CB B4
7E
16 : 35 : 48 <====Rx METER-2 7E A0 59 41 00 02 04 01 30 21 B9 E6 E7 00 61 48 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4
0A 04 08 5A 45 4E 30 30 30 31 30 BE 23 04 21 28 1F 30 00 00 00 36 7B 15 8B B0 60 EE E3 C6 58 CA 26 A3 EF CD 33 D0 D1 6C
CB 77 CA 6A 35 6B 6A 74 A1 44 7E
16 : 35 : 48 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 35 : 48 <====Rx METER-2 61 48 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4 0A 04 08 5A 45 4E 30 30 30 31 30 BE 23 04
21 28 1F 30 00 00 00 36 08 00 06 5F 1F 04 00 00 10 14 01 F4 00 07 33 D0 D1 6C CB 77 CA 6A 35 6B 6A 74
21 28 1F 30 00 00 00 36 7B 15 8B B0 60 EE E3 C6 58 CA 26 A3 EF CD 33 D0 D1 6C CB 77 CA 6A 35 6B 6A 74
16 : 35 : 48 METER-2 SERVICE = AARE
16 : 35 : 48 ====>Tx METER-2 7E A0 0A 00 02 04 01 41 53 2E 16 7E
16 : 35 : 53 METER-2 SENDING HDLC FRAME
16 : 35 : 53 ====>Tx METER-2 7E A0 0A 00 02 04 01 41 93 22 D0 7E
16 : 35 : 53 METER-2 RECEIVED HDLC FRAME
16 : 35 : 53 <====Rx METER-2 7E A0 23 41 00 02 04 01 73 A5 31 81 80 14 05 02 00 FA 06 02 00 FA 07 04 00 00 00 01 08 04 00 00 00 01 1C 5A 7E
16 : 35 : 53 METER-2 COSEM OUT DATA
16 : 35 : 53 ====>Tx METER-2 60 00 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 5A 45 4E 31 32 33 34 35 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A
80 08 5A 45 4E 53 4D 41 52 54 BE 34 04 32 21 30 30 00 00 00 79 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 7F 27 44 93 07 6C 54 E9 F6 61 C2 66
16 : 35 : 53 METER-2 COSEM OUT DATA - CIPHERED
16 : 35 : 53 ====>Tx METER-2 60 66 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 5A 45 4E 31 32 33 34 35 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A
80 08 5A 45 4E 53 4D 41 52 54 BE 34 04 32 21 30 30 00 00 00 79 BD E4 3D BE F2 7A 22 F6 21 C8 47 40 3D E0 E5 FC 11 77 53
ED 11 F4 4A AD 2A 8F A1 35 E4 EA 34 7F 27 44 93 07 6C 54 E9 F6 61 C2 66
16 : 35 : 53 METER-2 SERVICE = AARQ
16 : 35 : 53 ====>Tx METER-2 7E A0 77 00 02 04 01 41 10 B2 59 E6 E6 00 60 66 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 5A 45 4E 31 32 33 34 35 8A
02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 5A 45 4E 53 4D 41 52 54 BE 34 04 32 21 30 30 00 00 00 79 BD E4 3D BE F2
7A 22 F6 21 C8 47 40 3D E0 E5 FC 11 77 53 ED 11 F4 4A AD 2A 8F A1 35 E4 EA 34 7F 27 44 93 07 6C 54 E9 F6 61 C2 66 BE B3
7E
16 : 35 : 54 <====Rx METER-2 7E A0 59 41 00 02 04 01 30 21 B9 E6 E7 00 61 48 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4
0A 04 08 5A 45 4E 30 30 30 31 30 BE 23 04 21 28 1F 30 00 00 00 37 98 80 5D 82 0B A5 05 C4 C5 CE 64 88 02 C6 9E 6D 0A 2B
68 D9 04 D8 19 2F 12 C4 0E 91 7E
16 : 35 : 54 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 35 : 54 <====Rx METER-2 61 48 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4 0A 04 08 5A 45 4E 30 30 30 31 30 BE 23 04
21 28 1F 30 00 00 00 37 08 00 06 5F 1F 04 00 00 10 14 01 F4 00 07 9E 6D 0A 2B 68 D9 04 D8 19 2F 12 C4
21 28 1F 30 00 00 00 37 98 80 5D 82 0B A5 05 C4 C5 CE 64 88 02 C6 9E 6D 0A 2B 68 D9 04 D8 19 2F 12 C4
16 : 35 : 54 METER-2 SERVICE = AARE
16 : 35 : 54 METER-2 COSEM OUT DATA
16 : 35 : 54 ====>Tx METER-2 D0 12 20 00 00 00 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00
16 : 35 : 54 METER-2 COSEM OUT DATA - CIPHERED
16 : 35 : 54 ====>Tx METER-2 D0 12 20 00 00 00 00 9D 3A F2 47 35 18 A7 0E 51 39 BE 87 A7
16 : 35 : 54 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-0-255, IC = 15, ATTR: INDEX = 2
16 : 35 : 54 METER-2 SENDING HDLC FRAME
16 : 35 : 54 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 00 9D 3A F2 47 35 18 A7 0E 51 39 BE 87 A7 73 92 7E
16 : 35 : 54 METER-2 RECEIVED HDLC FRAME
16 : 35 : 54 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 00 01 B1 13 A8 1E EF 75 60 91 C3 01 49 4C A6 FF A7 F6 18 AB
64 C0 45 00 95 0D 83 77 03 78 56 93 1F F4 60 6E 5C F6 66 4A 7A 5D FB EA 0E 85 5C 6F 7F 59 F5 8E 34 74 E4 E6 07 DE B5 63
7B 20 CD AE 40 03 23 CF 7C 4B 1D A1 C5 D9 BF D5 6A F3 B1 08 B6 6A 7B 63 CF B8 26 73 6F 5B 83 E0 59 D2 F7 C2 18 07 B1 20
CA AB 4F E7 A4 DB 97 A9 04 42 99 C2 E9 04 23 7B 34 36 5B EA 5A C0 48 14 74 92 C0 E0 AB 14 3A F6 AC 99 59 B4 80 F0 B7 90
83 F0 74 95 9C AB 76 26 75 0C 66 F8 5D FE 94 A2 00 4B 75 E6 2A 49 66 D0 EF CB 73 F4 91 AB E0 DF DA 05 07 59 A3 93 19 EF
62 FD 72 DB 33 CB 62 81 97 7A BB 45 0E 70 7D 3F A1 86 53 43 C8 9A 7F 8D 46 98 15 28 A7 C2 31 A8 1E 6C 90 6E A9 A4 3A 6F
B8 C5 17 0E 7F 92 44 83 4B 7E
16 : 35 : 54 <====Rx METER-2 D4 81 E6 20 00 00 00 01 B1 13 A8 1E EF 75 60 91 C3 01 49 4C A6 FF A7 F6 18 AB 64 C0 45 00 95 0D 83 77 03 78 56 93 1F F4
60 6E 5C F6 66 4A 7A 5D FB EA 0E 85 5C 6F 7F 59 F5 8E 34 74 E4 E6 07 DE B5 63 7B 20 CD AE 40 03 23 CF 7C 4B 1D A1 C5 D9
BF D5 6A F3 B1 08 B6 6A 7B 63 CF B8 26 73 6F 5B 83 E0 59 D2 F7 C2 18 07 B1 20 CA AB 4F E7 A4 DB 97 A9 04 42 99 C2 E9 04
23 7B 34 36 5B EA 5A C0 48 14 74 92 C0 E0 AB 14 3A F6 AC 99 59 B4 80 F0 B7 90 83 F0 74 95 9C AB 76 26 75 0C 66 F8 5D FE
94 A2 00 4B 75 E6 2A 49 66 D0 EF CB 73 F4 91 AB E0 DF DA 05 07 59 A3 93 19 EF 62 FD 72 DB 33 CB 62 81 97 7A BB 45 0E 70
7D 3F A1 86 53 43 C8 9A 7F 8D 46 98 15 28 A7 C2 31 A8 1E 6C 90 6E A9 A4 3A 6F B8 C5 17 0E 7F 92 44
16 : 35 : 54 <====Rx METER-2 D4 81 E6 20 00 00 00 01 C4 02 81 00 00 00 00 01 00 81 D6 01 81 9A 02 04 12 00 01 11 00 09 06 00 00 00 01 00 FF 02 02 01
02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 00 01 01 FF 02 02 01 02 02 03 0F 01
16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03
0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00
01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12
00 01 11 00 09 06 00 00 2B 01 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02
16 : 35 : 54 METER-2 SERVICE = GET RESPONSE
16 : 35 : 54 ====>Tx METER-2 D0 0C 20 00 00 00 01 C0 02 C1 00 00 00 01
16 : 35 : 54 ====>Tx METER-2 D0 0C 20 00 00 00 01 14 C2 9D 4D 32 F8 A8
16 : 35 : 54 METER-2 SERVICE = GET BLOCK REQUEST
16 : 35 : 54 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 00 01 14 C2 9D 4D 32 F8 A8 F1 89 7E
16 : 35 : 54 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 00 02 AB DC 09 95 0B 77 C1 C1 E4 0E FE B5 31 DE 55 1C FC 79
09 BA 84 78 81 93 59 10 81 E7 AD 8D BF 92 B7 17 29 3F 80 E0 A5 6F DF 87 69 1B 0E E6 16 20 0C EC 6E FB 43 99 EF A8 A8 03
F3 CF 6D E5 6A 5F C8 D1 8B 27 39 26 E9 58 AD 28 8A 7E A5 B6 25 82 DF FB 63 20 F4 2D 08 B4 BB D2 F8 87 3D 01 7C 9D 1D 75
DC B4 EF DD 21 96 DF 3D 17 C8 AF 11 C0 B5 96 95 2C 46 BA E5 3B 1F EE 46 71 37 B4 9F 57 6A 56 72 9D E9 19 6C BC 63 27 CC
5C 92 F3 3C D3 48 31 A8 1B 20 06 14 FD E1 F8 57 95 E8 B9 0C A2 E6 18 D6 9E 31 26 47 6B 7E 8A C7 F4 33 01 E0 E1 7F B7 C3
21 95 B2 1D 40 57 8E 17 9B F5 46 BA 72 BE C5 8E BC 11 5D F1 FA 30 F7 98 53 1E 52 6B 2D 74 CB 6B 2A 7D 32 F2 81 98 03 48
7E 99 82 9B C4 4C D1 81 B4 7E
16 : 35 : 54 <====Rx METER-2 D4 81 E6 20 00 00 00 02 AB DC 09 95 0B 77 C1 C1 E4 0E FE B5 31 DE 55 1C FC 79 09 BA 84 78 81 93 59 10 81 E7 AD 8D BF 92
B7 17 29 3F 80 E0 A5 6F DF 87 69 1B 0E E6 16 20 0C EC 6E FB 43 99 EF A8 A8 03 F3 CF 6D E5 6A 5F C8 D1 8B 27 39 26 E9 58
AD 28 8A 7E A5 B6 25 82 DF FB 63 20 F4 2D 08 B4 BB D2 F8 87 3D 01 7C 9D 1D 75 DC B4 EF DD 21 96 DF 3D 17 C8 AF 11 C0 B5
96 95 2C 46 BA E5 3B 1F EE 46 71 37 B4 9F 57 6A 56 72 9D E9 19 6C BC 63 27 CC 5C 92 F3 3C D3 48 31 A8 1B 20 06 14 FD E1
F8 57 95 E8 B9 0C A2 E6 18 D6 9E 31 26 47 6B 7E 8A C7 F4 33 01 E0 E1 7F B7 C3 21 95 B2 1D 40 57 8E 17 9B F5 46 BA 72 BE
C5 8E BC 11 5D F1 FA 30 F7 98 53 1E 52 6B 2D 74 CB 6B 2A 7D 32 F2 81 98 03 48 7E 99 82 9B C4 4C D1
16 : 35 : 54 <====Rx METER-2 D4 81 E6 20 00 00 00 02 C4 02 81 00 00 00 00 02 00 81 D6 04 12 00 01 11 00 09 06 00 00 2B 01 05 FF 02 02 01 02 02 03 0F
01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02
03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 5B 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01
00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 5B 09 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04
12 00 01 11 00 09 06 00 00 5E 5B 0B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00
09 06 00 00 5E 5B 0C FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01
16 : 35 : 54 ====>Tx METER-2 D0 0C 20 00 00 00 02 C0 02 C1 00 00 00 02
16 : 35 : 54 ====>Tx METER-2 D0 0C 20 00 00 00 02 93 03 16 8B 41 75 87
16 : 35 : 54 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 00 02 93 03 16 8B 41 75 87 7B 76 7E
16 : 35 : 55 METER-2 RECEIVED HDLC FRAME
16 : 35 : 55 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 00 03 ED 79 8A 1D A8 B1 8E D8 41 13 64 B4 67 57 25 C5 23 00
44 2D BA F9 52 9D FB 2B 4B F5 99 04 6F 7F E7 36 64 7E 45 22 1D C9 CB 60 45 6A A3 17 96 9C E9 52 F1 BD 66 B5 3F AA 97 DF
E5 49 B9 52 69 24 87 9D B9 11 55 AB DF 29 22 C7 19 32 C6 D5 0C B3 E3 46 A0 E6 AD 10 AA AB EA CF 2C 0C 32 E8 42 8C 5D 9A
A3 C5 E1 A7 9B 9A 5F 6D 54 BA 68 E4 34 32 E4 68 AA FB 54 8E 9D 86 A8 B3 DD D0 10 91 EC 62 3A CE 84 9F 2B 67 8E 7B FA 91
75 7D A9 22 1B 37 7F 26 7D 3B 6D 22 E2 4E 7C 49 78 83 CE 01 3B 3D 90 E1 69 B3 85 51 9C 8A 69 93 7F 1D 03 86 B9 D9 68 C9
71 E6 5A 93 AD 60 54 27 CA 73 7D 9D 9A 83 6C 18 FA EA 91 53 31 FC 88 68 59 F8 E9 41 79 8B 01 E7 87 64 3B F2 22 BB C5 AD
14 D3 CA AD 59 FB BD B2 D6 7E
16 : 35 : 55 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 35 : 55 <====Rx METER-2 D4 81 E6 20 00 00 00 03 ED 79 8A 1D A8 B1 8E D8 41 13 64 B4 67 57 25 C5 23 00 44 2D BA F9 52 9D FB 2B 4B F5 99 04 6F 7F
E7 36 64 7E 45 22 1D C9 CB 60 45 6A A3 17 96 9C E9 52 F1 BD 66 B5 3F AA 97 DF E5 49 B9 52 69 24 87 9D B9 11 55 AB DF 29
22 C7 19 32 C6 D5 0C B3 E3 46 A0 E6 AD 10 AA AB EA CF 2C 0C 32 E8 42 8C 5D 9A A3 C5 E1 A7 9B 9A 5F 6D 54 BA 68 E4 34 32
E4 68 AA FB 54 8E 9D 86 A8 B3 DD D0 10 91 EC 62 3A CE 84 9F 2B 67 8E 7B FA 91 75 7D A9 22 1B 37 7F 26 7D 3B 6D 22 E2 4E
7C 49 78 83 CE 01 3B 3D 90 E1 69 B3 85 51 9C 8A 69 93 7F 1D 03 86 B9 D9 68 C9 71 E6 5A 93 AD 60 54 27 CA 73 7D 9D 9A 83
6C 18 FA EA 91 53 31 FC 88 68 59 F8 E9 41 79 8B 01 E7 87 64 3B F2 22 BB C5 AD 14 D3 CA AD 59 FB BD
16 : 35 : 55 <====Rx METER-2 D4 81 E6 20 00 00 00 03 C4 02 81 00 00 00 00 03 00 81 D6 11 00 09 06 00 00 5E 5B 12 FF 02 02 01 02 02 03 0F 01 16 01 00
02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 5B 1A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16
01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 60 13 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02
04 12 00 01 11 00 09 06 00 00 5E 60 14 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11
00 09 06 00 00 5E 60 15 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00
5E 60 16 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06
16 : 35 : 55 METER-2 SERVICE = GET RESPONSE
16 : 35 : 55 METER-2 COSEM OUT DATA
16 : 35 : 55 ====>Tx METER-2 D0 0C 20 00 00 00 03 C0 02 C1 00 00 00 03
16 : 35 : 55 METER-2 COSEM OUT DATA - CIPHERED
16 : 35 : 55 ====>Tx METER-2 D0 0C 20 00 00 00 03 DA 24 A9 98 05 B7 BA
16 : 35 : 55 METER-2 SERVICE = GET BLOCK REQUEST
16 : 35 : 55 METER-2 SENDING HDLC FRAME
16 : 35 : 55 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 00 03 DA 24 A9 98 05 B7 BA 35 4C 7E
16 : 35 : 55 <====Rx METER-2 7E A0 F8 41 00 02 04 01 B8 2A CB E6 E7 00 D4 81 E6 20 00 00 00 04 9D B8 BF E8 C2 BA 51 5F 40 8D BF 6D 3C 60 46 9E 1D BB
7D 2A 0E 22 45 E8 89 AE C4 C1 72 C6 85 01 6A 2B BB 7E BE 60 91 1F 05 42 ED 74 B0 C2 68 9B 27 BB 69 B3 71 3B 60 A6 51 84
E4 D6 77 EB 5E E2 F2 A2 14 3C 1A BD 85 F3 A5 07 38 CC F3 8D 64 F2 78 18 6D DD 73 98 36 AE 40 07 A7 F1 A0 10 AC D9 14 F1
B8 3C FA CB 62 DD F2 55 FF 87 47 1C BB CA EC 86 82 4B 61 A5 2D 5F AA C9 26 7D 54 D8 00 F0 FB 12 68 F3 14 81 28 C2 99 46
9A 0F 7A 0A A3 A7 76 CA A2 05 CC DF 7D 9D 30 60 C0 8D 1E C3 34 C1 D4 F0 A2 96 B7 B5 AC 13 91 D6 7C 18 3A 20 22 10 19 C6
21 5C 56 42 B0 0A A8 29 1B D8 D7 6B 9A C5 0C EF 0A 44 DB CF 58 C4 9D 39 FB D5 CB 50 64 15 A7 54 4D 1F A7 94 80 84 DB 98
F6 D8 7A 57 9B 9D 08 1C 86 7E
16 : 35 : 55 <====Rx METER-2 D4 81 E6 20 00 00 00 04 9D B8 BF E8 C2 BA 51 5F 40 8D BF 6D 3C 60 46 9E 1D BB 7D 2A 0E 22 45 E8 89 AE C4 C1 72 C6 85 01
6A 2B BB 7E BE 60 91 1F 05 42 ED 74 B0 C2 68 9B 27 BB 69 B3 71 3B 60 A6 51 84 E4 D6 77 EB 5E E2 F2 A2 14 3C 1A BD 85 F3
A5 07 38 CC F3 8D 64 F2 78 18 6D DD 73 98 36 AE 40 07 A7 F1 A0 10 AC D9 14 F1 B8 3C FA CB 62 DD F2 55 FF 87 47 1C BB CA
EC 86 82 4B 61 A5 2D 5F AA C9 26 7D 54 D8 00 F0 FB 12 68 F3 14 81 28 C2 99 46 9A 0F 7A 0A A3 A7 76 CA A2 05 CC DF 7D 9D
30 60 C0 8D 1E C3 34 C1 D4 F0 A2 96 B7 B5 AC 13 91 D6 7C 18 3A 20 22 10 19 C6 21 5C 56 42 B0 0A A8 29 1B D8 D7 6B 9A C5
0C EF 0A 44 DB CF 58 C4 9D 39 FB D5 CB 50 64 15 A7 54 4D 1F A7 94 80 84 DB 98 F6 D8 7A 57 9B 9D 08
16 : 35 : 55 <====Rx METER-2 D4 81 E6 20 00 00 00 04 C4 02 81 00 00 00 00 04 00 81 D6 00 00 5E 60 17 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02
16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 60 18 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00
02 04 12 00 01 11 00 09 06 00 00 5E 60 19 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01
11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00
00 60 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 04 FF
02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 02
16 : 35 : 55 ====>Tx METER-2 D0 0C 20 00 00 00 04 C0 02 C1 00 00 00 04
16 : 35 : 55 ====>Tx METER-2 D0 0C 20 00 00 00 04 FA C6 5A 65 56 B5 FB
16 : 35 : 55 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 BA 30 1E E6 E6 00 D0 0C 20 00 00 00 04 FA C6 5A 65 56 B5 FB 89 4B 7E
16 : 35 : 55 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 00 05 00 C1 F8 96 A8 6C 84 CC B8 9C 11 4A 81 1C 60 B7 60 2F
59 96 87 5B 5B A8 B2 35 7F 1F 60 F3 5F 94 1A AD 6E 6D 23 13 9C ED 1C 94 C8 BC 93 38 20 74 35 9C 8E BF 44 32 15 8F B3 69
B5 E4 69 F2 A2 F7 E6 60 AD 40 DF 81 E2 A2 5A A8 06 01 DD A4 14 28 FE 67 C4 F1 E7 4E A1 C2 85 1D 59 0C E5 5D CB DC 15 83
AC A6 03 BA 47 99 E2 F7 1E F1 D6 B1 25 18 CE 49 02 F6 6C 84 22 93 41 CC AA C7 4F 8B 62 7D 7C D7 EA 0E C5 CE 4B 12 36 06
09 B5 14 08 8C 2F BB DD A2 01 F1 05 05 9A C8 0B 48 18 FB 3A 95 C4 9D B2 28 4F E8 B0 FF 2D 71 28 CA 73 85 DF D4 36 E4 C7
8B BF 06 0A 88 7F DA F2 72 DD 54 CF 86 95 E7 6F 51 01 3E BB 8D 87 4F 4E F9 B9 33 ED 90 19 77 6C 32 63 3E 5C 4E 1D 0F 02
C3 BA 3A CF 99 10 6A 01 EE 7E
16 : 35 : 55 <====Rx METER-2 D4 81 E6 20 00 00 00 05 00 C1 F8 96 A8 6C 84 CC B8 9C 11 4A 81 1C 60 B7 60 2F 59 96 87 5B 5B A8 B2 35 7F 1F 60 F3 5F 94
1A AD 6E 6D 23 13 9C ED 1C 94 C8 BC 93 38 20 74 35 9C 8E BF 44 32 15 8F B3 69 B5 E4 69 F2 A2 F7 E6 60 AD 40 DF 81 E2 A2
5A A8 06 01 DD A4 14 28 FE 67 C4 F1 E7 4E A1 C2 85 1D 59 0C E5 5D CB DC 15 83 AC A6 03 BA 47 99 E2 F7 1E F1 D6 B1 25 18
CE 49 02 F6 6C 84 22 93 41 CC AA C7 4F 8B 62 7D 7C D7 EA 0E C5 CE 4B 12 36 06 09 B5 14 08 8C 2F BB DD A2 01 F1 05 05 9A
C8 0B 48 18 FB 3A 95 C4 9D B2 28 4F E8 B0 FF 2D 71 28 CA 73 85 DF D4 36 E4 C7 8B BF 06 0A 88 7F DA F2 72 DD 54 CF 86 95
E7 6F 51 01 3E BB 8D 87 4F 4E F9 B9 33 ED 90 19 77 6C 32 63 3E 5C 4E 1D 0F 02 C3 BA 3A CF 99 10 6A
16 : 35 : 55 <====Rx METER-2 D4 81 E6 20 00 00 00 05 C4 02 81 00 00 00 00 05 00 81 D6 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01
00 02 04 12 00 01 11 00 09 06 00 00 60 07 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00
01 11 00 09 06 00 00 60 0B 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06
00 00 60 0B 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 02
FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 03 FF 02 02 01 02
02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 04 FF 02 02
16 : 35 : 56 ====>Tx METER-2 D0 0C 20 00 00 00 05 C0 02 C1 00 00 00 05
16 : 35 : 56 METER-2 COSEM OUT DATA - CIPHERED
16 : 35 : 56 ====>Tx METER-2 D0 0C 20 00 00 00 05 51 C5 4D 47 EF CD BA
16 : 35 : 56 METER-2 SERVICE = GET BLOCK REQUEST
16 : 35 : 56 METER-2 SENDING HDLC FRAME
16 : 35 : 56 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 00 05 51 C5 4D 47 EF CD BA 3B 1C 7E
16 : 35 : 56 METER-2 RECEIVED HDLC FRAME
16 : 35 : 56 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 00 06 6D ED 77 8F 63 91 53 D7 43 71 EE 96 07 B1 3D E3 8C 7E
F7 51 96 F1 0E 6D 29 1C 1A 88 CF F9 17 9C 69 3D 6F 38 82 D9 F7 26 B4 31 E4 20 1B E8 90 93 61 71 E6 D9 75 62 51 A0 E0 98
9C 53 45 95 5A 86 DE ED F3 B9 0E 0E 9C CD 8A 90 00 F7 91 E4 5B 34 85 AD E1 5B 77 C6 8D 86 88 60 20 26 A5 25 B4 0A B3 35
3D 5B 52 04 AE 0B 97 F8 D4 76 D0 FF 33 E1 B6 30 AB 1E A2 94 27 A1 3D 38 22 D3 43 11 39 FE AF DF 24 25 CA 04 3B 9A 67 22
5A E2 82 6C 56 D0 F6 8E 14 92 9E C1 A7 DB 4A B0 33 96 FD BE 08 24 F7 32 4A 8A 83 B3 CA 34 B3 D0 CC FB 5E 99 4A C9 1D B6
17 3F 17 57 EB 35 09 B3 C2 E2 B5 6E 60 51 4B A2 39 9C 26 92 10 B6 7F D4 F6 2A 26 ED 63 25 09 5A 2C 15 5F BC E7 20 0B 5C
1E 44 8F B4 E0 A4 0F 5C 61 7E
16 : 35 : 56 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 35 : 56 <====Rx METER-2 D4 81 E6 20 00 00 00 06 6D ED 77 8F 63 91 53 D7 43 71 EE 96 07 B1 3D E3 8C 7E F7 51 96 F1 0E 6D 29 1C 1A 88 CF F9 17 9C
69 3D 6F 38 82 D9 F7 26 B4 31 E4 20 1B E8 90 93 61 71 E6 D9 75 62 51 A0 E0 98 9C 53 45 95 5A 86 DE ED F3 B9 0E 0E 9C CD
8A 90 00 F7 91 E4 5B 34 85 AD E1 5B 77 C6 8D 86 88 60 20 26 A5 25 B4 0A B3 35 3D 5B 52 04 AE 0B 97 F8 D4 76 D0 FF 33 E1
B6 30 AB 1E A2 94 27 A1 3D 38 22 D3 43 11 39 FE AF DF 24 25 CA 04 3B 9A 67 22 5A E2 82 6C 56 D0 F6 8E 14 92 9E C1 A7 DB
4A B0 33 96 FD BE 08 24 F7 32 4A 8A 83 B3 CA 34 B3 D0 CC FB 5E 99 4A C9 1D B6 17 3F 17 57 EB 35 09 B3 C2 E2 B5 6E 60 51
4B A2 39 9C 26 92 10 B6 7F D4 F6 2A 26 ED 63 25 09 5A 2C 15 5F BC E7 20 0B 5C 1E 44 8F B4 E0 A4 0F
16 : 35 : 56 <====Rx METER-2 D4 81 E6 20 00 00 00 06 C4 02 81 00 00 00 00 06 00 81 D6 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12
00 01 11 00 09 06 00 00 60 0B 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09
06 00 00 60 0B 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 02
00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 02 FF 02 02 01
02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 02 FF 02 02 01 02 02 03 0F 01
16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 03 FF 02 02 01 02 02 03
16 : 35 : 56 METER-2 SERVICE = GET RESPONSE
16 : 35 : 56 ====>Tx METER-2 D0 0C 20 00 00 00 06 C0 02 C1 00 00 00 06
16 : 35 : 56 ====>Tx METER-2 D0 0C 20 00 00 00 06 DA A8 DD 8F 87 4F F6
16 : 35 : 56 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 00 06 DA A8 DD 8F 87 4F F6 95 C0 7E
16 : 35 : 56 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 00 07 AE 3B B8 EC D7 5C 94 AB 13 A7 78 37 72 C8 F4 1E 06 F9
82 57 78 4B 4C 37 AE 48 B7 62 5D 8B AF 08 72 DB 24 C3 79 20 C1 22 99 42 A8 0D EC 31 49 0C 3C 25 9B 09 60 26 46 D1 85 8F
6C 71 77 62 52 11 A4 0D F0 77 65 58 DE 22 EC 50 49 30 CE 4C 6A 4F 7A 5B D8 B5 4F 83 30 1D 2C AE 67 F9 8B 1A 60 3F 57 18
F0 AD D3 FD A3 6A 10 D1 F1 F1 88 6D 5A 8F 99 17 17 5A 8D BE 5C 20 4D 5B DE 11 ED D1 2F 01 64 A2 E4 97 0F 1F D4 94 64 3D
99 A2 EC 83 C8 34 82 F5 97 99 A7 39 35 B6 0C 31 67 D1 2A 71 2F FE F2 FF E3 34 B4 AB F4 57 F3 43 C1 26 55 32 65 DF D7 1F
17 20 1A 47 12 A4 C7 10 C7 AB F3 50 D6 5A 98 D3 E7 67 F4 81 45 B1 5B F0 E7 08 1A 59 99 7D 10 5F B8 2F F1 96 38 92 65 0A
9B B7 1B 6E B1 F8 A7 D9 B9 7E
16 : 35 : 56 <====Rx METER-2 D4 81 E6 20 00 00 00 07 AE 3B B8 EC D7 5C 94 AB 13 A7 78 37 72 C8 F4 1E 06 F9 82 57 78 4B 4C 37 AE 48 B7 62 5D 8B AF 08
72 DB 24 C3 79 20 C1 22 99 42 A8 0D EC 31 49 0C 3C 25 9B 09 60 26 46 D1 85 8F 6C 71 77 62 52 11 A4 0D F0 77 65 58 DE 22
EC 50 49 30 CE 4C 6A 4F 7A 5B D8 B5 4F 83 30 1D 2C AE 67 F9 8B 1A 60 3F 57 18 F0 AD D3 FD A3 6A 10 D1 F1 F1 88 6D 5A 8F
99 17 17 5A 8D BE 5C 20 4D 5B DE 11 ED D1 2F 01 64 A2 E4 97 0F 1F D4 94 64 3D 99 A2 EC 83 C8 34 82 F5 97 99 A7 39 35 B6
0C 31 67 D1 2A 71 2F FE F2 FF E3 34 B4 AB F4 57 F3 43 C1 26 55 32 65 DF D7 1F 17 20 1A 47 12 A4 C7 10 C7 AB F3 50 D6 5A
98 D3 E7 67 F4 81 45 B1 5B F0 E7 08 1A 59 99 7D 10 5F B8 2F F1 96 38 92 65 0A 9B B7 1B 6E B1 F8 A7
16 : 35 : 56 <====Rx METER-2 D4 81 E6 20 00 00 00 07 C4 02 81 00 00 00 00 07 00 81 D6 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00
09 06 01 00 00 08 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00
08 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 08 05 FF 02 02
01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 00 01 02 FF 02 02 01 03 02 03 0F
01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 5E 5B 08
FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16
16 : 35 : 56 ====>Tx METER-2 D0 0C 20 00 00 00 07 C0 02 C1 00 00 00 07
16 : 35 : 56 ====>Tx METER-2 D0 0C 20 00 00 00 07 A2 E7 DD E0 CD 2B 01
16 : 35 : 56 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 00 07 A2 E7 DD E0 CD 2B 01 C6 6E 7E
16 : 35 : 57 METER-2 RECEIVED HDLC FRAME
16 : 35 : 57 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 00 08 DA A8 EF AC 42 BD 9E 71 26 2C F1 3F 95 B8 80 42 B5 AB
C0 DE 26 42 03 8E C6 C1 89 EE 3B 9B 6A 22 D0 73 C4 10 B7 89 B8 8E 92 9E 06 C9 8B DD 7D F2 6E 19 F4 D5 C2 D8 7A F7 36 0F
FE 98 87 68 4D 81 FE 2C 0D 7D CB 9A 2E 9F 11 C3 99 97 80 2F 4E 13 DE EF AD 94 4E 04 BD FB 2D FA 0A AC DD FC DA 7B FD 38
61 6E F6 61 03 6D 56 CF 2F 46 30 46 F1 21 78 E4 D4 3D D1 8A 75 2C 91 A1 A7 AE 9C 6B FA 22 07 86 08 3A 33 2A 0F 4F 9B 75
2F 8F 1A E8 1E 1D 73 EF 1A 8F 60 37 BD 5B E2 1E 90 CC 19 68 1B 90 B6 D5 71 D2 2D 24 27 A2 65 68 FB 07 28 6D 21 3E 34 B7
96 ED 90 D7 40 94 25 97 28 FD 24 DC B4 02 4B D1 B7 3C 02 F6 41 A1 53 F3 BD 61 E0 BE D2 79 BE 20 EB 55 2F 9E 06 25 5B FD
37 03 96 B9 67 E0 71 4E CD 7E
16 : 35 : 57 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 35 : 57 <====Rx METER-2 D4 81 E6 20 00 00 00 08 DA A8 EF AC 42 BD 9E 71 26 2C F1 3F 95 B8 80 42 B5 AB C0 DE 26 42 03 8E C6 C1 89 EE 3B 9B 6A 22
D0 73 C4 10 B7 89 B8 8E 92 9E 06 C9 8B DD 7D F2 6E 19 F4 D5 C2 D8 7A F7 36 0F FE 98 87 68 4D 81 FE 2C 0D 7D CB 9A 2E 9F
11 C3 99 97 80 2F 4E 13 DE EF AD 94 4E 04 BD FB 2D FA 0A AC DD FC DA 7B FD 38 61 6E F6 61 03 6D 56 CF 2F 46 30 46 F1 21
78 E4 D4 3D D1 8A 75 2C 91 A1 A7 AE 9C 6B FA 22 07 86 08 3A 33 2A 0F 4F 9B 75 2F 8F 1A E8 1E 1D 73 EF 1A 8F 60 37 BD 5B
E2 1E 90 CC 19 68 1B 90 B6 D5 71 D2 2D 24 27 A2 65 68 FB 07 28 6D 21 3E 34 B7 96 ED 90 D7 40 94 25 97 28 FD 24 DC B4 02
4B D1 B7 3C 02 F6 41 A1 53 F3 BD 61 E0 BE D2 79 BE 20 EB 55 2F 9E 06 25 5B FD 37 03 96 B9 67 E0 71
16 : 35 : 57 <====Rx METER-2 D4 81 E6 20 00 00 00 08 C4 02 81 00 00 00 00 08 00 81 D6 00 02 04 12 00 03 11 00 09 06 00 00 5E 5B 0E FF 02 02 01 03 02
03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 5E
5B 0D FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00
03 11 00 09 06 01 00 01 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02
0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F
03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 FF 02 02 01 03 02 03
16 : 35 : 57 METER-2 SERVICE = GET RESPONSE
16 : 35 : 57 METER-2 COSEM OUT DATA
16 : 35 : 57 ====>Tx METER-2 D0 0C 20 00 00 00 08 C0 02 C1 00 00 00 08
16 : 35 : 57 METER-2 COSEM OUT DATA - CIPHERED
16 : 35 : 57 ====>Tx METER-2 D0 0C 20 00 00 00 08 9E 0A 5B C1 60 21 5B
16 : 35 : 57 METER-2 SERVICE = GET BLOCK REQUEST
16 : 35 : 57 METER-2 SENDING HDLC FRAME
16 : 35 : 57 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 00 08 9E 0A 5B C1 60 21 5B 4A DD 7E
16 : 35 : 57 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 00 09 35 01 79 74 F9 8D B5 E1 89 0C F5 E2 11 24 12 CC 6A 6C
F3 F6 E4 17 93 70 62 6D 86 B3 26 62 4B 6E 9C CC 90 00 EE A4 43 EE F3 FC 80 FB 64 2A A4 57 64 67 76 D3 6B 3E 5D 8F B3 68
E6 0E 16 98 FF B7 4F 17 F1 A5 8C 97 BC F7 B5 DE 20 14 95 15 78 AA 1F 54 A8 39 25 34 54 09 AF 68 A5 39 96 A1 32 25 14 3F
42 93 CC 65 32 11 51 7B 44 CE 7F 11 B1 D5 8C 80 4A 30 00 5A 1F AD 2C 1E 11 2A 59 BC 1A 54 BF AE A8 A3 7D 02 EC 3E DA 90
8C 23 9E EF CE 8F 50 F5 58 A5 35 86 4E 57 6C 61 AF 3A 05 40 B9 20 13 10 A6 D1 C1 D6 5D B2 4D C4 F8 DD F0 6D A8 E4 4A 87
A7 1F CA 9D 73 3B 94 2B 52 46 C3 73 E9 38 95 25 B7 7F 68 63 EF 2B 57 1B D7 E8 B1 8B 39 49 20 D1 F9 69 10 AC 54 CD 5B 08
72 0B C5 19 8C A6 8F 91 A8 7E
16 : 35 : 57 <====Rx METER-2 D4 81 E6 20 00 00 00 09 35 01 79 74 F9 8D B5 E1 89 0C F5 E2 11 24 12 CC 6A 6C F3 F6 E4 17 93 70 62 6D 86 B3 26 62 4B 6E
9C CC 90 00 EE A4 43 EE F3 FC 80 FB 64 2A A4 57 64 67 76 D3 6B 3E 5D 8F B3 68 E6 0E 16 98 FF B7 4F 17 F1 A5 8C 97 BC F7
B5 DE 20 14 95 15 78 AA 1F 54 A8 39 25 34 54 09 AF 68 A5 39 96 A1 32 25 14 3F 42 93 CC 65 32 11 51 7B 44 CE 7F 11 B1 D5
8C 80 4A 30 00 5A 1F AD 2C 1E 11 2A 59 BC 1A 54 BF AE A8 A3 7D 02 EC 3E DA 90 8C 23 9E EF CE 8F 50 F5 58 A5 35 86 4E 57
6C 61 AF 3A 05 40 B9 20 13 10 A6 D1 C1 D6 5D B2 4D C4 F8 DD F0 6D A8 E4 4A 87 A7 1F CA 9D 73 3B 94 2B 52 46 C3 73 E9 38
95 25 B7 7F 68 63 EF 2B 57 1B D7 E8 B1 8B 39 49 20 D1 F9 69 10 AC 54 CD 5B 08 72 0B C5 19 8C A6 8F
16 : 35 : 57 <====Rx METER-2 D4 81 E6 20 00 00 00 09 C4 02 81 00 00 00 00 09 00 81 D6 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01
02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02
03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00
02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 FF 02 02 01
03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01
00 02 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02
16 : 35 : 57 ====>Tx METER-2 D0 0C 20 00 00 00 09 C0 02 C1 00 00 00 09
16 : 35 : 57 ====>Tx METER-2 D0 0C 20 00 00 00 09 E6 D8 20 BD 91 7D E7
16 : 35 : 57 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 00 09 E6 D8 20 BD 91 7D E7 F6 92 7E
16 : 35 : 57 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 00 0A 44 11 46 CE 95 72 C8 C9 C3 0B 51 9C 5C C3 57 97 7D 74
0A CC 24 85 5E A7 BF A7 61 12 F6 C9 11 5E 57 61 41 33 D7 9D 9D 4A 3A DA D6 E9 6C C8 D7 E3 D6 09 6B B5 3C BE A8 3D 46 94
00 DB 83 19 3C 1B C7 9E CE 98 6E 84 40 4F D2 B9 5A 95 E5 26 C7 40 6E 72 05 BF 81 30 79 0B 55 D8 61 57 27 4E 19 66 48 5D
75 76 37 39 14 26 7E 28 C4 19 AD 08 08 8D 5D 0D 83 9E 22 92 42 F7 F2 D3 B2 2F 69 71 3D 5E B6 51 7D 78 87 E0 FB 57 F6 0B
3C A7 E3 E7 27 39 67 E6 F1 31 BA A5 F1 1F 78 03 D8 61 8D C9 E6 A7 03 48 67 0B FE BA 1C 47 98 41 9F 3A 23 12 B8 29 C3 A1
63 C8 03 B8 67 DD 1E 2B 28 30 91 49 D8 3C D5 EA 60 E2 96 7E A8 F0 50 47 91 E7 AF 26 80 CA 48 AE 99 C9 4F BA 42 8A FF 87
58 B6 AF 0B 5E 29 7B D0 D6 7E
16 : 35 : 57 <====Rx METER-2 D4 81 E6 20 00 00 00 0A 44 11 46 CE 95 72 C8 C9 C3 0B 51 9C 5C C3 57 97 7D 74 0A CC 24 85 5E A7 BF A7 61 12 F6 C9 11 5E
57 61 41 33 D7 9D 9D 4A 3A DA D6 E9 6C C8 D7 E3 D6 09 6B B5 3C BE A8 3D 46 94 00 DB 83 19 3C 1B C7 9E CE 98 6E 84 40 4F
D2 B9 5A 95 E5 26 C7 40 6E 72 05 BF 81 30 79 0B 55 D8 61 57 27 4E 19 66 48 5D 75 76 37 39 14 26 7E 28 C4 19 AD 08 08 8D
5D 0D 83 9E 22 92 42 F7 F2 D3 B2 2F 69 71 3D 5E B6 51 7D 78 87 E0 FB 57 F6 0B 3C A7 E3 E7 27 39 67 E6 F1 31 BA A5 F1 1F
78 03 D8 61 8D C9 E6 A7 03 48 67 0B FE BA 1C 47 98 41 9F 3A 23 12 B8 29 C3 A1 63 C8 03 B8 67 DD 1E 2B 28 30 91 49 D8 3C
D5 EA 60 E2 96 7E A8 F0 50 47 91 E7 AF 26 80 CA 48 AE 99 C9 4F BA 42 8A FF 87 58 B6 AF 0B 5E 29 7B
16 : 35 : 57 <====Rx METER-2 D4 81 E6 20 00 00 00 0A C4 02 81 00 00 00 00 0A 00 81 D6 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 FF 02
02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09
06 01 00 02 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00
02 04 12 00 03 11 00 09 06 01 00 02 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00
01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01
00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 07 00 FF 02 02
16 : 35 : 58 ====>Tx METER-2 D0 0C 20 00 00 00 0A C0 02 C1 00 00 00 0A
16 : 35 : 58 METER-2 COSEM OUT DATA - CIPHERED
16 : 35 : 58 ====>Tx METER-2 D0 0C 20 00 00 00 0A 29 23 1E 9F F4 27 D5
16 : 35 : 58 METER-2 SERVICE = GET BLOCK REQUEST
16 : 35 : 58 METER-2 SENDING HDLC FRAME
16 : 35 : 58 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 00 0A 29 23 1E 9F F4 27 D5 E5 AE 7E
16 : 35 : 58 METER-2 RECEIVED HDLC FRAME
16 : 35 : 58 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 00 0B AC 27 DE 7D 75 E7 4D 59 7F 6E CF 98 49 0D 7A 01 EA 22
2F FB 88 4C 95 33 13 A0 50 31 0E 2D FF 93 95 A9 1D 89 FE FB A2 70 73 B0 9D D2 14 F3 59 01 80 06 5D 79 93 A0 3B 75 0D E7
62 40 5D 30 62 25 6C E5 BC 53 37 7B BA 04 14 72 7C 30 B6 E3 F5 F3 53 D2 5D 5C 71 89 6C E6 5D D9 79 E4 C1 3A 78 48 28 06
A1 B0 63 73 38 43 8C 92 99 00 95 CF 5B DB 92 51 88 A9 C4 E2 55 63 A2 88 5B A1 08 AF BA 25 5F 3E 76 56 F5 85 3C 43 61 E5
9B 90 24 F8 5C B0 06 C3 C9 16 1B FB 1A BA C3 76 F9 77 4E 0B 80 CC D8 9F 06 C9 77 E5 D0 13 93 67 5F 03 E7 17 83 40 F5 ED
C4 A5 D3 8A 85 57 4D 34 98 BB A3 AB 60 D2 2F 46 9F 5E F6 8A 66 49 C4 0B 80 89 98 31 F6 74 DB 46 A6 7C A0 0B 7D 15 E1 CA
7D BA FB 8B 89 C1 BC A1 93 7E
16 : 35 : 58 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 35 : 58 <====Rx METER-2 D4 81 E6 20 00 00 00 0B AC 27 DE 7D 75 E7 4D 59 7F 6E CF 98 49 0D 7A 01 EA 22 2F FB 88 4C 95 33 13 A0 50 31 0E 2D FF 93
95 A9 1D 89 FE FB A2 70 73 B0 9D D2 14 F3 59 01 80 06 5D 79 93 A0 3B 75 0D E7 62 40 5D 30 62 25 6C E5 BC 53 37 7B BA 04
14 72 7C 30 B6 E3 F5 F3 53 D2 5D 5C 71 89 6C E6 5D D9 79 E4 C1 3A 78 48 28 06 A1 B0 63 73 38 43 8C 92 99 00 95 CF 5B DB
92 51 88 A9 C4 E2 55 63 A2 88 5B A1 08 AF BA 25 5F 3E 76 56 F5 85 3C 43 61 E5 9B 90 24 F8 5C B0 06 C3 C9 16 1B FB 1A BA
C3 76 F9 77 4E 0B 80 CC D8 9F 06 C9 77 E5 D0 13 93 67 5F 03 E7 17 83 40 F5 ED C4 A5 D3 8A 85 57 4D 34 98 BB A3 AB 60 D2
2F 46 9F 5E F6 8A 66 49 C4 0B 80 89 98 31 F6 74 DB 46 A6 7C A0 0B 7D 15 E1 CA 7D BA FB 8B 89 C1 BC
16 : 35 : 58 <====Rx METER-2 D4 81 E6 20 00 00 00 0B C4 02 81 00 00 00 00 0B 00 81 D6 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16
01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02
16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 FF 02 02 01 03 02 03 0F
01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 07 00
FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11
00 09 06 01 00 09 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01
16 : 35 : 58 METER-2 SERVICE = GET RESPONSE
16 : 35 : 58 ====>Tx METER-2 D0 0C 20 00 00 00 0B C0 02 C1 00 00 00 0B
16 : 35 : 58 ====>Tx METER-2 D0 0C 20 00 00 00 0B C1 7D 7B 4D 38 FE C0
16 : 35 : 58 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 00 0B C1 7D 7B 4D 38 FE C0 32 8C 7E
16 : 35 : 58 <====Rx METER-2 7E A0 F8 41 00 02 04 01 B8 2A CB E6 E7 00 D4 81 E6 20 00 00 00 0C 53 0B 98 70 F9 D7 27 E8 4B 52 9E 54 C1 66 B7 C6 72 C3
89 9B D8 06 49 25 AE 68 9D 3D 82 09 E6 3F 87 F6 C0 B5 E4 D5 41 1C 4F 94 3F FC FE 19 75 04 38 16 D8 F8 13 C9 AC 51 D2 39
A8 07 D5 02 76 FB 52 52 31 31 07 99 5C 7A 99 90 D3 28 23 2A F3 11 9F 28 D5 1E 82 FB 72 7E 3E B2 DF B7 35 46 6E D2 CB D5
03 81 D0 A9 9D 35 C9 F3 62 BC C0 A8 B3 7F 00 59 CC C7 46 3F 80 E5 83 34 26 F7 8C 89 38 DF 3F C7 90 99 E1 9C 27 B8 05 40
BA AA 4C 90 93 7C 10 24 DB 68 E4 22 58 6E DD A7 07 D2 3F 66 90 EB 0D 21 73 78 D2 79 E8 8E FF DC F8 39 CE 0B 0C 3B 2B F3
B9 03 68 C5 91 A6 FC 1A A1 C3 EF B7 A9 01 AD 62 4E A4 4B E9 78 25 C5 E9 EA AB 2D D7 EC 84 2A 01 45 BF 0C 5D A6 BF BE C4
8E 4B E7 57 E8 36 7F 7A D1 7E
16 : 35 : 58 <====Rx METER-2 D4 81 E6 20 00 00 00 0C 53 0B 98 70 F9 D7 27 E8 4B 52 9E 54 C1 66 B7 C6 72 C3 89 9B D8 06 49 25 AE 68 9D 3D 82 09 E6 3F
87 F6 C0 B5 E4 D5 41 1C 4F 94 3F FC FE 19 75 04 38 16 D8 F8 13 C9 AC 51 D2 39 A8 07 D5 02 76 FB 52 52 31 31 07 99 5C 7A
99 90 D3 28 23 2A F3 11 9F 28 D5 1E 82 FB 72 7E 3E B2 DF B7 35 46 6E D2 CB D5 03 81 D0 A9 9D 35 C9 F3 62 BC C0 A8 B3 7F
00 59 CC C7 46 3F 80 E5 83 34 26 F7 8C 89 38 DF 3F C7 90 99 E1 9C 27 B8 05 40 BA AA 4C 90 93 7C 10 24 DB 68 E4 22 58 6E
DD A7 07 D2 3F 66 90 EB 0D 21 73 78 D2 79 E8 8E FF DC F8 39 CE 0B 0C 3B 2B F3 B9 03 68 C5 91 A6 FC 1A A1 C3 EF B7 A9 01
AD 62 4E A4 4B E9 78 25 C5 E9 EA AB 2D D7 EC 84 2A 01 45 BF 0C 5D A6 BF BE C4 8E 4B E7 57 E8 36 7F
16 : 35 : 58 <====Rx METER-2 D4 81 E6 20 00 00 00 0C C4 02 81 00 00 00 00 0C 00 81 D6 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09
08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00
03 11 00 09 06 01 00 09 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02
0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F
03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03
0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08
16 : 35 : 58 ====>Tx METER-2 D0 0C 20 00 00 00 0C C0 02 C1 00 00 00 0C
16 : 35 : 58 ====>Tx METER-2 D0 0C 20 00 00 00 0C CB 39 73 DD 93 22 C4
16 : 35 : 58 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 BA 30 1E E6 E6 00 D0 0C 20 00 00 00 0C CB 39 73 DD 93 22 C4 37 C9 7E
16 : 35 : 59 METER-2 RECEIVED HDLC FRAME
16 : 35 : 59 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 00 0D 2C 34 CF CC A9 E9 DB D4 46 C3 31 62 93 85 FD E1 E5 B3
71 AB 8B 2C 01 F8 74 0E AF 3F 07 DA 3D 6B 4B FD 12 B5 DB 43 EF CA EE 1A B7 D3 D9 53 58 15 19 9A 5B 96 98 05 A9 55 11 D2
CE 78 69 5D F0 43 72 94 2A 5F 8A 7C 28 FE 01 9D F0 6E 4F F3 BE 4F 78 17 C5 62 61 B2 C4 AD 1C 15 F6 10 48 1C 33 88 28 3E
00 C8 F1 05 C7 CB 65 C8 19 37 1E 42 18 B0 73 EE EC 5C C9 33 E5 F9 98 BC 16 C9 0A 9A 92 D4 1C F0 9F C1 03 D2 D3 A4 46 07
FF F4 CD 39 1F 42 42 3E D3 03 F4 6A DA 73 AF C9 45 77 28 EA BA 5F 69 13 21 DD 58 AF EB 34 65 DF 88 F4 90 0D E5 F6 37 A1
45 E4 74 41 FB 36 04 C4 71 1C B5 55 BD 46 62 10 4D 84 A8 90 2B 8F 6B B4 12 66 5B 0E DB CF C7 2E 98 D7 31 47 35 E2 D4 95
5A A7 0C D6 B5 7A A1 D1 36 7E
16 : 35 : 59 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 35 : 59 <====Rx METER-2 D4 81 E6 20 00 00 00 0D 2C 34 CF CC A9 E9 DB D4 46 C3 31 62 93 85 FD E1 E5 B3 71 AB 8B 2C 01 F8 74 0E AF 3F 07 DA 3D 6B
4B FD 12 B5 DB 43 EF CA EE 1A B7 D3 D9 53 58 15 19 9A 5B 96 98 05 A9 55 11 D2 CE 78 69 5D F0 43 72 94 2A 5F 8A 7C 28 FE
01 9D F0 6E 4F F3 BE 4F 78 17 C5 62 61 B2 C4 AD 1C 15 F6 10 48 1C 33 88 28 3E 00 C8 F1 05 C7 CB 65 C8 19 37 1E 42 18 B0
73 EE EC 5C C9 33 E5 F9 98 BC 16 C9 0A 9A 92 D4 1C F0 9F C1 03 D2 D3 A4 46 07 FF F4 CD 39 1F 42 42 3E D3 03 F4 6A DA 73
AF C9 45 77 28 EA BA 5F 69 13 21 DD 58 AF EB 34 65 DF 88 F4 90 0D E5 F6 37 A1 45 E4 74 41 FB 36 04 C4 71 1C B5 55 BD 46
62 10 4D 84 A8 90 2B 8F 6B B4 12 66 5B 0E DB CF C7 2E 98 D7 31 47 35 E2 D4 95 5A A7 0C D6 B5 7A A1
16 : 35 : 59 <====Rx METER-2 D4 81 E6 20 00 00 00 0D C4 02 81 00 00 00 00 0D 00 81 D6 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02
03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00
02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 FF 02 02 01
00 0A 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04
12 00 03 11 00 09 06 01 00 0A 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03
16 : 35 : 59 METER-2 SERVICE = GET RESPONSE
16 : 35 : 59 METER-2 COSEM OUT DATA
16 : 35 : 59 ====>Tx METER-2 D0 0C 20 00 00 00 0D C0 02 C1 00 00 00 0D
16 : 35 : 59 METER-2 COSEM OUT DATA - CIPHERED
16 : 35 : 59 ====>Tx METER-2 D0 0C 20 00 00 00 0D FA F5 89 4B 51 D4 1A
16 : 35 : 59 METER-2 SERVICE = GET BLOCK REQUEST
16 : 35 : 59 METER-2 SENDING HDLC FRAME
16 : 35 : 59 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 00 0D FA F5 89 4B 51 D4 1A C2 E9 7E
16 : 35 : 59 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 00 0E A3 3C 6A D6 DB A8 1E AA A6 1A 46 98 F3 7D 0B 58 05 44
08 67 5E B2 35 D5 AF 4E 32 F6 00 AF E4 6B 0C 5B 9D AA 1E 71 20 39 76 AA D8 F4 3D 0D FB E0 10 C8 80 04 ED 48 71 F6 36 55
34 03 05 EB 7C DE AC CD 2C 94 46 88 FA 8F 40 24 ED 8A 2E A9 B1 5F EF 6E 9D 9C 20 A7 A3 0F B0 DF 16 E2 1F 7F 79 FD 07 7D
78 B7 AC 6A 24 A9 07 AA 67 18 E3 CB DF 45 C2 62 9A CF 13 C6 6B 1F 48 28 B3 3B 4D D0 2B 7F 88 92 B7 8F 97 CD BB 92 56 58
FB FD 8C 47 F0 31 9B 3B E4 BB 2D 5C 71 73 3F 92 12 C5 9C 41 8C E0 6C 96 2B A1 87 0D 4D 46 0A 62 FF DF F5 D0 04 CC 73 04
4B A2 23 FE A0 09 EE 48 BD 99 96 7E 35 1E 2C 09 ED 4B BA EF AF D8 1A 4F D8 7F EE 69 58 C8 3F 0D 99 F9 FA 3E A9 8B FE 63
B1 AF F1 7C A4 41 2B D6 0A 7E
16 : 35 : 59 <====Rx METER-2 D4 81 E6 20 00 00 00 0E A3 3C 6A D6 DB A8 1E AA A6 1A 46 98 F3 7D 0B 58 05 44 08 67 5E B2 35 D5 AF 4E 32 F6 00 AF E4 6B
0C 5B 9D AA 1E 71 20 39 76 AA D8 F4 3D 0D FB E0 10 C8 80 04 ED 48 71 F6 36 55 34 03 05 EB 7C DE AC CD 2C 94 46 88 FA 8F
40 24 ED 8A 2E A9 B1 5F EF 6E 9D 9C 20 A7 A3 0F B0 DF 16 E2 1F 7F 79 FD 07 7D 78 B7 AC 6A 24 A9 07 AA 67 18 E3 CB DF 45
C2 62 9A CF 13 C6 6B 1F 48 28 B3 3B 4D D0 2B 7F 88 92 B7 8F 97 CD BB 92 56 58 FB FD 8C 47 F0 31 9B 3B E4 BB 2D 5C 71 73
3F 92 12 C5 9C 41 8C E0 6C 96 2B A1 87 0D 4D 46 0A 62 FF DF F5 D0 04 CC 73 04 4B A2 23 FE A0 09 EE 48 BD 99 96 7E 35 1E
2C 09 ED 4B BA EF AF D8 1A 4F D8 7F EE 69 58 C8 3F 0D 99 F9 FA 3E A9 8B FE 63 B1 AF F1 7C A4 41 2B
16 : 35 : 59 <====Rx METER-2 D4 81 E6 20 00 00 00 0E C4 02 81 00 00 00 00 0E 00 81 D6 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09
06 01 00 0B 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00
02 04 12 00 03 11 00 09 06 01 00 0C 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00
01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01
00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0E 07 00 FF 02 02 01 03 02 03 0F 01 16
16 : 35 : 59 ====>Tx METER-2 D0 0C 20 00 00 00 0E C0 02 C1 00 00 00 0E
16 : 35 : 59 ====>Tx METER-2 D0 0C 20 00 00 00 0E 15 2F 0A 10 4B E8 66
16 : 35 : 59 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 00 0E 15 2F 0A 10 4B E8 66 2F E6 7E
16 : 35 : 59 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 00 0F EE 3E 41 89 6E 66 3D 15 04 A8 32 1A 69 08 15 C0 D6 3B
00 F7 E3 5B 4E 9C 52 24 30 B5 6E 4D B6 3F 41 F0 DD 95 EB D7 4B 07 EE 0B 67 1F 9F 81 4D 0B A8 1A DD 48 7C E5 45 8F A0 19
73 2D E0 6E 92 97 0C 50 A0 55 C7 2E 16 B3 85 F4 7A 4C C8 E1 3B A7 7E C6 0E 89 90 F6 5E 61 01 C9 09 84 6A 60 0A CA C8 92
8A 45 24 A2 68 FE 53 43 94 3F DE 3E DB 02 AC 2B 74 CF F4 B4 AC 02 5A FC 9A 5C 10 71 19 4A D1 4B 12 2A B9 FE E6 DB ED BF
94 EC 87 B4 EE CD BB 56 0B 27 48 B1 2A 12 02 C9 4E 23 BC 4A 1C F9 B3 6A AC 7B CB 8E 37 F2 6A 26 A8 0F D7 05 3F 7F 3C 31
A3 49 B7 A1 3E 9A 3A EA 7D B3 8C A2 B6 F2 CF D7 EB 2E 91 C4 3E 6D 49 35 55 1D 51 2C B2 60 0C 55 E6 CC 4D 03 18 E1 43 34
A1 B1 AF BA 90 47 71 33 86 7E
16 : 35 : 59 <====Rx METER-2 D4 81 E6 20 00 00 00 0F EE 3E 41 89 6E 66 3D 15 04 A8 32 1A 69 08 15 C0 D6 3B 00 F7 E3 5B 4E 9C 52 24 30 B5 6E 4D B6 3F
41 F0 DD 95 EB D7 4B 07 EE 0B 67 1F 9F 81 4D 0B A8 1A DD 48 7C E5 45 8F A0 19 73 2D E0 6E 92 97 0C 50 A0 55 C7 2E 16 B3
85 F4 7A 4C C8 E1 3B A7 7E C6 0E 89 90 F6 5E 61 01 C9 09 84 6A 60 0A CA C8 92 8A 45 24 A2 68 FE 53 43 94 3F DE 3E DB 02
AC 2B 74 CF F4 B4 AC 02 5A FC 9A 5C 10 71 19 4A D1 4B 12 2A B9 FE E6 DB ED BF 94 EC 87 B4 EE CD BB 56 0B 27 48 B1 2A 12
02 C9 4E 23 BC 4A 1C F9 B3 6A AC 7B CB 8E 37 F2 6A 26 A8 0F D7 05 3F 7F 3C 31 A3 49 B7 A1 3E 9A 3A EA 7D B3 8C A2 B6 F2
CF D7 EB 2E 91 C4 3E 6D 49 35 55 1D 51 2C B2 60 0C 55 E6 CC 4D 03 18 E1 43 34 A1 B1 AF BA 90 47 71
16 : 35 : 59 <====Rx METER-2 D4 81 E6 20 00 00 00 0F C4 02 81 00 00 00 00 0F 00 81 D6 01 00 5B 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02
16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 FF 02 02 01 05 02 03 0F
01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00
02 04 12 00 04 11 00 09 06 01 00 01 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00
02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 FF 02 02 01
05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05
16 : 36 : 00 ====>Tx METER-2 D0 0C 20 00 00 00 0F C0 02 C1 00 00 00 0F
16 : 36 : 00 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 00 ====>Tx METER-2 D0 0C 20 00 00 00 0F 17 B1 0B BD 45 A0 50
16 : 36 : 00 METER-2 SERVICE = GET BLOCK REQUEST
16 : 36 : 00 METER-2 SENDING HDLC FRAME
16 : 36 : 00 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 00 0F 17 B1 0B BD 45 A0 50 65 C0 7E
16 : 36 : 00 METER-2 RECEIVED HDLC FRAME
16 : 36 : 00 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 00 10 34 79 B2 29 9D AC 55 06 AC 59 D7 CE 20 A0 B3 92 A8 D4
4E 49 F4 24 2A A6 38 FE 8F 68 09 FD 5B DE 24 5B B3 33 96 CA 6F 64 65 23 89 21 0B 85 01 2C 83 A6 62 12 5A 82 BE 39 A4 E4
6B 72 42 32 E5 41 5B 53 52 CB 47 CF 95 0A 44 03 6F 12 D3 AB 27 6D A3 0B 97 3C C8 CA E6 3E BC 9B 03 3B 04 44 E8 D2 BA 39
37 C6 3D BF E8 32 F2 50 06 8E 41 81 F6 17 F9 B0 5D 84 50 46 E7 93 2C 90 EC B6 AF 73 CA 7D 22 2A D0 24 92 C4 37 44 88 30
62 FF A1 54 97 68 98 5A E0 69 59 0B 6D 89 87 18 9E 44 F0 32 95 B8 E0 85 43 C6 00 89 4F 15 DB B4 CD 33 9A 03 1C EC 73 FE
3A FE 30 4F 0B A5 D7 35 E8 0C FD 5D D6 2A A0 77 F4 F3 EF A3 0C B1 F5 26 0A 81 1A DB 7B 97 2B 62 02 4B 0C 94 79 2E 59 6F
5B B8 88 5A 45 94 BB FC FF 7E
16 : 36 : 00 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 00 <====Rx METER-2 D4 81 E6 20 00 00 00 10 34 79 B2 29 9D AC 55 06 AC 59 D7 CE 20 A0 B3 92 A8 D4 4E 49 F4 24 2A A6 38 FE 8F 68 09 FD 5B DE
24 5B B3 33 96 CA 6F 64 65 23 89 21 0B 85 01 2C 83 A6 62 12 5A 82 BE 39 A4 E4 6B 72 42 32 E5 41 5B 53 52 CB 47 CF 95 0A
44 03 6F 12 D3 AB 27 6D A3 0B 97 3C C8 CA E6 3E BC 9B 03 3B 04 44 E8 D2 BA 39 37 C6 3D BF E8 32 F2 50 06 8E 41 81 F6 17
F9 B0 5D 84 50 46 E7 93 2C 90 EC B6 AF 73 CA 7D 22 2A D0 24 92 C4 37 44 88 30 62 FF A1 54 97 68 98 5A E0 69 59 0B 6D 89
87 18 9E 44 F0 32 95 B8 E0 85 43 C6 00 89 4F 15 DB B4 CD 33 9A 03 1C EC 73 FE 3A FE 30 4F 0B A5 D7 35 E8 0C FD 5D D6 2A
A0 77 F4 F3 EF A3 0C B1 F5 26 0A 81 1A DB 7B 97 2B 62 02 4B 0C 94 79 2E 59 6F 5B B8 88 5A 45 94 BB
16 : 36 : 00 <====Rx METER-2 D4 81 E6 20 00 00 00 10 C4 02 81 00 00 00 00 10 00 81 D6 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01
00 01 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F
05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03
0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11
00 09 06 01 00 02 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01
00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 FF 02 02
16 : 36 : 00 METER-2 SERVICE = GET RESPONSE
16 : 36 : 00 ====>Tx METER-2 D0 0C 20 00 00 00 10 C0 02 C1 00 00 00 10
16 : 36 : 00 ====>Tx METER-2 D0 0C 20 00 00 00 10 8E E8 D1 02 97 9D EC
16 : 36 : 00 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 00 10 8E E8 D1 02 97 9D EC 20 1E 7E
16 : 36 : 00 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 00 11 15 88 2A DF C3 1D 41 76 19 B5 9B B4 63 76 CA 5C CA 85
AC C2 28 19 61 16 75 FD 7B 72 04 02 73 12 55 80 81 79 07 41 57 9E 02 48 87 C9 CE 93 4F FF 3B 10 65 72 95 2B 69 95 40 7B
69 8B 55 8B 65 14 9D B2 44 2F A8 07 56 99 E4 69 96 07 88 39 79 95 17 47 B5 D2 5A 09 F7 FE B7 25 71 B0 19 E4 07 1B DC F3
60 C0 53 DB 54 A0 A8 1F 14 4E 86 5D 13 65 A4 BA 0A C6 10 F3 FA 4A B0 45 1B 2C 61 F7 25 AB DE 4A 28 51 27 E4 2D 05 20 B1
7C BF E1 25 79 AA 59 60 EE 0C CC F9 1A 97 5A F0 76 C3 84 B5 F6 93 EC 00 8C E0 C5 BC 09 9D 0B 11 7F 45 FE B9 C1 63 73 55
45 06 5D BD 96 B5 89 B6 81 56 74 50 E9 51 4A 4B 70 AB 23 F3 06 21 9A ED 34 FA FE 5F 06 F9 85 55 2A 56 D0 CD F7 D9 2E 8A
14 CA 28 BB 48 F4 8B 50 B6 7E
16 : 36 : 00 <====Rx METER-2 D4 81 E6 20 00 00 00 11 15 88 2A DF C3 1D 41 76 19 B5 9B B4 63 76 CA 5C CA 85 AC C2 28 19 61 16 75 FD 7B 72 04 02 73 12
55 80 81 79 07 41 57 9E 02 48 87 C9 CE 93 4F FF 3B 10 65 72 95 2B 69 95 40 7B 69 8B 55 8B 65 14 9D B2 44 2F A8 07 56 99
E4 69 96 07 88 39 79 95 17 47 B5 D2 5A 09 F7 FE B7 25 71 B0 19 E4 07 1B DC F3 60 C0 53 DB 54 A0 A8 1F 14 4E 86 5D 13 65
A4 BA 0A C6 10 F3 FA 4A B0 45 1B 2C 61 F7 25 AB DE 4A 28 51 27 E4 2D 05 20 B1 7C BF E1 25 79 AA 59 60 EE 0C CC F9 1A 97
5A F0 76 C3 84 B5 F6 93 EC 00 8C E0 C5 BC 09 9D 0B 11 7F 45 FE B9 C1 63 73 55 45 06 5D BD 96 B5 89 B6 81 56 74 50 E9 51
4A 4B 70 AB 23 F3 06 21 9A ED 34 FA FE 5F 06 F9 85 55 2A 56 D0 CD F7 D9 2E 8A 14 CA 28 BB 48 F4 8B
16 : 36 : 00 <====Rx METER-2 D4 81 E6 20 00 00 00 11 C4 02 81 00 00 00 00 11 00 81 D6 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16
01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 FF 02
02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01
02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02
03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02
06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16
16 : 36 : 00 ====>Tx METER-2 D0 0C 20 00 00 00 11 C0 02 C1 00 00 00 11
16 : 36 : 00 ====>Tx METER-2 D0 0C 20 00 00 00 11 0B 02 D4 58 35 11 C2
16 : 36 : 00 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 00 11 0B 02 D4 58 35 11 C2 AF 3A 7E
16 : 36 : 01 METER-2 RECEIVED HDLC FRAME
16 : 36 : 01 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 00 12 8D 95 BC 2A D3 6D 21 99 41 29 BB F6 6F 50 BC CA 68 D1
5D A8 F2 F2 04 55 7A A6 88 8B 38 B4 46 2B 78 F3 4F B0 F0 E0 C0 C5 CA 2E F2 0A 43 6E 06 D6 A7 4A CD 7F 90 20 CE 80 66 AF
44 5F 30 44 F9 0B 1C D2 78 9F 85 0C 84 94 01 00 98 76 EA D5 A5 6E 23 C4 43 CD EF 32 B8 ED 15 12 E8 A8 92 A5 FB 2B 73 FB
0B 77 E8 AA B8 71 3B 95 D7 D5 FF 39 98 BC 71 93 BA 8E F9 0F EE CF 30 92 82 BF 22 C1 52 B0 9C 2A 8D B0 AB 24 F1 BD 62 EC
DF CD C6 D5 03 EE 1D 23 2F 42 D2 A8 D1 40 EC A6 64 51 41 E5 D3 66 49 64 26 1B DA B9 C3 A7 A3 AE 39 A9 96 6A 1D 0E 46 72
5B C9 30 49 B6 8C CA 3B B5 97 FD 40 E1 A3 FE 74 25 32 A1 70 A7 FF 09 4A 4A 68 96 71 26 E9 60 F8 E8 ED F6 9C 04 25 9F DE
D8 38 CA D8 DD 22 72 66 DE 7E
16 : 36 : 01 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 01 <====Rx METER-2 D4 81 E6 20 00 00 00 12 8D 95 BC 2A D3 6D 21 99 41 29 BB F6 6F 50 BC CA 68 D1 5D A8 F2 F2 04 55 7A A6 88 8B 38 B4 46 2B
78 F3 4F B0 F0 E0 C0 C5 CA 2E F2 0A 43 6E 06 D6 A7 4A CD 7F 90 20 CE 80 66 AF 44 5F 30 44 F9 0B 1C D2 78 9F 85 0C 84 94
01 00 98 76 EA D5 A5 6E 23 C4 43 CD EF 32 B8 ED 15 12 E8 A8 92 A5 FB 2B 73 FB 0B 77 E8 AA B8 71 3B 95 D7 D5 FF 39 98 BC
71 93 BA 8E F9 0F EE CF 30 92 82 BF 22 C1 52 B0 9C 2A 8D B0 AB 24 F1 BD 62 EC DF CD C6 D5 03 EE 1D 23 2F 42 D2 A8 D1 40
EC A6 64 51 41 E5 D3 66 49 64 26 1B DA B9 C3 A7 A3 AE 39 A9 96 6A 1D 0E 46 72 5B C9 30 49 B6 8C CA 3B B5 97 FD 40 E1 A3
FE 74 25 32 A1 70 A7 FF 09 4A 4A 68 96 71 26 E9 60 F8 E8 ED F6 9C 04 25 9F DE D8 38 CA D8 DD 22 72
16 : 36 : 01 <====Rx METER-2 D4 81 E6 20 00 00 00 12 C4 02 81 00 00 00 00 12 00 81 D6 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00
04 11 00 09 06 01 00 09 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04
16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 09 06 01 FF 02 02 01 05 02 03 0F
02 04 12 00 04 11 00 09 06 01 00 09 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00
16 : 36 : 01 METER-2 SERVICE = GET RESPONSE
16 : 36 : 01 METER-2 COSEM OUT DATA
16 : 36 : 01 ====>Tx METER-2 D0 0C 20 00 00 00 12 C0 02 C1 00 00 00 12
16 : 36 : 01 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 01 ====>Tx METER-2 D0 0C 20 00 00 00 12 A8 5B 4A 88 6A BD 33
16 : 36 : 01 METER-2 SERVICE = GET BLOCK REQUEST
16 : 36 : 01 METER-2 SENDING HDLC FRAME
16 : 36 : 01 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 00 12 A8 5B 4A 88 6A BD 33 35 16 7E
16 : 36 : 01 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 00 13 E0 4F F1 E4 D4 75 AC B3 C4 89 AD CB 54 A9 0F 73 A3 0E
03 CF B3 EB 0B 82 33 70 DC 19 AC EA 07 0B 1F 80 F4 56 C4 4A 6F 8E 30 D8 46 9F 2C 77 6E EF 2D 11 C2 81 D6 56 CB AB 51 0C
A7 50 56 17 3B C7 62 21 02 E1 D0 4A 3D E1 61 23 CA 5F C3 6D 12 AE 53 42 50 38 F4 F0 60 93 23 2E 96 65 B1 B2 F2 EC E8 E8
09 5B FB BD C9 4E 5D D8 2C FF 8B 10 9D 16 FE E2 DA 61 48 E5 B1 BA 05 49 CF B3 D7 EE 2E E0 E6 27 4B AB 14 E9 11 6D F1 9D
BB 01 CB 66 A2 51 76 33 AA 41 84 50 94 40 F9 65 60 46 3C FC 08 20 C7 AB 66 54 0B F2 5B 1D 75 41 7B AF EE A7 24 47 EB DA
CC 6F C8 12 5C 3A 93 93 2A D8 C7 FE F6 AB F4 38 A3 9D 07 FB 6B AB AC 7D 3D 96 1D A3 96 3A 1B AD D7 9F D9 A1 A5 97 4F DE
56 CB 82 2B 4F 10 81 14 C5 7E
16 : 36 : 01 <====Rx METER-2 D4 81 E6 20 00 00 00 13 E0 4F F1 E4 D4 75 AC B3 C4 89 AD CB 54 A9 0F 73 A3 0E 03 CF B3 EB 0B 82 33 70 DC 19 AC EA 07 0B
1F 80 F4 56 C4 4A 6F 8E 30 D8 46 9F 2C 77 6E EF 2D 11 C2 81 D6 56 CB AB 51 0C A7 50 56 17 3B C7 62 21 02 E1 D0 4A 3D E1
61 23 CA 5F C3 6D 12 AE 53 42 50 38 F4 F0 60 93 23 2E 96 65 B1 B2 F2 EC E8 E8 09 5B FB BD C9 4E 5D D8 2C FF 8B 10 9D 16
FE E2 DA 61 48 E5 B1 BA 05 49 CF B3 D7 EE 2E E0 E6 27 4B AB 14 E9 11 6D F1 9D BB 01 CB 66 A2 51 76 33 AA 41 84 50 94 40
F9 65 60 46 3C FC 08 20 C7 AB 66 54 0B F2 5B 1D 75 41 7B AF EE A7 24 47 EB DA CC 6F C8 12 5C 3A 93 93 2A D8 C7 FE F6 AB
F4 38 A3 9D 07 FB 6B AB AC 7D 3D 96 1D A3 96 3A 1B AD D7 9F D9 A1 A5 97 4F DE 56 CB 82 2B 4F 10 81
16 : 36 : 01 <====Rx METER-2 D4 81 E6 20 00 00 00 13 C4 02 81 00 00 00 00 13 00 81 D6 09 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01
00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01
00 09 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F
05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0A 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03
00 09 06 01 00 0A 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01
16 : 36 : 01 ====>Tx METER-2 D0 0C 20 00 00 00 13 C0 02 C1 00 00 00 13
16 : 36 : 01 ====>Tx METER-2 D0 0C 20 00 00 00 13 D8 65 52 DB 51 FE 0B
16 : 36 : 01 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 00 13 D8 65 52 DB 51 FE 0B C2 18 7E
16 : 36 : 01 <====Rx METER-2 7E A0 F8 41 00 02 04 01 B8 2A CB E6 E7 00 D4 81 E6 20 00 00 00 14 EB 22 59 41 75 F6 63 2E 2E B5 D3 1B 60 2C 82 FC F4 09
FC ED DC E2 E3 AF 41 65 D6 DE 2E 15 8F B0 D0 74 A0 06 F5 25 AA FA 72 C8 10 20 C9 EA DA 4E 35 0C CD 8D 62 A7 C3 11 F5 36
39 67 26 65 A0 89 FD A9 67 C2 CE 3E CC 5F 66 7A 91 14 9D F6 E5 95 85 D3 AA C4 49 E0 4F AD 17 F9 C3 C5 ED 36 74 B5 9D 19
A6 17 CD 20 04 05 4E 22 49 A9 19 77 93 11 D2 BE 7F 0B 07 4B AE 46 60 D5 AC 0B 4C 68 A0 F0 15 F2 A6 1A F4 02 8A 76 82 32
CC 5C 6F A4 7C D4 E0 A4 7F 70 94 14 54 A4 8A F6 28 B5 F6 D5 53 26 4D A2 C1 0D EC BA 75 7F 0B 5C F1 B2 F1 D1 DC 54 00 11
A9 02 BE 3E 57 6B 8A A9 B1 C5 FE 64 C9 87 FF 31 EA 5D B3 00 20 E3 79 F5 2F 9C 88 41 62 37 AE 40 48 C4 56 43 89 16 72 C4
60 57 6F E7 53 41 E9 F3 B6 7E
16 : 36 : 01 <====Rx METER-2 D4 81 E6 20 00 00 00 14 EB 22 59 41 75 F6 63 2E 2E B5 D3 1B 60 2C 82 FC F4 09 FC ED DC E2 E3 AF 41 65 D6 DE 2E 15 8F B0
D0 74 A0 06 F5 25 AA FA 72 C8 10 20 C9 EA DA 4E 35 0C CD 8D 62 A7 C3 11 F5 36 39 67 26 65 A0 89 FD A9 67 C2 CE 3E CC 5F
66 7A 91 14 9D F6 E5 95 85 D3 AA C4 49 E0 4F AD 17 F9 C3 C5 ED 36 74 B5 9D 19 A6 17 CD 20 04 05 4E 22 49 A9 19 77 93 11
D2 BE 7F 0B 07 4B AE 46 60 D5 AC 0B 4C 68 A0 F0 15 F2 A6 1A F4 02 8A 76 82 32 CC 5C 6F A4 7C D4 E0 A4 7F 70 94 14 54 A4
8A F6 28 B5 F6 D5 53 26 4D A2 C1 0D EC BA 75 7F 0B 5C F1 B2 F1 D1 DC 54 00 11 A9 02 BE 3E 57 6B 8A A9 B1 C5 FE 64 C9 87
FF 31 EA 5D B3 00 20 E3 79 F5 2F 9C 88 41 62 37 AE 40 48 C4 56 43 89 16 72 C4 60 57 6F E7 53 41 E9
16 : 36 : 01 <====Rx METER-2 D4 81 E6 20 00 00 00 14 C4 02 81 00 00 00 00 14 00 81 D6 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01
16 00 02 04 12 00 04 11 00 09 06 01 00 0A 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16
01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0A 06 03 FF 02
02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0A 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02
03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 07
16 : 36 : 02 ====>Tx METER-2 D0 0C 20 00 00 00 14 C0 02 C1 00 00 00 14
16 : 36 : 02 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 02 ====>Tx METER-2 D0 0C 20 00 00 00 14 76 0B 30 8E AC 1C 4C
16 : 36 : 02 METER-2 SERVICE = GET BLOCK REQUEST
16 : 36 : 02 METER-2 SENDING HDLC FRAME
16 : 36 : 02 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 BA 30 1E E6 E6 00 D0 0C 20 00 00 00 14 76 0B 30 8E AC 1C 4C C3 CA 7E
16 : 36 : 02 METER-2 RECEIVED HDLC FRAME
16 : 36 : 02 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 00 15 67 50 A0 8C 95 14 2E 93 60 E9 B9 E8 2C 30 06 3B 16 1D
08 C5 E2 E1 88 90 03 F1 A1 7D E0 78 92 C3 41 08 24 6B 7D C3 CA 68 27 B2 CF 05 C8 E6 04 19 C3 B4 32 F3 D4 88 9D 20 5C 97
55 44 BB 25 56 A0 EC B8 7D 97 7B C6 6B A2 3F 6C 79 56 2C FD 67 E7 40 EA 8B BE 14 0F 1A 94 88 7E 43 3C CC C4 60 BA 2D B9
49 3B 02 60 DE C0 14 F9 25 6D 65 FC D3 D3 0E C7 57 39 A2 69 AB AE 97 E3 3E 16 C2 5C 52 20 E2 8C F2 5A FF 48 B1 35 BC D5
30 B9 4E 4C E5 9C D5 A7 35 9C 7B F2 C6 1B 27 A4 D2 2F 3E D3 FE AA 5F 5F 63 B1 59 9C 41 26 08 FA FD 57 A1 B2 9F 6C A5 AE
EF C4 84 4E 44 CF 08 36 6A CB 37 B8 44 99 1D EC 7B CD B2 00 23 12 7F 92 BD 1F 50 7C 94 E5 06 66 83 50 8E F9 D5 DC 36 B6
CF B6 56 DA 64 5C BD 8A E3 7E
16 : 36 : 02 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 02 <====Rx METER-2 D4 81 E6 20 00 00 00 15 67 50 A0 8C 95 14 2E 93 60 E9 B9 E8 2C 30 06 3B 16 1D 08 C5 E2 E1 88 90 03 F1 A1 7D E0 78 92 C3
41 08 24 6B 7D C3 CA 68 27 B2 CF 05 C8 E6 04 19 C3 B4 32 F3 D4 88 9D 20 5C 97 55 44 BB 25 56 A0 EC B8 7D 97 7B C6 6B A2
3F 6C 79 56 2C FD 67 E7 40 EA 8B BE 14 0F 1A 94 88 7E 43 3C CC C4 60 BA 2D B9 49 3B 02 60 DE C0 14 F9 25 6D 65 FC D3 D3
0E C7 57 39 A2 69 AB AE 97 E3 3E 16 C2 5C 52 20 E2 8C F2 5A FF 48 B1 35 BC D5 30 B9 4E 4C E5 9C D5 A7 35 9C 7B F2 C6 1B
27 A4 D2 2F 3E D3 FE AA 5F 5F 63 B1 59 9C 41 26 08 FA FD 57 A1 B2 9F 6C A5 AE EF C4 84 4E 44 CF 08 36 6A CB 37 B8 44 99
1D EC 7B CD B2 00 23 12 7F 92 BD 1F 50 7C 94 E5 06 66 83 50 8E F9 D5 DC 36 B6 CF B6 56 DA 64 5C BD
16 : 36 : 02 <====Rx METER-2 D4 81 E6 20 00 00 00 15 C4 02 81 00 00 00 00 15 00 81 D6 11 01 09 06 00 00 5E 5B 0A FF 02 02 01 08 02 03 0F 01 16 01 00
02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16
01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 00 FF 02 02
01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F 02 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00
02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07
11 01 09 06 00 00 63 62 01 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F 02 02 03
16 : 36 : 02 METER-2 SERVICE = GET RESPONSE
16 : 36 : 02 ====>Tx METER-2 D0 0C 20 00 00 00 15 C0 02 C1 00 00 00 15
16 : 36 : 02 ====>Tx METER-2 D0 0C 20 00 00 00 15 14 88 6A DE 61 B3 10
16 : 36 : 02 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 00 15 14 88 6A DE 61 B3 10 7A 7C 7E
16 : 36 : 02 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 00 16 BC D6 B2 7A 27 2A 15 64 3B 30 5F 95 43 33 A9 5C 5C 1E
EC 47 0E A2 BC 96 A8 53 FA FD A5 FC F2 5D 4C 63 64 0A 06 E9 1F 00 8F 1E 39 2D 90 56 FA 36 3B FF 97 74 46 AE 28 B9 AE D0
FF 82 A2 4E 92 32 5F F2 EA 73 E9 48 CA 61 61 0D 24 55 AA 84 0E 71 0F CB F3 CB D2 9E 0C 42 76 5F C3 E9 33 69 71 99 7D F6
C6 15 70 2C 96 11 68 58 DD 78 95 5F 0F 7F 4C 10 DB 8C 96 B0 8B 71 30 24 1B 6A 6F 97 D0 F0 B7 28 DA D3 6E 6C 17 51 CD AE
F4 EA B0 9A 7D FB C5 66 31 E5 D5 25 DA 7C EF 51 54 1D 85 CD 9F 06 14 C0 8D E6 49 C5 3D ED 16 0E F2 59 65 04 70 F1 53 8E
18 BB 9B 68 16 A7 C9 4B F3 DF C4 C8 28 66 17 12 E0 B2 70 7E DE 99 75 06 FB 4D 40 BF E7 6C CD 71 F9 F3 1F 19 90 E3 75 36
7B C4 68 99 C4 9D 14 5B 6D 7E
16 : 36 : 02 <====Rx METER-2 D4 81 E6 20 00 00 00 16 BC D6 B2 7A 27 2A 15 64 3B 30 5F 95 43 33 A9 5C 5C 1E EC 47 0E A2 BC 96 A8 53 FA FD A5 FC F2 5D
4C 63 64 0A 06 E9 1F 00 8F 1E 39 2D 90 56 FA 36 3B FF 97 74 46 AE 28 B9 AE D0 FF 82 A2 4E 92 32 5F F2 EA 73 E9 48 CA 61
61 0D 24 55 AA 84 0E 71 0F CB F3 CB D2 9E 0C 42 76 5F C3 E9 33 69 71 99 7D F6 C6 15 70 2C 96 11 68 58 DD 78 95 5F 0F 7F
4C 10 DB 8C 96 B0 8B 71 30 24 1B 6A 6F 97 D0 F0 B7 28 DA D3 6E 6C 17 51 CD AE F4 EA B0 9A 7D FB C5 66 31 E5 D5 25 DA 7C
EF 51 54 1D 85 CD 9F 06 14 C0 8D E6 49 C5 3D ED 16 0E F2 59 65 04 70 F1 53 8E 18 BB 9B 68 16 A7 C9 4B F3 DF C4 C8 28 66
17 12 E0 B2 70 7E DE 99 75 06 FB 4D 40 BF E7 6C CD 71 F9 F3 1F 19 90 E3 75 36 7B C4 68 99 C4 9D 14
16 : 36 : 02 <====Rx METER-2 D4 81 E6 20 00 00 00 16 C4 02 81 00 00 00 00 16 00 81 D6 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03
0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01
09 06 00 00 63 62 02 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F 02 02 03 0F 03 16 01 00 02 03 0F 04
16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02
02 0F 02 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 03 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F
02 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07
16 : 36 : 02 ====>Tx METER-2 D0 0C 20 00 00 00 16 C0 02 C1 00 00 00 16
16 : 36 : 02 ====>Tx METER-2 D0 0C 20 00 00 00 16 B2 B6 BD DB EF 7A 13
16 : 36 : 02 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 00 16 B2 B6 BD DB EF 7A 13 E9 27 7E
16 : 36 : 03 METER-2 RECEIVED HDLC FRAME
16 : 36 : 03 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 00 17 DE 8A 64 34 24 C3 CB D6 76 2E 0E F7 33 AF B1 0E 2A 47
1F 4D 0D D9 28 07 54 4F 6D CE 9B 15 F2 E7 5F ED AB 57 DD 8D 84 F1 7A 6E 97 A5 02 03 22 0A E5 2E 9C 6D 89 26 C3 4F 15 7B
FD 73 90 FF 2C 6E 08 FE 46 2C 81 26 80 85 7A 7B B8 7F 90 1B FD 21 F5 F4 98 8B 0B CB 06 C7 86 AB 63 81 29 7E 29 AE AB 08
38 21 60 C2 AE 81 36 B1 E8 C9 FB 72 D1 E7 1E AE 92 6F 74 80 D8 81 C6 39 54 F9 D1 F2 DF D2 AD B8 5D DD FE 3F 49 21 4E B9
04 54 9F 00 8E 52 6D 6F 6B B3 85 19 1F EB 72 92 5B 1D 38 22 36 AD 15 B9 7E C1 40 2D 79 55 68 26 EA 18 4A AB 34 ED 71 A8
3C 6D 3D C2 A8 30 26 B5 AB 14 78 60 80 4B 51 29 04 72 B8 1E 56 FF D0 D1 CD EF BF 7C D3 5C 4D FF DE 60 05 85 DB DD 9C 85
EA 1B 82 C1 E2 B0 B2 08 71 7E
16 : 36 : 03 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 03 <====Rx METER-2 D4 81 E6 20 00 00 00 17 DE 8A 64 34 24 C3 CB D6 76 2E 0E F7 33 AF B1 0E 2A 47 1F 4D 0D D9 28 07 54 4F 6D CE 9B 15 F2 E7
5F ED AB 57 DD 8D 84 F1 7A 6E 97 A5 02 03 22 0A E5 2E 9C 6D 89 26 C3 4F 15 7B FD 73 90 FF 2C 6E 08 FE 46 2C 81 26 80 85
7A 7B B8 7F 90 1B FD 21 F5 F4 98 8B 0B CB 06 C7 86 AB 63 81 29 7E 29 AE AB 08 38 21 60 C2 AE 81 36 B1 E8 C9 FB 72 D1 E7
1E AE 92 6F 74 80 D8 81 C6 39 54 F9 D1 F2 DF D2 AD B8 5D DD FE 3F 49 21 4E B9 04 54 9F 00 8E 52 6D 6F 6B B3 85 19 1F EB
72 92 5B 1D 38 22 36 AD 15 B9 7E C1 40 2D 79 55 68 26 EA 18 4A AB 34 ED 71 A8 3C 6D 3D C2 A8 30 26 B5 AB 14 78 60 80 4B
51 29 04 72 B8 1E 56 FF D0 D1 CD EF BF 7C D3 5C 4D FF DE 60 05 85 DB DD 9C 85 EA 1B 82 C1 E2 B0 B2
16 : 36 : 03 <====Rx METER-2 D4 81 E6 20 00 00 00 17 C4 02 81 00 00 00 00 17 00 81 D6 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F
02 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 04 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F 02 02
03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01
00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 05 FF 02 02 01 08 02 03 0F 01 16 01
00 02 03 0F 02 16 01 01 01 0F 02 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02
16 : 36 : 03 METER-2 SERVICE = GET RESPONSE
16 : 36 : 03 METER-2 COSEM OUT DATA
16 : 36 : 03 ====>Tx METER-2 D0 0C 20 00 00 00 17 C0 02 C1 00 00 00 17
16 : 36 : 03 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 03 ====>Tx METER-2 D0 0C 20 00 00 00 17 2B 7F 42 6C D6 65 FF
16 : 36 : 03 METER-2 SERVICE = GET BLOCK REQUEST
16 : 36 : 03 METER-2 SENDING HDLC FRAME
16 : 36 : 03 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 00 17 2B 7F 42 6C D6 65 FF D7 14 7E
16 : 36 : 03 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 00 18 E3 96 BA F2 C3 C9 FF 15 BD 3F 1E 09 AB 8B F4 39 DA 62
B4 85 F6 BC F3 0C 3D DA 73 05 3C 8F 87 38 D9 03 D1 16 9F 1B FA FD 2A A0 B5 3B 36 16 47 15 6A D0 0C 6A 98 62 5E D0 C8 A3
FF E7 29 5C 4B 54 25 58 03 65 8A 12 82 AA 17 28 73 DA 0C A1 5A 88 E7 61 86 60 7A C3 83 9C 5C 88 5A 5D F9 AB 10 D7 98 73
47 71 F3 1C 63 B4 11 C3 DE 43 6A 5C 12 E7 8E E8 80 56 C5 5F 44 DD 0A 5E 96 63 BC 95 64 1F 19 AE 92 A3 3B 66 B0 15 D6 99
86 18 45 10 44 7A 14 53 96 63 E3 C2 E7 1E 07 3A 36 56 2C F9 38 DF F2 26 16 AC 7C 67 ED 0B 14 CE EB D1 9F D9 56 43 BF DA
46 4D 51 52 40 89 8A 39 1A 0B C7 1A 5E 76 64 ED 21 93 0D 63 10 A5 42 06 D8 35 61 62 5C 2F 5D F5 DF 18 54 9B 17 4C BD 05
45 59 D1 D6 30 55 8A F7 61 7E
16 : 36 : 03 <====Rx METER-2 D4 81 E6 20 00 00 00 18 E3 96 BA F2 C3 C9 FF 15 BD 3F 1E 09 AB 8B F4 39 DA 62 B4 85 F6 BC F3 0C 3D DA 73 05 3C 8F 87 38
D9 03 D1 16 9F 1B FA FD 2A A0 B5 3B 36 16 47 15 6A D0 0C 6A 98 62 5E D0 C8 A3 FF E7 29 5C 4B 54 25 58 03 65 8A 12 82 AA
17 28 73 DA 0C A1 5A 88 E7 61 86 60 7A C3 83 9C 5C 88 5A 5D F9 AB 10 D7 98 73 47 71 F3 1C 63 B4 11 C3 DE 43 6A 5C 12 E7
8E E8 80 56 C5 5F 44 DD 0A 5E 96 63 BC 95 64 1F 19 AE 92 A3 3B 66 B0 15 D6 99 86 18 45 10 44 7A 14 53 96 63 E3 C2 E7 1E
07 3A 36 56 2C F9 38 DF F2 26 16 AC 7C 67 ED 0B 14 CE EB D1 9F D9 56 43 BF DA 46 4D 51 52 40 89 8A 39 1A 0B C7 1A 5E 76
64 ED 21 93 0D 63 10 A5 42 06 D8 35 61 62 5C 2F 5D F5 DF 18 54 9B 17 4C BD 05 45 59 D1 D6 30 55 8A
16 : 36 : 03 <====Rx METER-2 D4 81 E6 20 00 00 00 18 C4 02 81 00 00 00 00 18 00 81 D6 01 09 06 00 00 63 62 06 FF 02 02 01 08 02 03 0F 01 16 01 00 02
03 0F 02 16 01 01 01 0F 02 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F
07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 00 FF
02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02
03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11
01 09 06 01 00 5E 5B 03 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01
16 : 36 : 03 ====>Tx METER-2 D0 0C 20 00 00 00 18 C0 02 C1 00 00 00 18
16 : 36 : 03 ====>Tx METER-2 D0 0C 20 00 00 00 18 4F 63 8F 03 9A 23 43
16 : 36 : 03 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 00 18 4F 63 8F 03 9A 23 43 48 CF 7E
16 : 36 : 03 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 00 19 83 F3 96 77 C9 AA 9D 38 BD 2F FF 54 62 52 79 C5 99 A4
73 55 AB 14 C5 BB 65 AB A8 97 AE 26 7F 81 8D B8 F2 B3 97 93 46 C1 3E A0 CC A8 4A A9 35 CF 02 EA 4E AA 62 A0 A6 28 63 32
93 BB FE F2 D6 5B DB CF 03 0A BE 03 0D 9D 3E A9 3D 8C 95 81 36 47 C7 F0 ED B7 B4 34 7B 20 93 34 CE C8 BD 4B C4 8F 50 EB
37 48 5F 4F 1C FA 71 CB 27 0B D4 CD 4F AF 09 D8 77 C7 92 A7 75 82 95 4A 9C 96 DB D9 07 F4 1D B6 EF DB ED 6F 55 71 A3 D0
09 BA 64 F9 7F A7 4F C4 79 FC CC 64 44 A4 5F 7F CA 20 75 64 CD 73 1B 9F 3E B7 4A 83 30 92 0D AF C4 15 8C 06 3C 35 0F 48
58 48 C7 02 2C 29 72 84 06 FA FE EE 45 F2 A8 EB 7E 24 C8 BF 34 07 0A C0 C9 4D EC 8B 90 2D 86 45 29 DB 75 D7 1C 37 EF 5A
F9 3C 48 42 FA E3 4D 99 49 7E
16 : 36 : 03 <====Rx METER-2 D4 81 E6 20 00 00 00 19 83 F3 96 77 C9 AA 9D 38 BD 2F FF 54 62 52 79 C5 99 A4 73 55 AB 14 C5 BB 65 AB A8 97 AE 26 7F 81
8D B8 F2 B3 97 93 46 C1 3E A0 CC A8 4A A9 35 CF 02 EA 4E AA 62 A0 A6 28 63 32 93 BB FE F2 D6 5B DB CF 03 0A BE 03 0D 9D
3E A9 3D 8C 95 81 36 47 C7 F0 ED B7 B4 34 7B 20 93 34 CE C8 BD 4B C4 8F 50 EB 37 48 5F 4F 1C FA 71 CB 27 0B D4 CD 4F AF
09 D8 77 C7 92 A7 75 82 95 4A 9C 96 DB D9 07 F4 1D B6 EF DB ED 6F 55 71 A3 D0 09 BA 64 F9 7F A7 4F C4 79 FC CC 64 44 A4
5F 7F CA 20 75 64 CD 73 1B 9F 3E B7 4A 83 30 92 0D AF C4 15 8C 06 3C 35 0F 48 58 48 C7 02 2C 29 72 84 06 FA FE EE 45 F2
A8 EB 7E 24 C8 BF 34 07 0A C0 C9 4D EC 8B 90 2D 86 45 29 DB 75 D7 1C 37 EF 5A F9 3C 48 42 FA E3 4D
16 : 36 : 03 <====Rx METER-2 D4 81 E6 20 00 00 00 19 C4 02 81 00 00 00 00 19 00 81 D6 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01
00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 01 00
5E 5B 04 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05
16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04
12 00 07 11 01 09 06 01 00 5E 5B 05 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03
0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00
16 : 36 : 04 ====>Tx METER-2 D0 0C 20 00 00 00 19 C0 02 C1 00 00 00 19
16 : 36 : 04 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 04 ====>Tx METER-2 D0 0C 20 00 00 00 19 C6 67 FE 3E 45 54 18
16 : 36 : 04 METER-2 SERVICE = GET BLOCK REQUEST
16 : 36 : 04 METER-2 SENDING HDLC FRAME
16 : 36 : 04 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 00 19 C6 67 FE 3E 45 54 18 E7 D4 7E
16 : 36 : 04 METER-2 RECEIVED HDLC FRAME
16 : 36 : 04 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 00 1A B1 4B 79 3F 2E DB 2D 8F 2C 14 B0 5C 8F 41 C2 39 29 FB
A9 60 F1 34 40 07 06 95 20 38 DB 11 BC 3A C1 31 E7 3A FD E7 E0 F4 C1 55 1F 24 F0 7A 51 63 24 8B AA 8D 41 B4 0B DC D9 03
F6 7E A1 E5 F3 2D AA D3 4A BE DD A6 FC 3F 84 DC E1 E9 51 AC 6A AD 91 4F 17 4C C2 82 75 A7 E4 12 82 56 CD 43 97 34 62 AB
5F 8A 68 F4 43 F5 3D 1C 69 08 E5 38 83 A3 B3 A9 62 ED 4E 62 62 59 7A 3F B7 63 B1 1B 58 1B E8 0D 84 AF 53 C5 D5 5E 05 81
7B 33 E6 31 08 2D 84 90 6E 29 31 A3 9B 14 F0 56 2A E6 54 85 FE 00 38 72 51 1D 5B 4C 23 AC 9E 93 CE 5C FE 8F 9F AF D6 D7
8F B8 63 09 95 4B 72 59 0D B7 54 F6 C1 A1 25 77 16 1D 60 69 48 BD 35 D5 48 85 D5 70 9B AD 86 5A 1C D5 EB F9 DE E6 42 F7
4D 2E 99 6F E7 61 F4 48 D7 7E
16 : 36 : 04 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 04 <====Rx METER-2 D4 81 E6 20 00 00 00 1A B1 4B 79 3F 2E DB 2D 8F 2C 14 B0 5C 8F 41 C2 39 29 FB A9 60 F1 34 40 07 06 95 20 38 DB 11 BC 3A
C1 31 E7 3A FD E7 E0 F4 C1 55 1F 24 F0 7A 51 63 24 8B AA 8D 41 B4 0B DC D9 03 F6 7E A1 E5 F3 2D AA D3 4A BE DD A6 FC 3F
84 DC E1 E9 51 AC 6A AD 91 4F 17 4C C2 82 75 A7 E4 12 82 56 CD 43 97 34 62 AB 5F 8A 68 F4 43 F5 3D 1C 69 08 E5 38 83 A3
B3 A9 62 ED 4E 62 62 59 7A 3F B7 63 B1 1B 58 1B E8 0D 84 AF 53 C5 D5 5E 05 81 7B 33 E6 31 08 2D 84 90 6E 29 31 A3 9B 14
F0 56 2A E6 54 85 FE 00 38 72 51 1D 5B 4C 23 AC 9E 93 CE 5C FE 8F 9F AF D6 D7 8F B8 63 09 95 4B 72 59 0D B7 54 F6 C1 A1
25 77 16 1D 60 69 48 BD 35 D5 48 85 D5 70 9B AD 86 5A 1C D5 EB F9 DE E6 42 F7 4D 2E 99 6F E7 61 F4
16 : 36 : 04 <====Rx METER-2 D4 81 E6 20 00 00 00 1A C4 02 81 00 00 00 00 1A 00 81 D6 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01
09 06 01 00 5E 5B 06 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00
02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02
16 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 07 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16
01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02
02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 01 00 62 01 00 FF 02 02 01 08 02 03 0F
16 : 36 : 04 METER-2 SERVICE = GET RESPONSE
16 : 36 : 04 ====>Tx METER-2 D0 0C 20 00 00 00 1A C0 02 C1 00 00 00 1A
16 : 36 : 04 ====>Tx METER-2 D0 0C 20 00 00 00 1A 89 FC 1B AB FE A9 37
16 : 36 : 04 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 00 1A 89 FC 1B AB FE A9 37 B9 D1 7E
16 : 36 : 04 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 00 1B 34 1D BC DC 75 B7 55 9B 96 D0 6C 22 92 09 BB C5 82 50
0F 07 F0 27 8C BF B3 49 EB E3 39 26 21 10 B4 C4 0E A5 F9 76 E1 1D 40 5D 52 D0 C6 23 84 3D 94 69 7E 14 C9 00 7D AA 57 1A
B2 10 8C CF AA FE 1C F1 1D 7A F7 9F DE 0E 34 1C 51 A8 F3 CF 16 CA F2 58 92 99 AD CB 5A 00 F2 63 19 05 82 4B 6A B9 48 1B
77 19 A0 CD D5 F9 D6 54 6A 3D F9 1C BD 59 7F BE 1A CE 22 52 F7 F5 B4 5A 0A 8A 36 3C B0 7A 0A C7 E7 F1 52 FA FC 09 36 1A
E3 81 D8 9E 65 BA C1 98 F7 AA 32 37 49 3C 82 91 9F DD 7D 4F DC BF 18 FF 6A AB A0 2E 28 25 87 3B 6D 09 CA FD 9C 04 51 DB
B1 A9 85 53 F2 0A 11 94 F1 49 04 48 FF 43 75 2C BA 7F C4 3D FE 0A 7F 67 07 12 F9 85 2E 5A 17 6C 2C 6F AA 05 CF 46 8C A7
8B BD 6F CF 8D CE 74 B6 FC 7E
16 : 36 : 04 <====Rx METER-2 D4 81 E6 20 00 00 00 1B 34 1D BC DC 75 B7 55 9B 96 D0 6C 22 92 09 BB C5 82 50 0F 07 F0 27 8C BF B3 49 EB E3 39 26 21 10
B4 C4 0E A5 F9 76 E1 1D 40 5D 52 D0 C6 23 84 3D 94 69 7E 14 C9 00 7D AA 57 1A B2 10 8C CF AA FE 1C F1 1D 7A F7 9F DE 0E
34 1C 51 A8 F3 CF 16 CA F2 58 92 99 AD CB 5A 00 F2 63 19 05 82 4B 6A B9 48 1B 77 19 A0 CD D5 F9 D6 54 6A 3D F9 1C BD 59
7F BE 1A CE 22 52 F7 F5 B4 5A 0A 8A 36 3C B0 7A 0A C7 E7 F1 52 FA FC 09 36 1A E3 81 D8 9E 65 BA C1 98 F7 AA 32 37 49 3C
82 91 9F DD 7D 4F DC BF 18 FF 6A AB A0 2E 28 25 87 3B 6D 09 CA FD 9C 04 51 DB B1 A9 85 53 F2 0A 11 94 F1 49 04 48 FF 43
75 2C BA 7F C4 3D FE 0A 7F 67 07 12 F9 85 2E 5A 17 6C 2C 6F AA 05 CF 46 8C A7 8B BD 6F CF 8D CE 74
16 : 36 : 04 <====Rx METER-2 D4 81 E6 20 00 00 00 1B C4 02 81 00 00 00 00 1B 00 81 D6 01 16 01 00 02 03 0F 02 16 01 01 01 0F 02 02 03 0F 03 16 01 00
02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F
01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 01 00 63 01 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16
01 01 01 0F 01 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00
02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 01 00 63 02 00 FF 02 02 01 08
02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03
16 : 36 : 04 ====>Tx METER-2 D0 0C 20 00 00 00 1B C0 02 C1 00 00 00 1B
16 : 36 : 04 ====>Tx METER-2 D0 0C 20 00 00 00 1B BE D2 91 3F 8F 2E 04
16 : 36 : 04 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 00 1B BE D2 91 3F 8F 2E 04 90 BF 7E
16 : 36 : 05 METER-2 RECEIVED HDLC FRAME
16 : 36 : 05 <====Rx METER-2 7E A0 F8 41 00 02 04 01 B8 2A CB E6 E7 00 D4 81 E6 20 00 00 00 1C 04 3E 59 A0 E1 E3 60 19 03 C0 9D 72 2F DC C7 7E E9 36
A5 83 B5 F1 03 87 C0 51 C2 25 32 ED D6 DA 19 8F 57 31 7A F4 4A 8E 45 FC 4C 73 88 05 45 65 E1 34 79 4F 35 AE 4E 2E FD F2
57 4A F9 F7 7E C0 7F 72 4F 0E 26 84 64 A0 9B 6E 45 AB 76 87 AB 13 62 3B ED 22 52 7C E1 98 2F A4 34 04 5C D0 F3 11 9E A3
B5 06 36 8E D7 6B 21 50 14 61 C4 BE DE C3 00 9E 7E F0 4E 8C DA 9C 37 73 EA 93 B8 61 D0 CE 6B 7F 9C 20 36 5C 6B 42 29 6A
62 DE 52 14 74 C8 DB 9A 86 04 5B 28 DD 83 49 66 7C 70 18 7A 7D 6E 59 4B A4 27 B6 28 62 5B 30 B7 DE 9F E1 F7 09 F2 F1 FE
AE F2 1E BF 97 E5 CA 41 90 63 61 E5 0F A3 38 1C 90 09 FC 54 DC 8D 76 E1 EB A6 46 F7 8F 97 9A 28 1E 46 DF 7C EA 69 6C 89
0C 3C B5 E5 D6 D9 CB B6 C9 7E
16 : 36 : 05 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 05 <====Rx METER-2 D4 81 E6 20 00 00 00 1C 04 3E 59 A0 E1 E3 60 19 03 C0 9D 72 2F DC C7 7E E9 36 A5 83 B5 F1 03 87 C0 51 C2 25 32 ED D6 DA
19 8F 57 31 7A F4 4A 8E 45 FC 4C 73 88 05 45 65 E1 34 79 4F 35 AE 4E 2E FD F2 57 4A F9 F7 7E C0 7F 72 4F 0E 26 84 64 A0
9B 6E 45 AB 76 87 AB 13 62 3B ED 22 52 7C E1 98 2F A4 34 04 5C D0 F3 11 9E A3 B5 06 36 8E D7 6B 21 50 14 61 C4 BE DE C3
00 9E 7E F0 4E 8C DA 9C 37 73 EA 93 B8 61 D0 CE 6B 7F 9C 20 36 5C 6B 42 29 6A 62 DE 52 14 74 C8 DB 9A 86 04 5B 28 DD 83
49 66 7C 70 18 7A 7D 6E 59 4B A4 27 B6 28 62 5B 30 B7 DE 9F E1 F7 09 F2 F1 FE AE F2 1E BF 97 E5 CA 41 90 63 61 E5 0F A3
38 1C 90 09 FC 54 DC 8D 76 E1 EB A6 46 F7 8F 97 9A 28 1E 46 DF 7C EA 69 6C 89 0C 3C B5 E5 D6 D9 CB
16 : 36 : 05 <====Rx METER-2 D4 81 E6 20 00 00 00 1C C4 02 81 00 00 00 00 1C 00 81 D6 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03
0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03
0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00
02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 06 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16
00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 01 FF 02 02 01 02 02 03
0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00
16 : 36 : 05 METER-2 SERVICE = GET RESPONSE
16 : 36 : 05 METER-2 COSEM OUT DATA
16 : 36 : 05 ====>Tx METER-2 D0 0C 20 00 00 00 1C C0 02 C1 00 00 00 1C
16 : 36 : 05 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 05 ====>Tx METER-2 D0 0C 20 00 00 00 1C A8 5A 97 05 57 58 CA
16 : 36 : 05 METER-2 SERVICE = GET BLOCK REQUEST
16 : 36 : 05 METER-2 SENDING HDLC FRAME
16 : 36 : 05 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 BA 30 1E E6 E6 00 D0 0C 20 00 00 00 1C A8 5A 97 05 57 58 CA 0F 83 7E
16 : 36 : 05 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 00 1D 7A F9 6B CD C9 55 8E 45 BB 5C F9 DD FF 28 03 C4 F1 CB
86 46 B4 52 E7 1F 12 9E 4C 17 A5 B0 A6 88 1C 0C 5B E4 6E B1 28 FF 2B CB F5 CB 8D A3 98 8F 1E BB AC 1A F1 D1 22 BD 6C 4E
DB D5 CE 47 80 27 33 C5 1E 54 29 C1 C6 E3 30 98 F5 7C 8E A3 D8 C5 3B E1 DA 59 BD 22 81 74 46 BD C8 A1 A9 8B 3D 5C C1 38
E3 47 A0 65 DF 45 B5 87 6D AB FD 4A FD 1E 3A 6C AF 1F 7B EA 6A 17 4A DA AE 97 BA 70 B3 44 39 B3 04 1F F5 9B 4F 9B 5B E4
C4 D6 BC C8 E0 67 04 23 B7 14 F7 44 01 AA B0 12 CD B4 A9 CE 77 D4 C6 04 6D FE 60 D0 CC 8F 37 94 31 8F 54 11 B4 6E B7 91
2B BE 3E C5 CD D3 E7 AC CE 92 95 77 00 66 22 8E 9F C0 E3 DE 2D A5 A0 EF E2 53 0E 1E 14 64 D6 FD 4A FA D0 CE 4A 0C 51 DF
FA 3A 6E 64 B1 71 DC F8 FF 7E
16 : 36 : 05 <====Rx METER-2 D4 81 E6 20 00 00 00 1D 7A F9 6B CD C9 55 8E 45 BB 5C F9 DD FF 28 03 C4 F1 CB 86 46 B4 52 E7 1F 12 9E 4C 17 A5 B0 A6 88
1C 0C 5B E4 6E B1 28 FF 2B CB F5 CB 8D A3 98 8F 1E BB AC 1A F1 D1 22 BD 6C 4E DB D5 CE 47 80 27 33 C5 1E 54 29 C1 C6 E3
30 98 F5 7C 8E A3 D8 C5 3B E1 DA 59 BD 22 81 74 46 BD C8 A1 A9 8B 3D 5C C1 38 E3 47 A0 65 DF 45 B5 87 6D AB FD 4A FD 1E
3A 6C AF 1F 7B EA 6A 17 4A DA AE 97 BA 70 B3 44 39 B3 04 1F F5 9B 4F 9B 5B E4 C4 D6 BC C8 E0 67 04 23 B7 14 F7 44 01 AA
B0 12 CD B4 A9 CE 77 D4 C6 04 6D FE 60 D0 CC 8F 37 94 31 8F 54 11 B4 6E B7 91 2B BE 3E C5 CD D3 E7 AC CE 92 95 77 00 66
22 8E 9F C0 E3 DE 2D A5 A0 EF E2 53 0E 1E 14 64 D6 FD 4A FA D0 CE 4A 0C 51 DF FA 3A 6E 64 B1 71 DC
16 : 36 : 05 <====Rx METER-2 D4 81 E6 20 00 00 00 1D C4 02 81 00 00 00 00 1D 00 81 D6 6A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01
01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 6B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00
01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 6C FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01
00 01 01 02 02 0F 01 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 01 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16
01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F
08 16 01 00 02 03 0F 09 16 00 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02
16 : 36 : 05 ====>Tx METER-2 D0 0C 20 00 00 00 1D C0 02 C1 00 00 00 1D
16 : 36 : 05 ====>Tx METER-2 D0 0C 20 00 00 00 1D D6 74 A2 AB B1 17 5D
16 : 36 : 05 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 00 1D D6 74 A2 AB B1 17 5D 05 2D 7E
16 : 36 : 05 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 00 1E 42 D6 A1 2D A8 1A E8 37 BC 87 89 64 BC E0 97 B4 6D 9E
28 D5 23 6B F2 47 CD 45 B5 14 07 F8 C1 89 B8 61 62 C2 99 EF 87 15 85 29 02 7C 42 0C E0 FE 7E 8D 8D 23 DD 9F 52 47 64 96
66 FC 8F BC 0D 72 1E 05 49 70 7F B1 D6 E3 34 2B 1B C6 B6 04 E4 7A E5 9B 11 20 CC 99 23 E1 E7 97 F9 6F 13 FE 3C 4C 2A 20
0C 8E FC F6 B5 91 FE FE 76 06 14 97 41 3D B5 A0 43 EF 79 C0 E3 69 FB 5A A3 66 45 A2 BE 2F AF 27 74 68 94 B6 94 B4 83 1E
73 CA A8 F8 F8 81 86 54 F9 A5 91 25 24 CB 81 5C 6B 47 7F 26 16 1C BA 0C B0 9B 00 0D 5E A9 6F 53 10 03 83 A5 C3 C0 44 FD
4B B8 04 7D F0 F0 8F 21 E7 BA 18 78 29 AA 4F BA 4C A9 6B F2 E7 3D B9 96 8C 71 19 88 74 AB 06 D1 DD CA 8B D6 2D 38 1C EA
C3 16 26 58 14 77 8E 04 21 7E
16 : 36 : 05 <====Rx METER-2 D4 81 E6 20 00 00 00 1E 42 D6 A1 2D A8 1A E8 37 BC 87 89 64 BC E0 97 B4 6D 9E 28 D5 23 6B F2 47 CD 45 B5 14 07 F8 C1 89
B8 61 62 C2 99 EF 87 15 85 29 02 7C 42 0C E0 FE 7E 8D 8D 23 DD 9F 52 47 64 96 66 FC 8F BC 0D 72 1E 05 49 70 7F B1 D6 E3
34 2B 1B C6 B6 04 E4 7A E5 9B 11 20 CC 99 23 E1 E7 97 F9 6F 13 FE 3C 4C 2A 20 0C 8E FC F6 B5 91 FE FE 76 06 14 97 41 3D
B5 A0 43 EF 79 C0 E3 69 FB 5A A3 66 45 A2 BE 2F AF 27 74 68 94 B6 94 B4 83 1E 73 CA A8 F8 F8 81 86 54 F9 A5 91 25 24 CB
81 5C 6B 47 7F 26 16 1C BA 0C B0 9B 00 0D 5E A9 6F 53 10 03 83 A5 C3 C0 44 FD 4B B8 04 7D F0 F0 8F 21 E7 BA 18 78 29 AA
4F BA 4C A9 6B F2 E7 3D B9 96 8C 71 19 88 74 AB 06 D1 DD CA 8B D6 2D 38 1C EA C3 16 26 58 14 77 8E
16 : 36 : 05 <====Rx METER-2 D4 81 E6 20 00 00 00 1E C4 02 81 00 00 00 00 1E 00 81 D6 0F 04 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 02 FF 02 02
01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F
06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02
02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 04 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F
02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02
03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00
16 : 36 : 06 ====>Tx METER-2 D0 0C 20 00 00 00 1E C0 02 C1 00 00 00 1E
16 : 36 : 06 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 06 ====>Tx METER-2 D0 0C 20 00 00 00 1E 92 8B FF 98 A0 31 F0
16 : 36 : 06 METER-2 SERVICE = GET BLOCK REQUEST
16 : 36 : 06 METER-2 SENDING HDLC FRAME
16 : 36 : 06 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 00 1E 92 8B FF 98 A0 31 F0 E3 44 7E
16 : 36 : 06 METER-2 RECEIVED HDLC FRAME
16 : 36 : 06 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 00 1F D8 A1 35 D3 66 DE B4 59 89 1B D0 15 17 74 AC EC 54 33
4A F4 95 75 7C 2B 45 79 05 09 6A 0F 8D 5A 2B DA 91 82 63 F1 EF AD C7 0E 68 BD 4E 49 51 3A 0D 70 7B E3 68 4F 86 61 F8 E6
35 BE 7D 7E 46 2A 3A B6 34 75 8A E7 F9 AA AF E1 42 06 31 21 C9 DB D2 BF 13 B4 7B 76 A2 13 B7 BB 24 21 3F 5B AC F2 5D F7
87 52 E2 69 95 56 0E 81 42 6C A3 89 86 D2 C8 FB C5 E8 F1 22 77 AF C3 E6 AF 2A B8 6A 9F 85 FA A1 0B E7 FC 70 14 B9 9D 02
2D 77 A6 A9 0A A4 EE A0 FE 75 AF AC 08 66 E2 09 96 0A ED 50 82 28 65 6A 7F B0 88 3E C4 0C EA 45 D9 B5 26 94 7C 78 27 A4
29 5E 57 A0 9D 1A F5 B9 F8 CE 73 D8 6C 93 38 19 A9 6F 78 56 CA 0A 4A BB 7F 42 D8 B6 68 3A 50 52 59 A7 B8 61 79 18 38 32
E2 D2 F7 4A 5F 19 3B 6D 42 7E
16 : 36 : 06 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 06 <====Rx METER-2 D4 81 E6 20 00 00 00 1F D8 A1 35 D3 66 DE B4 59 89 1B D0 15 17 74 AC EC 54 33 4A F4 95 75 7C 2B 45 79 05 09 6A 0F 8D 5A
2B DA 91 82 63 F1 EF AD C7 0E 68 BD 4E 49 51 3A 0D 70 7B E3 68 4F 86 61 F8 E6 35 BE 7D 7E 46 2A 3A B6 34 75 8A E7 F9 AA
AF E1 42 06 31 21 C9 DB D2 BF 13 B4 7B 76 A2 13 B7 BB 24 21 3F 5B AC F2 5D F7 87 52 E2 69 95 56 0E 81 42 6C A3 89 86 D2
C8 FB C5 E8 F1 22 77 AF C3 E6 AF 2A B8 6A 9F 85 FA A1 0B E7 FC 70 14 B9 9D 02 2D 77 A6 A9 0A A4 EE A0 FE 75 AF AC 08 66
E2 09 96 0A ED 50 82 28 65 6A 7F B0 88 3E C4 0C EA 45 D9 B5 26 94 7C 78 27 A4 29 5E 57 A0 9D 1A F5 B9 F8 CE 73 D8 6C 93
38 19 A9 6F 78 56 CA 0A 4A BB 7F 42 D8 B6 68 3A 50 52 59 A7 B8 61 79 18 38 32 E2 D2 F7 4A 5F 19 3B
16 : 36 : 06 <====Rx METER-2 D4 81 E6 20 00 00 00 1F C4 02 81 00 00 00 00 1F 00 81 D6 02 02 0F 04 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 06 FF
02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02
03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16
00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02
03 0F 02 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 12 11 00 09 06 00 00 2C 00 00 FF 02 02 01 07 02 03 0F 01 16 01 00
16 : 36 : 06 METER-2 SERVICE = GET RESPONSE
16 : 36 : 06 ====>Tx METER-2 D0 0C 20 00 00 00 1F C0 02 C1 00 00 00 1F
16 : 36 : 06 ====>Tx METER-2 D0 0C 20 00 00 00 1F 30 B0 07 0F 90 B4 1A
16 : 36 : 06 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 00 1F 30 B0 07 0F 90 B4 1A 6A BD 7E
16 : 36 : 06 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 00 20 F9 F4 9C 33 31 10 96 DA CC C1 AD 9A 2D 15 4C 22 9C 12
7F 15 75 81 54 81 47 CE 6B F8 F3 72 FD 0D 0C 4B B1 F4 32 ED A7 4C A7 B1 07 38 FB 49 F1 C4 0A 61 3C 3A 90 B0 73 FD 00 CE
FD 70 7A 0B A0 54 C0 B8 46 DC 35 3D 65 63 36 B3 42 1A C5 D6 4B A8 B1 60 E2 70 C1 B8 29 BD 37 EE 94 0E 50 9F B8 B4 0B B7
D1 26 B9 6F 76 81 B3 FA 9F 54 C0 14 52 C7 48 EC 4C 27 1F E3 AD 2F 8F 72 CE 32 6B A5 52 98 03 4F 6F 44 3C 01 21 7A 37 86
10 60 95 58 53 79 E8 FA 16 2E 5D A8 7E 4E 81 9F 23 37 9B 44 0E B2 C2 2B 56 0D 66 C3 3C FE CF F1 2A 79 19 C0 6A A0 E0 9E
6A F1 CE 5B B3 B8 1E 3F C6 BA 77 6E E2 8E 02 D0 48 5F 7A 58 9C 3F B2 7A 2B B9 5D DD 10 EB B4 49 1E 70 16 54 1D 2B CC 9B
7A 42 C5 58 5A 36 1C 0C B3 7E
16 : 36 : 06 <====Rx METER-2 D4 81 E6 20 00 00 00 20 F9 F4 9C 33 31 10 96 DA CC C1 AD 9A 2D 15 4C 22 9C 12 7F 15 75 81 54 81 47 CE 6B F8 F3 72 FD 0D
0C 4B B1 F4 32 ED A7 4C A7 B1 07 38 FB 49 F1 C4 0A 61 3C 3A 90 B0 73 FD 00 CE FD 70 7A 0B A0 54 C0 B8 46 DC 35 3D 65 63
36 B3 42 1A C5 D6 4B A8 B1 60 E2 70 C1 B8 29 BD 37 EE 94 0E 50 9F B8 B4 0B B7 D1 26 B9 6F 76 81 B3 FA 9F 54 C0 14 52 C7
48 EC 4C 27 1F E3 AD 2F 8F 72 CE 32 6B A5 52 98 03 4F 6F 44 3C 01 21 7A 37 86 10 60 95 58 53 79 E8 FA 16 2E 5D A8 7E 4E
81 9F 23 37 9B 44 0E B2 C2 2B 56 0D 66 C3 3C FE CF F1 2A 79 19 C0 6A A0 E0 9E 6A F1 CE 5B B3 B8 1E 3F C6 BA 77 6E E2 8E
02 D0 48 5F 7A 58 9C 3F B2 7A 2B B9 5D DD 10 EB B4 49 1E 70 16 54 1D 2B CC 9B 7A 42 C5 58 5A 36 1C
16 : 36 : 06 <====Rx METER-2 D4 81 E6 20 00 00 00 20 C4 02 81 00 00 00 00 20 00 81 D6 01 00 02 03 0F 07 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02
16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 14 11 00 09 06 00 00 0D 00 00 FF 02 02 01 0A 02 03 0F 01 16 01 00
01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 02 03 0F 0A 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 15 11 00 09 06
00 00 10 00 01 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00
02 04 12 00 16 11 00 09 06 00 00 0F 00 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00
16 : 36 : 06 ====>Tx METER-2 D0 0C 20 00 00 00 20 C0 02 C1 00 00 00 20
16 : 36 : 06 ====>Tx METER-2 D0 0C 20 00 00 00 20 A3 F1 BB 18 17 8A FA
16 : 36 : 06 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 00 20 A3 F1 BB 18 17 8A FA 71 8A 7E
16 : 36 : 07 METER-2 RECEIVED HDLC FRAME
16 : 36 : 07 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 00 21 04 0C 33 86 B5 00 96 D3 E1 8A 6A 1C 74 62 5A AD 82 9D
06 E7 74 03 56 1E CC 26 18 84 19 F4 18 BC 97 78 7F 9D 23 52 9F CA AD 4B FF 39 67 13 51 37 08 8E 9F 2A FD 01 D6 DE 43 E3
19 84 21 EC 05 19 D3 D8 7D 01 22 48 77 11 AB 80 96 7D 4A 27 C8 0E 64 B3 ED C7 0E DA 72 48 CC D6 8F 14 D2 B9 13 E1 89 28
2E C5 ED 50 70 AA A9 E1 2E 1F 80 0A 79 B0 EB 02 0C 13 C8 06 EB 0F 18 99 21 34 3E 78 57 EF 4A 45 65 CD BD 95 47 D1 D7 27
2A D4 42 47 60 07 1A 82 E1 C4 87 08 C6 7B A9 5C 27 9A 78 15 EE 45 E6 D9 53 C4 0C AF C0 00 AD 3C 1E 0A 49 C1 C4 7F A6 BD
DE E7 B7 89 C0 C7 07 1D 9E E9 73 FA 2E E3 DC 21 D1 99 88 07 59 95 E4 60 48 79 A0 37 01 1E 05 10 F4 50 2E BF 0A 8B 3C 22
EC 6B 60 87 BF 55 59 E4 80 7E
16 : 36 : 07 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 07 <====Rx METER-2 D4 81 E6 20 00 00 00 21 04 0C 33 86 B5 00 96 D3 E1 8A 6A 1C 74 62 5A AD 82 9D 06 E7 74 03 56 1E CC 26 18 84 19 F4 18 BC
97 78 7F 9D 23 52 9F CA AD 4B FF 39 67 13 51 37 08 8E 9F 2A FD 01 D6 DE 43 E3 19 84 21 EC 05 19 D3 D8 7D 01 22 48 77 11
AB 80 96 7D 4A 27 C8 0E 64 B3 ED C7 0E DA 72 48 CC D6 8F 14 D2 B9 13 E1 89 28 2E C5 ED 50 70 AA A9 E1 2E 1F 80 0A 79 B0
EB 02 0C 13 C8 06 EB 0F 18 99 21 34 3E 78 57 EF 4A 45 65 CD BD 95 47 D1 D7 27 2A D4 42 47 60 07 1A 82 E1 C4 87 08 C6 7B
A9 5C 27 9A 78 15 EE 45 E6 D9 53 C4 0C AF C0 00 AD 3C 1E 0A 49 C1 C4 7F A6 BD DE E7 B7 89 C0 C7 07 1D 9E E9 73 FA 2E E3
DC 21 D1 99 88 07 59 95 E4 60 48 79 A0 37 01 1E 05 10 F4 50 2E BF 0A 8B 3C 22 EC 6B 60 87 BF 55 59
16 : 36 : 07 <====Rx METER-2 D4 81 E6 20 00 00 00 21 C4 02 81 00 00 00 00 21 00 81 D6 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 16
11 00 09 06 00 00 0F 00 01 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16
01 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 01 01 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F
03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 02 FF 02 02 01 04 02 03 0F 01 16 01 00 02
03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 04 FF 02 02 01
04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04
16 : 36 : 07 METER-2 SERVICE = GET RESPONSE
16 : 36 : 07 METER-2 COSEM OUT DATA
16 : 36 : 07 ====>Tx METER-2 D0 0C 20 00 00 00 21 C0 02 C1 00 00 00 21
16 : 36 : 07 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 07 ====>Tx METER-2 D0 0C 20 00 00 00 21 2A 4D 2F E2 26 2A 37
16 : 36 : 07 METER-2 SERVICE = GET BLOCK REQUEST
16 : 36 : 07 METER-2 SENDING HDLC FRAME
16 : 36 : 07 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 00 21 2A 4D 2F E2 26 2A 37 88 E9 7E
16 : 36 : 07 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 00 22 71 39 E0 E4 4C F6 A2 17 C8 EB 3C 65 CB 1C D1 C8 FD 92
D7 45 E8 43 35 D6 0B E5 5D 7D BD 79 69 75 D9 63 6D D4 F8 4D 5B D7 E8 03 9A 5B 24 C5 5A 10 D7 B2 15 37 78 AC 0C DD B5 5B
44 1C 2F 62 8B 25 AE 91 DD BF 3B FC 5D 62 88 DD E1 30 E1 F3 ED F0 39 BA 17 84 AD 30 3B B4 9D 60 F0 3A 07 64 BF 38 E0 39
22 A7 05 7F 62 35 A2 FF 88 E6 DF 52 3B 9F 05 4F 80 2F 69 52 4F 17 6E 43 7D 59 EE 81 BC F9 FD 23 C9 03 91 1C 68 56 7F 6B
0F 2E 09 AF 2A 28 31 36 9D 6C D6 2D AF 9B BB 20 1D 61 32 9A 0A C2 47 F8 EF AA 13 B4 37 BF C2 84 DC 53 5A CF 0A 47 17 6A
CA 62 DC EB 2F 9B 98 0E F9 3E FF BC 5B 86 B2 CE 1D 8C 1D 77 1F C1 6E 9C C9 29 D7 22 C5 0E 0F AE B1 CC 41 83 A0 AF C7 03
FA 0F 9B 07 26 28 FB 80 A2 7E
16 : 36 : 07 <====Rx METER-2 D4 81 E6 20 00 00 00 22 71 39 E0 E4 4C F6 A2 17 C8 EB 3C 65 CB 1C D1 C8 FD 92 D7 45 E8 43 35 D6 0B E5 5D 7D BD 79 69 75
D9 63 6D D4 F8 4D 5B D7 E8 03 9A 5B 24 C5 5A 10 D7 B2 15 37 78 AC 0C DD B5 5B 44 1C 2F 62 8B 25 AE 91 DD BF 3B FC 5D 62
88 DD E1 30 E1 F3 ED F0 39 BA 17 84 AD 30 3B B4 9D 60 F0 3A 07 64 BF 38 E0 39 22 A7 05 7F 62 35 A2 FF 88 E6 DF 52 3B 9F
05 4F 80 2F 69 52 4F 17 6E 43 7D 59 EE 81 BC F9 FD 23 C9 03 91 1C 68 56 7F 6B 0F 2E 09 AF 2A 28 31 36 9D 6C D6 2D AF 9B
BB 20 1D 61 32 9A 0A C2 47 F8 EF AA 13 B4 37 BF C2 84 DC 53 5A CF 0A 47 17 6A CA 62 DC EB 2F 9B 98 0E F9 3E FF BC 5B 86
B2 CE 1D 8C 1D 77 1F C1 6E 9C C9 29 D7 22 C5 0E 0F AE B1 CC 41 83 A0 AF C7 03 FA 0F 9B 07 26 28 FB
16 : 36 : 07 <====Rx METER-2 D4 81 E6 20 00 00 00 22 C4 02 81 00 00 00 00 22 00 81 D6 12 00 16 11 00 09 06 00 03 0F 00 04 FF 02 02 01 04 02 03 0F 01
16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 17 11 01 09 06 00 00 16 00 00
FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00
02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 00 02 04 12 00 28 11 00 09 06 00
00 19 09 00 FF 02 02 01 07 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F
05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 28 11 00
16 : 36 : 07 ====>Tx METER-2 D0 0C 20 00 00 00 22 C0 02 C1 00 00 00 22
16 : 36 : 07 ====>Tx METER-2 D0 0C 20 00 00 00 22 7C 81 2A 12 28 F1 58
16 : 36 : 07 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 00 22 7C 81 2A 12 28 F1 58 DB 1E 7E
16 : 36 : 07 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 00 23 38 BD FB E9 27 9B 7D D4 69 B7 6B 64 96 D6 E9 6F 0F FC
F2 A8 BB B4 E0 2B 54 3E 84 5D 66 32 57 1B 19 ED 2A 55 14 41 78 0A B0 28 55 5B F6 94 C6 08 39 82 E0 2C D0 43 69 8B 0C E9
C3 9B 5E 66 42 78 AC 39 13 7C 62 C0 CE A4 9E 23 1D 00 01 21 9E 39 C5 AF 54 4A 10 ED D4 37 4B F1 A7 27 2B DC 77 07 3B 9C
3E 1E 01 65 10 13 26 2D AC 87 21 FA 37 B5 3A 5E 5D F1 20 70 29 0D 74 63 AC A9 4E 0D F6 D5 BC 14 B7 48 FF 96 9A 2B 7C 4B
45 86 1E 16 4A 01 06 2D A8 CB 07 EB 05 DE 6D 05 DC 61 84 BC 47 D0 61 83 C9 59 58 04 93 82 B0 BC 89 44 AE 03 55 B5 81 D9
64 9B 1B 5A 8A 91 93 F9 C2 0D 82 23 2F A6 8F D5 05 AA 53 5E E0 58 6A 6C F4 93 74 C0 26 03 A8 8E 62 A3 B9 B3 08 1C E3 74
69 42 30 9B 64 E8 FB 2C B2 7E
16 : 36 : 07 <====Rx METER-2 D4 81 E6 20 00 00 00 23 38 BD FB E9 27 9B 7D D4 69 B7 6B 64 96 D6 E9 6F 0F FC F2 A8 BB B4 E0 2B 54 3E 84 5D 66 32 57 1B
19 ED 2A 55 14 41 78 0A B0 28 55 5B F6 94 C6 08 39 82 E0 2C D0 43 69 8B 0C E9 C3 9B 5E 66 42 78 AC 39 13 7C 62 C0 CE A4
9E 23 1D 00 01 21 9E 39 C5 AF 54 4A 10 ED D4 37 4B F1 A7 27 2B DC 77 07 3B 9C 3E 1E 01 65 10 13 26 2D AC 87 21 FA 37 B5
3A 5E 5D F1 20 70 29 0D 74 63 AC A9 4E 0D F6 D5 BC 14 B7 48 FF 96 9A 2B 7C 4B 45 86 1E 16 4A 01 06 2D A8 CB 07 EB 05 DE
6D 05 DC 61 84 BC 47 D0 61 83 C9 59 58 04 93 82 B0 BC 89 44 AE 03 55 B5 81 D9 64 9B 1B 5A 8A 91 93 F9 C2 0D 82 23 2F A6
8F D5 05 AA 53 5E E0 58 6A 6C F4 93 74 C0 26 03 A8 8E 62 A3 B9 B3 08 1C E3 74 69 42 30 9B 64 E8 FB
16 : 36 : 07 <====Rx METER-2 D4 81 E6 20 00 00 00 23 C4 02 81 00 00 00 00 23 00 81 D6 09 06 00 01 19 09 00 FF 02 02 01 07 02 03 0F 01 16 01 00 02 03
0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00
01 01 02 02 0F 01 16 00 02 04 12 00 28 11 00 09 06 00 02 19 09 00 FF 02 02 01 07 02 03 0F 01 16 01 00 02 03 0F 02 16 01
00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 01 01 02 02
0F 01 16 00 02 04 12 00 28 11 00 09 06 00 03 19 09 00 FF 02 02 01 07 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F
16 : 36 : 08 ====>Tx METER-2 D0 0C 20 00 00 00 23 C0 02 C1 00 00 00 23
16 : 36 : 08 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 08 ====>Tx METER-2 D0 0C 20 00 00 00 23 76 A8 85 C0 BD A3 60
16 : 36 : 08 METER-2 SERVICE = GET BLOCK REQUEST
16 : 36 : 08 METER-2 SENDING HDLC FRAME
16 : 36 : 08 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 00 23 76 A8 85 C0 BD A3 60 5E 7A 7E
16 : 36 : 08 METER-2 RECEIVED HDLC FRAME
16 : 36 : 08 <====Rx METER-2 7E A0 F8 41 00 02 04 01 B8 2A CB E6 E7 00 D4 81 E6 20 00 00 00 24 39 6C 60 94 B0 D4 34 B8 C2 2C A5 78 87 29 2F 7B F2 C2
C7 39 C9 BB 5C A6 41 E1 95 E8 9A FF C7 6A DE 34 36 68 5F E0 14 CA C8 B9 23 21 0C 3F 7F 0A BC FE D0 09 12 E9 25 9E 6F B3
66 E3 8D D5 E5 E0 7D EC F2 0C 8C B3 93 60 C5 C5 8B 03 C6 48 9A 9F DE E3 77 8E C9 03 15 DF 33 77 D3 31 BA 9F C9 0A 6E 2F
54 1A 5D 57 32 88 E1 1B CF CE D3 02 B2 9F 8B 35 05 8D 8A D0 61 6D C5 F7 C4 5E B1 97 57 6E CA 01 39 62 E9 85 6E 66 D2 56
37 37 2E 2E CB E5 1A D8 2B 62 75 33 34 D4 29 F4 F1 4E FD 56 33 32 40 13 A9 39 97 A3 9A 66 04 D5 90 0F FE 00 1F 01 A5 DB
1C 1C 3A 4D 58 10 18 9F B8 CF 4E 99 0D 72 7C 80 61 2E 66 EC C0 73 6C 96 59 50 F2 3C 99 A6 2B E0 B8 3C 08 22 08 1E 33 0F
F4 1A F4 C8 EA 42 FC E4 91 7E
16 : 36 : 08 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 08 <====Rx METER-2 D4 81 E6 20 00 00 00 24 39 6C 60 94 B0 D4 34 B8 C2 2C A5 78 87 29 2F 7B F2 C2 C7 39 C9 BB 5C A6 41 E1 95 E8 9A FF C7 6A
DE 34 36 68 5F E0 14 CA C8 B9 23 21 0C 3F 7F 0A BC FE D0 09 12 E9 25 9E 6F B3 66 E3 8D D5 E5 E0 7D EC F2 0C 8C B3 93 60
C5 C5 8B 03 C6 48 9A 9F DE E3 77 8E C9 03 15 DF 33 77 D3 31 BA 9F C9 0A 6E 2F 54 1A 5D 57 32 88 E1 1B CF CE D3 02 B2 9F
8B 35 05 8D 8A D0 61 6D C5 F7 C4 5E B1 97 57 6E CA 01 39 62 E9 85 6E 66 D2 56 37 37 2E 2E CB E5 1A D8 2B 62 75 33 34 D4
29 F4 F1 4E FD 56 33 32 40 13 A9 39 97 A3 9A 66 04 D5 90 0F FE 00 1F 01 A5 DB 1C 1C 3A 4D 58 10 18 9F B8 CF 4E 99 0D 72
7C 80 61 2E 66 EC C0 73 6C 96 59 50 F2 3C 99 A6 2B E0 B8 3C 08 22 08 1E 33 0F F4 1A F4 C8 EA 42 FC
16 : 36 : 08 <====Rx METER-2 D4 81 E6 20 00 00 00 24 C4 02 81 00 00 00 00 24 00 81 D6 01 02 02 0F 01 16 00 02 04 12 00 28 11 00 09 06 00 04 19 09 00
FF 02 02 01 07 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00
02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 29 11 00 09 06 00 00 19 00 00 FF 02 02 01
06 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06
16 01 00 01 00 02 04 12 00 2A 11 00 09 06 00 00 19 01 00 FF 02 02 01 0A 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03
16 : 36 : 08 METER-2 SERVICE = GET RESPONSE
16 : 36 : 08 ====>Tx METER-2 D0 0C 20 00 00 00 24 C0 02 C1 00 00 00 24
16 : 36 : 08 ====>Tx METER-2 D0 0C 20 00 00 00 24 9E 36 BC 13 F7 7D 84
16 : 36 : 08 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 BA 30 1E E6 E6 00 D0 0C 20 00 00 00 24 9E 36 BC 13 F7 7D 84 99 2D 7E
16 : 36 : 08 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 00 25 42 3C 0C 1C F8 8E B5 DA 41 F5 EF F3 0B 28 00 4A B2 60
FD 27 CA E6 F2 AC 5E 2F A7 79 0B 52 D1 0D 49 A7 B8 40 A9 B7 E6 E0 0B C7 28 B1 85 8E 2C B5 3F CA FA 86 8B D5 57 D1 2A 73
2E 58 AB 1A 1A FE 3A 97 69 B1 1B 09 E2 D3 A8 7F 3A BD E2 A2 86 89 C8 9F B7 C4 0B 19 73 B4 1B 24 B5 A0 D0 9C 42 15 45 AA
A3 52 38 46 B9 D0 52 B7 04 C7 96 13 B0 6D DB 58 5A 62 70 21 24 E0 B3 BF 21 52 B1 A3 66 F4 C4 46 2E C5 67 E2 3A 99 37 7B
8E 10 02 76 3F 50 AB 52 6E 41 86 22 DB FB 61 BC B5 0D 63 FA C4 6F A3 EE D6 92 CE BF 26 1E FB D8 80 48 51 24 6E C8 D7 38
91 5F EC 07 8B BF 4F 8A C6 27 53 C5 C0 A8 EE 20 16 91 1F B0 45 B7 81 99 19 44 5E 16 78 1F 3F 1D F9 0D F0 D7 53 7C 0E A8
86 23 05 B0 EA D1 F3 88 75 7E
16 : 36 : 08 <====Rx METER-2 D4 81 E6 20 00 00 00 25 42 3C 0C 1C F8 8E B5 DA 41 F5 EF F3 0B 28 00 4A B2 60 FD 27 CA E6 F2 AC 5E 2F A7 79 0B 52 D1 0D
49 A7 B8 40 A9 B7 E6 E0 0B C7 28 B1 85 8E 2C B5 3F CA FA 86 8B D5 57 D1 2A 73 2E 58 AB 1A 1A FE 3A 97 69 B1 1B 09 E2 D3
A8 7F 3A BD E2 A2 86 89 C8 9F B7 C4 0B 19 73 B4 1B 24 B5 A0 D0 9C 42 15 45 AA A3 52 38 46 B9 D0 52 B7 04 C7 96 13 B0 6D
DB 58 5A 62 70 21 24 E0 B3 BF 21 52 B1 A3 66 F4 C4 46 2E C5 67 E2 3A 99 37 7B 8E 10 02 76 3F 50 AB 52 6E 41 86 22 DB FB
61 BC B5 0D 63 FA C4 6F A3 EE D6 92 CE BF 26 1E FB D8 80 48 51 24 6E C8 D7 38 91 5F EC 07 8B BF 4F 8A C6 27 53 C5 C0 A8
EE 20 16 91 1F B0 45 B7 81 99 19 44 5E 16 78 1F 3F 1D F9 0D F0 D7 53 7C 0E A8 86 23 05 B0 EA D1 F3
16 : 36 : 08 <====Rx METER-2 D4 81 E6 20 00 00 00 25 C4 02 81 00 00 00 00 25 00 81 D6 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 02 03 0F 0A 16 01 00
01 00 02 04 12 00 30 11 00 09 06 00 00 19 07 00 FF 02 02 01 0A 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16
01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F
09 16 01 00 02 03 0F 0A 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 40 11 00 09 06 00 00 2B 00 02 FF
02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01
02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 40 11 00 09 06 00 00 2B 00 03 FF 02 02 01 05 02
16 : 36 : 08 ====>Tx METER-2 D0 0C 20 00 00 00 25 C0 02 C1 00 00 00 25
16 : 36 : 08 ====>Tx METER-2 D0 0C 20 00 00 00 25 06 A1 5A E3 5F 36 9E
16 : 36 : 08 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 00 25 06 A1 5A E3 5F 36 9E 88 A9 7E
16 : 36 : 09 METER-2 RECEIVED HDLC FRAME
16 : 36 : 09 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 00 26 FD DC CD D3 51 71 41 C8 A8 15 DF 10 70 FA BE BD D1 08
86 FD 0E C8 A3 46 71 BF F1 60 A2 04 DD 5E 16 CF F1 BA 88 A8 CB 02 24 07 47 F1 8A DB A1 0E 72 94 C7 99 6B 8F CC 07 DE 8B
CB 24 FC 22 CA F7 2C 3C C2 7A 5D A4 F9 BA CF 35 24 0F 36 42 1C 00 A3 4C 6E F9 0E 50 5E 28 88 4F 71 4F AE 45 F4 E5 62 61
DC F1 B9 D3 71 5D 1A 11 02 69 0E EE 5A 30 E4 E9 42 DA 4C D3 8A 35 6C F8 5A 08 9C 80 21 EA E6 D2 DA 48 F4 FB CC 95 F1 B0
02 91 DD 86 10 D5 95 98 C9 5E 32 F9 FC CB 72 37 38 2E AC 73 C3 32 36 C3 07 5E CD 24 88 D6 74 27 BE B9 6D B3 16 11 94 2D
80 A4 F6 18 8D 43 E9 2F EB 3A 98 6C B1 6B AB 8F F6 0F 0D 0B BE AC EE C6 87 29 17 2F F5 AF 24 2C E2 33 C8 85 DE 1D 78 F7
07 35 AC 4C 5F A3 57 3D 04 7E
16 : 36 : 09 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 09 <====Rx METER-2 D4 81 E6 20 00 00 00 26 FD DC CD D3 51 71 41 C8 A8 15 DF 10 70 FA BE BD D1 08 86 FD 0E C8 A3 46 71 BF F1 60 A2 04 DD 5E
16 CF F1 BA 88 A8 CB 02 24 07 47 F1 8A DB A1 0E 72 94 C7 99 6B 8F CC 07 DE 8B CB 24 FC 22 CA F7 2C 3C C2 7A 5D A4 F9 BA
CF 35 24 0F 36 42 1C 00 A3 4C 6E F9 0E 50 5E 28 88 4F 71 4F AE 45 F4 E5 62 61 DC F1 B9 D3 71 5D 1A 11 02 69 0E EE 5A 30
E4 E9 42 DA 4C D3 8A 35 6C F8 5A 08 9C 80 21 EA E6 D2 DA 48 F4 FB CC 95 F1 B0 02 91 DD 86 10 D5 95 98 C9 5E 32 F9 FC CB
72 37 38 2E AC 73 C3 32 36 C3 07 5E CD 24 88 D6 74 27 BE B9 6D B3 16 11 94 2D 80 A4 F6 18 8D 43 E9 2F EB 3A 98 6C B1 6B
AB 8F F6 0F 0D 0B BE AC EE C6 87 29 17 2F F5 AF 24 2C E2 33 C8 85 DE 1D 78 F7 07 35 AC 4C 5F A3 57
16 : 36 : 09 <====Rx METER-2 D4 81 E6 20 00 00 00 26 C4 02 81 00 00 00 00 26 00 81 D6 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02
03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 40 11 00 09 06 00 00 2B 00
04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01
00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 40 11 00 09 06 00 00 2B 00 05 FF 02 02 01 05 02 03 0F 01 16 01
00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F
02 16 00 02 04 12 00 40 11 00 09 06 00 00 2B 00 06 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02
16 : 36 : 09 METER-2 SERVICE = GET RESPONSE
16 : 36 : 09 METER-2 COSEM OUT DATA
16 : 36 : 09 ====>Tx METER-2 D0 0C 20 00 00 00 26 C0 02 C1 00 00 00 26
16 : 36 : 09 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 09 ====>Tx METER-2 D0 0C 20 00 00 00 26 5B E7 AB 5D 53 23 C4
16 : 36 : 09 METER-2 SERVICE = GET BLOCK REQUEST
16 : 36 : 09 METER-2 SENDING HDLC FRAME
16 : 36 : 09 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 00 26 5B E7 AB 5D 53 23 C4 9A 8D 7E
16 : 36 : 09 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 00 27 79 FC 56 0B F0 D9 68 A7 E4 FD 95 4D DC E9 8E 7E BD 12
CF F1 B9 26 18 C6 6C 5E 5D A4 8D A7 39 A9 07 DE F0 FB 3B 2E 22 F6 E8 9C CC 70 15 37 D7 5E 57 9D 79 17 04 FF 26 D8 B5 3F
3E 97 B8 C6 A9 DB B3 D1 AD D0 EC 40 1D B8 DC E3 D4 C9 E9 C9 94 0B 07 8C E3 71 2C 9C 5C F9 AC 6C 56 A7 B2 5E 94 6C 37 5E
B8 C8 10 D2 C1 AC 15 2D 5D 82 0E 38 B0 4F 5D 74 89 E9 E2 08 91 33 72 F4 F1 28 E3 8B 42 5A 6E 71 01 C5 3E 15 B3 CE 3C 6E
0C 13 94 5D AA 47 62 E6 7F 68 43 E1 40 3D A4 28 9F 1B B8 12 62 2D FF 93 94 38 36 60 D1 9A AF 82 4A C5 33 B4 F2 C1 A8 70
68 92 17 D2 93 30 60 17 60 01 0F EE 11 C1 71 73 02 39 E0 9A 06 62 0C 63 05 A3 66 DB CF 86 28 56 2B 62 5D A7 62 CC 74 73
78 9A C0 FC 1D 3C 7D 2D 51 7E
16 : 36 : 09 <====Rx METER-2 D4 81 E6 20 00 00 00 27 79 FC 56 0B F0 D9 68 A7 E4 FD 95 4D DC E9 8E 7E BD 12 CF F1 B9 26 18 C6 6C 5E 5D A4 8D A7 39 A9
07 DE F0 FB 3B 2E 22 F6 E8 9C CC 70 15 37 D7 5E 57 9D 79 17 04 FF 26 D8 B5 3F 3E 97 B8 C6 A9 DB B3 D1 AD D0 EC 40 1D B8
DC E3 D4 C9 E9 C9 94 0B 07 8C E3 71 2C 9C 5C F9 AC 6C 56 A7 B2 5E 94 6C 37 5E B8 C8 10 D2 C1 AC 15 2D 5D 82 0E 38 B0 4F
5D 74 89 E9 E2 08 91 33 72 F4 F1 28 E3 8B 42 5A 6E 71 01 C5 3E 15 B3 CE 3C 6E 0C 13 94 5D AA 47 62 E6 7F 68 43 E1 40 3D
A4 28 9F 1B B8 12 62 2D FF 93 94 38 36 60 D1 9A AF 82 4A C5 33 B4 F2 C1 A8 70 68 92 17 D2 93 30 60 17 60 01 0F EE 11 C1
71 73 02 39 E0 9A 06 62 0C 63 05 A3 66 DB CF 86 28 56 2B 62 5D A7 62 CC 74 73 78 9A C0 FC 1D 3C 7D
16 : 36 : 09 <====Rx METER-2 D4 81 E6 20 00 00 00 27 C4 02 81 00 00 00 00 27 00 81 D6 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05
16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 46 11 00 09 06 00 00 60 03 0A FF 02 02 01 04 02 03 0F 01
16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04
12 00 47 11 00 09 06 00 00 11 00 00 FF 02 02 01 0B 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03
0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00
02 03 0F 0A 16 01 00 02 03 0F 0B 16 01 00 01 00 02 04 12 00 47 11 00 09 06 00 00 11 00 80 FF 02 02
16 : 36 : 09 ====>Tx METER-2 D0 0C 20 00 00 00 27 C0 02 C1 00 00 00 27
16 : 36 : 09 ====>Tx METER-2 D0 0C 20 00 00 00 27 E5 BE 6E 11 9E 60 F8
16 : 36 : 09 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 00 27 E5 BE 6E 11 9E 60 F8 E5 31 7E
16 : 36 : 09 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 00 28 78 AC 26 1C 1D 3E 17 D1 0A A2 FF CF 36 47 89 91 DA B6
16 DB FF 8D AC F0 AF 33 FA 0B F6 19 72 FF 2C A9 5F 4F 08 D4 20 36 47 7E E8 4A AE A8 AD 10 F7 58 BE B0 09 30 2B B1 58 BF
A4 40 18 C4 76 DF DA 70 F0 61 F9 9F 62 74 80 89 05 50 17 92 37 2D FE CB 4E 2F EB 07 93 64 CE 73 04 DD C2 B9 12 38 53 E6
04 C5 F5 70 7E 85 36 B3 C8 A7 8B 51 C7 C3 60 97 C6 11 01 0C 74 02 1D D1 0A A5 98 F9 B4 96 B7 40 4C BB D3 7B 97 25 8E 36
14 99 AA D5 1D 40 81 29 74 17 84 0D 69 CE BA A8 16 54 99 A3 D3 CC F7 80 BF FA 29 B1 BA 20 C7 08 46 A1 B9 EC 92 E2 66 FC
29 E5 13 6A 99 A0 AA 65 D5 B4 06 2B 9C 68 1D CD 34 28 85 33 33 5C AC F9 8C 85 3A D3 68 5F E6 CE 48 E7 E5 71 35 A6 46 01
A8 7B D8 EC A6 A8 04 1D B2 7E
16 : 36 : 09 <====Rx METER-2 D4 81 E6 20 00 00 00 28 78 AC 26 1C 1D 3E 17 D1 0A A2 FF CF 36 47 89 91 DA B6 16 DB FF 8D AC F0 AF 33 FA 0B F6 19 72 FF
2C A9 5F 4F 08 D4 20 36 47 7E E8 4A AE A8 AD 10 F7 58 BE B0 09 30 2B B1 58 BF A4 40 18 C4 76 DF DA 70 F0 61 F9 9F 62 74
80 89 05 50 17 92 37 2D FE CB 4E 2F EB 07 93 64 CE 73 04 DD C2 B9 12 38 53 E6 04 C5 F5 70 7E 85 36 B3 C8 A7 8B 51 C7 C3
60 97 C6 11 01 0C 74 02 1D D1 0A A5 98 F9 B4 96 B7 40 4C BB D3 7B 97 25 8E 36 14 99 AA D5 1D 40 81 29 74 17 84 0D 69 CE
BA A8 16 54 99 A3 D3 CC F7 80 BF FA 29 B1 BA 20 C7 08 46 A1 B9 EC 92 E2 66 FC 29 E5 13 6A 99 A0 AA 65 D5 B4 06 2B 9C 68
1D CD 34 28 85 33 33 5C AC F9 8C 85 3A D3 68 5F E6 CE 48 E7 E5 71 35 A6 46 01 A8 7B D8 EC A6 A8 04
16 : 36 : 09 <====Rx METER-2 D4 81 E6 20 00 00 00 28 C4 02 81 00 00 00 00 28 00 81 D6 01 0B 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16
09 16 01 00 02 03 0F 0A 16 01 00 02 03 0F 0B 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 80 19 FF 02 02 01 02 02
03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 80 1E FF 02 02 01 02 02 03 0F 01 16 01
00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 98 01 09 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02
16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 9B 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03
16 : 36 : 10 ====>Tx METER-2 D0 0C 20 00 00 00 28 C0 02 C1 00 00 00 28
16 : 36 : 10 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 10 ====>Tx METER-2 D0 0C 20 00 00 00 28 31 73 2E 06 26 8A 20
16 : 36 : 10 METER-2 SERVICE = GET BLOCK REQUEST
16 : 36 : 10 METER-2 SENDING HDLC FRAME
16 : 36 : 10 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 00 28 31 73 2E 06 26 8A 20 51 7E 7E
16 : 36 : 10 METER-2 RECEIVED HDLC FRAME
16 : 36 : 10 <====Rx METER-2 7E A0 90 41 00 02 04 01 52 17 F9 E6 E7 00 D4 7F 20 00 00 00 29 B5 44 44 B2 75 82 A0 4A 80 4B 5C 6E FF A1 CA 06 01 33 87
3C 6A 83 A1 A1 F7 80 1F 52 E9 BE AD F8 21 6B 51 FB 84 43 93 1C DD 70 72 C1 7D 13 FA 84 AD 6F 77 26 1A 41 7A 3E CA 68 8C
31 63 E3 A8 5F 44 6E BA 00 FB 64 96 3D 95 2C E6 F5 29 08 0D C3 D8 CE B6 56 00 63 36 1F 62 6D 06 ED EF 49 27 DB 55 CB DD
49 7F 2A D0 4F 81 83 0B BC F5 B3 A3 00 ED 0B A5 25 0D 66 03 EE F6 CE 52 2C 7E
16 : 36 : 10 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 10 <====Rx METER-2 E6 E7 00 D4 7F 20 00 00 00 29 B5 44 44 B2 75 82 A0 4A 80 4B 5C 6E FF A1 CA 06 01 33 87 3C 6A 83 A1 A1 F7 80 1F 52 E9 BE
AD F8 21 6B 51 FB 84 43 93 1C DD 70 72 C1 7D 13 FA 84 AD 6F 77 26 1A 41 7A 3E CA 68 8C 31 63 E3 A8 5F 44 6E BA 00 FB 64
96 3D 95 2C E6 F5 29 08 0D C3 D8 CE B6 56 00 63 36 1F 62 6D 06 ED EF 49 27 DB 55 CB DD 49 7F 2A D0 4F 81 83 0B BC F5 B3
16 : 36 : 10 <====Rx METER-2 01 81 9A 02 04 12 00 01 11 00 09 06 00 00 00 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04
12 00 01 11 00 09 06 00 00 00 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00
09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B
01 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 03 FF 02 02
01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 04 FF 02 02 01 02 02 03 0F
01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02
03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01
00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 5B 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04
12 00 01 11 00 09 06 00 00 5E 5B 09 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00
09 06 00 00 5E 5B 0B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E
5B 0C FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 5B 12 FF 02 02
01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 5B 1A FF 02 02 01 02 02 03 0F
01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 60 13 FF 02 02 01 02 02 03 0F 01 16 01 00 02
03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 60 14 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01
00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 60 15 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04
12 00 01 11 00 09 06 00 00 5E 60 16 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00
09 06 00 00 5E 60 17 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E
60 18 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 60 19 FF 02 02
01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F
01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02
03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01
00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 02 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04
12 00 01 11 00 09 06 00 00 60 07 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00
09 06 00 00 60 0B 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60
0B 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 02 FF 02 02
01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 03 FF 02 02 01 02 02 03 0F
01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02
03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01
00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04
12 00 01 11 00 09 06 01 00 00 02 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00
09 06 00 00 60 01 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00
04 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 03 FF 02 02
01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 08 00 FF 02 02 01 02 02 03 0F
01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 08 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02
03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 08 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01
00 01 00 02 04 12 00 03 11 00 09 06 00 00 00 01 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03
16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 5E 5B 08 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F
02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 5E 5B 0E FF 02 02 01 03 02 03
0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 5E 5B
0D FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03
11 00 09 06 01 00 01 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F
01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03
16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F
02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 FF 02 02 01 03 02 03
0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08
03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03
11 00 09 06 01 00 01 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F
01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03
16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F
02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 FF 02 02 01 03 02 03
0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08
11 00 09 06 01 00 02 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F
01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03
16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F
02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 FF 02 02 01 03 02 03
0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 07
00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03
11 00 09 06 01 00 09 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F
01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03
16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F
02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 FF 02 02 01 03 02 03
0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08
04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03
11 00 09 06 01 00 0A 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F
01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03
16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F
02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 FF 02 02 01 03 02 03
0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08
11 00 09 06 01 00 0B 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F
01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03
16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F
02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0E 07 00 FF 02 02 01 03 02 03
0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 5B 07
00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04
11 00 09 06 01 00 01 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16
01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 FF 02 02 01 05 02 03 0F 01
16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02
04 12 00 04 11 00 09 06 01 00 01 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02
03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 FF 02 02 01 05
02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F
01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03
16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 FF
01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00
02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00
02 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05
16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F
02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00
09 06 01 00 02 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00
02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 09 06 00 FF 02 02 01 05 02 03 0F 01 16 01
00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12
00 04 11 00 09 06 01 00 09 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F
04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 09 06 02 FF 02 02 01 05 02 03
0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16
00 02 04 12 00 04 11 00 09 06 01 00 09 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01
00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 09 06 04 FF 02 02
01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02
02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0A 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03
0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0A 06
01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01
00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0A 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16
01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06
01 00 0A 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03
0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0A 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02
03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 07
11 01 09 06 00 00 5E 5B 0A FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16
01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02
0F 02 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F 02
02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16
01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 01 FF 02 02 01 08 02 03 0F 01 16
01 00 02 03 0F 02 16 01 01 01 0F 02 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00
02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 00 00 63
62 02 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F 02 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03
0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00
02 04 12 00 07 11 01 09 06 00 00 63 62 03 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F 02 02 03 0F 03
16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02
02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 04 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03
0F 02 16 01 01 01 0F 02 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07
16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 05 FF 02
02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F 02 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01
00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00
07 11 01 09 06 00 00 63 62 06 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F 02 02 03 0F 03 16 01 00 02
03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01
16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01
00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08
16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 03 FF 02 02 01 08 02 03 0F 01
16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03
0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 04
FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00
02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07
11 01 09 06 01 00 5E 5B 05 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16
0F 02 16 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 06 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F
03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01
02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 07 FF 02 02 01 08 02 03 0F 01 16 01 00 02
03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01
00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 01 00 62 01 00 FF 02 02 01
08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F 02 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02
01 09 06 01 00 63 01 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 03 16 01 00 02 03 0F
04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 16 00
02 02 0F 02 16 00 02 04 12 00 07 11 01 09 06 01 00 63 02 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 01
0F 01 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F
08 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F
01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02
03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 06 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00
02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 01 FF 02 02 01 02 02 03 0F
01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 6A FF 02 02 01 02 02 03
0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 6B FF 02 02 01 02 02
03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 6C FF 02 02 01 02
02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 01 FF 02 02 01
09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06
16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02
0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 02 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02
16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03
0F 08 16 01 00 02 03 0F 09 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04
12 00 0F 11 01 09 06 00 00 28 00 04 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03
0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00
01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 06
02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02
16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00
02 03 0F 02 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 12 11 00 09 06 00 00 2C 00 00 FF 02 02 01 07 02 03 0F 01 16 01
00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07
16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 14 11 00 09 06 00 00
0D 00 00 FF 02 02 01 0A 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05
16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 02 03 0F 0A 16 01 00 01 01
02 02 0F 01 16 00 02 04 12 00 15 11 00 09 06 00 00 10 00 01 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02
03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 00 FF 02 02 01 04 02 03 0F 01 16 01
00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 01 FF 02
02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 16 11 00
09 06 00 00 0F 01 01 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00
01 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 02 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16
01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 04 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F
02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 03 0F 00 04 FF 02 02 01 04 02
03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 17 11 01 09 06 00 00
16 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05
16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 00 02 04 12 00 28 11 00
09 06 00 00 19 09 00 FF 02 02 01 07 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00
02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 28 11 00 09 06 00 01
19 09 00 FF 02 02 01 07 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05
16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 28 11 00 09 06 00 02 19 09 00 FF
02 02 01 07 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02
03 0F 06 16 01 00 02 03 0F 07 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 28 11 00 09 06 00 03 19 09 00 FF 02 02 01 07
02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16
01 00 02 03 0F 07 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 28 11 00 09 06 00 04 19 09 00 FF 02 02 01 07 02 03 0F 01
0F 07 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 29 11 00 09 06 00 00 19 00 00 FF 02 02 01 06 02 03 0F 01 16 01 00 02
03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 01 00 02 04 12 00
2A 11 00 09 06 00 00 19 01 00 FF 02 02 01 0A 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04
16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 02 03
0F 0A 16 01 00 01 00 02 04 12 00 30 11 00 09 06 00 00 19 07 00 FF 02 02 01 0A 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00
01 00 02 03 0F 09 16 01 00 02 03 0F 0A 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 40 11 00 09 06 00
00 2B 00 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F
05 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 40 11 00 09 06 00 00 2B 00 03 FF 02 02 01 05 02 03 0F
01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 02 02 02 0F 01 16 00
02 02 0F 02 16 00 02 04 12 00 40 11 00 09 06 00 00 2B 00 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02
03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 40 11
00 09 06 00 00 2B 00 05 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01
00 02 03 0F 05 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 40 11 00 09 06 00 00 2B 00 06 FF 02 02 01
05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 02 02 02
0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 46 11 00 09 06 00 00 60 03 0A FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02
16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 47 11 00 09 06
00 00 11 00 00 FF 02 02 01 0B 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03
0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 02 03 0F 0A 16 01 00
02 03 0F 0B 16 01 00 01 00 02 04 12 00 47 11 00 09 06 00 00 11 00 80 FF 02 02 01 0B 02 03 0F 01 16 01 00 02 03 0F 02 16
01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F
08 16 01 00 02 03 0F 09 16 01 00 02 03 0F 0A 16 01 00 02 03 0F 0B 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 80
19 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 80 1E FF 02 02 01
02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 98 01 09 FF 02 02 01 02 02 03 0F 01
16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 9B 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03
0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 9B 01 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00
01 00 02 04 12 00 01 11 00 09 06 00 00 9B 01 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12
00 01 11 00 09 06 00 00 9B 01 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00
16 : 36 : 10 METER-2 SERVICE = GET RESPONSE
16 : 36 : 10 ====>Tx METER-2 D0 12 20 00 00 00 29 C0 01 C1 00 01 00 00 00 01 00 FF 02 00
16 : 36 : 10 ====>Tx METER-2 D0 12 20 00 00 00 29 68 88 C3 60 52 46 4F FA D9 A5 B5 5A 5B
16 : 36 : 10 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-0-1-0-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 10 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 29 68 88 C3 60 52 46 4F FA D9 A5 B5 5A 5B 1D 4B 7E
16 : 36 : 10 <====Rx METER-2 7E A0 1F 41 00 02 04 01 74 CA 22 E6 E7 00 D4 0E 20 00 00 00 2A 7E 9C FA 59 E4 AC B7 91 B0 1C 51 7E
16 : 36 : 10 <====Rx METER-2 D4 0E 20 00 00 00 2A 7E 9C FA 59 E4 AC B7 91 B0
16 : 36 : 10 <====Rx METER-2 D4 0E 20 00 00 00 2A C4 01 81 00 06 00 00 00 00
16 : 36 : 10 ====>Tx METER-2 D0 12 20 00 00 00 2A C0 01 C1 00 01 00 00 00 01 01 FF 02 00
16 : 36 : 10 ====>Tx METER-2 D0 12 20 00 00 00 2A AF 88 97 5F 4F E7 4C EA AF 54 E6 F1 0C
16 : 36 : 10 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-0-1-1-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 10 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 2A AF 88 97 5F 4F E7 4C EA AF 54 E6 F1 0C 99 E4 7E
16 : 36 : 10 <====Rx METER-2 7E A0 1C 41 00 02 04 01 96 B8 4E E6 E7 00 D4 0B 20 00 00 00 2B 85 00 F7 8A C7 9D A8 E3 7E
16 : 36 : 10 <====Rx METER-2 D4 0B 20 00 00 00 2B 85 00 F7 8A C7 9D
16 : 36 : 10 <====Rx METER-2 D4 0B 20 00 00 00 2B C4 01 81 00 11 00
16 : 36 : 10 ====>Tx METER-2 D0 12 20 00 00 00 2B C0 01 C1 00 01 00 00 2A 00 00 FF 02 00
16 : 36 : 10 ====>Tx METER-2 D0 12 20 00 00 00 2B 83 74 D7 BB 0E 92 4D 4B 05 34 9E 26 D2
16 : 36 : 10 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-42-0-0-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 10 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 2B 83 74 D7 BB 0E 92 4D 4B 05 34 9E 26 D2 14 05 7E
16 : 36 : 10 <====Rx METER-2 7E A0 2C 41 00 02 04 01 B8 8E 50 E6 E7 00 D4 1B 20 00 00 00 2C 11 65 7D CD 97 E4 E1 7C E9 7B 4E 7F 33 15 DE 91 AE 29 A5
C4 02 83 94 27 7E
16 : 36 : 10 <====Rx METER-2 D4 1B 20 00 00 00 2C 11 65 7D CD 97 E4 E1 7C E9 7B 4E 7F 33 15 DE 91 AE 29 A5 C4 02 83
16 : 36 : 11 <====Rx METER-2 D4 1B 20 00 00 00 2C C4 01 81 00 09 10 5A 45 4E 39 39 39 39 39 39 39 39 39 39 39 39 39
16 : 36 : 11 METER-2 SERVICE = GET RESPONSE
16 : 36 : 11 METER-2 COSEM OUT DATA
16 : 36 : 11 ====>Tx METER-2 D0 12 20 00 00 00 2C C0 01 C1 00 01 00 00 2B 01 02 FF 02 00
16 : 36 : 11 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 11 ====>Tx METER-2 D0 12 20 00 00 00 2C 04 27 22 49 9D 7E 8D D2 76 66 53 32 C9
16 : 36 : 11 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-1-2-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 11 METER-2 SENDING HDLC FRAME
16 : 36 : 11 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 2C 04 27 22 49 9D 7E 8D D2 76 66 53 32 C9 B3 DC 7E
16 : 36 : 11 METER-2 RECEIVED HDLC FRAME
16 : 36 : 11 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 00 2D 07 1B 9D 9E 4B C2 2D 7E B5 A2 16 7E
16 : 36 : 11 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 11 <====Rx METER-2 D4 0E 20 00 00 00 2D 07 1B 9D 9E 4B C2 2D 7E B5
16 : 36 : 11 <====Rx METER-2 D4 0E 20 00 00 00 2D C4 01 81 00 06 00 00 00 7A
16 : 36 : 11 ====>Tx METER-2 D0 12 20 00 00 00 2D C0 01 C1 00 01 00 00 2B 01 03 FF 02 00
16 : 36 : 11 ====>Tx METER-2 D0 12 20 00 00 00 2D BB F2 0B E7 EC 6A E9 F2 12 C5 CC D3 E8
16 : 36 : 11 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-1-3-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 11 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 2D BB F2 0B E7 EC 6A E9 F2 12 C5 CC D3 E8 D3 FE 7E
16 : 36 : 11 <====Rx METER-2 7E A0 1F 41 00 02 04 01 FC 8A 2A E6 E7 00 D4 0E 20 00 00 00 2E C5 95 79 4A C1 C4 7B 26 DE 54 20 7E
16 : 36 : 11 <====Rx METER-2 D4 0E 20 00 00 00 2E C5 95 79 4A C1 C4 7B 26 DE
16 : 36 : 11 <====Rx METER-2 D4 0E 20 00 00 00 2E C4 01 81 00 06 00 00 00 7A
16 : 36 : 11 ====>Tx METER-2 D0 12 20 00 00 00 2E C0 01 C1 00 01 00 00 2B 01 04 FF 02 00
16 : 36 : 11 ====>Tx METER-2 D0 12 20 00 00 00 2E DF BB B9 06 4E 1B 00 EE 78 EE B3 2C F7
16 : 36 : 11 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-1-4-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 11 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 2E DF BB B9 06 4E 1B 00 EE 78 EE B3 2C F7 5B 72 7E
16 : 36 : 11 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 2F 27 60 DA 46 78 AB 59 1D 98 BC 0D 7E
16 : 36 : 11 <====Rx METER-2 D4 0E 20 00 00 00 2F 27 60 DA 46 78 AB 59 1D 98
16 : 36 : 11 <====Rx METER-2 D4 0E 20 00 00 00 2F C4 01 81 00 06 00 00 00 7A
16 : 36 : 11 ====>Tx METER-2 D0 12 20 00 00 00 2F C0 01 C1 00 01 00 00 2B 01 05 FF 02 00
16 : 36 : 11 ====>Tx METER-2 D0 12 20 00 00 00 2F 02 89 1C 38 57 F9 0F 0A 7F C9 60 EB EC
16 : 36 : 11 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-1-5-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 11 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 2F 02 89 1C 38 57 F9 0F 0A 7F C9 60 EB EC 28 81 7E
16 : 36 : 11 <====Rx METER-2 7E A0 1F 41 00 02 04 01 30 EA 26 E6 E7 00 D4 0E 20 00 00 00 30 9C AE D5 EC BB 83 F8 72 03 5F 9C 7E
16 : 36 : 11 <====Rx METER-2 D4 0E 20 00 00 00 30 9C AE D5 EC BB 83 F8 72 03
16 : 36 : 11 <====Rx METER-2 D4 0E 20 00 00 00 30 C4 01 81 00 06 00 00 00 7A
16 : 36 : 11 ====>Tx METER-2 D0 12 20 00 00 00 30 C0 01 C1 00 01 00 00 2B 01 06 FF 02 00
16 : 36 : 11 ====>Tx METER-2 D0 12 20 00 00 00 30 F1 71 30 97 15 F1 8C 22 12 58 E0 A3 A7
16 : 36 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-1-6-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 12 METER-2 SENDING HDLC FRAME
16 : 36 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 30 F1 71 30 97 15 F1 8C 22 12 58 E0 A3 A7 E1 6F 7E
16 : 36 : 12 METER-2 RECEIVED HDLC FRAME
16 : 36 : 12 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 00 31 1C 3F 64 6D E9 66 BC 8D D3 EC 5E 7E
16 : 36 : 12 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 12 <====Rx METER-2 D4 0E 20 00 00 00 31 1C 3F 64 6D E9 66 BC 8D D3
16 : 36 : 12 <====Rx METER-2 D4 0E 20 00 00 00 31 C4 01 81 00 06 00 00 00 00
16 : 36 : 12 METER-2 SERVICE = GET RESPONSE
16 : 36 : 12 METER-2 COSEM OUT DATA
16 : 36 : 12 ====>Tx METER-2 D0 12 20 00 00 00 31 C0 01 C1 00 01 00 00 5E 5B 00 FF 02 00
16 : 36 : 12 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 12 ====>Tx METER-2 D0 12 20 00 00 00 31 13 AC 62 1E 08 60 E3 84 FC B9 31 A9 E2
16 : 36 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-0-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 31 13 AC 62 1E 08 60 E3 84 FC B9 31 A9 E2 60 85 7E
16 : 36 : 12 <====Rx METER-2 7E A0 1D 41 00 02 04 01 74 71 15 E6 E7 00 D4 0C 20 00 00 00 32 AA F6 7E D1 3A 3C 87 26 6F 7E
16 : 36 : 12 <====Rx METER-2 D4 0C 20 00 00 00 32 AA F6 7E D1 3A 3C 87
16 : 36 : 12 <====Rx METER-2 D4 0C 20 00 00 00 32 C4 01 81 00 12 00 04
16 : 36 : 12 ====>Tx METER-2 D0 12 20 00 00 00 32 C0 01 C1 00 01 00 00 5E 5B 09 FF 02 00
16 : 36 : 12 ====>Tx METER-2 D0 12 20 00 00 00 32 62 E2 FB 76 10 72 1C 54 05 63 41 97 44
16 : 36 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-9-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 32 62 E2 FB 76 10 72 1C 54 05 63 41 97 44 7C D6 7E
16 : 36 : 12 <====Rx METER-2 7E A0 1C 41 00 02 04 01 96 B8 4E E6 E7 00 D4 0B 20 00 00 00 33 E9 B6 97 78 4D 04 48 83 7E
16 : 36 : 12 <====Rx METER-2 D4 0B 20 00 00 00 33 E9 B6 97 78 4D 04
16 : 36 : 12 <====Rx METER-2 D4 0B 20 00 00 00 33 C4 01 81 00 11 06
16 : 36 : 12 ====>Tx METER-2 D0 12 20 00 00 00 33 C0 01 C1 00 01 00 00 5E 5B 0B FF 02 00
16 : 36 : 12 ====>Tx METER-2 D0 12 20 00 00 00 33 53 2C D5 8B 74 FA 17 7F BB 48 06 67 AC
16 : 36 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-11-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 33 53 2C D5 8B 74 FA 17 7F BB 48 06 67 AC 04 9E 7E
16 : 36 : 12 <====Rx METER-2 7E A0 1E 41 00 02 04 01 B8 7F B1 E6 E7 00 D4 0D 20 00 00 00 34 A4 A2 98 07 D1 BB C3 7D 36 60 7E
16 : 36 : 12 <====Rx METER-2 D4 0D 20 00 00 00 34 A4 A2 98 07 D1 BB C3 7D
16 : 36 : 12 <====Rx METER-2 D4 0D 20 00 00 00 34 C4 01 81 00 0A 02 44 31
16 : 36 : 12 ====>Tx METER-2 D0 12 20 00 00 00 34 C0 01 C1 00 01 00 00 5E 5B 0C FF 02 00
16 : 36 : 12 ====>Tx METER-2 D0 12 20 00 00 00 34 85 DD F3 AC 0F B4 7D 58 1A C9 34 ED 5E
16 : 36 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-12-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 34 85 DD F3 AC 0F B4 7D 58 1A C9 34 ED 5E 90 B1 7E
16 : 36 : 12 <====Rx METER-2 7E A0 25 41 00 02 04 01 DA A3 51 E6 E7 00 D4 14 20 00 00 00 35 79 32 01 CC 7B 11 AA 35 92 3B D4 72 18 3A C7 C3 90 7E
16 : 36 : 13 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 13 <====Rx METER-2 D4 14 20 00 00 00 35 79 32 01 CC 7B 11 AA 35 92 3B D4 72 18 3A C7
16 : 36 : 13 <====Rx METER-2 D4 14 20 00 00 00 35 C4 01 81 00 0A 09 28 31 30 2D 36 30 29 20 41
16 : 36 : 13 METER-2 SERVICE = GET RESPONSE
16 : 36 : 13 METER-2 COSEM OUT DATA
16 : 36 : 13 ====>Tx METER-2 D0 12 20 00 00 00 35 C0 01 C1 00 01 00 00 5E 5B 12 FF 02 00
16 : 36 : 13 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 13 ====>Tx METER-2 D0 12 20 00 00 00 35 E3 53 B3 F7 8E E7 0F 79 0E 9E CB 28 C4
16 : 36 : 13 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-18-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 13 METER-2 SENDING HDLC FRAME
16 : 36 : 13 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 35 E3 53 B3 F7 8E E7 0F 79 0E 9E CB 28 C4 72 3C 7E
16 : 36 : 13 METER-2 RECEIVED HDLC FRAME
16 : 36 : 13 <====Rx METER-2 7E A0 2D 41 00 02 04 01 FC 7B CB E6 E7 00 D4 1C 20 00 00 00 36 4B DD 1D 69 C4 17 D5 C4 46 B4 72 15 CE 5C 45 26 8B 3B 8B
AC 4D 7C C0 FF 2A 7E
16 : 36 : 13 <====Rx METER-2 D4 1C 20 00 00 00 36 4B DD 1D 69 C4 17 D5 C4 46 B4 72 15 CE 5C 45 26 8B 3B 8B AC 4D 7C C0
16 : 36 : 13 <====Rx METER-2 D4 1C 20 00 00 00 36 C4 01 81 00 04 81 80 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
16 : 36 : 13 ====>Tx METER-2 D0 12 20 00 00 00 36 C0 01 C1 00 01 00 00 5E 5B 1A FF 02 00
16 : 36 : 13 ====>Tx METER-2 D0 12 20 00 00 00 36 9D 2D B4 6F CE 6C 24 41 C6 78 BC 38 ED
16 : 36 : 13 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-26-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 13 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 36 9D 2D B4 6F CE 6C 24 41 C6 78 BC 38 ED 05 6C 7E
16 : 36 : 13 <====Rx METER-2 7E A0 2D 41 00 02 04 01 1E 67 0F E6 E7 00 D4 1C 20 00 00 00 37 EF 8E 07 CE 93 E8 7E 7B 90 E4 57 7D CE C9 CC 1B 0D 83 17
14 C2 20 BC 35 69 7E
16 : 36 : 13 <====Rx METER-2 D4 1C 20 00 00 00 37 EF 8E 07 CE 93 E8 7E 7B 90 E4 57 7D CE C9 CC 1B 0D 83 17 14 C2 20 BC
16 : 36 : 13 <====Rx METER-2 D4 1C 20 00 00 00 37 C4 01 81 00 04 81 80 18 10 00 00 00 00 10 00 00 00 7F 00 00 00 00 00
16 : 36 : 13 ====>Tx METER-2 D0 12 20 00 00 00 37 C0 01 C1 00 01 00 00 5E 60 13 FF 02 00
16 : 36 : 13 ====>Tx METER-2 D0 12 20 00 00 00 37 82 F6 03 E4 04 69 E9 5E 57 FE 02 79 A0
16 : 36 : 13 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-96-19-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 13 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 37 82 F6 03 E4 04 69 E9 5E 57 FE 02 79 A0 C1 4C 7E
16 : 36 : 13 <====Rx METER-2 7E A0 1C 41 00 02 04 01 30 84 8E E6 E7 00 D4 0B 20 00 00 00 38 89 7F 6C 20 F7 DA 9A 62 7E
16 : 36 : 13 <====Rx METER-2 D4 0B 20 00 00 00 38 89 7F 6C 20 F7 DA
16 : 36 : 13 <====Rx METER-2 D4 0B 20 00 00 00 38 C4 01 81 00 11 00
16 : 36 : 13 ====>Tx METER-2 D0 12 20 00 00 00 38 C0 01 C1 00 01 00 00 5E 60 14 FF 02 00
16 : 36 : 13 ====>Tx METER-2 D0 12 20 00 00 00 38 C4 E0 EE 32 AC C1 E9 5D 45 F2 2D A1 81
16 : 36 : 13 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-96-20-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 13 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 38 C4 E0 EE 32 AC C1 E9 5D 45 F2 2D A1 81 FF B1 7E
16 : 36 : 13 <====Rx METER-2 7E A0 1C 41 00 02 04 01 52 90 CE E6 E7 00 D4 0B 20 00 00 00 39 DA 2D 05 B4 31 22 9B BD 7E
16 : 36 : 13 <====Rx METER-2 D4 0B 20 00 00 00 39 DA 2D 05 B4 31 22
16 : 36 : 13 <====Rx METER-2 D4 0B 20 00 00 00 39 C4 01 81 00 11 00
16 : 36 : 14 METER-2 COSEM OUT DATA
16 : 36 : 14 ====>Tx METER-2 D0 12 20 00 00 00 39 C0 01 C1 00 01 00 00 5E 60 15 FF 02 00
16 : 36 : 14 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 14 ====>Tx METER-2 D0 12 20 00 00 00 39 52 F7 57 FE 56 84 E3 0E CA 28 80 87 B5
16 : 36 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-96-21-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 14 METER-2 SENDING HDLC FRAME
16 : 36 : 14 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 39 52 F7 57 FE 56 84 E3 0E CA 28 80 87 B5 7F B6 7E
16 : 36 : 14 METER-2 RECEIVED HDLC FRAME
16 : 36 : 14 <====Rx METER-2 7E A0 1F 41 00 02 04 01 74 CA 22 E6 E7 00 D4 0E 20 00 00 00 3A A3 CA 6E B1 F4 3D 1C FE 46 0C 9B 7E
16 : 36 : 14 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 14 <====Rx METER-2 D4 0E 20 00 00 00 3A A3 CA 6E B1 F4 3D 1C FE 46
16 : 36 : 14 <====Rx METER-2 D4 0E 20 00 00 00 3A C4 01 81 00 06 00 00 00 00
16 : 36 : 14 METER-2 SERVICE = GET RESPONSE
16 : 36 : 14 ====>Tx METER-2 D0 12 20 00 00 00 3A C0 01 C1 00 01 00 00 5E 60 16 FF 02 00
16 : 36 : 14 ====>Tx METER-2 D0 12 20 00 00 00 3A 51 43 71 06 AE 40 52 B5 C6 B5 EE 82 85
16 : 36 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-96-22-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 14 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 3A 51 43 71 06 AE 40 52 B5 C6 B5 EE 82 85 00 D8 7E
16 : 36 : 14 <====Rx METER-2 7E A0 28 41 00 02 04 01 96 84 F7 E6 E7 00 D4 17 20 00 00 00 3B BF 04 C4 CB 76 AD 90 20 FB 75 BC 09 E8 AB B4 E7 4B 6E 14
C8 7E
16 : 36 : 14 <====Rx METER-2 D4 17 20 00 00 00 3B BF 04 C4 CB 76 AD 90 20 FB 75 BC 09 E8 AB B4 E7 4B 6E
16 : 36 : 14 <====Rx METER-2 D4 17 20 00 00 00 3B C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 14 ====>Tx METER-2 D0 12 20 00 00 00 3B C0 01 C1 00 01 00 00 5E 60 17 FF 02 00
16 : 36 : 14 ====>Tx METER-2 D0 12 20 00 00 00 3B C9 FC 5F 3B 7F CB 06 0B 09 06 28 85 CD
16 : 36 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-96-23-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 14 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 3B C9 FC 5F 3B 7F CB 06 0B 09 06 28 85 CD E9 0F 7E
16 : 36 : 14 <====Rx METER-2 7E A0 1F 41 00 02 04 01 B8 AA 2E E6 E7 00 D4 0E 20 00 00 00 3C D6 5D D5 51 EE 75 40 EA AD B1 C1 7E
16 : 36 : 14 <====Rx METER-2 D4 0E 20 00 00 00 3C D6 5D D5 51 EE 75 40 EA AD
16 : 36 : 14 <====Rx METER-2 D4 0E 20 00 00 00 3C C4 01 81 00 05 00 00 00 00
16 : 36 : 14 ====>Tx METER-2 D0 12 20 00 00 00 3C C0 01 C1 00 01 00 00 5E 60 18 FF 02 00
16 : 36 : 14 ====>Tx METER-2 D0 12 20 00 00 00 3C D5 69 DA 77 06 FF 09 D2 92 CB 5F 4D 2E
16 : 36 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-96-24-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 14 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 3C D5 69 DA 77 06 FF 09 D2 92 CB 5F 4D 2E 2E 7E 7E
16 : 36 : 14 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 00 3D 28 81 C2 33 91 D9 A0 90 79 DF F1 7E
16 : 36 : 14 <====Rx METER-2 D4 0E 20 00 00 00 3D 28 81 C2 33 91 D9 A0 90 79
16 : 36 : 14 <====Rx METER-2 D4 0E 20 00 00 00 3D C4 01 81 00 05 00 00 00 00
16 : 36 : 14 ====>Tx METER-2 D0 12 20 00 00 00 3D C0 01 C1 00 01 00 00 5E 60 19 FF 02 00
16 : 36 : 14 ====>Tx METER-2 D0 12 20 00 00 00 3D BD 17 B9 A3 52 A2 92 1D 71 FF 7B B2 84
16 : 36 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-96-25-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 15 METER-2 SENDING HDLC FRAME
16 : 36 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 3D BD 17 B9 A3 52 A2 92 1D 71 FF 7B B2 84 1F 9F 7E
16 : 36 : 15 METER-2 RECEIVED HDLC FRAME
16 : 36 : 15 <====Rx METER-2 7E A0 28 41 00 02 04 01 FC D8 3B E6 E7 00 D4 17 20 00 00 00 3E 42 9E 10 E7 BF A4 58 10 90 61 9B BB 34 E9 78 7C 92 2F 2E
42 7E
16 : 36 : 15 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 15 <====Rx METER-2 D4 17 20 00 00 00 3E 42 9E 10 E7 BF A4 58 10 90 61 9B BB 34 E9 78 7C 92 2F
16 : 36 : 15 <====Rx METER-2 D4 17 20 00 00 00 3E C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 15 METER-2 SERVICE = GET RESPONSE
16 : 36 : 15 METER-2 COSEM OUT DATA
16 : 36 : 15 ====>Tx METER-2 D0 12 20 00 00 00 3E C0 01 C1 00 01 00 00 60 01 00 FF 02 00
16 : 36 : 15 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 15 ====>Tx METER-2 D0 12 20 00 00 00 3E 55 BD 12 2E 5D 30 08 DC A7 0D B5 8F 67
16 : 36 : 15 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-1-0-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 3E 55 BD 12 2E 5D 30 08 DC A7 0D B5 8F 67 EB 5E 7E
16 : 36 : 15 <====Rx METER-2 7E A0 25 41 00 02 04 01 1E 8B D1 E6 E7 00 D4 14 20 00 00 00 3F AA 7B 95 9B 28 FB C4 71 C4 D8 84 1B 40 EF C9 32 3B 7E
16 : 36 : 15 <====Rx METER-2 D4 14 20 00 00 00 3F AA 7B 95 9B 28 FB C4 71 C4 D8 84 1B 40 EF C9
16 : 36 : 15 <====Rx METER-2 D4 14 20 00 00 00 3F C4 01 81 00 0A 09 5A 4D 30 30 30 30 30 31 30
16 : 36 : 15 ====>Tx METER-2 D0 12 20 00 00 00 3F C0 01 C1 00 01 00 00 60 01 01 FF 02 00
16 : 36 : 15 ====>Tx METER-2 D0 12 20 00 00 00 3F 43 74 AE 98 C2 7C 59 52 03 59 72 07 F4
16 : 36 : 15 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-1-1-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 3F 43 74 AE 98 C2 7C 59 52 03 59 72 07 F4 83 E6 7E
16 : 36 : 15 <====Rx METER-2 7E A0 48 41 00 02 04 01 30 3D 93 E6 E7 00 D4 37 20 00 00 00 40 72 42 4D AF 2D 3E 58 27 11 5D 97 C3 AF 92 8C E4 9F 21 29
1C 28 51 02 25 4C B9 BB AB C9 1A 63 53 88 98 76 25 37 45 4F 9B BC 43 10 A2 2C 0E 3C 8F BA D7 BE 5F 7E
16 : 36 : 15 <====Rx METER-2 D4 37 20 00 00 00 40 72 42 4D AF 2D 3E 58 27 11 5D 97 C3 AF 92 8C E4 9F 21 29 1C 28 51 02 25 4C B9 BB AB C9 1A 63 53 88
16 : 36 : 15 <====Rx METER-2 D4 37 20 00 00 00 40 C4 01 81 00 0A 2C 5A 65 6E 4D 65 74 65 72 20 53 6F 6C 75 74 69 6F 6E 73 20 50 76 74 20 4C 74 64 2E
2C 20 42 61 6E 67 61 6C 6F 72 65 20 49 6E 64 69 61
16 : 36 : 15 ====>Tx METER-2 D0 12 20 00 00 00 40 C0 01 C1 00 01 00 00 60 01 04 FF 02 00
16 : 36 : 15 ====>Tx METER-2 D0 12 20 00 00 00 40 0F 31 58 F3 CA 22 A3 75 2F AD 59 32 1F
16 : 36 : 15 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-1-4-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 40 0F 31 58 F3 CA 22 A3 75 2F AD 59 32 1F 43 20 7E
16 : 36 : 15 <====Rx METER-2 7E A0 1D 41 00 02 04 01 52 45 51 E6 E7 00 D4 0C 20 00 00 00 41 6F 35 18 44 4F 36 CF D3 47 7E
16 : 36 : 15 <====Rx METER-2 D4 0C 20 00 00 00 41 6F 35 18 44 4F 36 CF
16 : 36 : 15 <====Rx METER-2 D4 0C 20 00 00 00 41 C4 01 81 00 12 07 E3
16 : 36 : 15 ====>Tx METER-2 D0 12 20 00 00 00 41 C0 01 C1 00 01 00 00 60 02 00 FF 02 00
16 : 36 : 15 ====>Tx METER-2 D0 12 20 00 00 00 41 FD 67 FE D6 4E D3 2B 00 99 0C 42 C9 00
16 : 36 : 15 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-2-0-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 41 FD 67 FE D6 4E D3 2B 00 99 0C 42 C9 00 F3 58 7E
16 : 36 : 15 <====Rx METER-2 7E A0 1D 41 00 02 04 01 74 71 15 E6 E7 00 D4 0C 20 00 00 00 42 8F A0 FA AF C4 95 FF A1 64 7E
16 : 36 : 15 <====Rx METER-2 D4 0C 20 00 00 00 42 8F A0 FA AF C4 95 FF
16 : 36 : 16 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 36 : 16 <====Rx METER-2 D4 0C 20 00 00 00 42 C4 01 81 00 12 00 00
16 : 36 : 16 METER-2 SERVICE = GET RESPONSE
16 : 36 : 16 METER-2 COSEM OUT DATA
16 : 36 : 16 ====>Tx METER-2 D0 12 20 00 00 00 42 C0 01 C1 00 01 00 00 60 07 00 FF 02 00
16 : 36 : 16 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 16 ====>Tx METER-2 D0 12 20 00 00 00 42 B8 81 5A 28 43 08 3B 60 BB 5A 83 3E 7C
16 : 36 : 16 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-7-0-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 16 METER-2 SENDING HDLC FRAME
16 : 36 : 16 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 42 B8 81 5A 28 43 08 3B 60 BB 5A 83 3E 7C 98 01 7E
16 : 36 : 16 METER-2 RECEIVED HDLC FRAME
16 : 36 : 16 <====Rx METER-2 7E A0 1D 41 00 02 04 01 96 6D D1 E6 E7 00 D4 0C 20 00 00 00 43 0D 85 38 EA D1 99 24 96 9D 7E
16 : 36 : 16 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 16 <====Rx METER-2 D4 0C 20 00 00 00 43 0D 85 38 EA D1 99 24
16 : 36 : 16 <====Rx METER-2 D4 0C 20 00 00 00 43 C4 01 81 00 12 00 08
16 : 36 : 16 ====>Tx METER-2 D0 12 20 00 00 00 43 C0 01 C1 00 01 00 00 60 0B 00 FF 02 00
16 : 36 : 16 ====>Tx METER-2 D0 12 20 00 00 00 43 A3 F6 5D 21 75 88 E0 FD 49 97 7B 4E A6
16 : 36 : 16 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-11-0-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 16 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 43 A3 F6 5D 21 75 88 E0 FD 49 97 7B 4E A6 15 65 7E
16 : 36 : 16 <====Rx METER-2 7E A0 1D 41 00 02 04 01 B8 11 19 E6 E7 00 D4 0C 20 00 00 00 44 67 1B 99 B5 B1 1B 2D 65 93 7E
16 : 36 : 16 <====Rx METER-2 D4 0C 20 00 00 00 44 67 1B 99 B5 B1 1B 2D
16 : 36 : 16 <====Rx METER-2 D4 0C 20 00 00 00 44 C4 01 81 00 12 00 00
16 : 36 : 16 ====>Tx METER-2 D0 12 20 00 00 00 44 C0 01 C1 00 01 00 00 60 0B 01 FF 02 00
16 : 36 : 16 ====>Tx METER-2 D0 12 20 00 00 00 44 34 85 77 36 BF 54 E3 89 8F 7A EB 69 B9
16 : 36 : 16 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-11-1-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 16 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 44 34 85 77 36 BF 54 E3 89 8F 7A EB 69 B9 70 A9 7E
16 : 36 : 16 <====Rx METER-2 7E A0 1D 41 00 02 04 01 DA 05 59 E6 E7 00 D4 0C 20 00 00 00 45 1C 89 69 A3 B9 BB 84 3B 7C 7E
16 : 36 : 16 <====Rx METER-2 D4 0C 20 00 00 00 45 1C 89 69 A3 B9 BB 84
16 : 36 : 16 <====Rx METER-2 D4 0C 20 00 00 00 45 C4 01 81 00 12 00 00
16 : 36 : 16 ====>Tx METER-2 D0 12 20 00 00 00 45 C0 01 C1 00 01 00 00 60 0B 02 FF 02 00
16 : 36 : 16 ====>Tx METER-2 D0 12 20 00 00 00 45 BE DA 28 4D 39 52 E2 74 0C C3 B8 C1 1A
16 : 36 : 16 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-11-2-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 16 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 45 BE DA 28 4D 39 52 E2 74 0C C3 B8 C1 1A 89 ED 7E
16 : 36 : 16 <====Rx METER-2 7E A0 1D 41 00 02 04 01 FC 31 1D E6 E7 00 D4 0C 20 00 00 00 46 BD A2 F0 45 F7 19 EA DE B4 7E
16 : 36 : 16 <====Rx METER-2 D4 0C 20 00 00 00 46 BD A2 F0 45 F7 19 EA
16 : 36 : 16 <====Rx METER-2 D4 0C 20 00 00 00 46 C4 01 81 00 12 00 66
16 : 36 : 16 ====>Tx METER-2 D0 12 20 00 00 00 46 C0 01 C1 00 01 00 00 60 0B 03 FF 02 00
16 : 36 : 17 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 17 ====>Tx METER-2 D0 12 20 00 00 00 46 26 65 5A 28 DB 72 F8 B2 07 95 3E C5 73
16 : 36 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-11-3-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 17 METER-2 SENDING HDLC FRAME
16 : 36 : 17 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 46 26 65 5A 28 DB 72 F8 B2 07 95 3E C5 73 8E 72 7E
16 : 36 : 17 METER-2 RECEIVED HDLC FRAME
16 : 36 : 17 <====Rx METER-2 7E A0 1D 41 00 02 04 01 1E 2D D9 E6 E7 00 D4 0C 20 00 00 00 47 4C 2D FB F1 EB 19 F6 89 AB 7E
16 : 36 : 17 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 17 <====Rx METER-2 D4 0C 20 00 00 00 47 4C 2D FB F1 EB 19 F6
16 : 36 : 17 <====Rx METER-2 D4 0C 20 00 00 00 47 C4 01 81 00 12 00 00
16 : 36 : 17 METER-2 SERVICE = GET RESPONSE
16 : 36 : 17 ====>Tx METER-2 D0 12 20 00 00 00 47 C0 01 C1 00 01 00 00 60 0B 04 FF 02 00
16 : 36 : 17 ====>Tx METER-2 D0 12 20 00 00 00 47 3A D4 D3 D6 4F 71 0A D0 65 BD 37 23 0E
16 : 36 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-11-4-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 17 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 47 3A D4 D3 D6 4F 71 0A D0 65 BD 37 23 0E DA FA 7E
16 : 36 : 17 <====Rx METER-2 7E A0 1D 41 00 02 04 01 30 51 11 E6 E7 00 D4 0C 20 00 00 00 48 86 8B D5 72 C6 72 10 44 DC 7E
16 : 36 : 17 <====Rx METER-2 D4 0C 20 00 00 00 48 86 8B D5 72 C6 72 10
16 : 36 : 17 <====Rx METER-2 D4 0C 20 00 00 00 48 C4 01 81 00 12 00 D2
16 : 36 : 17 ====>Tx METER-2 D0 12 20 00 00 00 48 C0 01 C1 00 01 00 00 60 0B 05 FF 02 00
16 : 36 : 17 ====>Tx METER-2 D0 12 20 00 00 00 48 72 0C CA 70 8F DD 75 EF E7 19 B3 F0 39
16 : 36 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-11-5-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 17 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 48 72 0C CA 70 8F DD 75 EF E7 19 B3 F0 39 B7 36 7E
16 : 36 : 17 <====Rx METER-2 7E A0 1D 41 00 02 04 01 52 45 51 E6 E7 00 D4 0C 20 00 00 00 49 57 CE 1A 22 BE 2E 66 CB FE 7E
16 : 36 : 17 <====Rx METER-2 D4 0C 20 00 00 00 49 57 CE 1A 22 BE 2E 66
16 : 36 : 17 <====Rx METER-2 D4 0C 20 00 00 00 49 C4 01 81 00 12 00 00
16 : 36 : 17 ====>Tx METER-2 D0 12 20 00 00 00 49 C0 01 C1 00 01 00 00 60 0B 06 FF 02 00
16 : 36 : 17 ====>Tx METER-2 D0 12 20 00 00 00 49 17 08 75 91 55 8E 26 75 37 03 BF 15 DD
16 : 36 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-11-6-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 17 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 49 17 08 75 91 55 8E 26 75 37 03 BF 15 DD 20 AC 7E
16 : 36 : 17 <====Rx METER-2 7E A0 1D 41 00 02 04 01 74 71 15 E6 E7 00 D4 0C 20 00 00 00 4A 21 D5 38 40 23 D2 63 87 70 7E
16 : 36 : 17 <====Rx METER-2 D4 0C 20 00 00 00 4A 21 D5 38 40 23 D2 63
16 : 36 : 17 <====Rx METER-2 D4 0C 20 00 00 00 4A C4 01 81 00 12 00 00
16 : 36 : 17 ====>Tx METER-2 D0 12 20 00 00 00 4A C0 01 C1 00 01 01 00 00 02 00 FF 02 00
16 : 36 : 17 ====>Tx METER-2 D0 12 20 00 00 00 4A 52 69 B4 5E 9B F5 8A 64 11 97 32 C2 8C
16 : 36 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-0-2-0-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 17 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 4A 52 69 B4 5E 9B F5 8A 64 11 97 32 C2 8C 60 53 7E
16 : 36 : 18 METER-2 RECEIVED HDLC FRAME
16 : 36 : 18 <====Rx METER-2 7E A0 23 41 00 02 04 01 96 06 81 E6 E7 00 D4 12 20 00 00 00 4B 87 7E 74 75 2F EB 4A 0D C7 2A B6 C9 EA B7 AC 7E
16 : 36 : 18 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 18 <====Rx METER-2 D4 12 20 00 00 00 4B 87 7E 74 75 2F EB 4A 0D C7 2A B6 C9 EA
16 : 36 : 18 <====Rx METER-2 D4 12 20 00 00 00 4B C4 01 81 00 0A 07 53 31 30 36 2E 36 35
16 : 36 : 18 METER-2 SERVICE = GET RESPONSE
16 : 36 : 18 METER-2 COSEM OUT DATA
16 : 36 : 18 ====>Tx METER-2 D0 12 20 00 00 00 4B C0 01 C1 00 01 00 00 60 01 02 FF 02 00
16 : 36 : 18 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 18 ====>Tx METER-2 D0 12 20 00 00 00 4B 6C 0E 8D B0 C5 2B F6 66 F4 F4 5B 1F 91
16 : 36 : 18 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-1-2-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 18 METER-2 SENDING HDLC FRAME
16 : 36 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 4B 6C 0E 8D B0 C5 2B F6 66 F4 F4 5B 1F 91 28 0B 7E
16 : 36 : 18 <====Rx METER-2 7E A0 28 41 00 02 04 01 B8 F8 3F E6 E7 00 D4 17 20 00 00 00 4C AD FD B3 26 B3 A9 E8 B0 37 6C 7B 21 23 8E 30 D3 6B 12 4A
5A 7E
16 : 36 : 18 <====Rx METER-2 D4 17 20 00 00 00 4C AD FD B3 26 B3 A9 E8 B0 37 6C 7B 21 23 8E 30 D3 6B 12
16 : 36 : 18 <====Rx METER-2 D4 17 20 00 00 00 4C C4 01 81 00 0A 0C 5A 45 4E 5A 4D 30 30 30 30 30 31 30
16 : 36 : 18 ====>Tx METER-2 D0 12 20 00 00 00 4C C0 01 C1 00 01 01 00 00 04 02 FF 02 00
16 : 36 : 18 ====>Tx METER-2 D0 12 20 00 00 00 4C 26 96 A3 C5 5F BB 6B FF 08 0A F7 FC 6E
16 : 36 : 18 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-0-4-2-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 4C 26 96 A3 C5 5F BB 6B FF 08 0A F7 FC 6E 59 F0 7E
16 : 36 : 18 <====Rx METER-2 7E A0 1D 41 00 02 04 01 DA 05 59 E6 E7 00 D4 0C 20 00 00 00 4D 22 00 4A 41 11 81 AC 11 FE 7E
16 : 36 : 18 <====Rx METER-2 D4 0C 20 00 00 00 4D 22 00 4A 41 11 81 AC
16 : 36 : 18 <====Rx METER-2 D4 0C 20 00 00 00 4D C4 01 81 00 12 00 01
16 : 36 : 18 ====>Tx METER-2 D0 12 20 00 00 00 4D C0 01 C1 00 01 01 00 00 04 03 FF 02 00
16 : 36 : 18 ====>Tx METER-2 D0 12 20 00 00 00 4D 87 A9 3C 66 AC F3 F5 CB 26 4F FA A0 CB
16 : 36 : 18 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-0-4-3-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 4D 87 A9 3C 66 AC F3 F5 CB 26 4F FA A0 CB A4 13 7E
16 : 36 : 18 <====Rx METER-2 7E A0 1D 41 00 02 04 01 FC 31 1D E6 E7 00 D4 0C 20 00 00 00 4E F4 0C F4 C1 6E 27 84 02 67 7E
16 : 36 : 18 <====Rx METER-2 D4 0C 20 00 00 00 4E F4 0C F4 C1 6E 27 84
16 : 36 : 18 <====Rx METER-2 D4 0C 20 00 00 00 4E C4 01 81 00 12 00 01
16 : 36 : 18 ====>Tx METER-2 D0 12 20 00 00 00 4E C0 01 C1 00 01 01 00 00 08 00 FF 02 00
16 : 36 : 18 ====>Tx METER-2 D0 12 20 00 00 00 4E 5C 8F AF 7A B0 7E 6B 9C 3C D4 74 B9 43
16 : 36 : 18 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-0-8-0-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 4E 5C 8F AF 7A B0 7E 6B 9C 3C D4 74 B9 43 9C D1 7E
16 : 36 : 19 METER-2 RECEIVED HDLC FRAME
16 : 36 : 19 <====Rx METER-2 7E A0 1D 41 00 02 04 01 1E 2D D9 E6 E7 00 D4 0C 20 00 00 00 4F 61 A7 00 D3 F0 5B 2C 08 29 7E
16 : 36 : 19 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 19 <====Rx METER-2 D4 0C 20 00 00 00 4F 61 A7 00 D3 F0 5B 2C
16 : 36 : 19 <====Rx METER-2 D4 0C 20 00 00 00 4F C4 01 81 00 12 07 08
16 : 36 : 19 METER-2 SERVICE = GET RESPONSE
16 : 36 : 19 METER-2 COSEM OUT DATA
16 : 36 : 19 ====>Tx METER-2 D0 12 20 00 00 00 4F C0 01 C1 00 01 01 00 00 08 04 FF 02 00
16 : 36 : 19 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 19 ====>Tx METER-2 D0 12 20 00 00 00 4F 67 BB B6 94 5B D0 A0 A2 67 C6 B9 B3 17
16 : 36 : 19 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-0-8-4-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 19 METER-2 SENDING HDLC FRAME
16 : 36 : 19 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 4F 67 BB B6 94 5B D0 A0 A2 67 C6 B9 B3 17 E3 32 7E
16 : 36 : 19 <====Rx METER-2 7E A0 1D 41 00 02 04 01 30 51 11 E6 E7 00 D4 0C 20 00 00 00 50 E5 3C 7E 9B 03 09 83 50 19 7E
16 : 36 : 19 <====Rx METER-2 D4 0C 20 00 00 00 50 E5 3C 7E 9B 03 09 83
16 : 36 : 19 <====Rx METER-2 D4 0C 20 00 00 00 50 C4 01 81 00 12 03 84
16 : 36 : 19 ====>Tx METER-2 D0 12 20 00 00 00 50 C0 01 C1 00 01 01 00 00 08 05 FF 02 00
16 : 36 : 19 ====>Tx METER-2 D0 12 20 00 00 00 50 B8 A4 1B B8 45 F5 B3 6B 82 F2 BE BF 53
16 : 36 : 19 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-0-8-5-255, IC = 1, ATTR: INDEX = 2
16 : 36 : 19 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 50 B8 A4 1B B8 45 F5 B3 6B 82 F2 BE BF 53 D5 B6 7E
16 : 36 : 19 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 00 51 84 B8 0E 66 53 0C D1 3C 0A 1E 15 7E
16 : 36 : 19 <====Rx METER-2 D4 0E 20 00 00 00 51 84 B8 0E 66 53 0C D1 3C 0A
16 : 36 : 19 <====Rx METER-2 D4 0E 20 00 00 00 51 C4 01 81 00 06 00 01 51 80
16 : 36 : 19 ====>Tx METER-2 D0 12 20 00 00 00 51 C0 01 C1 00 03 00 00 00 01 02 FF 03 00
16 : 36 : 19 ====>Tx METER-2 D0 12 20 00 00 00 51 8A A7 0F 81 C4 03 FF 58 65 C3 91 D4 02
16 : 36 : 19 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-0-1-2-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 19 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 51 8A A7 0F 81 C4 03 FF 58 65 C3 91 D4 02 4D 15 7E
16 : 36 : 19 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 52 79 41 5A 62 E9 4F A6 25 DB A4 76 D8 7E
16 : 36 : 19 <====Rx METER-2 D4 0F 20 00 00 00 52 79 41 5A 62 E9 4F A6 25 DB A4
16 : 36 : 19 <====Rx METER-2 D4 0F 20 00 00 00 52 C4 01 81 00 02 02 0F 00 16 FF
16 : 36 : 19 ====>Tx METER-2 D0 12 20 00 00 00 52 C0 01 C1 00 03 00 00 00 01 02 FF 02 00
16 : 36 : 19 ====>Tx METER-2 D0 12 20 00 00 00 52 4C 83 65 E4 73 30 D5 D4 00 74 DF 8E 5E
16 : 36 : 19 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-0-1-2-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 19 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 52 4C 83 65 E4 73 30 D5 D4 00 74 DF 8E 5E C1 B4 7E
16 : 36 : 19 <====Rx METER-2 7E A0 28 41 00 02 04 01 96 84 F7 E6 E7 00 D4 17 20 00 00 00 53 F2 3F C3 40 12 8B D9 70 1C F0 FC FA 4F CD 93 B9 A7 23 5F
DB 7E
16 : 36 : 19 <====Rx METER-2 D4 17 20 00 00 00 53 F2 3F C3 40 12 8B D9 70 1C F0 FC FA 4F CD 93 B9 A7 23
16 : 36 : 20 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 36 : 20 <====Rx METER-2 D4 17 20 00 00 00 53 C4 01 81 00 09 0C 07 E3 0B 14 03 10 24 15 FF 01 4A 00
16 : 36 : 20 METER-2 SERVICE = GET RESPONSE
16 : 36 : 20 METER-2 COSEM OUT DATA
16 : 36 : 20 ====>Tx METER-2 D0 12 20 00 00 00 53 C0 01 C1 00 03 00 00 5E 5B 08 FF 03 00
16 : 36 : 20 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 20 ====>Tx METER-2 D0 12 20 00 00 00 53 40 22 24 3B 96 C0 7F 06 60 9E C5 ED 44
16 : 36 : 20 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-8-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 20 METER-2 SENDING HDLC FRAME
16 : 36 : 20 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 53 40 22 24 3B 96 C0 7F 06 60 9E C5 ED 44 89 8F 7E
16 : 36 : 20 METER-2 RECEIVED HDLC FRAME
16 : 36 : 20 <====Rx METER-2 7E A0 20 41 00 02 04 01 B8 14 E1 E6 E7 00 D4 0F 20 00 00 00 54 DF 3C D0 F4 C1 40 34 2E D8 E7 88 C4 7E
16 : 36 : 20 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 20 <====Rx METER-2 D4 0F 20 00 00 00 54 DF 3C D0 F4 C1 40 34 2E D8 E7
16 : 36 : 20 <====Rx METER-2 D4 0F 20 00 00 00 54 C4 01 81 00 02 02 0F 00 16 06
16 : 36 : 20 ====>Tx METER-2 D0 12 20 00 00 00 54 C0 01 C1 00 03 00 00 5E 5B 08 FF 02 00
16 : 36 : 20 ====>Tx METER-2 D0 12 20 00 00 00 54 D8 DE 9B DB B7 57 D4 F6 60 68 61 DE 04
16 : 36 : 20 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-8-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 20 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 54 D8 DE 9B DB B7 57 D4 F6 60 68 61 DE 04 C0 AF 7E
16 : 36 : 20 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 00 55 8C 4C C7 2C DC 3E 22 F4 F0 32 0E 7E
16 : 36 : 20 <====Rx METER-2 D4 0E 20 00 00 00 55 8C 4C C7 2C DC 3E 22 F4 F0
16 : 36 : 20 <====Rx METER-2 D4 0E 20 00 00 00 55 C4 01 81 00 17 45 F8 18 00
16 : 36 : 20 ====>Tx METER-2 D0 12 20 00 00 00 55 C0 01 C1 00 03 00 00 5E 5B 0E FF 03 00
16 : 36 : 20 ====>Tx METER-2 D0 12 20 00 00 00 55 EE 0B D5 A8 FF EB 3C 1B 74 1C 08 7D 93
16 : 36 : 20 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-14-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 20 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 55 EE 0B D5 A8 FF EB 3C 1B 74 1C 08 7D 93 D0 12 7E
16 : 36 : 20 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 56 17 1A 79 36 11 E6 63 76 C1 80 20 07 7E
16 : 36 : 20 <====Rx METER-2 D4 0F 20 00 00 00 56 17 1A 79 36 11 E6 63 76 C1 80
16 : 36 : 20 <====Rx METER-2 D4 0F 20 00 00 00 56 C4 01 81 00 02 02 0F 00 16 06
16 : 36 : 20 ====>Tx METER-2 D0 12 20 00 00 00 56 C0 01 C1 00 03 00 00 5E 5B 0E FF 02 00
16 : 36 : 20 ====>Tx METER-2 D0 12 20 00 00 00 56 D8 4F C2 7D 78 C0 3D AB B6 62 7F 16 0F
16 : 36 : 20 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-14-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 20 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 56 D8 4F C2 7D 78 C0 3D AB B6 62 7F 16 0F 92 46 7E
16 : 36 : 20 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 57 6F 8F F2 F9 46 5E 84 CF EC 28 BC 7E
16 : 36 : 20 <====Rx METER-2 D4 0E 20 00 00 00 57 6F 8F F2 F9 46 5E 84 CF EC
16 : 36 : 20 <====Rx METER-2 D4 0E 20 00 00 00 57 C4 01 81 00 17 44 28 C0 00
16 : 36 : 20 ====>Tx METER-2 D0 12 20 00 00 00 57 C0 01 C1 00 03 00 00 5E 5B 0D FF 03 00
16 : 36 : 21 ====>Tx METER-2 D0 12 20 00 00 00 57 94 CB 52 28 AA C0 11 DC 7C 0F F9 DF D2
16 : 36 : 21 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-13-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 21 METER-2 SENDING HDLC FRAME
16 : 36 : 21 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 57 94 CB 52 28 AA C0 11 DC 7C 0F F9 DF D2 C7 A5 7E
16 : 36 : 21 METER-2 RECEIVED HDLC FRAME
16 : 36 : 21 <====Rx METER-2 7E A0 20 41 00 02 04 01 30 54 E9 E6 E7 00 D4 0F 20 00 00 00 58 E6 D2 31 03 75 6E 4A 4F 93 33 D5 90 7E
16 : 36 : 21 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 21 <====Rx METER-2 D4 0F 20 00 00 00 58 E6 D2 31 03 75 6E 4A 4F 93 33
16 : 36 : 21 <====Rx METER-2 D4 0F 20 00 00 00 58 C4 01 81 00 02 02 0F 00 16 06
16 : 36 : 21 METER-2 SERVICE = GET RESPONSE
16 : 36 : 21 METER-2 COSEM OUT DATA
16 : 36 : 21 ====>Tx METER-2 D0 12 20 00 00 00 58 C0 01 C1 00 03 00 00 5E 5B 0D FF 02 00
16 : 36 : 21 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 21 ====>Tx METER-2 D0 12 20 00 00 00 58 1B F5 C1 62 51 97 B0 88 DB A5 32 7A 35
16 : 36 : 21 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-13-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 21 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 58 1B F5 C1 62 51 97 B0 88 DB A5 32 7A 35 86 49 7E
16 : 36 : 21 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 00 59 3E 7B D1 2B 1D B7 73 9D 23 0E 1B 7E
16 : 36 : 21 <====Rx METER-2 D4 0E 20 00 00 00 59 3E 7B D1 2B 1D B7 73 9D 23
16 : 36 : 21 <====Rx METER-2 D4 0E 20 00 00 00 59 C4 01 81 00 06 00 00 02 A3
16 : 36 : 21 ====>Tx METER-2 D0 12 20 00 00 00 59 C0 01 C1 00 03 01 00 01 07 00 FF 03 00
16 : 36 : 21 ====>Tx METER-2 D0 12 20 00 00 00 59 F8 87 01 39 1E 10 F6 5F AF 60 88 03 D3
16 : 36 : 21 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-7-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 21 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 59 F8 87 01 39 1E 10 F6 5F AF 60 88 03 D3 C3 53 7E
16 : 36 : 21 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 5A 96 31 7E 4D 22 43 B9 16 36 49 51 82 7E
16 : 36 : 21 <====Rx METER-2 D4 0F 20 00 00 00 5A 96 31 7E 4D 22 43 B9 16 36 49
16 : 36 : 21 <====Rx METER-2 D4 0F 20 00 00 00 5A C4 01 81 00 02 02 0F 00 16 1B
16 : 36 : 21 ====>Tx METER-2 D0 12 20 00 00 00 5A C0 01 C1 00 03 01 00 01 07 00 FF 02 00
16 : 36 : 21 ====>Tx METER-2 D0 12 20 00 00 00 5A 5C 2E 87 19 25 8E 42 EF 0E 06 EE C8 9B
16 : 36 : 21 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-7-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 21 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 5A 5C 2E 87 19 25 8E 42 EF 0E 06 EE C8 9B DB 88 7E
16 : 36 : 21 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 5B BC 64 A2 D1 44 39 F9 79 50 71 B1 7E
16 : 36 : 21 <====Rx METER-2 D4 0E 20 00 00 00 5B BC 64 A2 D1 44 39 F9 79 50
16 : 36 : 21 <====Rx METER-2 D4 0E 20 00 00 00 5B C4 01 81 00 17 00 00 00 00
16 : 36 : 21 ====>Tx METER-2 D0 12 20 00 00 00 5B C0 01 C1 00 03 01 00 01 08 00 FF 03 00
16 : 36 : 21 ====>Tx METER-2 D0 12 20 00 00 00 5B 04 C8 4D E0 54 F9 64 C6 F4 8D F1 64 C5
16 : 36 : 21 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-8-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 21 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 5B 04 C8 4D E0 54 F9 64 C6 F4 8D F1 64 C5 6D D7 7E
16 : 36 : 21 <====Rx METER-2 7E A0 20 41 00 02 04 01 B8 14 E1 E6 E7 00 D4 0F 20 00 00 00 5C E7 49 8D 59 83 D5 CD 7E 2D CB 0C 4A 7E
16 : 36 : 22 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 22 <====Rx METER-2 D4 0F 20 00 00 00 5C E7 49 8D 59 83 D5 CD 7E 2D CB
16 : 36 : 22 <====Rx METER-2 D4 0F 20 00 00 00 5C C4 01 81 00 02 02 0F 00 16 1E
16 : 36 : 22 METER-2 SERVICE = GET RESPONSE
16 : 36 : 22 METER-2 COSEM OUT DATA
16 : 36 : 22 ====>Tx METER-2 D0 12 20 00 00 00 5C C0 01 C1 00 03 01 00 01 08 00 FF 02 00
16 : 36 : 22 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 22 ====>Tx METER-2 D0 12 20 00 00 00 5C 02 1F E7 A6 E3 0D 1B 7D E8 4F 72 DE DD
16 : 36 : 22 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-8-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 22 METER-2 SENDING HDLC FRAME
16 : 36 : 22 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 5C 02 1F E7 A6 E3 0D 1B 7D E8 4F 72 DE DD E6 E4 7E
16 : 36 : 22 METER-2 RECEIVED HDLC FRAME
16 : 36 : 22 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 00 5D 80 86 C6 76 31 FB 59 9C 44 16 AA 7E
16 : 36 : 22 <====Rx METER-2 D4 0E 20 00 00 00 5D 80 86 C6 76 31 FB 59 9C 44
16 : 36 : 22 <====Rx METER-2 D4 0E 20 00 00 00 5D C4 01 81 00 17 00 00 00 00
16 : 36 : 22 ====>Tx METER-2 D0 12 20 00 00 00 5D C0 01 C1 00 03 01 00 01 08 01 FF 03 00
16 : 36 : 22 ====>Tx METER-2 D0 12 20 00 00 00 5D F7 EF A1 7B 91 56 AA F7 AD 41 83 2D 0E
16 : 36 : 22 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-8-1-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 22 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 5D F7 EF A1 7B 91 56 AA F7 AD 41 83 2D 0E 34 CA 7E
16 : 36 : 22 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 5E EF 3E 1F 34 E7 0B BD F5 CC A8 55 49 7E
16 : 36 : 22 <====Rx METER-2 D4 0F 20 00 00 00 5E EF 3E 1F 34 E7 0B BD F5 CC A8
16 : 36 : 22 <====Rx METER-2 D4 0F 20 00 00 00 5E C4 01 81 00 02 02 0F 00 16 1E
16 : 36 : 22 ====>Tx METER-2 D0 12 20 00 00 00 5E C0 01 C1 00 03 01 00 01 08 01 FF 02 00
16 : 36 : 22 ====>Tx METER-2 D0 12 20 00 00 00 5E 8C CE BD EA 09 00 79 C9 54 A6 4D 09 B4
16 : 36 : 22 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-8-1-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 22 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 5E 8C CE BD EA 09 00 79 C9 54 A6 4D 09 B4 7D 2B 7E
16 : 36 : 22 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 5F CD 2C D5 C0 3C 2D 92 67 0D C8 2E 7E
16 : 36 : 22 <====Rx METER-2 D4 0E 20 00 00 00 5F CD 2C D5 C0 3C 2D 92 67 0D
16 : 36 : 22 <====Rx METER-2 D4 0E 20 00 00 00 5F C4 01 81 00 17 00 00 00 00
16 : 36 : 22 ====>Tx METER-2 D0 12 20 00 00 00 5F C0 01 C1 00 03 01 00 01 08 02 FF 03 00
16 : 36 : 22 ====>Tx METER-2 D0 12 20 00 00 00 5F 2B 8A C7 C0 78 0F 9A 9D 0E 27 F5 62 44
16 : 36 : 22 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-8-2-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 22 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 5F 2B 8A C7 C0 78 0F 9A 9D 0E 27 F5 62 44 07 42 7E
16 : 36 : 22 <====Rx METER-2 7E A0 20 41 00 02 04 01 30 54 E9 E6 E7 00 D4 0F 20 00 00 00 60 E9 C2 A0 5E B1 27 E1 8C 9F 61 25 78 7E
16 : 36 : 22 <====Rx METER-2 D4 0F 20 00 00 00 60 E9 C2 A0 5E B1 27 E1 8C 9F 61
16 : 36 : 22 <====Rx METER-2 D4 0F 20 00 00 00 60 C4 01 81 00 02 02 0F 00 16 1E
16 : 36 : 23 METER-2 COSEM OUT DATA
16 : 36 : 23 ====>Tx METER-2 D0 12 20 00 00 00 60 C0 01 C1 00 03 01 00 01 08 02 FF 02 00
16 : 36 : 23 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 23 ====>Tx METER-2 D0 12 20 00 00 00 60 08 A0 4E DD EF 14 19 35 E1 CA 1C DC EF
16 : 36 : 23 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-8-2-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 23 METER-2 SENDING HDLC FRAME
16 : 36 : 23 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 60 08 A0 4E DD EF 14 19 35 E1 CA 1C DC EF 80 9B 7E
16 : 36 : 23 METER-2 RECEIVED HDLC FRAME
16 : 36 : 23 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 00 61 99 E2 2F C0 52 21 E7 36 46 7C CF 7E
16 : 36 : 23 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 23 <====Rx METER-2 D4 0E 20 00 00 00 61 99 E2 2F C0 52 21 E7 36 46
16 : 36 : 23 <====Rx METER-2 D4 0E 20 00 00 00 61 C4 01 81 00 17 00 00 00 00
16 : 36 : 23 METER-2 SERVICE = GET RESPONSE
16 : 36 : 23 ====>Tx METER-2 D0 12 20 00 00 00 61 C0 01 C1 00 03 01 00 01 08 03 FF 03 00
16 : 36 : 23 ====>Tx METER-2 D0 12 20 00 00 00 61 B2 9E B2 EA FC 87 C4 9C D0 2A 28 B7 41
16 : 36 : 23 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-8-3-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 23 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 61 B2 9E B2 EA FC 87 C4 9C D0 2A 28 B7 41 53 42 7E
16 : 36 : 23 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 62 6B 2C 80 B2 7C 0E A5 0B B2 79 7C EA 7E
16 : 36 : 23 <====Rx METER-2 D4 0F 20 00 00 00 62 6B 2C 80 B2 7C 0E A5 0B B2 79
16 : 36 : 23 <====Rx METER-2 D4 0F 20 00 00 00 62 C4 01 81 00 02 02 0F 00 16 1E
16 : 36 : 23 ====>Tx METER-2 D0 12 20 00 00 00 62 C0 01 C1 00 03 01 00 01 08 03 FF 02 00
16 : 36 : 23 ====>Tx METER-2 D0 12 20 00 00 00 62 31 47 17 07 5D D7 6E C8 89 9F 7C 81 27
16 : 36 : 23 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-8-3-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 23 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 62 31 47 17 07 5D D7 6E C8 89 9F 7C 81 27 95 88 7E
16 : 36 : 23 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 63 F9 D9 6A 2B 45 6A 4D D3 72 0A 9A 7E
16 : 36 : 23 <====Rx METER-2 D4 0E 20 00 00 00 63 F9 D9 6A 2B 45 6A 4D D3 72
16 : 36 : 23 <====Rx METER-2 D4 0E 20 00 00 00 63 C4 01 81 00 17 00 00 00 00
16 : 36 : 23 ====>Tx METER-2 D0 12 20 00 00 00 63 C0 01 C1 00 03 01 00 01 08 04 FF 03 00
16 : 36 : 23 ====>Tx METER-2 D0 12 20 00 00 00 63 E5 61 E8 D5 A8 17 3B F8 A9 C0 70 D4 97
16 : 36 : 23 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-8-4-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 23 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 63 E5 61 E8 D5 A8 17 3B F8 A9 C0 70 D4 97 2E 93 7E
16 : 36 : 23 <====Rx METER-2 7E A0 20 41 00 02 04 01 B8 14 E1 E6 E7 00 D4 0F 20 00 00 00 64 FC 04 30 17 14 FD 9B 0E 11 AC C7 EB 7E
16 : 36 : 23 <====Rx METER-2 D4 0F 20 00 00 00 64 FC 04 30 17 14 FD 9B 0E 11 AC
16 : 36 : 23 <====Rx METER-2 D4 0F 20 00 00 00 64 C4 01 81 00 02 02 0F 00 16 1E
16 : 36 : 23 ====>Tx METER-2 D0 12 20 00 00 00 64 C0 01 C1 00 03 01 00 01 08 04 FF 02 00
16 : 36 : 23 ====>Tx METER-2 D0 12 20 00 00 00 64 37 B7 E3 D0 C7 CE 60 82 7D 71 27 9C B0
16 : 36 : 23 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-8-4-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 24 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 64 37 B7 E3 D0 C7 CE 60 82 7D 71 27 9C B0 62 69 7E
16 : 36 : 24 METER-2 RECEIVED HDLC FRAME
16 : 36 : 24 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 00 65 71 DB 58 9F 39 A2 13 45 53 B9 A3 7E
16 : 36 : 24 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 24 <====Rx METER-2 D4 0E 20 00 00 00 65 71 DB 58 9F 39 A2 13 45 53
16 : 36 : 24 <====Rx METER-2 D4 0E 20 00 00 00 65 C4 01 81 00 17 00 00 00 00
16 : 36 : 24 METER-2 SERVICE = GET RESPONSE
16 : 36 : 24 METER-2 COSEM OUT DATA
16 : 36 : 24 ====>Tx METER-2 D0 12 20 00 00 00 65 C0 01 C1 00 03 01 00 02 08 00 FF 03 00
16 : 36 : 24 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 24 ====>Tx METER-2 D0 12 20 00 00 00 65 36 B9 35 94 7B 6F E7 13 C8 D0 90 09 06
16 : 36 : 24 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-8-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 24 METER-2 SENDING HDLC FRAME
16 : 36 : 24 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 65 36 B9 35 94 7B 6F E7 13 C8 D0 90 09 06 42 20 7E
16 : 36 : 24 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 66 86 40 5D 17 98 FE 88 0D 17 CF 9B CB 7E
16 : 36 : 24 <====Rx METER-2 D4 0F 20 00 00 00 66 86 40 5D 17 98 FE 88 0D 17 CF
16 : 36 : 24 <====Rx METER-2 D4 0F 20 00 00 00 66 C4 01 81 00 02 02 0F 00 16 1E
16 : 36 : 24 ====>Tx METER-2 D0 12 20 00 00 00 66 C0 01 C1 00 03 01 00 02 08 00 FF 02 00
16 : 36 : 24 ====>Tx METER-2 D0 12 20 00 00 00 66 29 10 ED B0 85 27 E5 F6 EB 4A EB 9C 91
16 : 36 : 24 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-8-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 24 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 66 29 10 ED B0 85 27 E5 F6 EB 4A EB 9C 91 A9 31 7E
16 : 36 : 24 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 67 29 1E CF BD 54 FD 25 76 E5 6A 7B 7E
16 : 36 : 24 <====Rx METER-2 D4 0E 20 00 00 00 67 29 1E CF BD 54 FD 25 76 E5
16 : 36 : 24 <====Rx METER-2 D4 0E 20 00 00 00 67 C4 01 81 00 17 00 00 00 00
16 : 36 : 24 ====>Tx METER-2 D0 12 20 00 00 00 67 C0 01 C1 00 03 01 00 02 08 01 FF 03 00
16 : 36 : 24 ====>Tx METER-2 D0 12 20 00 00 00 67 A6 6F 6D 5C DC 7C C1 34 D5 88 EA 47 08
16 : 36 : 24 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-8-1-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 24 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 67 A6 6F 6D 5C DC 7C C1 34 D5 88 EA 47 08 14 A7 7E
16 : 36 : 24 <====Rx METER-2 7E A0 20 41 00 02 04 01 30 54 E9 E6 E7 00 D4 0F 20 00 00 00 68 A1 C7 A9 30 05 5E 6B 41 B7 CD 9B 10 7E
16 : 36 : 24 <====Rx METER-2 D4 0F 20 00 00 00 68 A1 C7 A9 30 05 5E 6B 41 B7 CD
16 : 36 : 24 <====Rx METER-2 D4 0F 20 00 00 00 68 C4 01 81 00 02 02 0F 00 16 1E
16 : 36 : 24 ====>Tx METER-2 D0 12 20 00 00 00 68 C0 01 C1 00 03 01 00 02 08 01 FF 02 00
16 : 36 : 24 ====>Tx METER-2 D0 12 20 00 00 00 68 87 2B 6D 84 D0 29 04 D5 CA 6E C9 56 26
16 : 36 : 24 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-8-1-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 24 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 68 87 2B 6D 84 D0 29 04 D5 CA 6E C9 56 26 9C C5 7E
16 : 36 : 24 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 00 69 BC F6 A9 01 65 D8 93 E3 01 9E 2D 7E
16 : 36 : 24 <====Rx METER-2 D4 0E 20 00 00 00 69 BC F6 A9 01 65 D8 93 E3 01
16 : 36 : 25 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 36 : 25 <====Rx METER-2 D4 0E 20 00 00 00 69 C4 01 81 00 17 00 00 00 00
16 : 36 : 25 METER-2 SERVICE = GET RESPONSE
16 : 36 : 25 METER-2 COSEM OUT DATA
16 : 36 : 25 ====>Tx METER-2 D0 12 20 00 00 00 69 C0 01 C1 00 03 01 00 02 08 02 FF 03 00
16 : 36 : 25 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 25 ====>Tx METER-2 D0 12 20 00 00 00 69 D9 62 84 3A 46 1C 81 93 8A 17 B8 44 5C
16 : 36 : 25 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-8-2-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 25 METER-2 SENDING HDLC FRAME
16 : 36 : 25 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 69 D9 62 84 3A 46 1C 81 93 8A 17 B8 44 5C 31 28 7E
16 : 36 : 25 METER-2 RECEIVED HDLC FRAME
16 : 36 : 25 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 6A 09 CF 35 A6 65 C9 8F 52 C9 79 6C DF 7E
16 : 36 : 25 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 25 <====Rx METER-2 D4 0F 20 00 00 00 6A 09 CF 35 A6 65 C9 8F 52 C9 79
16 : 36 : 25 <====Rx METER-2 D4 0F 20 00 00 00 6A C4 01 81 00 02 02 0F 00 16 1E
16 : 36 : 25 ====>Tx METER-2 D0 12 20 00 00 00 6A C0 01 C1 00 03 01 00 02 08 02 FF 02 00
16 : 36 : 25 ====>Tx METER-2 D0 12 20 00 00 00 6A 41 60 5E 60 7B F5 20 76 DA FD 3C 15 9A
16 : 36 : 25 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-8-2-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 25 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 6A 41 60 5E 60 7B F5 20 76 DA FD 3C 15 9A AD D5 7E
16 : 36 : 25 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 6B 12 F6 99 70 AA 7B 28 A7 16 2C CA 7E
16 : 36 : 25 <====Rx METER-2 D4 0E 20 00 00 00 6B 12 F6 99 70 AA 7B 28 A7 16
16 : 36 : 25 <====Rx METER-2 D4 0E 20 00 00 00 6B C4 01 81 00 17 00 00 00 00
16 : 36 : 25 ====>Tx METER-2 D0 12 20 00 00 00 6B C0 01 C1 00 03 01 00 02 08 03 FF 03 00
16 : 36 : 25 ====>Tx METER-2 D0 12 20 00 00 00 6B AC C2 F6 33 E3 CE A5 00 9F C9 FB E7 A9
16 : 36 : 25 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-8-3-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 25 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 6B AC C2 F6 33 E3 CE A5 00 9F C9 FB E7 A9 AA 8F 7E
16 : 36 : 25 <====Rx METER-2 7E A0 20 41 00 02 04 01 B8 14 E1 E6 E7 00 D4 0F 20 00 00 00 6C 73 E7 7B EA F4 C9 FD FE 56 9E 29 1C 7E
16 : 36 : 25 <====Rx METER-2 D4 0F 20 00 00 00 6C 73 E7 7B EA F4 C9 FD FE 56 9E
16 : 36 : 25 <====Rx METER-2 D4 0F 20 00 00 00 6C C4 01 81 00 02 02 0F 00 16 1E
16 : 36 : 25 ====>Tx METER-2 D0 12 20 00 00 00 6C C0 01 C1 00 03 01 00 02 08 03 FF 02 00
16 : 36 : 25 ====>Tx METER-2 D0 12 20 00 00 00 6C A7 0E 1C 8A EE F7 DD F5 BE 5B 63 A9 02
16 : 36 : 25 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-8-3-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 25 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 6C A7 0E 1C 8A EE F7 DD F5 BE 5B 63 A9 02 2E 7A 7E
16 : 36 : 25 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 00 6D 27 96 3B B3 11 F6 A7 CC 31 83 7F 7E
16 : 36 : 25 <====Rx METER-2 D4 0E 20 00 00 00 6D 27 96 3B B3 11 F6 A7 CC 31
16 : 36 : 25 <====Rx METER-2 D4 0E 20 00 00 00 6D C4 01 81 00 17 00 00 00 00
16 : 36 : 25 ====>Tx METER-2 D0 12 20 00 00 00 6D C0 01 C1 00 03 01 00 02 08 04 FF 03 00
16 : 36 : 26 ====>Tx METER-2 D0 12 20 00 00 00 6D 09 B1 DA 03 EC 6E 08 B4 6C BC 2F 4E EB
16 : 36 : 26 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-8-4-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 26 METER-2 SENDING HDLC FRAME
16 : 36 : 26 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 6D 09 B1 DA 03 EC 6E 08 B4 6C BC 2F 4E EB 7A C0 7E
16 : 36 : 26 METER-2 RECEIVED HDLC FRAME
16 : 36 : 26 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 6E 42 7A 75 C0 91 77 A0 09 D4 BB F2 52 7E
16 : 36 : 26 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 26 <====Rx METER-2 D4 0F 20 00 00 00 6E 42 7A 75 C0 91 77 A0 09 D4 BB
16 : 36 : 26 <====Rx METER-2 D4 0F 20 00 00 00 6E C4 01 81 00 02 02 0F 00 16 1E
16 : 36 : 26 METER-2 SERVICE = GET RESPONSE
16 : 36 : 26 METER-2 COSEM OUT DATA
16 : 36 : 26 ====>Tx METER-2 D0 12 20 00 00 00 6E C0 01 C1 00 03 01 00 02 08 04 FF 02 00
16 : 36 : 26 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 26 ====>Tx METER-2 D0 12 20 00 00 00 6E C4 56 41 2D C3 26 CA 94 F6 CB F3 8C 02
16 : 36 : 26 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-8-4-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 26 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 6E C4 56 41 2D C3 26 CA 94 F6 CB F3 8C 02 7B 08 7E
16 : 36 : 26 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 6F 93 88 E0 DF 2E B7 FA 17 5C FF 40 7E
16 : 36 : 26 <====Rx METER-2 D4 0E 20 00 00 00 6F 93 88 E0 DF 2E B7 FA 17 5C
16 : 36 : 26 <====Rx METER-2 D4 0E 20 00 00 00 6F C4 01 81 00 17 00 00 00 00
16 : 36 : 26 ====>Tx METER-2 D0 12 20 00 00 00 6F C0 01 C1 00 03 01 00 03 07 00 FF 03 00
16 : 36 : 26 ====>Tx METER-2 D0 12 20 00 00 00 6F 0A 19 5C AB 37 BE 6E F3 58 B8 A4 D2 8C
16 : 36 : 26 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-3-7-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 26 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 6F 0A 19 5C AB 37 BE 6E F3 58 B8 A4 D2 8C 2E D6 7E
16 : 36 : 26 <====Rx METER-2 7E A0 20 41 00 02 04 01 30 54 E9 E6 E7 00 D4 0F 20 00 00 00 70 41 41 41 69 2D F7 D7 3D 3D 90 BA D0 7E
16 : 36 : 26 <====Rx METER-2 D4 0F 20 00 00 00 70 41 41 41 69 2D F7 D7 3D 3D 90
16 : 36 : 26 <====Rx METER-2 D4 0F 20 00 00 00 70 C4 01 81 00 02 02 0F 00 16 1D
16 : 36 : 26 ====>Tx METER-2 D0 12 20 00 00 00 70 C0 01 C1 00 03 01 00 03 07 00 FF 02 00
16 : 36 : 26 ====>Tx METER-2 D0 12 20 00 00 00 70 6D 12 8E A9 B1 99 54 33 80 16 A6 14 31
16 : 36 : 26 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-3-7-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 26 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 70 6D 12 8E A9 B1 99 54 33 80 16 A6 14 31 06 9F 7E
16 : 36 : 26 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 00 71 0F 4C 1E 53 CE DA F8 EF 30 46 62 7E
16 : 36 : 26 <====Rx METER-2 D4 0E 20 00 00 00 71 0F 4C 1E 53 CE DA F8 EF 30
16 : 36 : 26 <====Rx METER-2 D4 0E 20 00 00 00 71 C4 01 81 00 17 00 00 00 00
16 : 36 : 26 ====>Tx METER-2 D0 12 20 00 00 00 71 C0 01 C1 00 03 01 00 05 08 00 FF 03 00
16 : 36 : 26 ====>Tx METER-2 D0 12 20 00 00 00 71 60 6B 12 CC DA 62 79 BD 51 EC 4B 6E 80
16 : 36 : 26 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-5-8-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 26 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 71 60 6B 12 CC DA 62 79 BD 51 EC 4B 6E 80 CA 74 7E
16 : 36 : 27 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 72 2D D5 4E C7 60 40 58 B9 24 5F 76 5C 7E
16 : 36 : 27 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 27 <====Rx METER-2 D4 0F 20 00 00 00 72 2D D5 4E C7 60 40 58 B9 24 5F
16 : 36 : 27 <====Rx METER-2 D4 0F 20 00 00 00 72 C4 01 81 00 02 02 0F 00 16 20
16 : 36 : 27 METER-2 SERVICE = GET RESPONSE
16 : 36 : 27 METER-2 COSEM OUT DATA
16 : 36 : 27 ====>Tx METER-2 D0 12 20 00 00 00 72 C0 01 C1 00 03 01 00 05 08 00 FF 02 00
16 : 36 : 27 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 27 ====>Tx METER-2 D0 12 20 00 00 00 72 E9 B4 03 23 64 3B 29 DD 1C 8C 70 C2 F5
16 : 36 : 27 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-5-8-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 27 METER-2 SENDING HDLC FRAME
16 : 36 : 27 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 72 E9 B4 03 23 64 3B 29 DD 1C 8C 70 C2 F5 3B 72 7E
16 : 36 : 27 METER-2 RECEIVED HDLC FRAME
16 : 36 : 27 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 73 F6 BE D2 F8 19 31 A7 40 23 C9 4B 7E
16 : 36 : 27 <====Rx METER-2 D4 0E 20 00 00 00 73 F6 BE D2 F8 19 31 A7 40 23
16 : 36 : 27 <====Rx METER-2 D4 0E 20 00 00 00 73 C4 01 81 00 17 00 00 00 00
16 : 36 : 27 ====>Tx METER-2 D0 12 20 00 00 00 73 C0 01 C1 00 03 01 00 08 08 00 FF 03 00
16 : 36 : 27 ====>Tx METER-2 D0 12 20 00 00 00 73 49 54 F2 7A 3D 83 8E FD CD BA EA FB 68
16 : 36 : 27 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-8-8-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 27 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 73 49 54 F2 7A 3D 83 8E FD CD BA EA FB 68 9A 52 7E
16 : 36 : 27 <====Rx METER-2 7E A0 20 41 00 02 04 01 B8 14 E1 E6 E7 00 D4 0F 20 00 00 00 74 FF 42 0F 02 DE 4C 9C 86 AA DE 26 DD 7E
16 : 36 : 27 <====Rx METER-2 D4 0F 20 00 00 00 74 FF 42 0F 02 DE 4C 9C 86 AA DE
16 : 36 : 27 <====Rx METER-2 D4 0F 20 00 00 00 74 C4 01 81 00 02 02 0F 00 16 20
16 : 36 : 27 ====>Tx METER-2 D0 12 20 00 00 00 74 C0 01 C1 00 03 01 00 08 08 00 FF 02 00
16 : 36 : 27 ====>Tx METER-2 D0 12 20 00 00 00 74 C6 CA 14 58 87 F6 43 08 61 F1 03 AE EF
16 : 36 : 27 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-8-8-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 27 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 74 C6 CA 14 58 87 F6 43 08 61 F1 03 AE EF 86 D4 7E
16 : 36 : 27 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 00 75 2A 6A 2B C2 BC 4F 95 3E F0 54 60 7E
16 : 36 : 27 <====Rx METER-2 D4 0E 20 00 00 00 75 2A 6A 2B C2 BC 4F 95 3E F0
16 : 36 : 27 <====Rx METER-2 D4 0E 20 00 00 00 75 C4 01 81 00 17 00 00 00 00
16 : 36 : 27 ====>Tx METER-2 D0 12 20 00 00 00 75 C0 01 C1 00 03 01 00 09 07 00 FF 03 00
16 : 36 : 27 ====>Tx METER-2 D0 12 20 00 00 00 75 E4 E6 71 AC 6A 01 CB EF C3 41 11 40 97
16 : 36 : 27 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-7-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 27 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 75 E4 E6 71 AC 6A 01 CB EF C3 41 11 40 97 43 C9 7E
16 : 36 : 27 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 76 3E 28 95 D8 4C 70 2F E1 CD DA CD B8 7E
16 : 36 : 27 <====Rx METER-2 D4 0F 20 00 00 00 76 3E 28 95 D8 4C 70 2F E1 CD DA
16 : 36 : 27 <====Rx METER-2 D4 0F 20 00 00 00 76 C4 01 81 00 02 02 0F 00 16 1C
16 : 36 : 28 METER-2 SERVICE = GET RESPONSE
16 : 36 : 28 METER-2 COSEM OUT DATA
16 : 36 : 28 ====>Tx METER-2 D0 12 20 00 00 00 76 C0 01 C1 00 03 01 00 09 07 00 FF 02 00
16 : 36 : 28 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 28 ====>Tx METER-2 D0 12 20 00 00 00 76 DC 19 DD D6 33 A6 95 CA EC 39 FC 00 17
16 : 36 : 28 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-7-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 28 METER-2 SENDING HDLC FRAME
16 : 36 : 28 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 76 DC 19 DD D6 33 A6 95 CA EC 39 FC 00 17 D9 65 7E
16 : 36 : 28 METER-2 RECEIVED HDLC FRAME
16 : 36 : 28 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 77 D0 4F 0D 59 44 27 F4 CD 4F EC 7B 7E
16 : 36 : 28 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 28 <====Rx METER-2 D4 0E 20 00 00 00 77 D0 4F 0D 59 44 27 F4 CD 4F
16 : 36 : 28 <====Rx METER-2 D4 0E 20 00 00 00 77 C4 01 81 00 17 00 00 00 00
16 : 36 : 28 ====>Tx METER-2 D0 12 20 00 00 00 77 C0 01 C1 00 03 01 00 09 08 00 FF 03 00
16 : 36 : 28 ====>Tx METER-2 D0 12 20 00 00 00 77 D6 AE 0F DB E9 10 27 C1 4D 46 CD 85 04
16 : 36 : 28 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-8-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 28 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 77 D6 AE 0F DB E9 10 27 C1 4D 46 CD 85 04 F8 12 7E
16 : 36 : 28 <====Rx METER-2 7E A0 20 41 00 02 04 01 30 54 E9 E6 E7 00 D4 0F 20 00 00 00 78 DC A7 49 F0 32 1B 8E E0 19 91 D5 ED 7E
16 : 36 : 28 <====Rx METER-2 D4 0F 20 00 00 00 78 DC A7 49 F0 32 1B 8E E0 19 91
16 : 36 : 28 <====Rx METER-2 D4 0F 20 00 00 00 78 C4 01 81 00 02 02 0F 00 16 1F
16 : 36 : 28 ====>Tx METER-2 D0 12 20 00 00 00 78 C0 01 C1 00 03 01 00 09 08 00 FF 02 00
16 : 36 : 28 ====>Tx METER-2 D0 12 20 00 00 00 78 7C 14 74 EB 0A 6F 23 FE 70 D0 33 1A 74
16 : 36 : 28 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-8-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 28 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 78 7C 14 74 EB 0A 6F 23 FE 70 D0 33 1A 74 44 F5 7E
16 : 36 : 28 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 00 79 D7 57 2A 9B FF BF 11 F9 BF A1 CA 7E
16 : 36 : 28 <====Rx METER-2 D4 0E 20 00 00 00 79 D7 57 2A 9B FF BF 11 F9 BF
16 : 36 : 28 <====Rx METER-2 D4 0E 20 00 00 00 79 C4 01 81 00 17 00 00 00 00
16 : 36 : 28 ====>Tx METER-2 D0 12 20 00 00 00 79 C0 01 C1 00 03 01 00 09 08 01 FF 03 00
16 : 36 : 28 ====>Tx METER-2 D0 12 20 00 00 00 79 63 97 E2 7B D4 C0 E6 BC 86 ED 3C 6E 0B
16 : 36 : 28 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-8-1-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 28 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 79 63 97 E2 7B D4 C0 E6 BC 86 ED 3C 6E 0B CC EF 7E
16 : 36 : 28 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 7A F8 C8 7A DD 99 67 4F 45 7F F8 56 E6 7E
16 : 36 : 28 <====Rx METER-2 D4 0F 20 00 00 00 7A F8 C8 7A DD 99 67 4F 45 7F F8
16 : 36 : 28 <====Rx METER-2 D4 0F 20 00 00 00 7A C4 01 81 00 02 02 0F 00 16 1F
16 : 36 : 28 ====>Tx METER-2 D0 12 20 00 00 00 7A C0 01 C1 00 03 01 00 09 08 01 FF 02 00
16 : 36 : 28 ====>Tx METER-2 D0 12 20 00 00 00 7A C8 BC E5 03 35 32 D6 62 CC 9C FF 10 29
16 : 36 : 29 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-8-1-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 29 METER-2 SENDING HDLC FRAME
16 : 36 : 29 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 7A C8 BC E5 03 35 32 D6 62 CC 9C FF 10 29 6F 40 7E
16 : 36 : 29 METER-2 RECEIVED HDLC FRAME
16 : 36 : 29 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 7B 03 7B C3 BF DF A1 FF D3 07 9D F8 7E
16 : 36 : 29 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 29 <====Rx METER-2 D4 0E 20 00 00 00 7B 03 7B C3 BF DF A1 FF D3 07
16 : 36 : 29 <====Rx METER-2 D4 0E 20 00 00 00 7B C4 01 81 00 17 00 00 00 00
16 : 36 : 29 METER-2 SERVICE = GET RESPONSE
16 : 36 : 29 METER-2 COSEM OUT DATA
16 : 36 : 29 ====>Tx METER-2 D0 12 20 00 00 00 7B C0 01 C1 00 03 01 00 09 08 02 FF 03 00
16 : 36 : 29 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 29 ====>Tx METER-2 D0 12 20 00 00 00 7B 57 98 EF 43 72 4C A0 F7 2F F3 DC D7 81
16 : 36 : 29 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-8-2-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 29 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 7B 57 98 EF 43 72 4C A0 F7 2F F3 DC D7 81 80 0D 7E
16 : 36 : 29 <====Rx METER-2 7E A0 20 41 00 02 04 01 B8 14 E1 E6 E7 00 D4 0F 20 00 00 00 7C 69 E6 04 43 A0 80 B6 9B 60 C6 AE 48 7E
16 : 36 : 29 <====Rx METER-2 D4 0F 20 00 00 00 7C 69 E6 04 43 A0 80 B6 9B 60 C6
16 : 36 : 29 <====Rx METER-2 D4 0F 20 00 00 00 7C C4 01 81 00 02 02 0F 00 16 1F
16 : 36 : 29 ====>Tx METER-2 D0 12 20 00 00 00 7C C0 01 C1 00 03 01 00 09 08 02 FF 02 00
16 : 36 : 29 ====>Tx METER-2 D0 12 20 00 00 00 7C 6F 49 07 DE 8E F5 82 7B 40 5C 00 3D 12
16 : 36 : 29 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-8-2-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 29 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 7C 6F 49 07 DE 8E F5 82 7B 40 5C 00 3D 12 D7 91 7E
16 : 36 : 29 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 00 7D 3C 57 F1 2D 17 EC 83 05 B6 10 AB 7E
16 : 36 : 29 <====Rx METER-2 D4 0E 20 00 00 00 7D 3C 57 F1 2D 17 EC 83 05 B6
16 : 36 : 29 <====Rx METER-2 D4 0E 20 00 00 00 7D C4 01 81 00 17 00 00 00 00
16 : 36 : 29 ====>Tx METER-2 D0 12 20 00 00 00 7D C0 01 C1 00 03 01 00 09 08 03 FF 03 00
16 : 36 : 29 ====>Tx METER-2 D0 12 20 00 00 00 7D 50 C3 3D 3A 88 68 03 63 6F 39 DB 97 CE
16 : 36 : 29 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-8-3-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 29 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 7D 50 C3 3D 3A 88 68 03 63 6F 39 DB 97 CE 73 19 7E
16 : 36 : 29 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 7E 93 64 0F 87 AD 9C 91 0E 8B F2 22 6D 7E
16 : 36 : 29 <====Rx METER-2 D4 0F 20 00 00 00 7E 93 64 0F 87 AD 9C 91 0E 8B F2
16 : 36 : 29 <====Rx METER-2 D4 0F 20 00 00 00 7E C4 01 81 00 02 02 0F 00 16 1F
16 : 36 : 29 ====>Tx METER-2 D0 12 20 00 00 00 7E C0 01 C1 00 03 01 00 09 08 03 FF 02 00
16 : 36 : 29 ====>Tx METER-2 D0 12 20 00 00 00 7E 66 DC F3 9E 72 02 EC B8 4F 1D 02 0E F5
16 : 36 : 29 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-8-3-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 29 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 7E 66 DC F3 9E 72 02 EC B8 4F 1D 02 0E F5 38 FA 7E
16 : 36 : 29 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 7F 34 B7 B0 0C E0 6C 28 CC F0 0A D3 7E
16 : 36 : 30 <====Rx METER-2 D4 0E 20 00 00 00 7F 34 B7 B0 0C E0 6C 28 CC F0
16 : 36 : 30 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 36 : 30 <====Rx METER-2 D4 0E 20 00 00 00 7F C4 01 81 00 17 00 00 00 00
16 : 36 : 30 METER-2 SERVICE = GET RESPONSE
16 : 36 : 30 METER-2 COSEM OUT DATA
16 : 36 : 30 ====>Tx METER-2 D0 12 20 00 00 00 7F C0 01 C1 00 03 01 00 09 08 04 FF 03 00
16 : 36 : 30 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 30 ====>Tx METER-2 D0 12 20 00 00 00 7F E9 52 D8 62 E0 26 A3 B4 5D 28 81 F0 85
16 : 36 : 30 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-8-4-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 30 METER-2 SENDING HDLC FRAME
16 : 36 : 30 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 7F E9 52 D8 62 E0 26 A3 B4 5D 28 81 F0 85 1D 39 7E
16 : 36 : 30 METER-2 RECEIVED HDLC FRAME
16 : 36 : 30 <====Rx METER-2 7E A0 20 41 00 02 04 01 30 54 E9 E6 E7 00 D4 0F 20 00 00 00 80 CF 23 E6 C1 08 FE EA BD 21 4A 5C 21 7E
16 : 36 : 30 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 30 <====Rx METER-2 D4 0F 20 00 00 00 80 CF 23 E6 C1 08 FE EA BD 21 4A
16 : 36 : 30 <====Rx METER-2 D4 0F 20 00 00 00 80 C4 01 81 00 02 02 0F 00 16 1F
16 : 36 : 30 ====>Tx METER-2 D0 12 20 00 00 00 80 C0 01 C1 00 03 01 00 09 08 04 FF 02 00
16 : 36 : 30 ====>Tx METER-2 D0 12 20 00 00 00 80 B1 98 D4 AC BA D7 C3 FA E1 2B A9 75 97
16 : 36 : 30 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-8-4-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 30 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 80 B1 98 D4 AC BA D7 C3 FA E1 2B A9 75 97 C5 CD 7E
16 : 36 : 30 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 00 81 28 00 49 A8 F0 A7 13 D8 D9 F4 32 7E
16 : 36 : 30 <====Rx METER-2 D4 0E 20 00 00 00 81 28 00 49 A8 F0 A7 13 D8 D9
16 : 36 : 30 <====Rx METER-2 D4 0E 20 00 00 00 81 C4 01 81 00 17 00 00 00 00
16 : 36 : 30 ====>Tx METER-2 D0 12 20 00 00 00 81 C0 01 C1 00 03 01 00 0A 08 00 FF 03 00
16 : 36 : 30 ====>Tx METER-2 D0 12 20 00 00 00 81 65 E0 48 8D 58 11 96 75 A7 15 74 13 3A
16 : 36 : 30 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-8-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 30 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 81 65 E0 48 8D 58 11 96 75 A7 15 74 13 3A ED D8 7E
16 : 36 : 30 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 82 E5 13 D4 DD 24 6F DC E1 8C EF 78 B0 7E
16 : 36 : 30 <====Rx METER-2 D4 0F 20 00 00 00 82 E5 13 D4 DD 24 6F DC E1 8C EF
16 : 36 : 30 <====Rx METER-2 D4 0F 20 00 00 00 82 C4 01 81 00 02 02 0F 00 16 1F
16 : 36 : 30 ====>Tx METER-2 D0 12 20 00 00 00 82 C0 01 C1 00 03 01 00 0A 08 00 FF 02 00
16 : 36 : 30 ====>Tx METER-2 D0 12 20 00 00 00 82 83 3E 03 79 87 98 22 A8 25 CE A0 1B 5C
16 : 36 : 30 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-8-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 30 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 82 83 3E 03 79 87 98 22 A8 25 CE A0 1B 5C 27 E6 7E
16 : 36 : 30 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 83 8E 4F D5 46 4E F6 41 BE EE 84 A4 7E
16 : 36 : 30 <====Rx METER-2 D4 0E 20 00 00 00 83 8E 4F D5 46 4E F6 41 BE EE
16 : 36 : 30 <====Rx METER-2 D4 0E 20 00 00 00 83 C4 01 81 00 17 00 00 00 00
16 : 36 : 30 ====>Tx METER-2 D0 12 20 00 00 00 83 C0 01 C1 00 03 01 00 0A 08 01 FF 03 00
16 : 36 : 31 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 31 ====>Tx METER-2 D0 12 20 00 00 00 83 E5 FE 8A CB 19 3C EC 29 41 4A 49 F5 61
16 : 36 : 31 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-8-1-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 31 METER-2 SENDING HDLC FRAME
16 : 36 : 31 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 83 E5 FE 8A CB 19 3C EC 29 41 4A 49 F5 61 95 C7 7E
16 : 36 : 31 METER-2 RECEIVED HDLC FRAME
16 : 36 : 31 <====Rx METER-2 7E A0 20 41 00 02 04 01 B8 14 E1 E6 E7 00 D4 0F 20 00 00 00 84 AD 9D 63 13 32 07 6A C7 EB 08 D0 FA 7E
16 : 36 : 31 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 31 <====Rx METER-2 D4 0F 20 00 00 00 84 AD 9D 63 13 32 07 6A C7 EB 08
16 : 36 : 31 <====Rx METER-2 D4 0F 20 00 00 00 84 C4 01 81 00 02 02 0F 00 16 1F
16 : 36 : 31 METER-2 SERVICE = GET RESPONSE
16 : 36 : 31 ====>Tx METER-2 D0 12 20 00 00 00 84 C0 01 C1 00 03 01 00 0A 08 01 FF 02 00
16 : 36 : 31 ====>Tx METER-2 D0 12 20 00 00 00 84 05 7F 43 7C 15 CC BA CA 6C 81 2B E5 3E
16 : 36 : 31 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-8-1-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 31 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 84 05 7F 43 7C 15 CC BA CA 6C 81 2B E5 3E F2 ED 7E
16 : 36 : 31 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 00 85 10 BA BB A3 0E BB CC 3F 72 72 A8 7E
16 : 36 : 31 <====Rx METER-2 D4 0E 20 00 00 00 85 10 BA BB A3 0E BB CC 3F 72
16 : 36 : 31 <====Rx METER-2 D4 0E 20 00 00 00 85 C4 01 81 00 17 00 00 00 00
16 : 36 : 31 ====>Tx METER-2 D0 12 20 00 00 00 85 C0 01 C1 00 03 01 00 0A 08 02 FF 03 00
16 : 36 : 31 ====>Tx METER-2 D0 12 20 00 00 00 85 76 F1 40 42 EA 75 55 2A 94 4A 0B F0 E2
16 : 36 : 31 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-8-2-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 31 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 85 76 F1 40 42 EA 75 55 2A 94 4A 0B F0 E2 1E F6 7E
16 : 36 : 31 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 86 CC DE C7 5E 25 9D 4C 34 23 A6 A1 F1 7E
16 : 36 : 31 <====Rx METER-2 D4 0F 20 00 00 00 86 CC DE C7 5E 25 9D 4C 34 23 A6
16 : 36 : 31 <====Rx METER-2 D4 0F 20 00 00 00 86 C4 01 81 00 02 02 0F 00 16 1F
16 : 36 : 31 ====>Tx METER-2 D0 12 20 00 00 00 86 C0 01 C1 00 03 01 00 0A 08 02 FF 02 00
16 : 36 : 31 ====>Tx METER-2 D0 12 20 00 00 00 86 C2 69 F2 A3 77 9D 1B D4 88 8F 81 F5 B5
16 : 36 : 31 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-8-2-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 31 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 86 C2 69 F2 A3 77 9D 1B D4 88 8F 81 F5 B5 59 28 7E
16 : 36 : 31 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 87 01 45 30 A8 A9 48 69 D5 10 AF 87 7E
16 : 36 : 31 <====Rx METER-2 D4 0E 20 00 00 00 87 01 45 30 A8 A9 48 69 D5 10
16 : 36 : 31 <====Rx METER-2 D4 0E 20 00 00 00 87 C4 01 81 00 17 00 00 00 00
16 : 36 : 31 ====>Tx METER-2 D0 12 20 00 00 00 87 C0 01 C1 00 03 01 00 0A 08 03 FF 03 00
16 : 36 : 31 ====>Tx METER-2 D0 12 20 00 00 00 87 5F 02 02 36 D9 32 10 C6 F2 5E E6 68 AD
16 : 36 : 31 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-8-3-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 31 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 87 5F 02 02 36 D9 32 10 C6 F2 5E E6 68 AD 6F 3C 7E
16 : 36 : 32 METER-2 RECEIVED HDLC FRAME
16 : 36 : 32 <====Rx METER-2 7E A0 20 41 00 02 04 01 30 54 E9 E6 E7 00 D4 0F 20 00 00 00 88 41 35 29 2B 6A A5 D8 FF 59 01 EE 88 7E
16 : 36 : 32 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 32 <====Rx METER-2 D4 0F 20 00 00 00 88 41 35 29 2B 6A A5 D8 FF 59 01
16 : 36 : 32 <====Rx METER-2 D4 0F 20 00 00 00 88 C4 01 81 00 02 02 0F 00 16 1F
16 : 36 : 32 METER-2 SERVICE = GET RESPONSE
16 : 36 : 32 METER-2 COSEM OUT DATA
16 : 36 : 32 ====>Tx METER-2 D0 12 20 00 00 00 88 C0 01 C1 00 03 01 00 0A 08 03 FF 02 00
16 : 36 : 32 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 32 ====>Tx METER-2 D0 12 20 00 00 00 88 AE BF 50 C5 8F 92 74 01 93 87 97 62 CB
16 : 36 : 32 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-8-3-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 32 METER-2 SENDING HDLC FRAME
16 : 36 : 32 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 88 AE BF 50 C5 8F 92 74 01 93 87 97 62 CB A0 82 7E
16 : 36 : 32 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 00 89 6A 27 7B 71 86 59 1F B4 35 CD 3E 7E
16 : 36 : 32 <====Rx METER-2 D4 0E 20 00 00 00 89 6A 27 7B 71 86 59 1F B4 35
16 : 36 : 32 <====Rx METER-2 D4 0E 20 00 00 00 89 C4 01 81 00 17 00 00 00 00
16 : 36 : 32 ====>Tx METER-2 D0 12 20 00 00 00 89 C0 01 C1 00 03 01 00 0A 08 04 FF 03 00
16 : 36 : 32 ====>Tx METER-2 D0 12 20 00 00 00 89 D6 C7 88 CE C3 CE D7 14 94 75 3C A5 34
16 : 36 : 32 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-8-4-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 32 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 89 D6 C7 88 CE C3 CE D7 14 94 75 3C A5 34 1C D9 7E
16 : 36 : 32 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 8A 99 44 5A 1C 79 0B 59 D6 B1 4C 0B 0E 7E
16 : 36 : 32 <====Rx METER-2 D4 0F 20 00 00 00 8A 99 44 5A 1C 79 0B 59 D6 B1 4C
16 : 36 : 32 <====Rx METER-2 D4 0F 20 00 00 00 8A C4 01 81 00 02 02 0F 00 16 1F
16 : 36 : 32 ====>Tx METER-2 D0 12 20 00 00 00 8A C0 01 C1 00 03 01 00 0A 08 04 FF 02 00
16 : 36 : 32 ====>Tx METER-2 D0 12 20 00 00 00 8A 66 F1 06 81 AF 71 89 CE 04 51 FD 9D D2
16 : 36 : 32 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-8-4-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 32 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 8A 66 F1 06 81 AF 71 89 CE 04 51 FD 9D D2 0C 5A 7E
16 : 36 : 32 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 8B 2D BB 0E CA 08 84 1C 4F 2E CE 8D 7E
16 : 36 : 32 <====Rx METER-2 D4 0E 20 00 00 00 8B 2D BB 0E CA 08 84 1C 4F 2E
16 : 36 : 32 <====Rx METER-2 D4 0E 20 00 00 00 8B C4 01 81 00 17 00 00 00 00
16 : 36 : 32 ====>Tx METER-2 D0 12 20 00 00 00 8B C0 01 C1 00 03 01 00 0B 07 00 FF 03 00
16 : 36 : 32 ====>Tx METER-2 D0 12 20 00 00 00 8B 86 C2 50 6B A0 39 B0 1B DF C8 F1 94 6E
16 : 36 : 32 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-11-7-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 32 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 8B 86 C2 50 6B A0 39 B0 1B DF C8 F1 94 6E 22 10 7E
16 : 36 : 32 <====Rx METER-2 7E A0 20 41 00 02 04 01 B8 14 E1 E6 E7 00 D4 0F 20 00 00 00 8C 40 79 23 8D 39 58 C6 84 DF 5B C0 89 7E
16 : 36 : 32 <====Rx METER-2 D4 0F 20 00 00 00 8C 40 79 23 8D 39 58 C6 84 DF 5B
16 : 36 : 32 <====Rx METER-2 D4 0F 20 00 00 00 8C C4 01 81 00 02 02 0F 00 16 21
16 : 36 : 33 METER-2 SERVICE = GET RESPONSE
16 : 36 : 33 METER-2 COSEM OUT DATA
16 : 36 : 33 ====>Tx METER-2 D0 12 20 00 00 00 8C C0 01 C1 00 03 01 00 0B 07 00 FF 02 00
16 : 36 : 33 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 33 ====>Tx METER-2 D0 12 20 00 00 00 8C 3B 76 B6 2A 59 C2 40 FC 96 E8 A8 F3 81
16 : 36 : 33 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-11-7-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 33 METER-2 SENDING HDLC FRAME
16 : 36 : 33 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 8C 3B 76 B6 2A 59 C2 40 FC 96 E8 A8 F3 81 61 15 7E
16 : 36 : 33 METER-2 RECEIVED HDLC FRAME
16 : 36 : 33 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 00 8D 65 D4 69 35 E6 E9 6C EE 90 8E 32 7E
16 : 36 : 33 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 33 <====Rx METER-2 D4 0E 20 00 00 00 8D 65 D4 69 35 E6 E9 6C EE 90
16 : 36 : 33 <====Rx METER-2 D4 0E 20 00 00 00 8D C4 01 81 00 17 00 00 00 00
16 : 36 : 33 ====>Tx METER-2 D0 12 20 00 00 00 8D C0 01 C1 00 03 01 00 0C 07 00 FF 03 00
16 : 36 : 33 ====>Tx METER-2 D0 12 20 00 00 00 8D 0A B0 4A A9 16 B3 23 B0 10 38 0E 77 CE
16 : 36 : 33 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-12-7-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 33 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 8D 0A B0 4A A9 16 B3 23 B0 10 38 0E 77 CE 2D 00 7E
16 : 36 : 33 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 8E 1E 02 DA D9 46 1F 89 7F A0 AF 1F 5F 7E
16 : 36 : 33 <====Rx METER-2 D4 0F 20 00 00 00 8E 1E 02 DA D9 46 1F 89 7F A0 AF
16 : 36 : 33 <====Rx METER-2 D4 0F 20 00 00 00 8E C4 01 81 00 02 02 0F 00 16 23
16 : 36 : 33 ====>Tx METER-2 D0 12 20 00 00 00 8E C0 01 C1 00 03 01 00 0C 07 00 FF 02 00
16 : 36 : 33 ====>Tx METER-2 D0 12 20 00 00 00 8E FC 88 EB 68 3C 61 1D 2F F5 D5 CD 42 45
16 : 36 : 33 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-12-7-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 33 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 8E FC 88 EB 68 3C 61 1D 2F F5 D5 CD 42 45 25 F8 7E
16 : 36 : 33 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 8F 8B 61 04 5C 36 FB 2C 31 A4 59 55 7E
16 : 36 : 33 <====Rx METER-2 D4 0E 20 00 00 00 8F 8B 61 04 5C 36 FB 2C 31 A4
16 : 36 : 33 <====Rx METER-2 D4 0E 20 00 00 00 8F C4 01 81 00 17 43 6D 87 AE
16 : 36 : 33 ====>Tx METER-2 D0 12 20 00 00 00 8F C0 01 C1 00 03 01 00 0D 07 00 FF 03 00
16 : 36 : 33 ====>Tx METER-2 D0 12 20 00 00 00 8F 64 58 70 79 9F 34 68 E1 9A CF 5C 5F 65
16 : 36 : 33 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-13-7-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 33 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 8F 64 58 70 79 9F 34 68 E1 9A CF 5C 5F 65 AE 14 7E
16 : 36 : 33 <====Rx METER-2 7E A0 20 41 00 02 04 01 30 54 E9 E6 E7 00 D4 0F 20 00 00 00 90 3D 63 98 81 42 CC AA 74 F0 83 B7 68 7E
16 : 36 : 33 <====Rx METER-2 D4 0F 20 00 00 00 90 3D 63 98 81 42 CC AA 74 F0 83
16 : 36 : 33 <====Rx METER-2 D4 0F 20 00 00 00 90 C4 01 81 00 02 02 0F 00 16 FF
16 : 36 : 33 ====>Tx METER-2 D0 12 20 00 00 00 90 C0 01 C1 00 03 01 00 0D 07 00 FF 02 00
16 : 36 : 33 ====>Tx METER-2 D0 12 20 00 00 00 90 03 86 CC CA A0 14 01 29 85 BA 1D 64 A5
16 : 36 : 34 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-13-7-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 34 METER-2 SENDING HDLC FRAME
16 : 36 : 34 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 90 03 86 CC CA A0 14 01 29 85 BA 1D 64 A5 C5 F0 7E
16 : 36 : 34 METER-2 RECEIVED HDLC FRAME
16 : 36 : 34 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 00 91 0B D3 41 BE E0 10 2D 76 7B 3A 9D 7E
16 : 36 : 34 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 34 <====Rx METER-2 D4 0E 20 00 00 00 91 0B D3 41 BE E0 10 2D 76 7B
16 : 36 : 34 <====Rx METER-2 D4 0E 20 00 00 00 91 C4 01 81 00 17 00 00 00 00
16 : 36 : 34 METER-2 SERVICE = GET RESPONSE
16 : 36 : 34 METER-2 COSEM OUT DATA
16 : 36 : 34 ====>Tx METER-2 D0 12 20 00 00 00 91 C0 01 C1 00 03 01 00 0E 07 00 FF 03 00
16 : 36 : 34 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 34 ====>Tx METER-2 D0 12 20 00 00 00 91 3B 82 7F EC 22 44 26 05 8E 0A 48 74 3F
16 : 36 : 34 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-14-7-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 34 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 91 3B 82 7F EC 22 44 26 05 8E 0A 48 74 3F 86 B1 7E
16 : 36 : 34 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 92 7A BB 64 48 EA 2A 42 CA 19 18 1E E2 7E
16 : 36 : 34 <====Rx METER-2 D4 0F 20 00 00 00 92 7A BB 64 48 EA 2A 42 CA 19 18
16 : 36 : 34 <====Rx METER-2 D4 0F 20 00 00 00 92 C4 01 81 00 02 02 0F 00 16 2C
16 : 36 : 34 ====>Tx METER-2 D0 12 20 00 00 00 92 C0 01 C1 00 03 01 00 0E 07 00 FF 02 00
16 : 36 : 34 ====>Tx METER-2 D0 12 20 00 00 00 92 D8 00 F7 1F EF 1B EF 1E E4 A4 32 C8 19
16 : 36 : 34 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-14-7-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 34 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 92 D8 00 F7 1F EF 1B EF 1E E4 A4 32 C8 19 03 5D 7E
16 : 36 : 34 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 93 14 F5 BE D5 83 8B 3B 7F 9A CE C3 7E
16 : 36 : 34 <====Rx METER-2 D4 0E 20 00 00 00 93 14 F5 BE D5 83 8B 3B 7F 9A
16 : 36 : 34 <====Rx METER-2 D4 0E 20 00 00 00 93 C4 01 81 00 17 42 47 D7 0A
16 : 36 : 34 ====>Tx METER-2 D0 12 20 00 00 00 93 C0 01 C1 00 03 01 00 5B 07 00 FF 03 00
16 : 36 : 34 ====>Tx METER-2 D0 12 20 00 00 00 93 0F 64 E5 F9 BA E6 E4 8F 0A 7B 9C F7 61
16 : 36 : 34 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-91-7-0-255, IC = 3, ATTR: INDEX = 3
16 : 36 : 34 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 93 0F 64 E5 F9 BA E6 E4 8F 0A 7B 9C F7 61 06 A2 7E
16 : 36 : 34 <====Rx METER-2 7E A0 20 41 00 02 04 01 B8 14 E1 E6 E7 00 D4 0F 20 00 00 00 94 96 AC 39 74 A6 61 3C 7D B5 6B FE 64 7E
16 : 36 : 34 <====Rx METER-2 D4 0F 20 00 00 00 94 96 AC 39 74 A6 61 3C 7D B5 6B
16 : 36 : 34 <====Rx METER-2 D4 0F 20 00 00 00 94 C4 01 81 00 02 02 0F 00 16 21
16 : 36 : 34 ====>Tx METER-2 D0 12 20 00 00 00 94 C0 01 C1 00 03 01 00 5B 07 00 FF 02 00
16 : 36 : 34 ====>Tx METER-2 D0 12 20 00 00 00 94 61 54 31 FF E8 C7 DB 17 F6 42 61 95 5B
16 : 36 : 34 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-91-7-0-255, IC = 3, ATTR: INDEX = 2
16 : 36 : 34 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 94 61 54 31 FF E8 C7 DB 17 F6 42 61 95 5B 84 68 7E
16 : 36 : 34 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 00 95 6D 8C 54 98 7A 92 DA 69 28 FB DF 7E
16 : 36 : 35 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 35 <====Rx METER-2 D4 0E 20 00 00 00 95 6D 8C 54 98 7A 92 DA 69 28
16 : 36 : 35 <====Rx METER-2 D4 0E 20 00 00 00 95 C4 01 81 00 17 00 00 00 00
16 : 36 : 35 METER-2 SERVICE = GET RESPONSE
16 : 36 : 35 METER-2 COSEM OUT DATA
16 : 36 : 35 ====>Tx METER-2 D0 12 20 00 00 00 95 C0 01 C1 00 04 01 00 01 06 00 FF 03 00
16 : 36 : 35 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 35 ====>Tx METER-2 D0 12 20 00 00 00 95 8D 92 49 AC 2A 9E D3 20 57 9C 36 43 84
16 : 36 : 35 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-0-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 35 METER-2 SENDING HDLC FRAME
16 : 36 : 35 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 95 8D 92 49 AC 2A 9E D3 20 57 9C 36 43 84 48 65 7E
16 : 36 : 35 METER-2 RECEIVED HDLC FRAME
16 : 36 : 35 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 96 96 37 12 0E 14 2E 40 E0 25 CB 0F D2 7E
16 : 36 : 35 <====Rx METER-2 D4 0F 20 00 00 00 96 96 37 12 0E 14 2E 40 E0 25 CB
16 : 36 : 35 <====Rx METER-2 D4 0F 20 00 00 00 96 C4 01 81 00 02 02 0F 00 16 1B
16 : 36 : 35 ====>Tx METER-2 D0 12 20 00 00 00 96 C0 01 C1 00 04 01 00 01 06 00 FF 02 00
16 : 36 : 35 ====>Tx METER-2 D0 12 20 00 00 00 96 4E 72 1C 8F 41 7D 38 E2 69 49 90 C2 1A
16 : 36 : 35 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-0-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 35 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 96 4E 72 1C 8F 41 7D 38 E2 69 49 90 C2 1A 0A 93 7E
16 : 36 : 35 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 97 46 F8 A2 0B E8 27 87 D0 CF 18 E6 7E
16 : 36 : 35 <====Rx METER-2 D4 0E 20 00 00 00 97 46 F8 A2 0B E8 27 87 D0 CF
16 : 36 : 35 <====Rx METER-2 D4 0E 20 00 00 00 97 C4 01 81 00 17 00 00 00 00
16 : 36 : 35 ====>Tx METER-2 D0 12 20 00 00 00 97 C0 01 C1 00 04 01 00 01 06 00 FF 04 00
16 : 36 : 35 ====>Tx METER-2 D0 12 20 00 00 00 97 44 82 DF B8 85 D9 8E 77 57 BD 50 B0 CE
16 : 36 : 35 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-0-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 35 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 97 44 82 DF B8 85 D9 8E 77 57 BD 50 B0 CE DE D3 7E
16 : 36 : 35 <====Rx METER-2 7E A0 1B 41 00 02 04 01 30 9C 49 E6 E7 00 D4 0A 20 00 00 00 98 5C 80 29 67 8B 80 1F 7E
16 : 36 : 35 <====Rx METER-2 D4 0A 20 00 00 00 98 5C 80 29 67 8B
16 : 36 : 35 <====Rx METER-2 D4 0A 20 00 00 00 98 C4 01 81 00 00
16 : 36 : 35 ====>Tx METER-2 D0 12 20 00 00 00 98 C0 01 C1 00 04 01 00 01 06 00 FF 05 00
16 : 36 : 35 ====>Tx METER-2 D0 12 20 00 00 00 98 60 69 ED 60 F5 8A 1D 80 82 10 AF 65 82
16 : 36 : 35 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-0-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 35 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 98 60 69 ED 60 F5 8A 1D 80 82 10 AF 65 82 B1 42 7E
16 : 36 : 35 <====Rx METER-2 7E A0 28 41 00 02 04 01 52 AC 77 E6 E7 00 D4 17 20 00 00 00 99 F8 BC EE B9 55 33 5B 6A D2 C7 71 BB BB 4E 65 A5 D2 3B 97
DF 7E
16 : 36 : 35 <====Rx METER-2 D4 17 20 00 00 00 99 F8 BC EE B9 55 33 5B 6A D2 C7 71 BB BB 4E 65 A5 D2 3B
16 : 36 : 35 <====Rx METER-2 D4 17 20 00 00 00 99 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 36 METER-2 SERVICE = GET RESPONSE
16 : 36 : 36 METER-2 COSEM OUT DATA
16 : 36 : 36 ====>Tx METER-2 D0 12 20 00 00 00 99 C0 01 C1 00 04 01 00 01 06 01 FF 03 00
16 : 36 : 36 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 36 ====>Tx METER-2 D0 12 20 00 00 00 99 9A 9B 5C 2A 7B 31 E7 26 2E 38 28 B0 CF
16 : 36 : 36 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-1-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 36 METER-2 SENDING HDLC FRAME
16 : 36 : 36 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 99 9A 9B 5C 2A 7B 31 E7 26 2E 38 28 B0 CF 0E 16 7E
16 : 36 : 36 METER-2 RECEIVED HDLC FRAME
16 : 36 : 36 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 9A 58 25 38 32 9F EC 5C 6F 7E 83 CE 4F 7E
16 : 36 : 36 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 36 <====Rx METER-2 D4 0F 20 00 00 00 9A 58 25 38 32 9F EC 5C 6F 7E 83
16 : 36 : 36 <====Rx METER-2 D4 0F 20 00 00 00 9A C4 01 81 00 02 02 0F 00 16 1B
16 : 36 : 36 ====>Tx METER-2 D0 12 20 00 00 00 9A C0 01 C1 00 04 01 00 01 06 01 FF 02 00
16 : 36 : 36 ====>Tx METER-2 D0 12 20 00 00 00 9A 06 B3 34 61 45 9D 4A 5B 84 3A 8F B5 7A
16 : 36 : 36 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-1-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 36 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 9A 06 B3 34 61 45 9D 4A 5B 84 3A 8F B5 7A 8D E2 7E
16 : 36 : 36 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 9B 9E BD 20 C8 85 E7 8A BA 23 59 79 7E
16 : 36 : 36 <====Rx METER-2 D4 0E 20 00 00 00 9B 9E BD 20 C8 85 E7 8A BA 23
16 : 36 : 36 <====Rx METER-2 D4 0E 20 00 00 00 9B C4 01 81 00 17 00 00 00 00
16 : 36 : 36 ====>Tx METER-2 D0 12 20 00 00 00 9B C0 01 C1 00 04 01 00 01 06 01 FF 04 00
16 : 36 : 36 ====>Tx METER-2 D0 12 20 00 00 00 9B AB 4D 62 33 6E 4B A8 C5 47 2C 1C 49 29
16 : 36 : 36 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-1-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 36 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 9B AB 4D 62 33 6E 4B A8 C5 47 2C 1C 49 29 3B 59 7E
16 : 36 : 36 <====Rx METER-2 7E A0 1B 41 00 02 04 01 B8 DC 41 E6 E7 00 D4 0A 20 00 00 00 9C C9 1C 0E 3D 2D 13 0F 7E
16 : 36 : 36 <====Rx METER-2 D4 0A 20 00 00 00 9C C9 1C 0E 3D 2D
16 : 36 : 36 <====Rx METER-2 D4 0A 20 00 00 00 9C C4 01 81 00 00
16 : 36 : 36 ====>Tx METER-2 D0 12 20 00 00 00 9C C0 01 C1 00 04 01 00 01 06 01 FF 05 00
16 : 36 : 36 ====>Tx METER-2 D0 12 20 00 00 00 9C 98 A5 40 31 71 D5 E5 17 8C 5B 15 C1 EA
16 : 36 : 36 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-1-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 36 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 9C 98 A5 40 31 71 D5 E5 17 8C 5B 15 C1 EA AC 47 7E
16 : 36 : 36 <====Rx METER-2 7E A0 28 41 00 02 04 01 DA EC 7F E6 E7 00 D4 17 20 00 00 00 9D F8 78 E8 61 37 C4 84 F3 E7 37 CF 63 31 39 E8 D8 C5 28 D4
34 7E
16 : 36 : 36 <====Rx METER-2 D4 17 20 00 00 00 9D F8 78 E8 61 37 C4 84 F3 E7 37 CF 63 31 39 E8 D8 C5 28
16 : 36 : 36 <====Rx METER-2 D4 17 20 00 00 00 9D C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 36 ====>Tx METER-2 D0 12 20 00 00 00 9D C0 01 C1 00 04 01 00 01 06 02 FF 03 00
16 : 36 : 36 ====>Tx METER-2 D0 12 20 00 00 00 9D C9 60 50 31 6A B2 39 C5 6E 9A 60 CC 07
16 : 36 : 36 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-2-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 37 METER-2 SENDING HDLC FRAME
16 : 36 : 37 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 9D C9 60 50 31 6A B2 39 C5 6E 9A 60 CC 07 DD 33 7E
16 : 36 : 37 METER-2 RECEIVED HDLC FRAME
16 : 36 : 37 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 9E 3D EA B3 17 3F 0E 76 4B EA 27 C4 28 7E
16 : 36 : 37 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 37 <====Rx METER-2 D4 0F 20 00 00 00 9E 3D EA B3 17 3F 0E 76 4B EA 27
16 : 36 : 37 <====Rx METER-2 D4 0F 20 00 00 00 9E C4 01 81 00 02 02 0F 00 16 1B
16 : 36 : 37 METER-2 SERVICE = GET RESPONSE
16 : 36 : 37 METER-2 COSEM OUT DATA
16 : 36 : 37 ====>Tx METER-2 D0 12 20 00 00 00 9E C0 01 C1 00 04 01 00 01 06 02 FF 02 00
16 : 36 : 37 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 37 ====>Tx METER-2 D0 12 20 00 00 00 9E E2 1A D7 F8 6C F3 8D 03 C6 F5 01 85 EF
16 : 36 : 37 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-2-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 37 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 9E E2 1A D7 F8 6C F3 8D 03 C6 F5 01 85 EF 54 9D 7E
16 : 36 : 37 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 9F FD DE 3F A0 8F 84 BB CE 5E A8 4E 7E
16 : 36 : 37 <====Rx METER-2 D4 0E 20 00 00 00 9F FD DE 3F A0 8F 84 BB CE 5E
16 : 36 : 37 <====Rx METER-2 D4 0E 20 00 00 00 9F C4 01 81 00 17 00 00 00 00
16 : 36 : 37 ====>Tx METER-2 D0 12 20 00 00 00 9F C0 01 C1 00 04 01 00 01 06 02 FF 04 00
16 : 36 : 37 ====>Tx METER-2 D0 12 20 00 00 00 9F EE D3 A3 6B 90 D9 BE 91 BE 4C B1 E3 8A
16 : 36 : 37 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-2-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 37 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 9F EE D3 A3 6B 90 D9 BE 91 BE 4C B1 E3 8A 1C 39 7E
16 : 36 : 37 <====Rx METER-2 7E A0 1B 41 00 02 04 01 30 9C 49 E6 E7 00 D4 0A 20 00 00 00 A0 2E FD C4 AD ED 8D EC 7E
16 : 36 : 37 <====Rx METER-2 D4 0A 20 00 00 00 A0 2E FD C4 AD ED
16 : 36 : 37 <====Rx METER-2 D4 0A 20 00 00 00 A0 C4 01 81 00 00
16 : 36 : 37 ====>Tx METER-2 D0 12 20 00 00 00 A0 C0 01 C1 00 04 01 00 01 06 02 FF 05 00
16 : 36 : 37 ====>Tx METER-2 D0 12 20 00 00 00 A0 30 70 3B F4 38 A1 FA 60 05 C0 DD 0B E0
16 : 36 : 37 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-2-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 37 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 A0 30 70 3B F4 38 A1 FA 60 05 C0 DD 0B E0 E7 F7 7E
16 : 36 : 37 <====Rx METER-2 7E A0 28 41 00 02 04 01 52 AC 77 E6 E7 00 D4 17 20 00 00 00 A1 1B 74 C3 09 4A C9 04 03 E5 A1 C0 B7 1F 5F EB 0A B6 B2 F4
00 7E
16 : 36 : 37 <====Rx METER-2 D4 17 20 00 00 00 A1 1B 74 C3 09 4A C9 04 03 E5 A1 C0 B7 1F 5F EB 0A B6 B2
16 : 36 : 37 <====Rx METER-2 D4 17 20 00 00 00 A1 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 37 ====>Tx METER-2 D0 12 20 00 00 00 A1 C0 01 C1 00 04 01 00 01 06 03 FF 03 00
16 : 36 : 37 ====>Tx METER-2 D0 12 20 00 00 00 A1 9B 9B 4C 14 77 46 6B AE 24 CF 19 E2 0B
16 : 36 : 37 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-3-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 37 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 A1 9B 9B 4C 14 77 46 6B AE 24 CF 19 E2 0B 6B 96 7E
16 : 36 : 37 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 A2 04 E2 1F 2A 1D 25 77 D4 AC 01 6E 80 7E
16 : 36 : 38 <====Rx METER-2 D4 0F 20 00 00 00 A2 04 E2 1F 2A 1D 25 77 D4 AC 01
16 : 36 : 38 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 36 : 38 <====Rx METER-2 D4 0F 20 00 00 00 A2 C4 01 81 00 02 02 0F 00 16 1B
16 : 36 : 38 METER-2 SERVICE = GET RESPONSE
16 : 36 : 38 METER-2 COSEM OUT DATA
16 : 36 : 38 ====>Tx METER-2 D0 12 20 00 00 00 A2 C0 01 C1 00 04 01 00 01 06 03 FF 02 00
16 : 36 : 38 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 38 ====>Tx METER-2 D0 12 20 00 00 00 A2 2D 8F 69 2A 16 AB 60 FE 45 4F 09 33 93
16 : 36 : 38 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-3-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 38 METER-2 SENDING HDLC FRAME
16 : 36 : 38 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 A2 2D 8F 69 2A 16 AB 60 FE 45 4F 09 33 93 C1 B3 7E
16 : 36 : 38 METER-2 RECEIVED HDLC FRAME
16 : 36 : 38 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 A3 8B 4A 7C DB A5 80 A9 C4 B7 64 4B 7E
16 : 36 : 38 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 38 <====Rx METER-2 D4 0E 20 00 00 00 A3 8B 4A 7C DB A5 80 A9 C4 B7
16 : 36 : 38 <====Rx METER-2 D4 0E 20 00 00 00 A3 C4 01 81 00 17 00 00 00 00
16 : 36 : 38 ====>Tx METER-2 D0 12 20 00 00 00 A3 C0 01 C1 00 04 01 00 01 06 03 FF 04 00
16 : 36 : 38 ====>Tx METER-2 D0 12 20 00 00 00 A3 6A D3 B6 55 66 71 51 4F FA F6 72 92 92
16 : 36 : 38 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-3-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 38 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 A3 6A D3 B6 55 66 71 51 4F FA F6 72 92 92 AB 5B 7E
16 : 36 : 38 <====Rx METER-2 7E A0 1B 41 00 02 04 01 B8 DC 41 E6 E7 00 D4 0A 20 00 00 00 A4 2B DB 3A C6 47 3E 09 7E
16 : 36 : 38 <====Rx METER-2 D4 0A 20 00 00 00 A4 2B DB 3A C6 47
16 : 36 : 38 <====Rx METER-2 D4 0A 20 00 00 00 A4 C4 01 81 00 00
16 : 36 : 38 ====>Tx METER-2 D0 12 20 00 00 00 A4 C0 01 C1 00 04 01 00 01 06 03 FF 05 00
16 : 36 : 38 ====>Tx METER-2 D0 12 20 00 00 00 A4 11 5B 12 E3 02 C9 56 30 54 91 4C 5D C4
16 : 36 : 38 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-3-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 38 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 A4 11 5B 12 E3 02 C9 56 30 54 91 4C 5D C4 9D 8D 7E
16 : 36 : 38 <====Rx METER-2 7E A0 28 41 00 02 04 01 DA EC 7F E6 E7 00 D4 17 20 00 00 00 A5 80 41 85 ED 2D A3 36 A1 40 C5 CE 9F 5E F8 6F 8C 48 4F 15
D8 7E
16 : 36 : 38 <====Rx METER-2 D4 17 20 00 00 00 A5 80 41 85 ED 2D A3 36 A1 40 C5 CE 9F 5E F8 6F 8C 48 4F
16 : 36 : 38 <====Rx METER-2 D4 17 20 00 00 00 A5 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 38 ====>Tx METER-2 D0 12 20 00 00 00 A5 C0 01 C1 00 04 01 00 01 06 04 FF 03 00
16 : 36 : 38 ====>Tx METER-2 D0 12 20 00 00 00 A5 C3 74 83 F4 52 9B 42 F5 B5 4E 73 8B EB
16 : 36 : 38 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-4-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 38 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 A5 C3 74 83 F4 52 9B 42 F5 B5 4E 73 8B EB AC 95 7E
16 : 36 : 38 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 A6 20 C6 6F 2F CC 28 53 91 37 44 A0 65 7E
16 : 36 : 38 <====Rx METER-2 D4 0F 20 00 00 00 A6 20 C6 6F 2F CC 28 53 91 37 44
16 : 36 : 38 <====Rx METER-2 D4 0F 20 00 00 00 A6 C4 01 81 00 02 02 0F 00 16 1B
16 : 36 : 39 ====>Tx METER-2 D0 12 20 00 00 00 A6 C0 01 C1 00 04 01 00 01 06 04 FF 02 00
16 : 36 : 39 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 39 ====>Tx METER-2 D0 12 20 00 00 00 A6 29 92 32 FD 0A D0 98 AE 93 B0 4C 9D 67
16 : 36 : 39 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-4-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 39 METER-2 SENDING HDLC FRAME
16 : 36 : 39 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 A6 29 92 32 FD 0A D0 98 AE 93 B0 4C 9D 67 28 F1 7E
16 : 36 : 39 METER-2 RECEIVED HDLC FRAME
16 : 36 : 39 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 A7 7F 1D C1 C6 17 15 7B A4 1D D2 D8 7E
16 : 36 : 39 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 39 <====Rx METER-2 D4 0E 20 00 00 00 A7 7F 1D C1 C6 17 15 7B A4 1D
16 : 36 : 39 <====Rx METER-2 D4 0E 20 00 00 00 A7 C4 01 81 00 17 00 00 00 00
16 : 36 : 39 METER-2 SERVICE = GET RESPONSE
16 : 36 : 39 ====>Tx METER-2 D0 12 20 00 00 00 A7 C0 01 C1 00 04 01 00 01 06 04 FF 04 00
16 : 36 : 39 ====>Tx METER-2 D0 12 20 00 00 00 A7 4A 38 9A 68 77 3E 8C 7F A7 8D C8 DC 43
16 : 36 : 39 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-4-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 39 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 A7 4A 38 9A 68 77 3E 8C 7F A7 8D C8 DC 43 CB C3 7E
16 : 36 : 39 <====Rx METER-2 7E A0 1B 41 00 02 04 01 30 9C 49 E6 E7 00 D4 0A 20 00 00 00 A8 A9 05 3D FB 49 8C 91 7E
16 : 36 : 39 <====Rx METER-2 D4 0A 20 00 00 00 A8 A9 05 3D FB 49
16 : 36 : 39 <====Rx METER-2 D4 0A 20 00 00 00 A8 C4 01 81 00 00
16 : 36 : 39 ====>Tx METER-2 D0 12 20 00 00 00 A8 C0 01 C1 00 04 01 00 01 06 04 FF 05 00
16 : 36 : 39 ====>Tx METER-2 D0 12 20 00 00 00 A8 5F 5F 24 D5 C8 4F C9 63 EB 8F 75 49 57
16 : 36 : 39 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-1-6-4-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 39 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 A8 5F 5F 24 D5 C8 4F C9 63 EB 8F 75 49 57 48 56 7E
16 : 36 : 39 <====Rx METER-2 7E A0 28 41 00 02 04 01 52 AC 77 E6 E7 00 D4 17 20 00 00 00 A9 35 71 D8 85 76 7C 71 DB 88 E9 DD 82 72 E8 9B 9E F9 78 A1
67 7E
16 : 36 : 39 <====Rx METER-2 D4 17 20 00 00 00 A9 35 71 D8 85 76 7C 71 DB 88 E9 DD 82 72 E8 9B 9E F9 78
16 : 36 : 39 <====Rx METER-2 D4 17 20 00 00 00 A9 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 39 ====>Tx METER-2 D0 12 20 00 00 00 A9 C0 01 C1 00 04 01 00 02 06 00 FF 03 00
16 : 36 : 39 ====>Tx METER-2 D0 12 20 00 00 00 A9 B5 96 C2 9E A1 1F 7B 9B EC 36 00 61 2C
16 : 36 : 39 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-0-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 39 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 A9 B5 96 C2 9E A1 1F 7B 9B EC 36 00 61 2C 10 C6 7E
16 : 36 : 39 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 AA 3B 67 9F 13 75 9C FB BD 79 97 9D 5F 7E
16 : 36 : 39 <====Rx METER-2 D4 0F 20 00 00 00 AA 3B 67 9F 13 75 9C FB BD 79 97
16 : 36 : 39 <====Rx METER-2 D4 0F 20 00 00 00 AA C4 01 81 00 02 02 0F 00 16 1B
16 : 36 : 39 ====>Tx METER-2 D0 12 20 00 00 00 AA C0 01 C1 00 04 01 00 02 06 00 FF 02 00
16 : 36 : 39 ====>Tx METER-2 D0 12 20 00 00 00 AA E3 4A EB 2C 14 18 88 B1 63 49 BF CD 5F
16 : 36 : 39 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-0-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 39 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 AA E3 4A EB 2C 14 18 88 B1 63 49 BF CD 5F A3 33 7E
16 : 36 : 40 METER-2 RECEIVED HDLC FRAME
16 : 36 : 40 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 AB AB 95 D3 81 E9 97 4B 1F D5 A4 61 7E
16 : 36 : 40 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 40 <====Rx METER-2 D4 0E 20 00 00 00 AB AB 95 D3 81 E9 97 4B 1F D5
16 : 36 : 40 <====Rx METER-2 D4 0E 20 00 00 00 AB C4 01 81 00 17 00 00 00 00
16 : 36 : 40 METER-2 SERVICE = GET RESPONSE
16 : 36 : 40 METER-2 COSEM OUT DATA
16 : 36 : 40 ====>Tx METER-2 D0 12 20 00 00 00 AB C0 01 C1 00 04 01 00 02 06 00 FF 04 00
16 : 36 : 40 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 40 ====>Tx METER-2 D0 12 20 00 00 00 AB F7 44 0F 2E 10 3A B0 8C F9 5E 71 F8 47
16 : 36 : 40 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-0-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 40 METER-2 SENDING HDLC FRAME
16 : 36 : 40 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 AB F7 44 0F 2E 10 3A B0 8C F9 5E 71 F8 47 3F 67 7E
16 : 36 : 40 <====Rx METER-2 7E A0 1B 41 00 02 04 01 B8 DC 41 E6 E7 00 D4 0A 20 00 00 00 AC 90 69 F4 92 1C A4 2B 7E
16 : 36 : 40 <====Rx METER-2 D4 0A 20 00 00 00 AC 90 69 F4 92 1C
16 : 36 : 40 <====Rx METER-2 D4 0A 20 00 00 00 AC C4 01 81 00 00
16 : 36 : 40 ====>Tx METER-2 D0 12 20 00 00 00 AC C0 01 C1 00 04 01 00 02 06 00 FF 05 00
16 : 36 : 40 ====>Tx METER-2 D0 12 20 00 00 00 AC 2C 6A A2 48 AA 7D 99 D3 F3 1F B8 67 67
16 : 36 : 40 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-0-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 40 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 AC 2C 6A A2 48 AA 7D 99 D3 F3 1F B8 67 67 26 DA 7E
16 : 36 : 40 <====Rx METER-2 7E A0 28 41 00 02 04 01 DA EC 7F E6 E7 00 D4 17 20 00 00 00 AD 00 4D CE FC 40 CC 6F 13 73 56 26 32 03 87 F2 25 83 5A E4
14 7E
16 : 36 : 40 <====Rx METER-2 D4 17 20 00 00 00 AD 00 4D CE FC 40 CC 6F 13 73 56 26 32 03 87 F2 25 83 5A
16 : 36 : 40 <====Rx METER-2 D4 17 20 00 00 00 AD C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 40 ====>Tx METER-2 D0 12 20 00 00 00 AD C0 01 C1 00 04 01 00 02 06 01 FF 03 00
16 : 36 : 40 ====>Tx METER-2 D0 12 20 00 00 00 AD 6B 06 8E 2C 69 4F B0 3A A3 36 5B 06 F6
16 : 36 : 40 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-1-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 40 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 AD 6B 06 8E 2C 69 4F B0 3A A3 36 5B 06 F6 27 6A 7E
16 : 36 : 40 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 AE CB 50 A4 5C 75 F3 B2 D0 FA DD A8 6C 7E
16 : 36 : 40 <====Rx METER-2 D4 0F 20 00 00 00 AE CB 50 A4 5C 75 F3 B2 D0 FA DD
16 : 36 : 40 <====Rx METER-2 D4 0F 20 00 00 00 AE C4 01 81 00 02 02 0F 00 16 1B
16 : 36 : 40 ====>Tx METER-2 D0 12 20 00 00 00 AE C0 01 C1 00 04 01 00 02 06 01 FF 02 00
16 : 36 : 40 ====>Tx METER-2 D0 12 20 00 00 00 AE F0 07 EE 2A 76 1E 49 FC E2 97 A1 E9 F2
16 : 36 : 40 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-1-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 40 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 AE F0 07 EE 2A 76 1E 49 FC E2 97 A1 E9 F2 4C AC 7E
16 : 36 : 40 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 AF 60 69 1A 88 64 9F B9 DB 3D 10 EB 7E
16 : 36 : 41 <====Rx METER-2 D4 0E 20 00 00 00 AF 60 69 1A 88 64 9F B9 DB 3D
16 : 36 : 41 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 36 : 41 <====Rx METER-2 D4 0E 20 00 00 00 AF C4 01 81 00 17 00 00 00 00
16 : 36 : 41 METER-2 SERVICE = GET RESPONSE
16 : 36 : 41 METER-2 COSEM OUT DATA
16 : 36 : 41 ====>Tx METER-2 D0 12 20 00 00 00 AF C0 01 C1 00 04 01 00 02 06 01 FF 04 00
16 : 36 : 41 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 41 ====>Tx METER-2 D0 12 20 00 00 00 AF 74 93 16 C1 81 DF 22 79 37 FB 96 85 96
16 : 36 : 41 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-1-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 41 METER-2 SENDING HDLC FRAME
16 : 36 : 41 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 AF 74 93 16 C1 81 DF 22 79 37 FB 96 85 96 67 95 7E
16 : 36 : 41 METER-2 RECEIVED HDLC FRAME
16 : 36 : 41 <====Rx METER-2 7E A0 1B 41 00 02 04 01 30 9C 49 E6 E7 00 D4 0A 20 00 00 00 B0 39 F9 E3 77 DE 20 76 7E
16 : 36 : 41 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 41 <====Rx METER-2 D4 0A 20 00 00 00 B0 39 F9 E3 77 DE
16 : 36 : 41 <====Rx METER-2 D4 0A 20 00 00 00 B0 C4 01 81 00 00
16 : 36 : 41 ====>Tx METER-2 D0 12 20 00 00 00 B0 C0 01 C1 00 04 01 00 02 06 01 FF 05 00
16 : 36 : 41 ====>Tx METER-2 D0 12 20 00 00 00 B0 F9 93 1E 3B 40 E8 66 C6 E0 FF 28 05 C5
16 : 36 : 41 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-1-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 41 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 B0 F9 93 1E 3B 40 E8 66 C6 E0 FF 28 05 C5 E8 A6 7E
16 : 36 : 41 <====Rx METER-2 7E A0 28 41 00 02 04 01 52 AC 77 E6 E7 00 D4 17 20 00 00 00 B1 51 C5 8C BE B5 3D AF BB 25 BA 27 58 63 86 1D 0F 7A 7A FB
0E 7E
16 : 36 : 41 <====Rx METER-2 D4 17 20 00 00 00 B1 51 C5 8C BE B5 3D AF BB 25 BA 27 58 63 86 1D 0F 7A 7A
16 : 36 : 41 <====Rx METER-2 D4 17 20 00 00 00 B1 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 41 ====>Tx METER-2 D0 12 20 00 00 00 B1 C0 01 C1 00 04 01 00 02 06 02 FF 03 00
16 : 36 : 41 ====>Tx METER-2 D0 12 20 00 00 00 B1 55 A2 E4 2D 08 6D AB 12 5A FB 81 EC 48
16 : 36 : 41 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-2-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 41 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 B1 55 A2 E4 2D 08 6D AB 12 5A FB 81 EC 48 4C A7 7E
16 : 36 : 41 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 B2 2D BA 88 5A B0 86 B3 9B C0 CC F8 F5 7E
16 : 36 : 41 <====Rx METER-2 D4 0F 20 00 00 00 B2 2D BA 88 5A B0 86 B3 9B C0 CC
16 : 36 : 41 <====Rx METER-2 D4 0F 20 00 00 00 B2 C4 01 81 00 02 02 0F 00 16 1B
16 : 36 : 41 ====>Tx METER-2 D0 12 20 00 00 00 B2 C0 01 C1 00 04 01 00 02 06 02 FF 02 00
16 : 36 : 41 ====>Tx METER-2 D0 12 20 00 00 00 B2 C5 0D DB BD 0D 74 E3 35 B5 CB F1 16 46
16 : 36 : 41 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-2-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 41 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 B2 C5 0D DB BD 0D 74 E3 35 B5 CB F1 16 46 2D AA 7E
16 : 36 : 41 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 B3 4B 2E 32 13 E2 AE 91 29 F1 01 F7 7E
16 : 36 : 42 <====Rx METER-2 D4 0E 20 00 00 00 B3 4B 2E 32 13 E2 AE 91 29 F1
16 : 36 : 42 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 36 : 42 <====Rx METER-2 D4 0E 20 00 00 00 B3 C4 01 81 00 17 00 00 00 00
16 : 36 : 42 METER-2 SERVICE = GET RESPONSE
16 : 36 : 42 METER-2 COSEM OUT DATA
16 : 36 : 42 ====>Tx METER-2 D0 12 20 00 00 00 B3 C0 01 C1 00 04 01 00 02 06 02 FF 04 00
16 : 36 : 42 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 42 ====>Tx METER-2 D0 12 20 00 00 00 B3 EB F4 72 D9 73 92 7F A3 07 49 F0 C6 CD
16 : 36 : 42 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-2-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 42 METER-2 SENDING HDLC FRAME
16 : 36 : 42 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 B3 EB F4 72 D9 73 92 7F A3 07 49 F0 C6 CD AF 43 7E
16 : 36 : 42 METER-2 RECEIVED HDLC FRAME
16 : 36 : 42 <====Rx METER-2 7E A0 1B 41 00 02 04 01 B8 DC 41 E6 E7 00 D4 0A 20 00 00 00 B4 18 23 52 6D 6B D6 73 7E
16 : 36 : 42 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 42 <====Rx METER-2 D4 0A 20 00 00 00 B4 18 23 52 6D 6B
16 : 36 : 42 <====Rx METER-2 D4 0A 20 00 00 00 B4 C4 01 81 00 00
16 : 36 : 42 ====>Tx METER-2 D0 12 20 00 00 00 B4 C0 01 C1 00 04 01 00 02 06 02 FF 05 00
16 : 36 : 42 ====>Tx METER-2 D0 12 20 00 00 00 B4 D9 85 79 AF A4 7E 68 35 7B 57 EE 29 BC
16 : 36 : 42 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-2-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 42 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 B4 D9 85 79 AF A4 7E 68 35 7B 57 EE 29 BC 83 16 7E
16 : 36 : 42 <====Rx METER-2 7E A0 28 41 00 02 04 01 DA EC 7F E6 E7 00 D4 17 20 00 00 00 B5 70 5E 9A 7B 5C CD CD 50 5E 46 E5 1B D1 02 D8 C6 BF 4B 75
7A 7E
16 : 36 : 42 <====Rx METER-2 D4 17 20 00 00 00 B5 70 5E 9A 7B 5C CD CD 50 5E 46 E5 1B D1 02 D8 C6 BF 4B
16 : 36 : 42 <====Rx METER-2 D4 17 20 00 00 00 B5 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 42 ====>Tx METER-2 D0 12 20 00 00 00 B5 C0 01 C1 00 04 01 00 02 06 03 FF 03 00
16 : 36 : 42 ====>Tx METER-2 D0 12 20 00 00 00 B5 4D E1 AF 6E 07 E3 CC A9 21 19 D4 29 1C
16 : 36 : 42 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-3-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 42 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 B5 4D E1 AF 6E 07 E3 CC A9 21 19 D4 29 1C CE 7D 7E
16 : 36 : 42 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 B6 92 60 36 97 34 7D 4A 99 18 4F 9F 4B 7E
16 : 36 : 42 <====Rx METER-2 D4 0F 20 00 00 00 B6 92 60 36 97 34 7D 4A 99 18 4F
16 : 36 : 42 <====Rx METER-2 D4 0F 20 00 00 00 B6 C4 01 81 00 02 02 0F 00 16 1B
16 : 36 : 42 ====>Tx METER-2 D0 12 20 00 00 00 B6 C0 01 C1 00 04 01 00 02 06 03 FF 02 00
16 : 36 : 42 ====>Tx METER-2 D0 12 20 00 00 00 B6 18 71 CA 4E 1C 9C 47 31 4B 96 8B F1 7E
16 : 36 : 42 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-3-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 42 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 B6 18 71 CA 4E 1C 9C 47 31 4B 96 8B F1 7E 8E 74 7E
16 : 36 : 42 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 B7 3F 07 09 41 4B DD 82 B7 1A F3 10 7E
16 : 36 : 42 <====Rx METER-2 D4 0E 20 00 00 00 B7 3F 07 09 41 4B DD 82 B7 1A
16 : 36 : 42 <====Rx METER-2 D4 0E 20 00 00 00 B7 C4 01 81 00 17 00 00 00 00
16 : 36 : 42 ====>Tx METER-2 D0 12 20 00 00 00 B7 C0 01 C1 00 04 01 00 02 06 03 FF 04 00
16 : 36 : 43 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 43 ====>Tx METER-2 D0 12 20 00 00 00 B7 DC 40 3F 88 0A 04 B7 EF 72 81 BE 02 52
16 : 36 : 43 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-3-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 43 METER-2 SENDING HDLC FRAME
16 : 36 : 43 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 B7 DC 40 3F 88 0A 04 B7 EF 72 81 BE 02 52 E1 C0 7E
16 : 36 : 43 METER-2 RECEIVED HDLC FRAME
16 : 36 : 43 <====Rx METER-2 7E A0 1B 41 00 02 04 01 30 9C 49 E6 E7 00 D4 0A 20 00 00 00 B8 9F FC 33 4C 6E FD 80 7E
16 : 36 : 43 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 43 <====Rx METER-2 D4 0A 20 00 00 00 B8 9F FC 33 4C 6E
16 : 36 : 43 <====Rx METER-2 D4 0A 20 00 00 00 B8 C4 01 81 00 00
16 : 36 : 43 METER-2 SERVICE = GET RESPONSE
16 : 36 : 43 ====>Tx METER-2 D0 12 20 00 00 00 B8 C0 01 C1 00 04 01 00 02 06 03 FF 05 00
16 : 36 : 43 ====>Tx METER-2 D0 12 20 00 00 00 B8 39 0A 41 6C 4E 0F 78 75 EE CA 2C F8 8B
16 : 36 : 43 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-3-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 43 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 B8 39 0A 41 6C 4E 0F 78 75 EE CA 2C F8 8B A0 DA 7E
16 : 36 : 43 <====Rx METER-2 7E A0 28 41 00 02 04 01 52 AC 77 E6 E7 00 D4 17 20 00 00 00 B9 60 9F F9 9A AC 1F A3 84 9E AA 6C EE 5B E6 66 F9 3C E5 3B
1F 7E
16 : 36 : 43 <====Rx METER-2 D4 17 20 00 00 00 B9 60 9F F9 9A AC 1F A3 84 9E AA 6C EE 5B E6 66 F9 3C E5
16 : 36 : 43 <====Rx METER-2 D4 17 20 00 00 00 B9 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 43 ====>Tx METER-2 D0 12 20 00 00 00 B9 C0 01 C1 00 04 01 00 02 06 04 FF 03 00
16 : 36 : 43 ====>Tx METER-2 D0 12 20 00 00 00 B9 E1 EB 45 3E 99 5A 1B 03 26 0E 0A BD 36
16 : 36 : 43 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-4-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 43 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 B9 E1 EB 45 3E 99 5A 1B 03 26 0E 0A BD 36 7C 33 7E
16 : 36 : 43 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 BA 08 2B BC 34 83 8A 2C A7 6E E8 7F 47 7E
16 : 36 : 43 <====Rx METER-2 D4 0F 20 00 00 00 BA 08 2B BC 34 83 8A 2C A7 6E E8
16 : 36 : 43 <====Rx METER-2 D4 0F 20 00 00 00 BA C4 01 81 00 02 02 0F 00 16 1B
16 : 36 : 43 ====>Tx METER-2 D0 12 20 00 00 00 BA C0 01 C1 00 04 01 00 02 06 04 FF 02 00
16 : 36 : 43 ====>Tx METER-2 D0 12 20 00 00 00 BA 61 FD 02 19 1E 61 87 8A F3 8D 0B C3 B7
16 : 36 : 43 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-4-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 43 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 BA 61 FD 02 19 1E 61 87 8A F3 8D 0B C3 B7 51 D0 7E
16 : 36 : 43 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 BB 65 A7 BB CA 6F 41 93 2B 68 A3 0D 7E
16 : 36 : 43 <====Rx METER-2 D4 0E 20 00 00 00 BB 65 A7 BB CA 6F 41 93 2B 68
16 : 36 : 43 <====Rx METER-2 D4 0E 20 00 00 00 BB C4 01 81 00 17 00 00 00 00
16 : 36 : 43 ====>Tx METER-2 D0 12 20 00 00 00 BB C0 01 C1 00 04 01 00 02 06 04 FF 04 00
16 : 36 : 43 ====>Tx METER-2 D0 12 20 00 00 00 BB E6 E5 73 90 FB 8C 4A 5E 78 80 AD A2 A8
16 : 36 : 43 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-4-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 43 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 BB E6 E5 73 90 FB 8C 4A 5E 78 80 AD A2 A8 9E B7 7E
16 : 36 : 44 METER-2 RECEIVED HDLC FRAME
16 : 36 : 44 <====Rx METER-2 7E A0 1B 41 00 02 04 01 B8 DC 41 E6 E7 00 D4 0A 20 00 00 00 BC 2A F9 23 82 EA D5 91 7E
16 : 36 : 44 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 44 <====Rx METER-2 D4 0A 20 00 00 00 BC 2A F9 23 82 EA
16 : 36 : 44 <====Rx METER-2 D4 0A 20 00 00 00 BC C4 01 81 00 00
16 : 36 : 44 METER-2 SERVICE = GET RESPONSE
16 : 36 : 44 METER-2 COSEM OUT DATA
16 : 36 : 44 ====>Tx METER-2 D0 12 20 00 00 00 BC C0 01 C1 00 04 01 00 02 06 04 FF 05 00
16 : 36 : 44 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 44 ====>Tx METER-2 D0 12 20 00 00 00 BC 86 7F 61 A4 AA 66 31 D5 91 37 3A 82 9A
16 : 36 : 44 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-2-6-4-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 44 METER-2 SENDING HDLC FRAME
16 : 36 : 44 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 BC 86 7F 61 A4 AA 66 31 D5 91 37 3A 82 9A 29 EB 7E
16 : 36 : 44 <====Rx METER-2 7E A0 28 41 00 02 04 01 DA EC 7F E6 E7 00 D4 17 20 00 00 00 BD E1 13 C1 71 18 97 33 7B 63 4F BD 4E C0 56 21 C8 0E 25 E8
49 7E
16 : 36 : 44 <====Rx METER-2 D4 17 20 00 00 00 BD E1 13 C1 71 18 97 33 7B 63 4F BD 4E C0 56 21 C8 0E 25
16 : 36 : 44 <====Rx METER-2 D4 17 20 00 00 00 BD C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 44 ====>Tx METER-2 D0 12 20 00 00 00 BD C0 01 C1 00 04 01 00 09 06 00 FF 03 00
16 : 36 : 44 ====>Tx METER-2 D0 12 20 00 00 00 BD B5 11 37 8E 68 E1 BD 08 AB E0 BC 0D 59
16 : 36 : 44 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-0-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 44 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 BD B5 11 37 8E 68 E1 BD 08 AB E0 BC 0D 59 EF 6E 7E
16 : 36 : 44 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 BE 73 8C 4D 84 5C 58 A1 63 46 26 E7 FF 7E
16 : 36 : 44 <====Rx METER-2 D4 0F 20 00 00 00 BE 73 8C 4D 84 5C 58 A1 63 46 26
16 : 36 : 44 <====Rx METER-2 D4 0F 20 00 00 00 BE C4 01 81 00 02 02 0F 00 16 1C
16 : 36 : 44 ====>Tx METER-2 D0 12 20 00 00 00 BE C0 01 C1 00 04 01 00 09 06 00 FF 02 00
16 : 36 : 44 ====>Tx METER-2 D0 12 20 00 00 00 BE EF E2 9E B1 30 08 1F 59 80 6E 71 6E 97
16 : 36 : 44 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-0-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 44 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 BE EF E2 9E B1 30 08 1F 59 80 6E 71 6E 97 9C 8D 7E
16 : 36 : 44 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 BF 2E 10 B4 2F CC A9 77 4F 7A A9 3A 7E
16 : 36 : 44 <====Rx METER-2 D4 0E 20 00 00 00 BF 2E 10 B4 2F CC A9 77 4F 7A
16 : 36 : 44 <====Rx METER-2 D4 0E 20 00 00 00 BF C4 01 81 00 17 00 00 00 00
16 : 36 : 44 ====>Tx METER-2 D0 12 20 00 00 00 BF C0 01 C1 00 04 01 00 09 06 00 FF 04 00
16 : 36 : 44 ====>Tx METER-2 D0 12 20 00 00 00 BF 92 76 4C D8 0D 7B D2 D4 5B B5 9C 11 6A
16 : 36 : 44 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-0-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 44 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 BF 92 76 4C D8 0D 7B D2 D4 5B B5 9C 11 6A 00 B3 7E
16 : 36 : 44 <====Rx METER-2 7E A0 1B 41 00 02 04 01 30 9C 49 E6 E7 00 D4 0A 20 00 00 00 C0 ED 3B DF F9 7E 72 F3 7E
16 : 36 : 44 <====Rx METER-2 D4 0A 20 00 00 00 C0 ED 3B DF F9 7E
16 : 36 : 45 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 36 : 45 <====Rx METER-2 D4 0A 20 00 00 00 C0 C4 01 81 00 00
16 : 36 : 45 METER-2 SERVICE = GET RESPONSE
16 : 36 : 45 METER-2 COSEM OUT DATA
16 : 36 : 45 ====>Tx METER-2 D0 12 20 00 00 00 C0 C0 01 C1 00 04 01 00 09 06 00 FF 05 00
16 : 36 : 45 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 45 ====>Tx METER-2 D0 12 20 00 00 00 C0 2A 7B 9A C8 EF 92 23 7A 6C 36 24 7C DA
16 : 36 : 45 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-0-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 45 METER-2 SENDING HDLC FRAME
16 : 36 : 45 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 C0 2A 7B 9A C8 EF 92 23 7A 6C 36 24 7C DA 13 10 7E
16 : 36 : 45 METER-2 RECEIVED HDLC FRAME
16 : 36 : 45 <====Rx METER-2 7E A0 28 41 00 02 04 01 52 AC 77 E6 E7 00 D4 17 20 00 00 00 C1 25 A5 27 AA AA EC FB 7A F2 77 E4 D6 17 C8 3E 49 4A 64 0B
15 7E
16 : 36 : 45 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 45 <====Rx METER-2 D4 17 20 00 00 00 C1 25 A5 27 AA AA EC FB 7A F2 77 E4 D6 17 C8 3E 49 4A 64
16 : 36 : 45 <====Rx METER-2 D4 17 20 00 00 00 C1 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 45 ====>Tx METER-2 D0 12 20 00 00 00 C1 C0 01 C1 00 04 01 00 09 06 01 FF 03 00
16 : 36 : 45 ====>Tx METER-2 D0 12 20 00 00 00 C1 14 8F B3 D5 C5 90 CB 27 F4 37 89 A6 4D
16 : 36 : 45 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-1-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 45 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 C1 14 8F B3 D5 C5 90 CB 27 F4 37 89 A6 4D 37 04 7E
16 : 36 : 45 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 C2 34 A5 FE E1 74 43 F5 FA 05 8B 26 1C 7E
16 : 36 : 45 <====Rx METER-2 D4 0F 20 00 00 00 C2 34 A5 FE E1 74 43 F5 FA 05 8B
16 : 36 : 45 <====Rx METER-2 D4 0F 20 00 00 00 C2 C4 01 81 00 02 02 0F 00 16 1C
16 : 36 : 45 ====>Tx METER-2 D0 12 20 00 00 00 C2 C0 01 C1 00 04 01 00 09 06 01 FF 02 00
16 : 36 : 45 ====>Tx METER-2 D0 12 20 00 00 00 C2 9E 00 11 CD D9 BF 92 0F 6E 24 44 B3 EF
16 : 36 : 45 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-1-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 45 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 C2 9E 00 11 CD D9 BF 92 0F 6E 24 44 B3 EF D7 02 7E
16 : 36 : 45 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 C3 73 D2 07 EB 75 70 E9 0A 69 62 1F 7E
16 : 36 : 45 <====Rx METER-2 D4 0E 20 00 00 00 C3 73 D2 07 EB 75 70 E9 0A 69
16 : 36 : 45 <====Rx METER-2 D4 0E 20 00 00 00 C3 C4 01 81 00 17 00 00 00 00
16 : 36 : 45 ====>Tx METER-2 D0 12 20 00 00 00 C3 C0 01 C1 00 04 01 00 09 06 01 FF 04 00
16 : 36 : 45 ====>Tx METER-2 D0 12 20 00 00 00 C3 C0 9B 32 CE B7 4B EE FF 27 DB 29 B6 3A
16 : 36 : 45 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-1-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 45 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 C3 C0 9B 32 CE B7 4B EE FF 27 DB 29 B6 3A F1 84 7E
16 : 36 : 45 <====Rx METER-2 7E A0 1B 41 00 02 04 01 B8 DC 41 E6 E7 00 D4 0A 20 00 00 00 C4 ED 51 B0 62 30 91 BF 7E
16 : 36 : 45 <====Rx METER-2 D4 0A 20 00 00 00 C4 ED 51 B0 62 30
16 : 36 : 45 <====Rx METER-2 D4 0A 20 00 00 00 C4 C4 01 81 00 00
16 : 36 : 45 ====>Tx METER-2 D0 12 20 00 00 00 C4 C0 01 C1 00 04 01 00 09 06 01 FF 05 00
16 : 36 : 46 ====>Tx METER-2 D0 12 20 00 00 00 C4 75 A4 64 8F EF 61 B6 CD 1F D6 EA 1F 55
16 : 36 : 46 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-1-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 46 METER-2 SENDING HDLC FRAME
16 : 36 : 46 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 C4 75 A4 64 8F EF 61 B6 CD 1F D6 EA 1F 55 E7 DA 7E
16 : 36 : 46 METER-2 RECEIVED HDLC FRAME
16 : 36 : 46 <====Rx METER-2 7E A0 28 41 00 02 04 01 DA EC 7F E6 E7 00 D4 17 20 00 00 00 C5 BE D4 E5 F1 66 69 FE 59 1C E8 BC 82 A8 D1 0F 57 85 5D F8
27 7E
16 : 36 : 46 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 46 <====Rx METER-2 D4 17 20 00 00 00 C5 BE D4 E5 F1 66 69 FE 59 1C E8 BC 82 A8 D1 0F 57 85 5D
16 : 36 : 46 <====Rx METER-2 D4 17 20 00 00 00 C5 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 46 METER-2 SERVICE = GET RESPONSE
16 : 36 : 46 METER-2 COSEM OUT DATA
16 : 36 : 46 ====>Tx METER-2 D0 12 20 00 00 00 C5 C0 01 C1 00 04 01 00 09 06 02 FF 03 00
16 : 36 : 46 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 46 ====>Tx METER-2 D0 12 20 00 00 00 C5 58 02 49 DF 05 7C 97 B7 4A F4 D2 FC AC
16 : 36 : 46 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-2-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 46 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 C5 58 02 49 DF 05 7C 97 B7 4A F4 D2 FC AC 2D B7 7E
16 : 36 : 46 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 C6 07 B6 CB 11 66 B8 F3 C0 DC EE BC 1C 7E
16 : 36 : 46 <====Rx METER-2 D4 0F 20 00 00 00 C6 07 B6 CB 11 66 B8 F3 C0 DC EE
16 : 36 : 46 <====Rx METER-2 D4 0F 20 00 00 00 C6 C4 01 81 00 02 02 0F 00 16 1C
16 : 36 : 46 ====>Tx METER-2 D0 12 20 00 00 00 C6 C0 01 C1 00 04 01 00 09 06 02 FF 02 00
16 : 36 : 46 ====>Tx METER-2 D0 12 20 00 00 00 C6 BA C0 85 A6 9B 38 F3 29 0B 29 74 E3 85
16 : 36 : 46 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-2-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 46 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 C6 BA C0 85 A6 9B 38 F3 29 0B 29 74 E3 85 8D EF 7E
16 : 36 : 46 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 C7 84 3D 38 79 C3 47 A1 09 79 3C C1 7E
16 : 36 : 46 <====Rx METER-2 D4 0E 20 00 00 00 C7 84 3D 38 79 C3 47 A1 09 79
16 : 36 : 46 <====Rx METER-2 D4 0E 20 00 00 00 C7 C4 01 81 00 17 00 00 00 00
16 : 36 : 46 ====>Tx METER-2 D0 12 20 00 00 00 C7 C0 01 C1 00 04 01 00 09 06 02 FF 04 00
16 : 36 : 46 ====>Tx METER-2 D0 12 20 00 00 00 C7 25 5A D6 4B 06 9A 2E A0 D6 C6 5E 37 A8
16 : 36 : 46 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-2-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 46 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 C7 25 5A D6 4B 06 9A 2E A0 D6 C6 5E 37 A8 45 EE 7E
16 : 36 : 46 <====Rx METER-2 7E A0 1B 41 00 02 04 01 30 9C 49 E6 E7 00 D4 0A 20 00 00 00 C8 A5 53 47 82 B0 B1 41 7E
16 : 36 : 46 <====Rx METER-2 D4 0A 20 00 00 00 C8 A5 53 47 82 B0
16 : 36 : 46 <====Rx METER-2 D4 0A 20 00 00 00 C8 C4 01 81 00 00
16 : 36 : 46 ====>Tx METER-2 D0 12 20 00 00 00 C8 C0 01 C1 00 04 01 00 09 06 02 FF 05 00
16 : 36 : 46 ====>Tx METER-2 D0 12 20 00 00 00 C8 14 1B 6B 44 E2 7C 70 E4 A8 72 9B 1C 90
16 : 36 : 46 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-2-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 46 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 C8 14 1B 6B 44 E2 7C 70 E4 A8 72 9B 1C 90 CA 75 7E
16 : 36 : 47 <====Rx METER-2 7E A0 28 41 00 02 04 01 52 AC 77 E6 E7 00 D4 17 20 00 00 00 C9 AC DD AF ED 63 4A 42 64 C7 E4 97 14 28 B1 31 4F 71 B9 1B
62 7E
16 : 36 : 47 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 47 <====Rx METER-2 D4 17 20 00 00 00 C9 AC DD AF ED 63 4A 42 64 C7 E4 97 14 28 B1 31 4F 71 B9
16 : 36 : 47 <====Rx METER-2 D4 17 20 00 00 00 C9 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 47 METER-2 SERVICE = GET RESPONSE
16 : 36 : 47 METER-2 COSEM OUT DATA
16 : 36 : 47 ====>Tx METER-2 D0 12 20 00 00 00 C9 C0 01 C1 00 04 01 00 09 06 03 FF 03 00
16 : 36 : 47 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 47 ====>Tx METER-2 D0 12 20 00 00 00 C9 01 6C C0 A0 74 85 21 10 D7 EA 49 97 FA
16 : 36 : 47 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-3-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 47 METER-2 SENDING HDLC FRAME
16 : 36 : 47 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 C9 01 6C C0 A0 74 85 21 10 D7 EA 49 97 FA 13 D3 7E
16 : 36 : 47 METER-2 RECEIVED HDLC FRAME
16 : 36 : 47 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 CA F1 07 1E DF DB 05 87 DB 71 5E 87 44 7E
16 : 36 : 47 <====Rx METER-2 D4 0F 20 00 00 00 CA F1 07 1E DF DB 05 87 DB 71 5E
16 : 36 : 47 <====Rx METER-2 D4 0F 20 00 00 00 CA C4 01 81 00 02 02 0F 00 16 1C
16 : 36 : 47 ====>Tx METER-2 D0 12 20 00 00 00 CA C0 01 C1 00 04 01 00 09 06 03 FF 02 00
16 : 36 : 47 ====>Tx METER-2 D0 12 20 00 00 00 CA 9E 72 2C 74 87 E6 25 96 CA D4 68 6F 46
16 : 36 : 47 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-3-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 47 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 CA 9E 72 2C 74 87 E6 25 96 CA D4 68 6F 46 08 46 7E
16 : 36 : 47 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 CB 28 A6 8D 72 FF 22 DF 4B E6 56 0C 7E
16 : 36 : 47 <====Rx METER-2 D4 0E 20 00 00 00 CB 28 A6 8D 72 FF 22 DF 4B E6
16 : 36 : 47 <====Rx METER-2 D4 0E 20 00 00 00 CB C4 01 81 00 17 00 00 00 00
16 : 36 : 47 ====>Tx METER-2 D0 12 20 00 00 00 CB C0 01 C1 00 04 01 00 09 06 03 FF 04 00
16 : 36 : 47 ====>Tx METER-2 D0 12 20 00 00 00 CB 42 A0 83 E5 44 10 4F 8C 29 27 AF 50 0B
16 : 36 : 47 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-3-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 47 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 CB 42 A0 83 E5 44 10 4F 8C 29 27 AF 50 0B AD E0 7E
16 : 36 : 47 <====Rx METER-2 7E A0 1B 41 00 02 04 01 B8 DC 41 E6 E7 00 D4 0A 20 00 00 00 CC 0A D1 8E 95 B2 32 A8 7E
16 : 36 : 47 <====Rx METER-2 D4 0A 20 00 00 00 CC 0A D1 8E 95 B2
16 : 36 : 47 <====Rx METER-2 D4 0A 20 00 00 00 CC C4 01 81 00 00
16 : 36 : 47 ====>Tx METER-2 D0 12 20 00 00 00 CC C0 01 C1 00 04 01 00 09 06 03 FF 05 00
16 : 36 : 47 ====>Tx METER-2 D0 12 20 00 00 00 CC 3F E5 C4 0F AD E3 CD E8 ED 7C 49 14 77
16 : 36 : 47 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-3-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 47 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 CC 3F E5 C4 0F AD E3 CD E8 ED 7C 49 14 77 3E CA 7E
16 : 36 : 47 <====Rx METER-2 7E A0 28 41 00 02 04 01 DA EC 7F E6 E7 00 D4 17 20 00 00 00 CD EC 66 37 0B 4C 8C 61 62 4A AC D3 C1 E0 0E 89 DB 0B F9 B9
C6 7E
16 : 36 : 47 <====Rx METER-2 D4 17 20 00 00 00 CD EC 66 37 0B 4C 8C 61 62 4A AC D3 C1 E0 0E 89 DB 0B F9
16 : 36 : 47 <====Rx METER-2 D4 17 20 00 00 00 CD C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 48 METER-2 SERVICE = GET RESPONSE
16 : 36 : 48 METER-2 COSEM OUT DATA
16 : 36 : 48 ====>Tx METER-2 D0 12 20 00 00 00 CD C0 01 C1 00 04 01 00 09 06 04 FF 03 00
16 : 36 : 48 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 48 ====>Tx METER-2 D0 12 20 00 00 00 CD 5A 79 EF 20 ED 20 77 EC D4 DE DD 86 67
16 : 36 : 48 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-4-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 48 METER-2 SENDING HDLC FRAME
16 : 36 : 48 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 CD 5A 79 EF 20 ED 20 77 EC D4 DE DD 86 67 C2 C1 7E
16 : 36 : 48 METER-2 RECEIVED HDLC FRAME
16 : 36 : 48 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 CE 6D 61 D4 C5 ED E5 B5 49 75 6F 3B 28 7E
16 : 36 : 48 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 48 <====Rx METER-2 D4 0F 20 00 00 00 CE 6D 61 D4 C5 ED E5 B5 49 75 6F
16 : 36 : 48 <====Rx METER-2 D4 0F 20 00 00 00 CE C4 01 81 00 02 02 0F 00 16 1C
16 : 36 : 48 ====>Tx METER-2 D0 12 20 00 00 00 CE C0 01 C1 00 04 01 00 09 06 04 FF 02 00
16 : 36 : 48 ====>Tx METER-2 D0 12 20 00 00 00 CE 79 95 85 28 31 C7 90 A3 29 C7 85 7A B7
16 : 36 : 48 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-4-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 48 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 CE 79 95 85 28 31 C7 90 A3 29 C7 85 7A B7 21 29 7E
16 : 36 : 48 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 CF DF 72 6E F5 12 CE 22 7C 91 F4 F4 7E
16 : 36 : 48 <====Rx METER-2 D4 0E 20 00 00 00 CF DF 72 6E F5 12 CE 22 7C 91
16 : 36 : 48 <====Rx METER-2 D4 0E 20 00 00 00 CF C4 01 81 00 17 00 00 00 00
16 : 36 : 48 ====>Tx METER-2 D0 12 20 00 00 00 CF C0 01 C1 00 04 01 00 09 06 04 FF 04 00
16 : 36 : 48 ====>Tx METER-2 D0 12 20 00 00 00 CF F1 0B 3D 95 63 0B 33 C7 78 29 6B 9A D8
16 : 36 : 48 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-4-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 48 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 CF F1 0B 3D 95 63 0B 33 C7 78 29 6B 9A D8 68 5C 7E
16 : 36 : 48 <====Rx METER-2 7E A0 1B 41 00 02 04 01 30 9C 49 E6 E7 00 D4 0A 20 00 00 00 D0 AD 96 42 67 04 C4 70 7E
16 : 36 : 48 <====Rx METER-2 D4 0A 20 00 00 00 D0 AD 96 42 67 04
16 : 36 : 48 <====Rx METER-2 D4 0A 20 00 00 00 D0 C4 01 81 00 00
16 : 36 : 48 ====>Tx METER-2 D0 12 20 00 00 00 D0 C0 01 C1 00 04 01 00 09 06 04 FF 05 00
16 : 36 : 48 ====>Tx METER-2 D0 12 20 00 00 00 D0 DB 34 AE 87 08 E8 DF EB F3 C1 37 EE 78
16 : 36 : 48 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-9-6-4-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 48 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 D0 DB 34 AE 87 08 E8 DF EB F3 C1 37 EE 78 13 22 7E
16 : 36 : 48 <====Rx METER-2 7E A0 28 41 00 02 04 01 52 AC 77 E6 E7 00 D4 17 20 00 00 00 D1 62 76 5A 06 22 D2 81 99 4D 18 6F CB FE 48 F5 AB AD E0 65
15 7E
16 : 36 : 48 <====Rx METER-2 D4 17 20 00 00 00 D1 62 76 5A 06 22 D2 81 99 4D 18 6F CB FE 48 F5 AB AD E0
16 : 36 : 48 <====Rx METER-2 D4 17 20 00 00 00 D1 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 48 ====>Tx METER-2 D0 12 20 00 00 00 D1 C0 01 C1 00 04 01 00 0A 06 00 FF 03 00
16 : 36 : 48 ====>Tx METER-2 D0 12 20 00 00 00 D1 50 C4 1B 3B 25 B8 FE 28 EA BE F0 3E C6
16 : 36 : 49 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-0-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 49 METER-2 SENDING HDLC FRAME
16 : 36 : 49 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 D1 50 C4 1B 3B 25 B8 FE 28 EA BE F0 3E C6 4B CA 7E
16 : 36 : 49 METER-2 RECEIVED HDLC FRAME
16 : 36 : 49 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 D2 ED 37 9A 95 B3 5E B1 3C 59 8D 01 66 7E
16 : 36 : 49 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 49 <====Rx METER-2 D4 0F 20 00 00 00 D2 ED 37 9A 95 B3 5E B1 3C 59 8D
16 : 36 : 49 <====Rx METER-2 D4 0F 20 00 00 00 D2 C4 01 81 00 02 02 0F 00 16 1C
16 : 36 : 49 METER-2 SERVICE = GET RESPONSE
16 : 36 : 49 METER-2 COSEM OUT DATA
16 : 36 : 49 ====>Tx METER-2 D0 12 20 00 00 00 D2 C0 01 C1 00 04 01 00 0A 06 00 FF 02 00
16 : 36 : 49 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 49 ====>Tx METER-2 D0 12 20 00 00 00 D2 91 10 E9 8D A6 F4 DB A0 3E 81 79 5B 6B
16 : 36 : 49 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-0-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 49 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 D2 91 10 E9 8D A6 F4 DB A0 3E 81 79 5B 6B 50 71 7E
16 : 36 : 49 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 D3 E2 45 46 3E 93 51 CF 6E 69 CC EA 7E
16 : 36 : 49 <====Rx METER-2 D4 0E 20 00 00 00 D3 E2 45 46 3E 93 51 CF 6E 69
16 : 36 : 49 <====Rx METER-2 D4 0E 20 00 00 00 D3 C4 01 81 00 17 00 00 00 00
16 : 36 : 49 ====>Tx METER-2 D0 12 20 00 00 00 D3 C0 01 C1 00 04 01 00 0A 06 00 FF 04 00
16 : 36 : 49 ====>Tx METER-2 D0 12 20 00 00 00 D3 49 1C BB 91 24 54 42 2B 8A F9 81 44 F3
16 : 36 : 49 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-0-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 49 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 D3 49 1C BB 91 24 54 42 2B 8A F9 81 44 F3 DC 3E 7E
16 : 36 : 49 <====Rx METER-2 7E A0 1B 41 00 02 04 01 B8 DC 41 E6 E7 00 D4 0A 20 00 00 00 D4 31 72 A8 DD 65 61 20 7E
16 : 36 : 49 <====Rx METER-2 D4 0A 20 00 00 00 D4 31 72 A8 DD 65
16 : 36 : 49 <====Rx METER-2 D4 0A 20 00 00 00 D4 C4 01 81 00 00
16 : 36 : 49 ====>Tx METER-2 D0 12 20 00 00 00 D4 C0 01 C1 00 04 01 00 0A 06 00 FF 05 00
16 : 36 : 49 ====>Tx METER-2 D0 12 20 00 00 00 D4 9A 51 2A 74 BC FF 9B 28 03 EB 54 C8 E8
16 : 36 : 49 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-0-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 49 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 D4 9A 51 2A 74 BC FF 9B 28 03 EB 54 C8 E8 67 2C 7E
16 : 36 : 49 <====Rx METER-2 7E A0 28 41 00 02 04 01 DA EC 7F E6 E7 00 D4 17 20 00 00 00 D5 C4 41 36 EB 6F 30 90 68 7D 43 55 D4 85 A4 D4 75 20 CF 28
F0 7E
16 : 36 : 49 <====Rx METER-2 D4 17 20 00 00 00 D5 C4 41 36 EB 6F 30 90 68 7D 43 55 D4 85 A4 D4 75 20 CF
16 : 36 : 49 <====Rx METER-2 D4 17 20 00 00 00 D5 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 49 ====>Tx METER-2 D0 12 20 00 00 00 D5 C0 01 C1 00 04 01 00 0A 06 01 FF 03 00
16 : 36 : 49 ====>Tx METER-2 D0 12 20 00 00 00 D5 5E B3 AC 90 E7 64 09 58 24 C9 96 6B E4
16 : 36 : 49 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-1-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 49 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 D5 5E B3 AC 90 E7 64 09 58 24 C9 96 6B E4 BA E9 7E
16 : 36 : 49 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 D6 AE 6F CB B0 C0 4A D8 99 B5 FC 9B 73 7E
16 : 36 : 50 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 50 <====Rx METER-2 D4 0F 20 00 00 00 D6 AE 6F CB B0 C0 4A D8 99 B5 FC
16 : 36 : 50 <====Rx METER-2 D4 0F 20 00 00 00 D6 C4 01 81 00 02 02 0F 00 16 1C
16 : 36 : 50 METER-2 SERVICE = GET RESPONSE
16 : 36 : 50 METER-2 COSEM OUT DATA
16 : 36 : 50 ====>Tx METER-2 D0 12 20 00 00 00 D6 C0 01 C1 00 04 01 00 0A 06 01 FF 02 00
16 : 36 : 50 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 50 ====>Tx METER-2 D0 12 20 00 00 00 D6 B9 B1 C0 AA 8D 0A 25 C5 63 09 2D A9 57
16 : 36 : 50 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-1-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 50 METER-2 SENDING HDLC FRAME
16 : 36 : 50 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 D6 B9 B1 C0 AA 8D 0A 25 C5 63 09 2D A9 57 A4 43 7E
16 : 36 : 50 METER-2 RECEIVED HDLC FRAME
16 : 36 : 50 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 D7 5B 32 31 3F 8D 25 D9 47 2F 11 1F 7E
16 : 36 : 50 <====Rx METER-2 D4 0E 20 00 00 00 D7 5B 32 31 3F 8D 25 D9 47 2F
16 : 36 : 50 <====Rx METER-2 D4 0E 20 00 00 00 D7 C4 01 81 00 17 00 00 00 00
16 : 36 : 50 ====>Tx METER-2 D0 12 20 00 00 00 D7 C0 01 C1 00 04 01 00 0A 06 01 FF 04 00
16 : 36 : 50 ====>Tx METER-2 D0 12 20 00 00 00 D7 68 CB EB AF 29 EB A9 E9 00 8B 78 E1 06
16 : 36 : 50 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-1-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 50 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 D7 68 CB EB AF 29 EB A9 E9 00 8B 78 E1 06 60 55 7E
16 : 36 : 50 <====Rx METER-2 7E A0 1B 41 00 02 04 01 30 9C 49 E6 E7 00 D4 0A 20 00 00 00 D8 5D 0F C6 02 31 D8 CB 7E
16 : 36 : 50 <====Rx METER-2 D4 0A 20 00 00 00 D8 5D 0F C6 02 31
16 : 36 : 50 <====Rx METER-2 D4 0A 20 00 00 00 D8 C4 01 81 00 00
16 : 36 : 50 ====>Tx METER-2 D0 12 20 00 00 00 D8 C0 01 C1 00 04 01 00 0A 06 01 FF 05 00
16 : 36 : 50 ====>Tx METER-2 D0 12 20 00 00 00 D8 8A CC 5E F5 C7 C4 FE 73 9D 4D F5 01 ED
16 : 36 : 50 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-1-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 50 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 D8 8A CC 5E F5 C7 C4 FE 73 9D 4D F5 01 ED 6F 48 7E
16 : 36 : 50 <====Rx METER-2 7E A0 28 41 00 02 04 01 52 AC 77 E6 E7 00 D4 17 20 00 00 00 D9 85 93 09 1C 15 ED C9 AB 20 4C 57 F4 70 27 A8 C3 2E F5 25
03 7E
16 : 36 : 50 <====Rx METER-2 D4 17 20 00 00 00 D9 85 93 09 1C 15 ED C9 AB 20 4C 57 F4 70 27 A8 C3 2E F5
16 : 36 : 50 <====Rx METER-2 D4 17 20 00 00 00 D9 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 50 ====>Tx METER-2 D0 12 20 00 00 00 D9 C0 01 C1 00 04 01 00 0A 06 02 FF 03 00
16 : 36 : 50 ====>Tx METER-2 D0 12 20 00 00 00 D9 ED 06 8D 5E 66 75 C3 A1 A7 A1 A6 62 DC
16 : 36 : 50 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-2-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 50 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 D9 ED 06 8D 5E 66 75 C3 A1 A7 A1 A6 62 DC 0A 1E 7E
16 : 36 : 50 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 DA 49 EB 5E EB 39 D7 94 A4 A6 3D B2 C5 7E
16 : 36 : 50 <====Rx METER-2 D4 0F 20 00 00 00 DA 49 EB 5E EB 39 D7 94 A4 A6 3D
16 : 36 : 50 <====Rx METER-2 D4 0F 20 00 00 00 DA C4 01 81 00 02 02 0F 00 16 1C
16 : 36 : 51 METER-2 COSEM OUT DATA
16 : 36 : 51 ====>Tx METER-2 D0 12 20 00 00 00 DA C0 01 C1 00 04 01 00 0A 06 02 FF 02 00
16 : 36 : 51 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 51 ====>Tx METER-2 D0 12 20 00 00 00 DA 22 31 97 95 68 0C C1 27 E8 10 FC A0 63
16 : 36 : 51 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-2-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 51 METER-2 SENDING HDLC FRAME
16 : 36 : 51 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 DA 22 31 97 95 68 0C C1 27 E8 10 FC A0 63 56 7E 7E
16 : 36 : 51 METER-2 RECEIVED HDLC FRAME
16 : 36 : 51 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 DB 57 97 B8 19 BB 52 C5 66 2B 92 88 7E
16 : 36 : 51 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 51 <====Rx METER-2 D4 0E 20 00 00 00 DB 57 97 B8 19 BB 52 C5 66 2B
16 : 36 : 51 <====Rx METER-2 D4 0E 20 00 00 00 DB C4 01 81 00 17 00 00 00 00
16 : 36 : 51 METER-2 SERVICE = GET RESPONSE
16 : 36 : 51 ====>Tx METER-2 D0 12 20 00 00 00 DB C0 01 C1 00 04 01 00 0A 06 02 FF 04 00
16 : 36 : 51 ====>Tx METER-2 D0 12 20 00 00 00 DB 6F D5 7C 6D 27 21 7F 33 4F 10 AE 1F 86
16 : 36 : 51 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-2-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 51 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 DB 6F D5 7C 6D 27 21 7F 33 4F 10 AE 1F 86 7E 8C 7E
16 : 36 : 51 <====Rx METER-2 7E A0 1B 41 00 02 04 01 B8 DC 41 E6 E7 00 D4 0A 20 00 00 00 DC 34 7B BC E3 69 24 DE 7E
16 : 36 : 51 <====Rx METER-2 D4 0A 20 00 00 00 DC 34 7B BC E3 69
16 : 36 : 51 <====Rx METER-2 D4 0A 20 00 00 00 DC C4 01 81 00 00
16 : 36 : 51 ====>Tx METER-2 D0 12 20 00 00 00 DC C0 01 C1 00 04 01 00 0A 06 02 FF 05 00
16 : 36 : 51 ====>Tx METER-2 D0 12 20 00 00 00 DC 51 82 50 51 C3 19 29 4F 9E D4 A7 67 7D
16 : 36 : 51 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-2-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 51 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 DC 51 82 50 51 C3 19 29 4F 9E D4 A7 67 7D A3 E6 7E
16 : 36 : 51 <====Rx METER-2 7E A0 28 41 00 02 04 01 DA EC 7F E6 E7 00 D4 17 20 00 00 00 DD 7F 33 49 A9 09 C9 23 3B 18 AC CA 9B 86 4F 02 35 D5 2A 3B
C1 7E
16 : 36 : 51 <====Rx METER-2 D4 17 20 00 00 00 DD 7F 33 49 A9 09 C9 23 3B 18 AC CA 9B 86 4F 02 35 D5 2A
16 : 36 : 51 <====Rx METER-2 D4 17 20 00 00 00 DD C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 51 ====>Tx METER-2 D0 12 20 00 00 00 DD C0 01 C1 00 04 01 00 0A 06 03 FF 03 00
16 : 36 : 51 ====>Tx METER-2 D0 12 20 00 00 00 DD B3 A6 49 62 33 DA 38 93 E9 3B 59 CB 19
16 : 36 : 51 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-3-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 51 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 DD B3 A6 49 62 33 DA 38 93 E9 3B 59 CB 19 89 F3 7E
16 : 36 : 51 <====Rx METER-2 7E A0 20 41 00 02 04 01 FC 34 E5 E6 E7 00 D4 0F 20 00 00 00 DE 70 CF 1B 97 81 65 E8 10 9A 05 29 17 7E
16 : 36 : 51 <====Rx METER-2 D4 0F 20 00 00 00 DE 70 CF 1B 97 81 65 E8 10 9A 05
16 : 36 : 51 <====Rx METER-2 D4 0F 20 00 00 00 DE C4 01 81 00 02 02 0F 00 16 1C
16 : 36 : 51 ====>Tx METER-2 D0 12 20 00 00 00 DE C0 01 C1 00 04 01 00 0A 06 03 FF 02 00
16 : 36 : 51 ====>Tx METER-2 D0 12 20 00 00 00 DE F2 64 13 80 92 67 2D CC CC F2 9F 41 28
16 : 36 : 51 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-3-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 52 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 DE F2 64 13 80 92 67 2D CC CC F2 9F 41 28 42 92 7E
16 : 36 : 52 METER-2 RECEIVED HDLC FRAME
16 : 36 : 52 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 DF 91 30 E8 85 5B 03 B9 DE 73 C3 B6 7E
16 : 36 : 52 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 52 <====Rx METER-2 D4 0E 20 00 00 00 DF 91 30 E8 85 5B 03 B9 DE 73
16 : 36 : 52 <====Rx METER-2 D4 0E 20 00 00 00 DF C4 01 81 00 17 00 00 00 00
16 : 36 : 52 METER-2 SERVICE = GET RESPONSE
16 : 36 : 52 METER-2 COSEM OUT DATA
16 : 36 : 52 ====>Tx METER-2 D0 12 20 00 00 00 DF C0 01 C1 00 04 01 00 0A 06 03 FF 04 00
16 : 36 : 52 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 52 ====>Tx METER-2 D0 12 20 00 00 00 DF 3D BC 1D 05 BD C0 54 0B 60 C9 D0 1A 05
16 : 36 : 52 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-3-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 52 METER-2 SENDING HDLC FRAME
16 : 36 : 52 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 DF 3D BC 1D 05 BD C0 54 0B 60 C9 D0 1A 05 B4 B6 7E
16 : 36 : 52 <====Rx METER-2 7E A0 1B 41 00 02 04 01 30 9C 49 E6 E7 00 D4 0A 20 00 00 00 E0 45 A7 62 6A 63 61 32 7E
16 : 36 : 52 <====Rx METER-2 D4 0A 20 00 00 00 E0 45 A7 62 6A 63
16 : 36 : 52 <====Rx METER-2 D4 0A 20 00 00 00 E0 C4 01 81 00 00
16 : 36 : 52 ====>Tx METER-2 D0 12 20 00 00 00 E0 C0 01 C1 00 04 01 00 0A 06 03 FF 05 00
16 : 36 : 52 ====>Tx METER-2 D0 12 20 00 00 00 E0 B6 40 CC 50 15 4B 9D 03 84 AD 4F D1 DD
16 : 36 : 52 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-3-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 52 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 E0 B6 40 CC 50 15 4B 9D 03 84 AD 4F D1 DD 58 48 7E
16 : 36 : 52 <====Rx METER-2 7E A0 28 41 00 02 04 01 52 AC 77 E6 E7 00 D4 17 20 00 00 00 E1 FD A0 49 D8 14 B5 88 EF B7 73 3B DA DC B6 4E CC FF 75 94
DF 7E
16 : 36 : 52 <====Rx METER-2 D4 17 20 00 00 00 E1 FD A0 49 D8 14 B5 88 EF B7 73 3B DA DC B6 4E CC FF 75
16 : 36 : 52 <====Rx METER-2 D4 17 20 00 00 00 E1 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 52 ====>Tx METER-2 D0 12 20 00 00 00 E1 C0 01 C1 00 04 01 00 0A 06 04 FF 03 00
16 : 36 : 52 ====>Tx METER-2 D0 12 20 00 00 00 E1 7A 67 8C D9 5A DC CB 92 40 71 00 15 13
16 : 36 : 52 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-4-255, IC = 4, ATTR: INDEX = 3
16 : 36 : 52 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 E1 7A 67 8C D9 5A DC CB 92 40 71 00 15 13 8E F9 7E
16 : 36 : 52 <====Rx METER-2 7E A0 20 41 00 02 04 01 74 74 ED E6 E7 00 D4 0F 20 00 00 00 E2 C4 44 5A 86 0B 8D 50 0B C8 32 BA 79 7E
16 : 36 : 52 <====Rx METER-2 D4 0F 20 00 00 00 E2 C4 44 5A 86 0B 8D 50 0B C8 32
16 : 36 : 52 <====Rx METER-2 D4 0F 20 00 00 00 E2 C4 01 81 00 02 02 0F 00 16 1C
16 : 36 : 52 ====>Tx METER-2 D0 12 20 00 00 00 E2 C0 01 C1 00 04 01 00 0A 06 04 FF 02 00
16 : 36 : 52 ====>Tx METER-2 D0 12 20 00 00 00 E2 C5 AB C3 96 5C 92 B2 53 E6 B4 C9 4E 76
16 : 36 : 52 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-4-255, IC = 4, ATTR: INDEX = 2
16 : 36 : 52 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 E2 C5 AB C3 96 5C 92 B2 53 E6 B4 C9 4E 76 F1 0E 7E
16 : 36 : 52 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 E3 15 47 E3 15 CA AD 1C D4 57 56 5A 7E
16 : 36 : 53 <====Rx METER-2 D4 0E 20 00 00 00 E3 15 47 E3 15 CA AD 1C D4 57
16 : 36 : 53 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 36 : 53 <====Rx METER-2 D4 0E 20 00 00 00 E3 C4 01 81 00 17 00 00 00 00
16 : 36 : 53 METER-2 SERVICE = GET RESPONSE
16 : 36 : 53 METER-2 COSEM OUT DATA
16 : 36 : 53 ====>Tx METER-2 D0 12 20 00 00 00 E3 C0 01 C1 00 04 01 00 0A 06 04 FF 04 00
16 : 36 : 53 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 53 ====>Tx METER-2 D0 12 20 00 00 00 E3 4E A5 C4 EC 82 90 59 C4 C6 16 7A 69 D1
16 : 36 : 53 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-4-255, IC = 4, ATTR: INDEX = 4
16 : 36 : 53 METER-2 SENDING HDLC FRAME
16 : 36 : 53 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 E3 4E A5 C4 EC 82 90 59 C4 C6 16 7A 69 D1 2B 05 7E
16 : 36 : 53 METER-2 RECEIVED HDLC FRAME
16 : 36 : 53 <====Rx METER-2 7E A0 1B 41 00 02 04 01 B8 DC 41 E6 E7 00 D4 0A 20 00 00 00 E4 B9 B2 BF 45 D7 89 44 7E
16 : 36 : 53 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 53 <====Rx METER-2 D4 0A 20 00 00 00 E4 B9 B2 BF 45 D7
16 : 36 : 53 <====Rx METER-2 D4 0A 20 00 00 00 E4 C4 01 81 00 00
16 : 36 : 53 ====>Tx METER-2 D0 12 20 00 00 00 E4 C0 01 C1 00 04 01 00 0A 06 04 FF 05 00
16 : 36 : 53 ====>Tx METER-2 D0 12 20 00 00 00 E4 6A 24 C7 F5 5F D6 C7 73 8F 61 AB 6E CC
16 : 36 : 53 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-10-6-4-255, IC = 4, ATTR: INDEX = 5
16 : 36 : 53 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 E4 6A 24 C7 F5 5F D6 C7 73 8F 61 AB 6E CC BB 99 7E
16 : 36 : 53 <====Rx METER-2 7E A0 28 41 00 02 04 01 DA EC 7F E6 E7 00 D4 17 20 00 00 00 E5 51 76 0B A7 27 12 5C E1 31 22 3C D8 4B DA 59 A7 2A 01 60
1B 7E
16 : 36 : 53 <====Rx METER-2 D4 17 20 00 00 00 E5 51 76 0B A7 27 12 5C E1 31 22 3C D8 4B DA 59 A7 2A 01
16 : 36 : 53 <====Rx METER-2 D4 17 20 00 00 00 E5 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 36 : 53 ====>Tx METER-2 D0 12 20 00 00 00 E5 C0 01 C1 00 07 00 00 5E 5B 0A FF 02 00
16 : 36 : 53 ====>Tx METER-2 D0 12 20 00 00 00 E5 C2 65 52 60 30 0C FA 65 2C 86 F7 F6 56
16 : 36 : 53 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-10-255, IC = 7, ATTR: INDEX = 2
16 : 36 : 53 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 E5 C2 65 52 60 30 0C FA 65 2C 86 F7 F6 56 A3 47 7E
16 : 36 : 53 <====Rx METER-2 7E A0 82 41 00 02 04 01 FC 11 37 E6 E7 00 D4 71 20 00 00 00 E6 F8 25 BC 40 04 57 4A 28 F0 DF B3 3B 82 74 8A 15 1D 2D EC
AD C2 0C 8D 3B A6 17 31 AC 90 D0 78 7B EC 24 AC 6C 3F CC FC FC AC 4D F3 30 63 B3 A8 36 CF D8 6D 8D 39 6A 46 4B 6D A3 1E
D1 1F 0E 8F FE 78 A0 99 9B 59 D1 31 3D CC 7C AD 86 6A 0C 55 EB A6 B9 0B D5 B2 8B CE 0C AA 6E C1 F4 B1 15 9E 32 C6 D8 A3
9C 38 6A 7C 91 D8 26 37 7F 59 AE 7E
16 : 36 : 53 <====Rx METER-2 D4 71 20 00 00 00 E6 F8 25 BC 40 04 57 4A 28 F0 DF B3 3B 82 74 8A 15 1D 2D EC AD C2 0C 8D 3B A6 17 31 AC 90 D0 78 7B EC
24 AC 6C 3F CC FC FC AC 4D F3 30 63 B3 A8 36 CF D8 6D 8D 39 6A 46 4B 6D A3 1E D1 1F 0E 8F FE 78 A0 99 9B 59 D1 31 3D CC
7C AD 86 6A 0C 55 EB A6 B9 0B D5 B2 8B CE 0C AA 6E C1 F4 B1 15 9E 32 C6 D8 A3 9C 38 6A 7C 91 D8 26 37 7F
16 : 36 : 53 <====Rx METER-2 D4 71 20 00 00 00 E6 C4 01 81 00 01 01 02 08 0A 09 5A 4D 30 30 30 30 30 31 30 0A 0C 5A 45 4E 5A 4D 30 30 30 30 30 31 30
0A 2C 5A 65 6E 4D 65 74 65 72 20 53 6F 6C 75 74 69 6F 6E 73 20 50 76 74 20 4C 74 64 2E 2C 20 42 61 6E 67 61 6C 6F 72 65
20 49 6E 64 69 61 0A 07 53 31 30 36 2E 36 35 11 06 0A 02 44 31 0A 09 28 31 30 2D 36 30 29 20 41 12 07 E3
16 : 36 : 53 ====>Tx METER-2 D0 12 20 00 00 00 E6 C0 01 C1 00 07 00 00 5E 5B 0A FF 03 00
16 : 36 : 53 ====>Tx METER-2 D0 12 20 00 00 00 E6 95 FD D6 05 8D 04 50 60 C1 57 09 FE B4
16 : 36 : 53 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-10-255, IC = 7, ATTR: INDEX = 3
16 : 36 : 53 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 E6 95 FD D6 05 8D 04 50 60 C1 57 09 FE B4 68 28 7E
16 : 36 : 53 <====Rx METER-2 7E A0 AD 41 00 02 04 01 1E 7A 89 E6 E7 00 D4 81 9B 20 00 00 00 E7 7C 36 60 A5 E0 C9 75 00 25 4B D6 11 69 C6 94 6F 8C CE
48 B9 60 66 C6 93 30 29 D9 4F 22 9D 8C 65 DF 7F 49 70 28 61 2B 26 96 E8 2C C1 8C ED 92 F2 9D 45 AD 9B 64 BB CA 14 3F C6
F9 62 5A 9F A2 9A 66 6C 02 7B 42 3C F8 F6 1D 85 82 62 E2 EE 01 7C 46 62 BE F8 84 7A BA DC CF 0A D6 69 0E D8 CC 5B 9F 73
62 03 61 11 A4 AA 57 9B B3 5A B7 AC 27 21 59 B0 2F 18 09 3F 00 8A BD 49 B3 32 4F A5 7C 22 70 58 92 DE 6A 5B 94 1D 55 4A
B6 72 48 50 21 6E C7 01 63 25 6D C3 D6 18 7E
16 : 36 : 53 <====Rx METER-2 D4 81 9B 20 00 00 00 E7 7C 36 60 A5 E0 C9 75 00 25 4B D6 11 69 C6 94 6F 8C CE 48 B9 60 66 C6 93 30 29 D9 4F 22 9D 8C 65
DF 7F 49 70 28 61 2B 26 96 E8 2C C1 8C ED 92 F2 9D 45 AD 9B 64 BB CA 14 3F C6 F9 62 5A 9F A2 9A 66 6C 02 7B 42 3C F8 F6
1D 85 82 62 E2 EE 01 7C 46 62 BE F8 84 7A BA DC CF 0A D6 69 0E D8 CC 5B 9F 73 62 03 61 11 A4 AA 57 9B B3 5A B7 AC 27 21
59 B0 2F 18 09 3F 00 8A BD 49 B3 32 4F A5 7C 22 70 58 92 DE 6A 5B 94 1D 55 4A B6 72 48 50 21 6E C7 01 63 25 6D C3
16 : 36 : 53 <====Rx METER-2 D4 81 9B 20 00 00 00 E7 C4 01 81 00 01 08 02 04 12 00 01 09 06 00 00 60 01 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00
00 60 01 02 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 01 01 FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 00 02 00
FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 5E 5B 09 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 5E 5B 0B FF 0F 02 12
00 00 02 04 12 00 01 09 06 00 00 5E 5B 0C FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 01 04 FF 0F 02 12 00 00
16 : 36 : 54 ====>Tx METER-2 D0 12 20 00 00 00 E7 C0 01 C1 00 07 00 00 5E 5B 0A FF 04 00
16 : 36 : 54 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 54 ====>Tx METER-2 D0 12 20 00 00 00 E7 65 0B DC FC DB 69 A5 CB 50 8E B0 5E BF
16 : 36 : 54 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-10-255, IC = 7, ATTR: INDEX = 4
16 : 36 : 54 METER-2 SENDING HDLC FRAME
16 : 36 : 54 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 E7 65 0B DC FC DB 69 A5 CB 50 8E B0 5E BF F3 2E 7E
16 : 36 : 54 METER-2 RECEIVED HDLC FRAME
16 : 36 : 54 <====Rx METER-2 7E A0 1F 41 00 02 04 01 30 EA 26 E6 E7 00 D4 0E 20 00 00 00 E8 BA 95 56 74 58 89 3C E2 05 46 7A 7E
16 : 36 : 54 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 54 <====Rx METER-2 D4 0E 20 00 00 00 E8 BA 95 56 74 58 89 3C E2 05
16 : 36 : 54 <====Rx METER-2 D4 0E 20 00 00 00 E8 C4 01 81 00 06 00 00 00 00
16 : 36 : 54 METER-2 SERVICE = GET RESPONSE
16 : 36 : 54 ====>Tx METER-2 D0 12 20 00 00 00 E8 C0 01 C1 00 07 00 00 5E 5B 0A FF 05 00
16 : 36 : 54 ====>Tx METER-2 D0 12 20 00 00 00 E8 24 26 5F 05 0C 82 86 90 D6 69 88 61 02
16 : 36 : 54 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-10-255, IC = 7, ATTR: INDEX = 5
16 : 36 : 54 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 E8 24 26 5F 05 0C 82 86 90 D6 69 88 61 02 B2 B6 7E
16 : 36 : 54 <====Rx METER-2 7E A0 1C 41 00 02 04 01 52 90 CE E6 E7 00 D4 0B 20 00 00 00 E9 13 23 40 D8 1E AB CD 6B 7E
16 : 36 : 54 <====Rx METER-2 D4 0B 20 00 00 00 E9 13 23 40 D8 1E AB
16 : 36 : 54 <====Rx METER-2 D4 0B 20 00 00 00 E9 C4 01 81 00 16 01
16 : 36 : 54 ====>Tx METER-2 D0 12 20 00 00 00 E9 C0 01 C1 00 07 00 00 5E 5B 0A FF 06 00
16 : 36 : 54 ====>Tx METER-2 D0 12 20 00 00 00 E9 A1 3A E9 FB 3F DE AA 75 BA FA CF 5F B6
16 : 36 : 54 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-10-255, IC = 7, ATTR: INDEX = 6
16 : 36 : 54 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 E9 A1 3A E9 FB 3F DE AA 75 BA FA CF 5F B6 B0 28 7E
16 : 36 : 54 <====Rx METER-2 7E A0 2C 41 00 02 04 01 74 EE 5C E6 E7 00 D4 1B 20 00 00 00 EA 7C 88 48 E6 CC EC D0 84 72 CD C9 0A 2B E7 B0 3B 9A 44 96
14 63 4B D1 8B 7E
16 : 36 : 54 <====Rx METER-2 D4 1B 20 00 00 00 EA 7C 88 48 E6 CC EC D0 84 72 CD C9 0A 2B E7 B0 3B 9A 44 96 14 63 4B
16 : 36 : 54 <====Rx METER-2 D4 1B 20 00 00 00 EA C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 36 : 54 ====>Tx METER-2 D0 12 20 00 00 00 EA C0 01 C1 00 07 00 00 5E 5B 0A FF 07 00
16 : 36 : 54 ====>Tx METER-2 D0 12 20 00 00 00 EA 31 E7 C3 10 E1 91 62 D3 FA 2D 1B 41 FB
16 : 36 : 54 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-10-255, IC = 7, ATTR: INDEX = 7
16 : 36 : 54 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 EA 31 E7 C3 10 E1 91 62 D3 FA 2D 1B 41 FB 3D 27 7E
16 : 36 : 54 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 EB 18 41 1F BF 22 C9 5C F2 DF 00 4F 7E
16 : 36 : 54 <====Rx METER-2 D4 0E 20 00 00 00 EB 18 41 1F BF 22 C9 5C F2 DF
16 : 36 : 54 <====Rx METER-2 D4 0E 20 00 00 00 EB C4 01 81 00 06 00 00 00 01
16 : 36 : 54 ====>Tx METER-2 D0 12 20 00 00 00 EB C0 01 C1 00 07 00 00 5E 5B 0A FF 08 00
16 : 36 : 54 ====>Tx METER-2 D0 12 20 00 00 00 EB 2B 2E 33 99 29 55 C8 54 E1 2F 27 0D A3
16 : 36 : 54 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-94-91-10-255, IC = 7, ATTR: INDEX = 8
16 : 36 : 54 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 EB 2B 2E 33 99 29 55 C8 54 E1 2F 27 0D A3 D0 50 7E
16 : 36 : 55 METER-2 RECEIVED HDLC FRAME
16 : 36 : 55 <====Rx METER-2 7E A0 1F 41 00 02 04 01 B8 AA 2E E6 E7 00 D4 0E 20 00 00 00 EC 75 26 BC BA 7D 69 7E 9A 14 6F 59 7E
16 : 36 : 55 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 55 <====Rx METER-2 D4 0E 20 00 00 00 EC 75 26 BC BA 7D 69 7E 9A 14
16 : 36 : 55 <====Rx METER-2 D4 0E 20 00 00 00 EC C4 01 81 00 06 00 00 00 01
16 : 36 : 55 METER-2 SERVICE = GET RESPONSE
16 : 36 : 55 METER-2 COSEM OUT DATA
16 : 36 : 55 ====>Tx METER-2 D0 12 20 00 00 00 EC C0 01 C1 00 07 00 00 63 62 00 FF 02 00
16 : 36 : 55 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 55 ====>Tx METER-2 D0 12 20 00 00 00 EC F4 EE 6D EA 6A F4 90 87 53 C3 B1 D7 D6
16 : 36 : 55 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-0-255, IC = 7, ATTR: INDEX = 2
16 : 36 : 55 METER-2 SENDING HDLC FRAME
16 : 36 : 55 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 EC F4 EE 6D EA 6A F4 90 87 53 C3 B1 D7 D6 B0 26 7E
16 : 36 : 55 <====Rx METER-2 7E A0 1C 41 00 02 04 01 DA D0 C6 E6 E7 00 D4 0B 20 00 00 00 ED 43 4D EB 34 08 5F 11 3A 7E
16 : 36 : 55 <====Rx METER-2 D4 0B 20 00 00 00 ED 43 4D EB 34 08 5F
16 : 36 : 55 <====Rx METER-2 D4 0B 20 00 00 00 ED C4 01 81 00 01 00
16 : 36 : 55 ====>Tx METER-2 D0 12 20 00 00 00 ED C0 01 C1 00 07 00 00 63 62 00 FF 03 00
16 : 36 : 55 ====>Tx METER-2 D0 12 20 00 00 00 ED A7 B8 BF AA BA 34 F0 B5 7A 2F 1E 79 42
16 : 36 : 55 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-0-255, IC = 7, ATTR: INDEX = 3
16 : 36 : 55 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 ED A7 B8 BF AA BA 34 F0 B5 7A 2F 1E 79 42 72 56 7E
16 : 36 : 55 <====Rx METER-2 7E A0 AD 41 00 02 04 01 FC 66 4D E6 E7 00 D4 81 9B 20 00 00 00 EE 11 37 04 13 48 94 9D 8A 1B 6E 2B 9C A8 30 04 5D FA 8C
3E 52 24 BE BB 90 D7 4A D5 C8 DE 2C 9F 97 CF 6C BC C2 0A B8 5F E6 3B 72 C3 BE C2 74 2B 71 FA 87 93 69 E5 C2 0C 39 82 6D
CA F0 F5 6A A7 E2 42 6D 36 23 2B BD 17 B8 A6 62 51 B9 8C D9 2B 78 72 2A 9A E5 7D 92 D8 E5 D3 A6 82 75 C2 B4 04 62 55 E2
0D 56 D6 4A E9 A9 9F 84 C6 68 D2 78 40 38 2E 61 8D 39 F0 E4 99 87 30 B2 18 A5 6E 77 05 ED EA 99 9A 03 CB BB 7E 78 64 CC
C1 89 8D 7C 3B 9E BB 3E E5 4D DE 4C F8 86 7E
16 : 36 : 55 <====Rx METER-2 D4 81 9B 20 00 00 00 EE 11 37 04 13 48 94 9D 8A 1B 6E 2B 9C A8 30 04 5D FA 8C 3E 52 24 BE BB 90 D7 4A D5 C8 DE 2C 9F 97
CF 6C BC C2 0A B8 5F E6 3B 72 C3 BE C2 74 2B 71 FA 87 93 69 E5 C2 0C 39 82 6D CA F0 F5 6A A7 E2 42 6D 36 23 2B BD 17 B8
A6 62 51 B9 8C D9 2B 78 72 2A 9A E5 7D 92 D8 E5 D3 A6 82 75 C2 B4 04 62 55 E2 0D 56 D6 4A E9 A9 9F 84 C6 68 D2 78 40 38
2E 61 8D 39 F0 E4 99 87 30 B2 18 A5 6E 77 05 ED EA 99 9A 03 CB BB 7E 78 64 CC C1 89 8D 7C 3B 9E BB 3E E5 4D DE 4C
16 : 36 : 55 <====Rx METER-2 D4 81 9B 20 00 00 00 EE C4 01 81 00 01 08 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00
00 60 0B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 5E 5B 0E FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0C 07 00
FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0D 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12
00 00 02 04 12 00 01 09 06 00 00 5E 5B 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0F 00 FF 0F 02 12 00 00
16 : 36 : 55 ====>Tx METER-2 D0 12 20 00 00 00 EE C0 01 C1 00 07 00 00 63 62 00 FF 04 00
16 : 36 : 55 ====>Tx METER-2 D0 12 20 00 00 00 EE 0E E2 F4 CA 02 C0 5C 23 E3 72 3F 00 0F
16 : 36 : 55 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-0-255, IC = 7, ATTR: INDEX = 4
16 : 36 : 55 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 EE 0E E2 F4 CA 02 C0 5C 23 E3 72 3F 00 0F 9D 8D 7E
16 : 36 : 55 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 00 EF 34 B2 4A 04 27 AB 95 13 C2 9D C7 7E
16 : 36 : 55 <====Rx METER-2 D4 0E 20 00 00 00 EF 34 B2 4A 04 27 AB 95 13 C2
16 : 36 : 55 <====Rx METER-2 D4 0E 20 00 00 00 EF C4 01 81 00 06 00 00 00 00
16 : 36 : 55 ====>Tx METER-2 D0 12 20 00 00 00 EF C0 01 C1 00 07 00 00 63 62 00 FF 05 00
16 : 36 : 55 ====>Tx METER-2 D0 12 20 00 00 00 EF 3B 88 DC 43 96 86 F5 B4 81 D8 9D 26 81
16 : 36 : 55 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-0-255, IC = 7, ATTR: INDEX = 5
16 : 36 : 55 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 EF 3B 88 DC 43 96 86 F5 B4 81 D8 9D 26 81 91 28 7E
16 : 36 : 55 <====Rx METER-2 7E A0 1C 41 00 02 04 01 30 84 8E E6 E7 00 D4 0B 20 00 00 00 F0 63 0E 67 65 00 C9 03 A4 7E
16 : 36 : 55 <====Rx METER-2 D4 0B 20 00 00 00 F0 63 0E 67 65 00 C9
16 : 36 : 55 <====Rx METER-2 D4 0B 20 00 00 00 F0 C4 01 81 00 16 01
16 : 36 : 56 METER-2 SERVICE = GET RESPONSE
16 : 36 : 56 METER-2 COSEM OUT DATA
16 : 36 : 56 ====>Tx METER-2 D0 12 20 00 00 00 F0 C0 01 C1 00 07 00 00 63 62 00 FF 06 00
16 : 36 : 56 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 56 ====>Tx METER-2 D0 12 20 00 00 00 F0 3E 25 EA 80 3B BF CD 93 AD E1 42 0D B2
16 : 36 : 56 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-0-255, IC = 7, ATTR: INDEX = 6
16 : 36 : 56 METER-2 SENDING HDLC FRAME
16 : 36 : 56 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 F0 3E 25 EA 80 3B BF CD 93 AD E1 42 0D B2 83 D1 7E
16 : 36 : 56 METER-2 RECEIVED HDLC FRAME
16 : 36 : 56 <====Rx METER-2 7E A0 2C 41 00 02 04 01 52 DA 18 E6 E7 00 D4 1B 20 00 00 00 F1 01 C1 66 A9 11 0C 74 74 15 3E AB 24 69 63 48 28 BA 49 17
B7 4C DD C7 E2 7E
16 : 36 : 56 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 56 <====Rx METER-2 D4 1B 20 00 00 00 F1 01 C1 66 A9 11 0C 74 74 15 3E AB 24 69 63 48 28 BA 49 17 B7 4C DD
16 : 36 : 56 <====Rx METER-2 D4 1B 20 00 00 00 F1 C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 36 : 56 ====>Tx METER-2 D0 12 20 00 00 00 F1 C0 01 C1 00 07 00 00 63 62 00 FF 07 00
16 : 36 : 56 ====>Tx METER-2 D0 12 20 00 00 00 F1 B1 AA 02 58 08 8F 4D C7 83 6B A9 32 D8
16 : 36 : 56 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-0-255, IC = 7, ATTR: INDEX = 7
16 : 36 : 56 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 F1 B1 AA 02 58 08 8F 4D C7 83 6B A9 32 D8 B6 FF 7E
16 : 36 : 56 <====Rx METER-2 7E A0 1F 41 00 02 04 01 74 CA 22 E6 E7 00 D4 0E 20 00 00 00 F2 87 54 09 C0 81 3D 06 8B 16 E5 D2 7E
16 : 36 : 56 <====Rx METER-2 D4 0E 20 00 00 00 F2 87 54 09 C0 81 3D 06 8B 16
16 : 36 : 56 <====Rx METER-2 D4 0E 20 00 00 00 F2 C4 01 81 00 06 00 00 00 00
16 : 36 : 56 ====>Tx METER-2 D0 12 20 00 00 00 F2 C0 01 C1 00 07 00 00 63 62 00 FF 08 00
16 : 36 : 56 ====>Tx METER-2 D0 12 20 00 00 00 F2 E5 73 03 7B F8 8E FC C8 DA 82 4C 58 EF
16 : 36 : 56 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-0-255, IC = 7, ATTR: INDEX = 8
16 : 36 : 56 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 F2 E5 73 03 7B F8 8E FC C8 DA 82 4C 58 EF 76 60 7E
16 : 36 : 56 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 00 F3 2E 50 1E 9A 63 5E 2B 11 D2 7D EB 7E
16 : 36 : 56 <====Rx METER-2 D4 0E 20 00 00 00 F3 2E 50 1E 9A 63 5E 2B 11 D2
16 : 36 : 56 <====Rx METER-2 D4 0E 20 00 00 00 F3 C4 01 81 00 06 00 00 00 32
16 : 36 : 56 ====>Tx METER-2 D0 12 20 00 00 00 F3 C0 01 C1 00 07 00 00 63 62 01 FF 02 00
16 : 36 : 56 ====>Tx METER-2 D0 12 20 00 00 00 F3 57 1C 89 AC EF 9E 84 88 6F 8A D1 0D 83
16 : 36 : 56 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-1-255, IC = 7, ATTR: INDEX = 2
16 : 36 : 56 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 00 F3 57 1C 89 AC EF 9E 84 88 6F 8A D1 0D 83 5D C7 7E
16 : 36 : 56 <====Rx METER-2 7E A0 1C 41 00 02 04 01 B8 C4 86 E6 E7 00 D4 0B 20 00 00 00 F4 A6 B9 E8 F7 05 DA 2D 49 7E
16 : 36 : 56 <====Rx METER-2 D4 0B 20 00 00 00 F4 A6 B9 E8 F7 05 DA
16 : 36 : 56 <====Rx METER-2 D4 0B 20 00 00 00 F4 C4 01 81 00 01 00
16 : 36 : 56 ====>Tx METER-2 D0 12 20 00 00 00 F4 C0 01 C1 00 07 00 00 63 62 01 FF 03 00
16 : 36 : 56 ====>Tx METER-2 D0 12 20 00 00 00 F4 8C 64 06 7C 13 93 B3 8B 4F F0 66 53 2F
16 : 36 : 57 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-1-255, IC = 7, ATTR: INDEX = 3
16 : 36 : 57 METER-2 SENDING HDLC FRAME
16 : 36 : 57 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 F4 8C 64 06 7C 13 93 B3 8B 4F F0 66 53 2F 72 AC 7E
16 : 36 : 57 METER-2 RECEIVED HDLC FRAME
16 : 36 : 57 <====Rx METER-2 7E A0 AD 41 00 02 04 01 DA 52 09 E6 E7 00 D4 81 9B 20 00 00 00 F5 E2 48 05 3D 4C 99 0F 15 50 99 84 3C 96 7D 23 9C A1 94
E1 A4 95 1C EA 7B BA 9E 59 37 AA 5B C0 CF E7 D5 66 E4 32 59 1D 40 D5 3D C7 99 AF D9 53 E9 AB 5A 49 46 2A 8E F1 FD 1A D1
24 F3 77 3E 8C 55 83 C9 5D 38 99 42 D9 B1 FB 3A 82 67 6D AD 68 70 88 A2 44 92 26 27 E6 04 D4 33 7B 12 7D FE 24 C7 A9 9A
2E 38 6F 6D 1E 87 99 02 1B 2A 1F F0 D8 BC AE 59 A0 42 12 08 9A F9 F3 04 F2 7E AE 75 9D 6F 78 F2 B7 2C D5 98 00 DD D7 EC
74 2F 37 74 3B 05 52 10 CF 78 14 7F D1 78 7E
16 : 36 : 57 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 57 <====Rx METER-2 D4 81 9B 20 00 00 00 F5 E2 48 05 3D 4C 99 0F 15 50 99 84 3C 96 7D 23 9C A1 94 E1 A4 95 1C EA 7B BA 9E 59 37 AA 5B C0 CF
E7 D5 66 E4 32 59 1D 40 D5 3D C7 99 AF D9 53 E9 AB 5A 49 46 2A 8E F1 FD 1A D1 24 F3 77 3E 8C 55 83 C9 5D 38 99 42 D9 B1
FB 3A 82 67 6D AD 68 70 88 A2 44 92 26 27 E6 04 D4 33 7B 12 7D FE 24 C7 A9 9A 2E 38 6F 6D 1E 87 99 02 1B 2A 1F F0 D8 BC
AE 59 A0 42 12 08 9A F9 F3 04 F2 7E AE 75 9D 6F 78 F2 B7 2C D5 98 00 DD D7 EC 74 2F 37 74 3B 05 52 10 CF 78 14 7F
16 : 36 : 57 <====Rx METER-2 D4 81 9B 20 00 00 00 F5 C4 01 81 00 01 08 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00
00 60 0B 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 5E 5B 0E FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0C 07 00
00 00 02 04 12 00 01 09 06 00 00 5E 5B 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0F 01 FF 0F 02 12 00 00
16 : 36 : 57 METER-2 SERVICE = GET RESPONSE
16 : 36 : 57 METER-2 COSEM OUT DATA
16 : 36 : 57 ====>Tx METER-2 D0 12 20 00 00 00 F5 C0 01 C1 00 07 00 00 63 62 01 FF 04 00
16 : 36 : 57 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 57 ====>Tx METER-2 D0 12 20 00 00 00 F5 88 94 E6 6D 13 4A 46 22 8F 06 6A 6D E9
16 : 36 : 57 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-1-255, IC = 7, ATTR: INDEX = 4
16 : 36 : 57 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 F5 88 94 E6 6D 13 4A 46 22 8F 06 6A 6D E9 C3 86 7E
16 : 36 : 57 <====Rx METER-2 7E A0 1F 41 00 02 04 01 FC 8A 2A E6 E7 00 D4 0E 20 00 00 00 F6 84 2C 60 98 66 D9 FF 4C A7 E8 7B 7E
16 : 36 : 57 <====Rx METER-2 D4 0E 20 00 00 00 F6 84 2C 60 98 66 D9 FF 4C A7
16 : 36 : 57 <====Rx METER-2 D4 0E 20 00 00 00 F6 C4 01 81 00 06 00 00 00 00
16 : 36 : 57 ====>Tx METER-2 D0 12 20 00 00 00 F6 C0 01 C1 00 07 00 00 63 62 01 FF 05 00
16 : 36 : 57 ====>Tx METER-2 D0 12 20 00 00 00 F6 6A 5D 7F 33 AA 3D 1B 36 7F 46 90 87 28
16 : 36 : 57 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-1-255, IC = 7, ATTR: INDEX = 5
16 : 36 : 57 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 F6 6A 5D 7F 33 AA 3D 1B 36 7F 46 90 87 28 CF 31 7E
16 : 36 : 57 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 00 F7 C9 23 F2 4F B2 EE 88 7A 7E
16 : 36 : 57 <====Rx METER-2 D4 0B 20 00 00 00 F7 C9 23 F2 4F B2 EE
16 : 36 : 57 <====Rx METER-2 D4 0B 20 00 00 00 F7 C4 01 81 00 16 01
16 : 36 : 57 ====>Tx METER-2 D0 12 20 00 00 00 F7 C0 01 C1 00 07 00 00 63 62 01 FF 06 00
16 : 36 : 57 ====>Tx METER-2 D0 12 20 00 00 00 F7 F3 91 49 EA 27 9A 58 0C 2C 9A 31 20 69
16 : 36 : 57 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-1-255, IC = 7, ATTR: INDEX = 6
16 : 36 : 57 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 F7 F3 91 49 EA 27 9A 58 0C 2C 9A 31 20 69 FD 45 7E
16 : 36 : 57 <====Rx METER-2 7E A0 2C 41 00 02 04 01 30 CE 58 E6 E7 00 D4 1B 20 00 00 00 F8 FB D2 28 52 6E 5D 85 4A 98 79 B6 9F BC A1 B0 5B 23 79 CF
EB 88 10 8F 35 7E
16 : 36 : 57 <====Rx METER-2 D4 1B 20 00 00 00 F8 FB D2 28 52 6E 5D 85 4A 98 79 B6 9F BC A1 B0 5B 23 79 CF EB 88 10
16 : 36 : 57 <====Rx METER-2 D4 1B 20 00 00 00 F8 C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 36 : 57 ====>Tx METER-2 D0 12 20 00 00 00 F8 C0 01 C1 00 07 00 00 63 62 01 FF 07 00
16 : 36 : 57 ====>Tx METER-2 D0 12 20 00 00 00 F8 69 65 1C EB 15 48 CC 70 31 9F A9 A1 8C
16 : 36 : 57 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-1-255, IC = 7, ATTR: INDEX = 7
16 : 36 : 57 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 00 F8 69 65 1C EB 15 48 CC 70 31 9F A9 A1 8C 2F 30 7E
16 : 36 : 57 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 00 F9 B1 0E 48 C3 88 7D 8B 8C 47 A7 95 7E
16 : 36 : 58 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 58 <====Rx METER-2 D4 0E 20 00 00 00 F9 B1 0E 48 C3 88 7D 8B 8C 47
16 : 36 : 58 <====Rx METER-2 D4 0E 20 00 00 00 F9 C4 01 81 00 06 00 00 00 00
16 : 36 : 58 METER-2 SERVICE = GET RESPONSE
16 : 36 : 58 METER-2 COSEM OUT DATA
16 : 36 : 58 ====>Tx METER-2 D0 12 20 00 00 00 F9 C0 01 C1 00 07 00 00 63 62 01 FF 08 00
16 : 36 : 58 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 58 ====>Tx METER-2 D0 12 20 00 00 00 F9 8B 0A 6F 3A 8A F8 FE D8 72 06 ED 51 72
16 : 36 : 58 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-1-255, IC = 7, ATTR: INDEX = 8
16 : 36 : 58 METER-2 SENDING HDLC FRAME
16 : 36 : 58 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 00 F9 8B 0A 6F 3A 8A F8 FE D8 72 06 ED 51 72 2F 0B 7E
16 : 36 : 58 METER-2 RECEIVED HDLC FRAME
16 : 36 : 58 <====Rx METER-2 7E A0 1F 41 00 02 04 01 74 CA 22 E6 E7 00 D4 0E 20 00 00 00 FA CF D4 FF 6C 63 CC 24 45 1F 2B BA 7E
16 : 36 : 58 <====Rx METER-2 D4 0E 20 00 00 00 FA CF D4 FF 6C 63 CC 24 45 1F
16 : 36 : 58 <====Rx METER-2 D4 0E 20 00 00 00 FA C4 01 81 00 06 00 00 00 32
16 : 36 : 58 ====>Tx METER-2 D0 12 20 00 00 00 FA C0 01 C1 00 07 00 00 63 62 02 FF 02 00
16 : 36 : 58 ====>Tx METER-2 D0 12 20 00 00 00 FA 61 E9 8D 7E 6E E2 43 2F FE 8E EE 87 86
16 : 36 : 58 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-2-255, IC = 7, ATTR: INDEX = 2
16 : 36 : 58 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 00 FA 61 E9 8D 7E 6E E2 43 2F FE 8E EE 87 86 81 49 7E
16 : 36 : 58 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 00 FB 52 E5 34 93 21 2D A2 E3 D2 5F B2 34 10 58 CF 26 EF C4
8E BC B0 FB 51 A0 BA 59 47 EB B2 01 6A 75 2E 4C 3D 69 D3 71 43 9B E6 87 1C 1F AA 8E F3 C7 34 2B A4 87 6A 29 12 85 C4 78
A4 B9 B0 19 67 FC 80 D6 AB E1 F4 D7 1E DF B7 3B DD F9 FF 19 2A 9A 87 2D 32 08 A7 54 65 F0 C0 9E 91 58 F6 4B 42 AF 98 E1
6F D7 83 77 4D 32 42 E0 4D 3F 01 B0 D8 E5 D5 ED E2 7B FC B5 9A F8 B5 16 16 D3 0E FB 39 17 C3 FA 09 29 EC 96 5A B3 CE F2
74 60 A5 62 25 03 F5 0B B1 FA 9F 54 F8 94 5C 96 92 E4 EF 3E 75 2C 17 D9 14 4E E5 55 C6 C9 33 AC EF 65 B4 90 E9 EB 92 21
FB 90 C3 23 C5 BD F5 7F B4 8D E8 A2 7B C4 7E FE 22 0F 98 7F D5 2F 8D 11 C6 A0 7D B5 EA 07 8A BA CB B2 5A FE BB A9 1D BF
04 C0 34 B8 A1 F7 87 D4 52 7E
16 : 36 : 58 <====Rx METER-2 D4 81 E6 20 00 00 00 FB 52 E5 34 93 21 2D A2 E3 D2 5F B2 34 10 58 CF 26 EF C4 8E BC B0 FB 51 A0 BA 59 47 EB B2 01 6A 75
2E 4C 3D 69 D3 71 43 9B E6 87 1C 1F AA 8E F3 C7 34 2B A4 87 6A 29 12 85 C4 78 A4 B9 B0 19 67 FC 80 D6 AB E1 F4 D7 1E DF
B7 3B DD F9 FF 19 2A 9A 87 2D 32 08 A7 54 65 F0 C0 9E 91 58 F6 4B 42 AF 98 E1 6F D7 83 77 4D 32 42 E0 4D 3F 01 B0 D8 E5
D5 ED E2 7B FC B5 9A F8 B5 16 16 D3 0E FB 39 17 C3 FA 09 29 EC 96 5A B3 CE F2 74 60 A5 62 25 03 F5 0B B1 FA 9F 54 F8 94
5C 96 92 E4 EF 3E 75 2C 17 D9 14 4E E5 55 C6 C9 33 AC EF 65 B4 90 E9 EB 92 21 FB 90 C3 23 C5 BD F5 7F B4 8D E8 A2 7B C4
7E FE 22 0F 98 7F D5 2F 8D 11 C6 A0 7D B5 EA 07 8A BA CB B2 5A FE BB A9 1D BF 04 C0 34 B8 A1 F7 87
16 : 36 : 58 <====Rx METER-2 D4 81 E6 20 00 00 00 FB C4 02 81 00 00 00 00 01 00 81 D6 01 10 02 03 09 0C 07 E3 0B 0E FF 11 01 00 FF 01 4A 00 12 00 65
06 00 00 00 01 02 03 09 0C 07 E3 0B 0E FF 11 03 00 FF 01 4A 00 12 00 66 06 00 00 00 02 02 03 09 0C 07 E3 0B 0E FF 11 0E
00 FF 01 4A 00 12 00 65 06 00 00 00 03 02 03 09 0C 07 E3 0B 0E FF 11 10 00 FF 01 4A 00 12 00 66 06 00 00 00 04 02 03 09
0C 07 E3 0B 0E FF 11 32 00 FF 01 4A 00 12 00 65 06 00 00 00 05 02 03 09 0C 07 E3 0B 0F FF 09 17 00 FF 01 4A 00 12 00 66
06 00 00 00 06 02 03 09 0C 07 E3 0B 0F FF 0F 0D 00 FF 01 4A 00 12 00 65 06 00 00 00 07 02 03 09 0C 07 E3 0B 0F FF 0F 0F
00 FF 01 4A 00 12 00 66 06 00 00 00 08 02 03 09 0C 07 E3 0B 0F FF 12 0A 00 FF 01 4A 00 12 00 65 06
16 : 36 : 58 ====>Tx METER-2 D0 0C 20 00 00 00 FB C0 02 C1 00 00 00 01
16 : 36 : 58 ====>Tx METER-2 D0 0C 20 00 00 00 FB 15 37 31 56 CB 6E 6E
16 : 36 : 58 METER-2 SERVICE = GET BLOCK REQUEST
16 : 36 : 58 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 00 FB 15 37 31 56 CB 6E 6E 95 C7 7E
16 : 36 : 58 <====Rx METER-2 7E A0 CE 41 00 02 04 01 B8 AD 45 E6 E7 00 D4 81 BC 20 00 00 00 FC 17 1C 78 A7 F1 75 BA 88 4D 19 13 87 65 52 54 E9 21 19
FF DA 97 56 68 55 E5 66 1B 7F 72 98 DC FC 0D 0A 50 0B A0 27 70 77 3D 7D 5B FB 51 27 D2 E4 86 7B 6A B0 65 D1 2E 71 90 3E
16 AC 5D D2 0D 4A C8 51 0A 27 6F DE 53 84 05 47 4C 25 2B 6D 77 59 D4 73 4C FF 58 2D BF 79 B1 52 9D AB FD 2E 12 6F 50 44
02 19 0E 56 79 B2 C3 DD 2F 1A 3E 65 7D 72 E6 C1 00 03 FE 99 48 80 61 E4 E4 20 31 4B EE A1 AA B4 69 C7 CE 27 FF FB CF 00
21 4F 22 9D 71 0A C6 0E A5 DC 69 B4 C2 13 5A 3B 76 6D D0 6C 8D 51 E7 21 47 07 31 7B 30 67 46 54 BD 4D 4D 57 EB 49 A0 32
98 72 D2 2C 18 1B BE 7E
16 : 36 : 58 <====Rx METER-2 E6 E7 00 D4 81 BC 20 00 00 00 FC 17 1C 78 A7 F1 75 BA 88 4D 19 13 87 65 52 54 E9 21 19 FF DA 97 56 68 55 E5 66 1B 7F 72
98 DC FC 0D 0A 50 0B A0 27 70 77 3D 7D 5B FB 51 27 D2 E4 86 7B 6A B0 65 D1 2E 71 90 3E 16 AC 5D D2 0D 4A C8 51 0A 27 6F
DE 53 84 05 47 4C 25 2B 6D 77 59 D4 73 4C FF 58 2D BF 79 B1 52 9D AB FD 2E 12 6F 50 44 02 19 0E 56 79 B2 C3 DD 2F 1A 3E
65 7D 72 E6 C1 00 03 FE 99 48 80 61 E4 E4 20 31 4B EE A1 AA B4 69 C7 CE 27 FF FB CF 00 21 4F 22 9D 71 0A C6 0E A5 DC 69
B4 C2 13 5A 3B 76 6D D0 6C 8D 51 E7 21 47 07 31 7B 30 67 46 54 BD 4D 4D 57 EB 49 A0 32 98 72 D2 2C 18
16 : 36 : 58 <====Rx METER-2 01 10 02 03 09 0C 07 E3 0B 0E FF 11 01 00 FF 01 4A 00 12 00 65 06 00 00 00 01 02 03 09 0C 07 E3 0B 0E FF 11 03 00 FF 01
4A 00 12 00 66 06 00 00 00 02 02 03 09 0C 07 E3 0B 0E FF 11 0E 00 FF 01 4A 00 12 00 65 06 00 00 00 03 02 03 09 0C 07 E3
0B 0E FF 11 10 00 FF 01 4A 00 12 00 66 06 00 00 00 04 02 03 09 0C 07 E3 0B 0E FF 11 32 00 FF 01 4A 00 12 00 65 06 00 00
00 05 02 03 09 0C 07 E3 0B 0F FF 09 17 00 FF 01 4A 00 12 00 66 06 00 00 00 06 02 03 09 0C 07 E3 0B 0F FF 0F 0D 00 FF 01
4A 00 12 00 65 06 00 00 00 07 02 03 09 0C 07 E3 0B 0F FF 0F 0F 00 FF 01 4A 00 12 00 66 06 00 00 00 08 02 03 09 0C 07 E3
0B 0F FF 12 0A 00 FF 01 4A 00 12 00 65 06 00 00 00 09 02 03 09 0C 07 E3 0B 13 FF 0A 07 00 FF 01 4A 00 12 00 66 06 00 00
00 0A 02 03 09 0C 07 E3 0B 13 FF 0A 16 00 FF 01 4A 00 12 00 65 06 00 00 00 0B 02 03 09 0C 07 E3 0B 13 FF 0F 29 00 FF 01
4A 00 12 00 66 06 00 00 00 0C 02 03 09 0C 07 E3 0B 13 FF 10 2C 00 FF 01 4A 00 12 00 65 06 00 00 00 0D 02 03 09 0C 07 E3
0B 13 FF 11 28 00 FF 01 4A 00 12 00 66 06 00 00 00 0E 02 03 09 0C 07 E3 0B 13 FF 11 34 00 FF 01 4A 00 12 00 65 06 00 00
00 0F 02 03 09 0C 07 E3 0B 14 FF 10 17 00 FF 01 4A 00 12 00 66 06 00 00 00 10
16 : 36 : 58 ====>Tx METER-2 D0 12 20 00 00 00 FC C0 01 C1 00 07 00 00 63 62 02 FF 03 00
16 : 36 : 58 ====>Tx METER-2 D0 12 20 00 00 00 FC C0 06 7C BF 54 3E DB BD 3B D5 57 D2 9D
16 : 36 : 58 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-2-255, IC = 7, ATTR: INDEX = 3
16 : 36 : 58 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 00 FC C0 06 7C BF 54 3E DB BD 3B D5 57 D2 9D 44 C0 7E
16 : 36 : 58 <====Rx METER-2 7E A0 52 41 00 02 04 01 DA F7 87 E6 E7 00 D4 41 20 00 00 00 FD 10 73 F8 B4 3A 8B A1 85 F4 30 B0 CB FC 23 8A 14 0D B7 20
89 C0 8B 2A D7 C5 07 23 75 09 6A D7 F0 48 C8 7E 0D 0A 41 71 03 CA FF 1F F4 F8 4F 16 30 E7 C9 C1 E5 53 A1 B5 A6 B1 15 37
78 78 A4 7E
16 : 36 : 58 <====Rx METER-2 D4 41 20 00 00 00 FD 10 73 F8 B4 3A 8B A1 85 F4 30 B0 CB FC 23 8A 14 0D B7 20 89 C0 8B 2A D7 C5 07 23 75 09 6A D7 F0 48
C8 7E 0D 0A 41 71 03 CA FF 1F F4 F8 4F 16 30 E7 C9 C1 E5 53 A1 B5 A6 B1 15 37 78
16 : 36 : 58 <====Rx METER-2 D4 41 20 00 00 00 FD C4 01 81 00 01 03 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00
60 0B 02 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0F 02 FF 0F 02 12 00 00
16 : 36 : 59 METER-2 SERVICE = GET RESPONSE
16 : 36 : 59 METER-2 COSEM OUT DATA
16 : 36 : 59 ====>Tx METER-2 D0 12 20 00 00 00 FD C0 01 C1 00 07 00 00 63 62 02 FF 04 00
16 : 36 : 59 METER-2 COSEM OUT DATA - CIPHERED
16 : 36 : 59 ====>Tx METER-2 D0 12 20 00 00 00 FD 2E 3E 61 6E 0E 8E DB F5 1C B8 22 A1 52
16 : 36 : 59 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-2-255, IC = 7, ATTR: INDEX = 4
16 : 36 : 59 METER-2 SENDING HDLC FRAME
16 : 36 : 59 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 00 FD 2E 3E 61 6E 0E 8E DB F5 1C B8 22 A1 52 1C 86 7E
16 : 36 : 59 METER-2 RECEIVED HDLC FRAME
16 : 36 : 59 <====Rx METER-2 7E A0 1F 41 00 02 04 01 FC 8A 2A E6 E7 00 D4 0E 20 00 00 00 FE 87 B9 1D 72 F7 82 DB 0E 66 78 B5 7E
16 : 36 : 59 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 36 : 59 <====Rx METER-2 D4 0E 20 00 00 00 FE 87 B9 1D 72 F7 82 DB 0E 66
16 : 36 : 59 <====Rx METER-2 D4 0E 20 00 00 00 FE C4 01 81 00 06 00 00 00 00
16 : 36 : 59 ====>Tx METER-2 D0 12 20 00 00 00 FE C0 01 C1 00 07 00 00 63 62 02 FF 05 00
16 : 36 : 59 ====>Tx METER-2 D0 12 20 00 00 00 FE 14 3A 26 52 79 8C 42 0C 4E 1D BF B2 B9
16 : 36 : 59 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-2-255, IC = 7, ATTR: INDEX = 5
16 : 36 : 59 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 00 FE 14 3A 26 52 79 8C 42 0C 4E 1D BF B2 B9 7B A7 7E
16 : 36 : 59 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 00 FF 8A 37 97 70 A6 7D A1 5C 7E
16 : 36 : 59 <====Rx METER-2 D4 0B 20 00 00 00 FF 8A 37 97 70 A6 7D
16 : 36 : 59 <====Rx METER-2 D4 0B 20 00 00 00 FF C4 01 81 00 16 01
16 : 36 : 59 ====>Tx METER-2 D0 12 20 00 00 00 FF C0 01 C1 00 07 00 00 63 62 02 FF 06 00
16 : 36 : 59 ====>Tx METER-2 D0 12 20 00 00 00 FF 07 BD 49 8D D1 2B 1D 13 72 19 3F 63 AC
16 : 36 : 59 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-2-255, IC = 7, ATTR: INDEX = 6
16 : 36 : 59 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 00 FF 07 BD 49 8D D1 2B 1D 13 72 19 3F 63 AC 3A 7B 7E
16 : 36 : 59 <====Rx METER-2 7E A0 2C 41 00 02 04 01 30 CE 58 E6 E7 00 D4 1B 20 00 00 01 00 CF EC 1D A0 4D D2 1F D3 16 71 2B F1 A8 CB 67 C2 AB C9 DD
B2 49 8A DC DB 7E
16 : 36 : 59 <====Rx METER-2 D4 1B 20 00 00 01 00 CF EC 1D A0 4D D2 1F D3 16 71 2B F1 A8 CB 67 C2 AB C9 DD B2 49 8A
16 : 36 : 59 <====Rx METER-2 D4 1B 20 00 00 01 00 C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 36 : 59 ====>Tx METER-2 D0 12 20 00 00 01 00 C0 01 C1 00 07 00 00 63 62 02 FF 07 00
16 : 36 : 59 ====>Tx METER-2 D0 12 20 00 00 01 00 0D D4 52 0B C7 74 BF 07 2F 06 D1 F3 B4
16 : 36 : 59 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-2-255, IC = 7, ATTR: INDEX = 7
16 : 36 : 59 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 00 0D D4 52 0B C7 74 BF 07 2F 06 D1 F3 B4 E7 06 7E
16 : 36 : 59 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 01 01 9A 19 BD EB 79 E2 EA 9B 62 4E 47 7E
16 : 36 : 59 <====Rx METER-2 D4 0E 20 00 00 01 01 9A 19 BD EB 79 E2 EA 9B 62
16 : 36 : 59 <====Rx METER-2 D4 0E 20 00 00 01 01 C4 01 81 00 06 00 00 00 10
16 : 36 : 59 ====>Tx METER-2 D0 12 20 00 00 01 01 C0 01 C1 00 07 00 00 63 62 02 FF 08 00
16 : 36 : 59 ====>Tx METER-2 D0 12 20 00 00 01 01 73 11 D2 B9 B0 72 4D 0A 86 71 88 3F 2C
16 : 37 : 00 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-2-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 00 METER-2 SENDING HDLC FRAME
16 : 37 : 00 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 01 73 11 D2 B9 B0 72 4D 0A 86 71 88 3F 2C 37 F6 7E
16 : 37 : 00 METER-2 RECEIVED HDLC FRAME
16 : 37 : 00 <====Rx METER-2 7E A0 1F 41 00 02 04 01 74 CA 22 E6 E7 00 D4 0E 20 00 00 01 02 34 C4 4F 8A 6B 27 02 97 15 67 21 7E
16 : 37 : 00 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 00 <====Rx METER-2 D4 0E 20 00 00 01 02 34 C4 4F 8A 6B 27 02 97 15
16 : 37 : 00 <====Rx METER-2 D4 0E 20 00 00 01 02 C4 01 81 00 06 00 00 00 14
16 : 37 : 00 METER-2 SERVICE = GET RESPONSE
16 : 37 : 00 METER-2 COSEM OUT DATA
16 : 37 : 00 ====>Tx METER-2 D0 12 20 00 00 01 02 C0 01 C1 00 07 00 00 63 62 03 FF 02 00
16 : 37 : 00 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 00 ====>Tx METER-2 D0 12 20 00 00 01 02 39 2D DE 0A C7 34 0A 17 AF 71 43 68 D8
16 : 37 : 00 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-3-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 00 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 02 39 2D DE 0A C7 34 0A 17 AF 71 43 68 D8 9F 7E 7E
16 : 37 : 00 <====Rx METER-2 7E A0 1C 41 00 02 04 01 96 B8 4E E6 E7 00 D4 0B 20 00 00 01 03 F7 EA 69 11 79 CE 53 55 7E
16 : 37 : 00 <====Rx METER-2 D4 0B 20 00 00 01 03 F7 EA 69 11 79 CE
16 : 37 : 00 <====Rx METER-2 D4 0B 20 00 00 01 03 C4 01 81 00 01 00
16 : 37 : 00 ====>Tx METER-2 D0 12 20 00 00 01 03 C0 01 C1 00 07 00 00 63 62 03 FF 03 00
16 : 37 : 00 ====>Tx METER-2 D0 12 20 00 00 01 03 E7 D1 23 1D 19 4D 2D 8B D8 65 E2 19 A6
16 : 37 : 00 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-3-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 00 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 03 E7 D1 23 1D 19 4D 2D 8B D8 65 E2 19 A6 E4 28 7E
16 : 37 : 00 <====Rx METER-2 7E A0 52 41 00 02 04 01 B8 E3 C7 E6 E7 00 D4 41 20 00 00 01 04 85 1F 3D AB 55 B9 EA 14 05 D1 DC 60 70 48 5F CA 65 5E 31
D8 DA D8 7F 27 3E 5E FA 0D DA DD 03 7D 42 3B E8 D7 1F 74 0B 8C 53 E3 C1 40 4B 63 DD 72 F0 24 80 08 B2 24 82 72 4F 6B CD
A4 C5 B5 7E
16 : 37 : 00 <====Rx METER-2 D4 41 20 00 00 01 04 85 1F 3D AB 55 B9 EA 14 05 D1 DC 60 70 48 5F CA 65 5E 31 D8 DA D8 7F 27 3E 5E FA 0D DA DD 03 7D 42
3B E8 D7 1F 74 0B 8C 53 E3 C1 40 4B 63 DD 72 F0 24 80 08 B2 24 82 72 4F 6B CD A4
16 : 37 : 00 <====Rx METER-2 D4 41 20 00 00 01 04 C4 01 81 00 01 03 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00
60 0B 03 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0F 03 FF 0F 02 12 00 00
16 : 37 : 00 ====>Tx METER-2 D0 12 20 00 00 01 04 C0 01 C1 00 07 00 00 63 62 03 FF 04 00
16 : 37 : 00 ====>Tx METER-2 D0 12 20 00 00 01 04 8B E6 0C D8 1C 6D 3C 4C D1 E4 0F 72 97
16 : 37 : 00 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-3-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 00 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 04 8B E6 0C D8 1C 6D 3C 4C D1 E4 0F 72 97 80 5A 7E
16 : 37 : 00 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 01 05 A3 70 96 1A 38 49 D1 B4 00 6A 84 7E
16 : 37 : 00 <====Rx METER-2 D4 0E 20 00 00 01 05 A3 70 96 1A 38 49 D1 B4 00
16 : 37 : 00 <====Rx METER-2 D4 0E 20 00 00 01 05 C4 01 81 00 06 00 00 00 00
16 : 37 : 00 ====>Tx METER-2 D0 12 20 00 00 01 05 C0 01 C1 00 07 00 00 63 62 03 FF 05 00
16 : 37 : 00 ====>Tx METER-2 D0 12 20 00 00 01 05 32 A8 96 DC 7E 7F 3A 9E 21 3A B1 27 D8
16 : 37 : 00 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-3-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 00 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 05 32 A8 96 DC 7E 7F 3A 9E 21 3A B1 27 D8 E0 B0 7E
16 : 37 : 00 <====Rx METER-2 7E A0 1C 41 00 02 04 01 FC E4 82 E6 E7 00 D4 0B 20 00 00 01 06 C2 FB 85 D7 2D 74 18 98 7E
16 : 37 : 01 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 01 <====Rx METER-2 D4 0B 20 00 00 01 06 C2 FB 85 D7 2D 74
16 : 37 : 01 <====Rx METER-2 D4 0B 20 00 00 01 06 C4 01 81 00 16 01
16 : 37 : 01 METER-2 SERVICE = GET RESPONSE
16 : 37 : 01 METER-2 COSEM OUT DATA
16 : 37 : 01 ====>Tx METER-2 D0 12 20 00 00 01 06 C0 01 C1 00 07 00 00 63 62 03 FF 06 00
16 : 37 : 01 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 01 ====>Tx METER-2 D0 12 20 00 00 01 06 F3 6C B4 7F BD 1A 00 D7 3D 5C 51 B6 FD
16 : 37 : 01 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-3-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 01 METER-2 SENDING HDLC FRAME
16 : 37 : 01 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 06 F3 6C B4 7F BD 1A 00 D7 3D 5C 51 B6 FD 3D 9A 7E
16 : 37 : 01 METER-2 RECEIVED HDLC FRAME
16 : 37 : 01 <====Rx METER-2 7E A0 2C 41 00 02 04 01 1E B2 90 E6 E7 00 D4 1B 20 00 00 01 07 62 9F DE B0 87 6B 12 21 D8 6C 75 92 4D B9 54 06 0F 3E 8D
32 55 98 30 1D 7E
16 : 37 : 01 <====Rx METER-2 D4 1B 20 00 00 01 07 62 9F DE B0 87 6B 12 21 D8 6C 75 92 4D B9 54 06 0F 3E 8D 32 55 98
16 : 37 : 01 <====Rx METER-2 D4 1B 20 00 00 01 07 C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 01 ====>Tx METER-2 D0 12 20 00 00 01 07 C0 01 C1 00 07 00 00 63 62 03 FF 07 00
16 : 37 : 01 ====>Tx METER-2 D0 12 20 00 00 01 07 5C D2 EB 6C 20 83 7B 0A 79 3B 0E 43 6B
16 : 37 : 01 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-3-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 01 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 07 5C D2 EB 6C 20 83 7B 0A 79 3B 0E 43 6B 46 3C 7E
16 : 37 : 01 <====Rx METER-2 7E A0 1F 41 00 02 04 01 30 EA 26 E6 E7 00 D4 0E 20 00 00 01 08 D1 BC 7B CC 35 35 54 94 65 9F 53 7E
16 : 37 : 01 <====Rx METER-2 D4 0E 20 00 00 01 08 D1 BC 7B CC 35 35 54 94 65
16 : 37 : 01 <====Rx METER-2 D4 0E 20 00 00 01 08 C4 01 81 00 06 00 00 00 00
16 : 37 : 01 ====>Tx METER-2 D0 12 20 00 00 01 08 C0 01 C1 00 07 00 00 63 62 03 FF 08 00
16 : 37 : 01 ====>Tx METER-2 D0 12 20 00 00 01 08 83 5A DB A5 1B FD DF 84 20 E0 3A 04 30
16 : 37 : 01 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-3-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 01 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 08 83 5A DB A5 1B FD DF 84 20 E0 3A 04 30 AA 59 7E
16 : 37 : 01 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 01 09 CF 6F 13 8F 24 23 01 18 C9 EC 97 7E
16 : 37 : 01 <====Rx METER-2 D4 0E 20 00 00 01 09 CF 6F 13 8F 24 23 01 18 C9
16 : 37 : 01 <====Rx METER-2 D4 0E 20 00 00 01 09 C4 01 81 00 06 00 00 00 32
16 : 37 : 01 ====>Tx METER-2 D0 12 20 00 00 01 09 C0 01 C1 00 07 00 00 63 62 04 FF 02 00
16 : 37 : 01 ====>Tx METER-2 D0 12 20 00 00 01 09 E3 66 38 B2 B8 D3 AB 43 E1 43 52 97 8A
16 : 37 : 01 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-4-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 01 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 09 E3 66 38 B2 B8 D3 AB 43 E1 43 52 97 8A E7 BE 7E
16 : 37 : 01 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 01 0A 56 2E F4 1F A0 29 06 59 E3 6C 3E 9F 3D 60 2E 28 9E 39
36 DA FA E2 25 41 5A A8 53 F9 F5 BA 0C 5E 83 07 25 62 AB F9 12 DD 0A DA 4C CB 45 9B 27 CC 02 53 D8 75 60 9A 0E 5C 11 16
7A 91 67 68 BC 2E 6F AD CA C8 DC 56 F2 E2 0A 9B B8 FF 8A 5F B5 F4 7A 47 61 29 FC 34 4C B7 3B 0B D9 CC 65 D1 FA 40 4A 2A
33 DE C9 BE E0 17 69 26 B0 69 36 56 DE 4A EC 7C 56 72 E5 A1 34 7A C8 0A C0 4F 3A D8 62 59 A2 8C D9 C0 22 9F 63 C1 A5 73
EA 2A ED 36 4A C1 F0 F3 5F EA CA 48 94 ED AB 5F CC 03 77 3C D3 3D 6F 04 32 52 27 BB 13 43 B2 77 A4 98 A2 17 35 BF 1E 5D
A9 C2 87 B8 31 13 D5 B2 A4 F5 9E 94 43 F9 8A 6C 4D F6 57 72 7C 45 56 5B 23 65 EA EE 28 B5 41 D2 95 11 E4 74 56 00 57 00
E5 A1 29 E1 A2 35 B1 AD 73 7E
16 : 37 : 01 <====Rx METER-2 D4 81 E6 20 00 00 01 0A 56 2E F4 1F A0 29 06 59 E3 6C 3E 9F 3D 60 2E 28 9E 39 36 DA FA E2 25 41 5A A8 53 F9 F5 BA 0C 5E
83 07 25 62 AB F9 12 DD 0A DA 4C CB 45 9B 27 CC 02 53 D8 75 60 9A 0E 5C 11 16 7A 91 67 68 BC 2E 6F AD CA C8 DC 56 F2 E2
0A 9B B8 FF 8A 5F B5 F4 7A 47 61 29 FC 34 4C B7 3B 0B D9 CC 65 D1 FA 40 4A 2A 33 DE C9 BE E0 17 69 26 B0 69 36 56 DE 4A
EC 7C 56 72 E5 A1 34 7A C8 0A C0 4F 3A D8 62 59 A2 8C D9 C0 22 9F 63 C1 A5 73 EA 2A ED 36 4A C1 F0 F3 5F EA CA 48 94 ED
AB 5F CC 03 77 3C D3 3D 6F 04 32 52 27 BB 13 43 B2 77 A4 98 A2 17 35 BF 1E 5D A9 C2 87 B8 31 13 D5 B2 A4 F5 9E 94 43 F9
8A 6C 4D F6 57 72 7C 45 56 5B 23 65 EA EE 28 B5 41 D2 95 11 E4 74 56 00 57 00 E5 A1 29 E1 A2 35 B1
16 : 37 : 01 <====Rx METER-2 D4 81 E6 20 00 00 01 0A C4 02 81 00 00 00 00 01 00 81 D6 01 08 02 08 09 0C 07 E3 0B 0E 04 11 01 00 FF 01 4A 00 12 00 D1
17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 12 00 01 06 00 00 00 01 02 08 09 0C 07 E3 0B 0E 04 11 02 00
FF 01 4A 00 12 00 D2 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 12 00 01 06 00 00 00 02 02 08 09 0C 07
E3 0B 13 02 0F 28 00 FF 01 4A 00 12 00 D1 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 12 00 02 06 00 00
00 03 02 08 09 0C 07 E3 0B 13 02 0F 29 00 FF 01 4A 00 12 00 D2 17 00 00 00 00 17 43 6D 91 EC 17 00 00 00 00 17 00 00 00
00 12 00 02 06 00 00 00 04 02 08 09 0C 07 E3 0B 13 02 10 17 00 FF 01 4A 00 12 00 D1 17 00 00 00 00
16 : 37 : 02 METER-2 SERVICE = GET RESPONSE
16 : 37 : 02 METER-2 COSEM OUT DATA
16 : 37 : 02 ====>Tx METER-2 D0 0C 20 00 00 01 0A C0 02 C1 00 00 00 01
16 : 37 : 02 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 02 ====>Tx METER-2 D0 0C 20 00 00 01 0A C6 F4 56 60 83 65 8B
16 : 37 : 02 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 02 METER-2 SENDING HDLC FRAME
16 : 37 : 02 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 01 0A C6 F4 56 60 83 65 8B 46 1D 7E
16 : 37 : 02 METER-2 RECEIVED HDLC FRAME
16 : 37 : 02 <====Rx METER-2 7E A0 C6 41 00 02 04 01 96 3D 53 E6 E7 00 D4 81 B4 20 00 00 01 0B 8F C2 A3 CA 9D E0 E2 6B EA 10 85 D1 63 E9 9B 2C B4 BA
64 FC 79 1D F1 5A 5B B3 09 0E 66 A3 4C 1A 82 C9 32 11 CE 2C A8 41 E7 8D 98 00 C4 DC BC 59 0B A3 60 47 50 B8 2B AA 8B 31
3E 93 DC 2E 3D C2 D1 D2 6A EB 52 34 24 DD EF D9 03 AB 5B 70 06 32 CD 2C 8E 53 FA 77 CD FA 2F 8F 53 CE FA 4D 2C C0 D7 CB
17 AA CC 81 7F 90 B5 C5 41 48 3E B6 9D DD E6 B4 85 69 6D D7 12 CE 37 9E 7F 9A D5 37 CA C4 67 6F 69 79 61 D4 06 D6 81 2D
FA 53 4F 34 3E AF B3 A4 89 0D AA 53 6A 83 8D F3 A1 2D 08 C6 DE 50 3A 13 29 E9 8B 24 12 13 93 6A D3 F5 90 8F 10 1F 76 7E
16 : 37 : 02 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 02 <====Rx METER-2 E6 E7 00 D4 81 B4 20 00 00 01 0B 8F C2 A3 CA 9D E0 E2 6B EA 10 85 D1 63 E9 9B 2C B4 BA 64 FC 79 1D F1 5A 5B B3 09 0E 66
A3 4C 1A 82 C9 32 11 CE 2C A8 41 E7 8D 98 00 C4 DC BC 59 0B A3 60 47 50 B8 2B AA 8B 31 3E 93 DC 2E 3D C2 D1 D2 6A EB 52
34 24 DD EF D9 03 AB 5B 70 06 32 CD 2C 8E 53 FA 77 CD FA 2F 8F 53 CE FA 4D 2C C0 D7 CB 17 AA CC 81 7F 90 B5 C5 41 48 3E
B6 9D DD E6 B4 85 69 6D D7 12 CE 37 9E 7F 9A D5 37 CA C4 67 6F 69 79 61 D4 06 D6 81 2D FA 53 4F 34 3E AF B3 A4 89 0D AA
16 : 37 : 02 <====Rx METER-2 01 08 02 08 09 0C 07 E3 0B 0E 04 11 01 00 FF 01 4A 00 12 00 D1 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00
00 12 00 01 06 00 00 00 01 02 08 09 0C 07 E3 0B 0E 04 11 02 00 FF 01 4A 00 12 00 D2 17 00 00 00 00 17 00 00 00 00 17 00
00 00 00 17 00 00 00 00 12 00 01 06 00 00 00 02 02 08 09 0C 07 E3 0B 13 02 0F 28 00 FF 01 4A 00 12 00 D1 17 00 00 00 00
17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 12 00 02 06 00 00 00 03 02 08 09 0C 07 E3 0B 13 02 0F 29 00 FF 01 4A 00 12
00 D2 17 00 00 00 00 17 43 6D 91 EC 17 00 00 00 00 17 00 00 00 00 12 00 02 06 00 00 00 04 02 08 09 0C 07 E3 0B 13 02 10
17 00 FF 01 4A 00 12 00 D1 17 00 00 00 00 17 43 6D A1 48 17 00 00 00 00 17 00 00 00 00 12 00 03 06 00 00 00 05 02 08 09
0C 07 E3 0B 13 02 10 36 00 FF 01 4A 00 12 00 D2 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 12 00 03 06
00 00 00 06 02 08 09 0C 07 E3 0B 14 03 10 14 00 FF 01 4A 00 12 00 D1 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00
00 00 00 12 00 04 06 00 00 00 07 02 08 09 0C 07 E3 0B 14 03 10 14 00 FF 01 4A 00 12 00 D2 17 00 00 00 00 17 00 00 00 00
17 00 00 00 00 17 00 00 00 00 12 00 04 06 00 00 00 08
16 : 37 : 02 ====>Tx METER-2 D0 12 20 00 00 01 0B C0 01 C1 00 07 00 00 63 62 04 FF 03 00
16 : 37 : 02 ====>Tx METER-2 D0 12 20 00 00 01 0B FF F9 F1 75 2B 5B 4E A5 C2 B2 DF 68 2E
16 : 37 : 02 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-4-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 02 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 0B FF F9 F1 75 2B 5B 4E A5 C2 B2 DF 68 2E 76 2A 7E
16 : 37 : 02 <====Rx METER-2 7E A0 AD 41 00 02 04 01 B8 46 49 E6 E7 00 D4 81 9B 20 00 00 01 0C DE D6 C5 3E 9E C6 20 37 75 9B C9 DD CD 5E 6C F5 91 21
FA F7 90 B2 84 5F 03 38 3E 1A 6A 19 9C 0D 2B D9 81 0B 8E 51 C6 1D 78 9B 5E 93 4B 53 C8 D3 DB 22 62 6D C6 9B 4E FE 66 1F
E1 22 E9 3B 3D 3F 04 89 9C BE D6 FB 22 26 E8 C1 13 9D 3B 18 18 0B C6 00 04 8D 40 96 20 A7 AB 07 99 2B E4 FB 7E 34 52 E1
20 10 EF 6D 7E 2B 84 46 72 02 D3 BD 0A C9 A4 C5 1C 51 FE 95 0B 60 2B 25 DF CC 19 BF A5 65 1C 4B 30 BD 8B 19 3F 9D 4D C2
81 A2 94 EA 3B 20 64 89 EF F8 53 71 F7 2D 7E
16 : 37 : 02 <====Rx METER-2 D4 81 9B 20 00 00 01 0C DE D6 C5 3E 9E C6 20 37 75 9B C9 DD CD 5E 6C F5 91 21 FA F7 90 B2 84 5F 03 38 3E 1A 6A 19 9C 0D
2B D9 81 0B 8E 51 C6 1D 78 9B 5E 93 4B 53 C8 D3 DB 22 62 6D C6 9B 4E FE 66 1F E1 22 E9 3B 3D 3F 04 89 9C BE D6 FB 22 26
E8 C1 13 9D 3B 18 18 0B C6 00 04 8D 40 96 20 A7 AB 07 99 2B E4 FB 7E 34 52 E1 20 10 EF 6D 7E 2B 84 46 72 02 D3 BD 0A C9
A4 C5 1C 51 FE 95 0B 60 2B 25 DF CC 19 BF A5 65 1C 4B 30 BD 8B 19 3F 9D 4D C2 81 A2 94 EA 3B 20 64 89 EF F8 53 71
16 : 37 : 02 <====Rx METER-2 D4 81 9B 20 00 00 01 0C C4 01 81 00 01 08 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00
00 60 0B 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 5E 5B 0E FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0C 07 00
00 00 02 04 12 00 01 09 06 00 00 5E 5B 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0F 04 FF 0F 02 12 00 00
16 : 37 : 02 ====>Tx METER-2 D0 12 20 00 00 01 0C C0 01 C1 00 07 00 00 63 62 04 FF 04 00
16 : 37 : 02 ====>Tx METER-2 D0 12 20 00 00 01 0C E7 F4 E7 D7 F7 1B 79 34 84 31 64 DF 76
16 : 37 : 02 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-4-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 02 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 0C E7 F4 E7 D7 F7 1B 79 34 84 31 64 DF 76 7A 27 7E
16 : 37 : 02 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 01 0D 51 CA 7F B7 E1 4A FE 21 2C 4C C4 7E
16 : 37 : 02 <====Rx METER-2 D4 0E 20 00 00 01 0D 51 CA 7F B7 E1 4A FE 21 2C
16 : 37 : 02 <====Rx METER-2 D4 0E 20 00 00 01 0D C4 01 81 00 06 00 00 00 00
16 : 37 : 02 ====>Tx METER-2 D0 12 20 00 00 01 0D C0 01 C1 00 07 00 00 63 62 04 FF 05 00
16 : 37 : 02 ====>Tx METER-2 D0 12 20 00 00 01 0D 5A C8 15 A6 91 3B B6 E3 24 CA 8D 36 F6
16 : 37 : 02 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-4-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 02 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 0D 5A C8 15 A6 91 3B B6 E3 24 CA 8D 36 F6 0D 6B 7E
16 : 37 : 02 <====Rx METER-2 7E A0 1C 41 00 02 04 01 FC E4 82 E6 E7 00 D4 0B 20 00 00 01 0E 96 E9 B7 FE BB 62 6A 66 7E
16 : 37 : 02 <====Rx METER-2 D4 0B 20 00 00 01 0E 96 E9 B7 FE BB 62
16 : 37 : 02 <====Rx METER-2 D4 0B 20 00 00 01 0E C4 01 81 00 16 01
16 : 37 : 02 ====>Tx METER-2 D0 12 20 00 00 01 0E C0 01 C1 00 07 00 00 63 62 04 FF 06 00
16 : 37 : 02 ====>Tx METER-2 D0 12 20 00 00 01 0E D7 9C BB EF D9 22 F2 58 05 0D 2F 14 34
16 : 37 : 03 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-4-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 03 METER-2 SENDING HDLC FRAME
16 : 37 : 03 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 0E D7 9C BB EF D9 22 F2 58 05 0D 2F 14 34 3D 1B 7E
16 : 37 : 03 METER-2 RECEIVED HDLC FRAME
16 : 37 : 03 <====Rx METER-2 7E A0 2C 41 00 02 04 01 1E B2 90 E6 E7 00 D4 1B 20 00 00 01 0F 4E 03 D5 1D 7E 73 EA 6C 4D 14 13 F6 6E 35 31 68 45 D3 AF
6E 6E 36 66 50 7E
16 : 37 : 03 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 03 <====Rx METER-2 D4 1B 20 00 00 01 0F 4E 03 D5 1D 7E 73 EA 6C 4D 14 13 F6 6E 35 31 68 45 D3 AF 6E 6E 36
16 : 37 : 03 <====Rx METER-2 D4 1B 20 00 00 01 0F C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 03 METER-2 SERVICE = GET RESPONSE
16 : 37 : 03 METER-2 COSEM OUT DATA
16 : 37 : 03 ====>Tx METER-2 D0 12 20 00 00 01 0F C0 01 C1 00 07 00 00 63 62 04 FF 07 00
16 : 37 : 03 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 03 ====>Tx METER-2 D0 12 20 00 00 01 0F F7 41 41 40 69 07 2D F8 7F 7D 66 B1 C8
16 : 37 : 03 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-4-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 03 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 0F F7 41 41 40 69 07 2D F8 7F 7D 66 B1 C8 DB 3B 7E
16 : 37 : 03 <====Rx METER-2 7E A0 1F 41 00 02 04 01 30 EA 26 E6 E7 00 D4 0E 20 00 00 01 10 E9 92 08 69 D1 F8 55 16 E9 7D 29 7E
16 : 37 : 03 <====Rx METER-2 D4 0E 20 00 00 01 10 E9 92 08 69 D1 F8 55 16 E9
16 : 37 : 03 <====Rx METER-2 D4 0E 20 00 00 01 10 C4 01 81 00 06 00 00 00 08
16 : 37 : 03 ====>Tx METER-2 D0 12 20 00 00 01 10 C0 01 C1 00 07 00 00 63 62 04 FF 08 00
16 : 37 : 03 ====>Tx METER-2 D0 12 20 00 00 01 10 F2 02 0B F7 71 32 E4 7F 24 42 AC 52 18
16 : 37 : 03 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-4-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 03 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 10 F2 02 0B F7 71 32 E4 7F 24 42 AC 52 18 E9 30 7E
16 : 37 : 03 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 01 11 66 41 8F 08 42 64 82 7A FF EB 0A 7E
16 : 37 : 03 <====Rx METER-2 D4 0E 20 00 00 01 11 66 41 8F 08 42 64 82 7A FF
16 : 37 : 03 <====Rx METER-2 D4 0E 20 00 00 01 11 C4 01 81 00 06 00 00 00 32
16 : 37 : 03 ====>Tx METER-2 D0 12 20 00 00 01 11 C0 01 C1 00 07 00 00 63 62 05 FF 02 00
16 : 37 : 03 ====>Tx METER-2 D0 12 20 00 00 01 11 05 59 80 49 13 3E 84 06 74 7E 3E 7F F2
16 : 37 : 03 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-5-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 03 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 11 05 59 80 49 13 3E 84 06 74 7E 3E 7F F2 DE E2 7E
16 : 37 : 03 <====Rx METER-2 7E A0 1C 41 00 02 04 01 74 A4 8A E6 E7 00 D4 0B 20 00 00 01 12 53 EC 72 C2 01 A0 1A 03 7E
16 : 37 : 03 <====Rx METER-2 D4 0B 20 00 00 01 12 53 EC 72 C2 01 A0
16 : 37 : 03 <====Rx METER-2 D4 0B 20 00 00 01 12 C4 01 81 00 01 00
16 : 37 : 03 ====>Tx METER-2 D0 12 20 00 00 01 12 C0 01 C1 00 07 00 00 63 62 05 FF 03 00
16 : 37 : 03 ====>Tx METER-2 D0 12 20 00 00 01 12 A8 E9 BD 78 32 CC A4 CD 8D 19 AB CE 07
16 : 37 : 03 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-5-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 03 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 12 A8 E9 BD 78 32 CC A4 CD 8D 19 AB CE 07 E8 42 7E
16 : 37 : 03 <====Rx METER-2 7E A0 52 41 00 02 04 01 96 9F 0F E6 E7 00 D4 41 20 00 00 01 13 49 3F 99 06 15 8D 44 6B 00 4B 29 6B F1 21 1C 1D B9 B6 F3
7C 6D DB 03 C2 37 0D 6E 66 94 AA 1A 70 E3 95 1C 04 C7 95 03 49 3F 8D 70 09 5D AC 87 1A C4 50 15 29 32 2C 04 D7 4F D1 6A
E8 E0 22 7E
16 : 37 : 04 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 04 <====Rx METER-2 D4 41 20 00 00 01 13 49 3F 99 06 15 8D 44 6B 00 4B 29 6B F1 21 1C 1D B9 B6 F3 7C 6D DB 03 C2 37 0D 6E 66 94 AA 1A 70 E3
95 1C 04 C7 95 03 49 3F 8D 70 09 5D AC 87 1A C4 50 15 29 32 2C 04 D7 4F D1 6A E8
16 : 37 : 04 <====Rx METER-2 D4 41 20 00 00 01 13 C4 01 81 00 01 03 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00
60 0B 05 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0F 05 FF 0F 02 12 00 00
16 : 37 : 04 METER-2 SERVICE = GET RESPONSE
16 : 37 : 04 METER-2 COSEM OUT DATA
16 : 37 : 04 ====>Tx METER-2 D0 12 20 00 00 01 13 C0 01 C1 00 07 00 00 63 62 05 FF 04 00
16 : 37 : 04 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 04 ====>Tx METER-2 D0 12 20 00 00 01 13 36 66 BA 85 4E B3 64 BF 36 A3 54 DA 79
16 : 37 : 04 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-5-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 04 METER-2 SENDING HDLC FRAME
16 : 37 : 04 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 13 36 66 BA 85 4E B3 64 BF 36 A3 54 DA 79 9B 7F 7E
16 : 37 : 04 METER-2 RECEIVED HDLC FRAME
16 : 37 : 04 <====Rx METER-2 7E A0 1F 41 00 02 04 01 B8 AA 2E E6 E7 00 D4 0E 20 00 00 01 14 BA D8 25 EB 8D 9F 07 0A 5A E6 14 7E
16 : 37 : 04 <====Rx METER-2 D4 0E 20 00 00 01 14 BA D8 25 EB 8D 9F 07 0A 5A
16 : 37 : 04 <====Rx METER-2 D4 0E 20 00 00 01 14 C4 01 81 00 06 00 00 00 00
16 : 37 : 04 ====>Tx METER-2 D0 12 20 00 00 01 14 C0 01 C1 00 07 00 00 63 62 05 FF 05 00
16 : 37 : 04 ====>Tx METER-2 D0 12 20 00 00 01 14 C0 0E 2E 10 87 E2 75 C9 97 75 96 CB FD
16 : 37 : 04 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-5-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 04 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 14 C0 0E 2E 10 87 E2 75 C9 97 75 96 CB FD 2E 84 7E
16 : 37 : 04 <====Rx METER-2 7E A0 1C 41 00 02 04 01 DA D0 C6 E6 E7 00 D4 0B 20 00 00 01 15 50 B8 1D 55 1D B2 CE B1 7E
16 : 37 : 04 <====Rx METER-2 D4 0B 20 00 00 01 15 50 B8 1D 55 1D B2
16 : 37 : 04 <====Rx METER-2 D4 0B 20 00 00 01 15 C4 01 81 00 16 01
16 : 37 : 04 ====>Tx METER-2 D0 12 20 00 00 01 15 C0 01 C1 00 07 00 00 63 62 05 FF 06 00
16 : 37 : 04 ====>Tx METER-2 D0 12 20 00 00 01 15 EE 03 29 F0 35 FC 71 FE FD ED 83 B2 FF
16 : 37 : 04 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-5-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 04 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 15 EE 03 29 F0 35 FC 71 FE FD ED 83 B2 FF 9B DC 7E
16 : 37 : 04 <====Rx METER-2 7E A0 2C 41 00 02 04 01 FC AE 54 E6 E7 00 D4 1B 20 00 00 01 16 71 EB 29 83 C3 FC 70 19 CC 4E 4C D3 D7 CD 9D E0 1D CE D1
B2 86 45 38 5B 7E
16 : 37 : 04 <====Rx METER-2 D4 1B 20 00 00 01 16 71 EB 29 83 C3 FC 70 19 CC 4E 4C D3 D7 CD 9D E0 1D CE D1 B2 86 45
16 : 37 : 04 <====Rx METER-2 D4 1B 20 00 00 01 16 C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 04 ====>Tx METER-2 D0 12 20 00 00 01 16 C0 01 C1 00 07 00 00 63 62 05 FF 07 00
16 : 37 : 04 ====>Tx METER-2 D0 12 20 00 00 01 16 DB 6E 8B AF 4A CE 4B D6 0D 01 A4 02 EA
16 : 37 : 04 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-5-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 04 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 16 DB 6E 8B AF 4A CE 4B D6 0D 01 A4 02 EA D5 EB 7E
16 : 37 : 04 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 01 17 A7 54 35 BD 21 72 5A 82 A4 8B 0D 7E
16 : 37 : 04 <====Rx METER-2 D4 0E 20 00 00 01 17 A7 54 35 BD 21 72 5A 82 A4
16 : 37 : 04 <====Rx METER-2 D4 0E 20 00 00 01 17 C4 01 81 00 06 00 00 00 00
16 : 37 : 05 METER-2 COSEM OUT DATA
16 : 37 : 05 ====>Tx METER-2 D0 12 20 00 00 01 17 C0 01 C1 00 07 00 00 63 62 05 FF 08 00
16 : 37 : 05 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 05 ====>Tx METER-2 D0 12 20 00 00 01 17 66 4B 84 BD A6 7E E1 C1 1C E8 B3 C5 BE
16 : 37 : 05 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-5-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 05 METER-2 SENDING HDLC FRAME
16 : 37 : 05 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 17 66 4B 84 BD A6 7E E1 C1 1C E8 B3 C5 BE 41 36 7E
16 : 37 : 05 METER-2 RECEIVED HDLC FRAME
16 : 37 : 05 <====Rx METER-2 7E A0 1F 41 00 02 04 01 30 EA 26 E6 E7 00 D4 0E 20 00 00 01 18 24 E3 0E A1 96 20 74 21 1C 23 F6 7E
16 : 37 : 05 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 05 <====Rx METER-2 D4 0E 20 00 00 01 18 24 E3 0E A1 96 20 74 21 1C
16 : 37 : 05 <====Rx METER-2 D4 0E 20 00 00 01 18 C4 01 81 00 06 00 00 00 02
16 : 37 : 05 METER-2 SERVICE = GET RESPONSE
16 : 37 : 05 ====>Tx METER-2 D0 12 20 00 00 01 18 C0 01 C1 00 07 00 00 63 62 06 FF 02 00
16 : 37 : 05 ====>Tx METER-2 D0 12 20 00 00 01 18 AF A5 27 BB 6A 39 80 35 F1 02 83 58 F1
16 : 37 : 05 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-6-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 05 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 18 AF A5 27 BB 6A 39 80 35 F1 02 83 58 F1 A7 47 7E
16 : 37 : 05 <====Rx METER-2 7E A0 1C 41 00 02 04 01 52 90 CE E6 E7 00 D4 0B 20 00 00 01 19 F9 2E C5 7A A2 4A 55 36 7E
16 : 37 : 05 <====Rx METER-2 D4 0B 20 00 00 01 19 F9 2E C5 7A A2 4A
16 : 37 : 05 <====Rx METER-2 D4 0B 20 00 00 01 19 C4 01 81 00 01 00
16 : 37 : 05 ====>Tx METER-2 D0 12 20 00 00 01 19 C0 01 C1 00 07 00 00 63 62 06 FF 03 00
16 : 37 : 05 ====>Tx METER-2 D0 12 20 00 00 01 19 BE 18 E9 95 30 53 08 77 84 EC FB 1B F2
16 : 37 : 05 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-6-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 05 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 19 BE 18 E9 95 30 53 08 77 84 EC FB 1B F2 59 2C 7E
16 : 37 : 05 <====Rx METER-2 7E A0 52 41 00 02 04 01 74 83 CB E6 E7 00 D4 41 20 00 00 01 1A 07 1A 16 12 D8 D6 7D ED 39 E4 A0 1A B8 45 6C A5 44 7B DB
D7 9B B2 CC 5A C5 58 A3 49 2A 27 F2 B6 B4 E0 29 6D 8C 3E 30 DA 41 FE A4 F2 FE B7 AF B2 EB D4 97 17 25 5F 0E 0C 2B 5E 9A
E4 17 BD 7E
16 : 37 : 05 <====Rx METER-2 D4 41 20 00 00 01 1A 07 1A 16 12 D8 D6 7D ED 39 E4 A0 1A B8 45 6C A5 44 7B DB D7 9B B2 CC 5A C5 58 A3 49 2A 27 F2 B6 B4
E0 29 6D 8C 3E 30 DA 41 FE A4 F2 FE B7 AF B2 EB D4 97 17 25 5F 0E 0C 2B 5E 9A E4
16 : 37 : 05 <====Rx METER-2 D4 41 20 00 00 01 1A C4 01 81 00 01 03 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00
60 0B 06 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0F 06 FF 0F 02 12 00 00
16 : 37 : 05 ====>Tx METER-2 D0 12 20 00 00 01 1A C0 01 C1 00 07 00 00 63 62 06 FF 04 00
16 : 37 : 05 ====>Tx METER-2 D0 12 20 00 00 01 1A 38 C0 8E 11 43 77 4C 52 0A F6 D6 8C 79
16 : 37 : 05 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-6-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 05 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 1A 38 C0 8E 11 43 77 4C 52 0A F6 D6 8C 79 E4 C8 7E
16 : 37 : 05 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 01 1B 4A AF DF 47 5E 65 C1 8B C9 5F EE 7E
16 : 37 : 05 <====Rx METER-2 D4 0E 20 00 00 01 1B 4A AF DF 47 5E 65 C1 8B C9
16 : 37 : 05 <====Rx METER-2 D4 0E 20 00 00 01 1B C4 01 81 00 06 00 00 00 00
16 : 37 : 05 ====>Tx METER-2 D0 12 20 00 00 01 1B C0 01 C1 00 07 00 00 63 62 06 FF 05 00
16 : 37 : 05 ====>Tx METER-2 D0 12 20 00 00 01 1B 62 27 67 B7 C1 E8 DE F8 DC 23 1B EE 7A
16 : 37 : 05 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-6-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 06 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 1B 62 27 67 B7 C1 E8 DE F8 DC 23 1B EE 7A B6 5B 7E
16 : 37 : 06 METER-2 RECEIVED HDLC FRAME
16 : 37 : 06 <====Rx METER-2 7E A0 1C 41 00 02 04 01 B8 C4 86 E6 E7 00 D4 0B 20 00 00 01 1C 74 81 16 55 E1 EC C8 4E 7E
16 : 37 : 06 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 06 <====Rx METER-2 D4 0B 20 00 00 01 1C 74 81 16 55 E1 EC
16 : 37 : 06 <====Rx METER-2 D4 0B 20 00 00 01 1C C4 01 81 00 16 01
16 : 37 : 06 METER-2 SERVICE = GET RESPONSE
16 : 37 : 06 METER-2 COSEM OUT DATA
16 : 37 : 06 ====>Tx METER-2 D0 12 20 00 00 01 1C C0 01 C1 00 07 00 00 63 62 06 FF 06 00
16 : 37 : 06 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 06 ====>Tx METER-2 D0 12 20 00 00 01 1C 1D 36 92 8D 63 CC 4C AF 07 4B 1B 75 DE
16 : 37 : 06 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-6-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 06 METER-2 SENDING HDLC FRAME
16 : 37 : 06 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 1C 1D 36 92 8D 63 CC 4C AF 07 4B 1B 75 DE FA 00 7E
16 : 37 : 06 <====Rx METER-2 7E A0 2C 41 00 02 04 01 DA 9A 10 E6 E7 00 D4 1B 20 00 00 01 1D 03 D6 97 5E 82 22 8A 32 07 50 F2 6D 3E C0 C6 1C 65 D0 07
16 30 B5 02 88 7E
16 : 37 : 06 <====Rx METER-2 D4 1B 20 00 00 01 1D 03 D6 97 5E 82 22 8A 32 07 50 F2 6D 3E C0 C6 1C 65 D0 07 16 30 B5
16 : 37 : 06 <====Rx METER-2 D4 1B 20 00 00 01 1D C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 06 ====>Tx METER-2 D0 12 20 00 00 01 1D C0 01 C1 00 07 00 00 63 62 06 FF 07 00
16 : 37 : 06 ====>Tx METER-2 D0 12 20 00 00 01 1D 5B 78 26 AD 36 96 55 3F 8B 4D 1A 66 8C
16 : 37 : 06 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-6-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 06 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 1D 5B 78 26 AD 36 96 55 3F 8B 4D 1A 66 8C C0 4B 7E
16 : 37 : 06 <====Rx METER-2 7E A0 1F 41 00 02 04 01 FC 8A 2A E6 E7 00 D4 0E 20 00 00 01 1E 75 26 25 C8 37 7D E0 93 7E 81 D8 7E
16 : 37 : 06 <====Rx METER-2 D4 0E 20 00 00 01 1E 75 26 25 C8 37 7D E0 93 7E
16 : 37 : 06 <====Rx METER-2 D4 0E 20 00 00 01 1E C4 01 81 00 06 00 00 00 00
16 : 37 : 06 ====>Tx METER-2 D0 12 20 00 00 01 1E C0 01 C1 00 07 00 00 63 62 06 FF 08 00
16 : 37 : 06 ====>Tx METER-2 D0 12 20 00 00 01 1E 71 49 41 BC ED 17 2A 36 AC 91 C8 AD 93
16 : 37 : 06 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-99-98-6-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 06 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 1E 71 49 41 BC ED 17 2A 36 AC 91 C8 AD 93 F4 41 7E
16 : 37 : 06 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 01 1F AC 2B 7E F3 A0 B8 1B 12 BE 19 E2 7E
16 : 37 : 06 <====Rx METER-2 D4 0E 20 00 00 01 1F AC 2B 7E F3 A0 B8 1B 12 BE
16 : 37 : 06 <====Rx METER-2 D4 0E 20 00 00 01 1F C4 01 81 00 06 00 00 00 14
16 : 37 : 06 ====>Tx METER-2 D0 12 20 00 00 01 1F C0 01 C1 00 07 01 00 5E 5B 00 FF 02 00
16 : 37 : 06 ====>Tx METER-2 D0 12 20 00 00 01 1F 95 D7 2D 84 7C A5 63 89 46 BE 2B 4C 7C
16 : 37 : 06 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-0-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 06 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 1F 95 D7 2D 84 7C A5 63 89 46 BE 2B 4C 7C 98 24 7E
16 : 37 : 06 <====Rx METER-2 7E A0 A1 41 00 02 04 01 30 9C F0 E6 E7 00 D4 81 8F 20 00 00 01 20 DC DC 2E 75 A3 E3 AC 40 3F B1 A0 20 E8 06 CE B8 5B F9
38 76 AE 98 85 5E FD 14 98 E6 C6 F3 A1 19 87 35 E7 A8 23 63 0B D3 FE 9D B1 4A A2 12 BA 3B D6 94 7C 72 9D BF CD EB 31 97
6C A2 50 01 3E 8E 82 69 9C D0 35 F0 D9 53 04 2F 85 CF C6 66 74 C8 EE CB D8 38 9C B6 F5 AA A9 CE 91 04 A0 B4 FC 73 2F BA
F3 12 AB 09 3B 9F 96 49 A9 44 23 85 83 A5 A4 E5 50 0B 18 5D 35 C2 CF 4B 6C 8E 90 62 37 41 2C 17 2A 44 BF 96 EB 3C 1F C5
40 FA 7E
16 : 37 : 06 <====Rx METER-2 D4 81 8F 20 00 00 01 20 DC DC 2E 75 A3 E3 AC 40 3F B1 A0 20 E8 06 CE B8 5B F9 38 76 AE 98 85 5E FD 14 98 E6 C6 F3 A1 19
87 35 E7 A8 23 63 0B D3 FE 9D B1 4A A2 12 BA 3B D6 94 7C 72 9D BF CD EB 31 97 6C A2 50 01 3E 8E 82 69 9C D0 35 F0 D9 53
04 2F 85 CF C6 66 74 C8 EE CB D8 38 9C B6 F5 AA A9 CE 91 04 A0 B4 FC 73 2F BA F3 12 AB 09 3B 9F 96 49 A9 44 23 85 83 A5
16 : 37 : 07 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 37 : 07 <====Rx METER-2 D4 81 8F 20 00 00 01 20 C4 01 81 00 01 01 02 16 09 0C 07 E3 0B 14 03 10 24 34 FF 01 4A 00 17 43 6D 94 7B 17 00 00 00 00
17 00 00 00 00 17 00 00 00 00 17 42 47 E1 48 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00
09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 17 00 00 00 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 17 44 28 C0 00 12 00
04 06 00 00 00 00 12 00 00 17 00 00 00 00 17 00 00 00 00 03 01 06 00 00 43 80
16 : 37 : 07 METER-2 SERVICE = GET RESPONSE
16 : 37 : 07 METER-2 COSEM OUT DATA
16 : 37 : 07 ====>Tx METER-2 D0 12 20 00 00 01 20 C0 01 C1 00 07 01 00 5E 5B 00 FF 03 00
16 : 37 : 07 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 07 ====>Tx METER-2 D0 12 20 00 00 01 20 32 B2 08 3B 5C B9 8C 7E B1 76 73 31 95
16 : 37 : 07 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-0-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 07 METER-2 SENDING HDLC FRAME
16 : 37 : 07 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 20 32 B2 08 3B 5C B9 8C 7E B1 76 73 31 95 31 B9 7E
16 : 37 : 07 METER-2 RECEIVED HDLC FRAME
16 : 37 : 07 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 01 21 81 3F 48 9F C0 D3 EB A6 29 39 80 77 B2 07 D1 DA 0E 2B
7A 3E 0D BD 14 CC 1A 07 D4 F3 92 3E 61 70 56 EE EE 82 C8 A0 B9 72 A9 E3 D4 1A DF AF 27 75 BC 47 EA 06 76 0E 00 8C 51 88
ED AB 7B 99 9A D7 8E FF 40 7F 9E C4 77 26 9C 0E 6E BD 1E 82 84 FF 86 2F 5A B3 AC C7 1C F6 EB EA A1 BA FD 09 A7 AE 1C 6D
D9 0D AA 55 13 E8 F5 C9 C4 3B B5 DA 24 5D 1D F7 B3 70 38 38 44 30 93 6D 32 C9 5C 2C E1 D1 9A A1 D2 45 C2 47 BA 79 36 99
13 FD 23 78 F0 7A A0 BC F6 49 63 56 2A 3E 08 B9 27 9E 3D 45 0C 0D 82 52 0C 9D 5B F7 23 47 A5 9E E8 2F D6 92 60 30 6F A2
9B 03 5D C3 6B EA 94 2B 41 2A 52 01 C5 02 A4 30 D0 D2 57 9B 07 CA 66 C5 FA 11 E9 88 0C FD 95 95 E8 C8 F3 B8 88 2E 2D C7
96 F0 25 9B B8 BD 5A 3A 23 7E
16 : 37 : 07 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 07 <====Rx METER-2 D4 81 E6 20 00 00 01 21 81 3F 48 9F C0 D3 EB A6 29 39 80 77 B2 07 D1 DA 0E 2B 7A 3E 0D BD 14 CC 1A 07 D4 F3 92 3E 61 70
56 EE EE 82 C8 A0 B9 72 A9 E3 D4 1A DF AF 27 75 BC 47 EA 06 76 0E 00 8C 51 88 ED AB 7B 99 9A D7 8E FF 40 7F 9E C4 77 26
9C 0E 6E BD 1E 82 84 FF 86 2F 5A B3 AC C7 1C F6 EB EA A1 BA FD 09 A7 AE 1C 6D D9 0D AA 55 13 E8 F5 C9 C4 3B B5 DA 24 5D
1D F7 B3 70 38 38 44 30 93 6D 32 C9 5C 2C E1 D1 9A A1 D2 45 C2 47 BA 79 36 99 13 FD 23 78 F0 7A A0 BC F6 49 63 56 2A 3E
08 B9 27 9E 3D 45 0C 0D 82 52 0C 9D 5B F7 23 47 A5 9E E8 2F D6 92 60 30 6F A2 9B 03 5D C3 6B EA 94 2B 41 2A 52 01 C5 02
A4 30 D0 D2 57 9B 07 CA 66 C5 FA 11 E9 88 0C FD 95 95 E8 C8 F3 B8 88 2E 2D C7 96 F0 25 9B B8 BD 5A
16 : 37 : 07 <====Rx METER-2 D4 81 E6 20 00 00 01 21 C4 02 81 00 00 00 00 01 00 81 D6 01 16 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02
04 12 00 03 09 06 01 00 0C 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0B 07 00 FF 0F 02 12 00 00 02 04 12 00 03
09 06 01 00 5B 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0D 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00
0E 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 07 00 FF
0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 02 12 00
00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F
16 : 37 : 07 ====>Tx METER-2 D0 0C 20 00 00 01 21 C0 02 C1 00 00 00 01
16 : 37 : 07 ====>Tx METER-2 D0 0C 20 00 00 01 21 7D A2 E0 D6 79 35 3D
16 : 37 : 07 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 07 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 01 21 7D A2 E0 D6 79 35 3D 8A C1 7E
16 : 37 : 07 <====Rx METER-2 7E A0 DA 41 00 02 04 01 74 72 93 E6 E7 00 D4 81 C8 20 00 00 01 22 33 FE B5 B2 91 F9 9C 24 36 30 68 14 EB 11 FA F6 18 04
03 7B D3 04 3F 05 71 02 53 A3 28 68 15 AE 48 14 1D 02 79 18 6B 51 68 F8 51 55 FF 69 E6 E7 BF 6F C7 E6 F8 72 6A E5 74 7D
35 14 EC 0F 01 AE 46 00 C2 85 A3 F0 3E 60 CE E0 73 04 C0 98 98 CB 58 FE D2 52 52 70 7C F3 00 22 BA 72 9D 4B EE 95 46 59
75 88 2F 98 A9 BF 46 55 A1 E2 79 24 D8 8E A4 84 08 39 9F 64 92 89 21 70 A3 89 3E 9E 8D 68 05 3C 92 82 5B C9 D3 EC 2D 09
2C 98 D1 5B 3A 2A 9B 6E E4 D0 4A 0D 65 E1 25 F9 43 4F 29 2D DF 4F 06 F8 3C 66 74 5B DC 44 BF 72 46 81 8F C6 D9 77 B7 71
91 33 2C AC 09 8A 4D D3 D4 2C FC EF D0 C1 06 06 AD 2A 99 7E
16 : 37 : 07 <====Rx METER-2 E6 E7 00 D4 81 C8 20 00 00 01 22 33 FE B5 B2 91 F9 9C 24 36 30 68 14 EB 11 FA F6 18 04 03 7B D3 04 3F 05 71 02 53 A3 28
68 15 AE 48 14 1D 02 79 18 6B 51 68 F8 51 55 FF 69 E6 E7 BF 6F C7 E6 F8 72 6A E5 74 7D 35 14 EC 0F 01 AE 46 00 C2 85 A3
F0 3E 60 CE E0 73 04 C0 98 98 CB 58 FE D2 52 52 70 7C F3 00 22 BA 72 9D 4B EE 95 46 59 75 88 2F 98 A9 BF 46 55 A1 E2 79
24 D8 8E A4 84 08 39 9F 64 92 89 21 70 A3 89 3E 9E 8D 68 05 3C 92 82 5B C9 D3 EC 2D 09 2C 98 D1 5B 3A 2A 9B 6E E4 D0 4A
0D 65 E1 25 F9 43 4F 29 2D DF 4F 06 F8 3C 66 74 5B DC 44 BF 72 46 81 8F C6 D9 77 B7 71 91 33 2C AC 09 8A 4D D3 D4 2C FC
EF D0 C1 06 06 AD
16 : 37 : 07 <====Rx METER-2 01 16 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0C 07 00 FF 0F 02 12 00 00 02 04
12 00 03 09 06 01 00 0B 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 5B 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09
06 01 00 0D 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0E 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09
07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F
02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 02 12 00 00
02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 05 12 00 00 02 04 12 00 04 09 06 01 00 09 06 00 FF 0F 02 12 00 00 02 04 12 00
04 09 06 01 00 09 06 00 FF 0F 05 12 00 00 02 04 12 00 03 09 06 00 00 5E 5B 0E FF 0F 02 12 00 00 02 04 12 00 01 09 06 00
00 5E 5B 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 00 01 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 02 00
FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0A 08 00 FF 0F 02 12
00 00 02 04 12 00 46 09 06 00 00 60 03 0A FF 0F 02 12 00 00 02 04 12 00 47 09 06 00 00 11 00 00 FF 0F 03 12 00 00
16 : 37 : 07 ====>Tx METER-2 D0 12 20 00 00 01 22 C0 01 C1 00 07 01 00 5E 5B 00 FF 04 00
16 : 37 : 07 ====>Tx METER-2 D0 12 20 00 00 01 22 43 5C C8 B7 C7 2B 93 5D BB 09 4B 05 61
16 : 37 : 07 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-0-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 07 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 22 43 5C C8 B7 C7 2B 93 5D BB 09 4B 05 61 4F 9E 7E
16 : 37 : 07 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 01 23 67 00 FE 4A 11 48 7E BB D2 24 71 7E
16 : 37 : 07 <====Rx METER-2 D4 0E 20 00 00 01 23 67 00 FE 4A 11 48 7E BB D2
16 : 37 : 07 <====Rx METER-2 D4 0E 20 00 00 01 23 C4 01 81 00 06 00 00 00 00
16 : 37 : 07 ====>Tx METER-2 D0 12 20 00 00 01 23 C0 01 C1 00 07 01 00 5E 5B 00 FF 05 00
16 : 37 : 07 ====>Tx METER-2 D0 12 20 00 00 01 23 59 F8 86 C5 70 BB DC 8E 71 23 60 CB 27
16 : 37 : 07 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-0-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 07 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 23 59 F8 86 C5 70 BB DC 8E 71 23 60 CB 27 32 C4 7E
16 : 37 : 07 <====Rx METER-2 7E A0 1C 41 00 02 04 01 B8 C4 86 E6 E7 00 D4 0B 20 00 00 01 24 74 91 A1 E1 86 B8 4C 11 7E
16 : 37 : 07 <====Rx METER-2 D4 0B 20 00 00 01 24 74 91 A1 E1 86 B8
16 : 37 : 07 <====Rx METER-2 D4 0B 20 00 00 01 24 C4 01 81 00 16 01
16 : 37 : 08 ====>Tx METER-2 D0 12 20 00 00 01 24 C0 01 C1 00 07 01 00 5E 5B 00 FF 06 00
16 : 37 : 08 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 08 ====>Tx METER-2 D0 12 20 00 00 01 24 56 3C BD AE 6A 20 99 6C E8 E1 03 AA 41
16 : 37 : 08 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-0-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 08 METER-2 SENDING HDLC FRAME
16 : 37 : 08 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 24 56 3C BD AE 6A 20 99 6C E8 E1 03 AA 41 E8 20 7E
16 : 37 : 08 METER-2 RECEIVED HDLC FRAME
16 : 37 : 08 <====Rx METER-2 7E A0 2C 41 00 02 04 01 DA 9A 10 E6 E7 00 D4 1B 20 00 00 01 25 2B 47 40 A6 8E 23 96 4C 1B 03 B2 92 E0 9C BA 19 1D C3 C6
42 25 E6 54 C9 7E
16 : 37 : 08 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 08 <====Rx METER-2 D4 1B 20 00 00 01 25 2B 47 40 A6 8E 23 96 4C 1B 03 B2 92 E0 9C BA 19 1D C3 C6 42 25 E6
16 : 37 : 08 <====Rx METER-2 D4 1B 20 00 00 01 25 C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 08 METER-2 SERVICE = GET RESPONSE
16 : 37 : 08 ====>Tx METER-2 D0 12 20 00 00 01 25 C0 01 C1 00 07 01 00 5E 5B 00 FF 07 00
16 : 37 : 08 ====>Tx METER-2 D0 12 20 00 00 01 25 B7 FC 33 1A 48 78 13 68 59 85 54 50 CE
16 : 37 : 08 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-0-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 08 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 25 B7 FC 33 1A 48 78 13 68 59 85 54 50 CE AE 49 7E
16 : 37 : 08 <====Rx METER-2 7E A0 1F 41 00 02 04 01 FC 8A 2A E6 E7 00 D4 0E 20 00 00 01 26 1E 19 13 BB 99 ED A0 A9 50 72 8C 7E
16 : 37 : 08 <====Rx METER-2 D4 0E 20 00 00 01 26 1E 19 13 BB 99 ED A0 A9 50
16 : 37 : 08 <====Rx METER-2 D4 0E 20 00 00 01 26 C4 01 81 00 06 00 00 00 01
16 : 37 : 08 ====>Tx METER-2 D0 12 20 00 00 01 26 C0 01 C1 00 07 01 00 5E 5B 00 FF 08 00
16 : 37 : 08 ====>Tx METER-2 D0 12 20 00 00 01 26 34 54 ED 1B 70 EB 66 6E 67 E6 77 2F D3
16 : 37 : 08 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-0-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 08 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 26 34 54 ED 1B 70 EB 66 6E 67 E6 77 2F D3 B7 0F 7E
16 : 37 : 08 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 01 27 6B A2 C5 5D 94 CF C7 CC 0E 7C 68 7E
16 : 37 : 08 <====Rx METER-2 D4 0E 20 00 00 01 27 6B A2 C5 5D 94 CF C7 CC 0E
16 : 37 : 08 <====Rx METER-2 D4 0E 20 00 00 01 27 C4 01 81 00 06 00 00 00 01
16 : 37 : 08 ====>Tx METER-2 D0 12 20 00 00 01 27 C0 01 C1 00 07 01 00 5E 5B 03 FF 02 00
16 : 37 : 08 ====>Tx METER-2 D0 12 20 00 00 01 27 8C 96 9B 9F 4D 6F E8 A3 CF 23 B7 3C BE
16 : 37 : 08 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-3-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 08 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 27 8C 96 9B 9F 4D 6F E8 A3 CF 23 B7 3C BE 12 35 7E
16 : 37 : 08 <====Rx METER-2 7E A0 72 41 00 02 04 01 30 20 AC E6 E7 00 D4 61 20 00 00 01 28 94 B0 04 46 FE 0A D8 4C 91 01 9F BA DA DA 77 DA B0 AB 3A
F1 50 44 9B C9 40 B4 B4 9C 64 7F 4C 56 51 ED 00 77 64 32 B0 4D 9D 4C AA B0 C0 56 2F 04 A2 61 CE AB 9B 91 B3 EB 51 64 56
45 6F DC 6D 68 5C 89 E3 F4 79 B0 57 2F E0 5A B4 C6 BB 3F C9 27 B2 0E FB 1C BB 7A 19 22 FC F4 4C D0 48 B8 7E
16 : 37 : 08 <====Rx METER-2 D4 61 20 00 00 01 28 94 B0 04 46 FE 0A D8 4C 91 01 9F BA DA DA 77 DA B0 AB 3A F1 50 44 9B C9 40 B4 B4 9C 64 7F 4C 56 51
ED 00 77 64 32 B0 4D 9D 4C AA B0 C0 56 2F 04 A2 61 CE AB 9B 91 B3 EB 51 64 56 45 6F DC 6D 68 5C 89 E3 F4 79 B0 57 2F E0
16 : 37 : 08 <====Rx METER-2 D4 61 20 00 00 01 28 C4 01 81 00 01 01 02 0E 02 02 0F 00 16 23 02 02 0F 00 16 21 02 02 0F 00 16 21 02 02 0F 00 16 FF 02
02 0F 00 16 2C 02 02 0F 00 16 1C 02 02 0F 00 16 1B 02 02 0F 00 16 1E 02 02 0F 00 16 1F 02 02 0F 00 16 1B 02 02 0F 00 16
1C 02 02 0F 00 16 06 02 02 0F 00 16 1E 02 02 0F 00 16 1F
16 : 37 : 08 ====>Tx METER-2 D0 12 20 00 00 01 28 C0 01 C1 00 07 01 00 5E 5B 03 FF 03 00
16 : 37 : 08 ====>Tx METER-2 D0 12 20 00 00 01 28 58 F5 C4 9C 78 2A 85 9D FC 7A 95 9E 6D
16 : 37 : 08 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-3-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 09 METER-2 SENDING HDLC FRAME
16 : 37 : 09 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 28 58 F5 C4 9C 78 2A 85 9D FC 7A 95 9E 6D 15 BB 7E
16 : 37 : 09 METER-2 RECEIVED HDLC FRAME
16 : 37 : 09 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 01 29 47 1C 75 19 2B E4 64 12 95 93 11 A8 4F 73 2A 0C BC 44
89 74 CB 04 77 F4 08 BA 65 CB 82 F1 8E 22 52 29 57 45 6C B7 5E F9 8F 37 69 78 1E FE 55 4B 95 D1 18 32 B5 7F 9C BE 35 46
50 40 74 DE D1 06 D6 2C C6 E2 1B 2C 9A 1F 57 07 E6 05 DB F9 C6 E8 EB 4D 7B 44 50 5E 06 75 36 7D 0A 85 F9 3D BC 47 22 A8
64 A1 07 7F A9 A4 88 66 87 C9 D2 37 96 88 E5 28 FC E9 F1 60 FC CC D6 08 6B BA AE E3 45 C6 69 7D B1 F5 D1 DF 00 E8 AA 81
A7 5E B6 97 D4 C1 65 C9 D4 27 48 29 E1 83 E0 F6 09 AE 3F B1 F0 C8 A0 31 61 A9 B2 B7 91 03 9C AB DF D8 F6 95 8D C6 21 8F
F5 53 FA 20 FD F6 AB A0 D7 6F AD D4 2D 6E C9 73 CC A0 BA 08 A7 12 30 D0 F3 56 06 01 F8 05 64 1D 4E C0 F7 F6 92 13 29 C8
D4 7E D2 2C 9C 51 A4 62 F8 7E
16 : 37 : 09 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 09 <====Rx METER-2 D4 81 E6 20 00 00 01 29 47 1C 75 19 2B E4 64 12 95 93 11 A8 4F 73 2A 0C BC 44 89 74 CB 04 77 F4 08 BA 65 CB 82 F1 8E 22
52 29 57 45 6C B7 5E F9 8F 37 69 78 1E FE 55 4B 95 D1 18 32 B5 7F 9C BE 35 46 50 40 74 DE D1 06 D6 2C C6 E2 1B 2C 9A 1F
57 07 E6 05 DB F9 C6 E8 EB 4D 7B 44 50 5E 06 75 36 7D 0A 85 F9 3D BC 47 22 A8 64 A1 07 7F A9 A4 88 66 87 C9 D2 37 96 88
E5 28 FC E9 F1 60 FC CC D6 08 6B BA AE E3 45 C6 69 7D B1 F5 D1 DF 00 E8 AA 81 A7 5E B6 97 D4 C1 65 C9 D4 27 48 29 E1 83
E0 F6 09 AE 3F B1 F0 C8 A0 31 61 A9 B2 B7 91 03 9C AB DF D8 F6 95 8D C6 21 8F F5 53 FA 20 FD F6 AB A0 D7 6F AD D4 2D 6E
C9 73 CC A0 BA 08 A7 12 30 D0 F3 56 06 01 F8 05 64 1D 4E C0 F7 F6 92 13 29 C8 D4 7E D2 2C 9C 51 A4
16 : 37 : 09 <====Rx METER-2 D4 81 E6 20 00 00 01 29 C4 02 81 00 00 00 00 01 00 81 D6 01 0E 02 04 12 00 03 09 06 01 00 0C 07 00 FF 0F 03 12 00 00 02
04 12 00 03 09 06 01 00 0B 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 5B 07 00 FF 0F 03 12 00 00 02 04 12 00 03
09 06 01 00 0D 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0E 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00
09 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF
0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 03 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 03 12 00
00 02 04 12 00 04 09 06 01 00 09 06 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 00 00 5E 5B 0E FF 0F
16 : 37 : 09 METER-2 SERVICE = GET RESPONSE
16 : 37 : 09 METER-2 COSEM OUT DATA
16 : 37 : 09 ====>Tx METER-2 D0 0C 20 00 00 01 29 C0 02 C1 00 00 00 01
16 : 37 : 09 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 09 ====>Tx METER-2 D0 0C 20 00 00 01 29 0A 7D 7A 87 AF F5 6A
16 : 37 : 09 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 09 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 01 29 0A 7D 7A 87 AF F5 6A 7E 4C 7E
16 : 37 : 09 <====Rx METER-2 7E A0 48 41 00 02 04 01 74 1D 97 E6 E7 00 D4 37 20 00 00 01 2A A4 73 0C E9 EE 72 F4 10 43 44 6B C5 77 05 37 DC AE 49 FE
68 5C 98 33 76 F1 4A CD 0F D2 AB 8E 50 86 C1 ED CA 6F 14 25 27 E3 97 6F 07 41 7C F5 54 D8 A9 B2 44 7E
16 : 37 : 09 <====Rx METER-2 E6 E7 00 D4 37 20 00 00 01 2A A4 73 0C E9 EE 72 F4 10 43 44 6B C5 77 05 37 DC AE 49 FE 68 5C 98 33 76 F1 4A CD 0F D2 AB
16 : 37 : 09 <====Rx METER-2 01 0E 02 04 12 00 03 09 06 01 00 0C 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0B 07 00 FF 0F 03 12 00 00 02 04
12 00 03 09 06 01 00 5B 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0D 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09
06 01 00 0E 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01
07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F
03 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 03 12 00 00 02 04 12 00 04 09 06 01 00 09 06 00 FF 0F 03 12 00 00
02 04 12 00 03 09 06 00 00 5E 5B 0E FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 03 12 00 00 02 04 12 00
03 09 06 01 00 0A 08 00 FF 0F 03 12 00 00
16 : 37 : 09 ====>Tx METER-2 D0 12 20 00 00 01 2A C0 01 C1 00 07 01 00 5E 5B 03 FF 04 00
16 : 37 : 09 ====>Tx METER-2 D0 12 20 00 00 01 2A 25 29 5B 3E C9 D6 D6 C1 03 1F A2 00 B1
16 : 37 : 09 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-3-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 09 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 2A 25 29 5B 3E C9 D6 D6 C1 03 1F A2 00 B1 C8 7B 7E
16 : 37 : 09 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 01 2B C1 1A 04 01 92 A8 86 A4 E2 9A ED 7E
16 : 37 : 09 <====Rx METER-2 D4 0E 20 00 00 01 2B C1 1A 04 01 92 A8 86 A4 E2
16 : 37 : 09 <====Rx METER-2 D4 0E 20 00 00 01 2B C4 01 81 00 06 00 00 00 00
16 : 37 : 09 ====>Tx METER-2 D0 12 20 00 00 01 2B C0 01 C1 00 07 01 00 5E 5B 03 FF 05 00
16 : 37 : 09 ====>Tx METER-2 D0 12 20 00 00 01 2B 9A 6C 7C D3 B3 FF B7 81 DA B4 E4 CE 6A
16 : 37 : 09 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-3-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 09 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 2B 9A 6C 7C D3 B3 FF B7 81 DA B4 E4 CE 6A E2 2B 7E
16 : 37 : 09 <====Rx METER-2 7E A0 1C 41 00 02 04 01 B8 C4 86 E6 E7 00 D4 0B 20 00 00 01 2C AB B1 20 74 C7 C5 B6 A1 7E
16 : 37 : 09 <====Rx METER-2 D4 0B 20 00 00 01 2C AB B1 20 74 C7 C5
16 : 37 : 09 <====Rx METER-2 D4 0B 20 00 00 01 2C C4 01 81 00 16 01
16 : 37 : 09 ====>Tx METER-2 D0 12 20 00 00 01 2C C0 01 C1 00 07 01 00 5E 5B 03 FF 06 00
16 : 37 : 09 ====>Tx METER-2 D0 12 20 00 00 01 2C A1 67 1E 84 54 D5 2C C5 48 DF 6B BC 76
16 : 37 : 09 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-3-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 09 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 2C A1 67 1E 84 54 D5 2C C5 48 DF 6B BC 76 40 0C 7E
16 : 37 : 09 <====Rx METER-2 7E A0 2C 41 00 02 04 01 DA 9A 10 E6 E7 00 D4 1B 20 00 00 01 2D C8 3D 39 9D B2 68 CB 30 3B 0C D4 95 99 77 DD BA A1 02 68
9F A2 DD 83 D5 7E
16 : 37 : 10 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 10 <====Rx METER-2 D4 1B 20 00 00 01 2D C8 3D 39 9D B2 68 CB 30 3B 0C D4 95 99 77 DD BA A1 02 68 9F A2 DD
16 : 37 : 10 <====Rx METER-2 D4 1B 20 00 00 01 2D C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 10 METER-2 SERVICE = GET RESPONSE
16 : 37 : 10 METER-2 COSEM OUT DATA
16 : 37 : 10 ====>Tx METER-2 D0 12 20 00 00 01 2D C0 01 C1 00 07 01 00 5E 5B 03 FF 07 00
16 : 37 : 10 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 10 ====>Tx METER-2 D0 12 20 00 00 01 2D 09 D2 7D 83 6A A3 B5 CC 0A 70 81 1B 90
16 : 37 : 10 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-3-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 10 METER-2 SENDING HDLC FRAME
16 : 37 : 10 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 2D 09 D2 7D 83 6A A3 B5 CC 0A 70 81 1B 90 D6 E5 7E
16 : 37 : 10 METER-2 RECEIVED HDLC FRAME
16 : 37 : 10 <====Rx METER-2 7E A0 1F 41 00 02 04 01 FC 8A 2A E6 E7 00 D4 0E 20 00 00 01 2E 6F 2E B7 BC 80 CB E2 D5 4F E6 82 7E
16 : 37 : 10 <====Rx METER-2 D4 0E 20 00 00 01 2E 6F 2E B7 BC 80 CB E2 D5 4F
16 : 37 : 10 <====Rx METER-2 D4 0E 20 00 00 01 2E C4 01 81 00 06 00 00 00 01
16 : 37 : 10 ====>Tx METER-2 D0 12 20 00 00 01 2E C0 01 C1 00 07 01 00 5E 5B 03 FF 08 00
16 : 37 : 10 ====>Tx METER-2 D0 12 20 00 00 01 2E 29 DB C0 92 CC FA 21 3D 49 57 8F EE 43
16 : 37 : 10 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-3-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 10 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 2E 29 DB C0 92 CC FA 21 3D 49 57 8F EE 43 4E 7B 7E
16 : 37 : 10 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 01 2F 5A D3 3E 90 E6 10 2D 81 BB A5 B9 7E
16 : 37 : 10 <====Rx METER-2 D4 0E 20 00 00 01 2F 5A D3 3E 90 E6 10 2D 81 BB
16 : 37 : 10 <====Rx METER-2 D4 0E 20 00 00 01 2F C4 01 81 00 06 00 00 00 01
16 : 37 : 10 ====>Tx METER-2 D0 12 20 00 00 01 2F C0 01 C1 00 07 01 00 5E 5B 04 FF 02 00
16 : 37 : 10 ====>Tx METER-2 D0 12 20 00 00 01 2F 1A EA 15 F0 3E 01 81 71 E1 2B 46 32 61
16 : 37 : 10 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-4-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 10 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 2F 1A EA 15 F0 3E 01 81 71 E1 2B 46 32 61 34 43 7E
16 : 37 : 10 <====Rx METER-2 7E A0 48 41 00 02 04 01 30 3D 93 E6 E7 00 D4 37 20 00 00 01 30 1F 4A B4 EB 92 3E 90 E4 24 F8 BC 30 F0 70 56 A9 48 E8 23
13 52 55 54 2B A4 73 D3 A2 BE 35 5C E6 24 CA DE F7 8A 3F 70 EA F6 4A 09 E4 29 64 4C 65 67 2E 22 4A 7E
16 : 37 : 10 <====Rx METER-2 D4 37 20 00 00 01 30 1F 4A B4 EB 92 3E 90 E4 24 F8 BC 30 F0 70 56 A9 48 E8 23 13 52 55 54 2B A4 73 D3 A2 BE 35 5C E6 24
16 : 37 : 10 <====Rx METER-2 D4 37 20 00 00 01 30 C4 01 81 00 01 01 02 07 02 02 0F FE 16 23 02 02 0F 00 16 1E 02 02 0F 00 16 1F 02 02 0F 00 16 1E 02
02 0F 00 16 1F 02 02 0F FE 16 21 02 02 0F 00 16 FF
16 : 37 : 10 ====>Tx METER-2 D0 12 20 00 00 01 30 C0 01 C1 00 07 01 00 5E 5B 04 FF 03 00
16 : 37 : 10 ====>Tx METER-2 D0 12 20 00 00 01 30 22 E1 0B BF BA B6 48 52 EE 81 1B 42 15
16 : 37 : 10 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-4-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 10 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 30 22 E1 0B BF BA B6 48 52 EE 81 1B 42 15 DF E4 7E
16 : 37 : 10 <====Rx METER-2 7E A0 9B 41 00 02 04 01 52 95 8F E6 E7 00 D4 81 89 20 00 00 01 31 FF FB DC 0A 94 E1 3D 94 9B 1D 2D 9B 74 91 F0 8A D3 50
9B 5D 08 A3 6C CB 8C 4E 9E FC 30 13 42 85 09 AF 3D 0E 96 B6 CE F0 36 66 2F 83 7C 46 12 A2 19 06 5F 61 07 3D 6C 60 F7 B3
28 45 1C 1F 14 14 AF 8C B0 9B 50 A4 0F 24 1A 99 B1 97 28 A8 4A A2 C7 10 4F 15 13 8B 6D 3D D5 6F DA E1 F4 3A D4 C8 D0 A4
23 01 7E 7B 3B FE 20 BD C0 FA D9 12 1C C2 F0 52 E6 46 B9 46 91 DD 8C 23 7C 6B 42 36 16 7A C6 20 36 A1 98 56 7E
16 : 37 : 10 <====Rx METER-2 D4 81 89 20 00 00 01 31 FF FB DC 0A 94 E1 3D 94 9B 1D 2D 9B 74 91 F0 8A D3 50 9B 5D 08 A3 6C CB 8C 4E 9E FC 30 13 42 85
09 AF 3D 0E 96 B6 CE F0 36 66 2F 83 7C 46 12 A2 19 06 5F 61 07 3D 6C 60 F7 B3 28 45 1C 1F 14 14 AF 8C B0 9B 50 A4 0F 24
1A 99 B1 97 28 A8 4A A2 C7 10 4F 15 13 8B 6D 3D D5 6F DA E1 F4 3A D4 C8 D0 A4 23 01 7E 7B 3B FE 20 BD C0 FA D9 12 1C C2
16 : 37 : 10 <====Rx METER-2 D4 81 89 20 00 00 01 31 C4 01 81 00 01 07 02 04 12 00 03 09 06 01 00 0C 1B 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01
00 01 1D 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 1D 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 02 1D 00
FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0A 1D 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0B 1B 00 FF 0F 03 12
00 00 02 04 12 00 04 09 06 00 01 60 0C 05 FF 0F 03 12 00 00
16 : 37 : 11 ====>Tx METER-2 D0 12 20 00 00 01 31 C0 01 C1 00 07 01 00 5E 5B 04 FF 04 00
16 : 37 : 11 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 11 ====>Tx METER-2 D0 12 20 00 00 01 31 E0 29 5E B7 85 5C CE 96 A8 B1 C5 DC 78
16 : 37 : 11 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-4-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 11 METER-2 SENDING HDLC FRAME
16 : 37 : 11 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 31 E0 29 5E B7 85 5C CE 96 A8 B1 C5 DC 78 35 62 7E
16 : 37 : 11 METER-2 RECEIVED HDLC FRAME
16 : 37 : 11 <====Rx METER-2 7E A0 1F 41 00 02 04 01 74 CA 22 E6 E7 00 D4 0E 20 00 00 01 32 A1 6B 3B 1E 1B 80 5D 70 B0 02 8C 7E
16 : 37 : 11 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 11 <====Rx METER-2 D4 0E 20 00 00 01 32 A1 6B 3B 1E 1B 80 5D 70 B0
16 : 37 : 11 <====Rx METER-2 D4 0E 20 00 00 01 32 C4 01 81 00 06 00 00 00 00
16 : 37 : 11 METER-2 SERVICE = GET RESPONSE
16 : 37 : 11 ====>Tx METER-2 D0 12 20 00 00 01 32 C0 01 C1 00 07 01 00 5E 5B 04 FF 05 00
16 : 37 : 11 ====>Tx METER-2 D0 12 20 00 00 01 32 D1 FC A7 7B FC F4 BB 0C 74 D0 EE C4 3F
16 : 37 : 11 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-4-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 11 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 32 D1 FC A7 7B FC F4 BB 0C 74 D0 EE C4 3F D4 21 7E
16 : 37 : 11 <====Rx METER-2 7E A0 1C 41 00 02 04 01 96 B8 4E E6 E7 00 D4 0B 20 00 00 01 33 73 85 82 7F 5E 5E 23 C6 7E
16 : 37 : 11 <====Rx METER-2 D4 0B 20 00 00 01 33 73 85 82 7F 5E 5E
16 : 37 : 11 <====Rx METER-2 D4 0B 20 00 00 01 33 C4 01 81 00 16 01
16 : 37 : 11 ====>Tx METER-2 D0 12 20 00 00 01 33 C0 01 C1 00 07 01 00 5E 5B 04 FF 06 00
16 : 37 : 11 ====>Tx METER-2 D0 12 20 00 00 01 33 83 17 1A E3 CA 68 2A 26 0F C6 FB F6 0C
16 : 37 : 11 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-4-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 11 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 33 83 17 1A E3 CA 68 2A 26 0F C6 FB F6 0C E3 7A 7E
16 : 37 : 11 <====Rx METER-2 7E A0 2C 41 00 02 04 01 B8 8E 50 E6 E7 00 D4 1B 20 00 00 01 34 E9 3F 90 97 90 0A A7 4B 69 C0 1E 44 D0 B1 A5 F7 C8 4E 45
7B EF 44 EE A5 7E
16 : 37 : 11 <====Rx METER-2 D4 1B 20 00 00 01 34 E9 3F 90 97 90 0A A7 4B 69 C0 1E 44 D0 B1 A5 F7 C8 4E 45 7B EF 44
16 : 37 : 11 <====Rx METER-2 D4 1B 20 00 00 01 34 C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 11 ====>Tx METER-2 D0 12 20 00 00 01 34 C0 01 C1 00 07 01 00 5E 5B 04 FF 07 00
16 : 37 : 11 ====>Tx METER-2 D0 12 20 00 00 01 34 0D 80 4D F7 C0 19 82 92 71 3E C3 D8 F8
16 : 37 : 11 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-4-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 11 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 34 0D 80 4D F7 C0 19 82 92 71 3E C3 D8 F8 AE 11 7E
16 : 37 : 11 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 01 35 DF 31 5D A0 6C EC 38 37 26 F0 8F 7E
16 : 37 : 11 <====Rx METER-2 D4 0E 20 00 00 01 35 DF 31 5D A0 6C EC 38 37 26
16 : 37 : 11 <====Rx METER-2 D4 0E 20 00 00 01 35 C4 01 81 00 06 00 00 00 01
16 : 37 : 11 ====>Tx METER-2 D0 12 20 00 00 01 35 C0 01 C1 00 07 01 00 5E 5B 04 FF 08 00
16 : 37 : 11 ====>Tx METER-2 D0 12 20 00 00 01 35 40 B6 4A EF 6D 71 A0 C5 DE 6D B2 B1 C0
16 : 37 : 11 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-4-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 35 40 B6 4A EF 6D 71 A0 C5 DE 6D B2 B1 C0 34 7D 7E
16 : 37 : 12 METER-2 RECEIVED HDLC FRAME
16 : 37 : 12 <====Rx METER-2 7E A0 1F 41 00 02 04 01 FC 8A 2A E6 E7 00 D4 0E 20 00 00 01 36 48 EF FB A6 44 15 94 7D DF 22 86 7E
16 : 37 : 12 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 12 <====Rx METER-2 D4 0E 20 00 00 01 36 48 EF FB A6 44 15 94 7D DF
16 : 37 : 12 <====Rx METER-2 D4 0E 20 00 00 01 36 C4 01 81 00 06 00 00 00 01
16 : 37 : 12 METER-2 SERVICE = GET RESPONSE
16 : 37 : 12 METER-2 COSEM OUT DATA
16 : 37 : 12 ====>Tx METER-2 D0 12 20 00 00 01 36 C0 01 C1 00 07 01 00 5E 5B 05 FF 02 00
16 : 37 : 12 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 12 ====>Tx METER-2 D0 12 20 00 00 01 36 1F 2F F4 6A 27 F0 5B 5F E7 05 4B 4C 2D
16 : 37 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-5-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 12 METER-2 SENDING HDLC FRAME
16 : 37 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 36 1F 2F F4 6A 27 F0 5B 5F E7 05 4B 4C 2D BC 6E 7E
16 : 37 : 12 <====Rx METER-2 7E A0 42 41 00 02 04 01 1E 16 B2 E6 E7 00 D4 31 20 00 00 01 37 CA 52 E1 73 15 17 3E FA E6 BB B1 7E 23 95 8B 20 4E 0F 50
EB 40 1F 58 F5 E0 9C 1C F1 A8 8F 26 D3 AD AC C8 E8 D8 4D C9 5B EE 07 F7 12 70 36 7E
16 : 37 : 12 <====Rx METER-2 D4 31 20 00 00 01 37 CA 52 E1 73 15 17 3E FA E6 BB B1 7E 23 95 8B 20 4E 0F 50 EB 40 1F 58 F5 E0 9C 1C F1 A8 8F 26 D3 AD
16 : 37 : 12 <====Rx METER-2 D4 31 20 00 00 01 37 C4 01 81 00 01 01 02 06 02 02 0F 00 16 1E 02 02 0F 00 16 1F 02 02 0F 00 16 1E 02 02 0F 00 16 1F 02
02 0F 00 16 1B 02 02 0F 00 16 1C
16 : 37 : 12 ====>Tx METER-2 D0 12 20 00 00 01 37 C0 01 C1 00 07 01 00 5E 5B 05 FF 03 00
16 : 37 : 12 ====>Tx METER-2 D0 12 20 00 00 01 37 61 E4 96 09 C1 11 6E F5 09 2F D7 D3 67
16 : 37 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-5-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 37 61 E4 96 09 C1 11 6E F5 09 2F D7 D3 67 00 F0 7E
16 : 37 : 12 <====Rx METER-2 7E A0 88 41 00 02 04 01 30 26 D2 E6 E7 00 D4 77 20 00 00 01 38 B7 08 46 A7 3C 2C C4 69 A3 7F 36 5B 93 0B 30 05 EF 2C C8
BE 50 9D 87 41 C2 3C 73 4A 3B FB 13 69 A2 DC 7B 66 66 AE 35 13 64 A2 DF 69 50 9B 69 07 A5 22 0D 72 46 61 02 DF 6E 58 EA
9B 88 B7 EA 55 4D 82 AD 42 87 9A 58 50 2E B5 18 2E 6E F8 68 35 E6 2E CB 0B C4 27 D2 6A 31 C0 9D EF 25 53 B1 38 1D 7F 28
D3 55 2A 54 C0 C0 40 01 C0 BA 96 53 45 1B 62 19 3C 7E
16 : 37 : 12 <====Rx METER-2 D4 77 20 00 00 01 38 B7 08 46 A7 3C 2C C4 69 A3 7F 36 5B 93 0B 30 05 EF 2C C8 BE 50 9D 87 41 C2 3C 73 4A 3B FB 13 69 A2
DC 7B 66 66 AE 35 13 64 A2 DF 69 50 9B 69 07 A5 22 0D 72 46 61 02 DF 6E 58 EA 9B 88 B7 EA 55 4D 82 AD 42 87 9A 58 50 2E
B5 18 2E 6E F8 68 35 E6 2E CB 0B C4 27 D2 6A 31 C0 9D EF 25 53 B1 38 1D 7F 28 D3 55 2A 54 C0 C0 40 01 C0 BA 96 53 45 1B
62
16 : 37 : 12 <====Rx METER-2 D4 77 20 00 00 01 38 C4 01 81 00 01 06 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00
0A 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF
0F 03 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 03 12 00 00 02 04 12 00 04 09 06 01 00 09 06 00 FF 0F 03 12 00
00
16 : 37 : 12 ====>Tx METER-2 D0 12 20 00 00 01 38 C0 01 C1 00 07 01 00 5E 5B 05 FF 04 00
16 : 37 : 12 ====>Tx METER-2 D0 12 20 00 00 01 38 A2 7F 52 2A 22 F0 45 87 66 60 6F C3 6B
16 : 37 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-5-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 38 A2 7F 52 2A 22 F0 45 87 66 60 6F C3 6B 91 15 7E
16 : 37 : 12 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 01 39 95 C9 58 44 48 B0 34 48 0B C6 7B 7E
16 : 37 : 12 <====Rx METER-2 D4 0E 20 00 00 01 39 95 C9 58 44 48 B0 34 48 0B
16 : 37 : 12 <====Rx METER-2 D4 0E 20 00 00 01 39 C4 01 81 00 06 00 00 00 00
16 : 37 : 12 ====>Tx METER-2 D0 12 20 00 00 01 39 C0 01 C1 00 07 01 00 5E 5B 05 FF 05 00
16 : 37 : 12 ====>Tx METER-2 D0 12 20 00 00 01 39 BC B3 9A 49 D1 6D 2D 41 85 30 A5 7F AA
16 : 37 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-5-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 39 BC B3 9A 49 D1 6D 2D 41 85 30 A5 7F AA 2A F0 7E
16 : 37 : 12 <====Rx METER-2 7E A0 1C 41 00 02 04 01 74 A4 8A E6 E7 00 D4 0B 20 00 00 01 3A 66 64 F0 E3 C6 20 02 F3 7E
16 : 37 : 12 <====Rx METER-2 D4 0B 20 00 00 01 3A 66 64 F0 E3 C6 20
16 : 37 : 13 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 37 : 13 <====Rx METER-2 D4 0B 20 00 00 01 3A C4 01 81 00 16 01
16 : 37 : 13 METER-2 SERVICE = GET RESPONSE
16 : 37 : 13 METER-2 COSEM OUT DATA
16 : 37 : 13 ====>Tx METER-2 D0 12 20 00 00 01 3A C0 01 C1 00 07 01 00 5E 5B 05 FF 06 00
16 : 37 : 13 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 13 ====>Tx METER-2 D0 12 20 00 00 01 3A 5A 7D EC 0F B8 F7 66 0B 4B 8D 4D DF C8
16 : 37 : 13 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-5-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 13 METER-2 SENDING HDLC FRAME
16 : 37 : 13 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 3A 5A 7D EC 0F B8 F7 66 0B 4B 8D 4D DF C8 17 77 7E
16 : 37 : 13 METER-2 RECEIVED HDLC FRAME
16 : 37 : 13 <====Rx METER-2 7E A0 2C 41 00 02 04 01 96 F2 98 E6 E7 00 D4 1B 20 00 00 01 3B 55 3C EE DA 13 B3 15 D7 5B D4 99 55 A3 66 09 0E F8 5D 87
53 50 0E BB 54 7E
16 : 37 : 13 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 13 <====Rx METER-2 D4 1B 20 00 00 01 3B 55 3C EE DA 13 B3 15 D7 5B D4 99 55 A3 66 09 0E F8 5D 87 53 50 0E
16 : 37 : 13 <====Rx METER-2 D4 1B 20 00 00 01 3B C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 13 ====>Tx METER-2 D0 12 20 00 00 01 3B C0 01 C1 00 07 01 00 5E 5B 05 FF 07 00
16 : 37 : 13 ====>Tx METER-2 D0 12 20 00 00 01 3B 87 5B D3 6B 4B C1 AD 80 99 00 BD 53 FC
16 : 37 : 13 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-5-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 13 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 3B 87 5B D3 6B 4B C1 AD 80 99 00 BD 53 FC 9B A4 7E
16 : 37 : 13 <====Rx METER-2 7E A0 1F 41 00 02 04 01 B8 AA 2E E6 E7 00 D4 0E 20 00 00 01 3C DA 3D DB A5 D5 3D 22 2C 1E ED 98 7E
16 : 37 : 13 <====Rx METER-2 D4 0E 20 00 00 01 3C DA 3D DB A5 D5 3D 22 2C 1E
16 : 37 : 13 <====Rx METER-2 D4 0E 20 00 00 01 3C C4 01 81 00 06 00 00 00 01
16 : 37 : 13 ====>Tx METER-2 D0 12 20 00 00 01 3C C0 01 C1 00 07 01 00 5E 5B 05 FF 08 00
16 : 37 : 13 ====>Tx METER-2 D0 12 20 00 00 01 3C 16 7D DF 80 1B 8F 82 9C FD 8C 44 94 51
16 : 37 : 13 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-5-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 13 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 3C 16 7D DF 80 1B 8F 82 9C FD 8C 44 94 51 9F 5B 7E
16 : 37 : 13 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 01 3D A4 0E 53 45 8E 93 62 0B 13 32 B1 7E
16 : 37 : 13 <====Rx METER-2 D4 0E 20 00 00 01 3D A4 0E 53 45 8E 93 62 0B 13
16 : 37 : 13 <====Rx METER-2 D4 0E 20 00 00 01 3D C4 01 81 00 06 00 00 00 01
16 : 37 : 13 ====>Tx METER-2 D0 12 20 00 00 01 3D C0 01 C1 00 07 01 00 5E 5B 06 FF 02 00
16 : 37 : 13 ====>Tx METER-2 D0 12 20 00 00 01 3D 63 2E 3E B2 1A E0 97 B9 4C 12 AC 41 1B
16 : 37 : 13 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-6-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 13 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 3D 63 2E 3E B2 1A E0 97 B9 4C 12 AC 41 1B 87 5C 7E
16 : 37 : 13 <====Rx METER-2 7E A0 84 41 00 02 04 01 FC DC 6F E6 E7 00 D4 73 20 00 00 01 3E 03 66 F9 CF B6 1E B6 B3 59 25 7B 07 66 07 BC E9 58 5F 22
0D F7 65 F0 5F 69 1F CB 02 DE 4E 6E CF C1 F6 F5 06 86 BA FF 74 64 0E E7 04 5B 2E A5 E1 40 18 B2 F2 74 7B 51 A5 D0 75 30
3E B8 E2 56 05 0B 6A 2D 9F A9 A3 8F D7 5A BC 55 CA 0C FA 7B 47 78 96 C6 A8 E9 49 6B 06 EB E1 22 34 DD 39 19 4B 93 0C DD
B4 03 B6 A1 45 9D D8 9A 84 75 DE 28 DA 7E
16 : 37 : 13 <====Rx METER-2 D4 73 20 00 00 01 3E 03 66 F9 CF B6 1E B6 B3 59 25 7B 07 66 07 BC E9 58 5F 22 0D F7 65 F0 5F 69 1F CB 02 DE 4E 6E CF C1
F6 F5 06 86 BA FF 74 64 0E E7 04 5B 2E A5 E1 40 18 B2 F2 74 7B 51 A5 D0 75 30 3E B8 E2 56 05 0B 6A 2D 9F A9 A3 8F D7 5A
BC 55 CA 0C FA 7B 47 78 96 C6 A8 E9 49 6B 06 EB E1 22 34 DD 39 19 4B 93 0C DD B4 03 B6 A1 45 9D D8 9A 84 75 DE
16 : 37 : 13 <====Rx METER-2 D4 73 20 00 00 01 3E C4 01 81 00 01 01 02 11 02 02 0F 00 16 FF 02 02 0F 00 16 FF 02 02 0F 00 16 1E 02 02 0F 00 16 1E 02
02 0F 00 16 1E 02 02 0F 00 16 1E 02 02 0F 00 16 1E 02 02 0F 00 16 1F 02 02 0F 00 16 1F 02 02 0F 00 16 1F 02 02 0F 00 16
1F 02 02 0F 00 16 1F 02 02 0F 00 16 1B 02 02 0F 00 16 1C 02 02 0F 00 16 06 02 02 0F 00 16 1E 02 02 0F 00 16 1F
16 : 37 : 13 ====>Tx METER-2 D0 12 20 00 00 01 3E C0 01 C1 00 07 01 00 5E 5B 06 FF 03 00
16 : 37 : 14 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 14 ====>Tx METER-2 D0 12 20 00 00 01 3E F9 6F 96 E9 89 7E CA FB 5F E3 A6 29 F7
16 : 37 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-6-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 14 METER-2 SENDING HDLC FRAME
16 : 37 : 14 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 3E F9 6F 96 E9 89 7E CA FB 5F E3 A6 29 F7 DB C9 7E
16 : 37 : 14 METER-2 RECEIVED HDLC FRAME
16 : 37 : 14 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 01 3F 51 FF 0B 69 8E 7E 52 0A 17 33 C5 D6 E4 55 D7 13 9B 82
4D 61 B5 F3 95 18 11 C8 A2 44 90 F4 C7 B4 2C 39 48 04 65 EA 6F D4 32 BB FE 95 FD 07 1F 75 F3 1B 9F DF 57 07 50 76 29 07
AE 8C 58 A5 66 14 7E EC F6 18 C0 DF 4B 94 4D F2 80 D7 01 0C F5 FD 47 11 A9 A9 C3 F8 AF 6F 35 A6 D7 36 28 10 EC 9A AF F6
08 B6 2C B0 99 13 6A 95 60 DC 60 09 C5 55 89 D3 99 75 54 18 25 96 DB 9D E1 94 CC 32 B5 10 63 96 EA 8F 3A 52 F2 57 69 83
6C 6E BC 93 A0 0E A4 3D 3B 91 A7 A5 47 89 6E 76 5C D4 FF BD 0A 3B 45 F0 69 49 0F ED ED 91 7C DE 6D 8D D8 8C 3D 85 3F F6
D4 A1 77 F5 E6 4F 60 00 0F 7F F0 46 1B 60 05 F7 7B 91 7B 10 8B 69 B4 A1 C0 5A 76 E7 31 E8 C8 60 EB 9C 51 0F 59 B6 D6 C2
55 07 7A 31 D4 E2 BB 29 CC 7E
16 : 37 : 14 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 14 <====Rx METER-2 D4 81 E6 20 00 00 01 3F 51 FF 0B 69 8E 7E 52 0A 17 33 C5 D6 E4 55 D7 13 9B 82 4D 61 B5 F3 95 18 11 C8 A2 44 90 F4 C7 B4
2C 39 48 04 65 EA 6F D4 32 BB FE 95 FD 07 1F 75 F3 1B 9F DF 57 07 50 76 29 07 AE 8C 58 A5 66 14 7E EC F6 18 C0 DF 4B 94
4D F2 80 D7 01 0C F5 FD 47 11 A9 A9 C3 F8 AF 6F 35 A6 D7 36 28 10 EC 9A AF F6 08 B6 2C B0 99 13 6A 95 60 DC 60 09 C5 55
89 D3 99 75 54 18 25 96 DB 9D E1 94 CC 32 B5 10 63 96 EA 8F 3A 52 F2 57 69 83 6C 6E BC 93 A0 0E A4 3D 3B 91 A7 A5 47 89
6E 76 5C D4 FF BD 0A 3B 45 F0 69 49 0F ED ED 91 7C DE 6D 8D D8 8C 3D 85 3F F6 D4 A1 77 F5 E6 4F 60 00 0F 7F F0 46 1B 60
05 F7 7B 91 7B 10 8B 69 B4 A1 C0 5A 76 E7 31 E8 C8 60 EB 9C 51 0F 59 B6 D6 C2 55 07 7A 31 D4 E2 BB
16 : 37 : 14 <====Rx METER-2 D4 81 E6 20 00 00 01 3F C4 02 81 00 00 00 00 01 00 81 D6 01 11 02 04 12 00 03 09 06 00 00 00 01 02 FF 0F 03 12 00 00 02
04 12 00 03 09 06 01 00 0D 00 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 03 12 00 00 02 04 12 00 03
09 06 01 00 01 08 01 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 08 02 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00
01 08 03 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 08 04 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF
0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 01 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 02 FF 0F 03 12 00
00 02 04 12 00 03 09 06 01 00 09 08 03 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 04 FF 0F
16 : 37 : 14 METER-2 SERVICE = GET RESPONSE
16 : 37 : 14 ====>Tx METER-2 D0 0C 20 00 00 01 3F C0 02 C1 00 00 00 01
16 : 37 : 14 ====>Tx METER-2 D0 0C 20 00 00 01 3F 6A 0A 64 EE 30 5E EE
16 : 37 : 14 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 14 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 01 3F 6A 0A 64 EE 30 5E EE 58 88 7E
16 : 37 : 14 <====Rx METER-2 7E A0 7E 41 00 02 04 01 30 BA 1D E6 E7 00 D4 6D 20 00 00 01 40 BC 8F EC 00 34 D8 B6 28 E5 C5 9C 20 F4 6E F5 37 AB C8 49
78 68 8F FE 1A E7 FF D6 5B 98 C6 5B B1 7B 7B 64 31 FE 34 6A D3 48 54 26 18 B1 55 8D F5 CD 5E 6B 1B 54 AB C5 C3 B3 4C EF
7F ED 06 E6 91 E7 13 B5 3F AE DE B9 71 DD DF 23 6B 96 70 38 8B D7 0E 6B 83 10 BC EB BC FA 71 42 74 DD 95 4C 8D 42 DB AD
F3 C0 F0 B2 B9 83 E3 7E
16 : 37 : 14 <====Rx METER-2 E6 E7 00 D4 6D 20 00 00 01 40 BC 8F EC 00 34 D8 B6 28 E5 C5 9C 20 F4 6E F5 37 AB C8 49 78 68 8F FE 1A E7 FF D6 5B 98 C6
5B B1 7B 7B 64 31 FE 34 6A D3 48 54 26 18 B1 55 8D F5 CD 5E 6B 1B 54 AB C5 C3 B3 4C EF 7F ED 06 E6 91 E7 13 B5 3F AE DE
B9 71 DD DF 23 6B 96 70 38 8B D7 0E 6B 83 10 BC EB BC FA 71 42 74 DD 95 4C 8D 42 DB AD F3 C0 F0 B2 B9
16 : 37 : 14 <====Rx METER-2 01 11 02 04 12 00 03 09 06 00 00 00 01 02 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0D 00 00 FF 0F 03 12 00 00 02 04
12 00 03 09 06 01 00 01 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 08 01 FF 0F 03 12 00 00 02 04 12 00 03 09
06 01 00 01 08 02 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 08 03 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01
08 04 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 01 FF 0F
03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 02 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 03 FF 0F 03 12 00 00
02 04 12 00 03 09 06 01 00 09 08 04 FF 0F 03 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 03 12 00 00 02 04 12 00
04 09 06 01 00 09 06 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 00 00 5E 5B 0D FF 0F 03 12 00 00 02 04 12 00 03 09 06 01
00 02 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0A 08 00 FF 0F 03 12 00 00
16 : 37 : 14 ====>Tx METER-2 D0 12 20 00 00 01 40 C0 01 C1 00 07 01 00 5E 5B 06 FF 04 00
16 : 37 : 14 ====>Tx METER-2 D0 12 20 00 00 01 40 AF 0A 99 93 9C F9 43 9A 4A 75 C5 21 F8
16 : 37 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-6-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 14 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 40 AF 0A 99 93 9C F9 43 9A 4A 75 C5 21 F8 78 B7 7E
16 : 37 : 14 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 01 41 E1 70 67 32 9E 00 15 BE FD C1 32 7E
16 : 37 : 14 <====Rx METER-2 D4 0E 20 00 00 01 41 E1 70 67 32 9E 00 15 BE FD
16 : 37 : 14 <====Rx METER-2 D4 0E 20 00 00 01 41 C4 01 81 00 06 00 00 00 00
16 : 37 : 14 ====>Tx METER-2 D0 12 20 00 00 01 41 C0 01 C1 00 07 01 00 5E 5B 06 FF 05 00
16 : 37 : 14 ====>Tx METER-2 D0 12 20 00 00 01 41 9D 9C 4E 97 C6 9A 7A EF 90 8E 1E A7 03
16 : 37 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-6-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 14 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 41 9D 9C 4E 97 C6 9A 7A EF 90 8E 1E A7 03 E7 7E 7E
16 : 37 : 14 <====Rx METER-2 7E A0 1C 41 00 02 04 01 74 A4 8A E6 E7 00 D4 0B 20 00 00 01 42 B4 D4 2F 06 75 06 1C 01 7E
16 : 37 : 14 <====Rx METER-2 D4 0B 20 00 00 01 42 B4 D4 2F 06 75 06
16 : 37 : 14 <====Rx METER-2 D4 0B 20 00 00 01 42 C4 01 81 00 16 01
16 : 37 : 14 ====>Tx METER-2 D0 12 20 00 00 01 42 C0 01 C1 00 07 01 00 5E 5B 06 FF 06 00
16 : 37 : 14 ====>Tx METER-2 D0 12 20 00 00 01 42 EA EF E1 C1 AA 9B F6 75 77 F3 6C 1A F3
16 : 37 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-6-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 42 EA EF E1 C1 AA 9B F6 75 77 F3 6C 1A F3 23 8B 7E
16 : 37 : 15 METER-2 RECEIVED HDLC FRAME
16 : 37 : 15 <====Rx METER-2 7E A0 2C 41 00 02 04 01 96 F2 98 E6 E7 00 D4 1B 20 00 00 01 43 A7 37 D9 8E 97 81 A8 CC 3F 8D E0 62 62 FD 63 48 43 C2 A2
54 13 8F CA 20 7E
16 : 37 : 15 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 15 <====Rx METER-2 D4 1B 20 00 00 01 43 A7 37 D9 8E 97 81 A8 CC 3F 8D E0 62 62 FD 63 48 43 C2 A2 54 13 8F
16 : 37 : 15 <====Rx METER-2 D4 1B 20 00 00 01 43 C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 15 METER-2 SERVICE = GET RESPONSE
16 : 37 : 15 METER-2 COSEM OUT DATA
16 : 37 : 15 ====>Tx METER-2 D0 12 20 00 00 01 43 C0 01 C1 00 07 01 00 5E 5B 06 FF 07 00
16 : 37 : 15 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 15 ====>Tx METER-2 D0 12 20 00 00 01 43 F9 DF C5 7F 51 D3 C7 E0 8C 67 2B 5F 1F
16 : 37 : 15 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-6-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 15 METER-2 SENDING HDLC FRAME
16 : 37 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 43 F9 DF C5 7F 51 D3 C7 E0 8C 67 2B 5F 1F 86 74 7E
16 : 37 : 15 <====Rx METER-2 7E A0 1F 41 00 02 04 01 B8 AA 2E E6 E7 00 D4 0E 20 00 00 01 44 48 13 19 46 50 17 8A DD D9 58 E1 7E
16 : 37 : 15 <====Rx METER-2 D4 0E 20 00 00 01 44 48 13 19 46 50 17 8A DD D9
16 : 37 : 15 <====Rx METER-2 D4 0E 20 00 00 01 44 C4 01 81 00 06 00 00 00 01
16 : 37 : 15 ====>Tx METER-2 D0 12 20 00 00 01 44 C0 01 C1 00 07 01 00 5E 5B 06 FF 08 00
16 : 37 : 15 ====>Tx METER-2 D0 12 20 00 00 01 44 FE 11 54 63 05 AF D6 40 0A 4F 3D 27 0D
16 : 37 : 15 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-6-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 44 FE 11 54 63 05 AF D6 40 0A 4F 3D 27 0D A1 EF 7E
16 : 37 : 15 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 01 45 4A 95 D2 47 2B 06 CD CB A8 5D 17 7E
16 : 37 : 15 <====Rx METER-2 D4 0E 20 00 00 01 45 4A 95 D2 47 2B 06 CD CB A8
16 : 37 : 15 <====Rx METER-2 D4 0E 20 00 00 01 45 C4 01 81 00 06 00 00 00 01
16 : 37 : 15 ====>Tx METER-2 D0 12 20 00 00 01 45 C0 01 C1 00 07 01 00 5E 5B 07 FF 02 00
16 : 37 : 15 ====>Tx METER-2 D0 12 20 00 00 01 45 C5 28 0A 15 F3 BF C5 C8 B3 D4 06 E1 CE
16 : 37 : 15 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-7-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 45 C5 28 0A 15 F3 BF C5 C8 B3 D4 06 E1 CE 5A D6 7E
16 : 37 : 15 <====Rx METER-2 7E A0 36 41 00 02 04 01 FC 30 08 E6 E7 00 D4 25 20 00 00 01 46 07 88 B5 8F 0D D3 AD D2 54 25 A8 2C 95 6F F7 85 C2 6A 39
0D 19 66 86 F8 1A AD ED 9C 8C 04 CA 02 C5 FB 7E
16 : 37 : 15 <====Rx METER-2 D4 25 20 00 00 01 46 07 88 B5 8F 0D D3 AD D2 54 25 A8 2C 95 6F F7 85 C2 6A 39 0D 19 66 86 F8 1A AD ED 9C 8C 04 CA 02
16 : 37 : 15 <====Rx METER-2 D4 25 20 00 00 01 46 C4 01 81 00 01 01 02 04 02 02 0F 00 16 21 02 02 0F 00 16 23 02 02 0F 00 16 FF 02 02 0F 00 16 1E
16 : 37 : 15 ====>Tx METER-2 D0 12 20 00 00 01 46 C0 01 C1 00 07 01 00 5E 5B 07 FF 03 00
16 : 37 : 15 ====>Tx METER-2 D0 12 20 00 00 01 46 EB 3D 2E 80 E9 E4 9E AD 7D B5 4D F0 B8
16 : 37 : 15 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-7-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 46 EB 3D 2E 80 E9 E4 9E AD 7D B5 4D F0 B8 FB 1A 7E
16 : 37 : 15 <====Rx METER-2 7E A0 64 41 00 02 04 01 1E 58 89 E6 E7 00 D4 53 20 00 00 01 47 47 83 FA A4 26 E4 D2 65 C1 CE FA 39 A8 B9 CF FE 96 8F EF
BA 2E 3F 7E E0 8B B5 76 70 4B FE CD EA BB 34 77 64 42 6F 0D A7 30 48 B9 32 FF 42 3F 4E C8 28 83 87 37 40 8C C3 9A 7C 44
2A B9 84 78 27 D5 C4 65 8F 19 FC 7A F6 3B 4B 0D B6 08 3D 96 08 7E
16 : 37 : 15 <====Rx METER-2 D4 53 20 00 00 01 47 47 83 FA A4 26 E4 D2 65 C1 CE FA 39 A8 B9 CF FE 96 8F EF BA 2E 3F 7E E0 8B B5 76 70 4B FE CD EA BB
34 77 64 42 6F 0D A7 30 48 B9 32 FF 42 3F 4E C8 28 83 87 37 40 8C C3 9A 7C 44 2A B9 84 78 27 D5 C4 65 8F 19 FC 7A F6 3B
4B 0D B6 08 3D
16 : 37 : 16 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 37 : 16 <====Rx METER-2 D4 53 20 00 00 01 47 C4 01 81 00 01 04 02 04 12 00 03 09 06 01 00 5E 5B 0E FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00
0C 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0D 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF
0F 03 12 00 00
16 : 37 : 16 METER-2 SERVICE = GET RESPONSE
16 : 37 : 16 METER-2 COSEM OUT DATA
16 : 37 : 16 ====>Tx METER-2 D0 12 20 00 00 01 47 C0 01 C1 00 07 01 00 5E 5B 07 FF 04 00
16 : 37 : 16 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 16 ====>Tx METER-2 D0 12 20 00 00 01 47 B8 8C 52 2C FA C3 8A AE EE 4B CB 26 11
16 : 37 : 16 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-7-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 16 METER-2 SENDING HDLC FRAME
16 : 37 : 16 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 47 B8 8C 52 2C FA C3 8A AE EE 4B CB 26 11 53 EB 7E
16 : 37 : 16 METER-2 RECEIVED HDLC FRAME
16 : 37 : 16 <====Rx METER-2 7E A0 1F 41 00 02 04 01 30 EA 26 E6 E7 00 D4 0E 20 00 00 01 48 3A BE 23 DE DB E8 0C 6B 1D 89 EF 7E
16 : 37 : 16 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 16 <====Rx METER-2 D4 0E 20 00 00 01 48 3A BE 23 DE DB E8 0C 6B 1D
16 : 37 : 16 <====Rx METER-2 D4 0E 20 00 00 01 48 C4 01 81 00 06 00 00 00 00
16 : 37 : 16 ====>Tx METER-2 D0 12 20 00 00 01 48 C0 01 C1 00 07 01 00 5E 5B 07 FF 05 00
16 : 37 : 16 ====>Tx METER-2 D0 12 20 00 00 01 48 36 98 70 AA 89 07 5D 58 51 23 26 AB 50
16 : 37 : 16 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-7-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 16 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 48 36 98 70 AA 89 07 5D 58 51 23 26 AB 50 85 2B 7E
16 : 37 : 16 <====Rx METER-2 7E A0 1C 41 00 02 04 01 52 90 CE E6 E7 00 D4 0B 20 00 00 01 49 8B 89 73 A5 B6 71 BA C1 7E
16 : 37 : 16 <====Rx METER-2 D4 0B 20 00 00 01 49 8B 89 73 A5 B6 71
16 : 37 : 16 <====Rx METER-2 D4 0B 20 00 00 01 49 C4 01 81 00 16 01
16 : 37 : 16 ====>Tx METER-2 D0 12 20 00 00 01 49 C0 01 C1 00 07 01 00 5E 5B 07 FF 06 00
16 : 37 : 16 ====>Tx METER-2 D0 12 20 00 00 01 49 37 98 EA D3 C5 54 77 9A 9E 59 EA 1A 7E
16 : 37 : 16 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-7-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 16 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 49 37 98 EA D3 C5 54 77 9A 9E 59 EA 1A 7E F1 BA 7E
16 : 37 : 16 <====Rx METER-2 7E A0 2C 41 00 02 04 01 74 EE 5C E6 E7 00 D4 1B 20 00 00 01 4A 37 02 91 30 1D 86 4E 7A CC 6F E7 36 AE D1 52 A4 09 72 F0
17 6F B7 4F B6 7E
16 : 37 : 16 <====Rx METER-2 D4 1B 20 00 00 01 4A 37 02 91 30 1D 86 4E 7A CC 6F E7 36 AE D1 52 A4 09 72 F0 17 6F B7
16 : 37 : 16 <====Rx METER-2 D4 1B 20 00 00 01 4A C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 16 ====>Tx METER-2 D0 12 20 00 00 01 4A C0 01 C1 00 07 01 00 5E 5B 07 FF 07 00
16 : 37 : 16 ====>Tx METER-2 D0 12 20 00 00 01 4A 70 FD 9E 4A CD AE 96 F1 70 EF 83 C8 DA
16 : 37 : 16 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-7-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 16 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 4A 70 FD 9E 4A CD AE 96 F1 70 EF 83 C8 DA EE F0 7E
16 : 37 : 16 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 01 4B BE 12 F1 7E 2A C1 A9 79 31 FE FC 7E
16 : 37 : 16 <====Rx METER-2 D4 0E 20 00 00 01 4B BE 12 F1 7E 2A C1 A9 79 31
16 : 37 : 16 <====Rx METER-2 D4 0E 20 00 00 01 4B C4 01 81 00 06 00 00 00 01
16 : 37 : 16 ====>Tx METER-2 D0 12 20 00 00 01 4B C0 01 C1 00 07 01 00 5E 5B 07 FF 08 00
16 : 37 : 17 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 17 ====>Tx METER-2 D0 12 20 00 00 01 4B FB 20 6B E1 0F CA 4B 3D B6 A4 2A 13 52
16 : 37 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-94-91-7-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 17 METER-2 SENDING HDLC FRAME
16 : 37 : 17 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 4B FB 20 6B E1 0F CA 4B 3D B6 A4 2A 13 52 44 CF 7E
16 : 37 : 17 METER-2 RECEIVED HDLC FRAME
16 : 37 : 17 <====Rx METER-2 7E A0 1F 41 00 02 04 01 B8 AA 2E E6 E7 00 D4 0E 20 00 00 01 4C A9 BD A2 81 17 FB 75 52 14 37 66 7E
16 : 37 : 17 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 17 <====Rx METER-2 D4 0E 20 00 00 01 4C A9 BD A2 81 17 FB 75 52 14
16 : 37 : 17 <====Rx METER-2 D4 0E 20 00 00 01 4C C4 01 81 00 06 00 00 00 01
16 : 37 : 17 METER-2 SERVICE = GET RESPONSE
16 : 37 : 17 ====>Tx METER-2 D0 12 20 00 00 01 4C C0 01 C1 00 07 01 00 62 01 00 FF 02 00
16 : 37 : 17 ====>Tx METER-2 D0 12 20 00 00 01 4C C2 7D 06 68 EA 6E EC D6 89 BF 62 F8 E9
16 : 37 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-98-1-0-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 17 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 4C C2 7D 06 68 EA 6E EC D6 89 BF 62 F8 E9 B5 F5 7E
16 : 37 : 17 <====Rx METER-2 7E A0 99 41 00 02 04 01 DA 6E B0 E6 E7 00 D4 81 87 20 00 00 01 4D 0D 1D 43 D2 1A F6 46 87 BC AC A2 BB D7 3E AF 61 11 FB
0E B4 68 B0 71 86 5D 18 C6 4D D9 F7 28 AB C7 8A 32 89 15 BF 16 0A 73 D7 C4 B0 1A FF E3 A2 C1 1A 1B BF B5 7C A8 7C BD BF
05 FD 27 43 C5 63 A3 C6 D7 3C 66 5D 15 51 C9 6C C5 55 C9 A2 AF 09 8D 01 A1 A9 AF 15 9B 1C 83 6B 3E D3 7F 0D 22 75 F8 90
BC FB 5A C1 7E EB 13 AA 8E 9E BC 7C F0 B1 FF 15 E2 15 C2 5A 49 A2 AB EE C0 28 12 10 ED 53 F1 22 6D 2B 7E
16 : 37 : 17 <====Rx METER-2 D4 81 87 20 00 00 01 4D 0D 1D 43 D2 1A F6 46 87 BC AC A2 BB D7 3E AF 61 11 FB 0E B4 68 B0 71 86 5D 18 C6 4D D9 F7 28 AB
C7 8A 32 89 15 BF 16 0A 73 D7 C4 B0 1A FF E3 A2 C1 1A 1B BF B5 7C A8 7C BD BF 05 FD 27 43 C5 63 A3 C6 D7 3C 66 5D 15 51
C9 6C C5 55 C9 A2 AF 09 8D 01 A1 A9 AF 15 9B 1C 83 6B 3E D3 7F 0D 22 75 F8 90 BC FB 5A C1 7E EB 13 AA 8E 9E BC 7C F0 B1
16 : 37 : 17 <====Rx METER-2 D4 81 87 20 00 00 01 4D C4 01 81 00 01 01 02 13 09 0C 07 E3 0B 14 03 10 25 01 FF 01 4A 00 17 00 00 00 00 17 00 00 00 00
17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00
17 00 00 00 00 17 00 00 00 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 17 00 00 00 00 09 0C FF FF FF FF FF FF FF FF FF
80 00 FF 06 00 00 02 A4 17 00 00 00 00 17 00 00 00 00
16 : 37 : 17 ====>Tx METER-2 D0 12 20 00 00 01 4D C0 01 C1 00 07 01 00 62 01 00 FF 03 00
16 : 37 : 17 ====>Tx METER-2 D0 12 20 00 00 01 4D 18 00 33 3F D3 BF 51 E5 B3 55 11 9E 8E
16 : 37 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-98-1-0-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 17 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 4D 18 00 33 3F D3 BF 51 E5 B3 55 11 9E 8E 78 2C 7E
16 : 37 : 17 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 01 4E D1 46 EE 1A 43 3A C6 3D 42 EE 89 8C 48 C9 C5 A6 59 4D
64 3A 19 2E 82 AE 39 62 7C EE 9F F8 A4 27 E0 91 2F 97 A5 C0 D2 A3 CF FA 26 BA 7E 88 3C 63 25 95 4F E4 3E B7 E2 37 5C 43
0A DF FF 19 4D 15 41 D2 4A 5D AA 25 A1 C7 C1 50 D3 DE F6 B9 F7 8D E9 12 71 9E 95 28 D7 1A 67 0F 8C AA 6A 36 43 FF 1D FB
A2 AE 2C FE 00 5F E7 47 E6 65 04 6C 86 C9 5A B4 35 DF 6F 8F BE 00 58 19 8E 96 DC B5 97 03 0D 2A 33 C6 DA E2 56 E8 43 71
EA 5A 71 69 20 34 21 6A A4 F1 13 96 FF C8 3F EA C9 8C B9 E0 F4 C6 FD 14 BD EC 32 91 E4 8D BA C3 E1 40 77 79 99 C4 77 0F
2F BC 39 A6 CD 0A DE C0 07 5C ED 55 53 D5 26 A9 18 12 CD C7 EC FE AB 1E 79 7B 65 70 4C F0 3E C6 08 3E A2 E0 01 5E D7 0D
B6 14 CB 09 38 E4 28 28 AC 7E
16 : 37 : 17 <====Rx METER-2 D4 81 E6 20 00 00 01 4E D1 46 EE 1A 43 3A C6 3D 42 EE 89 8C 48 C9 C5 A6 59 4D 64 3A 19 2E 82 AE 39 62 7C EE 9F F8 A4 27
E0 91 2F 97 A5 C0 D2 A3 CF FA 26 BA 7E 88 3C 63 25 95 4F E4 3E B7 E2 37 5C 43 0A DF FF 19 4D 15 41 D2 4A 5D AA 25 A1 C7
C1 50 D3 DE F6 B9 F7 8D E9 12 71 9E 95 28 D7 1A 67 0F 8C AA 6A 36 43 FF 1D FB A2 AE 2C FE 00 5F E7 47 E6 65 04 6C 86 C9
5A B4 35 DF 6F 8F BE 00 58 19 8E 96 DC B5 97 03 0D 2A 33 C6 DA E2 56 E8 43 71 EA 5A 71 69 20 34 21 6A A4 F1 13 96 FF C8
3F EA C9 8C B9 E0 F4 C6 FD 14 BD EC 32 91 E4 8D BA C3 E1 40 77 79 99 C4 77 0F 2F BC 39 A6 CD 0A DE C0 07 5C ED 55 53 D5
26 A9 18 12 CD C7 EC FE AB 1E 79 7B 65 70 4C F0 3E C6 08 3E A2 E0 01 5E D7 0D B6 14 CB 09 38 E4 28
16 : 37 : 17 <====Rx METER-2 D4 81 E6 20 00 00 01 4E C4 02 81 00 00 00 00 01 00 81 D6 01 13 02 04 12 00 03 09 06 00 00 00 01 02 FF 0F 02 12 00 00 02
04 12 00 03 09 06 01 00 0D 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03
09 06 01 00 01 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00
01 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF
0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 02 FF 0F 02 12 00
00 02 04 12 00 03 09 06 01 00 09 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 04 FF 0F
16 : 37 : 17 ====>Tx METER-2 D0 0C 20 00 00 01 4E C0 02 C1 00 00 00 01
16 : 37 : 17 ====>Tx METER-2 D0 0C 20 00 00 01 4E F7 21 B1 1D F2 F5 31
16 : 37 : 17 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 17 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 01 4E F7 21 B1 1D F2 F5 31 CA 65 7E
16 : 37 : 17 <====Rx METER-2 7E A0 A4 41 00 02 04 01 1E 43 C8 E6 E7 00 D4 81 92 20 00 00 01 4F 2D 27 35 20 3D EE 1A 6E 60 0B 3F 63 05 9E 01 54 55 B4
7B E8 71 2A B9 DE 33 68 E7 79 89 2E F3 1D E8 F3 81 84 5D 2C 75 5E 5B A5 B4 7C 57 D9 29 18 21 1B 12 D1 DB 13 91 09 0B 59
FC E3 C4 6D 9B D8 8C B0 11 6B 92 FE 60 7D 01 4D D5 29 83 B0 E4 E3 5B AA 98 9C D6 79 9A 7D 58 0A 91 EA 15 A9 92 60 E6 90
1A 34 A7 08 BC 76 ED 8D 19 27 44 B6 A6 6B 78 67 2C 29 A1 8F DA 3E EE 37 65 42 3F B9 5B CC B6 5D E1 B6 F7 AE 88 88 C8 FC
EB C8 BB 3C 8F 7E
16 : 37 : 17 <====Rx METER-2 E6 E7 00 D4 81 92 20 00 00 01 4F 2D 27 35 20 3D EE 1A 6E 60 0B 3F 63 05 9E 01 54 55 B4 7B E8 71 2A B9 DE 33 68 E7 79 89
2E F3 1D E8 F3 81 84 5D 2C 75 5E 5B A5 B4 7C 57 D9 29 18 21 1B 12 D1 DB 13 91 09 0B 59 FC E3 C4 6D 9B D8 8C B0 11 6B 92
FE 60 7D 01 4D D5 29 83 B0 E4 E3 5B AA 98 9C D6 79 9A 7D 58 0A 91 EA 15 A9 92 60 E6 90 1A 34 A7 08 BC 76 ED 8D 19 27 44
B6 A6 6B 78 67 2C 29 A1 8F DA 3E EE 37 65 42 3F B9 5B CC B6 5D E1 B6 F7 AE 88 88 C8 FC EB C8 BB
16 : 37 : 17 <====Rx METER-2 01 13 02 04 12 00 03 09 06 00 00 00 01 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0D 00 00 FF 0F 02 12 00 00 02 04
12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09
06 01 00 01 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01
08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 01 FF 0F
02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 03 FF 0F 02 12 00 00
02 04 12 00 03 09 06 01 00 09 08 04 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 02 12 00 00 02 04 12 00
04 09 06 01 00 01 06 00 FF 0F 05 12 00 00 02 04 12 00 04 09 06 01 00 09 06 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01
00 09 06 00 FF 0F 05 12 00 00 02 04 12 00 03 09 06 00 00 5E 5B 0D FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00
FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0A 08 00 FF 0F 02 12 00 00
16 : 37 : 17 ====>Tx METER-2 D0 12 20 00 00 01 4F C0 01 C1 00 07 01 00 62 01 00 FF 04 00
16 : 37 : 17 ====>Tx METER-2 D0 12 20 00 00 01 4F 62 C9 82 A5 A5 67 8E 65 C5 58 B3 B6 0A
16 : 37 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-98-1-0-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 18 METER-2 SENDING HDLC FRAME
16 : 37 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 4F 62 C9 82 A5 A5 67 8E 65 C5 58 B3 B6 0A F6 52 7E
16 : 37 : 18 METER-2 RECEIVED HDLC FRAME
16 : 37 : 18 <====Rx METER-2 7E A0 1F 41 00 02 04 01 30 EA 26 E6 E7 00 D4 0E 20 00 00 01 50 CB 73 A7 46 BA 1D 0D 0A 1C AA 2C 7E
16 : 37 : 18 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 18 <====Rx METER-2 D4 0E 20 00 00 01 50 CB 73 A7 46 BA 1D 0D 0A 1C
16 : 37 : 18 <====Rx METER-2 D4 0E 20 00 00 01 50 C4 01 81 00 06 00 00 00 00
16 : 37 : 18 METER-2 SERVICE = GET RESPONSE
16 : 37 : 18 METER-2 COSEM OUT DATA
16 : 37 : 18 ====>Tx METER-2 D0 12 20 00 00 01 50 C0 01 C1 00 07 01 00 62 01 00 FF 05 00
16 : 37 : 18 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 18 ====>Tx METER-2 D0 12 20 00 00 01 50 BF A9 AD EA E3 17 CE B5 6D 15 CB D2 9D
16 : 37 : 18 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-98-1-0-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 50 BF A9 AD EA E3 17 CE B5 6D 15 CB D2 9D 23 65 7E
16 : 37 : 18 <====Rx METER-2 7E A0 1C 41 00 02 04 01 52 90 CE E6 E7 00 D4 0B 20 00 00 01 51 34 BA 30 00 AB FF F6 D1 7E
16 : 37 : 18 <====Rx METER-2 D4 0B 20 00 00 01 51 34 BA 30 00 AB FF
16 : 37 : 18 <====Rx METER-2 D4 0B 20 00 00 01 51 C4 01 81 00 16 01
16 : 37 : 18 ====>Tx METER-2 D0 12 20 00 00 01 51 C0 01 C1 00 07 01 00 62 01 00 FF 06 00
16 : 37 : 18 ====>Tx METER-2 D0 12 20 00 00 01 51 DE 21 21 68 64 81 1C 1F F1 76 00 FB B5
16 : 37 : 18 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-98-1-0-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 51 DE 21 21 68 64 81 1C 1F F1 76 00 FB B5 0F A3 7E
16 : 37 : 18 <====Rx METER-2 7E A0 2C 41 00 02 04 01 74 EE 5C E6 E7 00 D4 1B 20 00 00 01 52 18 E2 B3 8B E1 23 3F 50 F4 02 CA 4A CF 47 5F 24 F8 EA BC
15 E2 F2 91 DA 7E
16 : 37 : 18 <====Rx METER-2 D4 1B 20 00 00 01 52 18 E2 B3 8B E1 23 3F 50 F4 02 CA 4A CF 47 5F 24 F8 EA BC 15 E2 F2
16 : 37 : 18 <====Rx METER-2 D4 1B 20 00 00 01 52 C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 18 ====>Tx METER-2 D0 12 20 00 00 01 52 C0 01 C1 00 07 01 00 62 01 00 FF 07 00
16 : 37 : 18 ====>Tx METER-2 D0 12 20 00 00 01 52 9C 5D 8A A7 59 3A 0C 35 CE 3C D3 4B 8F
16 : 37 : 18 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-98-1-0-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 52 9C 5D 8A A7 59 3A 0C 35 CE 3C D3 4B 8F 47 6F 7E
16 : 37 : 18 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 01 53 5D C7 8C 53 C8 92 85 28 C3 26 DC 7E
16 : 37 : 18 <====Rx METER-2 D4 0E 20 00 00 01 53 5D C7 8C 53 C8 92 85 28 C3
16 : 37 : 18 <====Rx METER-2 D4 0E 20 00 00 01 53 C4 01 81 00 06 00 00 00 01
16 : 37 : 18 ====>Tx METER-2 D0 12 20 00 00 01 53 C0 01 C1 00 07 01 00 62 01 00 FF 08 00
16 : 37 : 18 ====>Tx METER-2 D0 12 20 00 00 01 53 F7 14 54 65 7E 8D C9 AA 56 02 54 DC 47
16 : 37 : 18 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-98-1-0-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 53 F7 14 54 65 7E 8D C9 AA 56 02 54 DC 47 BE 87 7E
16 : 37 : 18 <====Rx METER-2 7E A0 1F 41 00 02 04 01 B8 AA 2E E6 E7 00 D4 0E 20 00 00 01 54 42 A4 79 0F 68 AA 3D 6D D2 61 08 7E
16 : 37 : 18 <====Rx METER-2 D4 0E 20 00 00 01 54 42 A4 79 0F 68 AA 3D 6D D2
16 : 37 : 19 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 37 : 19 <====Rx METER-2 D4 0E 20 00 00 01 54 C4 01 81 00 06 00 00 00 0D
16 : 37 : 19 METER-2 SERVICE = GET RESPONSE
16 : 37 : 19 METER-2 COSEM OUT DATA
16 : 37 : 19 ====>Tx METER-2 D0 12 20 00 00 01 54 C0 01 C1 00 07 01 00 63 01 00 FF 02 00
16 : 37 : 19 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 19 ====>Tx METER-2 D0 12 20 00 00 01 54 1A 5E BF 9C 1D E5 07 C5 FE 85 6B B9 61
16 : 37 : 19 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-1-0-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 19 METER-2 SENDING HDLC FRAME
16 : 37 : 19 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 54 1A 5E BF 9C 1D E5 07 C5 FE 85 6B B9 61 3C AC 7E
16 : 37 : 19 METER-2 RECEIVED HDLC FRAME
16 : 37 : 19 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 01 55 E6 53 FC F5 64 9E C6 E6 02 17 2F E4 75 68 76 4D A5 1A
D6 B5 FB 20 DE 70 88 9B F7 97 CD B3 95 AE 3D 5D EA 32 38 51 BE 74 66 8B E4 89 2C A2 EA 5E 8F 8A FB 2B 8B 2F 22 17 0E 46
9A 35 77 52 F4 DD 6F BF 39 C7 3A 84 E3 DA DF 90 88 E8 72 6B 8B 7C F7 2E 71 B4 90 D6 B2 DD A5 A5 CB DA FA A4 76 D1 9C FA
B6 EE 22 42 DB 80 A4 8B A7 C6 A2 FB 5A A0 E8 13 9E 7B 3A 97 F2 3B 1E 09 3E D0 6C D8 86 CF 23 AD 8D C8 5F 25 CA D8 91 60
7B BA 57 F7 D7 6C 54 FD 02 48 18 AA B9 D8 55 DC EA C7 CF 25 A4 A4 76 FD 3E 0D 19 84 B2 26 48 BA 7C 73 27 52 27 F5 16 09
C3 0C 6F 0D FE 40 B5 B9 96 50 DD 18 29 9B D0 C6 AA 47 01 7C 12 1D 00 BA E8 EE 89 88 25 B4 5F 0A 32 1E DC F4 A1 B1 12 C0
61 D0 6F D5 96 7D 12 C5 2E 7E
16 : 37 : 19 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 19 <====Rx METER-2 D4 81 E6 20 00 00 01 55 E6 53 FC F5 64 9E C6 E6 02 17 2F E4 75 68 76 4D A5 1A D6 B5 FB 20 DE 70 88 9B F7 97 CD B3 95 AE
3D 5D EA 32 38 51 BE 74 66 8B E4 89 2C A2 EA 5E 8F 8A FB 2B 8B 2F 22 17 0E 46 9A 35 77 52 F4 DD 6F BF 39 C7 3A 84 E3 DA
DF 90 88 E8 72 6B 8B 7C F7 2E 71 B4 90 D6 B2 DD A5 A5 CB DA FA A4 76 D1 9C FA B6 EE 22 42 DB 80 A4 8B A7 C6 A2 FB 5A A0
E8 13 9E 7B 3A 97 F2 3B 1E 09 3E D0 6C D8 86 CF 23 AD 8D C8 5F 25 CA D8 91 60 7B BA 57 F7 D7 6C 54 FD 02 48 18 AA B9 D8
55 DC EA C7 CF 25 A4 A4 76 FD 3E 0D 19 84 B2 26 48 BA 7C 73 27 52 27 F5 16 09 C3 0C 6F 0D FE 40 B5 B9 96 50 DD 18 29 9B
D0 C6 AA 47 01 7C 12 1D 00 BA E8 EE 89 88 25 B4 5F 0A 32 1E DC F4 A1 B1 12 C0 61 D0 6F D5 96 7D 12
16 : 37 : 19 <====Rx METER-2 D4 81 E6 20 00 00 01 55 C4 02 81 00 00 00 00 01 00 81 D6 01 82 01 62 02 09 09 0C 07 E3 0B 0E 04 00 0F 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 00 1E 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 00 2D 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 01 00 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 01 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 01 1E 00 FF 01 4A 00 12 00 00 12
16 : 37 : 19 ====>Tx METER-2 D0 0C 20 00 00 01 55 C0 02 C1 00 00 00 01
16 : 37 : 19 ====>Tx METER-2 D0 0C 20 00 00 01 55 A9 83 02 7A 99 36 79
16 : 37 : 19 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 19 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 01 55 A9 83 02 7A 99 36 79 4C 6A 7E
16 : 37 : 19 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 01 56 56 94 9C 73 16 49 83 17 0A D8 46 16 9A 3F 56 27 0F 1E
55 81 81 F2 DE B5 E1 78 C4 3C D9 F0 DE E3 2B 27 99 D5 8A 5F CD B5 7B FC DC A3 B3 53 DE 8A 14 0E EB CA 09 0F 79 92 04 16
32 C1 22 37 9E A8 84 46 E9 EF 92 71 07 40 6A DE 33 62 0C D5 6B E8 24 CC 3C 11 62 D2 5A 37 26 86 6F CD EF 77 84 B9 E3 D1
9B 77 D0 0A EF 84 E1 65 9C 13 FC 5C 16 A5 31 E1 73 81 30 1B 8D 9F BE 75 17 D1 BF 47 63 20 13 F8 10 20 AA BD 29 0C C3 5F
EE CD 96 6B C6 AD 99 8D 06 D7 49 E7 4C B2 80 84 51 39 EB A4 65 EC 28 A1 B3 EE 56 06 C4 75 5A 0B B8 1F 4F A3 07 C4 34 E9
D2 7B B6 D3 84 CC 50 2C 13 C9 86 94 E0 BC D4 16 45 31 89 71 12 5C 19 5B 21 09 B8 58 92 D8 11 A4 84 D7 9D 45 50 E4 EF 28
DC 11 D6 2A BE FA E0 72 D6 7E
16 : 37 : 19 <====Rx METER-2 D4 81 E6 20 00 00 01 56 56 94 9C 73 16 49 83 17 0A D8 46 16 9A 3F 56 27 0F 1E 55 81 81 F2 DE B5 E1 78 C4 3C D9 F0 DE E3
2B 27 99 D5 8A 5F CD B5 7B FC DC A3 B3 53 DE 8A 14 0E EB CA 09 0F 79 92 04 16 32 C1 22 37 9E A8 84 46 E9 EF 92 71 07 40
6A DE 33 62 0C D5 6B E8 24 CC 3C 11 62 D2 5A 37 26 86 6F CD EF 77 84 B9 E3 D1 9B 77 D0 0A EF 84 E1 65 9C 13 FC 5C 16 A5
31 E1 73 81 30 1B 8D 9F BE 75 17 D1 BF 47 63 20 13 F8 10 20 AA BD 29 0C C3 5F EE CD 96 6B C6 AD 99 8D 06 D7 49 E7 4C B2
80 84 51 39 EB A4 65 EC 28 A1 B3 EE 56 06 C4 75 5A 0B B8 1F 4F A3 07 C4 34 E9 D2 7B B6 D3 84 CC 50 2C 13 C9 86 94 E0 BC
D4 16 45 31 89 71 12 5C 19 5B 21 09 B8 58 92 D8 11 A4 84 D7 9D 45 50 E4 EF 28 DC 11 D6 2A BE FA E0
16 : 37 : 19 <====Rx METER-2 D4 81 E6 20 00 00 01 56 C4 02 81 00 00 00 00 02 00 81 D6 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 0E 04 01 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 0E 04 02 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
0E 04 02 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04
02 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 02 2D
16 : 37 : 19 ====>Tx METER-2 D0 0C 20 00 00 01 56 C0 02 C1 00 00 00 02
16 : 37 : 19 ====>Tx METER-2 D0 0C 20 00 00 01 56 76 4C D8 70 A2 BD 05
16 : 37 : 19 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 01 56 76 4C D8 70 A2 BD 05 F6 26 7E
16 : 37 : 19 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 01 57 60 D1 C7 79 D1 01 4C 2F 38 46 60 E0 50 0E 3D 94 71 04
15 BD 69 2C AF 6F 0E E2 D5 EA 6E 65 2D 4B 57 F6 D5 B9 49 20 71 B1 95 3D F2 D9 75 95 EA 1C FA 95 C7 E4 1D F6 81 90 38 DD
42 FB B2 8C 54 96 C3 3C 05 29 AD DB 8B B2 3F 1B 06 7A 54 94 54 1F EF EB 74 0A 58 D5 7D 9E 3D 89 67 1A 20 90 EA 36 AD 35
6F 3B FF EE DD 7E 8F FF 3D 16 97 2E E8 64 02 71 D9 B7 F6 0C B6 4E 0A 1A 7A DA 53 B8 FD 37 A6 2C E3 AF ED D4 9E 99 2F 34
ED F5 80 01 35 83 EE 2A 99 1C E4 00 10 36 89 20 20 B4 74 CF 77 7D 9F 8B 24 B3 A5 E3 1B 21 96 2B 0D 94 8F 1C 5A A7 CE F6
1D A1 5F 4F DA 00 DF 15 39 E0 20 15 06 DD FC E8 6A 80 0D 50 52 B5 B8 EE 69 C3 D0 45 D5 EB 4C 0E 27 AC 46 CA D7 28 25 D4
FA 2E 72 32 14 39 07 BC C7 7E
16 : 37 : 19 <====Rx METER-2 D4 81 E6 20 00 00 01 57 60 D1 C7 79 D1 01 4C 2F 38 46 60 E0 50 0E 3D 94 71 04 15 BD 69 2C AF 6F 0E E2 D5 EA 6E 65 2D 4B
57 F6 D5 B9 49 20 71 B1 95 3D F2 D9 75 95 EA 1C FA 95 C7 E4 1D F6 81 90 38 DD 42 FB B2 8C 54 96 C3 3C 05 29 AD DB 8B B2
3F 1B 06 7A 54 94 54 1F EF EB 74 0A 58 D5 7D 9E 3D 89 67 1A 20 90 EA 36 AD 35 6F 3B FF EE DD 7E 8F FF 3D 16 97 2E E8 64
02 71 D9 B7 F6 0C B6 4E 0A 1A 7A DA 53 B8 FD 37 A6 2C E3 AF ED D4 9E 99 2F 34 ED F5 80 01 35 83 EE 2A 99 1C E4 00 10 36
89 20 20 B4 74 CF 77 7D 9F 8B 24 B3 A5 E3 1B 21 96 2B 0D 94 8F 1C 5A A7 CE F6 1D A1 5F 4F DA 00 DF 15 39 E0 20 15 06 DD
FC E8 6A 80 0D 50 52 B5 B8 EE 69 C3 D0 45 D5 EB 4C 0E 27 AC 46 CA D7 28 25 D4 FA 2E 72 32 14 39 07
16 : 37 : 19 <====Rx METER-2 D4 81 E6 20 00 00 01 57 C4 02 81 00 00 00 00 03 00 81 D6 0B 0E 04 03 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 03 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 03 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 03 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 04 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 0E 04 04 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
16 : 37 : 19 ====>Tx METER-2 D0 0C 20 00 00 01 57 C0 02 C1 00 00 00 03
16 : 37 : 19 ====>Tx METER-2 D0 0C 20 00 00 01 57 AE F4 03 4B 80 2C 3C
16 : 37 : 19 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 01 57 AE F4 03 4B 80 2C 3C 25 40 7E
16 : 37 : 19 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 01 58 CA 66 52 C3 FE CE 33 F7 8C DA 75 8F BC 6E 35 22 53 7D
25 35 AA 0F 2E 13 FA 4B 9A E4 67 EC 6A FD 8F 2D A8 D5 B7 C5 09 40 72 AF 80 D9 7B 30 3F 64 3A 38 36 16 4F 28 5C 62 06 0D
95 B0 97 FD 82 65 3B 29 43 A5 AA 43 56 E8 5D C0 4C 77 DD A9 CD D5 F8 41 D9 24 DE 1E A3 73 BE 91 4D BC 07 7E 8D DE 67 CF
04 6A 2D 34 47 81 C0 15 3C 09 DC 7E BB 3A B7 D1 CB B7 6A 7A 32 08 5B 4B 95 2D 6C 36 EB 56 4C C2 B7 05 59 FD A7 0D 40 D1
2A 18 47 A8 40 07 09 3B 07 4E C0 C5 8A 33 3B B7 64 B7 E4 FC B4 D1 02 E8 EC 52 F1 5E 8B 9B E0 B9 C0 8A 23 8E 5D B4 97 80
2D 57 F0 17 D1 3F EE 3A 02 29 D1 0B 56 5C C7 42 2C A0 F6 87 BC A2 7D 54 36 83 5F C6 A1 85 AA 5D 17 9D 94 B8 20 E2 D3 BF
97 C4 17 61 90 F5 FA BD 5F 7E
16 : 37 : 19 <====Rx METER-2 D4 81 E6 20 00 00 01 58 CA 66 52 C3 FE CE 33 F7 8C DA 75 8F BC 6E 35 22 53 7D 25 35 AA 0F 2E 13 FA 4B 9A E4 67 EC 6A FD
8F 2D A8 D5 B7 C5 09 40 72 AF 80 D9 7B 30 3F 64 3A 38 36 16 4F 28 5C 62 06 0D 95 B0 97 FD 82 65 3B 29 43 A5 AA 43 56 E8
5D C0 4C 77 DD A9 CD D5 F8 41 D9 24 DE 1E A3 73 BE 91 4D BC 07 7E 8D DE 67 CF 04 6A 2D 34 47 81 C0 15 3C 09 DC 7E BB 3A
B7 D1 CB B7 6A 7A 32 08 5B 4B 95 2D 6C 36 EB 56 4C C2 B7 05 59 FD A7 0D 40 D1 2A 18 47 A8 40 07 09 3B 07 4E C0 C5 8A 33
3B B7 64 B7 E4 FC B4 D1 02 E8 EC 52 F1 5E 8B 9B E0 B9 C0 8A 23 8E 5D B4 97 80 2D 57 F0 17 D1 3F EE 3A 02 29 D1 0B 56 5C
C7 42 2C A0 F6 87 BC A2 7D 54 36 83 5F C6 A1 85 AA 5D 17 9D 94 B8 20 E2 D3 BF 97 C4 17 61 90 F5 FA
16 : 37 : 19 <====Rx METER-2 D4 81 E6 20 00 00 01 58 C4 02 81 00 00 00 00 04 00 81 D6 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 04 1E 00 FF
01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 04 2D 00 FF 01 4A
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 05 00 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 05 0F 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 05 1E 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 05 2D 00 FF 01 4A 00
16 : 37 : 20 METER-2 COSEM OUT DATA
16 : 37 : 20 ====>Tx METER-2 D0 0C 20 00 00 01 58 C0 02 C1 00 00 00 04
16 : 37 : 20 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 20 ====>Tx METER-2 D0 0C 20 00 00 01 58 AF D5 BE E2 D2 90 22
16 : 37 : 20 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 20 METER-2 SENDING HDLC FRAME
16 : 37 : 20 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 01 58 AF D5 BE E2 D2 90 22 CD CA 7E
16 : 37 : 20 METER-2 RECEIVED HDLC FRAME
16 : 37 : 20 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 01 59 AA AB DA 77 6F 2B 81 52 58 D6 2E 40 E0 32 75 DF 1D E6
C0 22 FD C6 E0 08 09 C1 AA 97 78 33 CB 67 22 F2 E0 B7 81 50 9A 13 1D 3B AC 0E 35 4C 1D 72 FC 60 82 B8 AA B9 B2 68 4D 7E
DE 31 50 E3 39 5A B2 27 A6 0E 59 23 97 FD 3B 5F 6F 95 A4 19 99 3C 50 31 5E CC 1B 74 E9 F5 03 B0 08 F2 81 45 31 4E AC A0
EE BD A3 DA E9 DF 08 24 B3 25 D4 55 66 A5 95 CD C5 4D 9B 27 EF C8 7B 2E 3E A5 2D 3D EC 7E 10 6B 4A 56 8F 87 B7 38 BC 22
24 9A 75 23 51 BA 52 4E 16 BF 01 C7 BC 65 5A 9F B3 31 ED 70 51 23 B4 94 FA 09 EC D9 BE 80 C9 82 BC 6B C3 5F A6 13 95 07
AC 8C 1E AC 2D 54 1A 48 0C D6 3D 7C FD BB 72 A2 5B E8 CA 50 4F 9D 87 91 D9 71 DE D7 37 58 5A 1B 69 22 1D 57 0C B0 F1 98
3B 38 94 BB 8F 59 79 12 2A 7E
16 : 37 : 20 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 20 <====Rx METER-2 D4 81 E6 20 00 00 01 59 AA AB DA 77 6F 2B 81 52 58 D6 2E 40 E0 32 75 DF 1D E6 C0 22 FD C6 E0 08 09 C1 AA 97 78 33 CB 67
22 F2 E0 B7 81 50 9A 13 1D 3B AC 0E 35 4C 1D 72 FC 60 82 B8 AA B9 B2 68 4D 7E DE 31 50 E3 39 5A B2 27 A6 0E 59 23 97 FD
3B 5F 6F 95 A4 19 99 3C 50 31 5E CC 1B 74 E9 F5 03 B0 08 F2 81 45 31 4E AC A0 EE BD A3 DA E9 DF 08 24 B3 25 D4 55 66 A5
95 CD C5 4D 9B 27 EF C8 7B 2E 3E A5 2D 3D EC 7E 10 6B 4A 56 8F 87 B7 38 BC 22 24 9A 75 23 51 BA 52 4E 16 BF 01 C7 BC 65
5A 9F B3 31 ED 70 51 23 B4 94 FA 09 EC D9 BE 80 C9 82 BC 6B C3 5F A6 13 95 07 AC 8C 1E AC 2D 54 1A 48 0C D6 3D 7C FD BB
72 A2 5B E8 CA 50 4F 9D 87 91 D9 71 DE D7 37 58 5A 1B 69 22 1D 57 0C B0 F1 98 3B 38 94 BB 8F 59 79
16 : 37 : 20 <====Rx METER-2 D4 81 E6 20 00 00 01 59 C4 02 81 00 00 00 00 05 00 81 D6 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 0E 04 06 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 0E 04 06 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 0E 04 06 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 0E 04 06 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
0E 04 07 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
16 : 37 : 20 METER-2 SERVICE = GET RESPONSE
16 : 37 : 20 ====>Tx METER-2 D0 0C 20 00 00 01 59 C0 02 C1 00 00 00 05
16 : 37 : 20 ====>Tx METER-2 D0 0C 20 00 00 01 59 9D 3A B7 9C 54 7F CE
16 : 37 : 20 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 01 59 9D 3A B7 9C 54 7F CE 7C 2D 7E
16 : 37 : 20 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 01 5A 62 DC B3 C4 59 DE E9 68 7A D3 78 B0 8E 0D CF 7F F6 73
22 19 E7 C2 D4 0A F0 F5 FE 4C 45 5A 2F 1C D6 48 AB 40 C8 E5 0C 91 A2 A5 85 DA 86 03 A3 33 F4 D9 65 DE 17 C0 67 B0 1E C5
E3 D6 38 44 74 2E FC 26 17 74 E8 E0 66 D3 5C AD 17 E0 46 01 5F 6C 37 36 3D 5F 42 D9 FC 2A 90 0D 8E DA DA DF D5 EB A8 4A
A0 6A EB C2 4B 2F 33 01 41 ED 40 54 21 63 31 8F A2 16 86 70 A8 55 6B A6 5F 4A A6 09 09 A4 4F BA 03 C7 07 91 5D C9 9D EA
46 6D A9 69 13 C8 71 42 F4 52 3D 1E 3F 91 2D 4A B2 39 95 36 A8 07 FE 46 32 2C 8A DA 9F 1A AF F6 D5 4F 5D E8 F5 24 13 04
74 26 CE 4A 6C 29 47 A9 35 26 46 C9 88 8A 8B 6A 9D 4F DD FB E5 4B 4B 3C AB AE 5E 15 4A 1E 97 4E D6 B3 BC 12 70 25 CA 62
D9 A4 87 FB C2 7B 3E 1F 0E 7E
16 : 37 : 20 <====Rx METER-2 D4 81 E6 20 00 00 01 5A 62 DC B3 C4 59 DE E9 68 7A D3 78 B0 8E 0D CF 7F F6 73 22 19 E7 C2 D4 0A F0 F5 FE 4C 45 5A 2F 1C
D6 48 AB 40 C8 E5 0C 91 A2 A5 85 DA 86 03 A3 33 F4 D9 65 DE 17 C0 67 B0 1E C5 E3 D6 38 44 74 2E FC 26 17 74 E8 E0 66 D3
5C AD 17 E0 46 01 5F 6C 37 36 3D 5F 42 D9 FC 2A 90 0D 8E DA DA DF D5 EB A8 4A A0 6A EB C2 4B 2F 33 01 41 ED 40 54 21 63
31 8F A2 16 86 70 A8 55 6B A6 5F 4A A6 09 09 A4 4F BA 03 C7 07 91 5D C9 9D EA 46 6D A9 69 13 C8 71 42 F4 52 3D 1E 3F 91
2D 4A B2 39 95 36 A8 07 FE 46 32 2C 8A DA 9F 1A AF F6 D5 4F 5D E8 F5 24 13 04 74 26 CE 4A 6C 29 47 A9 35 26 46 C9 88 8A
8B 6A 9D 4F DD FB E5 4B 4B 3C AB AE 5E 15 4A 1E 97 4E D6 B3 BC 12 70 25 CA 62 D9 A4 87 FB C2 7B 3E
16 : 37 : 20 <====Rx METER-2 D4 81 E6 20 00 00 01 5A C4 02 81 00 00 00 00 06 00 81 D6 09 0C 07 E3 0B 0E 04 07 0F 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 07 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 07 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 08 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 08 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 08 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
16 : 37 : 20 ====>Tx METER-2 D0 0C 20 00 00 01 5A C0 02 C1 00 00 00 06
16 : 37 : 20 ====>Tx METER-2 D0 0C 20 00 00 01 5A 5D 8A FA D6 0C D3 60
16 : 37 : 20 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 01 5A 5D 8A FA D6 0C D3 60 80 5C 7E
16 : 37 : 20 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 01 5B A8 8F 8C 32 0E C3 AB BD 22 BF E2 05 05 20 60 F2 22 EA
34 BD C3 1A C7 75 DC AA 65 18 6D 3C C2 35 40 F7 71 26 E8 70 B2 70 CF 39 5B 01 FF 8D EF 29 08 62 06 57 CD 1E 90 18 EE 4F
69 D6 C4 5F 66 FE BB B5 A1 86 93 6F 6C DF 46 54 BD A4 09 63 CE 82 DD 5C 38 A0 E8 B0 D4 C1 27 D4 9A DD CD 85 67 95 F0 0F
A2 3A D7 76 E3 76 BB A0 C2 12 E3 CF BA FA 9A BC 95 B6 C8 04 C7 91 3D 5B 4A 6E 11 D5 2C 92 CE 4E 39 77 8C A0 34 C1 47 04
AA 57 C3 D5 35 4D 99 9E 1B AB 96 19 C9 87 CE D0 9D 5C D0 CF D7 2C 34 AE 45 09 72 9E 0E D2 FC A9 27 7A DC 14 E5 FE C9 72
70 27 F3 80 9B 05 76 98 69 01 71 5F 30 0B 27 95 37 46 1C 86 3D F7 B9 07 6D 1C B3 58 66 AB FD 40 10 42 D9 39 E9 C8 06 B9
5C 45 0C 0C A9 7C C9 EB C9 7E
16 : 37 : 20 <====Rx METER-2 D4 81 E6 20 00 00 01 5B A8 8F 8C 32 0E C3 AB BD 22 BF E2 05 05 20 60 F2 22 EA 34 BD C3 1A C7 75 DC AA 65 18 6D 3C C2 35
40 F7 71 26 E8 70 B2 70 CF 39 5B 01 FF 8D EF 29 08 62 06 57 CD 1E 90 18 EE 4F 69 D6 C4 5F 66 FE BB B5 A1 86 93 6F 6C DF
46 54 BD A4 09 63 CE 82 DD 5C 38 A0 E8 B0 D4 C1 27 D4 9A DD CD 85 67 95 F0 0F A2 3A D7 76 E3 76 BB A0 C2 12 E3 CF BA FA
9A BC 95 B6 C8 04 C7 91 3D 5B 4A 6E 11 D5 2C 92 CE 4E 39 77 8C A0 34 C1 47 04 AA 57 C3 D5 35 4D 99 9E 1B AB 96 19 C9 87
CE D0 9D 5C D0 CF D7 2C 34 AE 45 09 72 9E 0E D2 FC A9 27 7A DC 14 E5 FE C9 72 70 27 F3 80 9B 05 76 98 69 01 71 5F 30 0B
27 95 37 46 1C 86 3D F7 B9 07 6D 1C B3 58 66 AB FD 40 10 42 D9 39 E9 C8 06 B9 5C 45 0C 0C A9 7C C9
16 : 37 : 20 <====Rx METER-2 D4 81 E6 20 00 00 01 5B C4 02 81 00 00 00 00 07 00 81 D6 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04
08 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 09 00
00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 09 0F 00 FF
01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 09 1E 00 FF 01 4A
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 09 2D 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0A 00 00
16 : 37 : 20 ====>Tx METER-2 D0 0C 20 00 00 01 5B C0 02 C1 00 00 00 07
16 : 37 : 20 ====>Tx METER-2 D0 0C 20 00 00 01 5B EE 61 28 7D 0D 62 91
16 : 37 : 20 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 01 5B EE 61 28 7D 0D 62 91 CB 9E 7E
16 : 37 : 20 <====Rx METER-2 7E A0 F8 41 00 02 04 01 B8 2A CB E6 E7 00 D4 81 E6 20 00 00 01 5C A0 F2 53 77 8A 1C 26 F9 D5 02 F7 C8 20 FF 70 C0 10 8E
5E B6 2F 89 93 76 1D D7 65 9D 8C EC 1B 68 B6 66 26 04 D9 85 65 7D E4 1A FD 5F 97 59 4B 45 32 14 80 57 2E D7 C2 1E AF 2A
F3 47 4B 37 BB 0A CE 6D D6 B7 46 5D 98 74 C3 E7 C1 70 27 BF FE BF E3 15 6D 96 83 5E F5 DF E9 44 05 BA B4 51 D2 0B 16 83
20 DD 73 C1 9D 09 49 40 46 F4 22 8E E1 2F 11 FC A4 33 1F 45 51 2D C9 70 D3 D0 6E 0C 3D 3A BE 2F C1 83 F9 E9 06 DA 99 41
8E 54 A3 C0 0E D7 6B 72 AD CC 0F 59 2D A2 48 A5 EF D6 87 9C 11 D4 54 CA EC B5 7B 01 6F 85 70 60 B9 A5 53 73 D5 A8 4C 1D
E3 BC 47 4E 79 69 AA A3 E8 E1 79 3C E6 90 4F 96 A8 27 D3 F4 FA E6 B8 A5 A1 39 AC 5D D8 D5 2C 98 0F EE AE 40 9F B1 73 CE
69 8B B9 D9 CB 63 AA 44 26 7E
16 : 37 : 20 <====Rx METER-2 D4 81 E6 20 00 00 01 5C A0 F2 53 77 8A 1C 26 F9 D5 02 F7 C8 20 FF 70 C0 10 8E 5E B6 2F 89 93 76 1D D7 65 9D 8C EC 1B 68
B6 66 26 04 D9 85 65 7D E4 1A FD 5F 97 59 4B 45 32 14 80 57 2E D7 C2 1E AF 2A F3 47 4B 37 BB 0A CE 6D D6 B7 46 5D 98 74
C3 E7 C1 70 27 BF FE BF E3 15 6D 96 83 5E F5 DF E9 44 05 BA B4 51 D2 0B 16 83 20 DD 73 C1 9D 09 49 40 46 F4 22 8E E1 2F
11 FC A4 33 1F 45 51 2D C9 70 D3 D0 6E 0C 3D 3A BE 2F C1 83 F9 E9 06 DA 99 41 8E 54 A3 C0 0E D7 6B 72 AD CC 0F 59 2D A2
48 A5 EF D6 87 9C 11 D4 54 CA EC B5 7B 01 6F 85 70 60 B9 A5 53 73 D5 A8 4C 1D E3 BC 47 4E 79 69 AA A3 E8 E1 79 3C E6 90
4F 96 A8 27 D3 F4 FA E6 B8 A5 A1 39 AC 5D D8 D5 2C 98 0F EE AE 40 9F B1 73 CE 69 8B B9 D9 CB 63 AA
16 : 37 : 20 <====Rx METER-2 D4 81 E6 20 00 00 01 5C C4 02 81 00 00 00 00 08 00 81 D6 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0A 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 0E 04 0A 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 0E 04 0A 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 0E 04 0B 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 0E 04 0B 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
16 : 37 : 20 ====>Tx METER-2 D0 0C 20 00 00 01 5C C0 02 C1 00 00 00 08
16 : 37 : 20 ====>Tx METER-2 D0 0C 20 00 00 01 5C E3 EE AB 9F 16 9A CB
16 : 37 : 21 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 21 METER-2 SENDING HDLC FRAME
16 : 37 : 21 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 BA 30 1E E6 E6 00 D0 0C 20 00 00 01 5C E3 EE AB 9F 16 9A CB E0 ED 7E
16 : 37 : 21 METER-2 RECEIVED HDLC FRAME
16 : 37 : 21 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 01 5D 6C 1B 83 23 86 04 22 01 20 00 C0 0C 94 4D CE 3B D0 10
FA 0F 2E 23 31 60 32 58 D8 8A 4D 99 70 68 03 B7 65 B6 8B 10 29 9C 91 CC 17 87 B9 42 47 DC C8 5D 58 E4 14 02 91 B1 37 47
42 7E 10 C1 26 DB 2D 9E 62 62 39 9B BE F0 3C 05 5A 99 89 90 91 FC F8 DF 5B BE D9 A1 7E 20 1D 11 35 8E C5 95 4B 78 F2 FC
6B 1F AB CE 82 1E D3 E8 0A A9 72 18 AC E9 31 C7 A8 FE 1B 9C 59 22 81 30 A2 19 02 FC 6D 7A C5 61 6F A0 E7 2C 8A C4 DF 0E
68 95 D6 78 82 70 23 B2 1F E1 F0 39 BB 97 95 AA E2 E7 00 D9 A7 D2 52 56 10 B4 7B 11 C4 1A 7B AC F4 79 C6 5B 56 D9 AA 51
07 20 2B A1 B6 54 77 F0 75 A4 65 A2 1F F4 E2 FC A4 E6 E3 53 C2 0D AF 77 C3 21 EE 0D 02 D7 53 FA 47 BE 6C DB 8C 71 D5 68
CB 4A E3 75 4F F6 8D 04 D9 7E
16 : 37 : 21 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 21 <====Rx METER-2 D4 81 E6 20 00 00 01 5D 6C 1B 83 23 86 04 22 01 20 00 C0 0C 94 4D CE 3B D0 10 FA 0F 2E 23 31 60 32 58 D8 8A 4D 99 70 68
03 B7 65 B6 8B 10 29 9C 91 CC 17 87 B9 42 47 DC C8 5D 58 E4 14 02 91 B1 37 47 42 7E 10 C1 26 DB 2D 9E 62 62 39 9B BE F0
3C 05 5A 99 89 90 91 FC F8 DF 5B BE D9 A1 7E 20 1D 11 35 8E C5 95 4B 78 F2 FC 6B 1F AB CE 82 1E D3 E8 0A A9 72 18 AC E9
31 C7 A8 FE 1B 9C 59 22 81 30 A2 19 02 FC 6D 7A C5 61 6F A0 E7 2C 8A C4 DF 0E 68 95 D6 78 82 70 23 B2 1F E1 F0 39 BB 97
95 AA E2 E7 00 D9 A7 D2 52 56 10 B4 7B 11 C4 1A 7B AC F4 79 C6 5B 56 D9 AA 51 07 20 2B A1 B6 54 77 F0 75 A4 65 A2 1F F4
E2 FC A4 E6 E3 53 C2 0D AF 77 C3 21 EE 0D 02 D7 53 FA 47 BE 6C DB 8C 71 D5 68 CB 4A E3 75 4F F6 8D
16 : 37 : 21 <====Rx METER-2 D4 81 E6 20 00 00 01 5D C4 02 81 00 00 00 00 09 00 81 D6 11 00 02 09 09 0C 07 E3 0B 0E 04 0B 1E 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0B 2D 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0C 00 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0C 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0C 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0C 2D 00 FF 01 4A 00 12 00 00 12 00 00
16 : 37 : 21 METER-2 SERVICE = GET RESPONSE
16 : 37 : 21 METER-2 COSEM OUT DATA
16 : 37 : 21 ====>Tx METER-2 D0 0C 20 00 00 01 5D C0 02 C1 00 00 00 09
16 : 37 : 21 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 21 ====>Tx METER-2 D0 0C 20 00 00 01 5D 36 AE E2 74 81 BB 00
16 : 37 : 21 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 01 5D 36 AE E2 74 81 BB 00 6E C9 7E
16 : 37 : 21 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 01 5E 3C 17 B1 D8 76 F3 78 A2 38 FA A2 78 3C C8 E9 AA 82 98
F0 18 9E DD 46 F6 46 5D E7 6C 47 53 35 09 3B 19 C3 8B 00 15 EB D7 33 D0 AB B8 CE 1A 5F D1 E5 2D B5 ED 49 A5 01 9B 63 80
47 EC 63 44 F0 FD 91 4D BE 74 98 01 49 1D E0 43 9C E5 5B A3 34 A9 62 68 F2 BD 7F 1F D4 0F 6E A3 A4 F8 48 8B 0F 60 0B C4
57 24 9B 05 59 FC 6F E0 C5 8E 08 0C 03 57 C2 48 33 BE 26 2B 7A 4B C8 E1 57 25 7F 62 0D D3 84 A1 0A E4 D2 37 55 E3 D0 BE
24 0D A6 77 3E E1 49 AE F4 B0 2E A2 36 E3 19 B6 41 59 72 88 DE 89 40 CB 41 19 3D 38 7C 88 02 0A 46 A2 68 D8 79 FB D4 AE
D6 96 13 6B FA 58 80 18 9D 8C 9F E7 16 B5 B9 20 06 8F 91 F0 04 EA 2A 64 FB 34 E4 31 EF 1E 8C 21 F5 69 2F D3 C0 E4 29 F1
06 FE 2F BC EC 8C BB 2A FB 7E
16 : 37 : 21 <====Rx METER-2 D4 81 E6 20 00 00 01 5E 3C 17 B1 D8 76 F3 78 A2 38 FA A2 78 3C C8 E9 AA 82 98 F0 18 9E DD 46 F6 46 5D E7 6C 47 53 35 09
3B 19 C3 8B 00 15 EB D7 33 D0 AB B8 CE 1A 5F D1 E5 2D B5 ED 49 A5 01 9B 63 80 47 EC 63 44 F0 FD 91 4D BE 74 98 01 49 1D
E0 43 9C E5 5B A3 34 A9 62 68 F2 BD 7F 1F D4 0F 6E A3 A4 F8 48 8B 0F 60 0B C4 57 24 9B 05 59 FC 6F E0 C5 8E 08 0C 03 57
C2 48 33 BE 26 2B 7A 4B C8 E1 57 25 7F 62 0D D3 84 A1 0A E4 D2 37 55 E3 D0 BE 24 0D A6 77 3E E1 49 AE F4 B0 2E A2 36 E3
19 B6 41 59 72 88 DE 89 40 CB 41 19 3D 38 7C 88 02 0A 46 A2 68 D8 79 FB D4 AE D6 96 13 6B FA 58 80 18 9D 8C 9F E7 16 B5
B9 20 06 8F 91 F0 04 EA 2A 64 FB 34 E4 31 EF 1E 8C 21 F5 69 2F D3 C0 E4 29 F1 06 FE 2F BC EC 8C BB
16 : 37 : 21 <====Rx METER-2 D4 81 E6 20 00 00 01 5E C4 02 81 00 00 00 00 0A 00 81 D6 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 0E 04 0D 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
0E 04 0D 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04
0D 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0D 2D
00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0E 00 00 FF
16 : 37 : 21 ====>Tx METER-2 D0 0C 20 00 00 01 5E C0 02 C1 00 00 00 0A
16 : 37 : 21 ====>Tx METER-2 D0 0C 20 00 00 01 5E A8 D5 5C C5 C5 14 F2
16 : 37 : 21 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 01 5E A8 D5 5C C5 C5 14 F2 C9 C1 7E
16 : 37 : 21 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 01 5F 94 39 4E 51 B2 B0 2D 92 AB A4 8A 05 A0 50 80 70 C1 2D
9B E3 AE 24 36 EC E1 61 72 DA F2 CB EE 70 4E 7C 20 21 78 50 39 A4 4A A7 1F 5E 9A 2B E0 96 C3 75 F7 F1 CC 07 28 60 5C AA
1F CF 00 D9 28 E4 39 14 68 DF 79 DC 0C F2 5E 70 28 56 88 29 D1 07 22 EF E3 3E 87 C9 7E 5D 62 BE 9F A4 23 15 94 8D 29 07
8D B6 7E 82 21 C5 7E 26 E4 C0 24 EF A8 9B 0F 86 50 0D D4 ED 5E 9B E0 0E 07 22 A4 A8 B3 9F DE 7E 6C 8E F9 10 E8 8A 68 EB
87 24 4A 8A 65 A3 A1 95 D1 3E 2B 40 DA 3B 1C 9F 37 D4 D7 4B 67 CC 8E 65 EA 1B DD FB E2 85 C9 69 E9 94 49 46 2F 5C DA AB
E9 4B 45 9D 8E 7C 54 BB EE 30 A9 49 56 48 12 91 23 81 9D E2 8D 7B 20 43 FD 5D B1 70 98 A4 54 DD 47 42 B1 F9 EE 15 74 99
63 E7 34 B2 FE B0 68 6E 9F 7E
16 : 37 : 21 <====Rx METER-2 D4 81 E6 20 00 00 01 5F 94 39 4E 51 B2 B0 2D 92 AB A4 8A 05 A0 50 80 70 C1 2D 9B E3 AE 24 36 EC E1 61 72 DA F2 CB EE 70
4E 7C 20 21 78 50 39 A4 4A A7 1F 5E 9A 2B E0 96 C3 75 F7 F1 CC 07 28 60 5C AA 1F CF 00 D9 28 E4 39 14 68 DF 79 DC 0C F2
5E 70 28 56 88 29 D1 07 22 EF E3 3E 87 C9 7E 5D 62 BE 9F A4 23 15 94 8D 29 07 8D B6 7E 82 21 C5 7E 26 E4 C0 24 EF A8 9B
0F 86 50 0D D4 ED 5E 9B E0 0E 07 22 A4 A8 B3 9F DE 7E 6C 8E F9 10 E8 8A 68 EB 87 24 4A 8A 65 A3 A1 95 D1 3E 2B 40 DA 3B
1C 9F 37 D4 D7 4B 67 CC 8E 65 EA 1B DD FB E2 85 C9 69 E9 94 49 46 2F 5C DA AB E9 4B 45 9D 8E 7C 54 BB EE 30 A9 49 56 48
12 91 23 81 9D E2 8D 7B 20 43 FD 5D B1 70 98 A4 54 DD 47 42 B1 F9 EE 15 74 99 63 E7 34 B2 FE B0 68
16 : 37 : 21 <====Rx METER-2 D4 81 E6 20 00 00 01 5F C4 02 81 00 00 00 00 0B 00 81 D6 04 0E 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0E 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0E 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0F 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 0E 04 0F 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 0E 04 0F 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
16 : 37 : 21 ====>Tx METER-2 D0 0C 20 00 00 01 5F C0 02 C1 00 00 00 0B
16 : 37 : 21 ====>Tx METER-2 D0 0C 20 00 00 01 5F FF FE D1 A9 A0 98 B7
16 : 37 : 21 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 01 5F FF FE D1 A9 A0 98 B7 20 A9 7E
16 : 37 : 21 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 01 60 26 DA E5 59 3B 0F 95 1C 53 81 A4 AF C8 8A 48 1C BB 5D
42 2E 72 24 4A 47 93 76 0B 6B 4F 59 7C A9 AE 29 38 2E C4 A6 DA F7 7C 91 E7 20 DD 6D 77 65 AA 5F 2E AB 76 3E 9B FB 49 86
94 70 76 A0 BE 4F 2A D9 03 1C FE 4C 0E C0 60 C1 1D 22 FE 55 93 54 8C 2B DE 43 76 BC 38 00 C9 8D DF 79 C5 FE 86 B4 BD A8
F3 8A FE A2 26 23 02 9E 4C C4 ED 56 5B B5 F6 17 22 43 05 F5 E9 A8 CE 63 4E BD 66 9A A4 C3 70 44 05 F1 29 07 1A 5A 60 4A
9A B3 6B 7D F8 12 95 DF F5 64 A4 5D 0E 8F B9 90 70 01 5D 3E 2D B3 39 A5 47 5F 47 25 90 4D CA F6 F9 EE C0 08 30 E4 92 5E
D0 06 F7 8B 85 62 F1 45 EA 93 12 AA EE F2 7B 88 7F 67 CD 30 69 CA F4 50 D2 32 91 B5 19 8E 40 B3 78 AD 0E 8A 8E A1 CF A5
D7 A2 5E 85 38 F5 80 D7 81 7E
16 : 37 : 21 <====Rx METER-2 D4 81 E6 20 00 00 01 60 26 DA E5 59 3B 0F 95 1C 53 81 A4 AF C8 8A 48 1C BB 5D 42 2E 72 24 4A 47 93 76 0B 6B 4F 59 7C A9
AE 29 38 2E C4 A6 DA F7 7C 91 E7 20 DD 6D 77 65 AA 5F 2E AB 76 3E 9B FB 49 86 94 70 76 A0 BE 4F 2A D9 03 1C FE 4C 0E C0
60 C1 1D 22 FE 55 93 54 8C 2B DE 43 76 BC 38 00 C9 8D DF 79 C5 FE 86 B4 BD A8 F3 8A FE A2 26 23 02 9E 4C C4 ED 56 5B B5
F6 17 22 43 05 F5 E9 A8 CE 63 4E BD 66 9A A4 C3 70 44 05 F1 29 07 1A 5A 60 4A 9A B3 6B 7D F8 12 95 DF F5 64 A4 5D 0E 8F
B9 90 70 01 5D 3E 2D B3 39 A5 47 5F 47 25 90 4D CA F6 F9 EE C0 08 30 E4 92 5E D0 06 F7 8B 85 62 F1 45 EA 93 12 AA EE F2
7B 88 7F 67 CD 30 69 CA F4 50 D2 32 91 B5 19 8E 40 B3 78 AD 0E 8A 8E A1 CF A5 D7 A2 5E 85 38 F5 80
16 : 37 : 21 <====Rx METER-2 D4 81 E6 20 00 00 01 60 C4 02 81 00 00 00 00 0C 00 81 D6 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0F 2D 00 FF 01 4A
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 10 00 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 10 0F 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 10 1E 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 10 2D 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 11 00 00 FF 01 4A 00 12 00
16 : 37 : 21 ====>Tx METER-2 D0 0C 20 00 00 01 60 C0 02 C1 00 00 00 0C
16 : 37 : 21 ====>Tx METER-2 D0 0C 20 00 00 01 60 13 CE 55 69 C8 A6 4C
16 : 37 : 21 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 01 60 13 CE 55 69 C8 A6 4C 35 9B 7E
16 : 37 : 22 METER-2 RECEIVED HDLC FRAME
16 : 37 : 22 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 01 61 DA 2C 02 29 7C 7A 08 FA D5 6B 20 E1 36 57 BB 09 76 65
0F 95 ED 3A B4 1F C8 30 AD C9 B6 EF 6A DB D6 9B 93 68 40 24 78 6B 2F D9 2D B4 2C C4 8F 18 E3 B7 A2 65 DD E3 E8 84 0C E4
A0 1C E2 78 84 B7 2F 42 83 02 40 26 0E 52 1B 8B 3C A5 10 27 69 28 B5 B4 40 AE AB AE A4 AF 4B 9F 59 49 94 CC 11 1E 15 D6
98 0E 8C 39 E3 AB 01 78 30 62 1B D1 65 F8 19 80 5A 52 42 8E 2F D9 F7 EA 2C D2 D3 CB 76 E2 09 30 AE 4A 85 EE 6E 4C D0 40
4D AE 86 C4 81 01 9C 96 00 61 0F 93 2D 53 BB FB FF F6 39 87 1C B7 74 F9 BE 79 0C 61 78 EF 72 41 25 02 14 34 78 59 DF 63
87 ED C9 56 4E 2B C7 14 98 60 54 F5 97 03 93 B3 EB 96 66 BC 50 AB 78 27 90 8B 4E F4 7B F1 39 9E 3A 3C C5 F1 30 6F 45 64
02 95 CE F0 0C 50 95 80 00 7E
16 : 37 : 22 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 22 <====Rx METER-2 D4 81 E6 20 00 00 01 61 DA 2C 02 29 7C 7A 08 FA D5 6B 20 E1 36 57 BB 09 76 65 0F 95 ED 3A B4 1F C8 30 AD C9 B6 EF 6A DB
D6 9B 93 68 40 24 78 6B 2F D9 2D B4 2C C4 8F 18 E3 B7 A2 65 DD E3 E8 84 0C E4 A0 1C E2 78 84 B7 2F 42 83 02 40 26 0E 52
1B 8B 3C A5 10 27 69 28 B5 B4 40 AE AB AE A4 AF 4B 9F 59 49 94 CC 11 1E 15 D6 98 0E 8C 39 E3 AB 01 78 30 62 1B D1 65 F8
19 80 5A 52 42 8E 2F D9 F7 EA 2C D2 D3 CB 76 E2 09 30 AE 4A 85 EE 6E 4C D0 40 4D AE 86 C4 81 01 9C 96 00 61 0F 93 2D 53
BB FB FF F6 39 87 1C B7 74 F9 BE 79 0C 61 78 EF 72 41 25 02 14 34 78 59 DF 63 87 ED C9 56 4E 2B C7 14 98 60 54 F5 97 03
93 B3 EB 96 66 BC 50 AB 78 27 90 8B 4E F4 7B F1 39 9E 3A 3C C5 F1 30 6F 45 64 02 95 CE F0 0C 50 95
16 : 37 : 22 <====Rx METER-2 D4 81 E6 20 00 00 01 61 C4 02 81 00 00 00 00 0D 00 81 D6 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 0E 04 11 0F 00 FF 01 4A 00 12 48 1F 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 0D 02 09 09
0C 07 E3 0B 0E 04 11 1E 00 FF 01 4A 00 12 56 CF 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 0F 02 09 09 0C 07
E3 0B 0E 04 11 2D 00 FF 01 4A 00 12 5F 56 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 10 02 09 09 0C 07 E3 0B
0E 04 12 00 00 FF 01 4A 00 12 24 C9 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 06 02 09 09 0C 07 E3 0B 0E 04
12 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
16 : 37 : 22 METER-2 SERVICE = GET RESPONSE
16 : 37 : 22 METER-2 COSEM OUT DATA
16 : 37 : 22 ====>Tx METER-2 D0 0C 20 00 00 01 61 C0 02 C1 00 00 00 0D
16 : 37 : 22 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 22 ====>Tx METER-2 D0 0C 20 00 00 01 61 C0 7D 9B 3F 0D E5 83
16 : 37 : 22 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 22 METER-2 SENDING HDLC FRAME
16 : 37 : 22 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 01 61 C0 7D 9B 3F 0D E5 83 A8 5D 7E
16 : 37 : 22 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 01 62 EE 43 80 68 D8 88 26 46 93 CA 0F AD 43 73 4D 9E 5F D9
16 C9 9B FD E8 4D DA E0 FE C2 48 C9 53 F4 25 68 3C BD 15 AC C9 A1 58 01 74 01 9A D9 7A 58 C3 EB 12 B0 F1 23 C5 7F CB 4F
B3 5C 5B 2E E4 CE FC 0F 2D 60 3F F2 CC 66 5E 6D F3 58 69 6C 0F 92 C9 35 01 FD 63 07 6E 64 D2 9A D5 A1 3D AC 89 CC DF 8D
47 FA 9C 7C 25 18 05 D6 C8 73 F7 D9 D6 5C 69 4C 03 8B F7 D6 B2 43 70 E4 42 F6 72 6E 06 79 15 46 13 A1 86 50 48 8B FB 1A
C0 FC 6B E5 07 B3 56 50 9A C7 30 B0 87 6E 12 02 CF DB 6D 26 CF CE 52 F4 9F C8 8A 00 D5 A2 A5 4D F8 EE 18 75 63 A7 D4 15
49 F7 4D C4 FB 65 C1 9C 33 83 19 3D 5A 0E 85 BE 82 30 99 55 F0 46 C7 C1 FC 0B E2 AF E5 7C 47 71 99 20 69 0B 96 EC 2E 4E
CE C0 31 5A E4 73 7E 4E 35 7E
16 : 37 : 22 <====Rx METER-2 D4 81 E6 20 00 00 01 62 EE 43 80 68 D8 88 26 46 93 CA 0F AD 43 73 4D 9E 5F D9 16 C9 9B FD E8 4D DA E0 FE C2 48 C9 53 F4
25 68 3C BD 15 AC C9 A1 58 01 74 01 9A D9 7A 58 C3 EB 12 B0 F1 23 C5 7F CB 4F B3 5C 5B 2E E4 CE FC 0F 2D 60 3F F2 CC 66
5E 6D F3 58 69 6C 0F 92 C9 35 01 FD 63 07 6E 64 D2 9A D5 A1 3D AC 89 CC DF 8D 47 FA 9C 7C 25 18 05 D6 C8 73 F7 D9 D6 5C
69 4C 03 8B F7 D6 B2 43 70 E4 42 F6 72 6E 06 79 15 46 13 A1 86 50 48 8B FB 1A C0 FC 6B E5 07 B3 56 50 9A C7 30 B0 87 6E
12 02 CF DB 6D 26 CF CE 52 F4 9F C8 8A 00 D5 A2 A5 4D F8 EE 18 75 63 A7 D4 15 49 F7 4D C4 FB 65 C1 9C 33 83 19 3D 5A 0E
85 BE 82 30 99 55 F0 46 C7 C1 FC 0B E2 AF E5 7C 47 71 99 20 69 0B 96 EC 2E 4E CE C0 31 5A E4 73 7E
16 : 37 : 22 <====Rx METER-2 D4 81 E6 20 00 00 01 62 C4 02 81 00 00 00 00 0E 00 81 D6 07 E3 0B 0E 04 12 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 12 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 13 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 13 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 13 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 13 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
16 : 37 : 22 ====>Tx METER-2 D0 0C 20 00 00 01 62 C0 02 C1 00 00 00 0E
16 : 37 : 22 ====>Tx METER-2 D0 0C 20 00 00 01 62 D4 C3 27 6C 5D 88 BA
16 : 37 : 22 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 01 62 D4 C3 27 6C 5D 88 BA F4 D5 7E
16 : 37 : 22 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 01 63 52 C4 D4 13 37 59 35 84 96 D9 BA FA D2 F6 C6 EC 9D B1
33 6D 7A CA 67 B6 28 8D 8D FE 4A EA 5B F1 42 2C 2C A6 09 0C B1 E5 72 DA C4 A4 AF 05 1E 8E 24 B6 C2 9D 31 BB 95 A1 3D 92
B0 D8 D4 F7 1A F0 6A 73 B1 1F DF 83 24 E0 34 5B 0F 39 3C BA E0 CE BD 8E A4 B3 53 46 99 15 72 C4 51 C7 D7 77 A4 40 F0 28
5A 82 9E AB 11 62 63 69 CC A1 D6 19 1A 0B E9 62 A1 B0 9E 8D D3 89 CE 44 5B BE 06 F7 DC 37 3B D2 BC EB 1D B3 01 AE 17 B9
9C 98 E4 16 52 FB E4 23 83 0E BE CB D2 79 D1 8E FC FF 74 CD EA FA 7B 28 A1 89 27 98 C1 EB 7B 3C 71 77 E1 2C 31 50 DB 53
DF 32 1C 18 2F 90 9A 3A 03 E0 B1 62 62 3C B8 7B D2 34 55 C7 A0 A1 D8 99 B6 3E 83 A3 02 DC 03 86 83 7E FC DF 13 DF 63 6F
36 97 FD 48 93 BA C2 CF 51 7E
16 : 37 : 22 <====Rx METER-2 D4 81 E6 20 00 00 01 63 52 C4 D4 13 37 59 35 84 96 D9 BA FA D2 F6 C6 EC 9D B1 33 6D 7A CA 67 B6 28 8D 8D FE 4A EA 5B F1
42 2C 2C A6 09 0C B1 E5 72 DA C4 A4 AF 05 1E 8E 24 B6 C2 9D 31 BB 95 A1 3D 92 B0 D8 D4 F7 1A F0 6A 73 B1 1F DF 83 24 E0
34 5B 0F 39 3C BA E0 CE BD 8E A4 B3 53 46 99 15 72 C4 51 C7 D7 77 A4 40 F0 28 5A 82 9E AB 11 62 63 69 CC A1 D6 19 1A 0B
E9 62 A1 B0 9E 8D D3 89 CE 44 5B BE 06 F7 DC 37 3B D2 BC EB 1D B3 01 AE 17 B9 9C 98 E4 16 52 FB E4 23 83 0E BE CB D2 79
D1 8E FC FF 74 CD EA FA 7B 28 A1 89 27 98 C1 EB 7B 3C 71 77 E1 2C 31 50 DB 53 DF 32 1C 18 2F 90 9A 3A 03 E0 B1 62 62 3C
B8 7B D2 34 55 C7 A0 A1 D8 99 B6 3E 83 A3 02 DC 03 86 83 7E FC DF 13 DF 63 6F 36 97 FD 48 93 BA C2
16 : 37 : 22 <====Rx METER-2 D4 81 E6 20 00 00 01 63 C4 02 81 00 00 00 00 0F 00 81 D6 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 14 00
00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 14 0F 00 FF
01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 14 1E 00 FF 01 4A
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 14 2D 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 15 00 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 15 0F 00 FF 01
16 : 37 : 22 ====>Tx METER-2 D0 0C 20 00 00 01 63 C0 02 C1 00 00 00 0F
16 : 37 : 22 ====>Tx METER-2 D0 0C 20 00 00 01 63 C8 D8 34 12 E7 45 2B
16 : 37 : 22 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 01 63 C8 D8 34 12 E7 45 2B EC 64 7E
16 : 37 : 22 <====Rx METER-2 7E A0 F8 41 00 02 04 01 B8 2A CB E6 E7 00 D4 81 E6 20 00 00 01 64 25 41 8E 90 85 3C 99 F4 50 0F 53 74 62 1D 93 A0 26 95
AF 5D 40 68 7D 6B 5A 72 B8 90 DC C6 C1 46 24 A3 A4 1D DD DD 3B D5 A5 8B A4 0C F1 59 5E ED 3A 8D 42 91 AC 22 1A 7E 95 7D
7E 1C FF 64 18 22 AB F4 4B 68 41 C8 42 89 EA 9C 7E CF 22 C4 D7 61 1D 02 FE E3 6A 63 44 99 63 0B 52 4C 21 FB BE 08 E8 D1
91 C2 1F 3A E6 83 03 5B BF 90 21 5F DC 8F F7 16 7B FE E0 F2 54 98 97 45 AB 06 AD E3 4E 0C F4 CE 60 FA 52 94 44 DD BD D8
7B 44 E5 95 5A 2C 5F 5B 08 BD D9 48 77 B9 69 AE 8A 2C 8E 4B 83 C7 4F F0 A0 CD 15 3C 0B 9D 1F 23 5E D1 9C DD 17 8B 02 D1
8D 61 3C 2B 19 45 E3 84 10 40 D2 05 2C 9D 0A F5 73 1E E4 66 19 AC 2B E5 ED 7A E4 0B 53 DC 6C D8 CD E8 CA A6 48 FC 8A AA
F3 3F 7B E5 F8 50 E9 45 AA 7E
16 : 37 : 22 <====Rx METER-2 D4 81 E6 20 00 00 01 64 25 41 8E 90 85 3C 99 F4 50 0F 53 74 62 1D 93 A0 26 95 AF 5D 40 68 7D 6B 5A 72 B8 90 DC C6 C1 46
24 A3 A4 1D DD DD 3B D5 A5 8B A4 0C F1 59 5E ED 3A 8D 42 91 AC 22 1A 7E 95 7D 7E 1C FF 64 18 22 AB F4 4B 68 41 C8 42 89
EA 9C 7E CF 22 C4 D7 61 1D 02 FE E3 6A 63 44 99 63 0B 52 4C 21 FB BE 08 E8 D1 91 C2 1F 3A E6 83 03 5B BF 90 21 5F DC 8F
F7 16 7B FE E0 F2 54 98 97 45 AB 06 AD E3 4E 0C F4 CE 60 FA 52 94 44 DD BD D8 7B 44 E5 95 5A 2C 5F 5B 08 BD D9 48 77 B9
69 AE 8A 2C 8E 4B 83 C7 4F F0 A0 CD 15 3C 0B 9D 1F 23 5E D1 9C DD 17 8B 02 D1 8D 61 3C 2B 19 45 E3 84 10 40 D2 05 2C 9D
0A F5 73 1E E4 66 19 AC 2B E5 ED 7A E4 0B 53 DC 6C D8 CD E8 CA A6 48 FC 8A AA F3 3F 7B E5 F8 50 E9
16 : 37 : 22 <====Rx METER-2 D4 81 E6 20 00 00 01 64 C4 02 81 00 00 00 00 10 00 81 D6 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 0E 04 15 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 0E 04 15 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 0E 04 16 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 0E 04 16 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 0E 04 16 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
16 : 37 : 22 ====>Tx METER-2 D0 0C 20 00 00 01 64 C0 02 C1 00 00 00 10
16 : 37 : 22 ====>Tx METER-2 D0 0C 20 00 00 01 64 99 21 DD 1D 96 E1 89
16 : 37 : 22 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 BA 30 1E E6 E6 00 D0 0C 20 00 00 01 64 99 21 DD 1D 96 E1 89 D0 AC 7E
16 : 37 : 22 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 01 65 6D 3E A8 39 6D D7 F1 43 CD 0E FF A9 95 9C 46 02 42 56
9A A3 8C 07 07 13 5D 34 F2 59 8B E5 9D 5E 71 B3 33 FC F4 DC 7E 82 BD 56 B0 DB AC 5D 71 55 5E 2F D8 A1 C2 BA AC E7 95 0E
E5 13 7F B0 05 99 08 AC 62 C5 72 4F AC C6 67 3E 26 BF 3F 0E E7 C0 DA 27 52 95 14 D2 4A E4 6C CD C8 8D D9 6B 44 2A E7 D5
0D 9C A2 55 C7 0E C9 AD 25 29 C5 2F 77 AA B4 CE 18 62 DA 47 34 67 46 5F F7 17 D5 25 68 D6 68 EC 4C BA 32 F6 CB 68 21 83
B7 88 6E 8E EB 1F B5 47 21 0D 80 58 DB 9A 3D 0B 24 04 29 57 05 2B 86 E6 C2 19 7F C6 82 97 74 C3 4D C4 D7 5B 7B 74 3B 57
2E EE 7A A7 D4 79 79 CD FC F4 53 95 97 AF 9C 6F F9 53 CC 60 8E B1 20 BA 94 90 C5 E0 72 97 9F 79 5E 86 BF 2B BC 80 37 4B
D2 95 0D C2 74 77 7C 94 38 7E
16 : 37 : 23 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 23 <====Rx METER-2 D4 81 E6 20 00 00 01 65 6D 3E A8 39 6D D7 F1 43 CD 0E FF A9 95 9C 46 02 42 56 9A A3 8C 07 07 13 5D 34 F2 59 8B E5 9D 5E
71 B3 33 FC F4 DC 7E 82 BD 56 B0 DB AC 5D 71 55 5E 2F D8 A1 C2 BA AC E7 95 0E E5 13 7F B0 05 99 08 AC 62 C5 72 4F AC C6
67 3E 26 BF 3F 0E E7 C0 DA 27 52 95 14 D2 4A E4 6C CD C8 8D D9 6B 44 2A E7 D5 0D 9C A2 55 C7 0E C9 AD 25 29 C5 2F 77 AA
B4 CE 18 62 DA 47 34 67 46 5F F7 17 D5 25 68 D6 68 EC 4C BA 32 F6 CB 68 21 83 B7 88 6E 8E EB 1F B5 47 21 0D 80 58 DB 9A
3D 0B 24 04 29 57 05 2B 86 E6 C2 19 7F C6 82 97 74 C3 4D C4 D7 5B 7B 74 3B 57 2E EE 7A A7 D4 79 79 CD FC F4 53 95 97 AF
9C 6F F9 53 CC 60 8E B1 20 BA 94 90 C5 E0 72 97 9F 79 5E 86 BF 2B BC 80 37 4B D2 95 0D C2 74 77 7C
16 : 37 : 23 <====Rx METER-2 D4 81 E6 20 00 00 01 65 C4 02 81 00 00 00 00 11 00 81 D6 02 09 09 0C 07 E3 0B 0E 04 16 2D 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 17 00 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 17 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 17 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 17 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 00 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00
16 : 37 : 23 METER-2 SERVICE = GET RESPONSE
16 : 37 : 23 METER-2 COSEM OUT DATA
16 : 37 : 23 ====>Tx METER-2 D0 0C 20 00 00 01 65 C0 02 C1 00 00 00 11
16 : 37 : 23 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 23 ====>Tx METER-2 D0 0C 20 00 00 01 65 EA 17 0C C6 1A C8 11
16 : 37 : 23 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 23 METER-2 SENDING HDLC FRAME
16 : 37 : 23 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 01 65 EA 17 0C C6 1A C8 11 DC C2 7E
16 : 37 : 23 METER-2 RECEIVED HDLC FRAME
16 : 37 : 23 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 01 66 D0 0B AC BE FF EF B7 82 7A E4 9C E5 F5 A8 A7 29 DB B7
4A A4 06 F2 B1 B9 53 AC 6E C8 BF A2 AB EA 35 07 4A CE F1 CF D2 02 1A 4D 81 4D AA 7D E4 A2 77 86 A2 30 FB 74 51 7F 58 2E
E3 B7 17 29 D5 BC 3D 32 25 A6 27 98 ED 9C 3E F0 40 E3 86 11 48 86 B9 95 04 10 35 8B 05 59 0F 4F 86 D9 52 F6 7E 5F 32 49
94 76 82 78 5F 3E 5F 4C 32 A2 26 DF 52 8E DF EA 65 91 2A 4B 86 4C C4 9D 3F E9 CB 8E 0F 43 0F 4D C3 67 03 C0 FF D4 13 31
AD 00 26 51 28 BE 55 C3 F0 EE 52 8E A1 8A FC 19 4A 7F 9F 71 03 8C 91 3B 3B 7A 09 AA B1 69 A2 9A 96 8F 9A 1B C3 DB 31 19
3A AE 26 D0 CC 4C C8 7B CC ED AD DE 33 B8 C3 9B F6 B4 AF A0 62 97 33 D4 D1 6A 5C AD 12 77 EE E0 FD 82 E7 8B 68 31 CE D7
27 3F 85 34 80 11 3B A6 8A 7E
16 : 37 : 23 <====Rx METER-2 D4 81 E6 20 00 00 01 66 D0 0B AC BE FF EF B7 82 7A E4 9C E5 F5 A8 A7 29 DB B7 4A A4 06 F2 B1 B9 53 AC 6E C8 BF A2 AB EA
35 07 4A CE F1 CF D2 02 1A 4D 81 4D AA 7D E4 A2 77 86 A2 30 FB 74 51 7F 58 2E E3 B7 17 29 D5 BC 3D 32 25 A6 27 98 ED 9C
3E F0 40 E3 86 11 48 86 B9 95 04 10 35 8B 05 59 0F 4F 86 D9 52 F6 7E 5F 32 49 94 76 82 78 5F 3E 5F 4C 32 A2 26 DF 52 8E
DF EA 65 91 2A 4B 86 4C C4 9D 3F E9 CB 8E 0F 43 0F 4D C3 67 03 C0 FF D4 13 31 AD 00 26 51 28 BE 55 C3 F0 EE 52 8E A1 8A
FC 19 4A 7F 9F 71 03 8C 91 3B 3B 7A 09 AA B1 69 A2 9A 96 8F 9A 1B C3 DB 31 19 3A AE 26 D0 CC 4C C8 7B CC ED AD DE 33 B8
C3 9B F6 B4 AF A0 62 97 33 D4 D1 6A 5C AD 12 77 EE E0 FD 82 E7 8B 68 31 CE D7 27 3F 85 34 80 11 3B
16 : 37 : 23 <====Rx METER-2 D4 81 E6 20 00 00 01 66 C4 02 81 00 00 00 00 12 00 81 D6 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
0F 05 00 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05
00 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 00 2D
00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 01 00 00 FF
01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 01 0F 00 FF 01 4A
16 : 37 : 23 ====>Tx METER-2 D0 0C 20 00 00 01 66 C0 02 C1 00 00 00 12
16 : 37 : 23 ====>Tx METER-2 D0 0C 20 00 00 01 66 0F 9D B2 BF 28 3A C0
16 : 37 : 23 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 01 66 0F 9D B2 BF 28 3A C0 2B 91 7E
16 : 37 : 23 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 01 67 B4 D1 10 A1 A5 A4 20 E5 39 3F 83 5B A2 37 18 2F 5D 74
1B 7D 4B D9 DA 63 E4 D0 61 5F BB B6 1A 8D 29 FB 15 EE 03 96 6A A8 FA 86 0D 9D DB FB 1B 7D 54 F1 92 F6 A8 50 9B 39 1F D9
49 65 BA B1 30 9B 07 A3 72 9F 62 2B B6 EB 05 A4 46 0E 45 77 FF 0F E6 48 1D E7 9F 64 6B 9E B4 C2 AA 70 E5 FD FE 92 C2 AC
6D 5A 23 28 5D 85 59 54 C1 FF DF E4 A6 19 66 57 98 2A CC C5 AF 53 8F 5A 53 68 7A 16 26 95 75 D0 3D FC 3F 58 FD 65 50 E7
AF CA 98 10 82 7D 06 5B 4F 4A DF 46 C8 90 C2 43 10 B2 69 B5 D6 CD 29 89 6A A5 BD D2 A9 B9 9D 8D 2E 71 E8 8A 4B EB 6B 54
87 89 69 E5 B2 F8 A6 70 81 4B AF B0 A9 24 9F E4 DE 24 28 5C E5 BA 8B D6 6C AF 73 18 B8 D0 93 21 BF 70 7C 90 77 AE 6D 49
EF E8 2C F6 B1 97 2F 95 D4 7E
16 : 37 : 23 <====Rx METER-2 D4 81 E6 20 00 00 01 67 B4 D1 10 A1 A5 A4 20 E5 39 3F 83 5B A2 37 18 2F 5D 74 1B 7D 4B D9 DA 63 E4 D0 61 5F BB B6 1A 8D
29 FB 15 EE 03 96 6A A8 FA 86 0D 9D DB FB 1B 7D 54 F1 92 F6 A8 50 9B 39 1F D9 49 65 BA B1 30 9B 07 A3 72 9F 62 2B B6 EB
05 A4 46 0E 45 77 FF 0F E6 48 1D E7 9F 64 6B 9E B4 C2 AA 70 E5 FD FE 92 C2 AC 6D 5A 23 28 5D 85 59 54 C1 FF DF E4 A6 19
66 57 98 2A CC C5 AF 53 8F 5A 53 68 7A 16 26 95 75 D0 3D FC 3F 58 FD 65 50 E7 AF CA 98 10 82 7D 06 5B 4F 4A DF 46 C8 90
C2 43 10 B2 69 B5 D6 CD 29 89 6A A5 BD D2 A9 B9 9D 8D 2E 71 E8 8A 4B EB 6B 54 87 89 69 E5 B2 F8 A6 70 81 4B AF B0 A9 24
9F E4 DE 24 28 5C E5 BA 8B D6 6C AF 73 18 B8 D0 93 21 BF 70 7C 90 77 AE 6D 49 EF E8 2C F6 B1 97 2F
16 : 37 : 23 <====Rx METER-2 D4 81 E6 20 00 00 01 67 C4 02 81 00 00 00 00 13 00 81 D6 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 01 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 02 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 0F 05 02 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 0F 05 02 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 0F 05 02 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
16 : 37 : 23 ====>Tx METER-2 D0 0C 20 00 00 01 67 C0 02 C1 00 00 00 13
16 : 37 : 23 ====>Tx METER-2 D0 0C 20 00 00 01 67 44 E8 52 B2 BA ED F6
16 : 37 : 23 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 01 67 44 E8 52 B2 BA ED F6 B8 AA 7E
16 : 37 : 23 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 01 68 E6 6E A6 E4 C2 AA 41 E6 86 C0 49 25 B1 3C CB 11 3F 9C
DF 82 E1 1D 30 89 57 3E B0 57 33 6C AA 18 76 5E 5F 6E 3A 1E 22 39 B1 11 45 EF 35 AA FA DC FA 10 83 37 56 09 1F 9F 26 EA
E5 66 CA 64 91 FF 7B C0 A4 AF 76 CE C1 69 55 49 D4 15 43 8F B8 83 7E D2 65 6F 38 CE 41 63 F9 00 5E 64 FB BE 4B AE E9 78
CA EB B7 9F 23 46 F7 7C BE DB D8 FD EC 9A 1A EC 89 EB D8 97 AC 00 F6 B2 FA 2D D2 FD 3A 2E 8E 53 40 A0 0A 0B 71 E7 56 80
C2 55 4F 05 A7 99 2C 02 80 53 FB 6C 6F 91 82 19 C6 A8 7D 6D 62 56 E5 49 78 2A A2 40 C6 77 48 A7 71 18 6A 6A C1 D8 D0 E4
39 DD 9C 4E C1 AE B1 09 77 E3 C1 4D DC 23 FF AF 0E EB C1 79 3F 01 E1 38 30 D3 87 90 F9 6F F0 E1 9F 99 4D 58 7A 25 63 8A
4B 94 EB 23 FB B0 BE 9E EF 7E
16 : 37 : 23 <====Rx METER-2 D4 81 E6 20 00 00 01 68 E6 6E A6 E4 C2 AA 41 E6 86 C0 49 25 B1 3C CB 11 3F 9C DF 82 E1 1D 30 89 57 3E B0 57 33 6C AA 18
76 5E 5F 6E 3A 1E 22 39 B1 11 45 EF 35 AA FA DC FA 10 83 37 56 09 1F 9F 26 EA E5 66 CA 64 91 FF 7B C0 A4 AF 76 CE C1 69
55 49 D4 15 43 8F B8 83 7E D2 65 6F 38 CE 41 63 F9 00 5E 64 FB BE 4B AE E9 78 CA EB B7 9F 23 46 F7 7C BE DB D8 FD EC 9A
1A EC 89 EB D8 97 AC 00 F6 B2 FA 2D D2 FD 3A 2E 8E 53 40 A0 0A 0B 71 E7 56 80 C2 55 4F 05 A7 99 2C 02 80 53 FB 6C 6F 91
82 19 C6 A8 7D 6D 62 56 E5 49 78 2A A2 40 C6 77 48 A7 71 18 6A 6A C1 D8 D0 E4 39 DD 9C 4E C1 AE B1 09 77 E3 C1 4D DC 23
FF AF 0E EB C1 79 3F 01 E1 38 30 D3 87 90 F9 6F F0 E1 9F 99 4D 58 7A 25 63 8A 4B 94 EB 23 FB B0 BE
16 : 37 : 23 <====Rx METER-2 D4 81 E6 20 00 00 01 68 C4 02 81 00 00 00 00 14 00 81 D6 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 03 00 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 03 0F 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 03 1E 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 03 2D 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 04 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 04 0F 00 FF 01 4A 00 12 00 00 12
16 : 37 : 23 ====>Tx METER-2 D0 0C 20 00 00 01 68 C0 02 C1 00 00 00 14
16 : 37 : 23 ====>Tx METER-2 D0 0C 20 00 00 01 68 F3 C7 3F 42 0F FC B1
16 : 37 : 23 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 01 68 F3 C7 3F 42 0F FC B1 4D 97 7E
16 : 37 : 23 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 01 69 01 F2 67 D8 11 FB 41 F3 47 9A FA 0B C7 5F 17 CB A5 31
5F 49 7D 6D 79 20 2D 0F F8 B9 BC 15 54 01 CD E0 12 C7 05 1C 60 80 FC B3 1D 94 D5 3F 94 D9 6E C7 C9 C5 60 18 CA CD 41 15
26 22 62 03 90 9A 9D 1E 36 0A 6F 24 8F 5C F7 5B 44 92 16 01 E0 AB 7B 98 FF 36 28 EF 23 9A AD 38 E4 F4 B6 ED FC BF 31 B6
9C 3B 40 B6 5F 8A C9 8B CF 91 C8 C5 7F 53 EB 26 E5 0F DD 9C 28 26 09 1B 2B B4 42 D3 8B E5 58 20 23 21 4E 43 78 FA D1 D1
D0 36 15 60 7D DF DD 85 E8 C5 81 78 BD 44 B7 8A 84 A6 83 A4 2B EB D3 D0 89 6A AD 2C B0 14 55 77 FA 6F 2D 68 FC 05 29 0D
AC BE 1D 25 D8 42 73 E2 97 81 54 59 A1 45 F2 2C 8E C4 33 FD 9E 83 49 B3 CF FE A6 71 47 EE 86 84 96 97 97 38 20 D2 BB 05
A3 15 C2 37 5D BE CE 77 0A 7E
16 : 37 : 23 <====Rx METER-2 D4 81 E6 20 00 00 01 69 01 F2 67 D8 11 FB 41 F3 47 9A FA 0B C7 5F 17 CB A5 31 5F 49 7D 6D 79 20 2D 0F F8 B9 BC 15 54 01
CD E0 12 C7 05 1C 60 80 FC B3 1D 94 D5 3F 94 D9 6E C7 C9 C5 60 18 CA CD 41 15 26 22 62 03 90 9A 9D 1E 36 0A 6F 24 8F 5C
F7 5B 44 92 16 01 E0 AB 7B 98 FF 36 28 EF 23 9A AD 38 E4 F4 B6 ED FC BF 31 B6 9C 3B 40 B6 5F 8A C9 8B CF 91 C8 C5 7F 53
EB 26 E5 0F DD 9C 28 26 09 1B 2B B4 42 D3 8B E5 58 20 23 21 4E 43 78 FA D1 D1 D0 36 15 60 7D DF DD 85 E8 C5 81 78 BD 44
B7 8A 84 A6 83 A4 2B EB D3 D0 89 6A AD 2C B0 14 55 77 FA 6F 2D 68 FC 05 29 0D AC BE 1D 25 D8 42 73 E2 97 81 54 59 A1 45
F2 2C 8E C4 33 FD 9E 83 49 B3 CF FE A6 71 47 EE 86 84 96 97 97 38 20 D2 BB 05 A3 15 C2 37 5D BE CE
16 : 37 : 24 <====Rx METER-2 D4 81 E6 20 00 00 01 69 C4 02 81 00 00 00 00 15 00 81 D6 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 0F 05 04 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 0F 05 04 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
0F 05 05 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05
05 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 05 1E
16 : 37 : 24 METER-2 SERVICE = GET RESPONSE
16 : 37 : 24 METER-2 COSEM OUT DATA
16 : 37 : 24 ====>Tx METER-2 D0 0C 20 00 00 01 69 C0 02 C1 00 00 00 15
16 : 37 : 24 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 24 ====>Tx METER-2 D0 0C 20 00 00 01 69 30 5A 0F 18 2B 55 1C
16 : 37 : 24 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 24 METER-2 SENDING HDLC FRAME
16 : 37 : 24 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 01 69 30 5A 0F 18 2B 55 1C 71 36 7E
16 : 37 : 24 METER-2 RECEIVED HDLC FRAME
16 : 37 : 24 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 01 6A FB 56 0C 04 F3 87 50 79 8B EC D0 3F 27 6B 2E 35 97 F5
95 4E 8E 03 62 95 2B 9E E8 C1 52 97 FB E4 A4 BD 74 BE 53 E1 26 B8 8F 57 26 D8 52 83 53 8B BC 7B 06 E1 11 50 E6 53 C8 BA
CC B6 D9 88 F0 28 BB 9F 6B 73 AE B3 1A B5 32 2D 5D E5 CA EC CA 02 04 77 A8 5C 6F 03 92 01 B5 7D 50 38 60 4D 4E 9C 6D 41
94 4D E7 64 97 AE 37 A7 70 AC 94 FB 43 10 64 2B BD B9 EA 27 E6 E0 64 E9 DB D9 02 E7 9F 02 47 A6 02 1C 4B 38 C1 45 CF 37
4A A3 3F 0F E6 F2 45 DF 9E 76 B6 8C 4A 2C 68 5F BF CF 60 9A B8 38 87 EB 80 0D 58 BE 8C E0 C7 BC 92 D9 97 1F F0 E2 B7 E2
D7 8B 11 D9 E4 AD F5 EE 67 47 D4 C9 C4 1B 83 96 B0 C5 6B 3C 02 C1 B0 2E 45 97 BE 46 09 5E B2 FD DA 50 59 34 4B CA D1 8D
53 EE FA 6F 1C E9 D9 AA 7E 7E
16 : 37 : 24 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 24 <====Rx METER-2 D4 81 E6 20 00 00 01 6A FB 56 0C 04 F3 87 50 79 8B EC D0 3F 27 6B 2E 35 97 F5 95 4E 8E 03 62 95 2B 9E E8 C1 52 97 FB E4
A4 BD 74 BE 53 E1 26 B8 8F 57 26 D8 52 83 53 8B BC 7B 06 E1 11 50 E6 53 C8 BA CC B6 D9 88 F0 28 BB 9F 6B 73 AE B3 1A B5
32 2D 5D E5 CA EC CA 02 04 77 A8 5C 6F 03 92 01 B5 7D 50 38 60 4D 4E 9C 6D 41 94 4D E7 64 97 AE 37 A7 70 AC 94 FB 43 10
64 2B BD B9 EA 27 E6 E0 64 E9 DB D9 02 E7 9F 02 47 A6 02 1C 4B 38 C1 45 CF 37 4A A3 3F 0F E6 F2 45 DF 9E 76 B6 8C 4A 2C
68 5F BF CF 60 9A B8 38 87 EB 80 0D 58 BE 8C E0 C7 BC 92 D9 97 1F F0 E2 B7 E2 D7 8B 11 D9 E4 AD F5 EE 67 47 D4 C9 C4 1B
83 96 B0 C5 6B 3C 02 C1 B0 2E 45 97 BE 46 09 5E B2 FD DA 50 59 34 4B CA D1 8D 53 EE FA 6F 1C E9 D9
16 : 37 : 24 <====Rx METER-2 D4 81 E6 20 00 00 01 6A C4 02 81 00 00 00 00 16 00 81 D6 0B 0F 05 05 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 06 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 06 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 06 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 06 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 0F 05 07 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
16 : 37 : 24 ====>Tx METER-2 D0 0C 20 00 00 01 6A C0 02 C1 00 00 00 16
16 : 37 : 24 ====>Tx METER-2 D0 0C 20 00 00 01 6A B4 7D 05 A5 12 EA 05
16 : 37 : 24 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 01 6A B4 7D 05 A5 12 EA 05 96 44 7E
16 : 37 : 24 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 01 6B 6E 7F 69 D9 43 9A F1 DA D7 8A 6C BD 95 3A DB 32 15 36
AE 16 D6 59 82 1C 72 9C 31 B7 78 1A 16 CB 64 D8 32 AB 05 F6 3E 1F 2C 28 B6 D5 FD 07 74 74 18 CC DE B0 8E 32 DB 08 AA 95
66 FA CC 02 42 A7 AD 2C CF 11 5A 3F E3 81 BC 12 EF 07 9F 75 3B C7 2F AD B3 C4 2D E7 2A 9C E1 36 81 90 55 28 CE 3B D5 BE
A9 65 59 D4 0D 3A 06 ED 43 8F 9C 81 CD B6 DE E6 1E 3D 79 5D E5 31 05 7C 4D 7D E0 A6 D7 2C 8F 49 D4 E5 5A 28 8F DA DA 87
B6 39 D0 09 BC E7 52 C6 2F B3 A0 3D CB E4 3C 99 D1 AA 9C 3A BC D8 A1 4B 54 07 16 F4 36 21 E0 77 E2 8B 73 97 0D 61 70 84
21 FF 72 71 85 5F 72 37 88 40 32 0D A1 78 0C DF A2 AC E8 B3 69 73 21 8F 26 BC 7E 8C F5 70 6A 67 A7 96 52 EC D0 A2 21 CC
6E 70 C6 C2 B9 D1 08 D0 DF 7E
16 : 37 : 24 <====Rx METER-2 D4 81 E6 20 00 00 01 6B 6E 7F 69 D9 43 9A F1 DA D7 8A 6C BD 95 3A DB 32 15 36 AE 16 D6 59 82 1C 72 9C 31 B7 78 1A 16 CB
64 D8 32 AB 05 F6 3E 1F 2C 28 B6 D5 FD 07 74 74 18 CC DE B0 8E 32 DB 08 AA 95 66 FA CC 02 42 A7 AD 2C CF 11 5A 3F E3 81
BC 12 EF 07 9F 75 3B C7 2F AD B3 C4 2D E7 2A 9C E1 36 81 90 55 28 CE 3B D5 BE A9 65 59 D4 0D 3A 06 ED 43 8F 9C 81 CD B6
DE E6 1E 3D 79 5D E5 31 05 7C 4D 7D E0 A6 D7 2C 8F 49 D4 E5 5A 28 8F DA DA 87 B6 39 D0 09 BC E7 52 C6 2F B3 A0 3D CB E4
3C 99 D1 AA 9C 3A BC D8 A1 4B 54 07 16 F4 36 21 E0 77 E2 8B 73 97 0D 61 70 84 21 FF 72 71 85 5F 72 37 88 40 32 0D A1 78
0C DF A2 AC E8 B3 69 73 21 8F 26 BC 7E 8C F5 70 6A 67 A7 96 52 EC D0 A2 21 CC 6E 70 C6 C2 B9 D1 08
16 : 37 : 24 <====Rx METER-2 D4 81 E6 20 00 00 01 6B C4 02 81 00 00 00 00 17 00 81 D6 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 07 0F 00 FF
01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 07 1E 00 FF 01 4A
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 07 2D 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 08 00 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 08 0F 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 08 1E 00 FF 01 4A 00
16 : 37 : 24 ====>Tx METER-2 D0 0C 20 00 00 01 6B C0 02 C1 00 00 00 17
16 : 37 : 24 ====>Tx METER-2 D0 0C 20 00 00 01 6B C1 19 33 54 CF 48 7E
16 : 37 : 24 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 01 6B C1 19 33 54 CF 48 7E 69 16 7E
16 : 37 : 24 <====Rx METER-2 7E A0 F8 41 00 02 04 01 B8 2A CB E6 E7 00 D4 81 E6 20 00 00 01 6C 94 DE 88 4C A4 CB 80 54 20 D9 11 F6 29 15 9E E6 37 03
5E 73 13 B6 20 03 F0 17 39 88 5D 14 18 49 E5 75 01 A8 30 55 47 69 65 8F F3 4F A9 A6 C6 DE 37 E6 FC 65 44 AD 76 14 BB 08
D8 E7 1E 82 85 CF CA A9 69 4E 7D E0 2A 27 BF 58 1B 22 EF 99 53 26 45 91 44 61 66 B5 4E AE EB 1D C2 E9 F1 5A BC 5F 17 36
F8 0D 82 7B B2 04 89 07 EF CB 61 96 8C A9 D8 DA 49 D4 5A AF F5 FD 4D 29 DC 19 82 91 B2 9A 54 67 A4 8A 5A C7 9C 9A 33 90
84 20 9C 4A 29 3C 0C 1F BF F3 9E CC 27 78 6A EF 45 09 77 27 74 26 BA 36 00 70 3C 31 DC 23 53 51 8F E6 0E 53 08 08 EB 1F
19 2B 25 C1 D1 A1 C2 A7 EA 09 46 CD B2 81 AA 57 C8 53 D3 E6 8E 4C 61 8C FA 81 D8 A6 F3 1D 03 ED 8A 7A 6C 3C C3 8A D7 47
03 9D DE 04 73 B3 96 48 9A 7E
16 : 37 : 24 <====Rx METER-2 D4 81 E6 20 00 00 01 6C 94 DE 88 4C A4 CB 80 54 20 D9 11 F6 29 15 9E E6 37 03 5E 73 13 B6 20 03 F0 17 39 88 5D 14 18 49
E5 75 01 A8 30 55 47 69 65 8F F3 4F A9 A6 C6 DE 37 E6 FC 65 44 AD 76 14 BB 08 D8 E7 1E 82 85 CF CA A9 69 4E 7D E0 2A 27
BF 58 1B 22 EF 99 53 26 45 91 44 61 66 B5 4E AE EB 1D C2 E9 F1 5A BC 5F 17 36 F8 0D 82 7B B2 04 89 07 EF CB 61 96 8C A9
D8 DA 49 D4 5A AF F5 FD 4D 29 DC 19 82 91 B2 9A 54 67 A4 8A 5A C7 9C 9A 33 90 84 20 9C 4A 29 3C 0C 1F BF F3 9E CC 27 78
6A EF 45 09 77 27 74 26 BA 36 00 70 3C 31 DC 23 53 51 8F E6 0E 53 08 08 EB 1F 19 2B 25 C1 D1 A1 C2 A7 EA 09 46 CD B2 81
AA 57 C8 53 D3 E6 8E 4C 61 8C FA 81 D8 A6 F3 1D 03 ED 8A 7A 6C 3C C3 8A D7 47 03 9D DE 04 73 B3 96
16 : 37 : 24 <====Rx METER-2 D4 81 E6 20 00 00 01 6C C4 02 81 00 00 00 00 18 00 81 D6 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 0F 05 08 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 0F 05 09 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 0F 05 09 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 0F 05 09 1E 00 FF 01 4A 00 12 2A A4 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 06 02 09 09 0C 07 E3 0B
0F 05 09 2D 00 FF 01 4A 00 12 5D BD 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09
16 : 37 : 24 ====>Tx METER-2 D0 0C 20 00 00 01 6C C0 02 C1 00 00 00 18
16 : 37 : 24 ====>Tx METER-2 D0 0C 20 00 00 01 6C A6 E7 27 2E 8E 93 1F
16 : 37 : 24 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 BA 30 1E E6 E6 00 D0 0C 20 00 00 01 6C A6 E7 27 2E 8E 93 1F F6 9A 7E
16 : 37 : 24 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 01 6D 36 EB 6B 64 89 D2 69 96 8A F3 50 2A 1C 37 D6 3A B3 BB
01 36 30 5D 30 F1 F4 8D BD A0 37 7E 30 38 DF AE 06 46 74 12 4F DD 7E B9 EB A8 F8 34 65 24 70 24 AC 74 D2 A5 21 46 53 3A
DF 61 23 19 E8 31 6F 07 A0 89 4F 1D A7 83 57 1B D7 D7 C5 D9 93 17 06 2D D1 6A B2 69 5A 45 07 B2 41 08 26 E7 02 AF 6B 72
21 AA D4 B1 8C 12 29 D9 5E BD D9 EE 4C 16 B1 8B 06 B8 CE 99 C6 3E 4A F6 53 AC 59 46 CD 98 1E C6 FC 27 1D 2A 40 E9 69 DA
FB F7 77 54 34 E6 EE 1C B9 B3 AB 82 67 8D BC 85 8C 3C A3 F4 E8 F6 B0 98 76 7E 96 6E AB 86 28 62 19 D2 F6 10 50 A8 F7 10
1A FF 81 B1 9C 97 B2 49 A2 F0 DE 22 55 EE 1F 8B 52 87 24 8F 80 68 DA 38 A8 C0 A9 67 CC E5 66 54 5C A3 A0 5B 8A 19 FD 78
4E A2 D8 E8 86 CE A0 74 70 7E
16 : 37 : 24 <====Rx METER-2 D4 81 E6 20 00 00 01 6D 36 EB 6B 64 89 D2 69 96 8A F3 50 2A 1C 37 D6 3A B3 BB 01 36 30 5D 30 F1 F4 8D BD A0 37 7E 30 38
DF AE 06 46 74 12 4F DD 7E B9 EB A8 F8 34 65 24 70 24 AC 74 D2 A5 21 46 53 3A DF 61 23 19 E8 31 6F 07 A0 89 4F 1D A7 83
57 1B D7 D7 C5 D9 93 17 06 2D D1 6A B2 69 5A 45 07 B2 41 08 26 E7 02 AF 6B 72 21 AA D4 B1 8C 12 29 D9 5E BD D9 EE 4C 16
B1 8B 06 B8 CE 99 C6 3E 4A F6 53 AC 59 46 CD 98 1E C6 FC 27 1D 2A 40 E9 69 DA FB F7 77 54 34 E6 EE 1C B9 B3 AB 82 67 8D
BC 85 8C 3C A3 F4 E8 F6 B0 98 76 7E 96 6E AB 86 28 62 19 D2 F6 10 50 A8 F7 10 1A FF 81 B1 9C 97 B2 49 A2 F0 DE 22 55 EE
1F 8B 52 87 24 8F 80 68 DA 38 A8 C0 A9 67 CC E5 66 54 5C A3 A0 5B 8A 19 FD 78 4E A2 D8 E8 86 CE A0
16 : 37 : 24 <====Rx METER-2 D4 81 E6 20 00 00 01 6D C4 02 81 00 00 00 00 19 00 81 D6 09 0C 07 E3 0B 0F 05 0A 00 00 FF 01 4A 00 12 5D E4 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 0B 11 0F 02 09 09 0C 07 E3 0B 0F 05 0A 0F 00 FF 01 4A 00 12 5E 39 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0A 1E 00 FF 01 4A 00 12 5E 07 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0A 2D 00 FF 01 4A 00 12 5E 4F 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0B 00 00 FF 01 4A 00 12 5E 7A 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0B 0F 00 FF 01 4A 00 12 5F 85 12 00 00 12 00 00 12
16 : 37 : 25 METER-2 COSEM OUT DATA
16 : 37 : 25 ====>Tx METER-2 D0 0C 20 00 00 01 6D C0 02 C1 00 00 00 19
16 : 37 : 25 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 25 ====>Tx METER-2 D0 0C 20 00 00 01 6D E3 42 A0 11 F8 57 BA
16 : 37 : 25 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 25 METER-2 SENDING HDLC FRAME
16 : 37 : 25 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 01 6D E3 42 A0 11 F8 57 BA 47 F5 7E
16 : 37 : 25 METER-2 RECEIVED HDLC FRAME
16 : 37 : 25 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 01 6E 5D 50 AA 62 54 C5 A7 B2 E2 4B BB 54 35 53 C3 35 AD B3
4B DE 5E D9 A0 92 40 DB 36 96 22 D5 C1 C1 78 6C 44 FB 1B 42 27 2E 1E A2 BF 98 17 7A 63 AB 04 CB 71 85 62 D6 9C BC 89 3B
40 52 F0 C4 CE EC E4 AB A4 61 9B C6 68 5E 97 AA 4D 40 40 B8 8E 0A 0C 21 0D 0D A7 B7 4B BC D3 36 4F 59 C2 C5 D7 F4 C0 A1
55 1A 09 DD 3B 53 74 64 0B ED 88 7A 2C 02 68 74 1A E1 7E 58 E4 66 0D DA A7 E7 DC C6 DD 64 3B 7E BE E4 24 79 F6 EB 75 38
23 9E 01 88 36 C7 39 6E 38 53 BD C8 EA 35 5D F9 21 A3 0B 04 3A 2F 5C 6A C1 50 A1 78 C2 F8 11 93 95 94 F1 A8 81 47 BD C0
61 92 7C 18 46 4F 03 EA 8D C2 CB 7E 3E DE 4C 51 01 38 C1 0F 4B 5C BB 96 41 DD DE 13 A3 02 57 66 AC 1F A6 8F 2A 10 A1 AA
30 18 C8 BD 70 33 3E 9E 6F 7E
16 : 37 : 25 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 25 <====Rx METER-2 D4 81 E6 20 00 00 01 6E 5D 50 AA 62 54 C5 A7 B2 E2 4B BB 54 35 53 C3 35 AD B3 4B DE 5E D9 A0 92 40 DB 36 96 22 D5 C1 C1
78 6C 44 FB 1B 42 27 2E 1E A2 BF 98 17 7A 63 AB 04 CB 71 85 62 D6 9C BC 89 3B 40 52 F0 C4 CE EC E4 AB A4 61 9B C6 68 5E
97 AA 4D 40 40 B8 8E 0A 0C 21 0D 0D A7 B7 4B BC D3 36 4F 59 C2 C5 D7 F4 C0 A1 55 1A 09 DD 3B 53 74 64 0B ED 88 7A 2C 02
68 74 1A E1 7E 58 E4 66 0D DA A7 E7 DC C6 DD 64 3B 7E BE E4 24 79 F6 EB 75 38 23 9E 01 88 36 C7 39 6E 38 53 BD C8 EA 35
5D F9 21 A3 0B 04 3A 2F 5C 6A C1 50 A1 78 C2 F8 11 93 95 94 F1 A8 81 47 BD C0 61 92 7C 18 46 4F 03 EA 8D C2 CB 7E 3E DE
4C 51 01 38 C1 0F 4B 5C BB 96 41 DD DE 13 A3 02 57 66 AC 1F A6 8F 2A 10 A1 AA 30 18 C8 BD 70 33 3E
16 : 37 : 25 <====Rx METER-2 D4 81 E6 20 00 00 01 6E C4 02 81 00 00 00 00 1A 00 81 D6 00 00 12 00 00 12 00 00 11 0B 11 12 02 09 09 0C 07 E3 0B 0F 05
0B 1E 00 FF 01 4A 00 12 5F 80 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0B 2D
00 FF 01 4A 00 12 5E A6 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0C 00 00 FF
01 4A 00 12 5F 40 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0C 0F 00 FF 01 4A
00 12 60 18 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 0F 02 09 09 0C 07 E3 0B 0F 05 0C 1E 00 FF 01 4A 00 12
5F E5 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 0E 02 09 09 0C 07 E3 0B 0F 05 0C 2D 00
16 : 37 : 25 METER-2 SERVICE = GET RESPONSE
16 : 37 : 25 ====>Tx METER-2 D0 0C 20 00 00 01 6E C0 02 C1 00 00 00 1A
16 : 37 : 25 ====>Tx METER-2 D0 0C 20 00 00 01 6E DD 08 3F F0 15 07 39
16 : 37 : 25 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 01 6E DD 08 3F F0 15 07 39 41 6B 7E
16 : 37 : 25 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 01 6F A8 35 15 A6 96 F8 D4 0C B2 6D 4C C2 6B 40 AB 93 DD F5
EE B8 BE 32 AA A2 8F 19 27 1F BD A6 61 0B B6 50 3E 70 7C 1B 9D C7 51 58 C9 97 7A C3 0A 99 8B 1C EC 78 C8 50 BC EE 76 B1
C8 82 16 A6 F7 B2 76 E8 AC E4 E9 B7 A5 EF 69 62 51 94 9A F2 B6 58 86 0C A7 7A 3A 26 B2 95 B1 E2 EA F7 5D CC 34 E3 ED 4D
45 98 13 8B 02 E1 38 70 A2 C8 30 74 6E B7 04 21 B5 AD 91 7C 32 B3 99 CC 01 F9 D0 09 E9 BE 0C A3 CA A2 AC B5 5E 51 8D 7F
09 A9 E4 B2 CD 7C 73 F2 C2 A2 D9 6F 57 12 BE 90 9C 02 84 43 C3 E9 C1 4E 66 53 1B 1C EA 19 18 DF 9D 36 E9 55 41 81 E3 48
9C 29 5C 41 43 6F 25 30 3A CD F9 26 31 FE B9 93 38 F5 97 7E 3A 05 44 A9 18 1E 34 E6 1E 68 EE 81 6A ED D5 FF A3 6F AF D8
FE AB F9 BC 25 CC 66 02 E8 7E
16 : 37 : 25 <====Rx METER-2 D4 81 E6 20 00 00 01 6F A8 35 15 A6 96 F8 D4 0C B2 6D 4C C2 6B 40 AB 93 DD F5 EE B8 BE 32 AA A2 8F 19 27 1F BD A6 61 0B
B6 50 3E 70 7C 1B 9D C7 51 58 C9 97 7A C3 0A 99 8B 1C EC 78 C8 50 BC EE 76 B1 C8 82 16 A6 F7 B2 76 E8 AC E4 E9 B7 A5 EF
69 62 51 94 9A F2 B6 58 86 0C A7 7A 3A 26 B2 95 B1 E2 EA F7 5D CC 34 E3 ED 4D 45 98 13 8B 02 E1 38 70 A2 C8 30 74 6E B7
04 21 B5 AD 91 7C 32 B3 99 CC 01 F9 D0 09 E9 BE 0C A3 CA A2 AC B5 5E 51 8D 7F 09 A9 E4 B2 CD 7C 73 F2 C2 A2 D9 6F 57 12
BE 90 9C 02 84 43 C3 E9 C1 4E 66 53 1B 1C EA 19 18 DF 9D 36 E9 55 41 81 E3 48 9C 29 5C 41 43 6F 25 30 3A CD F9 26 31 FE
B9 93 38 F5 97 7E 3A 05 44 A9 18 1E 34 E6 1E 68 EE 81 6A ED D5 FF A3 6F AF D8 FE AB F9 BC 25 CC 66
16 : 37 : 25 <====Rx METER-2 D4 81 E6 20 00 00 01 6F C4 02 81 00 00 00 00 1B 00 81 D6 FF 01 4A 00 12 5F B8 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 0B 11 10 02 09 09 0C 07 E3 0B 0F 05 0D 00 00 FF 01 4A 00 12 5F FC 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0D 0F 00 FF 01 4A 00 12 61 1F 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11
12 02 09 09 0C 07 E3 0B 0F 05 0D 1E 00 FF 01 4A 00 12 61 C4 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02
09 09 0C 07 E3 0B 0F 05 0D 2D 00 FF 01 4A 00 12 61 FD 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 12 02 09 09
0C 07 E3 0B 0F 05 0E 00 00 FF 01 4A 00 12 62 04 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B
16 : 37 : 25 ====>Tx METER-2 D0 0C 20 00 00 01 6F C0 02 C1 00 00 00 1B
16 : 37 : 25 ====>Tx METER-2 D0 0C 20 00 00 01 6F B6 97 4B 40 1C E1 64
16 : 37 : 25 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 01 6F B6 97 4B 40 1C E1 64 2A B3 7E
16 : 37 : 25 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 01 70 BB 4E B5 61 10 25 C8 3C C0 D1 0F 67 2E B2 5F E6 5B 58
64 96 80 A5 89 79 AF 87 BD 6D 65 39 B9 AA 0D EB D1 3B 37 01 50 23 6E 79 57 8B 24 07 BA 7B 5F B3 83 A9 26 70 D2 F1 CD 8F
68 DF 08 A3 34 7D 2C A8 34 69 81 3E F8 CF 9B F5 B8 AF 88 09 E6 CE 02 3C 8A 4F 79 0F F8 E4 E2 D3 E4 BC 36 9C 27 A6 60 02
3B 0E 67 1E E5 50 45 A2 8A 3B 8E 41 1B 7E 78 64 58 93 B4 D3 47 48 70 BB 7E 0A 33 36 B1 66 14 43 68 67 DB 52 66 C6 A7 08
B2 CE B7 70 5A 57 73 50 DB E2 9A AB F4 B6 28 0A C9 28 40 94 4B 29 86 1D 7A E5 1F B9 13 C4 49 7C 16 9B 9F F0 CF 51 6B BE
F3 12 A5 E0 1C 8E 90 87 80 2F 77 D8 93 19 24 A2 C8 77 79 AF 35 0C D6 C8 88 07 70 F9 A7 36 A0 E2 ED 0B 33 12 66 23 9E 79
FB EB 62 12 89 7D AB ED D5 7E
16 : 37 : 25 <====Rx METER-2 D4 81 E6 20 00 00 01 70 BB 4E B5 61 10 25 C8 3C C0 D1 0F 67 2E B2 5F E6 5B 58 64 96 80 A5 89 79 AF 87 BD 6D 65 39 B9 AA
0D EB D1 3B 37 01 50 23 6E 79 57 8B 24 07 BA 7B 5F B3 83 A9 26 70 D2 F1 CD 8F 68 DF 08 A3 34 7D 2C A8 34 69 81 3E F8 CF
9B F5 B8 AF 88 09 E6 CE 02 3C 8A 4F 79 0F F8 E4 E2 D3 E4 BC 36 9C 27 A6 60 02 3B 0E 67 1E E5 50 45 A2 8A 3B 8E 41 1B 7E
78 64 58 93 B4 D3 47 48 70 BB 7E 0A 33 36 B1 66 14 43 68 67 DB 52 66 C6 A7 08 B2 CE B7 70 5A 57 73 50 DB E2 9A AB F4 B6
28 0A C9 28 40 94 4B 29 86 1D 7A E5 1F B9 13 C4 49 7C 16 9B 9F F0 CF 51 6B BE F3 12 A5 E0 1C 8E 90 87 80 2F 77 D8 93 19
24 A2 C8 77 79 AF 35 0C D6 C8 88 07 70 F9 A7 36 A0 E2 ED 0B 33 12 66 23 9E 79 FB EB 62 12 89 7D AB
16 : 37 : 25 <====Rx METER-2 D4 81 E6 20 00 00 01 70 C4 02 81 00 00 00 00 1C 00 81 D6 11 11 02 09 09 0C 07 E3 0B 0F 05 0E 0F 00 FF 01 4A 00 12 62 11
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 12 02 09 09 0C 07 E3 0B 0F 05 0E 1E 00 FF 01 4A 00 12 61 8E 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0E 2D 00 FF 01 4A 00 12 61 BD 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0F 00 00 FF 01 4A 00 12 61 DA 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0F 0F 00 FF 01 4A 00 12 5A 1C 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 0B 11 10 02 09 09 0C 07 E3 0B 0F 05 0F 1E 00 FF 01 4A 00 12 5B 98 12 00 00
16 : 37 : 25 ====>Tx METER-2 D0 0C 20 00 00 01 70 C0 02 C1 00 00 00 1C
16 : 37 : 25 ====>Tx METER-2 D0 0C 20 00 00 01 70 8C 8D BB 3B 2D 63 8C
16 : 37 : 25 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 01 70 8C 8D BB 3B 2D 63 8C FD 00 7E
16 : 37 : 25 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 01 71 C3 AC D5 59 E0 3C C2 E6 D8 E3 43 17 5B A6 D9 5B 9F DA
D4 D1 E7 C2 3F 71 3E 52 0D 92 DA 4A A9 A4 6C A4 CB 01 C4 5A FF 6A B1 32 9B 8B 87 27 1D 25 66 73 04 67 0B B1 40 AB C3 F7
13 C1 57 76 AB 26 FC E1 22 D3 FB 06 5F 99 4B 02 2F 87 9A 75 7D E4 A1 45 53 22 D8 FE 2D 29 9E 35 8E B1 5C 9D BD 45 8F 87
7E 79 D4 F6 E3 E5 69 C9 5A 4E 28 B1 1C E4 8A 07 94 04 76 25 E9 11 3E 17 2D C9 3F 72 BC 25 06 36 52 17 4E 35 13 5E 60 EC
29 CF E0 AD 8F E1 7E CD D6 6A 86 3F F4 2F 4E 13 19 A8 CF F8 78 F4 1D FC 0F 24 67 30 E1 59 3F 80 C7 C9 DA 37 B8 DD C3 F6
4C FD 03 B5 56 E7 A5 86 A9 8E 75 10 21 73 A7 D7 A7 BB 08 8E 20 D9 9B F2 B1 22 3D 93 CC 76 76 54 A4 45 F5 57 FE FF A1 CA
1C 21 38 29 F4 34 0C 8A 62 7E
16 : 37 : 25 <====Rx METER-2 D4 81 E6 20 00 00 01 71 C3 AC D5 59 E0 3C C2 E6 D8 E3 43 17 5B A6 D9 5B 9F DA D4 D1 E7 C2 3F 71 3E 52 0D 92 DA 4A A9 A4
6C A4 CB 01 C4 5A FF 6A B1 32 9B 8B 87 27 1D 25 66 73 04 67 0B B1 40 AB C3 F7 13 C1 57 76 AB 26 FC E1 22 D3 FB 06 5F 99
4B 02 2F 87 9A 75 7D E4 A1 45 53 22 D8 FE 2D 29 9E 35 8E B1 5C 9D BD 45 8F 87 7E 79 D4 F6 E3 E5 69 C9 5A 4E 28 B1 1C E4
8A 07 94 04 76 25 E9 11 3E 17 2D C9 3F 72 BC 25 06 36 52 17 4E 35 13 5E 60 EC 29 CF E0 AD 8F E1 7E CD D6 6A 86 3F F4 2F
4E 13 19 A8 CF F8 78 F4 1D FC 0F 24 67 30 E1 59 3F 80 C7 C9 DA 37 B8 DD C3 F6 4C FD 03 B5 56 E7 A5 86 A9 8E 75 10 21 73
A7 D7 A7 BB 08 8E 20 D9 9B F2 B1 22 3D 93 CC 76 76 54 A4 45 F5 57 FE FF A1 CA 1C 21 38 29 F4 34 0C
16 : 37 : 25 <====Rx METER-2 D4 81 E6 20 00 00 01 71 C4 02 81 00 00 00 00 1D 00 81 D6 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 13 02 09 09 0C 07
E3 0B 0F 05 0F 2D 00 FF 01 4A 00 12 5C C1 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 14 02 09 09 0C 07 E3 0B
0F 05 10 00 00 FF 01 4A 00 12 5C C5 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 12 02 09 09 0C 07 E3 0B 0F 05
10 0F 00 FF 01 4A 00 12 5C C3 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 13 02 09 09 0C 07 E3 0B 0F 05 10 1E
00 FF 01 4A 00 12 5C BD 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 11 02 09 09 0C 07 E3 0B 0F 05 10 2D 00 FF
01 4A 00 12 5C C2 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 10 02 09 09 0C 07 E3 0B 0F
16 : 37 : 25 ====>Tx METER-2 D0 0C 20 00 00 01 71 C0 02 C1 00 00 00 1D
16 : 37 : 25 ====>Tx METER-2 D0 0C 20 00 00 01 71 47 16 59 77 E7 37 77
16 : 37 : 26 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 26 METER-2 SENDING HDLC FRAME
16 : 37 : 26 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 01 71 47 16 59 77 E7 37 77 2A E4 7E
16 : 37 : 26 METER-2 RECEIVED HDLC FRAME
16 : 37 : 26 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 01 72 F4 06 4A 8A 6F E8 5F 0A DD A8 A1 75 F8 BB 3C 49 3F F0
53 6F 24 CC 59 BF 5E BE 0B AA 03 91 0F F9 3D 69 33 52 9F 3A 9B A0 10 5F FD 88 D4 DB 9A D1 24 20 3F EE 68 3B 6D 41 3C 25
1A E4 2F 50 60 D9 39 59 81 8C C9 C6 C8 36 A5 46 D9 FA 74 F1 C9 7C B5 B7 02 4E B7 47 59 8D 1A 06 85 17 53 1A C4 7F A7 6F
7F 69 BA 03 60 90 AF 96 7E 6D F1 83 59 73 98 65 7E 69 B1 8F FC 24 DA 3E FE A0 18 79 E6 1C 29 01 B7 4E BC 29 41 71 B2 B3
FF 96 6F C0 16 87 5E 85 94 50 24 37 D9 BD F1 9D 79 C6 FA 4B 3C 4E 2F 43 98 C6 4F C9 35 07 C3 D2 D7 3B 9E 5E B4 07 02 7D
32 48 27 71 08 31 AA 79 4E 38 D8 D3 92 2D 41 D4 21 A5 EF 52 A4 D0 C1 3F 80 DD C0 53 A4 39 38 01 BD B1 4D F7 08 C7 3D EE
63 73 CE 9A 46 44 F7 DB 19 7E
16 : 37 : 26 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 26 <====Rx METER-2 D4 81 E6 20 00 00 01 72 F4 06 4A 8A 6F E8 5F 0A DD A8 A1 75 F8 BB 3C 49 3F F0 53 6F 24 CC 59 BF 5E BE 0B AA 03 91 0F F9
3D 69 33 52 9F 3A 9B A0 10 5F FD 88 D4 DB 9A D1 24 20 3F EE 68 3B 6D 41 3C 25 1A E4 2F 50 60 D9 39 59 81 8C C9 C6 C8 36
A5 46 D9 FA 74 F1 C9 7C B5 B7 02 4E B7 47 59 8D 1A 06 85 17 53 1A C4 7F A7 6F 7F 69 BA 03 60 90 AF 96 7E 6D F1 83 59 73
98 65 7E 69 B1 8F FC 24 DA 3E FE A0 18 79 E6 1C 29 01 B7 4E BC 29 41 71 B2 B3 FF 96 6F C0 16 87 5E 85 94 50 24 37 D9 BD
F1 9D 79 C6 FA 4B 3C 4E 2F 43 98 C6 4F C9 35 07 C3 D2 D7 3B 9E 5E B4 07 02 7D 32 48 27 71 08 31 AA 79 4E 38 D8 D3 92 2D
41 D4 21 A5 EF 52 A4 D0 C1 3F 80 DD C0 53 A4 39 38 01 BD B1 4D F7 08 C7 3D EE 63 73 CE 9A 46 44 F7
16 : 37 : 26 <====Rx METER-2 D4 81 E6 20 00 00 01 72 C4 02 81 00 00 00 00 1E 00 81 D6 05 11 00 00 FF 01 4A 00 12 5C C5 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 0C 11 10 02 09 09 0C 07 E3 0B 0F 05 11 0F 00 FF 01 4A 00 12 5C C4 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 0C 11 10 02 09 09 0C 07 E3 0B 0F 05 11 1E 00 FF 01 4A 00 12 5C C7 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 0C 11 10 02 09 09 0C 07 E3 0B 0F 05 11 2D 00 FF 01 4A 00 12 5C C7 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
0C 11 10 02 09 09 0C 07 E3 0B 0F 05 12 00 00 FF 01 4A 00 12 5C CD 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11
11 02 09 09 0C 07 E3 0B 0F 05 12 0F 00 FF 01 4A 00 12 3D 2F 12 00 00 12 00 00 12 00 00 12 00 00 12
16 : 37 : 26 METER-2 SERVICE = GET RESPONSE
16 : 37 : 26 METER-2 COSEM OUT DATA
16 : 37 : 26 ====>Tx METER-2 D0 0C 20 00 00 01 72 C0 02 C1 00 00 00 1E
16 : 37 : 26 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 26 ====>Tx METER-2 D0 0C 20 00 00 01 72 3D 89 C8 D6 44 4C 27
16 : 37 : 26 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 01 72 3D 89 C8 D6 44 4C 27 F7 C1 7E
16 : 37 : 26 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 01 73 37 C0 39 B5 76 3D 70 C3 12 39 15 EE 46 4A 22 3F 4F F7
C2 F9 41 5D AC F7 F5 B3 0A 53 44 36 A6 63 4C 9E 44 46 63 A1 A1 89 58 FD 96 9E 70 9E 21 E1 16 83 85 59 D8 10 C2 9C CE 77
D3 98 4E B8 05 AE E7 59 C0 56 D8 44 98 B6 F6 C8 99 93 49 CB E0 69 BD 75 D6 44 FA E3 78 25 84 EC AA 95 66 68 FE A2 36 76
CE 6A 31 AC 3C 14 2D 5C C0 DE AE 21 15 E7 84 7E FC 07 75 2C C9 00 25 31 DF 09 41 DE 24 D2 87 03 DA 2C 6C 5F 07 EC CF 1D
A9 7E 50 A3 EA 51 5C FE CF F0 51 CA 41 3D F3 F4 CD 1D 45 65 E9 49 4E 74 54 E5 7E B7 CA CE 45 A0 54 A4 EE 6F 7A 8C 6B 9D
83 05 CE 6D 7C 84 E1 68 46 41 B1 DB C7 63 C6 B0 B0 FA DF F5 70 1F 1C 2B 9C CD AA 0A E4 9F BD ED 6C 7D 01 9B A2 6D BA D0
01 76 5B 0D D0 8D 3A F3 E6 7E
16 : 37 : 26 <====Rx METER-2 D4 81 E6 20 00 00 01 73 37 C0 39 B5 76 3D 70 C3 12 39 15 EE 46 4A 22 3F 4F F7 C2 F9 41 5D AC F7 F5 B3 0A 53 44 36 A6 63
4C 9E 44 46 63 A1 A1 89 58 FD 96 9E 70 9E 21 E1 16 83 85 59 D8 10 C2 9C CE 77 D3 98 4E B8 05 AE E7 59 C0 56 D8 44 98 B6
F6 C8 99 93 49 CB E0 69 BD 75 D6 44 FA E3 78 25 84 EC AA 95 66 68 FE A2 36 76 CE 6A 31 AC 3C 14 2D 5C C0 DE AE 21 15 E7
84 7E FC 07 75 2C C9 00 25 31 DF 09 41 DE 24 D2 87 03 DA 2C 6C 5F 07 EC CF 1D A9 7E 50 A3 EA 51 5C FE CF F0 51 CA 41 3D
F3 F4 CD 1D 45 65 E9 49 4E 74 54 E5 7E B7 CA CE 45 A0 54 A4 EE 6F 7A 8C 6B 9D 83 05 CE 6D 7C 84 E1 68 46 41 B1 DB C7 63
C6 B0 B0 FA DF F5 70 1F 1C 2B 9C CD AA 0A E4 9F BD ED 6C 7D 01 9B A2 6D BA D0 01 76 5B 0D D0 8D 3A
16 : 37 : 26 <====Rx METER-2 D4 81 E6 20 00 00 01 73 C4 02 81 00 00 00 00 1F 00 81 D6 00 00 11 0C 11 0C 02 09 09 0C 07 E3 0B 0F 05 12 1E 00 FF 01 4A
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 12 2D 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 13 00 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 13 0F 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 13 1E 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 13 2D 00 FF 01 4A 00 12 00
16 : 37 : 26 ====>Tx METER-2 D0 0C 20 00 00 01 73 C0 02 C1 00 00 00 1F
16 : 37 : 26 ====>Tx METER-2 D0 0C 20 00 00 01 73 33 35 92 1D AC D7 B2
16 : 37 : 26 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 01 73 33 35 92 1D AC D7 B2 5B 06 7E
16 : 37 : 26 <====Rx METER-2 7E A0 F8 41 00 02 04 01 B8 2A CB E6 E7 00 D4 81 E6 20 00 00 01 74 E1 A5 3F AC EC 41 4C DA A8 46 14 1F 8D 82 50 1D DF B6
E7 E3 13 70 D2 4E DC 88 93 9C 7E 1E EF A6 44 31 EA 89 2B B6 CE 81 5F B5 92 BF 1B 58 A4 0F CF A3 7D 34 A8 CE 2B FB 0B 9B
D1 04 39 FD 6E 9F 8C 89 8C 1B 52 0D 1D DF 47 27 B7 6F 77 50 BC 7D B5 C1 8D CE 60 3B 77 06 F9 00 A8 39 B4 4E 4A E8 9D 33
51 32 E6 28 3B D4 A6 AC 47 17 21 92 01 A9 C5 9D 61 35 64 DA 24 F9 C3 B9 4D FB 15 32 6E BD 1B 22 7C 72 13 0D 22 AA 75 68
04 22 64 28 A1 D8 43 E6 30 F2 3A E6 53 2C 48 85 E6 B7 B0 41 B4 AE 5A 74 B6 FA C9 21 FA 62 3B 1E 71 AB B9 B0 A0 E4 3F 1F
42 81 EC 28 4F 92 54 E6 A9 73 27 1D DE 61 80 C2 05 14 B8 41 06 E4 5F 8E 25 2D 4D 3F 99 14 63 69 E2 9A EB 38 C7 A1 25 20
0C B8 66 6B 08 AD C9 0C 6D 7E
16 : 37 : 26 <====Rx METER-2 D4 81 E6 20 00 00 01 74 E1 A5 3F AC EC 41 4C DA A8 46 14 1F 8D 82 50 1D DF B6 E7 E3 13 70 D2 4E DC 88 93 9C 7E 1E EF A6
44 31 EA 89 2B B6 CE 81 5F B5 92 BF 1B 58 A4 0F CF A3 7D 34 A8 CE 2B FB 0B 9B D1 04 39 FD 6E 9F 8C 89 8C 1B 52 0D 1D DF
47 27 B7 6F 77 50 BC 7D B5 C1 8D CE 60 3B 77 06 F9 00 A8 39 B4 4E 4A E8 9D 33 51 32 E6 28 3B D4 A6 AC 47 17 21 92 01 A9
C5 9D 61 35 64 DA 24 F9 C3 B9 4D FB 15 32 6E BD 1B 22 7C 72 13 0D 22 AA 75 68 04 22 64 28 A1 D8 43 E6 30 F2 3A E6 53 2C
48 85 E6 B7 B0 41 B4 AE 5A 74 B6 FA C9 21 FA 62 3B 1E 71 AB B9 B0 A0 E4 3F 1F 42 81 EC 28 4F 92 54 E6 A9 73 27 1D DE 61
80 C2 05 14 B8 41 06 E4 5F 8E 25 2D 4D 3F 99 14 63 69 E2 9A EB 38 C7 A1 25 20 0C B8 66 6B 08 AD C9
16 : 37 : 26 <====Rx METER-2 D4 81 E6 20 00 00 01 74 C4 02 81 00 00 00 00 20 00 81 D6 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 0F 05 14 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 0F 05 14 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 0F 05 14 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
0F 05 14 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05
15 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
16 : 37 : 26 ====>Tx METER-2 D0 0C 20 00 00 01 74 C0 02 C1 00 00 00 20
16 : 37 : 26 ====>Tx METER-2 D0 0C 20 00 00 01 74 0B B9 B8 DB 45 6E 89
16 : 37 : 26 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 BA 30 1E E6 E6 00 D0 0C 20 00 00 01 74 0B B9 B8 DB 45 6E 89 46 0D 7E
16 : 37 : 26 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 01 75 63 0B 87 5F 6E 12 78 76 6F 27 77 31 CF 85 93 BE D0 BB
61 57 A5 5D 0C 3D 7C 26 34 50 0D 1F F3 21 3B F3 EF 5F 83 7C 3E 69 82 4E 89 ED 54 6E DB 98 CE BD 84 1F ED 04 33 15 83 53
FA 98 6B E5 9E C6 65 FB 04 3A 50 34 86 4B 7F 65 F6 9F 17 C9 B5 67 48 07 7B 62 10 F0 12 05 B9 49 A2 FA B3 FF 94 36 5D B0
55 B7 C8 3C E6 29 1A 38 38 2C 32 9B F0 E4 F9 FD 94 C5 60 BA 07 D1 63 8F 75 26 6B 73 A0 C6 72 21 AE 1D 50 18 FD 2D D3 E6
6F 8B 86 0D 0B 33 2F 26 E6 78 79 22 1D E8 A0 F9 78 67 85 89 50 A0 61 0F 4E E3 39 DE A6 CE 94 39 0D CE CC 7D FC D2 2A EC
EC C0 DA 59 86 F1 D2 FB 54 0B A3 B5 69 70 F3 01 C5 1E 35 7B 63 2E BD 19 61 93 16 C8 F6 DD A7 16 38 75 5B CC E4 CA 68 5D
1B BF F6 8E D6 21 EF 8D 34 7E
16 : 37 : 26 <====Rx METER-2 D4 81 E6 20 00 00 01 75 63 0B 87 5F 6E 12 78 76 6F 27 77 31 CF 85 93 BE D0 BB 61 57 A5 5D 0C 3D 7C 26 34 50 0D 1F F3 21
3B F3 EF 5F 83 7C 3E 69 82 4E 89 ED 54 6E DB 98 CE BD 84 1F ED 04 33 15 83 53 FA 98 6B E5 9E C6 65 FB 04 3A 50 34 86 4B
7F 65 F6 9F 17 C9 B5 67 48 07 7B 62 10 F0 12 05 B9 49 A2 FA B3 FF 94 36 5D B0 55 B7 C8 3C E6 29 1A 38 38 2C 32 9B F0 E4
F9 FD 94 C5 60 BA 07 D1 63 8F 75 26 6B 73 A0 C6 72 21 AE 1D 50 18 FD 2D D3 E6 6F 8B 86 0D 0B 33 2F 26 E6 78 79 22 1D E8
A0 F9 78 67 85 89 50 A0 61 0F 4E E3 39 DE A6 CE 94 39 0D CE CC 7D FC D2 2A EC EC C0 DA 59 86 F1 D2 FB 54 0B A3 B5 69 70
F3 01 C5 1E 35 7B 63 2E BD 19 61 93 16 C8 F6 DD A7 16 38 75 5B CC E4 CA 68 5D 1B BF F6 8E D6 21 EF
16 : 37 : 26 <====Rx METER-2 D4 81 E6 20 00 00 01 75 C4 02 81 00 00 00 00 21 00 81 D6 07 E3 0B 0F 05 15 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 15 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 15 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 16 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 16 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 16 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
16 : 37 : 26 ====>Tx METER-2 D0 0C 20 00 00 01 75 C0 02 C1 00 00 00 21
16 : 37 : 26 ====>Tx METER-2 D0 0C 20 00 00 01 75 57 E9 DB 6F 50 63 32
16 : 37 : 26 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 01 75 57 E9 DB 6F 50 63 32 CA A7 7E
16 : 37 : 27 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 01 76 3A 1D 50 31 F4 1B 67 8E 3D 52 33 FB A7 4F D9 2A EA D9
CB 8B CA 38 E2 3D A9 20 3F FC FB 24 A6 9F C9 9B 10 16 7E 8D 3B 8C AE 19 0B 50 B3 2A C4 62 CC 32 DC F4 27 6F 94 E8 A7 58
D6 DB A2 68 2C 40 3C 17 39 3A 73 55 FA 70 78 CA 0C 20 C9 57 31 3B B6 0D D5 62 FC EC 17 47 FD 8E 87 08 0C F1 A7 DF 8D 1F
0A A1 E2 0F 4C 54 EC CB C6 5D 25 B1 9F 80 28 13 F3 74 A0 05 69 7C 7D 3E F8 64 B6 5D A8 F2 46 98 FB A4 7E 89 95 34 79 D7
A0 B4 6A 23 39 8C B9 3D FC A5 36 F8 15 BE 30 EC 40 70 67 2C A1 EF 9C AB EE 45 F6 C5 E1 DE C3 03 1E 34 5F 19 AF D6 A6 55
FA 13 7C 80 FF C4 C6 47 6A 55 75 1D 87 2B 8F AE 38 35 EA D0 85 80 1A 7A 0B 5E D4 67 C7 E6 67 34 33 6E B7 CF 66 15 D7 8C
07 95 F3 75 69 C1 FA EA E7 7E
16 : 37 : 27 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 27 <====Rx METER-2 D4 81 E6 20 00 00 01 76 3A 1D 50 31 F4 1B 67 8E 3D 52 33 FB A7 4F D9 2A EA D9 CB 8B CA 38 E2 3D A9 20 3F FC FB 24 A6 9F
C9 9B 10 16 7E 8D 3B 8C AE 19 0B 50 B3 2A C4 62 CC 32 DC F4 27 6F 94 E8 A7 58 D6 DB A2 68 2C 40 3C 17 39 3A 73 55 FA 70
78 CA 0C 20 C9 57 31 3B B6 0D D5 62 FC EC 17 47 FD 8E 87 08 0C F1 A7 DF 8D 1F 0A A1 E2 0F 4C 54 EC CB C6 5D 25 B1 9F 80
28 13 F3 74 A0 05 69 7C 7D 3E F8 64 B6 5D A8 F2 46 98 FB A4 7E 89 95 34 79 D7 A0 B4 6A 23 39 8C B9 3D FC A5 36 F8 15 BE
30 EC 40 70 67 2C A1 EF 9C AB EE 45 F6 C5 E1 DE C3 03 1E 34 5F 19 AF D6 A6 55 FA 13 7C 80 FF C4 C6 47 6A 55 75 1D 87 2B
8F AE 38 35 EA D0 85 80 1A 7A 0B 5E D4 67 C7 E6 67 34 33 6E B7 CF 66 15 D7 8C 07 95 F3 75 69 C1 FA
16 : 37 : 27 <====Rx METER-2 D4 81 E6 20 00 00 01 76 C4 02 81 00 00 00 00 22 00 81 D6 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 16 2D
00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 17 00 00 FF
01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 17 0F 00 FF 01 4A
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 17 1E 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 17 2D 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 10 06 00 00 00 FF 01
16 : 37 : 27 METER-2 SERVICE = GET RESPONSE
16 : 37 : 27 METER-2 COSEM OUT DATA
16 : 37 : 27 ====>Tx METER-2 D0 0C 20 00 00 01 76 C0 02 C1 00 00 00 22
16 : 37 : 27 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 27 ====>Tx METER-2 D0 0C 20 00 00 01 76 3E F8 CE 35 4D AE 40
16 : 37 : 27 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 27 METER-2 SENDING HDLC FRAME
16 : 37 : 27 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 01 76 3E F8 CE 35 4D AE 40 3C 45 7E
16 : 37 : 27 METER-2 RECEIVED HDLC FRAME
16 : 37 : 27 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 01 77 0A 7B 1C FA 46 F2 F4 A8 32 02 5C 34 0D E8 F6 CF DD A1
90 17 37 EF 8D AF D7 41 E2 FB DF AF E9 0C E2 6C 64 14 45 23 1A 48 67 B3 57 54 B4 E7 02 5F 97 42 DD DB 6A 32 E9 83 07 6A
BA 58 CF 1C 00 C0 C7 EC FD 4A 7F B7 77 AB FC 6C D7 59 80 E5 AC AB 36 33 87 5F 4E D0 84 61 DB 32 0B 26 84 CC 45 EC 02 D2
8D 38 2C 45 C7 DC 03 0E 76 6D 13 5B 82 EF 7D D6 D9 D3 4E 33 DE 9C A6 24 CB 58 6E 05 94 1C 1C 75 B9 A7 11 B2 BA 5D EE 39
A8 60 E5 2C 61 C8 BA 12 87 4E 7E 38 1D FF 7B 69 C0 B4 23 84 20 46 4E 5E 66 86 D9 52 3A 94 7B EB 3A C5 28 5B 69 D3 C9 CE
E5 BD 82 46 4F D4 FB 06 A9 C4 3B 89 75 79 65 07 9F 91 94 2A D9 C7 38 50 8B 87 4C D7 42 7D F6 92 2F B0 CC 0C 6E D5 20 EF
5C 73 AE 4A A3 13 66 9E CE 7E
16 : 37 : 27 <====Rx METER-2 D4 81 E6 20 00 00 01 77 0A 7B 1C FA 46 F2 F4 A8 32 02 5C 34 0D E8 F6 CF DD A1 90 17 37 EF 8D AF D7 41 E2 FB DF AF E9 0C
E2 6C 64 14 45 23 1A 48 67 B3 57 54 B4 E7 02 5F 97 42 DD DB 6A 32 E9 83 07 6A BA 58 CF 1C 00 C0 C7 EC FD 4A 7F B7 77 AB
FC 6C D7 59 80 E5 AC AB 36 33 87 5F 4E D0 84 61 DB 32 0B 26 84 CC 45 EC 02 D2 8D 38 2C 45 C7 DC 03 0E 76 6D 13 5B 82 EF
7D D6 D9 D3 4E 33 DE 9C A6 24 CB 58 6E 05 94 1C 1C 75 B9 A7 11 B2 BA 5D EE 39 A8 60 E5 2C 61 C8 BA 12 87 4E 7E 38 1D FF
7B 69 C0 B4 23 84 20 46 4E 5E 66 86 D9 52 3A 94 7B EB 3A C5 28 5B 69 D3 C9 CE E5 BD 82 46 4F D4 FB 06 A9 C4 3B 89 75 79
65 07 9F 91 94 2A D9 C7 38 50 8B 87 4C D7 42 7D F6 92 2F B0 CC 0C 6E D5 20 EF 5C 73 AE 4A A3 13 66
16 : 37 : 27 <====Rx METER-2 D4 81 E6 20 00 00 01 77 C4 02 81 00 00 00 00 23 00 81 D6 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 13 02 00 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 13 02 00 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 13 02 00 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 13 02 01 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 13 02 01 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
16 : 37 : 27 ====>Tx METER-2 D0 0C 20 00 00 01 77 C0 02 C1 00 00 00 23
16 : 37 : 27 ====>Tx METER-2 D0 0C 20 00 00 01 77 20 90 EA 1C DB D2 DB
16 : 37 : 27 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 01 77 20 90 EA 1C DB D2 DB AD 46 7E
16 : 37 : 27 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 01 78 48 97 AA F2 99 D1 67 82 BD BA 3A 93 D9 BA DF 53 ED C0
8F 1C A2 7B 43 DC 85 33 DF FB 31 59 5E 0A 66 0F 9C AA 21 23 B3 FE 64 B8 84 EE 9D 3D 14 69 63 83 05 0F BB 3D D5 33 3B 33
77 07 3B F2 D8 58 63 6C 13 52 D4 89 EA C4 10 32 A5 D5 6C AA B5 12 CA 4C 8F 8C EB 5E 2D FA 5C A1 06 8E F1 B6 71 AD 5C 97
10 0D E3 6D 16 1C C8 A0 ED FF ED 18 A6 A6 80 A4 95 EB 40 FB 50 0D 38 4D AC 7D 64 BC 45 DA 25 51 02 5F 84 2C D3 50 D1 FD
56 1D 06 88 AD 74 D2 A3 E7 13 20 AE CB 4A B0 A9 BA 53 FC A7 6E C0 87 5A AA A8 75 58 36 0E FD 6A 4E 29 7A 1E 12 FE 26 9A
78 FE AD 8C 0F D4 E7 F5 42 97 B9 D5 4F 51 82 C7 BD 59 A7 FE 89 9B D4 50 CA 1F AE 5E 07 3F F4 9F 06 A9 10 2B F2 24 3C A9
63 9E 62 DD B1 99 10 2B 3A 7E
16 : 37 : 27 <====Rx METER-2 D4 81 E6 20 00 00 01 78 48 97 AA F2 99 D1 67 82 BD BA 3A 93 D9 BA DF 53 ED C0 8F 1C A2 7B 43 DC 85 33 DF FB 31 59 5E 0A
66 0F 9C AA 21 23 B3 FE 64 B8 84 EE 9D 3D 14 69 63 83 05 0F BB 3D D5 33 3B 33 77 07 3B F2 D8 58 63 6C 13 52 D4 89 EA C4
10 32 A5 D5 6C AA B5 12 CA 4C 8F 8C EB 5E 2D FA 5C A1 06 8E F1 B6 71 AD 5C 97 10 0D E3 6D 16 1C C8 A0 ED FF ED 18 A6 A6
80 A4 95 EB 40 FB 50 0D 38 4D AC 7D 64 BC 45 DA 25 51 02 5F 84 2C D3 50 D1 FD 56 1D 06 88 AD 74 D2 A3 E7 13 20 AE CB 4A
B0 A9 BA 53 FC A7 6E C0 87 5A AA A8 75 58 36 0E FD 6A 4E 29 7A 1E 12 FE 26 9A 78 FE AD 8C 0F D4 E7 F5 42 97 B9 D5 4F 51
82 C7 BD 59 A7 FE 89 9B D4 50 CA 1F AE 5E 07 3F F4 9F 06 A9 10 2B F2 24 3C A9 63 9E 62 DD B1 99 10
16 : 37 : 27 <====Rx METER-2 D4 81 E6 20 00 00 01 78 C4 02 81 00 00 00 00 24 00 81 D6 02 09 09 0C 07 E3 0B 13 02 01 1E 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 01 2D 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 02 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 02 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 02 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 02 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
16 : 37 : 27 ====>Tx METER-2 D0 0C 20 00 00 01 78 C0 02 C1 00 00 00 24
16 : 37 : 27 ====>Tx METER-2 D0 0C 20 00 00 01 78 49 32 D4 FA 6E 54 51
16 : 37 : 27 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 01 78 49 32 D4 FA 6E 54 51 FF 90 7E
16 : 37 : 27 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 01 79 05 FE 16 F7 77 5E 6F BC BD 47 39 5C D7 1C 60 EA BF 25
CC 7B 43 C7 90 00 2D D9 A7 2A 39 8C 6A 62 86 5A A1 1B 42 C5 74 EC AE DE 59 A0 2F E5 CD 1D D8 8B D7 17 AB 77 6B 9C 0F BA
9D 9B CD 79 5A D7 31 51 CA 7C 6B 4E 5F A0 52 34 1D 05 04 79 D4 BB AA 01 77 9B EF C6 E3 0F DA 66 D7 ED FE 65 0D 94 21 03
E7 4A 92 F3 0D 55 A7 78 FA B0 6E 6D C4 41 7E 5D CF CC F5 BC A5 40 CD 58 55 04 D8 91 40 73 00 A1 1A 7E 9E 6F 0A 03 86 75
35 FC B2 67 03 17 49 F0 07 19 89 EE 04 CD 5E 66 C2 1B 7B A3 AD 77 66 A3 51 99 E7 F3 B4 F7 83 1F EC B7 CF 8B AA B1 3C E1
B3 9B FB E3 5C 9C D8 D4 57 FE 87 3D 0D 54 49 53 69 9E 76 49 8B 10 01 D2 64 18 0A 52 04 B1 52 D6 47 C3 6B 3B CF 1C 20 CF
E0 3E 35 61 18 B7 FF 39 73 7E
16 : 37 : 27 <====Rx METER-2 D4 81 E6 20 00 00 01 79 05 FE 16 F7 77 5E 6F BC BD 47 39 5C D7 1C 60 EA BF 25 CC 7B 43 C7 90 00 2D D9 A7 2A 39 8C 6A 62
86 5A A1 1B 42 C5 74 EC AE DE 59 A0 2F E5 CD 1D D8 8B D7 17 AB 77 6B 9C 0F BA 9D 9B CD 79 5A D7 31 51 CA 7C 6B 4E 5F A0
52 34 1D 05 04 79 D4 BB AA 01 77 9B EF C6 E3 0F DA 66 D7 ED FE 65 0D 94 21 03 E7 4A 92 F3 0D 55 A7 78 FA B0 6E 6D C4 41
7E 5D CF CC F5 BC A5 40 CD 58 55 04 D8 91 40 73 00 A1 1A 7E 9E 6F 0A 03 86 75 35 FC B2 67 03 17 49 F0 07 19 89 EE 04 CD
5E 66 C2 1B 7B A3 AD 77 66 A3 51 99 E7 F3 B4 F7 83 1F EC B7 CF 8B AA B1 3C E1 B3 9B FB E3 5C 9C D8 D4 57 FE 87 3D 0D 54
49 53 69 9E 76 49 8B 10 01 D2 64 18 0A 52 04 B1 52 D6 47 C3 6B 3B CF 1C 20 CF E0 3E 35 61 18 B7 FF
16 : 37 : 27 <====Rx METER-2 D4 81 E6 20 00 00 01 79 C4 02 81 00 00 00 00 25 00 81 D6 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
13 02 03 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02
03 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 03 1E
00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 03 2D 00 FF
01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 04 00 00 FF 01 4A
16 : 37 : 27 ====>Tx METER-2 D0 0C 20 00 00 01 79 C0 02 C1 00 00 00 25
16 : 37 : 27 ====>Tx METER-2 D0 0C 20 00 00 01 79 BD 04 FD 0E 05 F1 A4
16 : 37 : 27 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 01 79 BD 04 FD 0E 05 F1 A4 F1 5F 7E
16 : 37 : 27 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 01 7A 4F F8 0B 6D B1 9A B7 6B 23 94 00 79 36 E3 79 0C B2 21
49 53 F1 ED F0 42 D0 7F 6D C7 D9 03 66 95 21 46 C3 72 52 26 8D AE 60 1E 83 F8 8C E3 6E 3F 1A 46 8C FD 34 C8 21 2A 18 B8
AE FA 19 A8 D6 F7 52 DA 50 7D 47 A4 CA 25 78 66 00 48 99 3D 1C 0C 14 5A 49 2C 73 54 7F FA EF 93 E4 8E 69 15 44 19 17 C8
16 B2 9D 0A 27 C0 5F 29 38 9E E2 D1 7B DD 3E D6 F6 24 E6 C2 82 19 6A 83 A6 2C 3A 0A 92 DE CD 3C FE AC 6C 53 DE 11 D8 54
E0 CF 38 DC 65 50 83 24 61 23 51 F5 A1 2D 0B 55 C5 06 C7 03 DE 8F DE 1B 20 5C AE 30 46 5A 2D 5D 69 4A BA 0A 31 29 BC 54
E7 83 CE C3 4F D1 37 AE 96 34 CE 35 DE B2 1C 56 A1 82 E8 D6 00 3A D4 E5 8B 94 D1 A3 1D D8 BD 80 C4 29 EC 71 6C 3A AB E4
D0 FD DF FC 26 36 F8 86 30 7E
16 : 37 : 27 <====Rx METER-2 D4 81 E6 20 00 00 01 7A 4F F8 0B 6D B1 9A B7 6B 23 94 00 79 36 E3 79 0C B2 21 49 53 F1 ED F0 42 D0 7F 6D C7 D9 03 66 95
21 46 C3 72 52 26 8D AE 60 1E 83 F8 8C E3 6E 3F 1A 46 8C FD 34 C8 21 2A 18 B8 AE FA 19 A8 D6 F7 52 DA 50 7D 47 A4 CA 25
78 66 00 48 99 3D 1C 0C 14 5A 49 2C 73 54 7F FA EF 93 E4 8E 69 15 44 19 17 C8 16 B2 9D 0A 27 C0 5F 29 38 9E E2 D1 7B DD
3E D6 F6 24 E6 C2 82 19 6A 83 A6 2C 3A 0A 92 DE CD 3C FE AC 6C 53 DE 11 D8 54 E0 CF 38 DC 65 50 83 24 61 23 51 F5 A1 2D
0B 55 C5 06 C7 03 DE 8F DE 1B 20 5C AE 30 46 5A 2D 5D 69 4A BA 0A 31 29 BC 54 E7 83 CE C3 4F D1 37 AE 96 34 CE 35 DE B2
1C 56 A1 82 E8 D6 00 3A D4 E5 8B 94 D1 A3 1D D8 BD 80 C4 29 EC 71 6C 3A AB E4 D0 FD DF FC 26 36 F8
16 : 37 : 28 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 37 : 28 <====Rx METER-2 D4 81 E6 20 00 00 01 7A C4 02 81 00 00 00 00 26 00 81 D6 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 04 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 04 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 13 02 05 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 13 02 05 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 13 02 05 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
16 : 37 : 28 METER-2 SERVICE = GET RESPONSE
16 : 37 : 28 METER-2 COSEM OUT DATA
16 : 37 : 28 ====>Tx METER-2 D0 0C 20 00 00 01 7A C0 02 C1 00 00 00 26
16 : 37 : 28 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 28 ====>Tx METER-2 D0 0C 20 00 00 01 7A EF 3F 96 D7 F0 E0 83
16 : 37 : 28 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 28 METER-2 SENDING HDLC FRAME
16 : 37 : 28 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 01 7A EF 3F 96 D7 F0 E0 83 99 F1 7E
16 : 37 : 28 METER-2 RECEIVED HDLC FRAME
16 : 37 : 28 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 01 7B 1F 92 6B 76 50 57 6F 57 50 B9 DC 06 94 95 D4 4D AC CF
97 07 26 E5 A1 14 94 42 7D 87 94 5F 63 8A CA B9 05 1D FE AB AA CA 76 2C A6 06 9B 32 6D CA 83 D6 3A AB 30 E6 F9 20 62 97
99 60 C7 FD 66 33 4C EE BC 72 7A A1 50 D9 EE D4 7F 10 C4 9B 42 3F E4 CA D0 14 9E D8 85 99 20 BD 16 DA 10 67 F2 46 87 BB
B7 27 0E 89 8A F9 61 29 62 19 9E 55 0E 5A DE F6 55 84 6A DF EF B6 B4 6E 33 59 DA 62 EF BD 96 C0 CE 8B 41 AA 31 67 39 1F
BC 91 06 7C 1D 47 94 AC 1D B0 8F E4 5B 4E 36 2A 3E C5 58 7F C0 6D 81 4A 86 46 6E F4 AD EE 8E 79 F8 74 53 E2 2F 46 77 ED
19 29 7F 3C 0D D2 EF CB 86 59 AF 40 2A 2C 31 74 BA F0 B2 B4 06 D2 E0 67 0B DB 82 8E 23 B0 3C 85 E6 32 1F E7 39 DE C4 0F
A8 48 A4 3F 8A 8C FF 2F F9 7E
16 : 37 : 28 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 28 <====Rx METER-2 D4 81 E6 20 00 00 01 7B 1F 92 6B 76 50 57 6F 57 50 B9 DC 06 94 95 D4 4D AC CF 97 07 26 E5 A1 14 94 42 7D 87 94 5F 63 8A
CA B9 05 1D FE AB AA CA 76 2C A6 06 9B 32 6D CA 83 D6 3A AB 30 E6 F9 20 62 97 99 60 C7 FD 66 33 4C EE BC 72 7A A1 50 D9
EE D4 7F 10 C4 9B 42 3F E4 CA D0 14 9E D8 85 99 20 BD 16 DA 10 67 F2 46 87 BB B7 27 0E 89 8A F9 61 29 62 19 9E 55 0E 5A
DE F6 55 84 6A DF EF B6 B4 6E 33 59 DA 62 EF BD 96 C0 CE 8B 41 AA 31 67 39 1F BC 91 06 7C 1D 47 94 AC 1D B0 8F E4 5B 4E
36 2A 3E C5 58 7F C0 6D 81 4A 86 46 6E F4 AD EE 8E 79 F8 74 53 E2 2F 46 77 ED 19 29 7F 3C 0D D2 EF CB 86 59 AF 40 2A 2C
31 74 BA F0 B2 B4 06 D2 E0 67 0B DB 82 8E 23 B0 3C 85 E6 32 1F E7 39 DE C4 0F A8 48 A4 3F 8A 8C FF
16 : 37 : 28 <====Rx METER-2 D4 81 E6 20 00 00 01 7B C4 02 81 00 00 00 00 27 00 81 D6 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 05 2D 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 06 00 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 06 0F 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 06 1E 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 06 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 07 00 00 FF 01 4A 00 12 00 00 12
16 : 37 : 28 ====>Tx METER-2 D0 0C 20 00 00 01 7B C0 02 C1 00 00 00 27
16 : 37 : 28 ====>Tx METER-2 D0 0C 20 00 00 01 7B A9 CD 23 F2 8C C3 A9
16 : 37 : 28 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 01 7B A9 CD 23 F2 8C C3 A9 B4 1C 7E
16 : 37 : 28 <====Rx METER-2 7E A0 F8 41 00 02 04 01 B8 2A CB E6 E7 00 D4 81 E6 20 00 00 01 7C 10 88 0C A7 DF 4C F7 19 7B 73 25 05 DC 07 6E 0C 87 F2
C3 A5 C9 B3 15 51 AE 5B CD E6 6C 5E A8 AF 82 46 3B 83 1E 8E 59 30 CA 89 D3 4D 8C AE 6E 42 E5 73 2C 0E E3 01 20 41 E1 30
D2 EE E2 62 01 89 6F B0 88 CD E4 97 8A A3 FD B5 CD 52 15 45 85 A3 00 07 53 D2 EA 35 C0 82 9E 2B 16 99 DC 15 31 C3 51 A4
D8 10 B9 30 22 12 6E B0 22 D4 24 8E 3D A1 1F B0 21 11 51 36 46 89 4B 0E 38 71 45 7B B5 94 43 F7 A5 18 07 A4 71 FF AC 45
79 6E 8D DF 6F 00 8A 8D ED 04 F5 BB 46 54 4C C7 BB C9 90 97 CF DC 82 66 F6 62 B2 65 BC 31 50 94 9F B5 DF E3 06 DC AD 03
EA D1 E3 F6 33 61 19 3D 05 A7 B8 FA 8E B0 E7 AF C2 FF 4B 44 AE 70 08 87 BA 1D 89 36 B5 79 CB 5F 7F FC 5F EF F2 7D 80 AB
05 EC 23 05 E2 45 B3 3A 60 7E
16 : 37 : 28 <====Rx METER-2 D4 81 E6 20 00 00 01 7C 10 88 0C A7 DF 4C F7 19 7B 73 25 05 DC 07 6E 0C 87 F2 C3 A5 C9 B3 15 51 AE 5B CD E6 6C 5E A8 AF
82 46 3B 83 1E 8E 59 30 CA 89 D3 4D 8C AE 6E 42 E5 73 2C 0E E3 01 20 41 E1 30 D2 EE E2 62 01 89 6F B0 88 CD E4 97 8A A3
FD B5 CD 52 15 45 85 A3 00 07 53 D2 EA 35 C0 82 9E 2B 16 99 DC 15 31 C3 51 A4 D8 10 B9 30 22 12 6E B0 22 D4 24 8E 3D A1
1F B0 21 11 51 36 46 89 4B 0E 38 71 45 7B B5 94 43 F7 A5 18 07 A4 71 FF AC 45 79 6E 8D DF 6F 00 8A 8D ED 04 F5 BB 46 54
4C C7 BB C9 90 97 CF DC 82 66 F6 62 B2 65 BC 31 50 94 9F B5 DF E3 06 DC AD 03 EA D1 E3 F6 33 61 19 3D 05 A7 B8 FA 8E B0
E7 AF C2 FF 4B 44 AE 70 08 87 BA 1D 89 36 B5 79 CB 5F 7F FC 5F EF F2 7D 80 AB 05 EC 23 05 E2 45 B3
16 : 37 : 28 <====Rx METER-2 D4 81 E6 20 00 00 01 7C C4 02 81 00 00 00 00 28 00 81 D6 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 13 02 07 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 13 02 07 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
13 02 07 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02
08 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 08 0F
16 : 37 : 28 ====>Tx METER-2 D0 0C 20 00 00 01 7C C0 02 C1 00 00 00 28
16 : 37 : 28 ====>Tx METER-2 D0 0C 20 00 00 01 7C 4C E9 2A A6 10 EC 94
16 : 37 : 28 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 BA 30 1E E6 E6 00 D0 0C 20 00 00 01 7C 4C E9 2A A6 10 EC 94 94 57 7E
16 : 37 : 28 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 01 7D B5 5D B5 99 0D 1E 94 A9 60 50 F2 46 35 72 16 73 6E B3
A0 30 7D 0A 2F 8F 87 67 B4 8F E5 83 9C 31 54 B7 AD 1C 09 14 D2 80 F8 D7 C4 22 4B 1F 59 8D 98 AA 02 1E 27 C8 0E F6 17 BC
57 AE 94 ED F7 D1 66 3F 1E B8 4B 00 44 B3 30 51 ED 09 86 46 82 34 22 1A 3A CB 4D 88 EC 44 BC EB 90 C0 8A C0 D3 CA 39 E8
4D BC D0 03 76 7B 9D 75 D2 4E 2F 6C 61 29 AB DA FB 40 D2 89 8C 57 42 1E 6F AB 5D F1 38 B1 51 46 C2 02 F8 99 1E FE 79 FE
2E 79 17 6A 8C 6B 1F 92 94 D2 25 9E C5 F0 75 C6 1D 01 9C 43 04 34 30 79 41 A9 D6 48 B9 B8 34 A2 4A D0 FB B3 9E 6F 7A 18
E1 49 8A 52 08 2F F5 79 D2 B9 1E D7 A4 DF 39 8E 9B DA F9 42 54 83 F9 CE 3E 2D 44 E8 1C E7 7C E9 51 90 CB EE 77 A0 91 28
23 64 24 E1 19 E0 81 47 E0 7E
16 : 37 : 28 <====Rx METER-2 D4 81 E6 20 00 00 01 7D B5 5D B5 99 0D 1E 94 A9 60 50 F2 46 35 72 16 73 6E B3 A0 30 7D 0A 2F 8F 87 67 B4 8F E5 83 9C 31
54 B7 AD 1C 09 14 D2 80 F8 D7 C4 22 4B 1F 59 8D 98 AA 02 1E 27 C8 0E F6 17 BC 57 AE 94 ED F7 D1 66 3F 1E B8 4B 00 44 B3
30 51 ED 09 86 46 82 34 22 1A 3A CB 4D 88 EC 44 BC EB 90 C0 8A C0 D3 CA 39 E8 4D BC D0 03 76 7B 9D 75 D2 4E 2F 6C 61 29
AB DA FB 40 D2 89 8C 57 42 1E 6F AB 5D F1 38 B1 51 46 C2 02 F8 99 1E FE 79 FE 2E 79 17 6A 8C 6B 1F 92 94 D2 25 9E C5 F0
75 C6 1D 01 9C 43 04 34 30 79 41 A9 D6 48 B9 B8 34 A2 4A D0 FB B3 9E 6F 7A 18 E1 49 8A 52 08 2F F5 79 D2 B9 1E D7 A4 DF
39 8E 9B DA F9 42 54 83 F9 CE 3E 2D 44 E8 1C E7 7C E9 51 90 CB EE 77 A0 91 28 23 64 24 E1 19 E0 81
16 : 37 : 28 <====Rx METER-2 D4 81 E6 20 00 00 01 7D C4 02 81 00 00 00 00 29 00 81 D6 0B 13 02 08 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 08 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 09 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 09 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 09 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 13 02 09 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
16 : 37 : 28 ====>Tx METER-2 D0 0C 20 00 00 01 7D C0 02 C1 00 00 00 29
16 : 37 : 28 ====>Tx METER-2 D0 0C 20 00 00 01 7D B6 78 28 1B A9 A5 10
16 : 37 : 28 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 01 7D B6 78 28 1B A9 A5 10 81 52 7E
16 : 37 : 28 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 01 7E 04 75 7E 91 53 E4 5D 7C 4A 80 AF FC FF 8C 3A 47 10 6F
46 C0 F7 82 C5 3B 73 F3 E3 F6 6F 55 D2 19 B1 2E 56 E3 82 50 62 BA 99 AA F4 86 CB 07 98 E1 D2 86 2B 24 D9 B0 72 77 23 31
F8 7B 3B 4B 77 A3 07 D2 3C 00 68 1C D4 CB D8 4D 8E 37 9F D5 93 93 DA 75 62 F0 B0 2A 7B 50 A7 48 68 44 D1 C3 01 68 C9 54
83 37 4C 40 1A 11 F2 15 A7 76 33 C8 49 C6 3A 1C E7 73 6C 5B F3 4A 85 50 D2 12 A1 93 EF 37 32 8D C1 E0 14 AB FC 17 EE F5
D0 77 33 FC 3C AE CB B9 B9 F5 8D A0 E7 13 00 8C 92 30 63 9C 57 80 60 3E 25 87 98 E4 EB 16 64 C9 DE 7E 42 D2 8D C1 3A AB
A4 F0 66 E8 B8 86 D0 22 FC 14 12 66 3E 07 94 4A 74 7D A8 02 68 01 4D 1A 19 95 A4 FD 63 47 58 FE 45 CA 15 80 24 F8 0D 6B
85 9E 42 02 4B C8 30 10 7D 7E
16 : 37 : 28 <====Rx METER-2 D4 81 E6 20 00 00 01 7E 04 75 7E 91 53 E4 5D 7C 4A 80 AF FC FF 8C 3A 47 10 6F 46 C0 F7 82 C5 3B 73 F3 E3 F6 6F 55 D2 19
B1 2E 56 E3 82 50 62 BA 99 AA F4 86 CB 07 98 E1 D2 86 2B 24 D9 B0 72 77 23 31 F8 7B 3B 4B 77 A3 07 D2 3C 00 68 1C D4 CB
D8 4D 8E 37 9F D5 93 93 DA 75 62 F0 B0 2A 7B 50 A7 48 68 44 D1 C3 01 68 C9 54 83 37 4C 40 1A 11 F2 15 A7 76 33 C8 49 C6
3A 1C E7 73 6C 5B F3 4A 85 50 D2 12 A1 93 EF 37 32 8D C1 E0 14 AB FC 17 EE F5 D0 77 33 FC 3C AE CB B9 B9 F5 8D A0 E7 13
00 8C 92 30 63 9C 57 80 60 3E 25 87 98 E4 EB 16 64 C9 DE 7E 42 D2 8D C1 3A AB A4 F0 66 E8 B8 86 D0 22 FC 14 12 66 3E 07
94 4A 74 7D A8 02 68 01 4D 1A 19 95 A4 FD 63 47 58 FE 45 CA 15 80 24 F8 0D 6B 85 9E 42 02 4B C8 30
16 : 37 : 28 <====Rx METER-2 D4 81 E6 20 00 00 01 7E C4 02 81 00 00 00 00 2A 00 81 D6 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0A 00 00 FF
01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0A 0F 00 FF 01 4A
00 12 2E 20 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 08 02 09 09 0C 07 E3 0B 13 02 0A 1E 00 FF 01 4A 00 12
2F 14 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 09 02 09 09 0C 07 E3 0B 13 02 0A 2D 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0B 00 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0B 0F 00 FF 01 4A 00
16 : 37 : 29 METER-2 COSEM OUT DATA
16 : 37 : 29 ====>Tx METER-2 D0 0C 20 00 00 01 7E C0 02 C1 00 00 00 2A
16 : 37 : 29 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 29 ====>Tx METER-2 D0 0C 20 00 00 01 7E 31 0D E0 09 88 DC 03
16 : 37 : 29 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 29 METER-2 SENDING HDLC FRAME
16 : 37 : 29 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 01 7E 31 0D E0 09 88 DC 03 73 FF 7E
16 : 37 : 29 METER-2 RECEIVED HDLC FRAME
16 : 37 : 29 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 01 7F 04 8C AE 6D 07 D8 9A 41 25 A7 D4 C2 92 D7 6A 2D 2E 41
06 95 A0 43 36 9F 20 2A B4 03 38 FC 9B 25 7F 0E 82 72 3F 2E 61 FC 20 24 80 D1 22 67 58 CC 04 85 A1 3D 2E 8F 16 51 51 B0
62 42 BC 4E D0 12 9F 0D 93 73 DE FC BA 76 16 E5 DE F5 A3 1D CD 87 F8 95 D5 01 20 A6 78 40 A6 31 F8 68 9D 7C 67 20 58 78
76 C5 1B 4F 2E EE D0 34 12 5E 07 D4 C0 9E AD D2 C9 DD 8A 6C 3D 74 C2 09 49 35 DD 02 E2 CC DA 9F 5C B5 F1 65 C5 E7 63 11
21 15 17 12 00 F0 E0 01 20 05 54 AE BD 9F 34 DC 6D 2F 11 45 52 26 40 D4 43 6B D3 A6 DC 91 9D 88 5F C5 80 1E 97 BA E2 04
0D 75 DD AE 66 6C A5 0A BB D2 6C C4 F9 B4 50 93 68 DC EB CF 47 4D ED E9 82 1D DF 52 F6 B5 14 FE A7 25 8A F5 72 FD F6 CA
DB 20 58 F1 D5 2D CC 6A 99 7E
16 : 37 : 29 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 29 <====Rx METER-2 D4 81 E6 20 00 00 01 7F 04 8C AE 6D 07 D8 9A 41 25 A7 D4 C2 92 D7 6A 2D 2E 41 06 95 A0 43 36 9F 20 2A B4 03 38 FC 9B 25
7F 0E 82 72 3F 2E 61 FC 20 24 80 D1 22 67 58 CC 04 85 A1 3D 2E 8F 16 51 51 B0 62 42 BC 4E D0 12 9F 0D 93 73 DE FC BA 76
16 E5 DE F5 A3 1D CD 87 F8 95 D5 01 20 A6 78 40 A6 31 F8 68 9D 7C 67 20 58 78 76 C5 1B 4F 2E EE D0 34 12 5E 07 D4 C0 9E
AD D2 C9 DD 8A 6C 3D 74 C2 09 49 35 DD 02 E2 CC DA 9F 5C B5 F1 65 C5 E7 63 11 21 15 17 12 00 F0 E0 01 20 05 54 AE BD 9F
34 DC 6D 2F 11 45 52 26 40 D4 43 6B D3 A6 DC 91 9D 88 5F C5 80 1E 97 BA E2 04 0D 75 DD AE 66 6C A5 0A BB D2 6C C4 F9 B4
50 93 68 DC EB CF 47 4D ED E9 82 1D DF 52 F6 B5 14 FE A7 25 8A F5 72 FD F6 CA DB 20 58 F1 D5 2D CC
16 : 37 : 29 <====Rx METER-2 D4 81 E6 20 00 00 01 7F C4 02 81 00 00 00 00 2B 00 81 D6 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 13 02 0B 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 13 02 0B 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 13 02 0C 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 13 02 0C 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
13 02 0C 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
16 : 37 : 29 METER-2 SERVICE = GET RESPONSE
16 : 37 : 29 ====>Tx METER-2 D0 0C 20 00 00 01 7F C0 02 C1 00 00 00 2B
16 : 37 : 29 ====>Tx METER-2 D0 0C 20 00 00 01 7F 88 30 EE CF ED A4 78
16 : 37 : 29 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 01 7F 88 30 EE CF ED A4 78 F6 43 7E
16 : 37 : 29 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 01 80 7E 8D C5 68 51 F7 D3 20 D6 E9 43 40 04 19 32 0E CE E1
42 72 EE 76 EC 61 C9 1E 70 33 D7 59 45 0D 35 B2 8D 8D C6 C2 D3 DC 59 30 DE 8A 31 BA 18 B1 44 3F 9A 79 3E 6D 74 E7 7D 51
68 C0 89 06 4B 86 92 D6 7C 98 9B 18 4F BA 6B 57 E3 C4 F7 FF 2C F9 C6 C6 59 02 0F 00 11 3F 3D F7 CF 80 76 5B 55 10 3B B7
3A D2 78 28 89 33 16 B5 92 FF 0E EE 85 4D C3 6B 74 6D 5A 2D 49 C4 CB 23 86 68 5E 83 93 A1 56 1D 7A 82 71 E3 0F 95 71 97
2F 73 FD 61 D2 E5 DF 3C 8A 19 10 C0 58 8C DF 4A BF 47 1C BB 03 47 E3 1C E7 C7 62 9B 41 72 A5 27 00 FE 11 F5 AE 19 01 F8
6D 24 2C E3 5A 4E A8 8D A6 98 B2 1E 3B A4 C9 C1 C1 90 FE 35 0B ED 57 C6 5F EB FE 5A F2 F4 B1 49 68 43 A4 22 C2 EC 8E 3F
F9 2C 89 B0 38 FE 27 E2 F0 7E
16 : 37 : 29 <====Rx METER-2 D4 81 E6 20 00 00 01 80 7E 8D C5 68 51 F7 D3 20 D6 E9 43 40 04 19 32 0E CE E1 42 72 EE 76 EC 61 C9 1E 70 33 D7 59 45 0D
35 B2 8D 8D C6 C2 D3 DC 59 30 DE 8A 31 BA 18 B1 44 3F 9A 79 3E 6D 74 E7 7D 51 68 C0 89 06 4B 86 92 D6 7C 98 9B 18 4F BA
6B 57 E3 C4 F7 FF 2C F9 C6 C6 59 02 0F 00 11 3F 3D F7 CF 80 76 5B 55 10 3B B7 3A D2 78 28 89 33 16 B5 92 FF 0E EE 85 4D
C3 6B 74 6D 5A 2D 49 C4 CB 23 86 68 5E 83 93 A1 56 1D 7A 82 71 E3 0F 95 71 97 2F 73 FD 61 D2 E5 DF 3C 8A 19 10 C0 58 8C
DF 4A BF 47 1C BB 03 47 E3 1C E7 C7 62 9B 41 72 A5 27 00 FE 11 F5 AE 19 01 F8 6D 24 2C E3 5A 4E A8 8D A6 98 B2 1E 3B A4
C9 C1 C1 90 FE 35 0B ED 57 C6 5F EB FE 5A F2 F4 B1 49 68 43 A4 22 C2 EC 8E 3F F9 2C 89 B0 38 FE 27
16 : 37 : 29 <====Rx METER-2 D4 81 E6 20 00 00 01 80 C4 02 81 00 00 00 00 2C 00 81 D6 09 0C 07 E3 0B 13 02 0C 2D 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0D 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0D 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0D 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0D 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0E 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
16 : 37 : 29 ====>Tx METER-2 D0 0C 20 00 00 01 80 C0 02 C1 00 00 00 2C
16 : 37 : 29 ====>Tx METER-2 D0 0C 20 00 00 01 80 77 DB B7 45 0D 6A D8
16 : 37 : 29 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 01 80 77 DB B7 45 0D 6A D8 9B B9 7E
16 : 37 : 29 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 01 81 F0 B0 B5 14 8D 98 83 F0 E3 2F 25 65 A0 8F D2 12 C3 83
69 D7 85 81 F5 B1 5D F2 5B 8F 4D 22 06 56 82 6B B9 A1 45 9D 4F 23 75 A9 A3 38 F7 A3 47 19 FD 6C EE E4 1D EF 05 6F 0B FA
8A 6D 37 AB 00 B4 7B 60 19 D7 1A 1E 29 85 11 32 D0 2B 63 6C 10 22 4E E1 4A 71 69 EE A9 06 FA B1 87 72 60 EF 04 C7 74 F6
6C 67 89 BE 5B 9B CD 2E BB FE D2 3D 46 AA 85 FF F5 16 DC 83 64 F8 DD 92 F3 93 BF 2D 6F 2F E1 C8 F4 AA 13 50 F2 F2 5E 0F
53 4D EB 17 1A 65 7D 4B EC B4 C6 55 28 B2 B8 6C 3B CF D6 91 EC C9 E1 AD 91 9C 75 39 87 E7 5D 0A 95 EA E0 3A 36 08 5B 37
9D 2D DA 6A DF 14 A5 EA 3F F7 5D 1F 80 6E 32 08 B1 38 B6 8F C0 D3 B6 13 73 00 28 0F 19 2C 24 F5 E5 26 3F 36 E1 A3 6B 45
97 8E 67 CA 38 2B EB EE 4D 7E
16 : 37 : 29 <====Rx METER-2 D4 81 E6 20 00 00 01 81 F0 B0 B5 14 8D 98 83 F0 E3 2F 25 65 A0 8F D2 12 C3 83 69 D7 85 81 F5 B1 5D F2 5B 8F 4D 22 06 56
82 6B B9 A1 45 9D 4F 23 75 A9 A3 38 F7 A3 47 19 FD 6C EE E4 1D EF 05 6F 0B FA 8A 6D 37 AB 00 B4 7B 60 19 D7 1A 1E 29 85
11 32 D0 2B 63 6C 10 22 4E E1 4A 71 69 EE A9 06 FA B1 87 72 60 EF 04 C7 74 F6 6C 67 89 BE 5B 9B CD 2E BB FE D2 3D 46 AA
85 FF F5 16 DC 83 64 F8 DD 92 F3 93 BF 2D 6F 2F E1 C8 F4 AA 13 50 F2 F2 5E 0F 53 4D EB 17 1A 65 7D 4B EC B4 C6 55 28 B2
B8 6C 3B CF D6 91 EC C9 E1 AD 91 9C 75 39 87 E7 5D 0A 95 EA E0 3A 36 08 5B 37 9D 2D DA 6A DF 14 A5 EA 3F F7 5D 1F 80 6E
32 08 B1 38 B6 8F C0 D3 B6 13 73 00 28 0F 19 2C 24 F5 E5 26 3F 36 E1 A3 6B 45 97 8E 67 CA 38 2B EB
16 : 37 : 29 <====Rx METER-2 D4 81 E6 20 00 00 01 81 C4 02 81 00 00 00 00 2D 00 81 D6 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02
0E 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0E 1E
00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0E 2D 00 FF
01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0F 00 00 FF 01 4A
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0F 0F 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0F 1E 00
16 : 37 : 29 ====>Tx METER-2 D0 0C 20 00 00 01 81 C0 02 C1 00 00 00 2D
16 : 37 : 29 ====>Tx METER-2 D0 0C 20 00 00 01 81 95 BF 36 40 80 60 F7
16 : 37 : 29 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 01 81 95 BF 36 40 80 60 F7 4A 82 7E
16 : 37 : 29 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 01 82 9B 4D 74 B9 3D DD BD 9A 38 5C D9 77 F5 41 C8 18 F2 2D
BE BC 91 38 5C 9D 67 7F 11 AC D8 15 AA FC E1 84 45 DB D4 0E B0 B4 7D C6 6E 73 7F 0C 38 2D 6A 87 63 E0 06 D5 A5 E9 B6 D9
A1 08 BE 61 BE 53 B6 F5 F7 49 87 6F D7 AC 28 66 16 C1 76 E5 D1 57 82 CC F0 E0 C4 F5 53 8E 47 EE 77 EA 6A 17 3B D1 E9 53
C3 B7 4F 72 03 81 F7 C0 48 A5 82 BE 42 9F 82 85 97 ED B6 F7 87 6D 74 54 76 A3 1E 1F BA F7 D6 36 9A ED B8 D0 3A 9C 31 E3
9F 6E 58 EE 7A EF CB F7 AF 1F 0D 8B 40 E9 AE 61 5F 40 AA 21 BF EE F7 D2 2B E1 D3 19 33 46 81 EE 6E 59 62 C7 68 2C 05 D5
AB FB 5A 6A 10 66 1B 51 12 68 80 29 C9 EF 57 A6 F8 CA 07 34 F6 84 C9 EA 36 CD E6 C2 46 CC 77 A3 5C E2 7A 09 B9 1A 62 CE
42 02 D5 0F 54 39 A6 2E 73 7E
16 : 37 : 29 <====Rx METER-2 D4 81 E6 20 00 00 01 82 9B 4D 74 B9 3D DD BD 9A 38 5C D9 77 F5 41 C8 18 F2 2D BE BC 91 38 5C 9D 67 7F 11 AC D8 15 AA FC
E1 84 45 DB D4 0E B0 B4 7D C6 6E 73 7F 0C 38 2D 6A 87 63 E0 06 D5 A5 E9 B6 D9 A1 08 BE 61 BE 53 B6 F5 F7 49 87 6F D7 AC
28 66 16 C1 76 E5 D1 57 82 CC F0 E0 C4 F5 53 8E 47 EE 77 EA 6A 17 3B D1 E9 53 C3 B7 4F 72 03 81 F7 C0 48 A5 82 BE 42 9F
82 85 97 ED B6 F7 87 6D 74 54 76 A3 1E 1F BA F7 D6 36 9A ED B8 D0 3A 9C 31 E3 9F 6E 58 EE 7A EF CB F7 AF 1F 0D 8B 40 E9
AE 61 5F 40 AA 21 BF EE F7 D2 2B E1 D3 19 33 46 81 EE 6E 59 62 C7 68 2C 05 D5 AB FB 5A 6A 10 66 1B 51 12 68 80 29 C9 EF
57 A6 F8 CA 07 34 F6 84 C9 EA 36 CD E6 C2 46 CC 77 A3 5C E2 7A 09 B9 1A 62 CE 42 02 D5 0F 54 39 A6
16 : 37 : 29 <====Rx METER-2 D4 81 E6 20 00 00 01 82 C4 02 81 00 00 00 00 2E 00 81 D6 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 0C 11 00 02 09 09 0C 07 E3 0B 13 02 0F 2D 00 FF 01 4A 00 12 14 D1 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
02 11 03 02 09 09 0C 07 E3 0B 13 02 10 00 00 FF 01 4A 00 12 5C 1C 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 02 11
13 02 09 09 0C 07 E3 0B 13 02 10 0F 00 FF 01 4A 00 12 5C 23 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 0B 02
09 09 0C 07 E3 0B 13 02 10 1E 00 FF 01 4A 00 12 5C D5 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 01 11 0A 02 09 09
0C 07 E3 0B 13 02 10 2D 00 FF 01 4A 00 12 58 5D 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 01
16 : 37 : 29 ====>Tx METER-2 D0 0C 20 00 00 01 82 C0 02 C1 00 00 00 2E
16 : 37 : 30 ====>Tx METER-2 D0 0C 20 00 00 01 82 9D 7F 15 DC F4 1B 99
16 : 37 : 30 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 30 METER-2 SENDING HDLC FRAME
16 : 37 : 30 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 01 82 9D 7F 15 DC F4 1B 99 0E A8 7E
16 : 37 : 30 METER-2 RECEIVED HDLC FRAME
16 : 37 : 30 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 01 83 A5 85 C9 17 5A 65 0E C7 63 16 39 7F 4A 8A D4 D1 ED 11
4D 31 9A 07 D9 C6 A2 70 19 07 1B 11 DE 8E 5F D6 FE 31 46 71 EA 38 B2 22 FF 26 EE 65 A7 A0 CD 5D 17 1C 7E 3F A7 9D CF DD
34 C7 DA EA DA 18 45 52 D2 88 79 82 24 C2 88 3F 03 68 8A 3B B5 B0 FB 41 0F 13 8B 31 97 AF 94 A5 FA E9 CB 79 01 21 82 80
25 8D D1 73 3B 59 E5 69 D5 C9 5C 1C F2 97 08 C4 25 1D 0C 22 EF CE A8 53 FB 7B 4C DE EE 4C 1C DD F7 B0 FA 96 F4 E2 23 0B
F7 25 E2 99 BD DE F3 1D 7B FD 0E ED 65 E6 73 D6 AD 30 2A 4B 8B 66 F7 D4 26 2A F8 51 F3 43 CA 2B 56 1B D8 3D 6B F8 4B 0C
07 67 F4 E6 61 4B 8B 0A C1 E4 7A 3A 66 16 F0 35 C3 1D D9 1B 64 39 D5 69 D1 A9 B3 D0 99 30 B8 21 0E E3 7E 18 FA D4 AE F6
10 11 D0 F3 07 61 3A 14 D5 7E
16 : 37 : 30 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 30 <====Rx METER-2 D4 81 E6 20 00 00 01 83 A5 85 C9 17 5A 65 0E C7 63 16 39 7F 4A 8A D4 D1 ED 11 4D 31 9A 07 D9 C6 A2 70 19 07 1B 11 DE 8E
5F D6 FE 31 46 71 EA 38 B2 22 FF 26 EE 65 A7 A0 CD 5D 17 1C 7E 3F A7 9D CF DD 34 C7 DA EA DA 18 45 52 D2 88 79 82 24 C2
88 3F 03 68 8A 3B B5 B0 FB 41 0F 13 8B 31 97 AF 94 A5 FA E9 CB 79 01 21 82 80 25 8D D1 73 3B 59 E5 69 D5 C9 5C 1C F2 97
08 C4 25 1D 0C 22 EF CE A8 53 FB 7B 4C DE EE 4C 1C DD F7 B0 FA 96 F4 E2 23 0B F7 25 E2 99 BD DE F3 1D 7B FD 0E ED 65 E6
73 D6 AD 30 2A 4B 8B 66 F7 D4 26 2A F8 51 F3 43 CA 2B 56 1B D8 3D 6B F8 4B 0C 07 67 F4 E6 61 4B 8B 0A C1 E4 7A 3A 66 16
F0 35 C3 1D D9 1B 64 39 D5 69 D1 A9 B3 D0 99 30 B8 21 0E E3 7E 18 FA D4 AE F6 10 11 D0 F3 07 61 3A
16 : 37 : 30 <====Rx METER-2 D4 81 E6 20 00 00 01 83 C4 02 81 00 00 00 00 2F 00 81 D6 11 00 02 09 09 0C 07 E3 0B 13 02 11 00 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 11 0F 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 11 1E 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 11 2D 00 FF 01 4A 00 12 1E A8 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 03 11 00 02 09 09 0C 07 E3 0B 13 02 12 00 00 FF 01 4A 00 12 2D AC 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 03 11 00 02 09 09 0C 07 E3 0B 13 02 12 0F 00 FF 01 4A 00 12 00 00 12 00 00
16 : 37 : 30 METER-2 SERVICE = GET RESPONSE
16 : 37 : 30 METER-2 COSEM OUT DATA
16 : 37 : 30 ====>Tx METER-2 D0 0C 20 00 00 01 83 C0 02 C1 00 00 00 2F
16 : 37 : 30 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 30 ====>Tx METER-2 D0 0C 20 00 00 01 83 76 E8 20 AF 82 77 5B
16 : 37 : 30 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 01 83 76 E8 20 AF 82 77 5B 8F D4 7E
16 : 37 : 30 <====Rx METER-2 7E A0 F8 41 00 02 04 01 B8 2A CB E6 E7 00 D4 81 E6 20 00 00 01 84 C6 B0 66 9F D0 F8 E9 D9 61 BB A0 3A C6 52 4F 66 89 25
59 7F 6A 61 BA 57 13 4C 7D E2 37 B2 E6 6E 96 FE 15 C0 02 17 54 41 B1 D6 E9 4C 43 33 D4 A1 97 C7 70 54 34 03 78 7C 16 50
24 2B 93 6E F4 D8 F9 47 04 AC 2D 87 DD 8D 92 D1 01 32 F6 C5 15 E8 28 A0 7C 64 5D 3C DE 70 6A F2 76 1F 0A AE 26 FF C9 81
79 E0 84 23 56 10 85 47 2D E2 DD AF BE 77 A6 8B CB DF 1D A8 B5 65 87 FE 6E FD F5 64 E6 72 09 F4 B9 90 A8 5C F9 0D E8 2E
03 B2 23 91 42 20 2D 52 5D 8E 6C 79 9C 64 B6 C8 79 A6 98 65 FA DB 19 DB 65 BC 0A 35 5E 2F AC 3D 4D FE 8F 38 D9 EA 28 21
04 D1 63 12 A6 5A BD C1 1E 4D D9 4F 3D 58 97 FA 20 8D F8 37 C5 B7 F0 D2 BD 75 59 DD 74 3F 25 14 41 61 9A EE E1 DD 61 D1
A0 DF 82 B1 D6 21 C9 7B 5F 7E
16 : 37 : 30 <====Rx METER-2 D4 81 E6 20 00 00 01 84 C6 B0 66 9F D0 F8 E9 D9 61 BB A0 3A C6 52 4F 66 89 25 59 7F 6A 61 BA 57 13 4C 7D E2 37 B2 E6 6E
96 FE 15 C0 02 17 54 41 B1 D6 E9 4C 43 33 D4 A1 97 C7 70 54 34 03 78 7C 16 50 24 2B 93 6E F4 D8 F9 47 04 AC 2D 87 DD 8D
92 D1 01 32 F6 C5 15 E8 28 A0 7C 64 5D 3C DE 70 6A F2 76 1F 0A AE 26 FF C9 81 79 E0 84 23 56 10 85 47 2D E2 DD AF BE 77
A6 8B CB DF 1D A8 B5 65 87 FE 6E FD F5 64 E6 72 09 F4 B9 90 A8 5C F9 0D E8 2E 03 B2 23 91 42 20 2D 52 5D 8E 6C 79 9C 64
B6 C8 79 A6 98 65 FA DB 19 DB 65 BC 0A 35 5E 2F AC 3D 4D FE 8F 38 D9 EA 28 21 04 D1 63 12 A6 5A BD C1 1E 4D D9 4F 3D 58
97 FA 20 8D F8 37 C5 B7 F0 D2 BD 75 59 DD 74 3F 25 14 41 61 9A EE E1 DD 61 D1 A0 DF 82 B1 D6 21 C9
16 : 37 : 30 <====Rx METER-2 D4 81 E6 20 00 00 01 84 C4 02 81 00 00 00 00 30 00 81 D6 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 13 02 12 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
13 02 12 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02
13 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 13 0F
00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 13 1E 00 FF
16 : 37 : 30 ====>Tx METER-2 D0 0C 20 00 00 01 84 C0 02 C1 00 00 00 30
16 : 37 : 30 ====>Tx METER-2 D0 0C 20 00 00 01 84 BD 09 2A 50 B0 8E 38
16 : 37 : 30 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 BA 30 1E E6 E6 00 D0 0C 20 00 00 01 84 BD 09 2A 50 B0 8E 38 C1 B9 7E
16 : 37 : 30 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 01 85 A7 C7 EA D0 88 FB 5C D6 18 69 00 AD E4 AA CD F1 0F 96
B5 9A 23 45 1E C1 19 8F C7 E7 B8 ED 95 2D 28 61 D5 30 63 E8 3A 2A 15 00 CA 3C 39 EE 49 4A A3 D3 64 37 07 65 24 C9 7B 67
C0 00 BE 1C F0 81 A4 7D 3E BE C6 42 C9 69 5D 5B 45 90 60 84 FE DA 50 E7 E6 64 DD 29 56 FD 97 98 40 EC 9E 6C 3E E7 15 3D
FD 09 7D F7 29 27 B8 81 01 A3 8A F2 0D 24 62 B8 1D D9 54 2B C2 81 9D 77 1C 2F EA D5 02 C1 2C AF 16 E0 EB D9 C5 45 6B 33
CD 8B 06 23 29 22 83 DB 00 E6 A3 65 62 38 60 52 73 84 D5 24 8C AD 39 E4 4C 1F 59 AD 45 43 3B AB D1 F8 5A 06 23 61 DD F6
9A 1A 0B 87 F8 72 FA 05 ED 0C C2 15 08 15 A0 21 42 B0 54 C7 D9 E1 08 96 B4 C5 09 21 14 B4 19 32 97 9C 6A FE A9 5F 32 F6
99 A8 02 9B 2C BD 4A C1 B5 7E
16 : 37 : 30 <====Rx METER-2 D4 81 E6 20 00 00 01 85 A7 C7 EA D0 88 FB 5C D6 18 69 00 AD E4 AA CD F1 0F 96 B5 9A 23 45 1E C1 19 8F C7 E7 B8 ED 95 2D
28 61 D5 30 63 E8 3A 2A 15 00 CA 3C 39 EE 49 4A A3 D3 64 37 07 65 24 C9 7B 67 C0 00 BE 1C F0 81 A4 7D 3E BE C6 42 C9 69
5D 5B 45 90 60 84 FE DA 50 E7 E6 64 DD 29 56 FD 97 98 40 EC 9E 6C 3E E7 15 3D FD 09 7D F7 29 27 B8 81 01 A3 8A F2 0D 24
62 B8 1D D9 54 2B C2 81 9D 77 1C 2F EA D5 02 C1 2C AF 16 E0 EB D9 C5 45 6B 33 CD 8B 06 23 29 22 83 DB 00 E6 A3 65 62 38
60 52 73 84 D5 24 8C AD 39 E4 4C 1F 59 AD 45 43 3B AB D1 F8 5A 06 23 61 DD F6 9A 1A 0B 87 F8 72 FA 05 ED 0C C2 15 08 15
A0 21 42 B0 54 C7 D9 E1 08 96 B4 C5 09 21 14 B4 19 32 97 9C 6A FE A9 5F 32 F6 99 A8 02 9B 2C BD 4A
16 : 37 : 30 <====Rx METER-2 D4 81 E6 20 00 00 01 85 C4 02 81 00 00 00 00 31 00 81 D6 02 13 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 14 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 14 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 14 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 13 02 14 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 13 02 15 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
16 : 37 : 30 ====>Tx METER-2 D0 0C 20 00 00 01 85 C0 02 C1 00 00 00 31
16 : 37 : 30 ====>Tx METER-2 D0 0C 20 00 00 01 85 77 E6 F3 40 8C F3 39
16 : 37 : 30 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 01 85 77 E6 F3 40 8C F3 39 62 30 7E
16 : 37 : 30 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 01 86 6D C2 FC 3D C9 CA BE 40 E8 1A 81 83 71 EF 2D E6 8B 5E
CC 6F 67 90 6F 5A 0F BD 55 38 62 39 72 9D C0 D0 E0 5B 6A 26 60 4D 05 E3 A7 1D 4C 2D 02 05 F3 3B 28 1A AB FE 52 CA AA EB
6D F0 89 EB 86 D5 D9 AB B2 7B 3A 16 4A C2 11 DB A8 D8 9B E8 99 D3 9E 0D 0F 69 25 15 53 90 30 52 80 FF 97 C2 91 A3 43 1F
D3 8A B9 6C 85 38 33 4C 30 D8 7E 71 65 28 A5 42 28 73 76 6A 11 07 29 7D 6B 81 20 D0 8D 42 CD A1 F8 F3 95 88 3F 6C 3F 37
C7 14 F9 5C EF 52 0C F7 E7 27 37 E0 B0 CF 9C 14 B7 71 BA 29 36 00 97 47 2C 21 9B 01 E3 0D 49 42 74 0D 49 B4 59 8A EA 70
C2 9F 9A 40 3F F2 AD A4 0D 5B 3F F8 11 7C 1C 8A 30 09 CA 44 B2 CE CE 21 4E 2A FB 18 A2 54 F7 36 B0 74 C5 87 8E AE C9 1C
7E 84 20 4B 38 46 C2 17 23 7E
16 : 37 : 30 <====Rx METER-2 D4 81 E6 20 00 00 01 86 6D C2 FC 3D C9 CA BE 40 E8 1A 81 83 71 EF 2D E6 8B 5E CC 6F 67 90 6F 5A 0F BD 55 38 62 39 72 9D
C0 D0 E0 5B 6A 26 60 4D 05 E3 A7 1D 4C 2D 02 05 F3 3B 28 1A AB FE 52 CA AA EB 6D F0 89 EB 86 D5 D9 AB B2 7B 3A 16 4A C2
11 DB A8 D8 9B E8 99 D3 9E 0D 0F 69 25 15 53 90 30 52 80 FF 97 C2 91 A3 43 1F D3 8A B9 6C 85 38 33 4C 30 D8 7E 71 65 28
A5 42 28 73 76 6A 11 07 29 7D 6B 81 20 D0 8D 42 CD A1 F8 F3 95 88 3F 6C 3F 37 C7 14 F9 5C EF 52 0C F7 E7 27 37 E0 B0 CF
9C 14 B7 71 BA 29 36 00 97 47 2C 21 9B 01 E3 0D 49 42 74 0D 49 B4 59 8A EA 70 C2 9F 9A 40 3F F2 AD A4 0D 5B 3F F8 11 7C
1C 8A 30 09 CA 44 B2 CE CE 21 4E 2A FB 18 A2 54 F7 36 B0 74 C5 87 8E AE C9 1C 7E 84 20 4B 38 46 C2
16 : 37 : 30 <====Rx METER-2 D4 81 E6 20 00 00 01 86 C4 02 81 00 00 00 00 32 00 81 D6 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 15 0F 00 FF 01 4A
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 15 1E 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 15 2D 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 16 00 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 16 0F 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 16 1E 00 FF 01 4A 00 12 00
16 : 37 : 30 ====>Tx METER-2 D0 0C 20 00 00 01 86 C0 02 C1 00 00 00 32
16 : 37 : 30 ====>Tx METER-2 D0 0C 20 00 00 01 86 1E 97 1B 35 79 88 DA
16 : 37 : 31 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 01 86 1E 97 1B 35 79 88 DA 80 AF 7E
16 : 37 : 31 METER-2 RECEIVED HDLC FRAME
16 : 37 : 31 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 01 87 A3 95 BF 50 90 3A 9D EB 03 DB FD 41 D9 FB A9 97 8E 1A
A5 C3 73 64 9D A2 49 BD 00 78 8C 6E FA B8 06 AA 92 EF 2F 12 3E 59 63 C4 B2 CF 10 9C 94 58 5A 68 D7 9A 0D 87 9F 80 E7 AA
A1 67 67 85 E0 2B 9B 06 F9 C5 5F D8 76 5E 6B A1 C9 31 54 43 68 36 99 86 E1 5B D9 5C A8 B7 8D E4 84 F9 61 5B 81 18 31 D4
8A 0A 98 48 E4 25 A9 FF D0 3A 46 15 51 FC 56 BD 08 E2 43 FB B9 2D 65 AA 59 6A 27 28 04 62 60 35 78 3F 55 04 BF CC 09 23
68 30 AA 4D 20 90 01 1D 16 83 B0 66 F2 D2 4F 9B F9 35 07 77 18 27 4D 37 B1 21 96 95 6E 8C A1 D5 99 28 8C 09 E2 E9 A2 F9
0D FC B6 2F 2E E0 1C 01 47 EF 21 EA A0 A1 BA C5 F6 90 0E 22 6D 08 AF FE 2F A8 A5 39 58 C1 6D 8B 8A 7C 66 B2 3B 7D 45 C6
05 48 41 9C 6F C8 E6 EA DE 7E
16 : 37 : 31 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 31 <====Rx METER-2 D4 81 E6 20 00 00 01 87 A3 95 BF 50 90 3A 9D EB 03 DB FD 41 D9 FB A9 97 8E 1A A5 C3 73 64 9D A2 49 BD 00 78 8C 6E FA B8
06 AA 92 EF 2F 12 3E 59 63 C4 B2 CF 10 9C 94 58 5A 68 D7 9A 0D 87 9F 80 E7 AA A1 67 67 85 E0 2B 9B 06 F9 C5 5F D8 76 5E
6B A1 C9 31 54 43 68 36 99 86 E1 5B D9 5C A8 B7 8D E4 84 F9 61 5B 81 18 31 D4 8A 0A 98 48 E4 25 A9 FF D0 3A 46 15 51 FC
56 BD 08 E2 43 FB B9 2D 65 AA 59 6A 27 28 04 62 60 35 78 3F 55 04 BF CC 09 23 68 30 AA 4D 20 90 01 1D 16 83 B0 66 F2 D2
4F 9B F9 35 07 77 18 27 4D 37 B1 21 96 95 6E 8C A1 D5 99 28 8C 09 E2 E9 A2 F9 0D FC B6 2F 2E E0 1C 01 47 EF 21 EA A0 A1
BA C5 F6 90 0E 22 6D 08 AF FE 2F A8 A5 39 58 C1 6D 8B 8A 7C 66 B2 3B 7D 45 C6 05 48 41 9C 6F C8 E6
16 : 37 : 31 <====Rx METER-2 D4 81 E6 20 00 00 01 87 C4 02 81 00 00 00 00 33 00 81 D6 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 13 02 16 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 13 02 17 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 13 02 17 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
13 02 17 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02
17 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
16 : 37 : 31 METER-2 SERVICE = GET RESPONSE
16 : 37 : 31 METER-2 COSEM OUT DATA
16 : 37 : 31 ====>Tx METER-2 D0 0C 20 00 00 01 87 C0 02 C1 00 00 00 33
16 : 37 : 31 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 31 ====>Tx METER-2 D0 0C 20 00 00 01 87 D0 58 54 DC 35 D4 B3
16 : 37 : 31 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 31 METER-2 SENDING HDLC FRAME
16 : 37 : 31 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 01 87 D0 58 54 DC 35 D4 B3 8D 12 7E
16 : 37 : 31 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 01 88 60 CE BA 22 05 AF 5E 62 97 A0 96 59 86 2A 67 EB F2 08
B7 DE ED A9 42 15 8E FE 51 D3 00 C7 C1 57 86 BC 9B D7 41 52 53 C8 29 E5 65 38 11 77 AF D3 11 79 25 E1 1C 97 95 2B 44 63
FE 8B 04 8F AC C7 AA 6F D6 DE 34 A3 B5 AF F3 25 8C F7 E1 82 AE 23 C7 16 50 E0 94 9F 0B 00 5E E9 6D E7 4A 1A 38 C3 B7 B2
AA 63 9E 86 ED 7F 52 2B 73 73 0D 66 99 49 B4 89 E1 18 89 35 14 40 19 BB 20 13 40 EB 51 B5 0B A4 36 D1 F0 20 DE DF 77 07
0C 6F 18 8C 9F E9 D1 B2 04 68 EA E8 71 3E CC 3A 25 8C 4F CD EA D1 FE ED 29 DE 43 42 C7 6B 54 5C 3A 19 77 A2 5F 5B 59 5F
FF 6E D5 D6 17 CF 7B DC E6 06 EB 4C D6 7E 25 EC F8 09 21 2A 5D 87 83 F4 7E C8 BF 88 76 4D 08 BF 09 D5 EA 3E 36 DC B9 79
81 2B 60 AE 14 7D 03 B4 AD 7E
16 : 37 : 31 <====Rx METER-2 D4 81 E6 20 00 00 01 88 60 CE BA 22 05 AF 5E 62 97 A0 96 59 86 2A 67 EB F2 08 B7 DE ED A9 42 15 8E FE 51 D3 00 C7 C1 57
86 BC 9B D7 41 52 53 C8 29 E5 65 38 11 77 AF D3 11 79 25 E1 1C 97 95 2B 44 63 FE 8B 04 8F AC C7 AA 6F D6 DE 34 A3 B5 AF
F3 25 8C F7 E1 82 AE 23 C7 16 50 E0 94 9F 0B 00 5E E9 6D E7 4A 1A 38 C3 B7 B2 AA 63 9E 86 ED 7F 52 2B 73 73 0D 66 99 49
B4 89 E1 18 89 35 14 40 19 BB 20 13 40 EB 51 B5 0B A4 36 D1 F0 20 DE DF 77 07 0C 6F 18 8C 9F E9 D1 B2 04 68 EA E8 71 3E
CC 3A 25 8C 4F CD EA D1 FE ED 29 DE 43 42 C7 6B 54 5C 3A 19 77 A2 5F 5B 59 5F FF 6E D5 D6 17 CF 7B DC E6 06 EB 4C D6 7E
25 EC F8 09 21 2A 5D 87 83 F4 7E C8 BF 88 76 4D 08 BF 09 D5 EA 3E 36 DC B9 79 81 2B 60 AE 14 7D 03
16 : 37 : 31 <====Rx METER-2 D4 81 E6 20 00 00 01 88 C4 02 81 00 00 00 00 34 00 81 D6 07 E3 0B 14 03 00 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 00 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 00 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 00 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 01 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 01 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
16 : 37 : 31 ====>Tx METER-2 D0 0C 20 00 00 01 88 C0 02 C1 00 00 00 34
16 : 37 : 31 ====>Tx METER-2 D0 0C 20 00 00 01 88 8E 22 F2 AB 6A 5B 9F
16 : 37 : 31 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 01 88 8E 22 F2 AB 6A 5B 9F A8 4A 7E
16 : 37 : 31 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 01 89 23 AD F0 7B A2 1B 2E 2E 06 AB 89 D9 5A 7F 1E 73 AD 2B
F9 4A BD EC 0F E1 4C 11 BD 27 1F D5 61 E1 0C CA 39 BD 7B C1 70 14 7C E9 50 40 AF 95 9B 81 6C CC F1 70 3A F4 AD AB E3 8B
7A 45 F1 F2 A2 BC B0 45 0F 62 FA CF 96 58 37 B0 AB 8F C3 11 BD CE 2F 74 23 8D F3 3B 2E 8C 95 41 E7 F2 91 07 25 04 A1 B4
7A 05 DE A9 AF E7 33 77 B0 B9 BB 06 54 34 5E D9 F2 3D E6 56 7D 28 7B B3 EE 50 65 90 B6 CE E3 83 84 B7 F8 DE C3 C8 0F B1
10 F0 32 EB 38 35 B8 FF 68 9F 6F 28 8B 56 7B B9 36 DA BC D4 F9 A8 D8 1F F8 2F 27 72 10 F5 BA 22 5A 40 66 8E B2 0E 75 31
DB D6 85 86 BF D1 7B 07 75 BE 38 CC CD EC 15 D7 C1 4C AF F6 7F 39 D1 C2 01 0C 10 58 02 42 E5 03 FD 40 C5 31 B2 18 40 9B
F1 89 86 8C 4E F4 A3 84 D4 7E
16 : 37 : 31 <====Rx METER-2 D4 81 E6 20 00 00 01 89 23 AD F0 7B A2 1B 2E 2E 06 AB 89 D9 5A 7F 1E 73 AD 2B F9 4A BD EC 0F E1 4C 11 BD 27 1F D5 61 E1
0C CA 39 BD 7B C1 70 14 7C E9 50 40 AF 95 9B 81 6C CC F1 70 3A F4 AD AB E3 8B 7A 45 F1 F2 A2 BC B0 45 0F 62 FA CF 96 58
37 B0 AB 8F C3 11 BD CE 2F 74 23 8D F3 3B 2E 8C 95 41 E7 F2 91 07 25 04 A1 B4 7A 05 DE A9 AF E7 33 77 B0 B9 BB 06 54 34
5E D9 F2 3D E6 56 7D 28 7B B3 EE 50 65 90 B6 CE E3 83 84 B7 F8 DE C3 C8 0F B1 10 F0 32 EB 38 35 B8 FF 68 9F 6F 28 8B 56
7B B9 36 DA BC D4 F9 A8 D8 1F F8 2F 27 72 10 F5 BA 22 5A 40 66 8E B2 0E 75 31 DB D6 85 86 BF D1 7B 07 75 BE 38 CC CD EC
15 D7 C1 4C AF F6 7F 39 D1 C2 01 0C 10 58 02 42 E5 03 FD 40 C5 31 B2 18 40 9B F1 89 86 8C 4E F4 A3
16 : 37 : 31 <====Rx METER-2 D4 81 E6 20 00 00 01 89 C4 02 81 00 00 00 00 35 00 81 D6 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 01 1E
00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 01 2D 00 FF
01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 02 00 00 FF 01 4A
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 02 0F 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 02 1E 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 02 2D 00 FF 01
16 : 37 : 31 ====>Tx METER-2 D0 0C 20 00 00 01 89 C0 02 C1 00 00 00 35
16 : 37 : 31 ====>Tx METER-2 D0 0C 20 00 00 01 89 7B 82 2E 3A 57 56 7F
16 : 37 : 31 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 01 89 7B 82 2E 3A 57 56 7F F3 78 7E
16 : 37 : 31 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 01 8A B8 E0 E8 5C F1 DC 76 4E 18 4D 22 B8 45 77 8A 61 8E D0
4B B2 6F F3 2C 6B CD 45 9B E7 8B BE 74 E5 8F 64 3D A0 01 CC 5E 7C 76 AE 22 6D B7 D4 B4 37 B7 40 0A 09 A1 91 55 96 A2 3A
25 66 A0 EF A7 BC 4E 2B 44 AA 50 0E 88 0C B6 CC FD 6E 1B 94 B1 F0 1C 87 16 45 6F 89 A5 13 D3 3F 25 8D 4E F2 D0 F8 B2 F3
EF 09 7B C5 FF 3D A1 5A CA E8 18 FD BF 1C E8 E7 7F E5 61 C6 2E 1B 12 14 9B 4B A9 F0 59 95 35 28 AF 81 F6 C5 9D 33 69 58
D3 E5 3A 88 AE 6F BC C7 49 54 B3 C8 46 96 AB 38 72 E8 09 6D 8B 53 9F 71 A2 22 FF A7 6A 69 69 A0 A4 0C 14 2D E3 2E 13 23
CD BD 35 64 4A E2 1B 50 A2 12 25 C5 6D E5 9D B9 22 30 FC 64 99 CC 5B 85 5D B0 E0 7B 80 BB E2 60 B4 8F 15 A7 41 2D 39 4D
DE 05 FE 39 9C E0 C2 52 96 7E
16 : 37 : 31 <====Rx METER-2 D4 81 E6 20 00 00 01 8A B8 E0 E8 5C F1 DC 76 4E 18 4D 22 B8 45 77 8A 61 8E D0 4B B2 6F F3 2C 6B CD 45 9B E7 8B BE 74 E5
8F 64 3D A0 01 CC 5E 7C 76 AE 22 6D B7 D4 B4 37 B7 40 0A 09 A1 91 55 96 A2 3A 25 66 A0 EF A7 BC 4E 2B 44 AA 50 0E 88 0C
B6 CC FD 6E 1B 94 B1 F0 1C 87 16 45 6F 89 A5 13 D3 3F 25 8D 4E F2 D0 F8 B2 F3 EF 09 7B C5 FF 3D A1 5A CA E8 18 FD BF 1C
E8 E7 7F E5 61 C6 2E 1B 12 14 9B 4B A9 F0 59 95 35 28 AF 81 F6 C5 9D 33 69 58 D3 E5 3A 88 AE 6F BC C7 49 54 B3 C8 46 96
AB 38 72 E8 09 6D 8B 53 9F 71 A2 22 FF A7 6A 69 69 A0 A4 0C 14 2D E3 2E 13 23 CD BD 35 64 4A E2 1B 50 A2 12 25 C5 6D E5
9D B9 22 30 FC 64 99 CC 5B 85 5D B0 E0 7B 80 BB E2 60 B4 8F 15 A7 41 2D 39 4D DE 05 FE 39 9C E0 C2
16 : 37 : 31 <====Rx METER-2 D4 81 E6 20 00 00 01 8A C4 02 81 00 00 00 00 36 00 81 D6 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 14 03 03 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 14 03 03 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 14 03 03 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 14 03 03 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 14 03 04 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
16 : 37 : 31 ====>Tx METER-2 D0 0C 20 00 00 01 8A C0 02 C1 00 00 00 36
16 : 37 : 31 ====>Tx METER-2 D0 0C 20 00 00 01 8A BC 35 88 4C 48 51 29
16 : 37 : 31 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 01 8A BC 35 88 4C 48 51 29 E9 DF 7E
16 : 37 : 32 <====Rx METER-2 7E A0 F8 41 00 02 04 01 96 56 03 E6 E7 00 D4 81 E6 20 00 00 01 8B D9 7B 04 3D 41 D5 3B 66 FF 42 D9 3D AA D8 35 0D D6 39
44 83 DC 82 C9 B5 8C 4B 64 E7 A9 AF F4 0B 97 9A B6 C6 25 29 D6 0C 9E 7F A1 66 98 2A 27 FC 4A DA FD A6 42 47 60 25 68 7F
51 DA 4D E1 3A C0 E8 79 71 3B 6D 3F 4C 12 12 6F B3 60 55 11 64 7E B2 6C 93 D0 2A B0 98 96 FA 1A 2A A9 AD 5E 9F D8 8F 35
49 22 D9 16 79 2B 6C 0D E0 BD DC 61 8B 9D 46 2A 0E FB 7E 7E C8 E4 1E A0 36 7E 30 7B 15 7C 49 BF 09 F2 57 FF F3 1B A3 6C
6F 0A 84 64 A4 DE EB 3A 81 53 36 70 66 E6 9D DF 19 B4 00 59 2C 3A CF FA 3F 78 68 6D 0A 69 66 C3 33 7A 1E A2 FA 2B CA B3
F3 87 A5 96 E3 41 AD 61 F4 DB AF 17 29 F7 5D 1C A2 04 D4 A8 74 A0 03 3B C6 8D 8E 47 B9 87 2D 44 AD E7 03 95 B9 F5 F1 C8
52 DC BE 85 4A 01 14 3B 98 7E
16 : 37 : 32 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 32 <====Rx METER-2 D4 81 E6 20 00 00 01 8B D9 7B 04 3D 41 D5 3B 66 FF 42 D9 3D AA D8 35 0D D6 39 44 83 DC 82 C9 B5 8C 4B 64 E7 A9 AF F4 0B
97 9A B6 C6 25 29 D6 0C 9E 7F A1 66 98 2A 27 FC 4A DA FD A6 42 47 60 25 68 7F 51 DA 4D E1 3A C0 E8 79 71 3B 6D 3F 4C 12
12 6F B3 60 55 11 64 7E B2 6C 93 D0 2A B0 98 96 FA 1A 2A A9 AD 5E 9F D8 8F 35 49 22 D9 16 79 2B 6C 0D E0 BD DC 61 8B 9D
46 2A 0E FB 7E 7E C8 E4 1E A0 36 7E 30 7B 15 7C 49 BF 09 F2 57 FF F3 1B A3 6C 6F 0A 84 64 A4 DE EB 3A 81 53 36 70 66 E6
9D DF 19 B4 00 59 2C 3A CF FA 3F 78 68 6D 0A 69 66 C3 33 7A 1E A2 FA 2B CA B3 F3 87 A5 96 E3 41 AD 61 F4 DB AF 17 29 F7
5D 1C A2 04 D4 A8 74 A0 03 3B C6 8D 8E 47 B9 87 2D 44 AD E7 03 95 B9 F5 F1 C8 52 DC BE 85 4A 01 14
16 : 37 : 32 <====Rx METER-2 D4 81 E6 20 00 00 01 8B C4 02 81 00 00 00 00 37 00 81 D6 02 09 09 0C 07 E3 0B 14 03 04 0F 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 04 1E 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 04 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 05 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 05 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 05 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00
16 : 37 : 32 METER-2 SERVICE = GET RESPONSE
16 : 37 : 32 METER-2 COSEM OUT DATA
16 : 37 : 32 ====>Tx METER-2 D0 0C 20 00 00 01 8B C0 02 C1 00 00 00 37
16 : 37 : 32 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 32 ====>Tx METER-2 D0 0C 20 00 00 01 8B AA 6E E0 62 7B 03 D8
16 : 37 : 32 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 32 METER-2 SENDING HDLC FRAME
16 : 37 : 32 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 98 20 1C E6 E6 00 D0 0C 20 00 00 01 8B AA 6E E0 62 7B 03 D8 1F 6B 7E
16 : 37 : 32 METER-2 RECEIVED HDLC FRAME
16 : 37 : 32 <====Rx METER-2 7E A0 F8 41 00 02 04 01 B8 2A CB E6 E7 00 D4 81 E6 20 00 00 01 8C 86 BD EE 6A 23 C2 94 B0 F5 1F F0 36 0C BD 53 A5 71 A0
2B D5 F1 D6 60 AC 2E 62 36 3F E1 BE 93 4C A7 B9 B1 B9 D5 01 35 99 A5 E8 A0 65 D7 D8 E5 B1 B4 33 BB 1B 35 A9 EC CA 1F 03
9C 05 44 B6 5B 69 0E 09 EE E1 C0 70 83 BC CC CE F4 44 69 8C 03 14 E3 A1 F0 8A 8B A4 A7 54 A9 E8 BC 10 C7 B7 76 5F 50 10
98 E6 BA AD B7 D0 16 E4 22 7A 5F 2D 94 F1 F7 94 72 6A A9 B6 B8 D8 8F 5D 71 74 77 90 A1 3E B1 7D 43 91 F1 D3 D5 C7 6D 0D
D9 7F A8 BC 09 5B FC 53 03 01 22 58 E1 9D 06 C4 45 EE E5 13 DC FB A8 23 80 5D B6 B9 B6 22 5F EA 25 41 60 75 0C 28 8E D6
07 FD 3F EB 4B 48 C3 2D 9A 1A 5C 1B 25 EC D2 69 19 E1 62 D1 6E 06 2D A9 06 C1 48 EF 80 3C 7E 10 49 D0 2A 8E F4 7A 89 C7
E3 0E 49 87 3A 6D FF C8 51 7E
16 : 37 : 32 <====Rx METER-2 D4 81 E6 20 00 00 01 8C 86 BD EE 6A 23 C2 94 B0 F5 1F F0 36 0C BD 53 A5 71 A0 2B D5 F1 D6 60 AC 2E 62 36 3F E1 BE 93 4C
A7 B9 B1 B9 D5 01 35 99 A5 E8 A0 65 D7 D8 E5 B1 B4 33 BB 1B 35 A9 EC CA 1F 03 9C 05 44 B6 5B 69 0E 09 EE E1 C0 70 83 BC
CC CE F4 44 69 8C 03 14 E3 A1 F0 8A 8B A4 A7 54 A9 E8 BC 10 C7 B7 76 5F 50 10 98 E6 BA AD B7 D0 16 E4 22 7A 5F 2D 94 F1
F7 94 72 6A A9 B6 B8 D8 8F 5D 71 74 77 90 A1 3E B1 7D 43 91 F1 D3 D5 C7 6D 0D D9 7F A8 BC 09 5B FC 53 03 01 22 58 E1 9D
06 C4 45 EE E5 13 DC FB A8 23 80 5D B6 B9 B6 22 5F EA 25 41 60 75 0C 28 8E D6 07 FD 3F EB 4B 48 C3 2D 9A 1A 5C 1B 25 EC
D2 69 19 E1 62 D1 6E 06 2D A9 06 C1 48 EF 80 3C 7E 10 49 D0 2A 8E F4 7A 89 C7 E3 0E 49 87 3A 6D FF
16 : 37 : 32 <====Rx METER-2 D4 81 E6 20 00 00 01 8C C4 02 81 00 00 00 00 38 00 81 D6 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
14 03 05 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03
06 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 06 0F
00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 06 1E 00 FF
01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 06 2D 00 FF 01 4A
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 07
16 : 37 : 32 ====>Tx METER-2 D0 0C 20 00 00 01 8C C0 02 C1 00 00 00 38
16 : 37 : 32 ====>Tx METER-2 D0 0C 20 00 00 01 8C 4F AA C1 DE 64 DF AF
16 : 37 : 32 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 BA 30 1E E6 E6 00 D0 0C 20 00 00 01 8C 4F AA C1 DE 64 DF AF 79 91 7E
16 : 37 : 32 <====Rx METER-2 7E A0 F8 41 00 02 04 01 DA 3E 8B E6 E7 00 D4 81 E6 20 00 00 01 8D 34 3E 98 16 97 F2 67 F1 79 5D 5B 97 D8 04 52 CC 72 B8
07 F0 BA 3E 3A BA B3 B6 90 24 C0 87 D9 AB 0E F0 69 BE B5 34 99 FD A3 F4 35 8B A1 3B 8E 98 60 21 82 DC 20 A9 DA 8A 87 D5
C5 92 68 51 FA D2 5D 86 F9 AB 08 D3 6F AD 55 82 DF 8C CA 9E C6 F5 C7 00 75 46 FF 70 AD C1 81 D6 7A AB 3F A7 FC B1 A3 55
EE 67 76 81 9E 0E 08 84 CC B1 3A 0E 9C 80 ED D0 D3 F2 9D 25 B7 D6 9F 74 26 07 99 21 BA 7F 05 6B F2 BE 54 1E 8F 57 04 37
BE 53 65 A4 0E BD 4D 9A 4F 36 94 74 F1 0B 58 51 11 B9 CE B8 E7 98 54 AF CD 1C 28 ED 8C 17 41 7E 6B AD C8 93 A5 20 84 AD
F0 D3 43 6A 7A 82 CB F7 A4 94 30 71 02 72 E1 BE CB 78 26 27 DB 15 90 CD 91 2F 05 7D 75 A9 AA 2C 54 32 3B EE 6D 35 0F 49
63 9C B3 2D 98 6F 3B A7 24 7E
16 : 37 : 32 <====Rx METER-2 D4 81 E6 20 00 00 01 8D 34 3E 98 16 97 F2 67 F1 79 5D 5B 97 D8 04 52 CC 72 B8 07 F0 BA 3E 3A BA B3 B6 90 24 C0 87 D9 AB
0E F0 69 BE B5 34 99 FD A3 F4 35 8B A1 3B 8E 98 60 21 82 DC 20 A9 DA 8A 87 D5 C5 92 68 51 FA D2 5D 86 F9 AB 08 D3 6F AD
55 82 DF 8C CA 9E C6 F5 C7 00 75 46 FF 70 AD C1 81 D6 7A AB 3F A7 FC B1 A3 55 EE 67 76 81 9E 0E 08 84 CC B1 3A 0E 9C 80
ED D0 D3 F2 9D 25 B7 D6 9F 74 26 07 99 21 BA 7F 05 6B F2 BE 54 1E 8F 57 04 37 BE 53 65 A4 0E BD 4D 9A 4F 36 94 74 F1 0B
58 51 11 B9 CE B8 E7 98 54 AF CD 1C 28 ED 8C 17 41 7E 6B AD C8 93 A5 20 84 AD F0 D3 43 6A 7A 82 CB F7 A4 94 30 71 02 72
E1 BE CB 78 26 27 DB 15 90 CD 91 2F 05 7D 75 A9 AA 2C 54 32 3B EE 6D 35 0F 49 63 9C B3 2D 98 6F 3B
16 : 37 : 32 <====Rx METER-2 D4 81 E6 20 00 00 01 8D C4 02 81 00 00 00 00 39 00 81 D6 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 07 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 07 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 14 03 07 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 14 03 08 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 14 03 08 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
16 : 37 : 32 ====>Tx METER-2 D0 0C 20 00 00 01 8D C0 02 C1 00 00 00 39
16 : 37 : 32 ====>Tx METER-2 D0 0C 20 00 00 01 8D B5 10 82 E5 AC 57 00
16 : 37 : 32 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 DC 00 18 E6 E6 00 D0 0C 20 00 00 01 8D B5 10 82 E5 AC 57 00 1C 06 7E
16 : 37 : 32 <====Rx METER-2 7E A0 F8 41 00 02 04 01 FC 0A CF E6 E7 00 D4 81 E6 20 00 00 01 8E 59 A4 0A 70 F4 C4 E6 FE 82 CF CF D7 CD DF A4 07 D0 DD
5C F0 7F FD D0 E3 D6 D0 D1 AD 50 7F 18 B3 08 37 FA 45 E6 F3 5B 62 DB 70 3C D5 62 C8 56 0B 4F BE 8F FD 8A 59 73 F4 8F 73
E5 A7 AD 14 12 14 B3 B4 37 31 8B 1F 41 46 3B 41 25 05 AC 28 76 24 67 7B 03 70 FF B3 9E 22 3B AA 87 03 98 20 E6 A0 7A 2D
DF DA 1A 27 8A 6E DA 84 E9 F3 E0 37 7A 6E A0 AF 59 C6 54 7A 61 16 D9 81 66 8B E6 DE 9B 84 57 6F DC 91 75 13 F4 F0 79 07
C8 29 A0 54 3C 88 93 5A 8A 9D 6C 0A E9 B1 7E FC 46 9A 86 E9 96 7E F7 B4 FB 8F BC B7 49 16 59 E3 A4 5C 7E 1C A5 9A 81 AA
3E AF EC C2 DD BC 85 7B 07 48 79 B6 35 94 E5 58 0F 3D D0 46 92 1D A8 B8 3D B7 54 1D 3F BA 89 22 DC 34 5F 0F 33 B4 3C 51
4D B3 20 7D A7 F0 4E 69 F8 7E
16 : 37 : 32 <====Rx METER-2 D4 81 E6 20 00 00 01 8E 59 A4 0A 70 F4 C4 E6 FE 82 CF CF D7 CD DF A4 07 D0 DD 5C F0 7F FD D0 E3 D6 D0 D1 AD 50 7F 18 B3
08 37 FA 45 E6 F3 5B 62 DB 70 3C D5 62 C8 56 0B 4F BE 8F FD 8A 59 73 F4 8F 73 E5 A7 AD 14 12 14 B3 B4 37 31 8B 1F 41 46
3B 41 25 05 AC 28 76 24 67 7B 03 70 FF B3 9E 22 3B AA 87 03 98 20 E6 A0 7A 2D DF DA 1A 27 8A 6E DA 84 E9 F3 E0 37 7A 6E
A0 AF 59 C6 54 7A 61 16 D9 81 66 8B E6 DE 9B 84 57 6F DC 91 75 13 F4 F0 79 07 C8 29 A0 54 3C 88 93 5A 8A 9D 6C 0A E9 B1
7E FC 46 9A 86 E9 96 7E F7 B4 FB 8F BC B7 49 16 59 E3 A4 5C 7E 1C A5 9A 81 AA 3E AF EC C2 DD BC 85 7B 07 48 79 B6 35 94
E5 58 0F 3D D0 46 92 1D A8 B8 3D B7 54 1D 3F BA 89 22 DC 34 5F 0F 33 B4 3C 51 4D B3 20 7D A7 F0 4E
16 : 37 : 32 <====Rx METER-2 D4 81 E6 20 00 00 01 8E C4 02 81 00 00 00 00 3A 00 81 D6 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 08 1E 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 08 2D 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 09 00 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 09 0F 00 FF 01 4A 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 09 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 09 2D 00 FF 01 4A 00 12 00 00 12
16 : 37 : 32 ====>Tx METER-2 D0 0C 20 00 00 01 8E C0 02 C1 00 00 00 3A
16 : 37 : 32 ====>Tx METER-2 D0 0C 20 00 00 01 8E C8 5E DA F0 87 47 48
16 : 37 : 32 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 FE 10 1A E6 E6 00 D0 0C 20 00 00 01 8E C8 5E DA F0 87 47 48 48 7B 7E
16 : 37 : 32 <====Rx METER-2 7E A0 F8 41 00 02 04 01 1E 16 0B E6 E7 00 D4 81 E6 20 00 00 01 8F 76 23 14 99 44 7B 09 B9 E1 3A F6 9B 37 57 75 FA 63 C4
AA 7B E5 FD 56 11 8A 0A 35 84 CD BC 8C 70 6C 28 11 7D 3E B6 04 3E 33 D1 6A 42 B3 9A AC 63 E4 19 A9 99 05 F3 44 85 31 CC
D3 E6 53 74 F0 83 69 01 8B E0 62 8D FE 7E 1F 8C 88 C3 D0 D7 82 E8 E4 DD 05 67 4C 46 FF 55 D5 32 EC C8 DD 03 6B 19 D1 3C
47 E6 A7 FB 9B 5D 54 A1 4C C5 D9 05 90 56 74 1D F1 91 0A 46 C5 50 DE 44 E5 2D EC 77 DF E7 D4 AA 9C F9 13 88 75 90 43 D5
2D 6A FA 92 15 4F 39 CC 86 1E 54 19 BC 8E FF 07 B2 1A B4 DE F7 A6 A5 E3 E3 0D FD B6 3B C1 58 52 A7 11 CF C3 52 07 E2 22
61 FF 67 EF A4 25 F8 8D 86 98 0A 39 FF D1 57 58 7B FD 9B 32 B3 2D 61 2A AD 26 E3 2C 30 38 14 C4 32 7E A3 4B 6B 7E A0 0E
42 18 EA AF 32 A5 1B 4E EC 7E
16 : 37 : 32 <====Rx METER-2 D4 81 E6 20 00 00 01 8F 76 23 14 99 44 7B 09 B9 E1 3A F6 9B 37 57 75 FA 63 C4 AA 7B E5 FD 56 11 8A 0A 35 84 CD BC 8C 70
6C 28 11 7D 3E B6 04 3E 33 D1 6A 42 B3 9A AC 63 E4 19 A9 99 05 F3 44 85 31 CC D3 E6 53 74 F0 83 69 01 8B E0 62 8D FE 7E
1F 8C 88 C3 D0 D7 82 E8 E4 DD 05 67 4C 46 FF 55 D5 32 EC C8 DD 03 6B 19 D1 3C 47 E6 A7 FB 9B 5D 54 A1 4C C5 D9 05 90 56
74 1D F1 91 0A 46 C5 50 DE 44 E5 2D EC 77 DF E7 D4 AA 9C F9 13 88 75 90 43 D5 2D 6A FA 92 15 4F 39 CC 86 1E 54 19 BC 8E
FF 07 B2 1A B4 DE F7 A6 A5 E3 E3 0D FD B6 3B C1 58 52 A7 11 CF C3 52 07 E2 22 61 FF 67 EF A4 25 F8 8D 86 98 0A 39 FF D1
57 58 7B FD 9B 32 B3 2D 61 2A AD 26 E3 2C 30 38 14 C4 32 7E A3 4B 6B 7E A0 0E 42 18 EA AF 32 A5 1B
16 : 37 : 33 <====Rx METER-2 D4 81 E6 20 00 00 01 8F C4 02 81 00 00 00 00 3B 00 81 D6 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 14 03 0A 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 14 03 0A 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
14 03 0A 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03
0A 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0B 00
16 : 37 : 33 METER-2 SERVICE = GET RESPONSE
16 : 37 : 33 METER-2 COSEM OUT DATA
16 : 37 : 33 ====>Tx METER-2 D0 0C 20 00 00 01 8F C0 02 C1 00 00 00 3B
16 : 37 : 33 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 33 ====>Tx METER-2 D0 0C 20 00 00 01 8F 8E D6 CD C2 24 3C 39
16 : 37 : 33 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 33 METER-2 SENDING HDLC FRAME
16 : 37 : 33 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 10 60 14 E6 E6 00 D0 0C 20 00 00 01 8F 8E D6 CD C2 24 3C 39 0F 26 7E
16 : 37 : 33 METER-2 RECEIVED HDLC FRAME
16 : 37 : 33 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 01 90 BB 80 CE 3A 53 E2 B3 6B 4E 3D AF A9 58 52 6A 0B 66 68
72 C6 24 9C B0 8D AE BC 1C 68 F0 0F 85 08 43 35 92 AF 40 15 45 E9 71 8E 38 8B 6E 88 48 68 14 E4 F1 18 1C EB 21 C3 70 58
EA 79 6E 1D 56 FE BE C8 81 0B CC 85 65 4E BA 7C EE 1C F0 EC 73 66 BB CA E1 C5 AD 48 96 DB 8E 06 75 52 CA 7F B1 57 D2 9D
D9 C6 B4 95 6E 3F 20 9C 58 05 5C 38 B5 C8 AF 01 BA CB B7 AD FE 34 5E 9B 0D 57 F3 37 67 62 24 2C 11 B8 72 0D A7 1B A0 D4
71 06 6B FC 58 39 C1 7C 68 32 C5 53 E6 03 D0 02 57 C7 C9 50 2D 7E F3 80 6C AE 58 CA B9 35 D1 56 54 17 1E 0E 65 64 BC BC
6B 5B E2 CD F2 F0 A4 FD 1E 3D 0F 00 A6 5D CA 84 6A 0D 0A 68 E4 BB 7F 14 AD 93 64 20 7B 25 C6 B4 98 55 24 94 A1 F8 4B 38
8D 19 4B CA 21 12 C5 D6 F5 7E
16 : 37 : 33 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 33 <====Rx METER-2 D4 81 E6 20 00 00 01 90 BB 80 CE 3A 53 E2 B3 6B 4E 3D AF A9 58 52 6A 0B 66 68 72 C6 24 9C B0 8D AE BC 1C 68 F0 0F 85 08
43 35 92 AF 40 15 45 E9 71 8E 38 8B 6E 88 48 68 14 E4 F1 18 1C EB 21 C3 70 58 EA 79 6E 1D 56 FE BE C8 81 0B CC 85 65 4E
BA 7C EE 1C F0 EC 73 66 BB CA E1 C5 AD 48 96 DB 8E 06 75 52 CA 7F B1 57 D2 9D D9 C6 B4 95 6E 3F 20 9C 58 05 5C 38 B5 C8
AF 01 BA CB B7 AD FE 34 5E 9B 0D 57 F3 37 67 62 24 2C 11 B8 72 0D A7 1B A0 D4 71 06 6B FC 58 39 C1 7C 68 32 C5 53 E6 03
D0 02 57 C7 C9 50 2D 7E F3 80 6C AE 58 CA B9 35 D1 56 54 17 1E 0E 65 64 BC BC 6B 5B E2 CD F2 F0 A4 FD 1E 3D 0F 00 A6 5D
CA 84 6A 0D 0A 68 E4 BB 7F 14 AD 93 64 20 7B 25 C6 B4 98 55 24 94 A1 F8 4B 38 8D 19 4B CA 21 12 C5
16 : 37 : 33 <====Rx METER-2 D4 81 E6 20 00 00 01 90 C4 02 81 00 00 00 00 3C 00 81 D6 0B 14 03 0B 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0B 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0B 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0C 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0C 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11
00 11 00 02 09 09 0C 07 E3 0B 14 03 0C 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
16 : 37 : 33 ====>Tx METER-2 D0 0C 20 00 00 01 90 C0 02 C1 00 00 00 3C
16 : 37 : 33 ====>Tx METER-2 D0 0C 20 00 00 01 90 99 19 B4 2E E5 59 6B
16 : 37 : 33 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 01 90 99 19 B4 2E E5 59 6B FB D9 7E
16 : 37 : 33 <====Rx METER-2 7E A0 F8 41 00 02 04 01 52 7E 83 E6 E7 00 D4 81 E6 20 00 00 01 91 3B 85 9E 9D 32 06 AC C2 75 49 15 D2 9C E8 FA A3 86 5C
28 81 ED B9 08 E6 5E 0E 7A 9C F9 80 68 AC C9 5E 5F 12 76 42 A7 05 97 BD 43 02 C3 62 DA 78 2C 4A 45 BF 83 E9 1B 24 C8 1F
EB B9 2F A5 E7 0A 3A 4A EC 1E 1B FC 76 B4 C3 95 B7 6D 61 DC A0 25 40 DD 85 6C BD DE 31 A0 1F 02 EC E6 0D 45 50 44 D1 5B
EC 94 F8 CF F1 87 7D 55 E3 A8 C0 88 87 F1 37 D9 5E E4 92 F0 11 DD 88 37 51 86 9A 07 16 8E D8 23 3F 2B 7D 5D E5 38 68 20
E9 25 C3 4B 81 79 E2 F7 95 FD 2D 39 1F CB F7 67 F0 64 B3 8C 9B 16 01 0B 75 1D 87 BF B9 58 30 AA DB 91 4E 3D 24 1C 08 EC
97 A6 FE 5A 0F B9 CC C9 34 AF E9 CA 20 82 7E EF 0D 09 F7 A1 43 78 C6 9F 49 CA 3A FB BA 2E 14 FC 74 14 59 CE 0F 7E BC DC
B4 01 AB E9 F9 91 3D 3F 23 7E
16 : 37 : 33 <====Rx METER-2 D4 81 E6 20 00 00 01 91 3B 85 9E 9D 32 06 AC C2 75 49 15 D2 9C E8 FA A3 86 5C 28 81 ED B9 08 E6 5E 0E 7A 9C F9 80 68 AC
C9 5E 5F 12 76 42 A7 05 97 BD 43 02 C3 62 DA 78 2C 4A 45 BF 83 E9 1B 24 C8 1F EB B9 2F A5 E7 0A 3A 4A EC 1E 1B FC 76 B4
C3 95 B7 6D 61 DC A0 25 40 DD 85 6C BD DE 31 A0 1F 02 EC E6 0D 45 50 44 D1 5B EC 94 F8 CF F1 87 7D 55 E3 A8 C0 88 87 F1
37 D9 5E E4 92 F0 11 DD 88 37 51 86 9A 07 16 8E D8 23 3F 2B 7D 5D E5 38 68 20 E9 25 C3 4B 81 79 E2 F7 95 FD 2D 39 1F CB
F7 67 F0 64 B3 8C 9B 16 01 0B 75 1D 87 BF B9 58 30 AA DB 91 4E 3D 24 1C 08 EC 97 A6 FE 5A 0F B9 CC C9 34 AF E9 CA 20 82
7E EF 0D 09 F7 A1 43 78 C6 9F 49 CA 3A FB BA 2E 14 FC 74 14 59 CE 0F 7E BC DC B4 01 AB E9 F9 91 3D
16 : 37 : 33 <====Rx METER-2 D4 81 E6 20 00 00 01 91 C4 02 81 00 00 00 00 3D 00 81 D6 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0C 2D 00 FF
01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0D 00 00 FF 01 4A
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0D 0F 00 FF 01 4A 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0D 1E 00 FF 01 4A 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0D 2D 00 FF 01 4A 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0E 00 00 FF 01 4A 00
16 : 37 : 33 ====>Tx METER-2 D0 0C 20 00 00 01 91 C0 02 C1 00 00 00 3D
16 : 37 : 33 ====>Tx METER-2 D0 0C 20 00 00 01 91 24 81 E8 3A 8D 1A 3D
16 : 37 : 33 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 54 40 10 E6 E6 00 D0 0C 20 00 00 01 91 24 81 E8 3A 8D 1A 3D 3B 6B 7E
16 : 37 : 33 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 01 92 CA 51 8B F2 52 DB 0B 8D 65 54 11 2D A0 5F AD BA 4D 79
44 DC BA 77 CD EF B7 13 A2 0F E8 D6 65 18 35 61 7F FA 1A 9F 2C 0A 7F 0F 99 22 5D A8 70 00 9B 8E 24 AB FF FA A7 8A 77 6D
D0 A7 F8 04 FB 40 4E 70 AC DB CF 9F 30 F5 AD D7 CD B5 F8 56 31 63 13 FC 79 3A D4 8E 5E EF BC 98 17 5E 8E 98 A4 00 0F E2
2C A5 C4 38 F3 B1 2D E6 D4 EA 9A 0C EF 6B AB 93 A4 6F 02 92 17 19 06 4B EE AC B0 81 14 72 59 B7 60 E0 03 4D DE 7D 79 CB
0D 51 40 90 9C C9 96 FC C2 B4 AD D7 F0 E8 B2 A8 F4 BF 8B 14 42 E8 E5 A7 7C 3D 9F C8 48 14 45 4C 31 46 5C 9D 34 62 28 CA
21 5F 95 62 15 2B 51 2E 0C 25 7C 06 B3 84 AA 2B 94 07 FB AA 14 2C 30 A4 C2 EA B1 4E 23 1F 5C 3D 8B DB 1B DC 99 9A E9 41
1D 0C B0 31 0D 90 E3 4F EA 7E
16 : 37 : 33 <====Rx METER-2 D4 81 E6 20 00 00 01 92 CA 51 8B F2 52 DB 0B 8D 65 54 11 2D A0 5F AD BA 4D 79 44 DC BA 77 CD EF B7 13 A2 0F E8 D6 65 18
35 61 7F FA 1A 9F 2C 0A 7F 0F 99 22 5D A8 70 00 9B 8E 24 AB FF FA A7 8A 77 6D D0 A7 F8 04 FB 40 4E 70 AC DB CF 9F 30 F5
AD D7 CD B5 F8 56 31 63 13 FC 79 3A D4 8E 5E EF BC 98 17 5E 8E 98 A4 00 0F E2 2C A5 C4 38 F3 B1 2D E6 D4 EA 9A 0C EF 6B
AB 93 A4 6F 02 92 17 19 06 4B EE AC B0 81 14 72 59 B7 60 E0 03 4D DE 7D 79 CB 0D 51 40 90 9C C9 96 FC C2 B4 AD D7 F0 E8
B2 A8 F4 BF 8B 14 42 E8 E5 A7 7C 3D 9F C8 48 14 45 4C 31 46 5C 9D 34 62 28 CA 21 5F 95 62 15 2B 51 2E 0C 25 7C 06 B3 84
AA 2B 94 07 FB AA 14 2C 30 A4 C2 EA B1 4E 23 1F 5C 3D 8B DB 1B DC 99 9A E9 41 1D 0C B0 31 0D 90 E3
16 : 37 : 33 <====Rx METER-2 D4 81 E6 20 00 00 01 92 C4 02 81 00 00 00 00 3E 00 81 D6 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11
00 02 09 09 0C 07 E3 0B 14 03 0E 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02
09 09 0C 07 E3 0B 14 03 0E 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09
0C 07 E3 0B 14 03 0E 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07
E3 0B 14 03 0F 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B
14 03 0F 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
16 : 37 : 33 ====>Tx METER-2 D0 0C 20 00 00 01 92 C0 02 C1 00 00 00 3E
16 : 37 : 33 ====>Tx METER-2 D0 0C 20 00 00 01 92 65 04 57 48 EF 47 1B
16 : 37 : 33 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 01 92 65 04 57 48 EF 47 1B 18 68 7E
16 : 37 : 33 <====Rx METER-2 7E A0 DE 41 00 02 04 01 96 18 38 E6 E7 00 D4 81 CC 20 00 00 01 93 0F 4D 0C 21 89 84 75 CB 25 B3 3D 31 5E D4 0C 1C 23 28
C3 FB 5B 23 96 93 85 F7 7F 2E 2C BE D5 7C D7 29 B8 64 09 7C 84 45 4E E1 E2 E8 8B A6 A7 E4 C0 27 51 9D 09 E9 B7 BB 16 D8
23 88 DF 8B 0C EA EC 21 D9 7A 56 BE 35 E8 05 CA AB 35 8F D7 8F 66 FE 6F 22 9E 9B 24 B5 DA B6 07 CB 04 87 BE D0 5C DF 1E
4B C3 A2 15 A5 FB D2 F6 AF 53 B0 2E C1 BA 91 BB A7 E8 93 D7 72 B7 92 19 DC 63 3B 19 EA AA EA 42 C8 13 7E 9D 25 5D C4 1B
44 4D 52 5E 90 55 F1 A5 73 CD 33 2B 52 64 71 6E 89 11 9A 04 E7 8E 62 6E 76 4F 49 4B 5A 9D 61 63 3F 3A 44 16 CB B5 14 1C
6D 28 3E 7D 88 18 52 18 ED DE A6 EA AF 28 2F 3E 56 30 DA 04 03 DE 3E 7E
16 : 37 : 33 <====Rx METER-2 E6 E7 00 D4 81 CC 20 00 00 01 93 0F 4D 0C 21 89 84 75 CB 25 B3 3D 31 5E D4 0C 1C 23 28 C3 FB 5B 23 96 93 85 F7 7F 2E 2C
BE D5 7C D7 29 B8 64 09 7C 84 45 4E E1 E2 E8 8B A6 A7 E4 C0 27 51 9D 09 E9 B7 BB 16 D8 23 88 DF 8B 0C EA EC 21 D9 7A 56
BE 35 E8 05 CA AB 35 8F D7 8F 66 FE 6F 22 9E 9B 24 B5 DA B6 07 CB 04 87 BE D0 5C DF 1E 4B C3 A2 15 A5 FB D2 F6 AF 53 B0
2E C1 BA 91 BB A7 E8 93 D7 72 B7 92 19 DC 63 3B 19 EA AA EA 42 C8 13 7E 9D 25 5D C4 1B 44 4D 52 5E 90 55 F1 A5 73 CD 33
2B 52 64 71 6E 89 11 9A 04 E7 8E 62 6E 76 4F 49 4B 5A 9D 61 63 3F 3A 44 16 CB B5 14 1C 6D 28 3E 7D 88 18 52 18 ED DE A6
16 : 37 : 33 <====Rx METER-2 01 82 01 62 02 09 09 0C 07 E3 0B 0E 04 00 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 0E 04 00 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 0E 04 00 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 0E 04 01 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 0E 04 01 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 0E 04 01 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E
04 01 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 02
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 02 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 02 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 02 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 03 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 03 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 03 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 03 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 04 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 04 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 04 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 04 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 05 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 05 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 0E 04 05 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 0E 04 05 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 0E 04 06 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 0E 04 06 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 0E 04 06 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E
04 06 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 07
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 07 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 07 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 07 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 08 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 08 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 08 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 08 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 09 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 09 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 09 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 09 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0A 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0A 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 0E 04 0A 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 0E 04 0A 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 0E 04 0B 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 0E 04 0B 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 0E 04 0B 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E
04 0B 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0C
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0C 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0C 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0C 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0D 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0D 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0D 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0D 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0E 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0E 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0E 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0E 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0F 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 0F 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 0E 04 0F 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 0E 04 0F 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 0E 04 10 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 0E 04 10 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 0E 04 10 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E
04 10 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 11
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 11 0F 00
FF 01 4A 00 12 48 1F 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 0D 02 09 09 0C 07 E3 0B 0E 04 11 1E 00 FF 01
4A 00 12 56 CF 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 0F 02 09 09 0C 07 E3 0B 0E 04 11 2D 00 FF 01 4A 00
12 5F 56 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 10 02 09 09 0C 07 E3 0B 0E 04 12 00 00 FF 01 4A 00 12 24
C9 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 06 02 09 09 0C 07 E3 0B 0E 04 12 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 12 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 12 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 13 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 13 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 13 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 13 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 14 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 14 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 0E 04 14 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 0E 04 14 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 0E 04 15 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 0E 04 15 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 0E 04 15 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E
04 15 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 16
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 16 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 16 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 16 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 17 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 17 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 17 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0E 04 17 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 00 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 00 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 00 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 00 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 01 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 01 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 0F 05 01 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 0F 05 01 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 0F 05 02 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 0F 05 02 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 0F 05 02 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F
05 02 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 03
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 03 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 03 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 03 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 04 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 04 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 04 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 04 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 05 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 05 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 05 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 05 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 06 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 06 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 0F 05 06 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 0F 05 06 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 0F 05 07 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 0F 05 07 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 0F 05 07 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F
05 07 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 08
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 08 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 08 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 08 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 09 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 09 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 09 1E 00 FF 01 4A 00 12 2A A4 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 06 02 09 09 0C 07 E3 0B 0F 05 09 2D 00 FF 01 4A 00 12 5D BD 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0A 00 00 FF 01 4A 00 12 5D E4 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 0B 11 0F 02 09 09 0C 07 E3 0B 0F 05 0A 0F 00 FF 01 4A 00 12 5E 39 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0A 1E 00 FF 01 4A 00 12 5E 07 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0A 2D 00 FF 01 4A 00 12 5E 4F 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0B 00 00 FF 01 4A 00 12 5E 7A 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0B 0F 00 FF 01 4A 00 12 5F 85 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B
11 12 02 09 09 0C 07 E3 0B 0F 05 0B 1E 00 FF 01 4A 00 12 5F 80 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11
02 09 09 0C 07 E3 0B 0F 05 0B 2D 00 FF 01 4A 00 12 5E A6 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09
09 0C 07 E3 0B 0F 05 0C 00 00 FF 01 4A 00 12 5F 40 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C
07 E3 0B 0F 05 0C 0F 00 FF 01 4A 00 12 60 18 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 0F 02 09 09 0C 07 E3
0B 0F 05 0C 1E 00 FF 01 4A 00 12 5F E5 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 0E 02 09 09 0C 07 E3 0B 0F
05 0C 2D 00 FF 01 4A 00 12 5F B8 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 10 02 09 09 0C 07 E3 0B 0F 05 0D
00 00 FF 01 4A 00 12 5F FC 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0D 0F 00
FF 01 4A 00 12 61 1F 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 12 02 09 09 0C 07 E3 0B 0F 05 0D 1E 00 FF 01
4A 00 12 61 C4 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0D 2D 00 FF 01 4A 00
12 61 FD 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 12 02 09 09 0C 07 E3 0B 0F 05 0E 00 00 FF 01 4A 00 12 62
04 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0E 0F 00 FF 01 4A 00 12 62 11 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 12 02 09 09 0C 07 E3 0B 0F 05 0E 1E 00 FF 01 4A 00 12 61 8E 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0E 2D 00 FF 01 4A 00 12 61 BD 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0F 00 00 FF 01 4A 00 12 61 DA 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 0B 11 11 02 09 09 0C 07 E3 0B 0F 05 0F 0F 00 FF 01 4A 00 12 5A 1C 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 0B 11 10 02 09 09 0C 07 E3 0B 0F 05 0F 1E 00 FF 01 4A 00 12 5B 98 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 0B 11 13 02 09 09 0C 07 E3 0B 0F 05 0F 2D 00 FF 01 4A 00 12 5C C1 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 0B 11 14 02 09 09 0C 07 E3 0B 0F 05 10 00 00 FF 01 4A 00 12 5C C5 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 0C 11 12 02 09 09 0C 07 E3 0B 0F 05 10 0F 00 FF 01 4A 00 12 5C C3 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C
11 13 02 09 09 0C 07 E3 0B 0F 05 10 1E 00 FF 01 4A 00 12 5C BD 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 11
02 09 09 0C 07 E3 0B 0F 05 10 2D 00 FF 01 4A 00 12 5C C2 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 10 02 09
09 0C 07 E3 0B 0F 05 11 00 00 FF 01 4A 00 12 5C C5 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 10 02 09 09 0C
07 E3 0B 0F 05 11 0F 00 FF 01 4A 00 12 5C C4 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 10 02 09 09 0C 07 E3
0B 0F 05 11 1E 00 FF 01 4A 00 12 5C C7 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 10 02 09 09 0C 07 E3 0B 0F
05 11 2D 00 FF 01 4A 00 12 5C C7 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 10 02 09 09 0C 07 E3 0B 0F 05 12
00 00 FF 01 4A 00 12 5C CD 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 11 02 09 09 0C 07 E3 0B 0F 05 12 0F 00
FF 01 4A 00 12 3D 2F 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 0C 02 09 09 0C 07 E3 0B 0F 05 12 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 12 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 13 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 13 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 13 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 13 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 14 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 14 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 14 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 14 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 15 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 15 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 0F 05 15 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 0F 05 15 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 0F 05 16 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 0F 05 16 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 0F 05 16 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F
05 16 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 17
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 17 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 17 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 0F 05 17 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 10 06 00 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 00 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 00 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 00 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 01 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 01 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 01 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 01 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 02 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 13 02 02 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 13 02 02 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 13 02 02 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 13 02 03 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 13 02 03 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 13 02 03 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13
02 03 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 04
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 04 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 04 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 04 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 05 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 05 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 05 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 05 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 06 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 06 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 06 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 06 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 07 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 13 02 07 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 13 02 07 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 13 02 07 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 13 02 08 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 13 02 08 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 13 02 08 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13
02 08 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 09
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 09 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 09 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 09 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0A 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0A 0F 00 FF 01 4A 00 12 2E 20 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 08 02 09 09 0C 07 E3 0B 13 02 0A 1E 00 FF 01 4A 00 12 2F 14 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 09 02 09 09 0C 07 E3 0B 13 02 0A 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0B 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0B 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0B 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0B 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0C 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0C 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 13 02 0C 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 13 02 0C 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 13 02 0D 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 13 02 0D 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 13 02 0D 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13
02 0D 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0E
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0E 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0E 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0E 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0F 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0F 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 0F 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 0C 11 00 02 09 09 0C 07 E3 0B 13 02 0F 2D 00 FF 01 4A 00 12 14 D1 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 02 11 03 02 09 09 0C 07 E3 0B 13 02 10 00 00 FF 01 4A 00 12 5C 1C 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 02 11 13 02 09 09 0C 07 E3 0B 13 02 10 0F 00 FF 01 4A 00 12 5C 23 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 0B 02 09 09 0C 07 E3 0B 13 02 10 1E 00 FF 01 4A 00 12 5C D5 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 01 11 0A 02 09 09 0C 07 E3 0B 13 02 10 2D 00 FF 01 4A 00 12 58 5D 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 01 11 00 02 09 09 0C 07 E3 0B 13 02 11 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 13 02 11 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 13 02 11 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 13 02 11 2D 00 FF 01 4A 00 12 1E A8 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 03 11 00 02 09
09 0C 07 E3 0B 13 02 12 00 00 FF 01 4A 00 12 2D AC 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 03 11 00 02 09 09 0C
07 E3 0B 13 02 12 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 13 02 12 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13
02 12 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 13
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 13 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 13 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 13 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 14 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 14 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 14 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 14 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 15 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 15 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 15 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 15 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13 02 16 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 13 02 16 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 13 02 16 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 13 02 16 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 13 02 17 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 13 02 17 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 13 02 17 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 13
02 17 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 00
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 00 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 00 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 00 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 01 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 01 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 01 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 01 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 02 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 02 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 02 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 02 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 03 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 14 03 03 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 14 03 03 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 14 03 03 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 14 03 04 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 14 03 04 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 14 03 04 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14
03 04 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 05
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 05 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 05 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 05 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 06 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 06 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 06 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 06 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 07 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 07 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 07 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 07 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 08 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 14 03 08 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 14 03 08 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 14 03 08 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 14 03 09 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 14 03 09 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 14 03 09 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14
03 09 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0A
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0A 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0A 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0A 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0B 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0B 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0B 1E 00 FF 01 4A 00 12 00 00 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0B 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00
00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0C 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12
00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0C 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00
12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0C 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00
00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0C 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12
00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0D 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00
11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0D 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00
11 00 02 09 09 0C 07 E3 0B 14 03 0D 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00
02 09 09 0C 07 E3 0B 14 03 0D 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09
09 0C 07 E3 0B 14 03 0E 00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C
07 E3 0B 14 03 0E 0F 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3
0B 14 03 0E 1E 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14
03 0E 2D 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0F
00 00 FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0F 0F 00
FF 01 4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0F 1E 00 FF 01
4A 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 0F 2D 00 FF 01 4A 00
12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 10 00 00 FF 01 4A 00 12 00
00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 10 0F 00 FF 01 4A 00 12 00 00 12
00 00 12 00 00 12 00 00 12 00 00 12 00 00 11 00 11 00 02 09 09 0C 07 E3 0B 14 03 10 1E 00 FF 01 4A 00 12 29 72 12 00 00
12 00 00 12 00 00 12 00 00 12 00 00 11 02 11 00
16 : 37 : 34 METER-2 SERVICE = GET RESPONSE
16 : 37 : 34 METER-2 COSEM OUT DATA
16 : 37 : 34 ====>Tx METER-2 D0 12 20 00 00 01 93 C0 01 C1 00 07 01 00 63 01 00 FF 03 00
16 : 37 : 34 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 34 ====>Tx METER-2 D0 12 20 00 00 01 93 62 23 34 65 CC B2 95 0A 1D 11 95 A5 E1
16 : 37 : 34 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-1-0-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 34 METER-2 SENDING HDLC FRAME
16 : 37 : 34 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 93 62 23 34 65 CC B2 95 0A 1D 11 95 A5 E1 32 C1 7E
16 : 37 : 34 METER-2 RECEIVED HDLC FRAME
16 : 37 : 34 <====Rx METER-2 7E A0 BF 41 00 02 04 01 B8 34 CB E6 E7 00 D4 81 AD 20 00 00 01 94 A0 4C C9 00 5D 84 AD 76 FC 9C 1B 48 F4 87 A7 E8 1B 99
93 F2 BD DB 93 E9 B3 83 24 4F 6C 3D 2B 36 A9 86 F3 DD 3C 64 DD B3 1E 04 D2 4E 58 D4 79 EE F6 81 49 8A E3 E8 BB 72 EB 01
24 DD 67 F6 12 17 1F CB 1A 75 4A 21 97 33 CB 20 D9 5E 25 DD E1 63 02 D4 E0 D5 99 65 34 44 2E CD 7B 03 B3 DB 8A F2 58 93
CE 69 7A 4F A3 13 88 BC 89 75 6E EE 17 FD 3E C7 78 95 79 28 B3 74 7A 82 49 3E B7 71 67 D5 E1 88 E7 10 DC 20 40 8C AE 13
3A FC F9 FE 67 D6 64 68 01 5B 8B 2E AB 5E 50 44 C1 7E 46 AA 65 F4 B8 1E 1C 49 17 1A B3 04 BE 87 7E
16 : 37 : 34 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 34 <====Rx METER-2 D4 81 AD 20 00 00 01 94 A0 4C C9 00 5D 84 AD 76 FC 9C 1B 48 F4 87 A7 E8 1B 99 93 F2 BD DB 93 E9 B3 83 24 4F 6C 3D 2B 36
A9 86 F3 DD 3C 64 DD B3 1E 04 D2 4E 58 D4 79 EE F6 81 49 8A E3 E8 BB 72 EB 01 24 DD 67 F6 12 17 1F CB 1A 75 4A 21 97 33
CB 20 D9 5E 25 DD E1 63 02 D4 E0 D5 99 65 34 44 2E CD 7B 03 B3 DB 8A F2 58 93 CE 69 7A 4F A3 13 88 BC 89 75 6E EE 17 FD
3E C7 78 95 79 28 B3 74 7A 82 49 3E B7 71 67 D5 E1 88 E7 10 DC 20 40 8C AE 13 3A FC F9 FE 67 D6 64 68 01 5B 8B 2E AB 5E
16 : 37 : 34 <====Rx METER-2 D4 81 AD 20 00 00 01 94 C4 01 81 00 01 09 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01
00 0C 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 1D 00
FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0A 1D 00 FF 0F 02 12
00 00 02 04 12 00 03 09 06 01 00 0B 1B 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0A 01 FF 0F 02 12 00 00 02 04
12 00 04 09 06 00 01 60 0C 05 FF 0F 02 12 00 00
16 : 37 : 34 ====>Tx METER-2 D0 12 20 00 00 01 94 C0 01 C1 00 07 01 00 63 01 00 FF 04 00
16 : 37 : 34 ====>Tx METER-2 D0 12 20 00 00 01 94 E2 4C 21 7D CA 4E 27 F0 54 4D 2E 17 9A
16 : 37 : 34 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-1-0-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 34 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 94 E2 4C 21 7D CA 4E 27 F0 54 4D 2E 17 9A E4 A5 7E
16 : 37 : 34 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 01 95 A0 F3 A8 84 29 45 25 51 58 A9 C3 7E
16 : 37 : 34 <====Rx METER-2 D4 0E 20 00 00 01 95 A0 F3 A8 84 29 45 25 51 58
16 : 37 : 34 <====Rx METER-2 D4 0E 20 00 00 01 95 C4 01 81 00 06 00 00 03 84
16 : 37 : 34 ====>Tx METER-2 D0 12 20 00 00 01 95 C0 01 C1 00 07 01 00 63 01 00 FF 05 00
16 : 37 : 34 ====>Tx METER-2 D0 12 20 00 00 01 95 13 65 55 6F F0 54 0D 65 AD 4F D5 4C F1
16 : 37 : 34 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-1-0-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 34 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 95 13 65 55 6F F0 54 0D 65 AD 4F D5 4C F1 71 4A 7E
16 : 37 : 34 <====Rx METER-2 7E A0 1C 41 00 02 04 01 FC E4 82 E6 E7 00 D4 0B 20 00 00 01 96 19 F1 4C 5B BA 0E FF 6C 7E
16 : 37 : 34 <====Rx METER-2 D4 0B 20 00 00 01 96 19 F1 4C 5B BA 0E
16 : 37 : 34 <====Rx METER-2 D4 0B 20 00 00 01 96 C4 01 81 00 16 01
16 : 37 : 34 ====>Tx METER-2 D0 12 20 00 00 01 96 C0 01 C1 00 07 01 00 63 01 00 FF 06 00
16 : 37 : 34 ====>Tx METER-2 D0 12 20 00 00 01 96 8D 0A 9D FA D7 26 08 12 6A F4 50 B4 14
16 : 37 : 34 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-1-0-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 34 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 96 8D 0A 9D FA D7 26 08 12 6A F4 50 B4 14 12 C7 7E
16 : 37 : 34 <====Rx METER-2 7E A0 2C 41 00 02 04 01 1E B2 90 E6 E7 00 D4 1B 20 00 00 01 97 5F BD FF D9 70 71 D6 0D 90 A7 B3 8B 52 F4 99 52 5A E3 CD
A5 B2 6C 5E FF 7E
16 : 37 : 34 <====Rx METER-2 D4 1B 20 00 00 01 97 5F BD FF D9 70 71 D6 0D 90 A7 B3 8B 52 F4 99 52 5A E3 CD A5 B2 6C
16 : 37 : 35 <====Rx METER-2 D4 1B 20 00 00 01 97 C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 35 METER-2 SERVICE = GET RESPONSE
16 : 37 : 35 METER-2 COSEM OUT DATA
16 : 37 : 35 ====>Tx METER-2 D0 12 20 00 00 01 97 C0 01 C1 00 07 01 00 63 01 00 FF 07 00
16 : 37 : 35 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 35 ====>Tx METER-2 D0 12 20 00 00 01 97 E7 77 BA 01 2D 03 DC 13 63 1A DA 5E 6D
16 : 37 : 35 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-1-0-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 35 METER-2 SENDING HDLC FRAME
16 : 37 : 35 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 97 E7 77 BA 01 2D 03 DC 13 63 1A DA 5E 6D 18 C6 7E
16 : 37 : 35 METER-2 RECEIVED HDLC FRAME
16 : 37 : 35 <====Rx METER-2 7E A0 1F 41 00 02 04 01 30 EA 26 E6 E7 00 D4 0E 20 00 00 01 98 DD D6 B8 E3 A0 40 FE 22 43 2E BD 7E
16 : 37 : 35 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 35 <====Rx METER-2 D4 0E 20 00 00 01 98 DD D6 B8 E3 A0 40 FE 22 43
16 : 37 : 35 <====Rx METER-2 D4 0E 20 00 00 01 98 C4 01 81 00 06 00 00 01 62
16 : 37 : 35 ====>Tx METER-2 D0 12 20 00 00 01 98 C0 01 C1 00 07 01 00 63 01 00 FF 08 00
16 : 37 : 35 ====>Tx METER-2 D0 12 20 00 00 01 98 2B 7A 9E F6 F5 F4 C4 CD 8D D8 66 2F E4
16 : 37 : 35 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-1-0-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 35 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 98 2B 7A 9E F6 F5 F4 C4 CD 8D D8 66 2F E4 A2 45 7E
16 : 37 : 35 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 01 99 14 CC 70 B0 FA F8 83 FC A1 D4 EC 7E
16 : 37 : 35 <====Rx METER-2 D4 0E 20 00 00 01 99 14 CC 70 B0 FA F8 83 FC A1
16 : 37 : 35 <====Rx METER-2 D4 0E 20 00 00 01 99 C4 01 81 00 06 00 00 07 80
16 : 37 : 35 ====>Tx METER-2 D0 12 20 00 00 01 99 C0 01 C1 00 07 01 00 63 02 00 FF 02 00
16 : 37 : 35 ====>Tx METER-2 D0 12 20 00 00 01 99 0F AE E1 03 74 C4 0F 97 3F 9B 7D 4B 1E
16 : 37 : 35 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-2-0-255, IC = 7, ATTR: INDEX = 2
16 : 37 : 35 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 99 0F AE E1 03 74 C4 0F 97 3F 9B 7D 4B 1E F4 95 7E
16 : 37 : 35 <====Rx METER-2 7E A0 F8 41 00 02 04 01 74 4A C7 E6 E7 00 D4 81 E6 20 00 00 01 9A 1F DB F5 7B 5D 1A 92 07 A7 3F F3 B3 F8 0D 84 D0 AA 5F
84 49 C2 B9 14 3D 42 31 44 58 9C 73 45 23 72 6B 5F 47 AF FD 68 84 65 CE D6 F7 F2 37 56 42 A4 A9 FF A8 7E 3F 7D 11 E2 F8
A4 57 39 A6 1A FB EF 05 A6 E4 24 0F 80 62 08 09 A8 09 1A 47 35 22 82 A7 38 9C C8 8E 50 80 3A 73 1F 6C 62 F5 51 9B 5C 3D
60 5A FB 9D DF 88 BF 6D 18 05 B5 61 B1 0E 3C 2D AD B8 DC 1D 62 3B 53 25 CE 21 58 2F 6A 65 B4 BE 07 9D D9 93 E2 66 80 C6
12 6F 6B 23 87 A9 B1 4B 41 97 79 89 82 CB 2C B1 36 07 C4 A1 EA 45 42 55 4D 3C 20 F0 65 EA 1B 18 69 F9 83 BC 2D C8 25 77
40 C7 CF 8C 19 52 75 12 2D 22 D7 9D 5B FC DD E3 18 58 AA C2 86 62 C5 B3 D6 DE 79 F7 2C 6B 1E 31 88 F0 05 46 56 5F 6B 06
AC B1 00 57 9A D5 34 9B AA 7E
16 : 37 : 35 <====Rx METER-2 D4 81 E6 20 00 00 01 9A 1F DB F5 7B 5D 1A 92 07 A7 3F F3 B3 F8 0D 84 D0 AA 5F 84 49 C2 B9 14 3D 42 31 44 58 9C 73 45 23
72 6B 5F 47 AF FD 68 84 65 CE D6 F7 F2 37 56 42 A4 A9 FF A8 7E 3F 7D 11 E2 F8 A4 57 39 A6 1A FB EF 05 A6 E4 24 0F 80 62
08 09 A8 09 1A 47 35 22 82 A7 38 9C C8 8E 50 80 3A 73 1F 6C 62 F5 51 9B 5C 3D 60 5A FB 9D DF 88 BF 6D 18 05 B5 61 B1 0E
3C 2D AD B8 DC 1D 62 3B 53 25 CE 21 58 2F 6A 65 B4 BE 07 9D D9 93 E2 66 80 C6 12 6F 6B 23 87 A9 B1 4B 41 97 79 89 82 CB
2C B1 36 07 C4 A1 EA 45 42 55 4D 3C 20 F0 65 EA 1B 18 69 F9 83 BC 2D C8 25 77 40 C7 CF 8C 19 52 75 12 2D 22 D7 9D 5B FC
DD E3 18 58 AA C2 86 62 C5 B3 D6 DE 79 F7 2C 6B 1E 31 88 F0 05 46 56 5F 6B 06 AC B1 00 57 9A D5 34
16 : 37 : 35 <====Rx METER-2 D4 81 E6 20 00 00 01 9A C4 02 81 00 00 00 00 01 00 81 D6 01 03 02 09 09 0C 07 E3 0B 0F 05 00 00 00 FF 01 4A 00 17 00 00
00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 17 00 00 00
00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 09 09 0C 07 E3 0B 10 06 00 00 00 FF 01 4A 00 17 00 00 00 00 17 00 00 00
00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 17 00 00 00 00 09 0C FF FF FF
FF FF FF FF FF FF 80 00 FF 02 09 09 0C 07 E3 0B 14 03 00 00 00 FF 01 4A 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00
16 : 37 : 35 ====>Tx METER-2 D0 0C 20 00 00 01 9A C0 02 C1 00 00 00 01
16 : 37 : 35 ====>Tx METER-2 D0 0C 20 00 00 01 9A C7 5B C9 B5 38 D1 2E
16 : 37 : 35 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 35 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 76 50 12 E6 E6 00 D0 0C 20 00 00 01 9A C7 5B C9 B5 38 D1 2E C9 61 7E
16 : 37 : 35 <====Rx METER-2 7E A0 2A 41 00 02 04 01 96 3F C0 E6 E7 00 D4 19 20 00 00 01 9B F1 74 81 17 0F 4A C0 D7 35 C9 77 96 BA 6F 37 D3 0E 0A 6D
0C BA E5 7E
16 : 37 : 35 <====Rx METER-2 E6 E7 00 D4 19 20 00 00 01 9B F1 74 81 17 0F 4A C0 D7 35 C9 77 96 BA 6F 37 D3 0E 0A 6D 0C
16 : 37 : 35 <====Rx METER-2 01 03 02 09 09 0C 07 E3 0B 0F 05 00 00 00 FF 01 4A 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00
00 00 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 17 00 00 00 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 09 09 0C
07 E3 0B 10 06 00 00 00 FF 01 4A 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 09 0C FF
FF FF FF FF FF FF FF FF 80 00 FF 17 00 00 00 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 09 09 0C 07 E3 0B 14 03 00
00 00 FF 01 4A 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 09 0C FF FF FF FF FF FF FF
16 : 37 : 35 ====>Tx METER-2 D0 12 20 00 00 01 9B C0 01 C1 00 07 01 00 63 02 00 FF 03 00
16 : 37 : 36 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 36 ====>Tx METER-2 D0 12 20 00 00 01 9B 05 7B 4F B2 DE 66 C2 86 11 74 CD BD AB
16 : 37 : 36 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-2-0-255, IC = 7, ATTR: INDEX = 3
16 : 37 : 36 METER-2 SENDING HDLC FRAME
16 : 37 : 36 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 9B 05 7B 4F B2 DE 66 C2 86 11 74 CD BD AB B9 24 7E
16 : 37 : 36 METER-2 RECEIVED HDLC FRAME
16 : 37 : 36 <====Rx METER-2 7E A0 BF 41 00 02 04 01 B8 34 CB E6 E7 00 D4 81 AD 20 00 00 01 9C 73 6D 67 7B D1 6D 91 4E AA F8 6D 30 5C 53 DD 51 2E 7A
22 42 2B F5 6E 20 D9 4F 7F 59 A3 3A 1D 1D FD 25 70 0B 67 B2 2E 6A EA 90 3A 8D 6C 4F 40 9C EB E3 4E B6 DF CD 7A 4E 64 AD
B4 DA DA FD C7 AE C6 CF 2A 8B 0A A1 65 F7 25 19 BC 6F 41 99 FA 5D 3E C1 FD F6 5F A5 A4 C9 6E C1 AA D3 A4 79 EC C4 A2 62
65 C8 70 47 07 55 30 99 E7 71 80 8C 03 FA E3 8F 6D C7 CD 51 8B 84 74 E0 F4 FF E8 8B 74 97 97 A0 B1 84 4C D5 F0 C9 61 05
93 D8 AC A5 02 7F C5 54 64 62 DE D9 DF 17 CB 9D 5D 5D 51 1C 8A 2E B4 0B 6E 2D 16 54 48 D2 69 65 7E
16 : 37 : 36 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 36 <====Rx METER-2 D4 81 AD 20 00 00 01 9C 73 6D 67 7B D1 6D 91 4E AA F8 6D 30 5C 53 DD 51 2E 7A 22 42 2B F5 6E 20 D9 4F 7F 59 A3 3A 1D 1D
FD 25 70 0B 67 B2 2E 6A EA 90 3A 8D 6C 4F 40 9C EB E3 4E B6 DF CD 7A 4E 64 AD B4 DA DA FD C7 AE C6 CF 2A 8B 0A A1 65 F7
25 19 BC 6F 41 99 FA 5D 3E C1 FD F6 5F A5 A4 C9 6E C1 AA D3 A4 79 EC C4 A2 62 65 C8 70 47 07 55 30 99 E7 71 80 8C 03 FA
E3 8F 6D C7 CD 51 8B 84 74 E0 F4 FF E8 8B 74 97 97 A0 B1 84 4C D5 F0 C9 61 05 93 D8 AC A5 02 7F C5 54 64 62 DE D9 DF 17
16 : 37 : 36 <====Rx METER-2 D4 81 AD 20 00 00 01 9C C4 01 81 00 01 09 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01
00 02 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0A 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00
FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 02 12
00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 05 12 00 00 02 04 12 00 04 09 06 01 00 09 06 00 FF 0F 02 12 00 00 02 04
12 00 04 09 06 01 00 09 06 00 FF 0F 05 12 00 00
16 : 37 : 36 METER-2 SERVICE = GET RESPONSE
16 : 37 : 36 ====>Tx METER-2 D0 12 20 00 00 01 9C C0 01 C1 00 07 01 00 63 02 00 FF 04 00
16 : 37 : 36 ====>Tx METER-2 D0 12 20 00 00 01 9C 89 46 BA B4 D1 0B 16 02 0D 06 B2 41 4C
16 : 37 : 36 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-2-0-255, IC = 7, ATTR: INDEX = 4
16 : 37 : 36 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 9C 89 46 BA B4 D1 0B 16 02 0D 06 B2 41 4C 3B 6F 7E
16 : 37 : 36 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 01 9D EF 29 27 82 F4 AF 46 F1 54 BD EA 7E
16 : 37 : 36 <====Rx METER-2 D4 0E 20 00 00 01 9D EF 29 27 82 F4 AF 46 F1 54
16 : 37 : 36 <====Rx METER-2 D4 0E 20 00 00 01 9D C4 01 81 00 06 00 01 51 80
16 : 37 : 36 ====>Tx METER-2 D0 12 20 00 00 01 9D C0 01 C1 00 07 01 00 63 02 00 FF 05 00
16 : 37 : 36 ====>Tx METER-2 D0 12 20 00 00 01 9D 57 65 B6 6F 14 85 F0 B9 77 A8 DB 00 6A
16 : 37 : 36 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-2-0-255, IC = 7, ATTR: INDEX = 5
16 : 37 : 36 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 9D 57 65 B6 6F 14 85 F0 B9 77 A8 DB 00 6A F6 45 7E
16 : 37 : 36 <====Rx METER-2 7E A0 1C 41 00 02 04 01 FC E4 82 E6 E7 00 D4 0B 20 00 00 01 9E 36 76 19 76 AD 62 85 86 7E
16 : 37 : 36 <====Rx METER-2 D4 0B 20 00 00 01 9E 36 76 19 76 AD 62
16 : 37 : 36 <====Rx METER-2 D4 0B 20 00 00 01 9E C4 01 81 00 16 01
16 : 37 : 36 ====>Tx METER-2 D0 12 20 00 00 01 9E C0 01 C1 00 07 01 00 63 02 00 FF 06 00
16 : 37 : 36 ====>Tx METER-2 D0 12 20 00 00 01 9E EF 7A 7F C5 EB D5 9A 3B C5 34 77 BB 3D
16 : 37 : 36 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-2-0-255, IC = 7, ATTR: INDEX = 6
16 : 37 : 36 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 9E EF 7A 7F C5 EB D5 9A 3B C5 34 77 BB 3D 3E 77 7E
16 : 37 : 36 <====Rx METER-2 7E A0 2C 41 00 02 04 01 1E B2 90 E6 E7 00 D4 1B 20 00 00 01 9F 19 AF 2C 77 AF 4E BC 15 C6 08 8C 79 04 A8 22 DC AA 14 E0
AB BD 90 ED A1 7E
16 : 37 : 36 <====Rx METER-2 D4 1B 20 00 00 01 9F 19 AF 2C 77 AF 4E BC 15 C6 08 8C 79 04 A8 22 DC AA 14 E0 AB BD 90
16 : 37 : 36 <====Rx METER-2 D4 1B 20 00 00 01 9F C4 01 81 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
16 : 37 : 36 ====>Tx METER-2 D0 12 20 00 00 01 9F C0 01 C1 00 07 01 00 63 02 00 FF 07 00
16 : 37 : 36 ====>Tx METER-2 D0 12 20 00 00 01 9F D5 FC 7C F1 3F 51 3B 71 5E 7C 28 3D 41
16 : 37 : 36 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-2-0-255, IC = 7, ATTR: INDEX = 7
16 : 37 : 37 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 9F D5 FC 7C F1 3F 51 3B 71 5E 7C 28 3D 41 7B 15 7E
16 : 37 : 37 METER-2 RECEIVED HDLC FRAME
16 : 37 : 37 <====Rx METER-2 7E A0 1F 41 00 02 04 01 30 EA 26 E6 E7 00 D4 0E 20 00 00 01 A0 5B C4 0B 3B 1F 13 69 27 31 6F E9 7E
16 : 37 : 37 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 37 <====Rx METER-2 D4 0E 20 00 00 01 A0 5B C4 0B 3B 1F 13 69 27 31
16 : 37 : 37 <====Rx METER-2 D4 0E 20 00 00 01 A0 C4 01 81 00 06 00 00 00 03
16 : 37 : 37 METER-2 SERVICE = GET RESPONSE
16 : 37 : 37 METER-2 COSEM OUT DATA
16 : 37 : 37 ====>Tx METER-2 D0 12 20 00 00 01 A0 C0 01 C1 00 07 01 00 63 02 00 FF 08 00
16 : 37 : 37 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 37 ====>Tx METER-2 D0 12 20 00 00 01 A0 B9 2F E5 74 26 38 4B 28 1E BB AF 1C 90
16 : 37 : 37 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-99-2-0-255, IC = 7, ATTR: INDEX = 8
16 : 37 : 37 METER-2 SENDING HDLC FRAME
16 : 37 : 37 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 A0 B9 2F E5 74 26 38 4B 28 1E BB AF 1C 90 47 5D 7E
16 : 37 : 37 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 01 A1 C1 7F 78 86 60 8F 5E 89 48 44 02 7E
16 : 37 : 37 <====Rx METER-2 D4 0E 20 00 00 01 A1 C1 7F 78 86 60 8F 5E 89 48
16 : 37 : 37 <====Rx METER-2 D4 0E 20 00 00 01 A1 C4 01 81 00 06 00 00 00 28
16 : 37 : 37 ====>Tx METER-2 D0 12 20 00 00 01 A1 C0 01 C1 00 08 00 00 01 00 00 FF 02 00
16 : 37 : 37 ====>Tx METER-2 D0 12 20 00 00 01 A1 3D 66 F2 5D 4E 7D A6 D1 6C 04 65 DE B1
16 : 37 : 37 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-1-0-0-255, IC = 8, ATTR: INDEX = 2
16 : 37 : 37 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 A1 3D 66 F2 5D 4E 7D A6 D1 6C 04 65 DE B1 12 06 7E
16 : 37 : 37 <====Rx METER-2 7E A0 28 41 00 02 04 01 74 98 33 E6 E7 00 D4 17 20 00 00 01 A2 39 16 5A 6D 29 29 D6 57 54 A5 A1 8C EB F2 34 FD 6E 23 41
95 7E
16 : 37 : 37 <====Rx METER-2 D4 17 20 00 00 01 A2 39 16 5A 6D 29 29 D6 57 54 A5 A1 8C EB F2 34 FD 6E 23
16 : 37 : 37 <====Rx METER-2 D4 17 20 00 00 01 A2 C4 01 81 00 09 0C 07 E3 0B 14 03 10 25 23 FF 01 4A 00
16 : 37 : 37 ====>Tx METER-2 D0 12 20 00 00 01 A2 C0 01 C1 00 08 00 00 01 00 00 FF 03 00
16 : 37 : 37 ====>Tx METER-2 D0 12 20 00 00 01 A2 55 AA 62 27 B6 72 66 85 13 6C 8A 01 96
16 : 37 : 37 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-1-0-0-255, IC = 8, ATTR: INDEX = 3
16 : 37 : 37 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 A2 55 AA 62 27 B6 72 66 85 13 6C 8A 01 96 86 49 7E
16 : 37 : 37 <====Rx METER-2 7E A0 1D 41 00 02 04 01 96 6D D1 E6 E7 00 D4 0C 20 00 00 01 A3 77 41 9A 56 25 8B F0 75 F4 7E
16 : 37 : 37 <====Rx METER-2 D4 0C 20 00 00 01 A3 77 41 9A 56 25 8B F0
16 : 37 : 37 <====Rx METER-2 D4 0C 20 00 00 01 A3 C4 01 81 00 10 01 4A
16 : 37 : 37 ====>Tx METER-2 D0 12 20 00 00 01 A3 C0 01 C1 00 08 00 00 01 00 00 FF 04 00
16 : 37 : 37 ====>Tx METER-2 D0 12 20 00 00 01 A3 01 1D D3 6D E8 87 A1 E7 8B 50 3A 0A 2E
16 : 37 : 37 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-1-0-0-255, IC = 8, ATTR: INDEX = 4
16 : 37 : 37 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 A3 01 1D D3 6D E8 87 A1 E7 8B 50 3A 0A 2E D6 C9 7E
16 : 37 : 37 <====Rx METER-2 7E A0 1C 41 00 02 04 01 B8 C4 86 E6 E7 00 D4 0B 20 00 00 01 A4 66 59 6A 4A 37 39 6A A7 7E
16 : 37 : 38 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 38 <====Rx METER-2 D4 0B 20 00 00 01 A4 66 59 6A 4A 37 39
16 : 37 : 38 <====Rx METER-2 D4 0B 20 00 00 01 A4 C4 01 81 00 11 00
16 : 37 : 38 METER-2 SERVICE = GET RESPONSE
16 : 37 : 38 METER-2 COSEM OUT DATA
16 : 37 : 38 ====>Tx METER-2 D0 12 20 00 00 01 A4 C0 01 C1 00 08 00 00 01 00 00 FF 05 00
16 : 37 : 38 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 38 ====>Tx METER-2 D0 12 20 00 00 01 A4 D7 28 22 7C 1A C2 F5 82 10 E8 51 60 86
16 : 37 : 38 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-1-0-0-255, IC = 8, ATTR: INDEX = 5
16 : 37 : 38 METER-2 SENDING HDLC FRAME
16 : 37 : 38 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 A4 D7 28 22 7C 1A C2 F5 82 10 E8 51 60 86 2F 2F 7E
16 : 37 : 38 METER-2 RECEIVED HDLC FRAME
16 : 37 : 38 <====Rx METER-2 7E A0 28 41 00 02 04 01 DA EC 7F E6 E7 00 D4 17 20 00 00 01 A5 98 9B 60 D6 61 00 7A BE FD 6C 61 1F 45 F7 AF 17 86 3A 76
64 7E
16 : 37 : 38 <====Rx METER-2 D4 17 20 00 00 01 A5 98 9B 60 D6 61 00 7A BE FD 6C 61 1F 45 F7 AF 17 86 3A
16 : 37 : 38 <====Rx METER-2 D4 17 20 00 00 01 A5 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 37 : 38 ====>Tx METER-2 D0 12 20 00 00 01 A5 C0 01 C1 00 08 00 00 01 00 00 FF 06 00
16 : 37 : 38 ====>Tx METER-2 D0 12 20 00 00 01 A5 E1 03 6E 58 32 C8 AF AD E7 D4 89 3B 4E
16 : 37 : 38 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-1-0-0-255, IC = 8, ATTR: INDEX = 6
16 : 37 : 38 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 A5 E1 03 6E 58 32 C8 AF AD E7 D4 89 3B 4E 01 FB 7E
16 : 37 : 38 <====Rx METER-2 7E A0 28 41 00 02 04 01 FC D8 3B E6 E7 00 D4 17 20 00 00 01 A6 AB 3B 5B 3B CB AC FA 8D 34 F9 97 0D 1C BD B4 8E 8D 9B 09
52 7E
16 : 37 : 38 <====Rx METER-2 D4 17 20 00 00 01 A6 AB 3B 5B 3B CB AC FA 8D 34 F9 97 0D 1C BD B4 8E 8D 9B
16 : 37 : 38 <====Rx METER-2 D4 17 20 00 00 01 A6 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 37 : 38 ====>Tx METER-2 D0 12 20 00 00 01 A6 C0 01 C1 00 08 00 00 01 00 00 FF 07 00
16 : 37 : 38 ====>Tx METER-2 D0 12 20 00 00 01 A6 1E C4 88 0C FC 24 4C EC 62 76 50 30 1B
16 : 37 : 38 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-1-0-0-255, IC = 8, ATTR: INDEX = 7
16 : 37 : 38 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 A6 1E C4 88 0C FC 24 4C EC 62 76 50 30 1B CE 94 7E
16 : 37 : 38 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 01 A7 CE 7B 19 92 5B BF 09 C3 7E
16 : 37 : 38 <====Rx METER-2 D4 0B 20 00 00 01 A7 CE 7B 19 92 5B BF
16 : 37 : 38 <====Rx METER-2 D4 0B 20 00 00 01 A7 C4 01 81 00 0F 3C
16 : 37 : 38 ====>Tx METER-2 D0 12 20 00 00 01 A7 C0 01 C1 00 08 00 00 01 00 00 FF 08 00
16 : 37 : 38 ====>Tx METER-2 D0 12 20 00 00 01 A7 52 C4 CC 5E 8A BA E1 C4 2B 76 78 8B 19
16 : 37 : 38 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-1-0-0-255, IC = 8, ATTR: INDEX = 8
16 : 37 : 38 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 A7 52 C4 CC 5E 8A BA E1 C4 2B 76 78 8B 19 5A D7 7E
16 : 37 : 38 <====Rx METER-2 7E A0 1C 41 00 02 04 01 30 84 8E E6 E7 00 D4 0B 20 00 00 01 A8 FE 33 05 B8 40 75 94 BA 7E
16 : 37 : 38 <====Rx METER-2 D4 0B 20 00 00 01 A8 FE 33 05 B8 40 75
16 : 37 : 38 <====Rx METER-2 D4 0B 20 00 00 01 A8 C4 01 81 00 03 00
16 : 37 : 39 ====>Tx METER-2 D0 12 20 00 00 01 A8 C0 01 C1 00 08 00 00 01 00 00 FF 09 00
16 : 37 : 39 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 39 ====>Tx METER-2 D0 12 20 00 00 01 A8 F0 40 45 C1 1A AE 77 79 E4 37 F0 77 D6
16 : 37 : 39 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-1-0-0-255, IC = 8, ATTR: INDEX = 9
16 : 37 : 39 METER-2 SENDING HDLC FRAME
16 : 37 : 39 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 A8 F0 40 45 C1 1A AE 77 79 E4 37 F0 77 D6 A3 DD 7E
16 : 37 : 39 METER-2 RECEIVED HDLC FRAME
16 : 37 : 39 <====Rx METER-2 7E A0 1C 41 00 02 04 01 52 90 CE E6 E7 00 D4 0B 20 00 00 01 A9 79 7F DE BA 72 C7 7E 14 7E
16 : 37 : 39 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 39 <====Rx METER-2 D4 0B 20 00 00 01 A9 79 7F DE BA 72 C7
16 : 37 : 39 <====Rx METER-2 D4 0B 20 00 00 01 A9 C4 01 81 00 16 01
16 : 37 : 39 METER-2 SERVICE = GET RESPONSE
16 : 37 : 39 ====>Tx METER-2 D0 12 20 00 00 01 A9 C0 01 C1 00 09 00 00 0A 00 01 FF 02 00
16 : 37 : 39 ====>Tx METER-2 D0 12 20 00 00 01 A9 00 49 11 28 43 0B 87 E9 B1 4B F1 81 98
16 : 37 : 39 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-10-0-1-255, IC = 9, ATTR: INDEX = 2
16 : 37 : 39 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 A9 00 49 11 28 43 0B 87 E9 B1 4B F1 81 98 99 C8 7E
16 : 37 : 39 <====Rx METER-2 7E A0 35 41 00 02 04 01 74 1E A8 E6 E7 00 D4 24 20 00 00 01 AA 50 7C A5 56 B0 3C 89 07 D8 FE 05 67 0C A1 2A 5B 1B E6 AD
54 7F 3B 86 7E 7F 9F D9 B5 36 92 25 D0 E4 7E
16 : 37 : 39 <====Rx METER-2 D4 24 20 00 00 01 AA 50 7C A5 56 B0 3C 89 07 D8 FE 05 67 0C A1 2A 5B 1B E6 AD 54 7F 3B 86 7E 7F 9F D9 B5 36 92 25
16 : 37 : 39 <====Rx METER-2 D4 24 20 00 00 01 AA C4 01 81 00 01 01 02 02 12 00 01 01 01 02 05 16 02 12 00 07 09 06 01 00 62 01 00 FF 0F 02 00
16 : 37 : 39 ====>Tx METER-2 D0 12 20 00 00 01 AA C0 01 C1 00 09 00 00 0A 00 6A FF 02 00
16 : 37 : 39 ====>Tx METER-2 D0 12 20 00 00 01 AA 4F 5F 38 4D 6F 95 D3 82 E9 33 BF F6 11
16 : 37 : 39 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-10-0-106-255, IC = 9, ATTR: INDEX = 2
16 : 37 : 39 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 AA 4F 5F 38 4D 6F 95 D3 82 E9 33 BF F6 11 17 E7 7E
16 : 37 : 39 <====Rx METER-2 7E A0 4E 41 00 02 04 01 96 CC 0B E6 E7 00 D4 3D 20 00 00 01 AB 1B A4 37 3C 70 27 9D 07 6C 7D 65 73 1A 56 28 B9 D7 4D 97
C0 5B 56 7A C8 62 13 50 5E 68 6F AF 2C C4 CA 41 BF 16 7F 44 E3 58 F4 6F 98 EA 6A 60 30 55 BA 37 E5 33 82 E0 00 5E ED 7E
16 : 37 : 39 <====Rx METER-2 D4 3D 20 00 00 01 AB 1B A4 37 3C 70 27 9D 07 6C 7D 65 73 1A 56 28 B9 D7 4D 97 C0 5B 56 7A C8 62 13 50 5E 68 6F AF 2C C4
16 : 37 : 39 <====Rx METER-2 D4 3D 20 00 00 01 AB C4 01 81 00 01 02 02 02 12 00 01 01 01 02 05 16 02 12 00 46 09 06 00 00 60 03 0A FF 0F 01 00 02 02
12 00 02 01 01 02 05 16 02 12 00 46 09 06 00 00 60 03 0A FF 0F 02 00
16 : 37 : 39 ====>Tx METER-2 D0 12 20 00 00 01 AB C0 01 C1 00 09 00 00 0A 00 6B FF 02 00
16 : 37 : 39 ====>Tx METER-2 D0 12 20 00 00 01 AB B8 17 EC C6 9F 06 1F 42 33 C8 96 8A A1
16 : 37 : 39 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-10-0-107-255, IC = 9, ATTR: INDEX = 2
16 : 37 : 39 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 AB B8 17 EC C6 9F 06 1F 42 33 C8 96 8A A1 C3 E9 7E
16 : 37 : 39 <====Rx METER-2 7E A0 35 41 00 02 04 01 B8 7E A4 E6 E7 00 D4 24 20 00 00 01 AC 43 68 D7 40 DD FD 88 E2 4A 4C 2B 5C 99 4F A0 92 75 43 41
C4 67 89 14 C8 D0 C0 67 9F B1 62 03 17 36 7E
16 : 37 : 39 <====Rx METER-2 D4 24 20 00 00 01 AC 43 68 D7 40 DD FD 88 E2 4A 4C 2B 5C 99 4F A0 92 75 43 41 C4 67 89 14 C8 D0 C0 67 9F B1 62 03
16 : 37 : 39 <====Rx METER-2 D4 24 20 00 00 01 AC C4 01 81 00 01 01 02 02 12 00 01 01 01 02 05 16 02 12 00 12 09 06 00 00 2C 00 00 FF 0F 04 00
16 : 37 : 39 ====>Tx METER-2 D0 12 20 00 00 01 AC C0 01 C1 00 09 00 00 0A 00 6C FF 02 00
16 : 37 : 39 ====>Tx METER-2 D0 12 20 00 00 01 AC F0 E6 38 0B C1 86 AF F1 A3 D1 07 22 0F
16 : 37 : 39 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-10-0-108-255, IC = 9, ATTR: INDEX = 2
16 : 37 : 40 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 AC F0 E6 38 0B C1 86 AF F1 A3 D1 07 22 0F 50 8E 7E
16 : 37 : 40 METER-2 RECEIVED HDLC FRAME
16 : 37 : 40 <====Rx METER-2 7E A0 9A 41 00 02 04 01 DA 00 18 E6 E7 00 D4 81 88 20 00 00 01 AD 79 07 76 40 DE D6 DA BF AC 8F 76 84 BA F1 46 28 0B D9
1B 90 C4 C9 1F F6 06 12 D6 57 39 99 EC 08 E4 79 59 DC E2 0A 09 68 19 AE 02 35 D9 4C 51 C4 5C 11 1D 6B 86 38 64 49 34 AC
8C 4C 3D CF A6 A3 58 25 61 B8 30 3A 14 A4 8F 2A D1 08 28 35 87 B3 5E 6E 2B 98 22 20 1E 7B FA 0D B0 67 6A AB CA AA 5F 5B
FD 83 65 01 33 FE 6E AD 2D 20 F7 71 A8 02 18 E8 70 09 DA DE 9A D6 88 46 40 B1 EF 66 E6 49 15 CF 3A AD BE 7E
16 : 37 : 40 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 40 <====Rx METER-2 D4 81 88 20 00 00 01 AD 79 07 76 40 DE D6 DA BF AC 8F 76 84 BA F1 46 28 0B D9 1B 90 C4 C9 1F F6 06 12 D6 57 39 99 EC 08
E4 79 59 DC E2 0A 09 68 19 AE 02 35 D9 4C 51 C4 5C 11 1D 6B 86 38 64 49 34 AC 8C 4C 3D CF A6 A3 58 25 61 B8 30 3A 14 A4
8F 2A D1 08 28 35 87 B3 5E 6E 2B 98 22 20 1E 7B FA 0D B0 67 6A AB CA AA 5F 5B FD 83 65 01 33 FE 6E AD 2D 20 F7 71 A8 02
16 : 37 : 40 <====Rx METER-2 D4 81 88 20 00 00 01 AD C4 01 81 00 01 05 02 02 12 00 01 01 01 02 05 16 02 12 00 28 09 06 00 00 19 09 00 FF 0F 01 00 02
02 12 00 02 01 01 02 05 16 02 12 00 28 09 06 00 01 19 09 00 FF 0F 01 00 02 02 12 00 03 01 01 02 05 16 02 12 00 28 09 06
00 02 19 09 00 FF 0F 01 00 02 02 12 00 04 01 01 02 05 16 02 12 00 28 09 06 00 03 19 09 00 FF 0F 01 00 02 02 12 00 05 01
01 02 05 16 02 12 00 28 09 06 00 04 19 09 00 FF 0F 01 00
16 : 37 : 40 METER-2 SERVICE = GET RESPONSE
16 : 37 : 40 METER-2 COSEM OUT DATA
16 : 37 : 40 ====>Tx METER-2 D0 12 20 00 00 01 AD C0 01 C1 00 0F 00 00 28 00 01 FF 03 00
16 : 37 : 40 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 40 ====>Tx METER-2 D0 12 20 00 00 01 AD 82 08 1D 24 F1 65 67 4D A5 61 3D F5 BC
16 : 37 : 40 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-1-255, IC = 15, ATTR: INDEX = 3
16 : 37 : 40 METER-2 SENDING HDLC FRAME
16 : 37 : 40 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 AD 82 08 1D 24 F1 65 67 4D A5 61 3D F5 BC CB 8C 7E
16 : 37 : 40 <====Rx METER-2 7E A0 21 41 00 02 04 01 FC E1 7A E6 E7 00 D4 10 20 00 00 01 AE FF 89 A3 2F 91 58 04 A5 FC 31 A0 A2 E4 7E
16 : 37 : 40 <====Rx METER-2 D4 10 20 00 00 01 AE FF 89 A3 2F 91 58 04 A5 FC 31 A0
16 : 37 : 40 <====Rx METER-2 D4 10 20 00 00 01 AE C4 01 81 00 02 02 0F 10 12 00 01
16 : 37 : 40 ====>Tx METER-2 D0 12 20 00 00 01 AE C0 01 C1 00 0F 00 00 28 00 01 FF 04 00
16 : 37 : 40 ====>Tx METER-2 D0 12 20 00 00 01 AE FC 55 B3 97 FB A6 97 92 9E 4D 17 31 00
16 : 37 : 40 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-1-255, IC = 15, ATTR: INDEX = 4
16 : 37 : 40 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 AE FC 55 B3 97 FB A6 97 92 9E 4D 17 31 00 CF EC 7E
16 : 37 : 40 <====Rx METER-2 7E A0 23 41 00 02 04 01 1E 46 89 E6 E7 00 D4 12 20 00 00 01 AF A8 4D 2B EF AE 53 A2 3E A4 1C C6 31 FA 4B 83 7E
16 : 37 : 40 <====Rx METER-2 D4 12 20 00 00 01 AF A8 4D 2B EF AE 53 A2 3E A4 1C C6 31 FA
16 : 37 : 40 <====Rx METER-2 D4 12 20 00 00 01 AF C4 01 81 00 09 07 60 85 74 05 08 01 01
16 : 37 : 40 ====>Tx METER-2 D0 12 20 00 00 01 AF C0 01 C1 00 0F 00 00 28 00 01 FF 05 00
16 : 37 : 40 ====>Tx METER-2 D0 12 20 00 00 01 AF FF 4F BD 7C 18 14 5E 04 8D AB EB 25 88
16 : 37 : 40 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-1-255, IC = 15, ATTR: INDEX = 5
16 : 37 : 40 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 AF FF 4F BD 7C 18 14 5E 04 8D AB EB 25 88 07 7E 7E
16 : 37 : 40 <====Rx METER-2 7E A0 2D 41 00 02 04 01 30 1B C7 E6 E7 00 D4 1C 20 00 00 01 B0 54 D8 58 66 FC C3 80 7E 2F A7 D8 AA B9 F4 F5 43 42 D7 67
AD D7 D8 FB E3 AD 7E
16 : 37 : 40 <====Rx METER-2 D4 1C 20 00 00 01 B0 54 D8 58 66 FC C3 80 7E 2F A7 D8 AA B9 F4 F5 43 42 D7 67 AD D7 D8 FB
16 : 37 : 40 <====Rx METER-2 D4 1C 20 00 00 01 B0 C4 01 81 00 02 06 04 18 00 00 10 12 01 F4 12 07 ED 11 06 0F 00 09 00
16 : 37 : 40 ====>Tx METER-2 D0 12 20 00 00 01 B0 C0 01 C1 00 0F 00 00 28 00 01 FF 06 00
16 : 37 : 40 ====>Tx METER-2 D0 12 20 00 00 01 B0 11 51 7E BC 7A 85 FD 07 35 23 42 52 E0
16 : 37 : 40 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-1-255, IC = 15, ATTR: INDEX = 6
16 : 37 : 40 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 B0 11 51 7E BC 7A 85 FD 07 35 23 42 52 E0 69 8A 7E
16 : 37 : 40 <====Rx METER-2 7E A0 23 41 00 02 04 01 52 2E 01 E6 E7 00 D4 12 20 00 00 01 B1 A6 1D 7E 50 08 B7 BF 66 7A 7D F1 04 68 6C 0D 7E
16 : 37 : 40 <====Rx METER-2 D4 12 20 00 00 01 B1 A6 1D 7E 50 08 B7 BF 66 7A 7D F1 04 68
16 : 37 : 41 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 37 : 41 <====Rx METER-2 D4 12 20 00 00 01 B1 C4 01 81 00 09 07 60 85 74 05 08 02 00
16 : 37 : 41 METER-2 SERVICE = GET RESPONSE
16 : 37 : 41 METER-2 COSEM OUT DATA
16 : 37 : 41 ====>Tx METER-2 D0 12 20 00 00 01 B1 C0 01 C1 00 0F 00 00 28 00 01 FF 08 00
16 : 37 : 41 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 41 ====>Tx METER-2 D0 12 20 00 00 01 B1 74 51 93 8E 81 12 05 1C D5 06 BC DB 6F
16 : 37 : 41 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-1-255, IC = 15, ATTR: INDEX = 8
16 : 37 : 41 METER-2 SENDING HDLC FRAME
16 : 37 : 41 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 B1 74 51 93 8E 81 12 05 1C D5 06 BC DB 6F B6 C5 7E
16 : 37 : 41 METER-2 RECEIVED HDLC FRAME
16 : 37 : 41 <====Rx METER-2 7E A0 1C 41 00 02 04 01 74 A4 8A E6 E7 00 D4 0B 20 00 00 01 B2 6A 86 FE 0E 7D A4 1F E3 7E
16 : 37 : 41 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 41 <====Rx METER-2 D4 0B 20 00 00 01 B2 6A 86 FE 0E 7D A4
16 : 37 : 41 <====Rx METER-2 D4 0B 20 00 00 01 B2 C4 01 81 00 16 00
16 : 37 : 41 ====>Tx METER-2 D0 12 20 00 00 01 B2 C0 01 C1 00 0F 00 00 28 00 02 FF 03 00
16 : 37 : 41 ====>Tx METER-2 D0 12 20 00 00 01 B2 98 8B 28 76 81 7F BE 4B 8A BC 2D 5A 4C
16 : 37 : 41 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-2-255, IC = 15, ATTR: INDEX = 3
16 : 37 : 41 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 B2 98 8B 28 76 81 7F BE 4B 8A BC 2D 5A 4C 9B CA 7E
16 : 37 : 41 <====Rx METER-2 7E A0 21 41 00 02 04 01 96 BD B6 E6 E7 00 D4 10 20 00 00 01 B3 0D D7 5F F5 76 F4 DC D7 F0 56 D5 5C 9C 7E
16 : 37 : 41 <====Rx METER-2 D4 10 20 00 00 01 B3 0D D7 5F F5 76 F4 DC D7 F0 56 D5
16 : 37 : 41 <====Rx METER-2 D4 10 20 00 00 01 B3 C4 01 81 00 02 02 0F 20 12 00 01
16 : 37 : 41 ====>Tx METER-2 D0 12 20 00 00 01 B3 C0 01 C1 00 0F 00 00 28 00 02 FF 04 00
16 : 37 : 41 ====>Tx METER-2 D0 12 20 00 00 01 B3 7F 67 18 B9 57 BA 62 AA D6 80 26 EA 7F
16 : 37 : 41 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-2-255, IC = 15, ATTR: INDEX = 4
16 : 37 : 41 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 B3 7F 67 18 B9 57 BA 62 AA D6 80 26 EA 7F 0C E6 7E
16 : 37 : 41 <====Rx METER-2 7E A0 23 41 00 02 04 01 B8 7A 49 E6 E7 00 D4 12 20 00 00 01 B4 ED 21 99 2F CB 80 A4 0C D0 F3 C5 A7 75 8C 08 7E
16 : 37 : 41 <====Rx METER-2 D4 12 20 00 00 01 B4 ED 21 99 2F CB 80 A4 0C D0 F3 C5 A7 75
16 : 37 : 41 <====Rx METER-2 D4 12 20 00 00 01 B4 C4 01 81 00 09 07 60 85 74 05 08 01 03
16 : 37 : 41 ====>Tx METER-2 D0 12 20 00 00 01 B4 C0 01 C1 00 0F 00 00 28 00 02 FF 05 00
16 : 37 : 41 ====>Tx METER-2 D0 12 20 00 00 01 B4 83 CA 8C 8F CC 39 D1 4F 8B 75 1E 84 46
16 : 37 : 41 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-2-255, IC = 15, ATTR: INDEX = 5
16 : 37 : 41 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 B4 83 CA 8C 8F CC 39 D1 4F 8B 75 1E 84 46 45 7D 7E
16 : 37 : 41 <====Rx METER-2 7E A0 2D 41 00 02 04 01 DA 4F 8F E6 E7 00 D4 1C 20 00 00 01 B5 A7 3B 12 61 87 A0 3E B4 18 92 61 56 5A 98 ED 71 F6 E8 35
7A B8 C9 F5 FE CF 7E
16 : 37 : 41 <====Rx METER-2 D4 1C 20 00 00 01 B5 A7 3B 12 61 87 A0 3E B4 18 92 61 56 5A 98 ED 71 F6 E8 35 7A B8 C9 F5
16 : 37 : 41 <====Rx METER-2 D4 1C 20 00 00 01 B5 C4 01 81 00 02 06 04 18 00 10 14 12 01 F4 12 07 ED 11 06 0F 00 09 00
16 : 37 : 41 ====>Tx METER-2 D0 12 20 00 00 01 B5 C0 01 C1 00 0F 00 00 28 00 02 FF 06 00
16 : 37 : 42 ====>Tx METER-2 D0 12 20 00 00 01 B5 CB 59 F5 9A 52 7D BD BA F5 58 B1 55 98
16 : 37 : 42 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-2-255, IC = 15, ATTR: INDEX = 6
16 : 37 : 42 METER-2 SENDING HDLC FRAME
16 : 37 : 42 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 B5 CB 59 F5 9A 52 7D BD BA F5 58 B1 55 98 6D 96 7E
16 : 37 : 42 METER-2 RECEIVED HDLC FRAME
16 : 37 : 42 <====Rx METER-2 7E A0 23 41 00 02 04 01 FC 5A 4D E6 E7 00 D4 12 20 00 00 01 B6 DC D8 90 F7 4F 31 60 C8 94 C3 47 1E 85 01 90 7E
16 : 37 : 42 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 42 <====Rx METER-2 D4 12 20 00 00 01 B6 DC D8 90 F7 4F 31 60 C8 94 C3 47 1E 85
16 : 37 : 42 <====Rx METER-2 D4 12 20 00 00 01 B6 C4 01 81 00 09 07 60 85 74 05 08 02 01
16 : 37 : 42 METER-2 SERVICE = GET RESPONSE
16 : 37 : 42 METER-2 COSEM OUT DATA
16 : 37 : 42 ====>Tx METER-2 D0 12 20 00 00 01 B6 C0 01 C1 00 0F 00 00 28 00 02 FF 08 00
16 : 37 : 42 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 42 ====>Tx METER-2 D0 12 20 00 00 01 B6 03 06 18 55 03 0D EC F6 AD 8D DD 1F 6F
16 : 37 : 42 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-2-255, IC = 15, ATTR: INDEX = 8
16 : 37 : 42 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 B6 03 06 18 55 03 0D EC F6 AD 8D DD 1F 6F 46 20 7E
16 : 37 : 42 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 01 B7 51 78 3D 77 81 CC 63 3F 7E
16 : 37 : 42 <====Rx METER-2 D4 0B 20 00 00 01 B7 51 78 3D 77 81 CC
16 : 37 : 42 <====Rx METER-2 D4 0B 20 00 00 01 B7 C4 01 81 00 16 02
16 : 37 : 42 ====>Tx METER-2 D0 12 20 00 00 01 B7 C0 01 C1 00 0F 00 00 28 00 02 FF 09 00
16 : 37 : 42 ====>Tx METER-2 D0 12 20 00 00 01 B7 FF 6F F8 A7 A8 A6 3F CD 33 40 A1 75 55
16 : 37 : 42 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-2-255, IC = 15, ATTR: INDEX = 9
16 : 37 : 42 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 B7 FF 6F F8 A7 A8 A6 3F CD 33 40 A1 75 55 42 8E 7E
16 : 37 : 42 <====Rx METER-2 7E A0 22 41 00 02 04 01 30 EF DE E6 E7 00 D4 11 20 00 00 01 B8 41 59 6A 10 7C B1 32 7D 60 35 F6 00 96 74 7E
16 : 37 : 42 <====Rx METER-2 D4 11 20 00 00 01 B8 41 59 6A 10 7C B1 32 7D 60 35 F6 00
16 : 37 : 42 <====Rx METER-2 D4 11 20 00 00 01 B8 C4 01 81 00 09 06 00 00 2B 00 02 FF
16 : 37 : 42 ====>Tx METER-2 D0 12 20 00 00 01 B8 C0 01 C1 00 0F 00 00 28 00 04 FF 03 00
16 : 37 : 42 ====>Tx METER-2 D0 12 20 00 00 01 B8 65 E0 1E 32 79 BA 41 83 97 61 D6 F6 36
16 : 37 : 42 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-4-255, IC = 15, ATTR: INDEX = 3
16 : 37 : 42 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 B8 65 E0 1E 32 79 BA 41 83 97 61 D6 F6 36 AF DA 7E
16 : 37 : 42 <====Rx METER-2 7E A0 21 41 00 02 04 01 52 95 36 E6 E7 00 D4 10 20 00 00 01 B9 AF 9C FB 06 9E 3F D8 CA 38 7E 90 DD 41 7E
16 : 37 : 42 <====Rx METER-2 D4 10 20 00 00 01 B9 AF 9C FB 06 9E 3F D8 CA 38 7E 90
16 : 37 : 42 <====Rx METER-2 D4 10 20 00 00 01 B9 C4 01 81 00 02 02 0F 40 12 00 01
16 : 37 : 42 ====>Tx METER-2 D0 12 20 00 00 01 B9 C0 01 C1 00 0F 00 00 28 00 04 FF 04 00
16 : 37 : 42 ====>Tx METER-2 D0 12 20 00 00 01 B9 81 0D 71 48 AF B7 A6 87 91 40 96 A1 F7
16 : 37 : 42 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-4-255, IC = 15, ATTR: INDEX = 4
16 : 37 : 42 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 B9 81 0D 71 48 AF B7 A6 87 91 40 96 A1 F7 F7 06 7E
16 : 37 : 43 <====Rx METER-2 7E A0 23 41 00 02 04 01 74 1A 45 E6 E7 00 D4 12 20 00 00 01 BA 53 6A 12 F4 DA 94 EA A3 07 07 B1 DA CD 60 95 7E
16 : 37 : 43 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 43 <====Rx METER-2 D4 12 20 00 00 01 BA 53 6A 12 F4 DA 94 EA A3 07 07 B1 DA CD
16 : 37 : 43 <====Rx METER-2 D4 12 20 00 00 01 BA C4 01 81 00 09 07 60 85 74 05 08 01 03
16 : 37 : 43 METER-2 SERVICE = GET RESPONSE
16 : 37 : 43 METER-2 COSEM OUT DATA
16 : 37 : 43 ====>Tx METER-2 D0 12 20 00 00 01 BA C0 01 C1 00 0F 00 00 28 00 04 FF 05 00
16 : 37 : 43 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 43 ====>Tx METER-2 D0 12 20 00 00 01 BA B1 79 BB 33 95 D2 90 06 39 1E 8E D1 27
16 : 37 : 43 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-4-255, IC = 15, ATTR: INDEX = 5
16 : 37 : 43 METER-2 SENDING HDLC FRAME
16 : 37 : 43 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 BA B1 79 BB 33 95 D2 90 06 39 1E 8E D1 27 D0 F5 7E
16 : 37 : 43 METER-2 RECEIVED HDLC FRAME
16 : 37 : 43 <====Rx METER-2 7E A0 2D 41 00 02 04 01 96 27 07 E6 E7 00 D4 1C 20 00 00 01 BB B5 13 FB A9 08 12 3D 8B F8 1D A9 FB 0F 6D FC ED 1E DC 98
30 C3 16 53 B7 E3 7E
16 : 37 : 43 <====Rx METER-2 D4 1C 20 00 00 01 BB B5 13 FB A9 08 12 3D 8B F8 1D A9 FB 0F 6D FC ED 1E DC 98 30 C3 16 53
16 : 37 : 43 <====Rx METER-2 D4 1C 20 00 00 01 BB C4 01 81 00 02 06 04 18 60 10 90 12 01 F4 12 07 ED 11 06 0F 00 09 00
16 : 37 : 43 ====>Tx METER-2 D0 12 20 00 00 01 BB C0 01 C1 00 0F 00 00 28 00 04 FF 08 00
16 : 37 : 43 ====>Tx METER-2 D0 12 20 00 00 01 BB 9C 1A B4 F3 05 AA 1C E8 18 56 31 D5 1A
16 : 37 : 43 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-4-255, IC = 15, ATTR: INDEX = 8
16 : 37 : 43 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 BB 9C 1A B4 F3 05 AA 1C E8 18 56 31 D5 1A 9D D3 7E
16 : 37 : 43 <====Rx METER-2 7E A0 1C 41 00 02 04 01 B8 C4 86 E6 E7 00 D4 0B 20 00 00 01 BC BB DC F4 4E BF 9A 23 E6 7E
16 : 37 : 43 <====Rx METER-2 D4 0B 20 00 00 01 BC BB DC F4 4E BF 9A
16 : 37 : 43 <====Rx METER-2 D4 0B 20 00 00 01 BC C4 01 81 00 16 02
16 : 37 : 43 ====>Tx METER-2 D0 12 20 00 00 01 BC C0 01 C1 00 0F 00 00 28 00 04 FF 09 00
16 : 37 : 43 ====>Tx METER-2 D0 12 20 00 00 01 BC 95 AD 2D 49 A6 E7 C7 56 A2 DE 09 CF 80
16 : 37 : 43 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-4-255, IC = 15, ATTR: INDEX = 9
16 : 37 : 43 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 BC 95 AD 2D 49 A6 E7 C7 56 A2 DE 09 CF 80 7D F4 7E
16 : 37 : 43 <====Rx METER-2 7E A0 22 41 00 02 04 01 DA BB 96 E6 E7 00 D4 11 20 00 00 01 BD 01 66 A7 D1 64 FF 51 95 82 36 72 E0 E9 75 7E
16 : 37 : 43 <====Rx METER-2 D4 11 20 00 00 01 BD 01 66 A7 D1 64 FF 51 95 82 36 72 E0
16 : 37 : 43 <====Rx METER-2 D4 11 20 00 00 01 BD C4 01 81 00 09 06 00 00 2B 00 04 FF
16 : 37 : 43 ====>Tx METER-2 D0 12 20 00 00 01 BD C0 01 C1 00 0F 00 00 28 00 06 FF 03 00
16 : 37 : 43 ====>Tx METER-2 D0 12 20 00 00 01 BD 6F 7F C2 73 CB 30 C3 F0 86 7E 3A 51 E2
16 : 37 : 43 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-6-255, IC = 15, ATTR: INDEX = 3
16 : 37 : 43 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 BD 6F 7F C2 73 CB 30 C3 F0 86 7E 3A 51 E2 31 21 7E
16 : 37 : 43 <====Rx METER-2 7E A0 21 41 00 02 04 01 FC E1 7A E6 E7 00 D4 10 20 00 00 01 BE 3B 31 B4 D9 4C 0A DB FB E3 AE F9 E3 EB 7E
16 : 37 : 43 <====Rx METER-2 D4 10 20 00 00 01 BE 3B 31 B4 D9 4C 0A DB FB E3 AE F9
16 : 37 : 43 <====Rx METER-2 D4 10 20 00 00 01 BE C4 01 81 00 02 02 0F 60 12 00 01
16 : 37 : 44 METER-2 SERVICE = GET RESPONSE
16 : 37 : 44 METER-2 COSEM OUT DATA
16 : 37 : 44 ====>Tx METER-2 D0 12 20 00 00 01 BE C0 01 C1 00 0F 00 00 28 00 06 FF 04 00
16 : 37 : 44 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 44 ====>Tx METER-2 D0 12 20 00 00 01 BE A9 7C 89 66 D1 76 5D 16 A8 51 57 3C 86
16 : 37 : 44 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-6-255, IC = 15, ATTR: INDEX = 4
16 : 37 : 44 METER-2 SENDING HDLC FRAME
16 : 37 : 44 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 BE A9 7C 89 66 D1 76 5D 16 A8 51 57 3C 86 4F 26 7E
16 : 37 : 44 METER-2 RECEIVED HDLC FRAME
16 : 37 : 44 <====Rx METER-2 7E A0 23 41 00 02 04 01 1E 46 89 E6 E7 00 D4 12 20 00 00 01 BF 7F D7 B5 EC 2D 70 0F 20 9B 9C AD C9 E2 C3 D0 7E
16 : 37 : 44 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 44 <====Rx METER-2 D4 12 20 00 00 01 BF 7F D7 B5 EC 2D 70 0F 20 9B 9C AD C9 E2
16 : 37 : 44 <====Rx METER-2 D4 12 20 00 00 01 BF C4 01 81 00 09 07 60 85 74 05 08 01 03
16 : 37 : 44 ====>Tx METER-2 D0 12 20 00 00 01 BF C0 01 C1 00 0F 00 00 28 00 06 FF 05 00
16 : 37 : 44 ====>Tx METER-2 D0 12 20 00 00 01 BF E5 24 D6 2E 76 81 80 9E F5 80 58 19 EF
16 : 37 : 44 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-6-255, IC = 15, ATTR: INDEX = 5
16 : 37 : 44 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 BF E5 24 D6 2E 76 81 80 9E F5 80 58 19 EF 82 2F 7E
16 : 37 : 44 <====Rx METER-2 7E A0 2D 41 00 02 04 01 30 1B C7 E6 E7 00 D4 1C 20 00 00 01 C0 E1 EE F0 03 17 D2 12 C9 1B 90 56 1C 8E 49 EC 56 99 96 E8
45 23 42 61 2F 7C 7E
16 : 37 : 44 <====Rx METER-2 D4 1C 20 00 00 01 C0 E1 EE F0 03 17 D2 12 C9 1B 90 56 1C 8E 49 EC 56 99 96 E8 45 23 42 61
16 : 37 : 44 <====Rx METER-2 D4 1C 20 00 00 01 C0 C4 01 81 00 02 06 04 18 40 10 98 12 01 F4 12 07 ED 11 06 0F 00 09 00
16 : 37 : 44 ====>Tx METER-2 D0 12 20 00 00 01 C0 C0 01 C1 00 0F 00 00 28 00 06 FF 08 00
16 : 37 : 44 ====>Tx METER-2 D0 12 20 00 00 01 C0 34 86 04 DF E7 DF 37 18 7A 91 29 DE 1A
16 : 37 : 44 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-6-255, IC = 15, ATTR: INDEX = 8
16 : 37 : 44 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 C0 34 86 04 DF E7 DF 37 18 7A 91 29 DE 1A 0A E9 7E
16 : 37 : 44 <====Rx METER-2 7E A0 1C 41 00 02 04 01 52 90 CE E6 E7 00 D4 0B 20 00 00 01 C1 BA 30 33 2D 63 D2 DB 3F 7E
16 : 37 : 44 <====Rx METER-2 D4 0B 20 00 00 01 C1 BA 30 33 2D 63 D2
16 : 37 : 44 <====Rx METER-2 D4 0B 20 00 00 01 C1 C4 01 81 00 16 02
16 : 37 : 44 ====>Tx METER-2 D0 12 20 00 00 01 C1 C0 01 C1 00 0F 00 00 28 00 06 FF 09 00
16 : 37 : 44 ====>Tx METER-2 D0 12 20 00 00 01 C1 DF 14 AF E5 26 14 98 8F 81 FA A1 23 44
16 : 37 : 44 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-40-0-6-255, IC = 15, ATTR: INDEX = 9
16 : 37 : 44 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 C1 DF 14 AF E5 26 14 98 8F 81 FA A1 23 44 06 9D 7E
16 : 37 : 44 <====Rx METER-2 7E A0 22 41 00 02 04 01 74 CF DA E6 E7 00 D4 11 20 00 00 01 C2 22 3B 5A EF 15 1A 3E 6E 2E B5 7A 17 ED E2 7E
16 : 37 : 44 <====Rx METER-2 D4 11 20 00 00 01 C2 22 3B 5A EF 15 1A 3E 6E 2E B5 7A 17
16 : 37 : 44 <====Rx METER-2 D4 11 20 00 00 01 C2 C4 01 81 00 09 06 00 00 2B 00 06 FF
16 : 37 : 44 ====>Tx METER-2 D0 12 20 00 00 01 C2 C0 01 C1 00 11 00 00 29 00 00 FF 02 00
16 : 37 : 45 ====>Tx METER-2 D0 12 20 00 00 01 C2 F5 FA 3E D3 F8 DD 62 9D A7 1B 43 4A 0C
16 : 37 : 45 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-41-0-0-255, IC = 17, ATTR: INDEX = 2
16 : 37 : 45 METER-2 SENDING HDLC FRAME
16 : 37 : 45 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 C2 F5 FA 3E D3 F8 DD 62 9D A7 1B 43 4A 0C 44 71 7E
16 : 37 : 45 METER-2 RECEIVED HDLC FRAME
16 : 37 : 45 <====Rx METER-2 7E A0 33 41 00 02 04 01 96 CF 34 E6 E7 00 D4 22 20 00 00 01 C3 F5 3A 21 55 70 E3 42 79 15 4E 94 91 A5 A5 FE 01 7A 8C 62
78 52 5A BA 03 63 DE 70 E0 BE 4A AE 7E
16 : 37 : 45 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 45 <====Rx METER-2 D4 22 20 00 00 01 C3 F5 3A 21 55 70 E3 42 79 15 4E 94 91 A5 A5 FE 01 7A 8C 62 78 52 5A BA 03 63 DE 70 E0 BE
16 : 37 : 45 <====Rx METER-2 D4 22 20 00 00 01 C3 C4 01 81 00 01 01 02 02 12 00 01 09 10 5A 45 4E 39 39 39 39 39 39 39 39 39 39 39 39 39
16 : 37 : 45 METER-2 SERVICE = GET RESPONSE
16 : 37 : 45 METER-2 COSEM OUT DATA
16 : 37 : 45 ====>Tx METER-2 D0 12 20 00 00 01 C3 C0 01 C1 00 12 00 00 2C 00 00 FF 02 00
16 : 37 : 45 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 45 ====>Tx METER-2 D0 12 20 00 00 01 C3 9D 23 3B 46 D3 22 FF 74 86 6B 07 BC 35
16 : 37 : 45 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-44-0-0-255, IC = 18, ATTR: INDEX = 2
16 : 37 : 45 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 C3 9D 23 3B 46 D3 22 FF 74 86 6B 07 BC 35 16 B6 7E
16 : 37 : 45 <====Rx METER-2 7E A0 1F 41 00 02 04 01 B8 AA 2E E6 E7 00 D4 0E 20 00 00 01 C4 37 2F 40 82 D2 1E 41 4C 8A 92 EF 7E
16 : 37 : 45 <====Rx METER-2 D4 0E 20 00 00 01 C4 37 2F 40 82 D2 1E 41 4C 8A
16 : 37 : 45 <====Rx METER-2 D4 0E 20 00 00 01 C4 C4 01 81 00 06 00 00 00 C8
16 : 37 : 45 ====>Tx METER-2 D0 12 20 00 00 01 C4 C0 01 C1 00 12 00 00 2C 00 00 FF 03 00
16 : 37 : 45 ====>Tx METER-2 D0 12 20 00 00 01 C4 E9 DC D2 F0 B4 12 75 BD BB 9E D2 B1 88
16 : 37 : 45 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-44-0-0-255, IC = 18, ATTR: INDEX = 3
16 : 37 : 45 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 C4 E9 DC D2 F0 B4 12 75 BD BB 9E D2 B1 88 D3 F2 7E
16 : 37 : 45 <====Rx METER-2 7E A0 1D 41 00 02 04 01 DA 05 59 E6 E7 00 D4 0C 20 00 00 01 C5 B4 58 22 2A FB 3C FD 31 4E 7E
16 : 37 : 45 <====Rx METER-2 D4 0C 20 00 00 01 C5 B4 58 22 2A FB 3C FD
16 : 37 : 45 <====Rx METER-2 D4 0C 20 00 00 01 C5 C4 01 81 00 04 01 80
16 : 37 : 45 ====>Tx METER-2 D0 12 20 00 00 01 C5 C0 01 C1 00 12 00 00 2C 00 00 FF 04 00
16 : 37 : 45 ====>Tx METER-2 D0 12 20 00 00 01 C5 E2 12 A5 61 63 C3 3A CE D3 5B 56 FE 56
16 : 37 : 45 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-44-0-0-255, IC = 18, ATTR: INDEX = 4
16 : 37 : 45 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 C5 E2 12 A5 61 63 C3 3A CE D3 5B 56 FE 56 DD 95 7E
16 : 37 : 45 <====Rx METER-2 7E A0 1F 41 00 02 04 01 FC 8A 2A E6 E7 00 D4 0E 20 00 00 01 C6 11 43 68 E7 B4 B1 D5 EB 05 3F DC 7E
16 : 37 : 45 <====Rx METER-2 D4 0E 20 00 00 01 C6 11 43 68 E7 B4 B1 D5 EB 05
16 : 37 : 45 <====Rx METER-2 D4 0E 20 00 00 01 C6 C4 01 81 00 06 00 00 00 00
16 : 37 : 45 ====>Tx METER-2 D0 12 20 00 00 01 C6 C0 01 C1 00 12 00 00 2C 00 00 FF 05 00
16 : 37 : 45 ====>Tx METER-2 D0 12 20 00 00 01 C6 37 10 1D 18 C5 0B 7E 48 5B 2B DC 71 E4
16 : 37 : 45 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-44-0-0-255, IC = 18, ATTR: INDEX = 5
16 : 37 : 46 METER-2 SENDING HDLC FRAME
16 : 37 : 46 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 C6 37 10 1D 18 C5 0B 7E 48 5B 2B DC 71 E4 C3 E2 7E
16 : 37 : 46 METER-2 RECEIVED HDLC FRAME
16 : 37 : 46 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 01 C7 6E FB 0F 5F 6F 6D 98 34 7E
16 : 37 : 46 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 46 <====Rx METER-2 D4 0B 20 00 00 01 C7 6E FB 0F 5F 6F 6D
16 : 37 : 46 <====Rx METER-2 D4 0B 20 00 00 01 C7 C4 01 81 00 03 01
16 : 37 : 46 METER-2 SERVICE = GET RESPONSE
16 : 37 : 46 METER-2 COSEM OUT DATA
16 : 37 : 46 ====>Tx METER-2 D0 12 20 00 00 01 C7 C0 01 C1 00 12 00 00 2C 00 00 FF 06 00
16 : 37 : 46 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 46 ====>Tx METER-2 D0 12 20 00 00 01 C7 2D 5E 50 D1 93 F2 71 F6 16 0F 2F B6 EF
16 : 37 : 46 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-44-0-0-255, IC = 18, ATTR: INDEX = 6
16 : 37 : 46 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 C7 2D 5E 50 D1 93 F2 71 F6 16 0F 2F B6 EF FE DC 7E
16 : 37 : 46 <====Rx METER-2 7E A0 1C 41 00 02 04 01 30 84 8E E6 E7 00 D4 0B 20 00 00 01 C8 A3 F3 62 D7 EC 27 5F D6 7E
16 : 37 : 46 <====Rx METER-2 D4 0B 20 00 00 01 C8 A3 F3 62 D7 EC 27
16 : 37 : 46 <====Rx METER-2 D4 0B 20 00 00 01 C8 C4 01 81 00 16 01
16 : 37 : 46 ====>Tx METER-2 D0 12 20 00 00 01 C8 C0 01 C1 00 12 00 00 2C 00 00 FF 07 00
16 : 37 : 46 ====>Tx METER-2 D0 12 20 00 00 01 C8 42 2B 8E 5C 4E D9 10 4F 49 98 C2 80 D4
16 : 37 : 46 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-44-0-0-255, IC = 18, ATTR: INDEX = 7
16 : 37 : 46 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 C8 42 2B 8E 5C 4E D9 10 4F 49 98 C2 80 D4 BA 59 7E
16 : 37 : 46 <====Rx METER-2 7E A0 1C 41 00 02 04 01 52 90 CE E6 E7 00 D4 0B 20 00 00 01 C9 8C 79 18 CE A3 77 D5 3F 7E
16 : 37 : 46 <====Rx METER-2 D4 0B 20 00 00 01 C9 8C 79 18 CE A3 77
16 : 37 : 46 <====Rx METER-2 D4 0B 20 00 00 01 C9 C4 01 81 00 01 00
16 : 37 : 46 ====>Tx METER-2 D0 12 20 00 00 01 C9 C0 01 C1 00 14 00 00 0D 00 00 FF 02 00
16 : 37 : 46 ====>Tx METER-2 D0 12 20 00 00 01 C9 CE 63 88 EB 34 0A DD 64 1C 8A 4A 7C D1
16 : 37 : 46 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-13-0-0-255, IC = 20, ATTR: INDEX = 2
16 : 37 : 46 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 C9 CE 63 88 EB 34 0A DD 64 1C 8A 4A 7C D1 AF 39 7E
16 : 37 : 46 <====Rx METER-2 7E A0 24 41 00 02 04 01 74 02 82 E6 E7 00 D4 13 20 00 00 01 CA D6 5D AA 0C 32 3C 02 74 1C EC A7 05 1C 13 86 78 7E
16 : 37 : 46 <====Rx METER-2 D4 13 20 00 00 01 CA D6 5D AA 0C 32 3C 02 74 1C EC A7 05 1C 13
16 : 37 : 46 <====Rx METER-2 D4 13 20 00 00 01 CA C4 01 81 00 09 08 43 61 6C 65 6E 64 61 72
16 : 37 : 46 ====>Tx METER-2 D0 12 20 00 00 01 CA C0 01 C1 00 14 00 00 0D 00 00 FF 03 00
16 : 37 : 47 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 47 ====>Tx METER-2 D0 12 20 00 00 01 CA 5F B5 18 C0 C8 1C 94 6D 5B FF 48 98 D7
16 : 37 : 47 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-13-0-0-255, IC = 20, ATTR: INDEX = 3
16 : 37 : 47 METER-2 SENDING HDLC FRAME
16 : 37 : 47 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 CA 5F B5 18 C0 C8 1C 94 6D 5B FF 48 98 D7 78 8E 7E
16 : 37 : 47 METER-2 RECEIVED HDLC FRAME
16 : 37 : 47 <====Rx METER-2 7E A0 5C 41 00 02 04 01 96 BE 89 E6 E7 00 D4 4B 20 00 00 01 CB 67 81 56 86 16 F7 4C DC 42 5E D9 AE A2 34 F0 34 F5 AA 91
74 CF 3A F8 44 92 D9 E0 65 D3 F8 3A 8A 3D C0 95 3E 1C 1C EE BE 19 7F C9 C0 06 AA C8 AA BA 7A DD 29 36 51 BC 5C 39 1B 37
C5 62 68 DA 2B 23 53 A3 04 85 8E 4A B4 7E
16 : 37 : 47 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 47 <====Rx METER-2 D4 4B 20 00 00 01 CB 67 81 56 86 16 F7 4C DC 42 5E D9 AE A2 34 F0 34 F5 AA 91 74 CF 3A F8 44 92 D9 E0 65 D3 F8 3A 8A 3D
C0 95 3E 1C 1C EE BE 19 7F C9 C0 06 AA C8 AA BA 7A DD 29 36 51 BC 5C 39 1B 37 C5 62 68 DA 2B 23 53 A3 04 85 8E
16 : 37 : 47 <====Rx METER-2 D4 4B 20 00 00 01 CB C4 01 81 00 01 02 02 03 09 07 53 65 61 73 6F 6E 31 09 0C FF FF 01 01 FF 00 00 00 FF 00 00 00 09 05
57 65 65 6B 31 02 03 09 07 53 65 61 73 6F 6E 32 09 0C FF FF 06 01 FF 00 00 00 FF 00 00 00 09 05 57 65 65 6B 31
16 : 37 : 47 METER-2 SERVICE = GET RESPONSE
16 : 37 : 47 ====>Tx METER-2 D0 12 20 00 00 01 CB C0 01 C1 00 14 00 00 0D 00 00 FF 04 00
16 : 37 : 47 ====>Tx METER-2 D0 12 20 00 00 01 CB 1A 94 2E 2C BC A9 C8 94 DD 3D 43 AE 01
16 : 37 : 47 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-13-0-0-255, IC = 20, ATTR: INDEX = 4
16 : 37 : 47 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 CB 1A 94 2E 2C BC A9 C8 94 DD 3D 43 AE 01 A2 43 7E
16 : 37 : 47 <====Rx METER-2 7E A0 33 41 00 02 04 01 B8 B3 FC E6 E7 00 D4 22 20 00 00 01 CC 20 95 9A F3 E7 32 90 EF 81 08 BB 65 72 DC DC 08 E0 18 DD
45 60 62 A6 D3 9B 61 90 F5 95 40 13 7E
16 : 37 : 47 <====Rx METER-2 D4 22 20 00 00 01 CC 20 95 9A F3 E7 32 90 EF 81 08 BB 65 72 DC DC 08 E0 18 DD 45 60 62 A6 D3 9B 61 90 F5 95
16 : 37 : 47 <====Rx METER-2 D4 22 20 00 00 01 CC C4 01 81 00 01 01 02 08 09 05 57 65 65 6B 31 11 00 11 00 11 00 11 00 11 00 11 00 11 00
16 : 37 : 47 ====>Tx METER-2 D0 12 20 00 00 01 CC C0 01 C1 00 14 00 00 0D 00 00 FF 05 00
16 : 37 : 47 ====>Tx METER-2 D0 12 20 00 00 01 CC E6 41 CE 2E 5B D9 BB 81 B7 2A 19 A1 39
16 : 37 : 47 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-13-0-0-255, IC = 20, ATTR: INDEX = 5
16 : 37 : 47 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 CC E6 41 CE 2E 5B D9 BB 81 B7 2A 19 A1 39 F9 27 7E
16 : 37 : 47 <====Rx METER-2 7E A0 6E 41 00 02 04 01 DA 27 E0 E6 E7 00 D4 5D 20 00 00 01 CD A9 E0 9F FB C5 04 FC 65 BC 8C EB 46 9E 8E 7F 27 D5 3E 5F
37 C0 5A 8B 8A A7 4E 49 7F 48 58 45 E5 26 16 0A 77 97 65 4D 4F 6C 12 65 A0 48 D5 0A 6D A7 B4 F4 A7 CB 45 EB 67 46 D3 2D
83 96 B8 EE B4 6E E7 47 69 61 31 6D C6 19 1E DD 79 0D 21 A0 21 70 BA 97 DE 84 F7 15 CF EC EA 7E
16 : 37 : 47 <====Rx METER-2 D4 5D 20 00 00 01 CD A9 E0 9F FB C5 04 FC 65 BC 8C EB 46 9E 8E 7F 27 D5 3E 5F 37 C0 5A 8B 8A A7 4E 49 7F 48 58 45 E5 26
16 0A 77 97 65 4D 4F 6C 12 65 A0 48 D5 0A 6D A7 B4 F4 A7 CB 45 EB 67 46 D3 2D 83 96 B8 EE B4 6E E7 47 69 61 31 6D C6 19
16 : 37 : 47 <====Rx METER-2 D4 5D 20 00 00 01 CD C4 01 81 00 01 01 02 02 11 00 01 04 02 03 09 04 00 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 01 02 03
09 04 06 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 0C 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04
12 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 04
16 : 37 : 47 ====>Tx METER-2 D0 12 20 00 00 01 CD C0 01 C1 00 14 00 00 0D 00 00 FF 06 00
16 : 37 : 47 ====>Tx METER-2 D0 12 20 00 00 01 CD 82 5C 40 5A 73 C6 DD 44 6D 24 DC 98 FE
16 : 37 : 47 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-13-0-0-255, IC = 20, ATTR: INDEX = 6
16 : 37 : 47 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 CD 82 5C 40 5A 73 C6 DD 44 6D 24 DC 98 FE F1 32 7E
16 : 37 : 47 <====Rx METER-2 7E A0 24 41 00 02 04 01 FC 42 8A E6 E7 00 D4 13 20 00 00 01 CE 97 B4 50 CD 64 DA 99 EB D8 40 71 9A AE 78 FF B9 7E
16 : 37 : 47 <====Rx METER-2 D4 13 20 00 00 01 CE 97 B4 50 CD 64 DA 99 EB D8 40 71 9A AE 78
16 : 37 : 47 <====Rx METER-2 D4 13 20 00 00 01 CE C4 01 81 00 09 08 43 61 6C 65 6E 64 61 72
16 : 37 : 47 ====>Tx METER-2 D0 12 20 00 00 01 CE C0 01 C1 00 14 00 00 0D 00 00 FF 07 00
16 : 37 : 48 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 48 ====>Tx METER-2 D0 12 20 00 00 01 CE 83 50 9E 14 62 E2 D8 E3 14 78 95 C9 CC
16 : 37 : 48 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-13-0-0-255, IC = 20, ATTR: INDEX = 7
16 : 37 : 48 METER-2 SENDING HDLC FRAME
16 : 37 : 48 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 CE 83 50 9E 14 62 E2 D8 E3 14 78 95 C9 CC 6A 36 7E
16 : 37 : 48 METER-2 RECEIVED HDLC FRAME
16 : 37 : 48 <====Rx METER-2 7E A0 5C 41 00 02 04 01 1E FE 81 E6 E7 00 D4 4B 20 00 00 01 CF 7E ED 78 99 13 E5 20 EF 47 C6 D0 76 8C E4 6B 4A 88 80 34
28 4C A0 7F 94 A3 FE 50 EA A7 E1 C9 10 CB 30 8D 02 83 06 BF 42 1E 9F 32 51 60 AD F0 0B 6C 75 6B 80 C6 D8 B3 A6 5A 31 C2
7D 60 51 0E 72 41 77 C0 A2 3A 8D 4B FF 7E
16 : 37 : 48 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 48 <====Rx METER-2 D4 4B 20 00 00 01 CF 7E ED 78 99 13 E5 20 EF 47 C6 D0 76 8C E4 6B 4A 88 80 34 28 4C A0 7F 94 A3 FE 50 EA A7 E1 C9 10 CB
30 8D 02 83 06 BF 42 1E 9F 32 51 60 AD F0 0B 6C 75 6B 80 C6 D8 B3 A6 5A 31 C2 7D 60 51 0E 72 41 77 C0 A2 3A 8D
16 : 37 : 48 <====Rx METER-2 D4 4B 20 00 00 01 CF C4 01 81 00 01 02 02 03 09 07 53 65 61 73 6F 6E 31 09 0C FF FF 01 01 FF 00 00 00 FF 00 00 00 09 05
16 : 37 : 48 METER-2 SERVICE = GET RESPONSE
16 : 37 : 48 ====>Tx METER-2 D0 12 20 00 00 01 CF C0 01 C1 00 14 00 00 0D 00 00 FF 08 00
16 : 37 : 48 ====>Tx METER-2 D0 12 20 00 00 01 CF F0 AC 70 3F AF BC D3 4C 9F 50 02 5E A5
16 : 37 : 48 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-13-0-0-255, IC = 20, ATTR: INDEX = 8
16 : 37 : 48 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 CF F0 AC 70 3F AF BC D3 4C 9F 50 02 5E A5 4F A5 7E
16 : 37 : 48 <====Rx METER-2 7E A0 33 41 00 02 04 01 30 F3 F4 E6 E7 00 D4 22 20 00 00 01 D0 C4 78 A6 A3 13 6D BC 18 CC E9 DA BC 6C 05 C5 91 98 63 90
1A F1 87 0E D8 8E 03 EC 11 1B 8D 38 7E
16 : 37 : 48 <====Rx METER-2 D4 22 20 00 00 01 D0 C4 78 A6 A3 13 6D BC 18 CC E9 DA BC 6C 05 C5 91 98 63 90 1A F1 87 0E D8 8E 03 EC 11 1B
16 : 37 : 48 <====Rx METER-2 D4 22 20 00 00 01 D0 C4 01 81 00 01 01 02 08 09 05 57 65 65 6B 31 11 00 11 00 11 00 11 00 11 00 11 00 11 00
16 : 37 : 48 ====>Tx METER-2 D0 12 20 00 00 01 D0 C0 01 C1 00 14 00 00 0D 00 00 FF 09 00
16 : 37 : 48 ====>Tx METER-2 D0 12 20 00 00 01 D0 98 C0 86 32 FE 24 CF 2A DE 1A 6D DA 6B
16 : 37 : 48 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-13-0-0-255, IC = 20, ATTR: INDEX = 9
16 : 37 : 48 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 D0 98 C0 86 32 FE 24 CF 2A DE 1A 6D DA 6B 84 51 7E
16 : 37 : 48 <====Rx METER-2 7E A0 6E 41 00 02 04 01 52 67 E8 E6 E7 00 D4 5D 20 00 00 01 D1 B5 D4 48 A6 EB C9 2A 6B 9F 4D A0 7F 83 48 E5 0E 49 B5 B5
9A 6C CC 9B DE 75 70 D9 56 7A AE EF 72 68 64 28 9A 0B 65 0D 3E 2B 92 03 16 E4 E1 D2 89 B8 EB 81 16 55 E9 65 49 8D 2F 31
8D 12 00 7B 19 D3 49 08 5D 7E 85 BE 42 F9 79 95 09 DA 63 B4 17 F9 32 3D BB 3F 80 5F 5F 26 F5 7E
16 : 37 : 48 <====Rx METER-2 D4 5D 20 00 00 01 D1 B5 D4 48 A6 EB C9 2A 6B 9F 4D A0 7F 83 48 E5 0E 49 B5 B5 9A 6C CC 9B DE 75 70 D9 56 7A AE EF 72 68
64 28 9A 0B 65 0D 3E 2B 92 03 16 E4 E1 D2 89 B8 EB 81 16 55 E9 65 49 8D 2F 31 8D 12 00 7B 19 D3 49 08 5D 7E 85 BE 42 F9
16 : 37 : 48 <====Rx METER-2 D4 5D 20 00 00 01 D1 C4 01 81 00 01 01 02 02 11 00 01 04 02 03 09 04 00 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 01 02 03
16 : 37 : 48 ====>Tx METER-2 D0 12 20 00 00 01 D1 C0 01 C1 00 14 00 00 0D 00 00 FF 0A 00
16 : 37 : 48 ====>Tx METER-2 D0 12 20 00 00 01 D1 46 22 21 48 F5 7A 40 39 65 20 7C 4A 71
16 : 37 : 48 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-13-0-0-255, IC = 20, ATTR: INDEX = 10
16 : 37 : 48 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 D1 46 22 21 48 F5 7A 40 39 65 20 7C 4A 71 7A 78 7E
16 : 37 : 48 <====Rx METER-2 7E A0 28 41 00 02 04 01 74 98 33 E6 E7 00 D4 17 20 00 00 01 D2 98 69 49 B5 EA 97 C9 26 A2 82 AE 4B FB FB BD 86 67 B5 7C
13 7E
16 : 37 : 48 <====Rx METER-2 D4 17 20 00 00 01 D2 98 69 49 B5 EA 97 C9 26 A2 82 AE 4B FB FB BD 86 67 B5
16 : 37 : 48 <====Rx METER-2 D4 17 20 00 00 01 D2 C4 01 81 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
16 : 37 : 48 ====>Tx METER-2 D0 12 20 00 00 01 D2 C0 01 C1 00 15 00 00 10 00 01 FF 02 00
16 : 37 : 49 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 49 ====>Tx METER-2 D0 12 20 00 00 01 D2 0F F1 50 9A 59 AE 0E 6C 0E 22 45 AB 19
16 : 37 : 49 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-16-0-1-255, IC = 21, ATTR: INDEX = 2
16 : 37 : 49 METER-2 SENDING HDLC FRAME
16 : 37 : 49 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 D2 0F F1 50 9A 59 AE 0E 6C 0E 22 45 AB 19 AF F6 7E
16 : 37 : 49 METER-2 RECEIVED HDLC FRAME
16 : 37 : 49 <====Rx METER-2 7E A0 1E 41 00 02 04 01 96 03 79 E6 E7 00 D4 0D 20 00 00 01 D3 15 36 1F 85 B6 CF C4 FD DB EA 7E
16 : 37 : 49 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 49 <====Rx METER-2 D4 0D 20 00 00 01 D3 15 36 1F 85 B6 CF C4 FD
16 : 37 : 49 <====Rx METER-2 D4 0D 20 00 00 01 D3 C4 01 81 00 01 01 09 00
16 : 37 : 49 METER-2 SERVICE = GET RESPONSE
16 : 37 : 49 ====>Tx METER-2 D0 12 20 00 00 01 D3 C0 01 C1 00 15 00 00 10 00 01 FF 03 00
16 : 37 : 49 ====>Tx METER-2 D0 12 20 00 00 01 D3 3B A8 C9 7C 40 45 93 6D EB 70 70 DD D0
16 : 37 : 49 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-16-0-1-255, IC = 21, ATTR: INDEX = 3
16 : 37 : 49 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 D3 3B A8 C9 7C 40 45 93 6D EB 70 70 DD D0 8B CB 7E
16 : 37 : 49 <====Rx METER-2 7E A0 29 41 00 02 04 01 B8 2D A0 E6 E7 00 D4 18 20 00 00 01 D4 ED D0 E5 8D 6A B2 89 B7 AC 55 8B 7D B3 8F 17 40 EF AD 57
2D 9C 7E
16 : 37 : 49 <====Rx METER-2 D4 18 20 00 00 01 D4 ED D0 E5 8D 6A B2 89 B7 AC 55 8B 7D B3 8F 17 40 EF AD 57
16 : 37 : 49 <====Rx METER-2 D4 18 20 00 00 01 D4 C4 01 81 00 02 03 12 00 01 09 06 00 00 60 0D 01 FF 0F 02
16 : 37 : 49 ====>Tx METER-2 D0 12 20 00 00 01 D4 C0 01 C1 00 15 00 00 10 00 01 FF 04 00
16 : 37 : 49 ====>Tx METER-2 D0 12 20 00 00 01 D4 16 AD 42 2E 56 23 16 F7 65 A8 3D EE 5C
16 : 37 : 49 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-16-0-1-255, IC = 21, ATTR: INDEX = 4
16 : 37 : 49 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 D4 16 AD 42 2E 56 23 16 F7 65 A8 3D EE 5C E8 EB 7E
16 : 37 : 49 <====Rx METER-2 7E A0 38 41 00 02 04 01 DA 25 CA E6 E7 00 D4 27 20 00 00 01 D5 D6 C3 46 80 EA A6 B1 CD F7 35 D4 A1 EF 4D AF 85 C6 42 D9
F7 D6 18 21 49 4C 39 A5 DA B4 EB 57 17 AE 8D D8 F8 7E
16 : 37 : 49 <====Rx METER-2 D4 27 20 00 00 01 D5 D6 C3 46 80 EA A6 B1 CD F7 35 D4 A1 EF 4D AF 85 C6 42 D9 F7 D6 18 21 49 4C 39 A5 DA B4 EB 57 17 AE
8D
16 : 37 : 49 <====Rx METER-2 D4 27 20 00 00 01 D5 C4 01 81 00 01 01 02 02 02 02 09 06 00 00 0A 00 6C FF 12 00 02 02 02 09 06 00 00 0A 00 6C FF 12 00
02
16 : 37 : 49 ====>Tx METER-2 D0 12 20 00 00 01 D5 C0 01 C1 00 16 00 00 0F 00 00 FF 02 00
16 : 37 : 49 ====>Tx METER-2 D0 12 20 00 00 01 D5 16 C1 C8 83 D1 29 BE 8B 69 75 85 15 25
16 : 37 : 49 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-0-0-255, IC = 22, ATTR: INDEX = 2
16 : 37 : 49 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 D5 16 C1 C8 83 D1 29 BE 8B 69 75 85 15 25 CA 62 7E
16 : 37 : 49 <====Rx METER-2 7E A0 27 41 00 02 04 01 FC 2C 22 E6 E7 00 D4 16 20 00 00 01 D6 24 F8 43 16 1A 79 32 F4 74 5C C3 EA 32 18 9B 0C 73 D2 05
7E
16 : 37 : 49 <====Rx METER-2 D4 16 20 00 00 01 D6 24 F8 43 16 1A 79 32 F4 74 5C C3 EA 32 18 9B 0C 73
16 : 37 : 49 <====Rx METER-2 D4 16 20 00 00 01 D6 C4 01 81 00 02 02 09 06 00 00 0A 00 01 FF 12 00 01
16 : 37 : 50 METER-2 COSEM OUT DATA
16 : 37 : 50 ====>Tx METER-2 D0 12 20 00 00 01 D6 C0 01 C1 00 16 00 00 0F 00 00 FF 03 00
16 : 37 : 50 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 50 ====>Tx METER-2 D0 12 20 00 00 01 D6 A4 10 49 D9 54 4C 55 9C DA 06 BA 4A 9E
16 : 37 : 50 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-0-0-255, IC = 22, ATTR: INDEX = 3
16 : 37 : 50 METER-2 SENDING HDLC FRAME
16 : 37 : 50 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 D6 A4 10 49 D9 54 4C 55 9C DA 06 BA 4A 9E 8F 8C 7E
16 : 37 : 50 METER-2 RECEIVED HDLC FRAME
16 : 37 : 50 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 01 D7 CB 7B 39 CE A3 4A 3B 7D 7E
16 : 37 : 50 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 50 <====Rx METER-2 D4 0B 20 00 00 01 D7 CB 7B 39 CE A3 4A
16 : 37 : 50 <====Rx METER-2 D4 0B 20 00 00 01 D7 C4 01 81 00 16 01
16 : 37 : 50 METER-2 SERVICE = GET RESPONSE
16 : 37 : 50 ====>Tx METER-2 D0 12 20 00 00 01 D7 C0 01 C1 00 16 00 00 0F 00 00 FF 04 00
16 : 37 : 50 ====>Tx METER-2 D0 12 20 00 00 01 D7 2E 9D 45 19 92 4A 35 52 92 D2 89 80 F8
16 : 37 : 50 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-0-0-255, IC = 22, ATTR: INDEX = 4
16 : 37 : 50 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 D7 2E 9D 45 19 92 4A 35 52 92 D2 89 80 F8 70 6F 7E
16 : 37 : 50 <====Rx METER-2 7E A0 2B 41 00 02 04 01 30 D6 9F E6 E7 00 D4 1A 20 00 00 01 D8 B0 C2 B3 28 59 88 C3 21 8B 36 4F BB F7 12 31 9B DA 2D E6
21 A5 C7 2B 7E
16 : 37 : 50 <====Rx METER-2 D4 1A 20 00 00 01 D8 B0 C2 B3 28 59 88 C3 21 8B 36 4F BB F7 12 31 9B DA 2D E6 21 A5
16 : 37 : 50 <====Rx METER-2 D4 1A 20 00 00 01 D8 C4 01 81 00 01 01 02 02 09 04 00 00 00 00 09 05 FF FF FF 01 FF
16 : 37 : 50 ====>Tx METER-2 D0 12 20 00 00 01 D8 C0 01 C1 00 16 00 00 0F 00 01 FF 02 00
16 : 37 : 50 ====>Tx METER-2 D0 12 20 00 00 01 D8 DC DE 06 CD 89 6D 90 68 89 EB CF 50 5B
16 : 37 : 50 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-0-1-255, IC = 22, ATTR: INDEX = 2
16 : 37 : 50 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 D8 DC DE 06 CD 89 6D 90 68 89 EB CF 50 5B 4A 1A 7E
16 : 37 : 50 <====Rx METER-2 7E A0 27 41 00 02 04 01 52 58 6E E6 E7 00 D4 16 20 00 00 01 D9 E7 A1 4F 50 39 F7 56 E2 4E 7C F2 4D 01 A5 0F AB C3 67 CB
7E
16 : 37 : 50 <====Rx METER-2 D4 16 20 00 00 01 D9 E7 A1 4F 50 39 F7 56 E2 4E 7C F2 4D 01 A5 0F AB C3
16 : 37 : 50 <====Rx METER-2 D4 16 20 00 00 01 D9 C4 01 81 00 02 02 09 06 00 00 0A 00 6A FF 12 00 01
16 : 37 : 50 ====>Tx METER-2 D0 12 20 00 00 01 D9 C0 01 C1 00 16 00 00 0F 00 01 FF 03 00
16 : 37 : 50 ====>Tx METER-2 D0 12 20 00 00 01 D9 A2 A7 95 20 6F 33 B8 89 7F F2 C0 D0 C3
16 : 37 : 51 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-0-1-255, IC = 22, ATTR: INDEX = 3
16 : 37 : 51 METER-2 SENDING HDLC FRAME
16 : 37 : 51 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 D9 A2 A7 95 20 6F 33 B8 89 7F F2 C0 D0 C3 86 8D 7E
16 : 37 : 51 METER-2 RECEIVED HDLC FRAME
16 : 37 : 51 <====Rx METER-2 7E A0 1C 41 00 02 04 01 74 A4 8A E6 E7 00 D4 0B 20 00 00 01 DA 39 A7 8D B4 D6 3E 8B 48 7E
16 : 37 : 51 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 51 <====Rx METER-2 D4 0B 20 00 00 01 DA 39 A7 8D B4 D6 3E
16 : 37 : 51 <====Rx METER-2 D4 0B 20 00 00 01 DA C4 01 81 00 16 01
16 : 37 : 51 METER-2 SERVICE = GET RESPONSE
16 : 37 : 51 METER-2 COSEM OUT DATA
16 : 37 : 51 ====>Tx METER-2 D0 12 20 00 00 01 DA C0 01 C1 00 16 00 00 0F 00 01 FF 04 00
16 : 37 : 51 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 51 ====>Tx METER-2 D0 12 20 00 00 01 DA 07 6E 80 76 DD 30 26 D9 80 56 9D 58 40
16 : 37 : 51 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-0-1-255, IC = 22, ATTR: INDEX = 4
16 : 37 : 51 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 DA 07 6E 80 76 DD 30 26 D9 80 56 9D 58 40 8C 8C 7E
16 : 37 : 51 <====Rx METER-2 7E A0 2B 41 00 02 04 01 96 EA 5F E6 E7 00 D4 1A 20 00 00 01 DB A5 AA 48 87 7D 51 0C A8 3E 98 0E EF 9B 1E AE C5 52 8B 30
1F 99 B8 35 7E
16 : 37 : 51 <====Rx METER-2 D4 1A 20 00 00 01 DB A5 AA 48 87 7D 51 0C A8 3E 98 0E EF 9B 1E AE C5 52 8B 30 1F 99
16 : 37 : 51 <====Rx METER-2 D4 1A 20 00 00 01 DB C4 01 81 00 01 01 02 02 09 04 FF FF FF FF 09 05 FF FF FF FF FF
16 : 37 : 51 ====>Tx METER-2 D0 12 20 00 00 01 DB C0 01 C1 00 16 00 00 0F 01 01 FF 02 00
16 : 37 : 51 ====>Tx METER-2 D0 12 20 00 00 01 DB C0 15 89 2C D0 D4 E2 B1 98 CF 28 B2 7E
16 : 37 : 51 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-1-1-255, IC = 22, ATTR: INDEX = 2
16 : 37 : 51 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 DB C0 15 89 2C D0 D4 E2 B1 98 CF 28 B2 7E E5 FD 7E
16 : 37 : 51 <====Rx METER-2 7E A0 27 41 00 02 04 01 B8 0C 26 E6 E7 00 D4 16 20 00 00 01 DC 0B AA CF 6E 94 B3 3C DF 24 28 AF 9F 14 D6 E0 51 FA 2C F9
7E
16 : 37 : 51 <====Rx METER-2 D4 16 20 00 00 01 DC 0B AA CF 6E 94 B3 3C DF 24 28 AF 9F 14 D6 E0 51 FA
16 : 37 : 51 <====Rx METER-2 D4 16 20 00 00 01 DC C4 01 81 00 02 02 09 06 00 00 0A 00 6A FF 12 00 02
16 : 37 : 51 ====>Tx METER-2 D0 12 20 00 00 01 DC C0 01 C1 00 16 00 00 0F 01 01 FF 03 00
16 : 37 : 51 ====>Tx METER-2 D0 12 20 00 00 01 DC E7 FC B0 E0 23 1B 22 95 4C 84 55 78 66
16 : 37 : 51 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-1-1-255, IC = 22, ATTR: INDEX = 3
16 : 37 : 51 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 DC E7 FC B0 E0 23 1B 22 95 4C 84 55 78 66 BD CA 7E
16 : 37 : 51 <====Rx METER-2 7E A0 1C 41 00 02 04 01 DA D0 C6 E6 E7 00 D4 0B 20 00 00 01 DD 14 AE AE D9 7B 6D 7D 41 7E
16 : 37 : 51 <====Rx METER-2 D4 0B 20 00 00 01 DD 14 AE AE D9 7B 6D
16 : 37 : 51 <====Rx METER-2 D4 0B 20 00 00 01 DD C4 01 81 00 16 01
16 : 37 : 51 ====>Tx METER-2 D0 12 20 00 00 01 DD C0 01 C1 00 16 00 00 0F 01 01 FF 04 00
16 : 37 : 51 ====>Tx METER-2 D0 12 20 00 00 01 DD DB 47 25 AB 51 CE 69 8F 91 01 CE 76 D1
16 : 37 : 51 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-1-1-255, IC = 22, ATTR: INDEX = 4
16 : 37 : 52 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 DD DB 47 25 AB 51 CE 69 8F 91 01 CE 76 D1 75 2F 7E
16 : 37 : 52 METER-2 RECEIVED HDLC FRAME
16 : 37 : 52 <====Rx METER-2 7E A0 2B 41 00 02 04 01 FC B6 93 E6 E7 00 D4 1A 20 00 00 01 DE 04 2C 74 3E 94 48 37 BB 05 7C EE 96 D1 ED 59 C3 8E 10 66
2A 56 41 AA 7E
16 : 37 : 52 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 52 <====Rx METER-2 D4 1A 20 00 00 01 DE 04 2C 74 3E 94 48 37 BB 05 7C EE 96 D1 ED 59 C3 8E 10 66 2A 56
16 : 37 : 52 <====Rx METER-2 D4 1A 20 00 00 01 DE C4 01 81 00 01 01 02 02 09 04 FF FF FF FF 09 05 FF FF FF FF FF
16 : 37 : 52 METER-2 SERVICE = GET RESPONSE
16 : 37 : 52 METER-2 COSEM OUT DATA
16 : 37 : 52 ====>Tx METER-2 D0 12 20 00 00 01 DE C0 01 C1 00 16 00 00 0F 00 02 FF 02 00
16 : 37 : 52 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 52 ====>Tx METER-2 D0 12 20 00 00 01 DE 4F CA 01 23 54 22 8E 70 35 E9 20 6A FA
16 : 37 : 52 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-0-2-255, IC = 22, ATTR: INDEX = 2
16 : 37 : 52 METER-2 SENDING HDLC FRAME
16 : 37 : 52 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 DE 4F CA 01 23 54 22 8E 70 35 E9 20 6A FA 6D 10 7E
16 : 37 : 52 <====Rx METER-2 7E A0 27 41 00 02 04 01 1E 30 E6 E6 E7 00 D4 16 20 00 00 01 DF FE F4 D0 55 04 1D 8C 2A A9 DB 4B 7D 12 59 0E E3 D0 01 6B
7E
16 : 37 : 52 <====Rx METER-2 D4 16 20 00 00 01 DF FE F4 D0 55 04 1D 8C 2A A9 DB 4B 7D 12 59 0E E3 D0
16 : 37 : 52 <====Rx METER-2 D4 16 20 00 00 01 DF C4 01 81 00 02 02 09 06 00 00 0A 00 6B FF 12 00 01
16 : 37 : 52 ====>Tx METER-2 D0 12 20 00 00 01 DF C0 01 C1 00 16 00 00 0F 00 02 FF 03 00
16 : 37 : 52 ====>Tx METER-2 D0 12 20 00 00 01 DF C3 4B D3 E6 25 3E 6D 7F 94 1D EA 17 54
16 : 37 : 52 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-0-2-255, IC = 22, ATTR: INDEX = 3
16 : 37 : 52 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 DF C3 4B D3 E6 25 3E 6D 7F 94 1D EA 17 54 1A B7 7E
16 : 37 : 52 <====Rx METER-2 7E A0 1C 41 00 02 04 01 30 84 8E E6 E7 00 D4 0B 20 00 00 01 E0 2C C0 71 33 C2 A7 81 2B 7E
16 : 37 : 52 <====Rx METER-2 D4 0B 20 00 00 01 E0 2C C0 71 33 C2 A7
16 : 37 : 52 <====Rx METER-2 D4 0B 20 00 00 01 E0 C4 01 81 00 16 01
16 : 37 : 52 ====>Tx METER-2 D0 12 20 00 00 01 E0 C0 01 C1 00 16 00 00 0F 00 02 FF 04 00
16 : 37 : 52 ====>Tx METER-2 D0 12 20 00 00 01 E0 83 C9 7C 66 D5 49 40 E3 5D 47 31 8F D9
16 : 37 : 52 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-0-2-255, IC = 22, ATTR: INDEX = 4
16 : 37 : 52 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 E0 83 C9 7C 66 D5 49 40 E3 5D 47 31 8F D9 A1 62 7E
16 : 37 : 52 <====Rx METER-2 7E A0 2B 41 00 02 04 01 52 C2 DF E6 E7 00 D4 1A 20 00 00 01 E1 EC 8C 76 BC D9 9A 97 59 E3 21 D2 FF 5F AC 3A 77 8F AC 6B
96 6A 50 86 7E
16 : 37 : 52 <====Rx METER-2 D4 1A 20 00 00 01 E1 EC 8C 76 BC D9 9A 97 59 E3 21 D2 FF 5F AC 3A 77 8F AC 6B 96 6A
16 : 37 : 52 <====Rx METER-2 D4 1A 20 00 00 01 E1 C4 01 81 00 01 01 02 02 09 04 FF FF FF FF 09 05 FF FF FF FF FF
16 : 37 : 52 ====>Tx METER-2 D0 12 20 00 00 01 E1 C0 01 C1 00 16 00 00 0F 00 04 FF 02 00
16 : 37 : 52 ====>Tx METER-2 D0 12 20 00 00 01 E1 FA B2 3C E9 79 C5 B5 BA A6 A7 F5 4F E2
16 : 37 : 52 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-0-4-255, IC = 22, ATTR: INDEX = 2
16 : 37 : 52 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 E1 FA B2 3C E9 79 C5 B5 BA A6 A7 F5 4F E2 EA 5F 7E
16 : 37 : 53 <====Rx METER-2 7E A0 27 41 00 02 04 01 74 6C 2A E6 E7 00 D4 16 20 00 00 01 E2 81 4A D4 69 93 37 69 7A 67 DE F3 AD B6 54 E1 C3 8D CD 39
7E
16 : 37 : 53 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 53 <====Rx METER-2 D4 16 20 00 00 01 E2 81 4A D4 69 93 37 69 7A 67 DE F3 AD B6 54 E1 C3 8D
16 : 37 : 53 <====Rx METER-2 D4 16 20 00 00 01 E2 C4 01 81 00 02 02 09 06 00 00 0A 00 6C FF 12 00 01
16 : 37 : 53 METER-2 SERVICE = GET RESPONSE
16 : 37 : 53 METER-2 COSEM OUT DATA
16 : 37 : 53 ====>Tx METER-2 D0 12 20 00 00 01 E2 C0 01 C1 00 16 00 00 0F 00 04 FF 03 00
16 : 37 : 53 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 53 ====>Tx METER-2 D0 12 20 00 00 01 E2 90 4A 56 46 48 8A 6D B0 39 3D 83 5D 6A
16 : 37 : 53 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-0-4-255, IC = 22, ATTR: INDEX = 3
16 : 37 : 53 METER-2 SENDING HDLC FRAME
16 : 37 : 53 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 E2 90 4A 56 46 48 8A 6D B0 39 3D 83 5D 6A 60 76 7E
16 : 37 : 53 METER-2 RECEIVED HDLC FRAME
16 : 37 : 53 <====Rx METER-2 7E A0 1C 41 00 02 04 01 96 B8 4E E6 E7 00 D4 0B 20 00 00 01 E3 99 1C 3C 2C 08 F3 0C AC 7E
16 : 37 : 53 <====Rx METER-2 D4 0B 20 00 00 01 E3 99 1C 3C 2C 08 F3
16 : 37 : 53 <====Rx METER-2 D4 0B 20 00 00 01 E3 C4 01 81 00 16 01
16 : 37 : 53 ====>Tx METER-2 D0 12 20 00 00 01 E3 C0 01 C1 00 16 00 00 0F 00 04 FF 04 00
16 : 37 : 53 ====>Tx METER-2 D0 12 20 00 00 01 E3 64 2D FC 24 C6 4B DC F3 27 03 73 1E 1D
16 : 37 : 53 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-15-0-4-255, IC = 22, ATTR: INDEX = 4
16 : 37 : 53 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 E3 64 2D FC 24 C6 4B DC F3 27 03 73 1E 1D A6 49 7E
16 : 37 : 53 <====Rx METER-2 7E A0 2B 41 00 02 04 01 B8 96 97 E6 E7 00 D4 1A 20 00 00 01 E4 E0 90 95 35 A9 80 FB CA C9 6D 9C E1 68 94 2A A3 75 FF E9
4D 9A BF A0 7E
16 : 37 : 53 <====Rx METER-2 D4 1A 20 00 00 01 E4 E0 90 95 35 A9 80 FB CA C9 6D 9C E1 68 94 2A A3 75 FF E9 4D 9A
16 : 37 : 53 <====Rx METER-2 D4 1A 20 00 00 01 E4 C4 01 81 00 01 01 02 02 09 04 FF FF FF FF 09 05 FF FF FF FF FF
16 : 37 : 53 ====>Tx METER-2 D0 12 20 00 00 01 E4 C0 01 C1 00 16 00 03 0F 00 04 FF 02 00
16 : 37 : 53 ====>Tx METER-2 D0 12 20 00 00 01 E4 00 50 3A B1 AB 0F 5E 7C 31 3C 93 66 7D
16 : 37 : 53 METER-2 SERVICE = GET REQUEST, OBIS = 0-3-15-0-4-255, IC = 22, ATTR: INDEX = 2
16 : 37 : 53 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 E4 00 50 3A B1 AB 0F 5E 7C 31 3C 93 66 7D 8F 9F 7E
16 : 37 : 53 <====Rx METER-2 7E A0 27 41 00 02 04 01 DA 18 66 E6 E7 00 D4 16 20 00 00 01 E5 36 88 80 BE 5D F3 14 90 DA 5F 50 32 29 68 79 22 77 B2 03
7E
16 : 37 : 53 <====Rx METER-2 D4 16 20 00 00 01 E5 36 88 80 BE 5D F3 14 90 DA 5F 50 32 29 68 79 22 77
16 : 37 : 53 <====Rx METER-2 D4 16 20 00 00 01 E5 C4 01 81 00 02 02 09 06 00 00 0A 00 6C FF 12 00 04
16 : 37 : 53 ====>Tx METER-2 D0 12 20 00 00 01 E5 C0 01 C1 00 16 00 03 0F 00 04 FF 03 00
16 : 37 : 53 ====>Tx METER-2 D0 12 20 00 00 01 E5 6E 63 43 B1 F4 6E 77 E8 71 82 BA 96 18
16 : 37 : 53 METER-2 SERVICE = GET REQUEST, OBIS = 0-3-15-0-4-255, IC = 22, ATTR: INDEX = 3
16 : 37 : 53 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 E5 6E 63 43 B1 F4 6E 77 E8 71 82 BA 96 18 7A 78 7E
16 : 37 : 53 <====Rx METER-2 7E A0 1C 41 00 02 04 01 FC E4 82 E6 E7 00 D4 0B 20 00 00 01 E6 0B AA 0A 72 86 2D 48 CB 7E
16 : 37 : 54 <====Rx METER-2 D4 0B 20 00 00 01 E6 0B AA 0A 72 86 2D
16 : 37 : 54 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 37 : 54 <====Rx METER-2 D4 0B 20 00 00 01 E6 C4 01 81 00 16 01
16 : 37 : 54 METER-2 SERVICE = GET RESPONSE
16 : 37 : 54 METER-2 COSEM OUT DATA
16 : 37 : 54 ====>Tx METER-2 D0 12 20 00 00 01 E6 C0 01 C1 00 16 00 03 0F 00 04 FF 04 00
16 : 37 : 54 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 54 ====>Tx METER-2 D0 12 20 00 00 01 E6 76 D1 78 4E 8C 89 C4 ED 66 1B D6 A3 50
16 : 37 : 54 METER-2 SERVICE = GET REQUEST, OBIS = 0-3-15-0-4-255, IC = 22, ATTR: INDEX = 4
16 : 37 : 54 METER-2 SENDING HDLC FRAME
16 : 37 : 54 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 E6 76 D1 78 4E 8C 89 C4 ED 66 1B D6 A3 50 50 23 7E
16 : 37 : 54 METER-2 RECEIVED HDLC FRAME
16 : 37 : 54 <====Rx METER-2 7E A0 2B 41 00 02 04 01 1E AA 57 E6 E7 00 D4 1A 20 00 00 01 E7 5B 11 BD E7 6A 50 7C 8D 7A A2 3A 6C 23 B2 E0 CE 63 80 DA
DC 8F 67 FC 7E
16 : 37 : 54 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 54 <====Rx METER-2 D4 1A 20 00 00 01 E7 5B 11 BD E7 6A 50 7C 8D 7A A2 3A 6C 23 B2 E0 CE 63 80 DA DC 8F
16 : 37 : 54 <====Rx METER-2 D4 1A 20 00 00 01 E7 C4 01 81 00 01 01 02 02 09 04 FF FF FF FF 09 05 FF FF FF FF FF
16 : 37 : 54 ====>Tx METER-2 D0 12 20 00 00 01 E7 C0 01 C1 00 17 00 00 16 00 00 FF 02 00
16 : 37 : 54 ====>Tx METER-2 D0 12 20 00 00 01 E7 6B B1 06 B7 1B 8D 0E 33 A8 7E 54 77 1D
16 : 37 : 54 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-22-0-0-255, IC = 23, ATTR: INDEX = 2
16 : 37 : 54 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 E7 6B B1 06 B7 1B 8D 0E 33 A8 7E 54 77 1D 78 4F 7E
16 : 37 : 54 <====Rx METER-2 7E A0 1C 41 00 02 04 01 30 84 8E E6 E7 00 D4 0B 20 00 00 01 E8 BD E8 CE EB B0 52 1B 75 7E
16 : 37 : 54 <====Rx METER-2 D4 0B 20 00 00 01 E8 BD E8 CE EB B0 52
16 : 37 : 54 <====Rx METER-2 D4 0B 20 00 00 01 E8 C4 01 81 00 16 05
16 : 37 : 54 ====>Tx METER-2 D0 12 20 00 00 01 E8 C0 01 C1 00 17 00 00 16 00 00 FF 03 00
16 : 37 : 54 ====>Tx METER-2 D0 12 20 00 00 01 E8 9D DE 61 5B 49 B9 27 EB 03 5F 86 00 DB
16 : 37 : 54 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-22-0-0-255, IC = 23, ATTR: INDEX = 3
16 : 37 : 54 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 E8 9D DE 61 5B 49 B9 27 EB 03 5F 86 00 DB 4A 5F 7E
16 : 37 : 54 <====Rx METER-2 7E A0 1C 41 00 02 04 01 52 90 CE E6 E7 00 D4 0B 20 00 00 01 E9 EE 4D 74 4C 22 98 19 17 7E
16 : 37 : 54 <====Rx METER-2 D4 0B 20 00 00 01 E9 EE 4D 74 4C 22 98
16 : 37 : 54 <====Rx METER-2 D4 0B 20 00 00 01 E9 C4 01 81 00 11 01
16 : 37 : 54 ====>Tx METER-2 D0 12 20 00 00 01 E9 C0 01 C1 00 17 00 00 16 00 00 FF 04 00
16 : 37 : 54 ====>Tx METER-2 D0 12 20 00 00 01 E9 30 76 1B 36 00 A4 4F 37 57 54 19 92 6A
16 : 37 : 54 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-22-0-0-255, IC = 23, ATTR: INDEX = 4
16 : 37 : 54 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 E9 30 76 1B 36 00 A4 4F 37 57 54 19 92 6A C8 4C 7E
16 : 37 : 54 <====Rx METER-2 7E A0 1C 41 00 02 04 01 74 A4 8A E6 E7 00 D4 0B 20 00 00 01 EA 2D 8A 77 BD F3 19 95 EF 7E
16 : 37 : 55 <====Rx METER-2 D4 0B 20 00 00 01 EA 2D 8A 77 BD F3 19
16 : 37 : 55 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 37 : 55 <====Rx METER-2 D4 0B 20 00 00 01 EA C4 01 81 00 11 01
16 : 37 : 55 METER-2 SERVICE = GET RESPONSE
16 : 37 : 55 METER-2 COSEM OUT DATA
16 : 37 : 55 ====>Tx METER-2 D0 12 20 00 00 01 EA C0 01 C1 00 17 00 00 16 00 00 FF 05 00
16 : 37 : 55 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 55 ====>Tx METER-2 D0 12 20 00 00 01 EA 9D D9 F4 82 37 AE DE 73 9D 9E E4 AB E4
16 : 37 : 55 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-22-0-0-255, IC = 23, ATTR: INDEX = 5
16 : 37 : 55 METER-2 SENDING HDLC FRAME
16 : 37 : 55 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 EA 9D D9 F4 82 37 AE DE 73 9D 9E E4 AB E4 1B A4 7E
16 : 37 : 55 METER-2 RECEIVED HDLC FRAME
16 : 37 : 55 <====Rx METER-2 7E A0 1D 41 00 02 04 01 96 6D D1 E6 E7 00 D4 0C 20 00 00 01 EB F5 D6 67 B4 A0 34 A2 13 C5 7E
16 : 37 : 55 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 55 <====Rx METER-2 D4 0C 20 00 00 01 EB F5 D6 67 B4 A0 34 A2
16 : 37 : 55 <====Rx METER-2 D4 0C 20 00 00 01 EB C4 01 81 00 12 00 FA
16 : 37 : 55 ====>Tx METER-2 D0 12 20 00 00 01 EB C0 01 C1 00 17 00 00 16 00 00 FF 06 00
16 : 37 : 55 ====>Tx METER-2 D0 12 20 00 00 01 EB 1A A9 93 FF 64 D1 40 55 72 B6 7C B9 73
16 : 37 : 55 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-22-0-0-255, IC = 23, ATTR: INDEX = 6
16 : 37 : 55 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 EB 1A A9 93 FF 64 D1 40 55 72 B6 7C B9 73 16 C4 7E
16 : 37 : 55 <====Rx METER-2 7E A0 1D 41 00 02 04 01 B8 11 19 E6 E7 00 D4 0C 20 00 00 01 EC 3F 3D E6 60 35 E2 5A 0A 95 7E
16 : 37 : 55 <====Rx METER-2 D4 0C 20 00 00 01 EC 3F 3D E6 60 35 E2 5A
16 : 37 : 55 <====Rx METER-2 D4 0C 20 00 00 01 EC C4 01 81 00 12 00 FA
16 : 37 : 55 ====>Tx METER-2 D0 12 20 00 00 01 EC C0 01 C1 00 17 00 00 16 00 00 FF 07 00
16 : 37 : 55 ====>Tx METER-2 D0 12 20 00 00 01 EC 5A FE AA D9 4C FA BB 44 62 91 6A EF CE
16 : 37 : 55 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-22-0-0-255, IC = 23, ATTR: INDEX = 7
16 : 37 : 55 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 EC 5A FE AA D9 4C FA BB 44 62 91 6A EF CE 63 C1 7E
16 : 37 : 55 <====Rx METER-2 7E A0 1D 41 00 02 04 01 DA 05 59 E6 E7 00 D4 0C 20 00 00 01 ED 4E 1A 2F 40 98 41 8F C2 62 7E
16 : 37 : 55 <====Rx METER-2 D4 0C 20 00 00 01 ED 4E 1A 2F 40 98 41 8F
16 : 37 : 55 <====Rx METER-2 D4 0C 20 00 00 01 ED C4 01 81 00 12 0B B8
16 : 37 : 55 ====>Tx METER-2 D0 12 20 00 00 01 ED C0 01 C1 00 17 00 00 16 00 00 FF 08 00
16 : 37 : 55 ====>Tx METER-2 D0 12 20 00 00 01 ED C5 08 E7 A3 AA ED 46 CB 98 60 74 07 E3
16 : 37 : 55 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-22-0-0-255, IC = 23, ATTR: INDEX = 8
16 : 37 : 55 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 ED C5 08 E7 A3 AA ED 46 CB 98 60 74 07 E3 3A 75 7E
16 : 37 : 55 <====Rx METER-2 7E A0 1D 41 00 02 04 01 FC 31 1D E6 E7 00 D4 0C 20 00 00 01 EE 62 06 CA AA 89 9A 9A 2F 0F 7E
16 : 37 : 55 <====Rx METER-2 D4 0C 20 00 00 01 EE 62 06 CA AA 89 9A 9A
16 : 37 : 55 <====Rx METER-2 D4 0C 20 00 00 01 EE C4 01 81 00 12 00 78
16 : 37 : 56 METER-2 SERVICE = GET RESPONSE
16 : 37 : 56 METER-2 COSEM OUT DATA
16 : 37 : 56 ====>Tx METER-2 D0 12 20 00 00 01 EE C0 01 C1 00 17 00 00 16 00 00 FF 09 00
16 : 37 : 56 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 56 ====>Tx METER-2 D0 12 20 00 00 01 EE 02 79 98 81 AD D4 AE 0E 11 D0 73 7C BA
16 : 37 : 56 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-22-0-0-255, IC = 23, ATTR: INDEX = 9
16 : 37 : 56 METER-2 SENDING HDLC FRAME
16 : 37 : 56 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 EE 02 79 98 81 AD D4 AE 0E 11 D0 73 7C BA FD BB 7E
16 : 37 : 56 METER-2 RECEIVED HDLC FRAME
16 : 37 : 56 <====Rx METER-2 7E A0 1D 41 00 02 04 01 1E 2D D9 E6 E7 00 D4 0C 20 00 00 01 EF 13 1E AA 56 BF FC CB B3 00 7E
16 : 37 : 56 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 56 <====Rx METER-2 D4 0C 20 00 00 01 EF 13 1E AA 56 BF FC CB
16 : 37 : 56 <====Rx METER-2 D4 0C 20 00 00 01 EF C4 01 81 00 12 01 00
16 : 37 : 56 ====>Tx METER-2 D0 12 20 00 00 01 EF C0 01 C1 00 28 00 00 19 09 00 FF 02 00
16 : 37 : 56 ====>Tx METER-2 D0 12 20 00 00 01 EF F8 8B 79 24 77 3A D0 B5 F0 00 E0 2F 0A
16 : 37 : 56 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-9-0-255, IC = 40, ATTR: INDEX = 2
16 : 37 : 56 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 EF F8 8B 79 24 77 3A D0 B5 F0 00 E0 2F 0A 3F 8D 7E
16 : 37 : 56 <====Rx METER-2 7E A0 F8 41 00 02 04 01 30 6A C3 E6 E7 00 D4 81 E6 20 00 00 01 F0 7E 0A 2A 0F 27 77 DD 19 BD 85 ED 6B F3 67 A1 F6 70 A4
85 37 0C 6D F4 B6 A7 1B 50 A9 F2 04 4A 18 DE 2A 2A A8 65 73 79 7C DF EC 1F F8 D6 D9 12 54 B3 56 41 CA 6F 41 C9 95 2A 67
81 B4 C9 9B 6C BE BD 36 C1 21 A9 B1 7B 56 38 3A 0C 70 96 88 A8 E6 D7 75 92 39 F2 F3 E8 67 C6 3B 44 33 AF B1 24 1A 99 6A
32 C1 76 05 5A EB DD 5A 87 CC 55 35 E2 37 AD 3B 7C 3B F9 4F 6A 8E 0B 2C E5 D6 34 F5 E8 74 28 4D 9C D5 51 89 FB C6 AA 67
7A 8E 62 20 C0 B2 F8 DA 07 54 4A 96 D4 C9 DA D0 EF ED BD 58 84 EE 2D 01 AB 12 22 66 5E B5 82 72 91 7F 8C 00 0D 6D 34 AB
0C 5D 82 7B 1F AC CE 76 5B 5F DF BA 06 F2 BD 15 D2 C1 A1 A9 71 86 E2 52 24 4E 56 75 5A 83 0D 79 2B FB E2 0A 31 DC DB 0A
7F B8 13 5F 2B FA 10 6F 99 7E
16 : 37 : 56 <====Rx METER-2 D4 81 E6 20 00 00 01 F0 7E 0A 2A 0F 27 77 DD 19 BD 85 ED 6B F3 67 A1 F6 70 A4 85 37 0C 6D F4 B6 A7 1B 50 A9 F2 04 4A 18
DE 2A 2A A8 65 73 79 7C DF EC 1F F8 D6 D9 12 54 B3 56 41 CA 6F 41 C9 95 2A 67 81 B4 C9 9B 6C BE BD 36 C1 21 A9 B1 7B 56
38 3A 0C 70 96 88 A8 E6 D7 75 92 39 F2 F3 E8 67 C6 3B 44 33 AF B1 24 1A 99 6A 32 C1 76 05 5A EB DD 5A 87 CC 55 35 E2 37
AD 3B 7C 3B F9 4F 6A 8E 0B 2C E5 D6 34 F5 E8 74 28 4D 9C D5 51 89 FB C6 AA 67 7A 8E 62 20 C0 B2 F8 DA 07 54 4A 96 D4 C9
DA D0 EF ED BD 58 84 EE 2D 01 AB 12 22 66 5E B5 82 72 91 7F 8C 00 0D 6D 34 AB 0C 5D 82 7B 1F AC CE 76 5B 5F DF BA 06 F2
BD 15 D2 C1 A1 A9 71 86 E2 52 24 4E 56 75 5A 83 0D 79 2B FB E2 0A 31 DC DB 0A 7F B8 13 5F 2B FA 10
16 : 37 : 56 <====Rx METER-2 D4 81 E6 20 00 00 01 F0 C4 02 81 00 00 00 00 01 00 81 D6 01 0D 02 04 12 00 01 09 06 00 00 60 01 02 FF 0F 02 12 00 00 02
04 12 00 28 09 06 00 00 19 09 00 FF 0F 01 12 00 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03
09 06 01 00 0C 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0B 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00
01 08 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 09 06 00 FF
0F 02 12 00 00 02 04 12 00 01 09 06 00 00 5E 5B 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 00 01 00 FF 0F 02 12 00
00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00 02 04 12 00 46 09 06 00 00 60 03 0A FF 0F
16 : 37 : 56 ====>Tx METER-2 D0 0C 20 00 00 01 F0 C0 02 C1 00 00 00 01
16 : 37 : 56 ====>Tx METER-2 D0 0C 20 00 00 01 F0 3C 4A CF 51 23 4B A3
16 : 37 : 56 METER-2 SERVICE = GET BLOCK REQUEST
16 : 37 : 56 ====>Tx METER-2 7E A0 1D 00 02 04 01 41 32 70 16 E6 E6 00 D0 0C 20 00 00 01 F0 3C 4A CF 51 23 4B A3 5E D9 7E
16 : 37 : 56 <====Rx METER-2 7E A0 36 41 00 02 04 01 52 44 44 E6 E7 00 D4 25 20 00 00 01 F1 2F 2D CD F6 AE 79 11 A5 51 F9 B6 E7 6E 2B 37 05 CA 01 0C
C7 79 16 85 F5 A7 B8 C0 6F A9 C7 1C B3 3C 65 7E
16 : 37 : 56 <====Rx METER-2 E6 E7 00 D4 25 20 00 00 01 F1 2F 2D CD F6 AE 79 11 A5 51 F9 B6 E7 6E 2B 37 05 CA 01 0C C7 79 16 85 F5 A7 B8 C0 6F A9 C7
1C B3
16 : 37 : 56 <====Rx METER-2 01 0D 02 04 12 00 01 09 06 00 00 60 01 02 FF 0F 02 12 00 00 02 04 12 00 28 09 06 00 00 19 09 00 FF 0F 01 12 00 00 02 04
12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0C 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09
06 01 00 0B 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 01
06 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 09 06 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 5E 5B 00 FF 0F
02 12 00 00 02 04 12 00 01 09 06 00 00 00 01 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00
02 04 12 00 46 09 06 00 00 60 03 0A FF 0F 02 12 00 00 02 04 12 00 47 09 06 00 00 11 00 00 FF 0F 03 12 00 00
16 : 37 : 56 ====>Tx METER-2 D0 12 20 00 00 01 F1 C0 01 C1 00 28 00 00 19 09 00 FF 03 00
16 : 37 : 56 ====>Tx METER-2 D0 12 20 00 00 01 F1 41 0D EF 90 36 D3 D0 00 E2 B4 18 32 16
16 : 37 : 56 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-9-0-255, IC = 40, ATTR: INDEX = 3
16 : 37 : 56 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 F1 41 0D EF 90 36 D3 D0 00 E2 B4 18 32 16 99 A5 7E
16 : 37 : 56 <====Rx METER-2 7E A0 50 41 00 02 04 01 74 38 FC E6 E7 00 D4 3F 20 00 00 01 F2 7B A0 88 FE 4A 04 91 68 6D 96 C8 D8 D1 D0 31 7F 08 92 47
50 BA C1 71 A0 DD CA 6F BF 95 AF 92 7E 6A 88 51 B2 06 A5 D5 E8 99 ED 46 C7 0D 3A 57 8F 92 92 A3 72 71 87 48 AA 93 6C 8C
8D 7E
16 : 37 : 56 <====Rx METER-2 D4 3F 20 00 00 01 F2 7B A0 88 FE 4A 04 91 68 6D 96 C8 D8 D1 D0 31 7F 08 92 47 50 BA C1 71 A0 DD CA 6F BF 95 AF 92 7E 6A
16 : 37 : 56 <====Rx METER-2 D4 3F 20 00 00 01 F2 C4 01 81 00 02 03 16 00 09 2E 5B 46 43 30 30 3A 30 30 31 30 3A 30 30 31 30 3A 30 32 31 32 3A 30 30
30 30 3A 30 30 30 30 3A 30 30 30 30 3A 30 30 30 37 5D 3A 33 30 30 35 16 00
16 : 37 : 57 METER-2 SERVICE = GET RESPONSE
16 : 37 : 57 METER-2 COSEM OUT DATA
16 : 37 : 57 ====>Tx METER-2 D0 12 20 00 00 01 F2 C0 01 C1 00 28 00 00 19 09 00 FF 04 00
16 : 37 : 57 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 57 ====>Tx METER-2 D0 12 20 00 00 01 F2 0B 66 4D 11 81 45 80 5C 4B 93 FA 6E 03
16 : 37 : 57 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-9-0-255, IC = 40, ATTR: INDEX = 4
16 : 37 : 57 METER-2 SENDING HDLC FRAME
16 : 37 : 57 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 F2 0B 66 4D 11 81 45 80 5C 4B 93 FA 6E 03 2D 8E 7E
16 : 37 : 57 METER-2 RECEIVED HDLC FRAME
16 : 37 : 57 <====Rx METER-2 7E A0 1C 41 00 02 04 01 96 B8 4E E6 E7 00 D4 0B 20 00 00 01 F3 CD C8 6D 63 19 EE 1E 59 7E
16 : 37 : 57 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 37 : 57 <====Rx METER-2 D4 0B 20 00 00 01 F3 CD C8 6D 63 19 EE
16 : 37 : 57 <====Rx METER-2 D4 0B 20 00 00 01 F3 C4 01 81 00 01 00
16 : 37 : 57 ====>Tx METER-2 D0 12 20 00 00 01 F3 C0 01 C1 00 28 00 00 19 09 00 FF 05 00
16 : 37 : 57 ====>Tx METER-2 D0 12 20 00 00 01 F3 BD 51 0C 2F 48 EB 92 4B EF 23 81 FC 58
16 : 37 : 57 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-9-0-255, IC = 40, ATTR: INDEX = 5
16 : 37 : 57 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 F3 BD 51 0C 2F 48 EB 92 4B EF 23 81 FC 58 81 57 7E
16 : 37 : 57 <====Rx METER-2 7E A0 1D 41 00 02 04 01 B8 11 19 E6 E7 00 D4 0C 20 00 00 01 F4 D0 6D 90 2B 9F 62 33 AC 6E 7E
16 : 37 : 57 <====Rx METER-2 D4 0C 20 00 00 01 F4 D0 6D 90 2B 9F 62 33
16 : 37 : 57 <====Rx METER-2 D4 0C 20 00 00 01 F4 C4 01 81 00 12 00 00
16 : 37 : 57 ====>Tx METER-2 D0 12 20 00 00 01 F4 C0 01 C1 00 28 00 00 19 09 00 FF 06 00
16 : 37 : 57 ====>Tx METER-2 D0 12 20 00 00 01 F4 31 67 3C F3 56 3A 75 84 21 48 F8 A8 94
16 : 37 : 57 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-9-0-255, IC = 40, ATTR: INDEX = 6
16 : 37 : 57 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 F4 31 67 3C F3 56 3A 75 84 21 48 F8 A8 94 98 D0 7E
16 : 37 : 57 <====Rx METER-2 7E A0 1C 41 00 02 04 01 DA D0 C6 E6 E7 00 D4 0B 20 00 00 01 F5 71 09 47 96 D6 49 C5 CC 7E
16 : 37 : 57 <====Rx METER-2 D4 0B 20 00 00 01 F5 71 09 47 96 D6 49
16 : 37 : 57 <====Rx METER-2 D4 0B 20 00 00 01 F5 C4 01 81 00 11 03
16 : 37 : 57 ====>Tx METER-2 D0 12 20 00 00 01 F5 C0 01 C1 00 28 00 00 19 09 00 FF 07 00
16 : 37 : 57 ====>Tx METER-2 D0 12 20 00 00 01 F5 62 5D 1D 33 8E E6 93 44 A4 91 72 EA 0C
16 : 37 : 57 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-9-0-255, IC = 40, ATTR: INDEX = 7
16 : 37 : 57 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 F5 62 5D 1D 33 8E E6 93 44 A4 91 72 EA 0C F3 45 7E
16 : 37 : 57 <====Rx METER-2 7E A0 1D 41 00 02 04 01 FC 31 1D E6 E7 00 D4 0C 20 00 00 01 F6 9E 00 FC 9E C5 9A C9 46 55 7E
16 : 37 : 57 <====Rx METER-2 D4 0C 20 00 00 01 F6 9E 00 FC 9E C5 9A C9
16 : 37 : 58 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 37 : 58 <====Rx METER-2 D4 0C 20 00 00 01 F6 C4 01 81 00 12 00 0F
16 : 37 : 58 METER-2 SERVICE = GET RESPONSE
16 : 37 : 58 METER-2 COSEM OUT DATA
16 : 37 : 58 ====>Tx METER-2 D0 12 20 00 00 01 F6 C0 01 C1 00 28 00 01 19 09 00 FF 02 00
16 : 37 : 58 METER-2 COSEM OUT DATA - CIPHERED
16 : 37 : 58 ====>Tx METER-2 D0 12 20 00 00 01 F6 CE C5 18 9D 95 E8 A7 56 26 17 E5 48 B6
16 : 37 : 58 METER-2 SERVICE = GET REQUEST, OBIS = 0-1-25-9-0-255, IC = 40, ATTR: INDEX = 2
16 : 37 : 58 METER-2 SENDING HDLC FRAME
16 : 37 : 58 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 F6 CE C5 18 9D 95 E8 A7 56 26 17 E5 48 B6 DE 57 7E
16 : 37 : 58 METER-2 RECEIVED HDLC FRAME
16 : 38 : 07 <====Rx METER-2 7E A0 52 41 00 02 04 01 1E DF 07 E6 E7 00 D4 41 20 00 00 01 F7 A4 44 DA D0 EA 37 31 EC 7E 82 79 30 78 FE 25 7B 39 AA 46
16 F8 E4 18 9B F3 2A FD D6 50 E6 A8 41 DE F4 38 9C 96 26 B5 6B 77 C9 F3 55 1E E9 8D 57 3C 08 EB EA 6F E8 E2 FE 2A 54 34
6D B3 06 7E
16 : 38 : 07 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 07 <====Rx METER-2 D4 41 20 00 00 01 F7 A4 44 DA D0 EA 37 31 EC 7E 82 79 30 78 FE 25 7B 39 AA 46 16 F8 E4 18 9B F3 2A FD D6 50 E6 A8 41 DE
F4 38 9C 96 26 B5 6B 77 C9 F3 55 1E E9 8D 57 3C 08 EB EA 6F E8 E2 FE 2A 54 34 6D
16 : 38 : 07 <====Rx METER-2 D4 41 20 00 00 01 F7 C4 01 81 00 01 03 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 28 09 06 00 01
19 09 00 FF 0F 01 12 00 00 02 04 12 00 01 09 06 00 00 60 0D 01 FF 0F 02 12 00 00
16 : 38 : 07 METER-2 SERVICE = GET RESPONSE
16 : 38 : 07 METER-2 COSEM OUT DATA
16 : 38 : 07 ====>Tx METER-2 D0 12 20 00 00 01 F7 C0 01 C1 00 28 00 01 19 09 00 FF 03 00
16 : 38 : 07 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 07 ====>Tx METER-2 D0 12 20 00 00 01 F7 74 3D 2B B5 FB 7B 83 6B 05 6B B8 40 C9
16 : 38 : 07 METER-2 SERVICE = GET REQUEST, OBIS = 0-1-25-9-0-255, IC = 40, ATTR: INDEX = 3
16 : 38 : 07 METER-2 SENDING HDLC FRAME
16 : 38 : 07 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 F7 74 3D 2B B5 FB 7B 83 6B 05 6B B8 40 C9 2F E4 7E
16 : 38 : 07 METER-2 RECEIVED HDLC FRAME
16 : 38 : 07 <====Rx METER-2 7E A0 4D 41 00 02 04 01 30 9E 63 E6 E7 00 D4 3C 20 00 00 01 F8 C5 C5 16 50 93 84 4B A9 34 9C 00 AB 39 C4 19 7B 20 4B 63
4D F7 84 98 3C 71 1C A2 05 A2 A8 01 64 4E 6F E3 B8 46 E5 4A 33 F2 19 0F D0 76 F7 2A CD 87 A2 F5 76 EB 0C 9E 6B 15 7E
16 : 38 : 07 <====Rx METER-2 D4 3C 20 00 00 01 F8 C5 C5 16 50 93 84 4B A9 34 9C 00 AB 39 C4 19 7B 20 4B 63 4D F7 84 98 3C 71 1C A2 05 A2 A8 01 64 4E
16 : 38 : 07 <====Rx METER-2 D4 3C 20 00 00 01 F8 C4 01 81 00 02 03 16 00 09 2B 5B 30 30 30 30 3A 30 30 30 30 3A 30 30 30 30 3A 30 30 30 30 3A 30 30
30 30 3A 30 30 30 30 3A 30 30 30 30 3A 30 30 30 30 5D 3A 30 16 00
16 : 38 : 07 ====>Tx METER-2 D0 12 20 00 00 01 F8 C0 01 C1 00 28 00 01 19 09 00 FF 04 00
16 : 38 : 07 ====>Tx METER-2 D0 12 20 00 00 01 F8 EF 16 DB F8 5E C3 B5 F2 86 9F D6 BC 83
16 : 38 : 07 METER-2 SERVICE = GET REQUEST, OBIS = 0-1-25-9-0-255, IC = 40, ATTR: INDEX = 4
16 : 38 : 07 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 01 F8 EF 16 DB F8 5E C3 B5 F2 86 9F D6 BC 83 94 13 7E
16 : 38 : 07 <====Rx METER-2 7E A0 1C 41 00 02 04 01 52 90 CE E6 E7 00 D4 0B 20 00 00 01 F9 AC A4 7D 3A 6E 22 A0 88 7E
16 : 38 : 08 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 08 <====Rx METER-2 D4 0B 20 00 00 01 F9 AC A4 7D 3A 6E 22
16 : 38 : 08 <====Rx METER-2 D4 0B 20 00 00 01 F9 C4 01 81 00 01 00
16 : 38 : 08 METER-2 SERVICE = GET RESPONSE
16 : 38 : 08 METER-2 COSEM OUT DATA
16 : 38 : 08 ====>Tx METER-2 D0 12 20 00 00 01 F9 C0 01 C1 00 28 00 01 19 09 00 FF 05 00
16 : 38 : 08 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 08 ====>Tx METER-2 D0 12 20 00 00 01 F9 18 EE B5 A1 0D CF 63 22 7F 23 61 F2 EE
16 : 38 : 08 METER-2 SERVICE = GET REQUEST, OBIS = 0-1-25-9-0-255, IC = 40, ATTR: INDEX = 5
16 : 38 : 08 METER-2 SENDING HDLC FRAME
16 : 38 : 08 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 01 F9 18 EE B5 A1 0D CF 63 22 7F 23 61 F2 EE 19 15 7E
16 : 38 : 08 METER-2 RECEIVED HDLC FRAME
16 : 38 : 08 <====Rx METER-2 7E A0 1D 41 00 02 04 01 74 71 15 E6 E7 00 D4 0C 20 00 00 01 FA D2 DB 51 23 27 EB 6F C4 99 7E
16 : 38 : 08 <====Rx METER-2 D4 0C 20 00 00 01 FA D2 DB 51 23 27 EB 6F
16 : 38 : 08 <====Rx METER-2 D4 0C 20 00 00 01 FA C4 01 81 00 12 00 00
16 : 38 : 08 ====>Tx METER-2 D0 12 20 00 00 01 FA C0 01 C1 00 28 00 01 19 09 00 FF 06 00
16 : 38 : 08 ====>Tx METER-2 D0 12 20 00 00 01 FA 14 2E 24 ED E6 0F 37 84 51 82 28 C0 B1
16 : 38 : 08 METER-2 SERVICE = GET REQUEST, OBIS = 0-1-25-9-0-255, IC = 40, ATTR: INDEX = 6
16 : 38 : 08 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 01 FA 14 2E 24 ED E6 0F 37 84 51 82 28 C0 B1 2F 37 7E
16 : 38 : 08 <====Rx METER-2 7E A0 1C 41 00 02 04 01 96 B8 4E E6 E7 00 D4 0B 20 00 00 01 FB EE 70 B8 AF 54 58 FE 15 7E
16 : 38 : 08 <====Rx METER-2 D4 0B 20 00 00 01 FB EE 70 B8 AF 54 58
16 : 38 : 08 <====Rx METER-2 D4 0B 20 00 00 01 FB C4 01 81 00 11 03
16 : 38 : 08 ====>Tx METER-2 D0 12 20 00 00 01 FB C0 01 C1 00 28 00 01 19 09 00 FF 07 00
16 : 38 : 08 ====>Tx METER-2 D0 12 20 00 00 01 FB AC D9 E1 64 70 77 E7 24 B1 C1 FA 1C BE
16 : 38 : 08 METER-2 SERVICE = GET REQUEST, OBIS = 0-1-25-9-0-255, IC = 40, ATTR: INDEX = 7
16 : 38 : 08 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 01 FB AC D9 E1 64 70 77 E7 24 B1 C1 FA 1C BE C3 D9 7E
16 : 38 : 08 <====Rx METER-2 7E A0 1D 41 00 02 04 01 B8 11 19 E6 E7 00 D4 0C 20 00 00 01 FC A4 2B 6A 5D 9A 23 67 72 97 7E
16 : 38 : 08 <====Rx METER-2 D4 0C 20 00 00 01 FC A4 2B 6A 5D 9A 23 67
16 : 38 : 08 <====Rx METER-2 D4 0C 20 00 00 01 FC C4 01 81 00 12 00 0F
16 : 38 : 09 METER-2 SERVICE = GET RESPONSE
16 : 38 : 09 METER-2 COSEM OUT DATA
16 : 38 : 09 ====>Tx METER-2 D0 12 20 00 00 01 FC C0 01 C1 00 28 00 02 19 09 00 FF 02 00
16 : 38 : 09 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 09 ====>Tx METER-2 D0 12 20 00 00 01 FC 2D 80 A3 A9 C0 8F C1 A2 28 80 FF 80 56
16 : 38 : 09 METER-2 SERVICE = GET REQUEST, OBIS = 0-2-25-9-0-255, IC = 40, ATTR: INDEX = 2
16 : 38 : 09 METER-2 SENDING HDLC FRAME
16 : 38 : 09 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 01 FC 2D 80 A3 A9 C0 8F C1 A2 28 80 FF 80 56 42 C4 7E
16 : 38 : 09 METER-2 RECEIVED HDLC FRAME
16 : 38 : 09 <====Rx METER-2 7E A0 64 41 00 02 04 01 DA 70 09 E6 E7 00 D4 53 20 00 00 01 FD 6E 86 50 5E 6E 61 2E 93 A0 F1 CF C0 40 C7 80 86 9A 8E 1A
F0 B1 64 65 36 3F 1A 53 C8 61 AE 28 74 96 A5 97 CF 23 D9 43 53 52 63 7A E6 C9 AE 0E 31 A5 4E 0E 82 06 65 8B B6 B1 9A 86
0B AA 3C E8 C9 9B 4A 99 14 B9 C6 79 B8 A2 F2 A8 2F 23 2E 4C 48 7E
16 : 38 : 09 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 09 <====Rx METER-2 D4 53 20 00 00 01 FD 6E 86 50 5E 6E 61 2E 93 A0 F1 CF C0 40 C7 80 86 9A 8E 1A F0 B1 64 65 36 3F 1A 53 C8 61 AE 28 74 96
A5 97 CF 23 D9 43 53 52 63 7A E6 C9 AE 0E 31 A5 4E 0E 82 06 65 8B B6 B1 9A 86 0B AA 3C E8 C9 9B 4A 99 14 B9 C6 79 B8 A2
F2 A8 2F 23 2E
16 : 38 : 09 <====Rx METER-2 D4 53 20 00 00 01 FD C4 01 81 00 01 04 02 04 12 00 01 09 06 00 00 60 01 02 FF 0F 02 12 00 00 02 04 12 00 28 09 06 00 02
19 09 00 FF 0F 01 12 00 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0D 02 FF
0F 02 12 00 00
16 : 38 : 09 ====>Tx METER-2 D0 12 20 00 00 01 FD C0 01 C1 00 28 00 02 19 09 00 FF 03 00
16 : 38 : 09 ====>Tx METER-2 D0 12 20 00 00 01 FD 33 D8 54 F9 7A 3B F5 6A A2 ED 40 3D 76
16 : 38 : 09 METER-2 SERVICE = GET REQUEST, OBIS = 0-2-25-9-0-255, IC = 40, ATTR: INDEX = 3
16 : 38 : 09 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 01 FD 33 D8 54 F9 7A 3B F5 6A A2 ED 40 3D 76 5A 4F 7E
16 : 38 : 09 <====Rx METER-2 7E A0 4D 41 00 02 04 01 FC FE 6F E6 E7 00 D4 3C 20 00 00 01 FE BA B8 02 1E 6F F9 65 D1 9E 25 50 6F FD 91 24 00 A2 04 A9
1D 69 77 0A 89 F6 AE 29 30 67 67 B4 42 79 E3 BB 76 E4 E8 84 A4 D0 3F 4A 3F B7 F3 CF C6 BC 22 F7 08 4A AF 3F EB 4A 7E
16 : 38 : 09 <====Rx METER-2 D4 3C 20 00 00 01 FE BA B8 02 1E 6F F9 65 D1 9E 25 50 6F FD 91 24 00 A2 04 A9 1D 69 77 0A 89 F6 AE 29 30 67 67 B4 42 79
16 : 38 : 09 <====Rx METER-2 D4 3C 20 00 00 01 FE C4 01 81 00 02 03 16 00 09 2B 5B 30 30 30 30 3A 30 30 30 30 3A 30 30 30 30 3A 30 30 30 30 3A 30 30
16 : 38 : 09 ====>Tx METER-2 D0 12 20 00 00 01 FE C0 01 C1 00 28 00 02 19 09 00 FF 04 00
16 : 38 : 09 ====>Tx METER-2 D0 12 20 00 00 01 FE 6C 7B 67 36 56 6E 8F 68 A9 66 45 A4 6A
16 : 38 : 09 METER-2 SERVICE = GET REQUEST, OBIS = 0-2-25-9-0-255, IC = 40, ATTR: INDEX = 4
16 : 38 : 09 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 01 FE 6C 7B 67 36 56 6E 8F 68 A9 66 45 A4 6A 4C 98 7E
16 : 38 : 09 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 01 FF EE A3 44 52 FF 22 AD 9C 7E
16 : 38 : 09 <====Rx METER-2 D4 0B 20 00 00 01 FF EE A3 44 52 FF 22
16 : 38 : 09 <====Rx METER-2 D4 0B 20 00 00 01 FF C4 01 81 00 01 00
16 : 38 : 10 ====>Tx METER-2 D0 12 20 00 00 01 FF C0 01 C1 00 28 00 02 19 09 00 FF 05 00
16 : 38 : 10 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 10 ====>Tx METER-2 D0 12 20 00 00 01 FF 59 95 F6 32 91 93 9C F4 FA 22 AA 04 DB
16 : 38 : 10 METER-2 SERVICE = GET REQUEST, OBIS = 0-2-25-9-0-255, IC = 40, ATTR: INDEX = 5
16 : 38 : 10 METER-2 SENDING HDLC FRAME
16 : 38 : 10 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 01 FF 59 95 F6 32 91 93 9C F4 FA 22 AA 04 DB 92 DE 7E
16 : 38 : 10 METER-2 RECEIVED HDLC FRAME
16 : 38 : 10 <====Rx METER-2 7E A0 1D 41 00 02 04 01 30 51 11 E6 E7 00 D4 0C 20 00 00 02 00 C2 D9 30 58 22 DF 02 2F F7 7E
16 : 38 : 10 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 10 <====Rx METER-2 D4 0C 20 00 00 02 00 C2 D9 30 58 22 DF 02
16 : 38 : 10 <====Rx METER-2 D4 0C 20 00 00 02 00 C4 01 81 00 12 00 00
16 : 38 : 10 METER-2 SERVICE = GET RESPONSE
16 : 38 : 10 ====>Tx METER-2 D0 12 20 00 00 02 00 C0 01 C1 00 28 00 02 19 09 00 FF 06 00
16 : 38 : 10 ====>Tx METER-2 D0 12 20 00 00 02 00 8B C0 7A C8 01 22 66 6D 25 BC BF 46 B6
16 : 38 : 10 METER-2 SERVICE = GET REQUEST, OBIS = 0-2-25-9-0-255, IC = 40, ATTR: INDEX = 6
16 : 38 : 10 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 02 00 8B C0 7A C8 01 22 66 6D 25 BC BF 46 B6 70 F1 7E
16 : 38 : 10 <====Rx METER-2 7E A0 1C 41 00 02 04 01 52 90 CE E6 E7 00 D4 0B 20 00 00 02 01 67 F5 EC 3F 0A 44 71 D0 7E
16 : 38 : 10 <====Rx METER-2 D4 0B 20 00 00 02 01 67 F5 EC 3F 0A 44
16 : 38 : 10 <====Rx METER-2 D4 0B 20 00 00 02 01 C4 01 81 00 11 03
16 : 38 : 10 ====>Tx METER-2 D0 12 20 00 00 02 01 C0 01 C1 00 28 00 02 19 09 00 FF 07 00
16 : 38 : 10 ====>Tx METER-2 D0 12 20 00 00 02 01 DC 03 8D BE DF 24 96 67 B5 B9 AC 16 62
16 : 38 : 10 METER-2 SERVICE = GET REQUEST, OBIS = 0-2-25-9-0-255, IC = 40, ATTR: INDEX = 7
16 : 38 : 10 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 02 01 DC 03 8D BE DF 24 96 67 B5 B9 AC 16 62 99 A7 7E
16 : 38 : 10 <====Rx METER-2 7E A0 1D 41 00 02 04 01 74 71 15 E6 E7 00 D4 0C 20 00 00 02 02 9B FE D7 D6 28 7B 2F 13 8F 7E
16 : 38 : 10 <====Rx METER-2 D4 0C 20 00 00 02 02 9B FE D7 D6 28 7B 2F
16 : 38 : 10 <====Rx METER-2 D4 0C 20 00 00 02 02 C4 01 81 00 12 00 0F
16 : 38 : 10 ====>Tx METER-2 D0 12 20 00 00 02 02 C0 01 C1 00 28 00 03 19 09 00 FF 02 00
16 : 38 : 10 ====>Tx METER-2 D0 12 20 00 00 02 02 50 02 40 E6 A9 80 0E 92 AA B1 A0 29 22
16 : 38 : 10 METER-2 SERVICE = GET REQUEST, OBIS = 0-3-25-9-0-255, IC = 40, ATTR: INDEX = 2
16 : 38 : 10 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 02 02 50 02 40 E6 A9 80 0E 92 AA B1 A0 29 22 54 AF 7E
16 : 38 : 11 <====Rx METER-2 7E A0 76 41 00 02 04 01 96 6A 03 E6 E7 00 D4 65 20 00 00 02 03 F1 8D 9F 0F 36 49 CB 8D 42 3B 0C 33 C8 CC F6 6A 54 77 FB
08 8D CD 97 07 42 D0 0E E4 49 FD E3 4E 90 0C 13 69 5E 08 1A C3 0C FA AE D1 4E 8C 7B 56 FE 81 63 65 7A 68 22 A6 DD 76 A9
4B BF 5C 86 E0 C2 F5 CA 3F CC 3E 63 26 42 8B B4 A7 80 F9 BD FA 01 72 86 17 88 6E C8 82 F8 C3 02 5C 89 FA E4 B2 6F C3 7E
16 : 38 : 11 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 11 <====Rx METER-2 D4 65 20 00 00 02 03 F1 8D 9F 0F 36 49 CB 8D 42 3B 0C 33 C8 CC F6 6A 54 77 FB 08 8D CD 97 07 42 D0 0E E4 49 FD E3 4E 90
0C 13 69 5E 08 1A C3 0C FA AE D1 4E 8C 7B 56 FE 81 63 65 7A 68 22 A6 DD 76 A9 4B BF 5C 86 E0 C2 F5 CA 3F CC 3E 63 26 42
16 : 38 : 11 <====Rx METER-2 D4 65 20 00 00 02 03 C4 01 81 00 01 05 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 28 09 06 00 03
19 09 00 FF 0F 01 12 00 00 02 04 12 00 03 09 06 01 00 01 09 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF
0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 02 12 00 00
16 : 38 : 11 METER-2 SERVICE = GET RESPONSE
16 : 38 : 11 METER-2 COSEM OUT DATA
16 : 38 : 11 ====>Tx METER-2 D0 12 20 00 00 02 03 C0 01 C1 00 28 00 03 19 09 00 FF 03 00
16 : 38 : 11 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 11 ====>Tx METER-2 D0 12 20 00 00 02 03 A3 4A 5C 71 18 59 19 22 DA 2E 95 18 40
16 : 38 : 11 METER-2 SERVICE = GET REQUEST, OBIS = 0-3-25-9-0-255, IC = 40, ATTR: INDEX = 3
16 : 38 : 11 METER-2 SENDING HDLC FRAME
16 : 38 : 11 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 02 03 A3 4A 5C 71 18 59 19 22 DA 2E 95 18 40 59 9E 7E
16 : 38 : 11 METER-2 RECEIVED HDLC FRAME
16 : 38 : 11 <====Rx METER-2 7E A0 4D 41 00 02 04 01 B8 DE 6B E6 E7 00 D4 3C 20 00 00 02 04 DB E5 75 05 69 71 24 18 AF D8 B8 66 D1 87 09 47 31 9E 43
E8 02 D7 E2 E4 20 0D 19 D4 25 28 E7 DA 3D 26 53 F9 6D B8 14 99 BE 12 66 96 F9 F4 55 00 68 2D 50 2C BD 9D FD 2D E9 7E
16 : 38 : 11 <====Rx METER-2 D4 3C 20 00 00 02 04 DB E5 75 05 69 71 24 18 AF D8 B8 66 D1 87 09 47 31 9E 43 E8 02 D7 E2 E4 20 0D 19 D4 25 28 E7 DA 3D
16 : 38 : 11 <====Rx METER-2 D4 3C 20 00 00 02 04 C4 01 81 00 02 03 16 00 09 2B 5B 30 30 30 30 3A 30 30 30 30 3A 30 30 30 30 3A 30 30 30 30 3A 30 30
16 : 38 : 11 ====>Tx METER-2 D0 12 20 00 00 02 04 C0 01 C1 00 28 00 03 19 09 00 FF 04 00
16 : 38 : 11 ====>Tx METER-2 D0 12 20 00 00 02 04 64 E2 07 56 01 EA 61 2D 04 25 F3 80 97
16 : 38 : 11 METER-2 SERVICE = GET REQUEST, OBIS = 0-3-25-9-0-255, IC = 40, ATTR: INDEX = 4
16 : 38 : 11 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 02 04 64 E2 07 56 01 EA 61 2D 04 25 F3 80 97 7A 21 7E
16 : 38 : 11 <====Rx METER-2 7E A0 1C 41 00 02 04 01 DA D0 C6 E6 E7 00 D4 0B 20 00 00 02 05 16 1E B9 9D D8 A1 21 CF 7E
16 : 38 : 11 <====Rx METER-2 D4 0B 20 00 00 02 05 16 1E B9 9D D8 A1
16 : 38 : 11 <====Rx METER-2 D4 0B 20 00 00 02 05 C4 01 81 00 01 00
16 : 38 : 11 ====>Tx METER-2 D0 12 20 00 00 02 05 C0 01 C1 00 28 00 03 19 09 00 FF 05 00
16 : 38 : 11 ====>Tx METER-2 D0 12 20 00 00 02 05 03 13 67 8A CE FC CD CE 3A CA 0D 48 30
16 : 38 : 11 METER-2 SERVICE = GET REQUEST, OBIS = 0-3-25-9-0-255, IC = 40, ATTR: INDEX = 5
16 : 38 : 11 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 02 05 03 13 67 8A CE FC CD CE 3A CA 0D 48 30 8F D6 7E
16 : 38 : 11 <====Rx METER-2 7E A0 1D 41 00 02 04 01 FC 31 1D E6 E7 00 D4 0C 20 00 00 02 06 41 F6 16 C7 DB A1 25 78 54 7E
16 : 38 : 11 <====Rx METER-2 D4 0C 20 00 00 02 06 41 F6 16 C7 DB A1 25
16 : 38 : 11 <====Rx METER-2 D4 0C 20 00 00 02 06 C4 01 81 00 12 00 00
16 : 38 : 12 METER-2 COSEM OUT DATA
16 : 38 : 12 ====>Tx METER-2 D0 12 20 00 00 02 06 C0 01 C1 00 28 00 03 19 09 00 FF 06 00
16 : 38 : 12 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 12 ====>Tx METER-2 D0 12 20 00 00 02 06 A1 79 3F 9E 39 DC 9F D3 88 13 DD AF 7C
16 : 38 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 0-3-25-9-0-255, IC = 40, ATTR: INDEX = 6
16 : 38 : 12 METER-2 SENDING HDLC FRAME
16 : 38 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 02 06 A1 79 3F 9E 39 DC 9F D3 88 13 DD AF 7C BB 96 7E
16 : 38 : 12 METER-2 RECEIVED HDLC FRAME
16 : 38 : 12 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 02 07 19 E5 3D 43 7B FB 87 A5 7E
16 : 38 : 12 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 12 <====Rx METER-2 D4 0B 20 00 00 02 07 19 E5 3D 43 7B FB
16 : 38 : 12 <====Rx METER-2 D4 0B 20 00 00 02 07 C4 01 81 00 11 03
16 : 38 : 12 METER-2 SERVICE = GET RESPONSE
16 : 38 : 12 ====>Tx METER-2 D0 12 20 00 00 02 07 C0 01 C1 00 28 00 03 19 09 00 FF 07 00
16 : 38 : 12 ====>Tx METER-2 D0 12 20 00 00 02 07 FA 73 6E CB 00 0E 72 7B 1A F2 9F 51 BB
16 : 38 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 0-3-25-9-0-255, IC = 40, ATTR: INDEX = 7
16 : 38 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 02 07 FA 73 6E CB 00 0E 72 7B 1A F2 9F 51 BB 41 02 7E
16 : 38 : 12 <====Rx METER-2 7E A0 1D 41 00 02 04 01 30 51 11 E6 E7 00 D4 0C 20 00 00 02 08 43 17 80 32 BB 9D CE 95 8A 7E
16 : 38 : 12 <====Rx METER-2 D4 0C 20 00 00 02 08 43 17 80 32 BB 9D CE
16 : 38 : 12 <====Rx METER-2 D4 0C 20 00 00 02 08 C4 01 81 00 12 00 0F
16 : 38 : 12 ====>Tx METER-2 D0 12 20 00 00 02 08 C0 01 C1 00 28 00 04 19 09 00 FF 02 00
16 : 38 : 12 ====>Tx METER-2 D0 12 20 00 00 02 08 84 DB 48 22 DC 92 E7 87 9C 39 E4 28 11
16 : 38 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 0-4-25-9-0-255, IC = 40, ATTR: INDEX = 2
16 : 38 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 02 08 84 DB 48 22 DC 92 E7 87 9C 39 E4 28 11 71 69 7E
16 : 38 : 12 <====Rx METER-2 7E A0 64 41 00 02 04 01 52 30 01 E6 E7 00 D4 53 20 00 00 02 09 8F 56 68 CE 59 A8 76 BA 51 3F 2E 8E 40 19 16 58 A2 6A 73
4C B4 9A 25 49 AA 20 60 D2 B8 CA 48 65 02 65 D0 60 06 DF 53 13 E2 CA 16 83 D8 46 E5 01 1F 11 2D 65 A8 BF D0 8E 2C B3 CD
1F 71 BC C6 2F 7C AA 96 7C 77 8B 6F 6B 6E 28 0E E2 E2 50 CA E1 7E
16 : 38 : 12 <====Rx METER-2 D4 53 20 00 00 02 09 8F 56 68 CE 59 A8 76 BA 51 3F 2E 8E 40 19 16 58 A2 6A 73 4C B4 9A 25 49 AA 20 60 D2 B8 CA 48 65 02
65 D0 60 06 DF 53 13 E2 CA 16 83 D8 46 E5 01 1F 11 2D 65 A8 BF D0 8E 2C B3 CD 1F 71 BC C6 2F 7C AA 96 7C 77 8B 6F 6B 6E
28 0E E2 E2 50
16 : 38 : 12 <====Rx METER-2 D4 53 20 00 00 02 09 C4 01 81 00 01 04 02 04 12 00 01 09 06 00 00 60 01 02 FF 0F 02 12 00 00 02 04 12 00 28 09 06 00 04
19 09 00 FF 0F 01 12 00 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 5E 5B 12 FF
0F 02 12 00 00
16 : 38 : 12 ====>Tx METER-2 D0 12 20 00 00 02 09 C0 01 C1 00 28 00 04 19 09 00 FF 03 00
16 : 38 : 12 ====>Tx METER-2 D0 12 20 00 00 02 09 C1 42 B8 F2 F1 7C 20 9A 95 B8 E2 5A 60
16 : 38 : 12 METER-2 SERVICE = GET REQUEST, OBIS = 0-4-25-9-0-255, IC = 40, ATTR: INDEX = 3
16 : 38 : 12 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 02 09 C1 42 B8 F2 F1 7C 20 9A 95 B8 E2 5A 60 07 8A 7E
16 : 38 : 12 <====Rx METER-2 7E A0 50 41 00 02 04 01 74 38 FC E6 E7 00 D4 3F 20 00 00 02 0A A9 FD 12 B4 2F 6A CF C9 9D F2 1D 01 F0 3C A8 FB 2A F3 A5
97 D3 8A 92 C2 50 A8 06 54 95 DD AA 72 1C 1B C8 87 19 65 A1 DC 87 A4 68 61 A8 7B 70 26 F9 D9 3B 6C 9C 60 92 37 08 ED 18
BE 7E
16 : 38 : 13 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 13 <====Rx METER-2 D4 3F 20 00 00 02 0A A9 FD 12 B4 2F 6A CF C9 9D F2 1D 01 F0 3C A8 FB 2A F3 A5 97 D3 8A 92 C2 50 A8 06 54 95 DD AA 72 1C
16 : 38 : 13 <====Rx METER-2 D4 3F 20 00 00 02 0A C4 01 81 00 02 03 16 00 09 2E 5B 46 43 30 30 3A 30 30 31 30 3A 30 30 31 30 3A 30 32 31 32 3A 30 30
16 : 38 : 13 METER-2 SERVICE = GET RESPONSE
16 : 38 : 13 METER-2 COSEM OUT DATA
16 : 38 : 13 ====>Tx METER-2 D0 12 20 00 00 02 0A C0 01 C1 00 28 00 04 19 09 00 FF 04 00
16 : 38 : 13 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 13 ====>Tx METER-2 D0 12 20 00 00 02 0A E2 BE F5 99 61 2E 91 DE 9F 28 1C C9 D0
16 : 38 : 13 METER-2 SERVICE = GET REQUEST, OBIS = 0-4-25-9-0-255, IC = 40, ATTR: INDEX = 4
16 : 38 : 13 METER-2 SENDING HDLC FRAME
16 : 38 : 13 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 02 0A E2 BE F5 99 61 2E 91 DE 9F 28 1C C9 D0 75 8B 7E
16 : 38 : 13 METER-2 RECEIVED HDLC FRAME
16 : 38 : 13 <====Rx METER-2 7E A0 1C 41 00 02 04 01 96 B8 4E E6 E7 00 D4 0B 20 00 00 02 0B 0E 60 61 E9 FF 7F 72 F1 7E
16 : 38 : 13 <====Rx METER-2 D4 0B 20 00 00 02 0B 0E 60 61 E9 FF 7F
16 : 38 : 13 <====Rx METER-2 D4 0B 20 00 00 02 0B C4 01 81 00 01 00
16 : 38 : 13 ====>Tx METER-2 D0 12 20 00 00 02 0B C0 01 C1 00 28 00 04 19 09 00 FF 05 00
16 : 38 : 13 ====>Tx METER-2 D0 12 20 00 00 02 0B 96 2D 08 5C 33 EE ED AC BA 8C 0B 34 37
16 : 38 : 13 METER-2 SERVICE = GET REQUEST, OBIS = 0-4-25-9-0-255, IC = 40, ATTR: INDEX = 5
16 : 38 : 13 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 02 0B 96 2D 08 5C 33 EE ED AC BA 8C 0B 34 37 AF C6 7E
16 : 38 : 13 <====Rx METER-2 7E A0 1D 41 00 02 04 01 B8 11 19 E6 E7 00 D4 0C 20 00 00 02 0C 5A 58 F9 CF 5F 90 69 DD E4 7E
16 : 38 : 13 <====Rx METER-2 D4 0C 20 00 00 02 0C 5A 58 F9 CF 5F 90 69
16 : 38 : 13 <====Rx METER-2 D4 0C 20 00 00 02 0C C4 01 81 00 12 00 00
16 : 38 : 13 ====>Tx METER-2 D0 12 20 00 00 02 0C C0 01 C1 00 28 00 04 19 09 00 FF 06 00
16 : 38 : 13 ====>Tx METER-2 D0 12 20 00 00 02 0C 35 FF 1B 3F 6F EC 1F 90 59 2D 96 61 79
16 : 38 : 13 METER-2 SERVICE = GET REQUEST, OBIS = 0-4-25-9-0-255, IC = 40, ATTR: INDEX = 6
16 : 38 : 13 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 02 0C 35 FF 1B 3F 6F EC 1F 90 59 2D 96 61 79 A9 DF 7E
16 : 38 : 13 <====Rx METER-2 7E A0 1C 41 00 02 04 01 DA D0 C6 E6 E7 00 D4 0B 20 00 00 02 0D D9 FE AB F7 F7 21 C2 A8 7E
16 : 38 : 13 <====Rx METER-2 D4 0B 20 00 00 02 0D D9 FE AB F7 F7 21
16 : 38 : 13 <====Rx METER-2 D4 0B 20 00 00 02 0D C4 01 81 00 11 03
16 : 38 : 13 ====>Tx METER-2 D0 12 20 00 00 02 0D C0 01 C1 00 28 00 04 19 09 00 FF 07 00
16 : 38 : 13 ====>Tx METER-2 D0 12 20 00 00 02 0D 94 4D 90 7D 1F C4 E3 9C 11 4F 7A 60 D9
16 : 38 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 0-4-25-9-0-255, IC = 40, ATTR: INDEX = 7
16 : 38 : 14 METER-2 SENDING HDLC FRAME
16 : 38 : 14 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 02 0D 94 4D 90 7D 1F C4 E3 9C 11 4F 7A 60 D9 35 D5 7E
16 : 38 : 14 METER-2 RECEIVED HDLC FRAME
16 : 38 : 14 <====Rx METER-2 7E A0 1D 41 00 02 04 01 FC 31 1D E6 E7 00 D4 0C 20 00 00 02 0E E0 47 20 6D B7 3B AC 06 09 7E
16 : 38 : 14 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 14 <====Rx METER-2 D4 0C 20 00 00 02 0E E0 47 20 6D B7 3B AC
16 : 38 : 14 <====Rx METER-2 D4 0C 20 00 00 02 0E C4 01 81 00 12 00 0F
16 : 38 : 14 METER-2 SERVICE = GET RESPONSE
16 : 38 : 14 METER-2 COSEM OUT DATA
16 : 38 : 14 ====>Tx METER-2 D0 12 20 00 00 02 0E C0 01 C1 00 29 00 00 19 00 00 FF 02 00
16 : 38 : 14 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 14 ====>Tx METER-2 D0 12 20 00 00 02 0E E2 3A 14 00 CE 8F D7 FA E7 43 D6 F2 B8
16 : 38 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-0-0-255, IC = 41, ATTR: INDEX = 2
16 : 38 : 14 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 02 0E E2 3A 14 00 CE 8F D7 FA E7 43 D6 F2 B8 3F 8F 7E
16 : 38 : 14 <====Rx METER-2 7E A0 1D 41 00 02 04 01 1E 2D D9 E6 E7 00 D4 0C 20 00 00 02 0F FA B8 48 C3 76 37 0B B2 F6 7E
16 : 38 : 14 <====Rx METER-2 D4 0C 20 00 00 02 0F FA B8 48 C3 76 37 0B
16 : 38 : 14 <====Rx METER-2 D4 0C 20 00 00 02 0F C4 01 81 00 12 0F DB
16 : 38 : 14 ====>Tx METER-2 D0 12 20 00 00 02 0F C0 01 C1 00 29 00 00 19 00 00 FF 03 00
16 : 38 : 14 ====>Tx METER-2 D0 12 20 00 00 02 0F 9C C1 E1 45 0F 14 72 54 91 1F D5 5A 06
16 : 38 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-0-0-255, IC = 41, ATTR: INDEX = 3
16 : 38 : 14 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 02 0F 9C C1 E1 45 0F 14 72 54 91 1F D5 5A 06 68 47 7E
16 : 38 : 14 <====Rx METER-2 7E A0 22 41 00 02 04 01 30 EF DE E6 E7 00 D4 11 20 00 00 02 10 0B 77 2D 2A 23 72 28 E2 66 5F 51 50 77 F0 7E
16 : 38 : 14 <====Rx METER-2 D4 11 20 00 00 02 10 0B 77 2D 2A 23 72 28 E2 66 5F 51 50
16 : 38 : 14 <====Rx METER-2 D4 11 20 00 00 02 10 C4 01 81 00 09 06 00 00 19 07 00 FF
16 : 38 : 14 ====>Tx METER-2 D0 12 20 00 00 02 10 C0 01 C1 00 29 00 00 19 00 00 FF 04 00
16 : 38 : 14 ====>Tx METER-2 D0 12 20 00 00 02 10 F6 86 71 B6 0B F1 31 F8 F0 2D 67 20 6C
16 : 38 : 14 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-0-0-255, IC = 41, ATTR: INDEX = 4
16 : 38 : 14 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 02 10 F6 86 71 B6 0B F1 31 F8 F0 2D 67 20 6C 65 7E 7E
16 : 38 : 14 <====Rx METER-2 7E A0 1D 41 00 02 04 01 52 45 51 E6 E7 00 D4 0C 20 00 00 02 11 53 9E 11 F0 9B 2E 85 E2 30 7E
16 : 38 : 14 <====Rx METER-2 D4 0C 20 00 00 02 11 53 9E 11 F0 9B 2E 85
16 : 38 : 14 <====Rx METER-2 D4 0C 20 00 00 02 11 C4 01 81 00 12 02 40
16 : 38 : 15 METER-2 SERVICE = GET RESPONSE
16 : 38 : 15 METER-2 COSEM OUT DATA
16 : 38 : 15 ====>Tx METER-2 D0 12 20 00 00 02 11 C0 01 C1 00 29 00 00 19 00 00 FF 05 00
16 : 38 : 15 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 15 ====>Tx METER-2 D0 12 20 00 00 02 11 AE E2 27 2A B5 76 EC 46 CC E4 BF 86 AB
16 : 38 : 15 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-0-0-255, IC = 41, ATTR: INDEX = 5
16 : 38 : 15 METER-2 SENDING HDLC FRAME
16 : 38 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 02 11 AE E2 27 2A B5 76 EC 46 CC E4 BF 86 AB E2 8D 7E
16 : 38 : 15 METER-2 RECEIVED HDLC FRAME
16 : 38 : 15 <====Rx METER-2 7E A0 1C 41 00 02 04 01 74 A4 8A E6 E7 00 D4 0B 20 00 00 02 12 F4 70 AB 84 03 BC 15 64 7E
16 : 38 : 15 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 15 <====Rx METER-2 D4 0B 20 00 00 02 12 F4 70 AB 84 03 BC
16 : 38 : 15 <====Rx METER-2 D4 0B 20 00 00 02 12 C4 01 81 00 11 01
16 : 38 : 15 ====>Tx METER-2 D0 12 20 00 00 02 12 C0 01 C1 00 29 00 00 19 00 00 FF 06 00
16 : 38 : 15 ====>Tx METER-2 D0 12 20 00 00 02 12 EA 46 76 E3 F1 DA D8 99 1B 30 9B 9A 6E
16 : 38 : 15 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-0-0-255, IC = 41, ATTR: INDEX = 6
16 : 38 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 02 12 EA 46 76 E3 F1 DA D8 99 1B 30 9B 9A 6E 58 72 7E
16 : 38 : 15 <====Rx METER-2 7E A0 1D 41 00 02 04 01 96 6D D1 E6 E7 00 D4 0C 20 00 00 02 13 BA 0D FD 1A 32 C0 D2 CB E1 7E
16 : 38 : 15 <====Rx METER-2 D4 0C 20 00 00 02 13 BA 0D FD 1A 32 C0 D2
16 : 38 : 15 <====Rx METER-2 D4 0C 20 00 00 02 13 C4 01 81 00 12 00 B4
16 : 38 : 15 ====>Tx METER-2 D0 12 20 00 00 02 13 C0 01 C1 00 2A 00 00 19 01 00 FF 02 00
16 : 38 : 15 ====>Tx METER-2 D0 12 20 00 00 02 13 D3 20 4C CB 8C FB A5 9D 2F 2B 21 BB 04
16 : 38 : 15 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-1-0-255, IC = 42, ATTR: INDEX = 2
16 : 38 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 02 13 D3 20 4C CB 8C FB A5 9D 2F 2B 21 BB 04 C7 FF 7E
16 : 38 : 15 <====Rx METER-2 7E A0 22 41 00 02 04 01 B8 AF D6 E6 E7 00 D4 11 20 00 00 02 14 9D 7C DD 80 37 5B 36 D7 07 C2 63 FD 94 AC 7E
16 : 38 : 15 <====Rx METER-2 D4 11 20 00 00 02 14 9D 7C DD 80 37 5B 36 D7 07 C2 63 FD
16 : 38 : 15 <====Rx METER-2 D4 11 20 00 00 02 14 C4 01 81 00 09 06 00 00 19 02 00 FF
16 : 38 : 15 ====>Tx METER-2 D0 12 20 00 00 02 14 C0 01 C1 00 2A 00 00 19 01 00 FF 03 00
16 : 38 : 15 ====>Tx METER-2 D0 12 20 00 00 02 14 C1 A0 2C BD 1D C4 B9 4F E3 AB C9 EF 47
16 : 38 : 15 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-1-0-255, IC = 42, ATTR: INDEX = 3
16 : 38 : 15 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 02 14 C1 A0 2C BD 1D C4 B9 4F E3 AB C9 EF 47 CB E1 7E
16 : 38 : 15 <====Rx METER-2 7E A0 1F 41 00 02 04 01 DA BE 6E E6 E7 00 D4 0E 20 00 00 02 15 1E B2 4A 3D 04 81 0A F4 2E F5 45 7E
16 : 38 : 16 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 16 <====Rx METER-2 D4 0E 20 00 00 02 15 1E B2 4A 3D 04 81 0A F4 2E
16 : 38 : 16 <====Rx METER-2 D4 0E 20 00 00 02 15 C4 01 81 00 06 00 00 00 00
16 : 38 : 16 METER-2 SERVICE = GET RESPONSE
16 : 38 : 16 METER-2 COSEM OUT DATA
16 : 38 : 16 ====>Tx METER-2 D0 12 20 00 00 02 15 C0 01 C1 00 2A 00 00 19 01 00 FF 04 00
16 : 38 : 16 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 16 ====>Tx METER-2 D0 12 20 00 00 02 15 2A 78 D3 62 7B 25 6D 5D 63 FC 4F 63 5A
16 : 38 : 16 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-1-0-255, IC = 42, ATTR: INDEX = 4
16 : 38 : 16 METER-2 SENDING HDLC FRAME
16 : 38 : 16 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 02 15 2A 78 D3 62 7B 25 6D 5D 63 FC 4F 63 5A E3 D7 7E
16 : 38 : 16 METER-2 RECEIVED HDLC FRAME
16 : 38 : 16 <====Rx METER-2 7E A0 1C 41 00 02 04 01 FC E4 82 E6 E7 00 D4 0B 20 00 00 02 16 92 46 59 75 E9 A2 C2 0E 7E
16 : 38 : 16 <====Rx METER-2 D4 0B 20 00 00 02 16 92 46 59 75 E9 A2
16 : 38 : 16 <====Rx METER-2 D4 0B 20 00 00 02 16 C4 01 81 00 01 00
16 : 38 : 16 ====>Tx METER-2 D0 12 20 00 00 02 16 C0 01 C1 00 2A 00 00 19 01 00 FF 05 00
16 : 38 : 16 ====>Tx METER-2 D0 12 20 00 00 02 16 67 C4 F7 46 D3 BA 14 38 C2 91 27 85 D1
16 : 38 : 16 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-1-0-255, IC = 42, ATTR: INDEX = 5
16 : 38 : 16 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 02 16 67 C4 F7 46 D3 BA 14 38 C2 91 27 85 D1 80 2F 7E
16 : 38 : 16 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 02 17 92 97 00 AF 7F 19 B1 F3 7E
16 : 38 : 16 <====Rx METER-2 D4 0B 20 00 00 02 17 92 97 00 AF 7F 19
16 : 38 : 16 <====Rx METER-2 D4 0B 20 00 00 02 17 C4 01 81 00 01 00
16 : 38 : 16 ====>Tx METER-2 D0 12 20 00 00 02 17 C0 01 C1 00 2A 00 00 19 01 00 FF 06 00
16 : 38 : 16 ====>Tx METER-2 D0 12 20 00 00 02 17 FE 5E BA BF 42 6B 55 C9 87 C9 8D 38 0B
16 : 38 : 16 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-1-0-255, IC = 42, ATTR: INDEX = 6
16 : 38 : 16 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 02 17 FE 5E BA BF 42 6B 55 C9 87 C9 8D 38 0B 78 22 7E
16 : 38 : 16 <====Rx METER-2 7E A0 1F 41 00 02 04 01 30 EA 26 E6 E7 00 D4 0E 20 00 00 02 18 33 2B 63 35 CA 54 12 6D 66 49 8A 7E
16 : 38 : 16 <====Rx METER-2 D4 0E 20 00 00 02 18 33 2B 63 35 CA 54 12 6D 66
16 : 38 : 16 <====Rx METER-2 D4 0E 20 00 00 02 18 C4 01 81 00 06 00 00 00 00
16 : 38 : 16 ====>Tx METER-2 D0 12 20 00 00 02 18 C0 01 C1 00 2A 00 00 19 01 00 FF 07 00
16 : 38 : 16 ====>Tx METER-2 D0 12 20 00 00 02 18 6D 98 EA DD 7C ED 25 AF DF F1 0C 80 D4
16 : 38 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-1-0-255, IC = 42, ATTR: INDEX = 7
16 : 38 : 17 METER-2 SENDING HDLC FRAME
16 : 38 : 17 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 02 18 6D 98 EA DD 7C ED 25 AF DF F1 0C 80 D4 14 49 7E
16 : 38 : 17 METER-2 RECEIVED HDLC FRAME
16 : 38 : 17 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 02 19 43 1C 51 F4 9E 48 87 F2 91 09 7E 7E
16 : 38 : 17 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 17 <====Rx METER-2 D4 0E 20 00 00 02 19 43 1C 51 F4 9E 48 87 F2 91
16 : 38 : 17 <====Rx METER-2 D4 0E 20 00 00 02 19 C4 01 81 00 06 00 00 00 00
16 : 38 : 17 METER-2 SERVICE = GET RESPONSE
16 : 38 : 17 METER-2 COSEM OUT DATA
16 : 38 : 17 ====>Tx METER-2 D0 12 20 00 00 02 19 C0 01 C1 00 2A 00 00 19 01 00 FF 08 00
16 : 38 : 17 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 17 ====>Tx METER-2 D0 12 20 00 00 02 19 F7 8A C3 B5 4D 83 CC D9 8D F3 DC 60 CD
16 : 38 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-1-0-255, IC = 42, ATTR: INDEX = 8
16 : 38 : 17 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 02 19 F7 8A C3 B5 4D 83 CC D9 8D F3 DC 60 CD C7 AC 7E
16 : 38 : 17 <====Rx METER-2 7E A0 1C 41 00 02 04 01 74 A4 8A E6 E7 00 D4 0B 20 00 00 02 1A 40 10 F9 54 DC 5F 9D A3 7E
16 : 38 : 17 <====Rx METER-2 D4 0B 20 00 00 02 1A 40 10 F9 54 DC 5F
16 : 38 : 17 <====Rx METER-2 D4 0B 20 00 00 02 1A C4 01 81 00 03 00
16 : 38 : 17 ====>Tx METER-2 D0 12 20 00 00 02 1A C0 01 C1 00 2A 00 00 19 01 00 FF 09 00
16 : 38 : 17 ====>Tx METER-2 D0 12 20 00 00 02 1A C9 4D F5 25 96 8A 63 BB 94 0C 4D FC 70
16 : 38 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-1-0-255, IC = 42, ATTR: INDEX = 9
16 : 38 : 17 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 02 1A C9 4D F5 25 96 8A 63 BB 94 0C 4D FC 70 88 1B 7E
16 : 38 : 17 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 02 1B BC 2B A4 AD 62 67 D9 5F F1 55 D3 7E
16 : 38 : 17 <====Rx METER-2 D4 0E 20 00 00 02 1B BC 2B A4 AD 62 67 D9 5F F1
16 : 38 : 17 <====Rx METER-2 D4 0E 20 00 00 02 1B C4 01 81 00 06 00 00 00 00
16 : 38 : 17 ====>Tx METER-2 D0 12 20 00 00 02 1B C0 01 C1 00 2A 00 00 19 01 00 FF 0A 00
16 : 38 : 17 ====>Tx METER-2 D0 12 20 00 00 02 1B 18 D7 1E AF 71 8C 05 5C A3 3F 1B BB 5B
16 : 38 : 17 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-1-0-255, IC = 42, ATTR: INDEX = 10
16 : 38 : 17 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 02 1B 18 D7 1E AF 71 8C 05 5C A3 3F 1B BB 5B 5C 4F 7E
16 : 38 : 17 <====Rx METER-2 7E A0 1F 41 00 02 04 01 B8 AA 2E E6 E7 00 D4 0E 20 00 00 02 1C 11 75 8D BE 01 63 72 00 43 2B 65 7E
16 : 38 : 17 <====Rx METER-2 D4 0E 20 00 00 02 1C 11 75 8D BE 01 63 72 00 43
16 : 38 : 17 <====Rx METER-2 D4 0E 20 00 00 02 1C C4 01 81 00 06 00 00 00 00
16 : 38 : 18 METER-2 COSEM OUT DATA
16 : 38 : 18 ====>Tx METER-2 D0 12 20 00 00 02 1C C0 01 C1 00 30 00 00 19 07 00 FF 02 00
16 : 38 : 18 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 18 ====>Tx METER-2 D0 12 20 00 00 02 1C 7F 00 CE 8F B4 78 87 18 A8 2A B9 DB 5A
16 : 38 : 18 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-7-0-255, IC = 48, ATTR: INDEX = 2
16 : 38 : 18 METER-2 SENDING HDLC FRAME
16 : 38 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 02 1C 7F 00 CE 8F B4 78 87 18 A8 2A B9 DB 5A FC 9F 7E
16 : 38 : 18 METER-2 RECEIVED HDLC FRAME
16 : 38 : 18 <====Rx METER-2 7E A0 22 41 00 02 04 01 DA BB 96 E6 E7 00 D4 11 20 00 00 02 1D 1A A5 4D 1C 28 3F 81 82 AD 5B C9 42 0A BC 7E
16 : 38 : 18 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 18 <====Rx METER-2 D4 11 20 00 00 02 1D 1A A5 4D 1C 28 3F 81 82 AD 5B C9 42
16 : 38 : 18 <====Rx METER-2 D4 11 20 00 00 02 1D C4 01 81 00 09 06 00 00 19 02 00 FF
16 : 38 : 18 METER-2 SERVICE = GET RESPONSE
16 : 38 : 18 ====>Tx METER-2 D0 12 20 00 00 02 1D C0 01 C1 00 30 00 00 19 07 00 FF 03 00
16 : 38 : 18 ====>Tx METER-2 D0 12 20 00 00 02 1D 8E 18 8D 73 91 CE DC 17 23 E4 11 EA 79
16 : 38 : 18 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-7-0-255, IC = 48, ATTR: INDEX = 3
16 : 38 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 02 1D 8E 18 8D 73 91 CE DC 17 23 E4 11 EA 79 8F 7C 7E
16 : 38 : 18 <====Rx METER-2 7E A0 1C 41 00 02 04 01 FC E4 82 E6 E7 00 D4 0B 20 00 00 02 1E 6B 39 E9 26 26 73 8C C9 7E
16 : 38 : 18 <====Rx METER-2 D4 0B 20 00 00 02 1E 6B 39 E9 26 26 73
16 : 38 : 18 <====Rx METER-2 D4 0B 20 00 00 02 1E C4 01 81 00 16 00
16 : 38 : 18 ====>Tx METER-2 D0 12 20 00 00 02 1E C0 01 C1 00 30 00 00 19 07 00 FF 04 00
16 : 38 : 18 ====>Tx METER-2 D0 12 20 00 00 02 1E 7A 4C 9A C1 5D A9 29 27 BF A1 3D E8 F2
16 : 38 : 18 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-7-0-255, IC = 48, ATTR: INDEX = 4
16 : 38 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 02 1E 7A 4C 9A C1 5D A9 29 27 BF A1 3D E8 F2 34 A2 7E
16 : 38 : 18 <====Rx METER-2 7E A0 2E 41 00 02 04 01 1E 09 A7 E6 E7 00 D4 1D 20 00 00 02 1F 2D 7F AF 9B C3 45 5A 8F 9A 76 40 0E 9F B2 D2 E3 A2 70 66
4D 34 AD 4D 73 13 EE 7E
16 : 38 : 18 <====Rx METER-2 D4 1D 20 00 00 02 1F 2D 7F AF 9B C3 45 5A 8F 9A 76 40 0E 9F B2 D2 E3 A2 70 66 4D 34 AD 4D 73
16 : 38 : 18 <====Rx METER-2 D4 1D 20 00 00 02 1F C4 01 81 00 01 01 09 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
16 : 38 : 18 ====>Tx METER-2 D0 12 20 00 00 02 1F C0 01 C1 00 30 00 00 19 07 00 FF 05 00
16 : 38 : 18 ====>Tx METER-2 D0 12 20 00 00 02 1F B6 AF 24 B1 06 60 F5 00 7A E4 89 3E 94
16 : 38 : 18 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-7-0-255, IC = 48, ATTR: INDEX = 5
16 : 38 : 18 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 02 1F B6 AF 24 B1 06 60 F5 00 7A E4 89 3E 94 72 EF 7E
16 : 38 : 18 <====Rx METER-2 7E A0 2E 41 00 02 04 01 30 75 6F E6 E7 00 D4 1D 20 00 00 02 20 29 29 FE 83 6E 23 45 16 49 C4 A9 02 C1 2E C7 33 DD D7 5F
E9 FF 57 18 5C 86 18 7E
16 : 38 : 19 <====Rx METER-2 D4 1D 20 00 00 02 20 29 29 FE 83 6E 23 45 16 49 C4 A9 02 C1 2E C7 33 DD D7 5F E9 FF 57 18 5C
16 : 38 : 19 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 38 : 19 <====Rx METER-2 D4 1D 20 00 00 02 20 C4 01 81 00 01 01 09 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
16 : 38 : 19 METER-2 SERVICE = GET RESPONSE
16 : 38 : 19 METER-2 COSEM OUT DATA
16 : 38 : 19 ====>Tx METER-2 D0 12 20 00 00 02 20 C0 01 C1 00 30 00 00 19 07 00 FF 06 00
16 : 38 : 19 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 19 ====>Tx METER-2 D0 12 20 00 00 02 20 EB A8 2C 72 B6 DC D8 30 04 EC 20 DC D8
16 : 38 : 19 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-7-0-255, IC = 48, ATTR: INDEX = 6
16 : 38 : 19 METER-2 SENDING HDLC FRAME
16 : 38 : 19 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 02 20 EB A8 2C 72 B6 DC D8 30 04 EC 20 DC D8 AD B6 7E
16 : 38 : 19 METER-2 RECEIVED HDLC FRAME
16 : 38 : 19 <====Rx METER-2 7E A0 2E 41 00 02 04 01 52 61 2F E6 E7 00 D4 1D 20 00 00 02 21 38 05 A5 6B BF 0A 11 2C FB 66 72 C5 03 D2 B5 69 4E D6 9C
17 A6 66 3F 92 1F F3 7E
16 : 38 : 19 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 19 <====Rx METER-2 D4 1D 20 00 00 02 21 38 05 A5 6B BF 0A 11 2C FB 66 72 C5 03 D2 B5 69 4E D6 9C 17 A6 66 3F 92
16 : 38 : 19 <====Rx METER-2 D4 1D 20 00 00 02 21 C4 01 81 00 01 01 09 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
16 : 38 : 19 ====>Tx METER-2 D0 12 20 00 00 02 21 C0 01 C1 00 30 00 00 19 07 00 FF 07 00
16 : 38 : 19 ====>Tx METER-2 D0 12 20 00 00 02 21 61 B0 FD A1 E7 B1 A9 4C CE B1 4A BA A6
16 : 38 : 19 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-7-0-255, IC = 48, ATTR: INDEX = 7
16 : 38 : 19 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 02 21 61 B0 FD A1 E7 B1 A9 4C CE B1 4A BA A6 28 DA 7E
16 : 38 : 19 <====Rx METER-2 7E A0 2C 41 00 02 04 01 74 EE 5C E6 E7 00 D4 1B 20 00 00 02 22 C9 97 CA CB 9B 68 EB A3 89 E9 C6 D0 15 37 32 D1 F2 31 C8
65 43 D8 63 01 7E
16 : 38 : 19 <====Rx METER-2 D4 1B 20 00 00 02 22 C9 97 CA CB 9B 68 EB A3 89 E9 C6 D0 15 37 32 D1 F2 31 C8 65 43 D8
16 : 38 : 19 <====Rx METER-2 D4 1B 20 00 00 02 22 C4 01 81 00 09 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
16 : 38 : 19 ====>Tx METER-2 D0 12 20 00 00 02 22 C0 01 C1 00 30 00 00 19 07 00 FF 08 00
16 : 38 : 19 ====>Tx METER-2 D0 12 20 00 00 02 22 AC 7A BE 35 5E D7 43 2A 48 21 DC D8 16
16 : 38 : 19 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-7-0-255, IC = 48, ATTR: INDEX = 8
16 : 38 : 19 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 02 22 AC 7A BE 35 5E D7 43 2A 48 21 DC D8 16 58 47 7E
16 : 38 : 19 <====Rx METER-2 7E A0 2C 41 00 02 04 01 96 F2 98 E6 E7 00 D4 1B 20 00 00 02 23 29 59 59 2A DD 08 22 1B F6 0D B8 29 37 C7 8D B5 0E 39 FC
77 E7 06 44 B5 7E
16 : 38 : 19 <====Rx METER-2 D4 1B 20 00 00 02 23 29 59 59 2A DD 08 22 1B F6 0D B8 29 37 C7 8D B5 0E 39 FC 77 E7 06
16 : 38 : 19 <====Rx METER-2 D4 1B 20 00 00 02 23 C4 01 81 00 09 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
16 : 38 : 19 ====>Tx METER-2 D0 12 20 00 00 02 23 C0 01 C1 00 30 00 00 19 07 00 FF 09 00
16 : 38 : 19 ====>Tx METER-2 D0 12 20 00 00 02 23 AB 69 2F A4 A8 C9 F6 23 CF EE 8E 78 94
16 : 38 : 19 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-7-0-255, IC = 48, ATTR: INDEX = 9
16 : 38 : 20 METER-2 SENDING HDLC FRAME
16 : 38 : 20 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 02 23 AB 69 2F A4 A8 C9 F6 23 CF EE 8E 78 94 68 34 7E
16 : 38 : 20 METER-2 RECEIVED HDLC FRAME
16 : 38 : 20 <====Rx METER-2 7E A0 1C 41 00 02 04 01 B8 C4 86 E6 E7 00 D4 0B 20 00 00 02 24 12 F2 1C 7B DD A1 A7 12 7E
16 : 38 : 20 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 20 <====Rx METER-2 D4 0B 20 00 00 02 24 12 F2 1C 7B DD A1
16 : 38 : 20 <====Rx METER-2 D4 0B 20 00 00 02 24 C4 01 81 00 11 00
16 : 38 : 20 METER-2 SERVICE = GET RESPONSE
16 : 38 : 20 METER-2 COSEM OUT DATA
16 : 38 : 20 ====>Tx METER-2 D0 12 20 00 00 02 24 C0 01 C1 00 30 00 00 19 07 00 FF 0A 00
16 : 38 : 20 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 20 ====>Tx METER-2 D0 12 20 00 00 02 24 41 60 12 D0 9A 9A 6A E8 7A C5 9B 79 7B
16 : 38 : 20 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-25-7-0-255, IC = 48, ATTR: INDEX = 10
16 : 38 : 20 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 02 24 41 60 12 D0 9A 9A 6A E8 7A C5 9B 79 7B 1F 44 7E
16 : 38 : 20 <====Rx METER-2 7E A0 28 41 00 02 04 01 DA EC 7F E6 E7 00 D4 17 20 00 00 02 25 AC 85 62 3E 6F 49 EC BC 19 17 22 D6 8B D3 13 2F 97 02 F0
57 7E
16 : 38 : 20 <====Rx METER-2 D4 17 20 00 00 02 25 AC 85 62 3E 6F 49 EC BC 19 17 22 D6 8B D3 13 2F 97 02
16 : 38 : 20 <====Rx METER-2 D4 17 20 00 00 02 25 C4 01 81 00 01 01 02 03 11 03 12 27 10 06 00 01 51 80
16 : 38 : 20 ====>Tx METER-2 D0 12 20 00 00 02 25 C0 01 C1 00 40 00 00 2B 00 02 FF 02 00
16 : 38 : 20 ====>Tx METER-2 D0 12 20 00 00 02 25 76 E0 5E DA 88 C6 60 26 99 AA 76 DE 2C
16 : 38 : 20 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-2-255, IC = 64, ATTR: INDEX = 2
16 : 38 : 20 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 02 25 76 E0 5E DA 88 C6 60 26 99 AA 76 DE 2C BC E4 7E
16 : 38 : 20 <====Rx METER-2 7E A0 1C 41 00 02 04 01 FC E4 82 E6 E7 00 D4 0B 20 00 00 02 26 60 1A 20 46 67 69 C0 B6 7E
16 : 38 : 20 <====Rx METER-2 D4 0B 20 00 00 02 26 60 1A 20 46 67 69
16 : 38 : 20 <====Rx METER-2 D4 0B 20 00 00 02 26 C4 01 81 00 16 02
16 : 38 : 20 ====>Tx METER-2 D0 12 20 00 00 02 26 C0 01 C1 00 40 00 00 2B 00 02 FF 03 00
16 : 38 : 20 ====>Tx METER-2 D0 12 20 00 00 02 26 AD A5 E8 AB 44 69 E7 58 44 50 9F 22 47
16 : 38 : 20 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-2-255, IC = 64, ATTR: INDEX = 3
16 : 38 : 20 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 02 26 AD A5 E8 AB 44 69 E7 58 44 50 9F 22 47 FC 3D 7E
16 : 38 : 20 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 02 27 F5 FE 1D 28 5F 75 D2 0C 7E
16 : 38 : 20 <====Rx METER-2 D4 0B 20 00 00 02 27 F5 FE 1D 28 5F 75
16 : 38 : 20 <====Rx METER-2 D4 0B 20 00 00 02 27 C4 01 81 00 16 00
16 : 38 : 21 METER-2 COSEM OUT DATA
16 : 38 : 21 ====>Tx METER-2 D0 12 20 00 00 02 27 C0 01 C1 00 40 00 00 2B 00 02 FF 04 00
16 : 38 : 21 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 21 ====>Tx METER-2 D0 12 20 00 00 02 27 6C D7 74 07 01 51 52 C5 B3 FA 4B C0 88
16 : 38 : 21 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-2-255, IC = 64, ATTR: INDEX = 4
16 : 38 : 21 METER-2 SENDING HDLC FRAME
16 : 38 : 21 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 02 27 6C D7 74 07 01 51 52 C5 B3 FA 4B C0 88 8F 01 7E
16 : 38 : 21 METER-2 RECEIVED HDLC FRAME
16 : 38 : 21 <====Rx METER-2 7E A0 24 41 00 02 04 01 30 22 86 E6 E7 00 D4 13 20 00 00 02 28 32 E6 4C 4D 41 6B 52 8C 22 E6 44 1A 04 9D 62 49 7E
16 : 38 : 21 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 21 <====Rx METER-2 D4 13 20 00 00 02 28 32 E6 4C 4D 41 6B 52 8C 22 E6 44 1A 04 9D
16 : 38 : 21 <====Rx METER-2 D4 13 20 00 00 02 28 C4 01 81 00 09 08 5A 45 4E 31 32 33 34 35
16 : 38 : 21 METER-2 SERVICE = GET RESPONSE
16 : 38 : 21 ====>Tx METER-2 D0 12 20 00 00 02 28 C0 01 C1 00 40 00 00 2B 00 02 FF 05 00
16 : 38 : 21 ====>Tx METER-2 D0 12 20 00 00 02 28 E9 38 0F 79 DE 2D 48 E5 B1 C4 92 4D CB
16 : 38 : 21 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-2-255, IC = 64, ATTR: INDEX = 5
16 : 38 : 21 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 02 28 E9 38 0F 79 DE 2D 48 E5 B1 C4 92 4D CB EF 29 7E
16 : 38 : 21 <====Rx METER-2 7E A0 24 41 00 02 04 01 52 36 C6 E6 E7 00 D4 13 20 00 00 02 29 96 DA 4E F9 7F C2 90 97 8B 0D C9 24 C5 4B D2 59 7E
16 : 38 : 21 <====Rx METER-2 D4 13 20 00 00 02 29 96 DA 4E F9 7F C2 90 97 8B 0D C9 24 C5 4B
16 : 38 : 21 <====Rx METER-2 D4 13 20 00 00 02 29 C4 01 81 00 09 08 5A 45 4E 30 30 30 31 30
16 : 38 : 21 ====>Tx METER-2 D0 12 20 00 00 02 29 C0 01 C1 00 40 00 00 2B 00 03 FF 02 00
16 : 38 : 21 ====>Tx METER-2 D0 12 20 00 00 02 29 B2 53 B9 F8 F7 C5 D4 7C 3A 3E BC 8C AB
16 : 38 : 21 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-3-255, IC = 64, ATTR: INDEX = 2
16 : 38 : 21 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 02 29 B2 53 B9 F8 F7 C5 D4 7C 3A 3E BC 8C AB AD 13 7E
16 : 38 : 21 <====Rx METER-2 7E A0 1C 41 00 02 04 01 74 A4 8A E6 E7 00 D4 0B 20 00 00 02 2A F5 C1 89 CF EC 0E 65 58 7E
16 : 38 : 21 <====Rx METER-2 D4 0B 20 00 00 02 2A F5 C1 89 CF EC 0E
16 : 38 : 21 <====Rx METER-2 D4 0B 20 00 00 02 2A C4 01 81 00 16 03
16 : 38 : 22 METER-2 COSEM OUT DATA
16 : 38 : 22 ====>Tx METER-2 D0 12 20 00 00 02 2A C0 01 C1 00 40 00 00 2B 00 03 FF 03 00
16 : 38 : 22 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 22 ====>Tx METER-2 D0 12 20 00 00 02 2A 8F D8 71 F0 18 CB B9 83 66 DF 34 AA 46
16 : 38 : 22 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-3-255, IC = 64, ATTR: INDEX = 3
16 : 38 : 22 METER-2 SENDING HDLC FRAME
16 : 38 : 22 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 02 2A 8F D8 71 F0 18 CB B9 83 66 DF 34 AA 46 C0 C7 7E
16 : 38 : 22 METER-2 RECEIVED HDLC FRAME
16 : 38 : 22 <====Rx METER-2 7E A0 1C 41 00 02 04 01 96 B8 4E E6 E7 00 D4 0B 20 00 00 02 2B CA AC B8 BD 13 4C D1 1B 7E
16 : 38 : 22 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 22 <====Rx METER-2 D4 0B 20 00 00 02 2B CA AC B8 BD 13 4C
16 : 38 : 22 <====Rx METER-2 D4 0B 20 00 00 02 2B C4 01 81 00 16 00
16 : 38 : 22 METER-2 SERVICE = GET RESPONSE
16 : 38 : 22 ====>Tx METER-2 D0 12 20 00 00 02 2B C0 01 C1 00 40 00 00 2B 00 03 FF 04 00
16 : 38 : 22 ====>Tx METER-2 D0 12 20 00 00 02 2B 54 42 03 BA CB 09 BE D5 F9 A3 D4 B2 0F
16 : 38 : 22 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-3-255, IC = 64, ATTR: INDEX = 4
16 : 38 : 22 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 02 2B 54 42 03 BA CB 09 BE D5 F9 A3 D4 B2 0F 58 66 7E
16 : 38 : 22 <====Rx METER-2 7E A0 24 41 00 02 04 01 B8 62 8E E6 E7 00 D4 13 20 00 00 02 2C 80 59 D5 95 83 D7 25 A1 14 85 52 9D 1D 98 9E D3 7E
16 : 38 : 22 <====Rx METER-2 D4 13 20 00 00 02 2C 80 59 D5 95 83 D7 25 A1 14 85 52 9D 1D 98
16 : 38 : 22 <====Rx METER-2 D4 13 20 00 00 02 2C C4 01 81 00 09 08 5A 45 4E 31 32 33 34 35
16 : 38 : 22 ====>Tx METER-2 D0 12 20 00 00 02 2C C0 01 C1 00 40 00 00 2B 00 03 FF 05 00
16 : 38 : 22 ====>Tx METER-2 D0 12 20 00 00 02 2C F1 AB 49 AF 16 70 21 0A 13 DB 82 88 D8
16 : 38 : 22 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-3-255, IC = 64, ATTR: INDEX = 5
16 : 38 : 22 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 02 2C F1 AB 49 AF 16 70 21 0A 13 DB 82 88 D8 E2 7D 7E
16 : 38 : 22 <====Rx METER-2 7E A0 24 41 00 02 04 01 DA 76 CE E6 E7 00 D4 13 20 00 00 02 2D B7 1F C1 F3 23 C9 9D D7 2A 31 38 CB 64 49 A9 39 7E
16 : 38 : 22 <====Rx METER-2 D4 13 20 00 00 02 2D B7 1F C1 F3 23 C9 9D D7 2A 31 38 CB 64 49
16 : 38 : 22 <====Rx METER-2 D4 13 20 00 00 02 2D C4 01 81 00 09 08 5A 45 4E 30 30 30 31 30
16 : 38 : 22 ====>Tx METER-2 D0 12 20 00 00 02 2D C0 01 C1 00 40 00 00 2B 00 04 FF 02 00
16 : 38 : 22 ====>Tx METER-2 D0 12 20 00 00 02 2D 4E DB 31 D9 EB F6 55 9A 51 06 C2 B4 2C
16 : 38 : 22 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-4-255, IC = 64, ATTR: INDEX = 2
16 : 38 : 23 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 02 2D 4E DB 31 D9 EB F6 55 9A 51 06 C2 B4 2C E5 97 7E
16 : 38 : 23 METER-2 RECEIVED HDLC FRAME
16 : 38 : 23 <====Rx METER-2 7E A0 1C 41 00 02 04 01 FC E4 82 E6 E7 00 D4 0B 20 00 00 02 2E FF 05 22 09 2E 9B 2F FC 7E
16 : 38 : 23 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 23 <====Rx METER-2 D4 0B 20 00 00 02 2E FF 05 22 09 2E 9B
16 : 38 : 23 <====Rx METER-2 D4 0B 20 00 00 02 2E C4 01 81 00 16 03
16 : 38 : 23 METER-2 SERVICE = GET RESPONSE
16 : 38 : 23 METER-2 COSEM OUT DATA
16 : 38 : 23 ====>Tx METER-2 D0 12 20 00 00 02 2E C0 01 C1 00 40 00 00 2B 00 04 FF 03 00
16 : 38 : 23 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 23 ====>Tx METER-2 D0 12 20 00 00 02 2E 7A 17 04 67 C8 25 7E F4 21 70 84 98 C1
16 : 38 : 23 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-4-255, IC = 64, ATTR: INDEX = 3
16 : 38 : 23 METER-2 SENDING HDLC FRAME
16 : 38 : 23 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 02 2E 7A 17 04 67 C8 25 7E F4 21 70 84 98 C1 A8 49 7E
16 : 38 : 23 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 02 2F C7 71 5A 5D 74 55 7B E3 7E
16 : 38 : 23 <====Rx METER-2 D4 0B 20 00 00 02 2F C7 71 5A 5D 74 55
16 : 38 : 23 <====Rx METER-2 D4 0B 20 00 00 02 2F C4 01 81 00 16 00
16 : 38 : 23 ====>Tx METER-2 D0 12 20 00 00 02 2F C0 01 C1 00 40 00 00 2B 00 04 FF 04 00
16 : 38 : 23 ====>Tx METER-2 D0 12 20 00 00 02 2F FC 89 4A 0A 4D 48 AA D1 CE B9 79 0B B5
16 : 38 : 23 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-4-255, IC = 64, ATTR: INDEX = 4
16 : 38 : 23 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 02 2F FC 89 4A 0A 4D 48 AA D1 CE B9 79 0B B5 9E F5 7E
16 : 38 : 23 <====Rx METER-2 7E A0 24 41 00 02 04 01 30 22 86 E6 E7 00 D4 13 20 00 00 02 30 EF 03 B4 C4 83 1D 0F 3C B5 B2 23 B3 33 D9 CA EA 7E
16 : 38 : 23 <====Rx METER-2 D4 13 20 00 00 02 30 EF 03 B4 C4 83 1D 0F 3C B5 B2 23 B3 33 D9
16 : 38 : 23 <====Rx METER-2 D4 13 20 00 00 02 30 C4 01 81 00 09 08 5A 45 4E 30 30 30 31 30
16 : 38 : 23 ====>Tx METER-2 D0 12 20 00 00 02 30 C0 01 C1 00 40 00 00 2B 00 04 FF 05 00
16 : 38 : 23 ====>Tx METER-2 D0 12 20 00 00 02 30 C9 B1 17 F8 FE 7D ED CF BA 7C E7 96 C8
16 : 38 : 23 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-4-255, IC = 64, ATTR: INDEX = 5
16 : 38 : 23 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 02 30 C9 B1 17 F8 FE 7D ED CF BA 7C E7 96 C8 9A 44 7E
16 : 38 : 23 <====Rx METER-2 7E A0 24 41 00 02 04 01 52 36 C6 E6 E7 00 D4 13 20 00 00 02 31 E4 50 BF 29 86 31 5F 11 C8 FC 66 E1 EC 1A 40 10 7E
16 : 38 : 23 <====Rx METER-2 D4 13 20 00 00 02 31 E4 50 BF 29 86 31 5F 11 C8 FC 66 E1 EC 1A
16 : 38 : 23 <====Rx METER-2 D4 13 20 00 00 02 31 C4 01 81 00 09 08 5A 45 4E 30 30 30 31 30
16 : 38 : 24 ====>Tx METER-2 D0 12 20 00 00 02 31 C0 01 C1 00 40 00 00 2B 00 05 FF 02 00
16 : 38 : 24 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 24 ====>Tx METER-2 D0 12 20 00 00 02 31 76 34 5B F8 65 6F 22 1C DB E2 D1 98 45
16 : 38 : 24 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-5-255, IC = 64, ATTR: INDEX = 2
16 : 38 : 24 METER-2 SENDING HDLC FRAME
16 : 38 : 24 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 02 31 76 34 5B F8 65 6F 22 1C DB E2 D1 98 45 A8 8B 7E
16 : 38 : 24 METER-2 RECEIVED HDLC FRAME
16 : 38 : 24 <====Rx METER-2 7E A0 1C 41 00 02 04 01 74 A4 8A E6 E7 00 D4 0B 20 00 00 02 32 EF 7E 0D 2C 9B AB AA 9A 7E
16 : 38 : 24 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 24 <====Rx METER-2 D4 0B 20 00 00 02 32 EF 7E 0D 2C 9B AB
16 : 38 : 24 <====Rx METER-2 D4 0B 20 00 00 02 32 C4 01 81 00 16 03
16 : 38 : 24 METER-2 SERVICE = GET RESPONSE
16 : 38 : 24 ====>Tx METER-2 D0 12 20 00 00 02 32 C0 01 C1 00 40 00 00 2B 00 05 FF 03 00
16 : 38 : 24 ====>Tx METER-2 D0 12 20 00 00 02 32 1B C0 A4 D7 E1 0B 25 3F A9 30 B1 BA A1
16 : 38 : 24 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-5-255, IC = 64, ATTR: INDEX = 3
16 : 38 : 24 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 02 32 1B C0 A4 D7 E1 0B 25 3F A9 30 B1 BA A1 25 F5 7E
16 : 38 : 24 <====Rx METER-2 7E A0 1C 41 00 02 04 01 96 B8 4E E6 E7 00 D4 0B 20 00 00 02 33 27 26 B1 26 0C 26 7C 82 7E
16 : 38 : 24 <====Rx METER-2 D4 0B 20 00 00 02 33 27 26 B1 26 0C 26
16 : 38 : 24 <====Rx METER-2 D4 0B 20 00 00 02 33 C4 01 81 00 16 00
16 : 38 : 24 ====>Tx METER-2 D0 12 20 00 00 02 33 C0 01 C1 00 40 00 00 2B 00 05 FF 04 00
16 : 38 : 24 ====>Tx METER-2 D0 12 20 00 00 02 33 03 74 88 8A D5 6C B7 54 2B 86 8E 14 CB
16 : 38 : 24 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-5-255, IC = 64, ATTR: INDEX = 4
16 : 38 : 24 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 02 33 03 74 88 8A D5 6C B7 54 2B 86 8E 14 CB DA 4A 7E
16 : 38 : 24 <====Rx METER-2 7E A0 24 41 00 02 04 01 B8 62 8E E6 E7 00 D4 13 20 00 00 02 34 35 06 A0 34 FF BE 46 61 87 C7 ED 28 41 3F 5F 02 7E
16 : 38 : 24 <====Rx METER-2 D4 13 20 00 00 02 34 35 06 A0 34 FF BE 46 61 87 C7 ED 28 41 3F
16 : 38 : 24 <====Rx METER-2 D4 13 20 00 00 02 34 C4 01 81 00 09 08 5A 45 4E 31 32 33 34 35
16 : 38 : 24 ====>Tx METER-2 D0 12 20 00 00 02 34 C0 01 C1 00 40 00 00 2B 00 05 FF 05 00
16 : 38 : 24 ====>Tx METER-2 D0 12 20 00 00 02 34 6D 09 40 BA B1 AC 3B 31 33 F0 A2 3E 44
16 : 38 : 24 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-5-255, IC = 64, ATTR: INDEX = 5
16 : 38 : 24 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 02 34 6D 09 40 BA B1 AC 3B 31 33 F0 A2 3E 44 38 7D 7E
16 : 38 : 24 <====Rx METER-2 7E A0 24 41 00 02 04 01 DA 76 CE E6 E7 00 D4 13 20 00 00 02 35 E0 32 03 F4 8F 59 A9 83 DD A3 5F 3F 44 D2 60 29 7E
16 : 38 : 25 <====Rx METER-2 D4 13 20 00 00 02 35 E0 32 03 F4 8F 59 A9 83 DD A3 5F 3F 44 D2
16 : 38 : 25 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 38 : 25 <====Rx METER-2 D4 13 20 00 00 02 35 C4 01 81 00 09 08 5A 45 4E 30 30 30 31 30
16 : 38 : 25 METER-2 SERVICE = GET RESPONSE
16 : 38 : 25 METER-2 COSEM OUT DATA
16 : 38 : 25 ====>Tx METER-2 D0 12 20 00 00 02 35 C0 01 C1 00 40 00 00 2B 00 06 FF 02 00
16 : 38 : 25 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 25 ====>Tx METER-2 D0 12 20 00 00 02 35 CF C2 48 DA 2E 90 04 8A C6 86 D1 FA 1A
16 : 38 : 25 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-6-255, IC = 64, ATTR: INDEX = 2
16 : 38 : 25 METER-2 SENDING HDLC FRAME
16 : 38 : 25 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 02 35 CF C2 48 DA 2E 90 04 8A C6 86 D1 FA 1A 84 C4 7E
16 : 38 : 25 METER-2 RECEIVED HDLC FRAME
16 : 38 : 25 <====Rx METER-2 7E A0 1C 41 00 02 04 01 FC E4 82 E6 E7 00 D4 0B 20 00 00 02 36 21 90 23 E0 45 3F FD 18 7E
16 : 38 : 25 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 25 <====Rx METER-2 D4 0B 20 00 00 02 36 21 90 23 E0 45 3F
16 : 38 : 25 <====Rx METER-2 D4 0B 20 00 00 02 36 C4 01 81 00 16 02
16 : 38 : 25 ====>Tx METER-2 D0 12 20 00 00 02 36 C0 01 C1 00 40 00 00 2B 00 06 FF 03 00
16 : 38 : 25 ====>Tx METER-2 D0 12 20 00 00 02 36 A4 9E 73 75 58 59 97 D1 A2 7A 75 8A B1
16 : 38 : 25 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-6-255, IC = 64, ATTR: INDEX = 3
16 : 38 : 25 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 02 36 A4 9E 73 75 58 59 97 D1 A2 7A 75 8A B1 97 D8 7E
16 : 38 : 25 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 02 37 07 1F 93 CA 6A BE BC DE 7E
16 : 38 : 25 <====Rx METER-2 D4 0B 20 00 00 02 37 07 1F 93 CA 6A BE
16 : 38 : 25 <====Rx METER-2 D4 0B 20 00 00 02 37 C4 01 81 00 16 00
16 : 38 : 25 ====>Tx METER-2 D0 12 20 00 00 02 37 C0 01 C1 00 40 00 00 2B 00 06 FF 04 00
16 : 38 : 25 ====>Tx METER-2 D0 12 20 00 00 02 37 88 58 63 F1 39 47 37 FB 8F 2D 75 C5 29
16 : 38 : 25 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-6-255, IC = 64, ATTR: INDEX = 4
16 : 38 : 25 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 02 37 88 58 63 F1 39 47 37 FB 8F 2D 75 C5 29 DC 88 7E
16 : 38 : 25 <====Rx METER-2 7E A0 24 41 00 02 04 01 30 22 86 E6 E7 00 D4 13 20 00 00 02 38 7E 97 FD E4 5B 56 E2 81 97 E8 CE AF 69 06 82 55 7E
16 : 38 : 25 <====Rx METER-2 D4 13 20 00 00 02 38 7E 97 FD E4 5B 56 E2 81 97 E8 CE AF 69 06
16 : 38 : 25 <====Rx METER-2 D4 13 20 00 00 02 38 C4 01 81 00 09 08 5A 45 4E 30 30 30 31 30
16 : 38 : 25 ====>Tx METER-2 D0 12 20 00 00 02 38 C0 01 C1 00 40 00 00 2B 00 06 FF 05 00
16 : 38 : 25 ====>Tx METER-2 D0 12 20 00 00 02 38 94 92 FB AC 70 CD 62 EE A2 6B A4 59 88
16 : 38 : 26 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-43-0-6-255, IC = 64, ATTR: INDEX = 5
16 : 38 : 26 METER-2 SENDING HDLC FRAME
16 : 38 : 26 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 02 38 94 92 FB AC 70 CD 62 EE A2 6B A4 59 88 D7 D3 7E
16 : 38 : 26 METER-2 RECEIVED HDLC FRAME
16 : 38 : 26 <====Rx METER-2 7E A0 24 41 00 02 04 01 52 36 C6 E6 E7 00 D4 13 20 00 00 02 39 39 E4 88 FD 45 71 DA F9 3F 2A F6 4E D3 62 2B 7B 7E
16 : 38 : 26 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 26 <====Rx METER-2 D4 13 20 00 00 02 39 39 E4 88 FD 45 71 DA F9 3F 2A F6 4E D3 62
16 : 38 : 26 <====Rx METER-2 D4 13 20 00 00 02 39 C4 01 81 00 09 08 5A 45 4E 30 30 30 31 30
16 : 38 : 26 METER-2 SERVICE = GET RESPONSE
16 : 38 : 26 METER-2 COSEM OUT DATA
16 : 38 : 26 ====>Tx METER-2 D0 12 20 00 00 02 39 C0 01 C1 00 46 00 00 60 03 0A FF 02 00
16 : 38 : 26 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 26 ====>Tx METER-2 D0 12 20 00 00 02 39 69 57 20 16 7A C0 AD 55 28 C8 4F 67 8D
16 : 38 : 26 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-3-10-255, IC = 70, ATTR: INDEX = 2
16 : 38 : 26 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 02 39 69 57 20 16 7A C0 AD 55 28 C8 4F 67 8D 38 D2 7E
16 : 38 : 26 <====Rx METER-2 7E A0 1C 41 00 02 04 01 74 A4 8A E6 E7 00 D4 0B 20 00 00 02 3A D6 DD E3 E0 E9 89 78 25 7E
16 : 38 : 26 <====Rx METER-2 D4 0B 20 00 00 02 3A D6 DD E3 E0 E9 89
16 : 38 : 26 <====Rx METER-2 D4 0B 20 00 00 02 3A C4 01 81 00 03 01
16 : 38 : 26 ====>Tx METER-2 D0 12 20 00 00 02 3A C0 01 C1 00 46 00 00 60 03 0A FF 03 00
16 : 38 : 26 ====>Tx METER-2 D0 12 20 00 00 02 3A 10 20 49 7D 73 0F 2C A7 F3 66 17 FA DE
16 : 38 : 26 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-3-10-255, IC = 70, ATTR: INDEX = 3
16 : 38 : 26 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 02 3A 10 20 49 7D 73 0F 2C A7 F3 66 17 FA DE 5D FC 7E
16 : 38 : 26 <====Rx METER-2 7E A0 1C 41 00 02 04 01 96 B8 4E E6 E7 00 D4 0B 20 00 00 02 3B 31 89 AE AE E3 56 42 24 7E
16 : 38 : 26 <====Rx METER-2 D4 0B 20 00 00 02 3B 31 89 AE AE E3 56
16 : 38 : 26 <====Rx METER-2 D4 0B 20 00 00 02 3B C4 01 81 00 16 01
16 : 38 : 26 ====>Tx METER-2 D0 12 20 00 00 02 3B C0 01 C1 00 46 00 00 60 03 0A FF 04 00
16 : 38 : 26 ====>Tx METER-2 D0 12 20 00 00 02 3B 0F 67 F5 E1 2B 0B F5 CE CD 16 4B 58 78
16 : 38 : 26 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-96-3-10-255, IC = 70, ATTR: INDEX = 4
16 : 38 : 26 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 02 3B 0F 67 F5 E1 2B 0B F5 CE CD 16 4B 58 78 5B 80 7E
16 : 38 : 26 <====Rx METER-2 7E A0 1C 41 00 02 04 01 B8 C4 86 E6 E7 00 D4 0B 20 00 00 02 3C 6F A0 C0 41 3D 5A EB D0 7E
16 : 38 : 26 <====Rx METER-2 D4 0B 20 00 00 02 3C 6F A0 C0 41 3D 5A
16 : 38 : 26 <====Rx METER-2 D4 0B 20 00 00 02 3C C4 01 81 00 16 04
16 : 38 : 27 METER-2 COSEM OUT DATA
16 : 38 : 27 ====>Tx METER-2 D0 12 20 00 00 02 3C C0 01 C1 00 47 00 00 11 00 00 FF 02 00
16 : 38 : 27 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 27 ====>Tx METER-2 D0 12 20 00 00 02 3C 6B F1 24 FF 2A 1E 66 C2 E4 75 D8 9E A4
16 : 38 : 27 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-0-255, IC = 71, ATTR: INDEX = 2
16 : 38 : 27 METER-2 SENDING HDLC FRAME
16 : 38 : 27 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 02 3C 6B F1 24 FF 2A 1E 66 C2 E4 75 D8 9E A4 DF E6 7E
16 : 38 : 27 METER-2 RECEIVED HDLC FRAME
16 : 38 : 27 <====Rx METER-2 7E A0 29 41 00 02 04 01 DA 39 E0 E6 E7 00 D4 18 20 00 00 02 3D 4E 34 92 00 30 84 03 DF 5F B4 29 DD 45 92 48 76 5A 86 C3
4C BC 7E
16 : 38 : 27 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 27 <====Rx METER-2 D4 18 20 00 00 02 3D 4E 34 92 00 30 84 03 DF 5F B4 29 DD 45 92 48 76 5A 86 C3
16 : 38 : 27 <====Rx METER-2 D4 18 20 00 00 02 3D C4 01 81 00 02 03 12 00 03 09 06 01 00 01 07 00 FF 0F 02
16 : 38 : 27 METER-2 SERVICE = GET RESPONSE
16 : 38 : 27 ====>Tx METER-2 D0 12 20 00 00 02 3D C0 01 C1 00 47 00 00 11 00 00 FF 03 00
16 : 38 : 27 ====>Tx METER-2 D0 12 20 00 00 02 3D E3 0C 3D 7C 7E F4 4E E3 D1 5D EE F0 1F
16 : 38 : 27 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-0-255, IC = 71, ATTR: INDEX = 3
16 : 38 : 27 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 02 3D E3 0C 3D 7C 7E F4 4E E3 D1 5D EE F0 1F 7B 68 7E
16 : 38 : 27 <====Rx METER-2 7E A0 1F 41 00 02 04 01 FC 8A 2A E6 E7 00 D4 0E 20 00 00 02 3E A7 2D 67 43 BB C9 E1 D8 6E 8D B5 7E
16 : 38 : 27 <====Rx METER-2 D4 0E 20 00 00 02 3E A7 2D 67 43 BB C9 E1 D8 6E
16 : 38 : 27 <====Rx METER-2 D4 0E 20 00 00 02 3E C4 01 81 00 06 00 00 43 80
16 : 38 : 27 ====>Tx METER-2 D0 12 20 00 00 02 3E C0 01 C1 00 47 00 00 11 00 00 FF 04 00
16 : 38 : 27 ====>Tx METER-2 D0 12 20 00 00 02 3E 86 BC 99 99 58 35 04 F8 97 78 BF 90 86
16 : 38 : 27 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-0-255, IC = 71, ATTR: INDEX = 4
16 : 38 : 27 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 02 3E 86 BC 99 99 58 35 04 F8 97 78 BF 90 86 90 C0 7E
16 : 38 : 27 <====Rx METER-2 7E A0 1F 41 00 02 04 01 1E 96 EE E6 E7 00 D4 0E 20 00 00 02 3F 5E B6 AB BE D1 D2 74 2B 83 6F 87 7E
16 : 38 : 27 <====Rx METER-2 D4 0E 20 00 00 02 3F 5E B6 AB BE D1 D2 74 2B 83
16 : 38 : 27 <====Rx METER-2 D4 0E 20 00 00 02 3F C4 01 81 00 06 00 00 43 80
16 : 38 : 27 ====>Tx METER-2 D0 12 20 00 00 02 3F C0 01 C1 00 47 00 00 11 00 00 FF 05 00
16 : 38 : 27 ====>Tx METER-2 D0 12 20 00 00 02 3F 20 A9 60 71 92 45 1E D1 AC 7D 4B 85 2E
16 : 38 : 27 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-0-255, IC = 71, ATTR: INDEX = 5
16 : 38 : 27 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 02 3F 20 A9 60 71 92 45 1E D1 AC 7D 4B 85 2E B2 34 7E
16 : 38 : 27 <====Rx METER-2 7E A0 1F 41 00 02 04 01 30 EA 26 E6 E7 00 D4 0E 20 00 00 02 40 70 DD C9 2B FC D0 E5 A7 C1 49 2F 7E
16 : 38 : 28 <====Rx METER-2 D4 0E 20 00 00 02 40 70 DD C9 2B FC D0 E5 A7 C1
16 : 38 : 28 METER-2 RECEIVED APPLICATION LAYER FRAME
16 : 38 : 28 <====Rx METER-2 D4 0E 20 00 00 02 40 C4 01 81 00 05 00 00 00 00
16 : 38 : 28 METER-2 SERVICE = GET RESPONSE
16 : 38 : 28 METER-2 COSEM OUT DATA
16 : 38 : 28 ====>Tx METER-2 D0 12 20 00 00 02 40 C0 01 C1 00 47 00 00 11 00 00 FF 06 00
16 : 38 : 28 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 28 ====>Tx METER-2 D0 12 20 00 00 02 40 59 B6 07 F9 D4 5E DF FF 9F D8 1E 00 7A
16 : 38 : 28 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-0-255, IC = 71, ATTR: INDEX = 6
16 : 38 : 28 METER-2 SENDING HDLC FRAME
16 : 38 : 28 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 02 40 59 B6 07 F9 D4 5E DF FF 9F D8 1E 00 7A 37 63 7E
16 : 38 : 28 METER-2 RECEIVED HDLC FRAME
16 : 38 : 28 <====Rx METER-2 7E A0 1F 41 00 02 04 01 52 FE 66 E6 E7 00 D4 0E 20 00 00 02 41 77 F4 44 BF A9 A6 0F CD 5F 73 D2 7E
16 : 38 : 28 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 28 <====Rx METER-2 D4 0E 20 00 00 02 41 77 F4 44 BF A9 A6 0F CD 5F
16 : 38 : 28 <====Rx METER-2 D4 0E 20 00 00 02 41 C4 01 81 00 06 00 00 01 2C
16 : 38 : 28 ====>Tx METER-2 D0 12 20 00 00 02 41 C0 01 C1 00 47 00 00 11 00 00 FF 07 00
16 : 38 : 28 ====>Tx METER-2 D0 12 20 00 00 02 41 B7 23 FE 34 AB 2B 79 46 4B D9 92 A8 DE
16 : 38 : 28 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-0-255, IC = 71, ATTR: INDEX = 7
16 : 38 : 28 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 02 41 B7 23 FE 34 AB 2B 79 46 4B D9 92 A8 DE A8 FD 7E
16 : 38 : 28 <====Rx METER-2 7E A0 1F 41 00 02 04 01 74 CA 22 E6 E7 00 D4 0E 20 00 00 02 42 AB 47 29 8C 84 DE BA 53 90 F9 7B 7E
16 : 38 : 28 <====Rx METER-2 D4 0E 20 00 00 02 42 AB 47 29 8C 84 DE BA 53 90
16 : 38 : 28 <====Rx METER-2 D4 0E 20 00 00 02 42 C4 01 81 00 06 00 00 01 2C
16 : 38 : 28 ====>Tx METER-2 D0 12 20 00 00 02 42 C0 01 C1 00 47 00 00 11 00 00 FF 08 00
16 : 38 : 28 ====>Tx METER-2 D0 12 20 00 00 02 42 E4 2A 61 1E A2 CA 8B 51 CA E0 26 BE C1
16 : 38 : 28 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-0-255, IC = 71, ATTR: INDEX = 8
16 : 38 : 28 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 02 42 E4 2A 61 1E A2 CA 8B 51 CA E0 26 BE C1 ED 05 7E
16 : 38 : 28 <====Rx METER-2 7E A0 32 41 00 02 04 01 96 1A AB E6 E7 00 D4 21 20 00 00 02 43 D7 A8 64 17 21 77 91 A4 0A 8C 98 31 7B DE A5 92 B8 6A 1F
E4 45 55 08 C0 0B 2E D1 FF AF 2D 7E
16 : 38 : 28 <====Rx METER-2 D4 21 20 00 00 02 43 D7 A8 64 17 21 77 91 A4 0A 8C 98 31 7B DE A5 92 B8 6A 1F E4 45 55 08 C0 0B 2E D1 FF
16 : 38 : 28 <====Rx METER-2 D4 21 20 00 00 02 43 C4 01 81 00 02 03 12 00 01 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 06 00 00 00 00
16 : 38 : 28 ====>Tx METER-2 D0 12 20 00 00 02 43 C0 01 C1 00 47 00 00 11 00 00 FF 09 00
16 : 38 : 28 ====>Tx METER-2 D0 12 20 00 00 02 43 98 AC 30 E9 6E A1 07 C5 53 2C 4C 62 0F
16 : 38 : 28 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-0-255, IC = 71, ATTR: INDEX = 9
16 : 38 : 29 METER-2 SENDING HDLC FRAME
16 : 38 : 29 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 02 43 98 AC 30 E9 6E A1 07 C5 53 2C 4C 62 0F 34 DF 7E
16 : 38 : 29 METER-2 RECEIVED HDLC FRAME
16 : 38 : 29 <====Rx METER-2 7E A0 1C 41 00 02 04 01 B8 C4 86 E6 E7 00 D4 0B 20 00 00 02 44 30 09 E5 20 F7 D7 A1 0F 7E
16 : 38 : 29 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 29 <====Rx METER-2 D4 0B 20 00 00 02 44 30 09 E5 20 F7 D7
16 : 38 : 29 <====Rx METER-2 D4 0B 20 00 00 02 44 C4 01 81 00 01 00
16 : 38 : 29 METER-2 SERVICE = GET RESPONSE
16 : 38 : 29 METER-2 COSEM OUT DATA
16 : 38 : 29 ====>Tx METER-2 D0 12 20 00 00 02 44 C0 01 C1 00 47 00 00 11 00 00 FF 0A 00
16 : 38 : 29 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 29 ====>Tx METER-2 D0 12 20 00 00 02 44 4E 92 01 08 3D 49 74 5A 94 BE 59 BA C7
16 : 38 : 29 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-0-255, IC = 71, ATTR: INDEX = 10
16 : 38 : 29 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 02 44 4E 92 01 08 3D 49 74 5A 94 BE 59 BA C7 E5 39 7E
16 : 38 : 29 <====Rx METER-2 7E A0 1C 41 00 02 04 01 DA D0 C6 E6 E7 00 D4 0B 20 00 00 02 45 33 47 49 E1 49 F8 57 20 7E
16 : 38 : 29 <====Rx METER-2 D4 0B 20 00 00 02 45 33 47 49 E1 49 F8
16 : 38 : 29 <====Rx METER-2 D4 0B 20 00 00 02 45 C4 01 81 00 03 00
16 : 38 : 29 ====>Tx METER-2 D0 12 20 00 00 02 45 C0 01 C1 00 47 00 00 11 00 00 FF 0B 00
16 : 38 : 29 ====>Tx METER-2 D0 12 20 00 00 02 45 4E 66 45 73 68 1B B4 26 C6 67 74 3D CF
16 : 38 : 29 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-0-255, IC = 71, ATTR: INDEX = 11
16 : 38 : 29 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 02 45 4E 66 45 73 68 1B B4 26 C6 67 74 3D CF E3 1C 7E
16 : 38 : 29 <====Rx METER-2 7E A0 36 41 00 02 04 01 FC 30 08 E6 E7 00 D4 25 20 00 00 02 46 FC 87 73 2D 25 3F 42 8C 6B 4F B9 DA B6 93 D9 C7 D0 26 AE
D3 2B 8A 4D 74 5A FC 45 1B 73 AB 30 2F 05 48 7E
16 : 38 : 29 <====Rx METER-2 D4 25 20 00 00 02 46 FC 87 73 2D 25 3F 42 8C 6B 4F B9 DA B6 93 D9 C7 D0 26 AE D3 2B 8A 4D 74 5A FC 45 1B 73 AB 30 2F
16 : 38 : 29 <====Rx METER-2 D4 25 20 00 00 02 46 C4 01 81 00 02 02 02 02 09 06 00 00 0A 00 6A FF 12 00 01 02 02 09 06 00 00 0A 00 6A FF 12 00 02
16 : 38 : 29 ====>Tx METER-2 D0 12 20 00 00 02 46 C0 01 C1 00 47 00 00 11 00 80 FF 02 00
16 : 38 : 29 ====>Tx METER-2 D0 12 20 00 00 02 46 4D 78 84 7A 43 F6 FB EE CC ED 41 7F 05
16 : 38 : 29 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-128-255, IC = 71, ATTR: INDEX = 2
16 : 38 : 29 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 02 46 4D 78 84 7A 43 F6 FB EE CC ED 41 7F 05 BA DC 7E
16 : 38 : 29 <====Rx METER-2 7E A0 29 41 00 02 04 01 1E 11 60 E6 E7 00 D4 18 20 00 00 02 47 7E 5A BD 01 00 38 10 08 73 C6 E3 C6 BB D4 75 4F AC A0 A7
66 56 7E
16 : 38 : 29 <====Rx METER-2 D4 18 20 00 00 02 47 7E 5A BD 01 00 38 10 08 73 C6 E3 C6 BB D4 75 4F AC A0 A7
16 : 38 : 29 <====Rx METER-2 D4 18 20 00 00 02 47 C4 01 81 00 02 03 12 00 03 09 06 01 00 0B 07 00 FF 0F 02
16 : 38 : 30 ====>Tx METER-2 D0 12 20 00 00 02 47 C0 01 C1 00 47 00 00 11 00 80 FF 03 00
16 : 38 : 30 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 30 ====>Tx METER-2 D0 12 20 00 00 02 47 00 71 F5 FD 0F 00 E7 02 D5 66 FB 26 AE
16 : 38 : 30 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-128-255, IC = 71, ATTR: INDEX = 3
16 : 38 : 30 METER-2 SENDING HDLC FRAME
16 : 38 : 30 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 02 47 00 71 F5 FD 0F 00 E7 02 D5 66 FB 26 AE 12 BC 7E
16 : 38 : 30 METER-2 RECEIVED HDLC FRAME
16 : 38 : 30 <====Rx METER-2 7E A0 1D 41 00 02 04 01 30 51 11 E6 E7 00 D4 0C 20 00 00 02 48 09 86 73 4C 59 31 0B 86 DF 7E
16 : 38 : 30 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 30 <====Rx METER-2 D4 0C 20 00 00 02 48 09 86 73 4C 59 31 0B
16 : 38 : 30 <====Rx METER-2 D4 0C 20 00 00 02 48 C4 01 81 00 12 00 48
16 : 38 : 30 METER-2 SERVICE = GET RESPONSE
16 : 38 : 30 ====>Tx METER-2 D0 12 20 00 00 02 48 C0 01 C1 00 47 00 00 11 00 80 FF 04 00
16 : 38 : 30 ====>Tx METER-2 D0 12 20 00 00 02 48 DC A3 FD 79 D8 AF 32 09 E3 65 04 A6 E1
16 : 38 : 30 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-128-255, IC = 71, ATTR: INDEX = 4
16 : 38 : 30 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 02 48 DC A3 FD 79 D8 AF 32 09 E3 65 04 A6 E1 74 4C 7E
16 : 38 : 30 <====Rx METER-2 7E A0 1D 41 00 02 04 01 52 45 51 E6 E7 00 D4 0C 20 00 00 02 49 5C 2B B9 43 21 1B 1E 1B 03 7E
16 : 38 : 30 <====Rx METER-2 D4 0C 20 00 00 02 49 5C 2B B9 43 21 1B 1E
16 : 38 : 30 <====Rx METER-2 D4 0C 20 00 00 02 49 C4 01 81 00 12 00 48
16 : 38 : 30 ====>Tx METER-2 D0 12 20 00 00 02 49 C0 01 C1 00 47 00 00 11 00 80 FF 05 00
16 : 38 : 30 ====>Tx METER-2 D0 12 20 00 00 02 49 F9 69 07 37 8C 07 91 FF A3 5D F7 A6 9C
16 : 38 : 30 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-128-255, IC = 71, ATTR: INDEX = 5
16 : 38 : 30 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 02 49 F9 69 07 37 8C 07 91 FF A3 5D F7 A6 9C 26 2E 7E
16 : 38 : 30 <====Rx METER-2 7E A0 1F 41 00 02 04 01 74 CA 22 E6 E7 00 D4 0E 20 00 00 02 4A BB BE 24 4A 58 95 82 65 DA FF 22 7E
16 : 38 : 30 <====Rx METER-2 D4 0E 20 00 00 02 4A BB BE 24 4A 58 95 82 65 DA
16 : 38 : 30 <====Rx METER-2 D4 0E 20 00 00 02 4A C4 01 81 00 05 00 00 00 00
16 : 38 : 30 ====>Tx METER-2 D0 12 20 00 00 02 4A C0 01 C1 00 47 00 00 11 00 80 FF 06 00
16 : 38 : 30 ====>Tx METER-2 D0 12 20 00 00 02 4A 8B 70 A3 96 73 7B 59 F2 3E 89 6A 6B 0A
16 : 38 : 30 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-128-255, IC = 71, ATTR: INDEX = 6
16 : 38 : 30 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 02 4A 8B 70 A3 96 73 7B 59 F2 3E 89 6A 6B 0A 3E 2C 7E
16 : 38 : 30 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 02 4B 65 09 E7 52 00 F4 67 D0 EE A4 91 7E
16 : 38 : 31 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 31 <====Rx METER-2 D4 0E 20 00 00 02 4B 65 09 E7 52 00 F4 67 D0 EE
16 : 38 : 31 <====Rx METER-2 D4 0E 20 00 00 02 4B C4 01 81 00 06 00 00 01 2C
16 : 38 : 31 METER-2 SERVICE = GET RESPONSE
16 : 38 : 31 METER-2 COSEM OUT DATA
16 : 38 : 31 ====>Tx METER-2 D0 12 20 00 00 02 4B C0 01 C1 00 47 00 00 11 00 80 FF 07 00
16 : 38 : 31 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 31 ====>Tx METER-2 D0 12 20 00 00 02 4B AB CA 3D BF 06 93 8C 2E 40 84 EB 4E D1
16 : 38 : 31 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-128-255, IC = 71, ATTR: INDEX = 7
16 : 38 : 31 METER-2 SENDING HDLC FRAME
16 : 38 : 31 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 02 4B AB CA 3D BF 06 93 8C 2E 40 84 EB 4E D1 5D 79 7E
16 : 38 : 31 METER-2 RECEIVED HDLC FRAME
16 : 38 : 31 <====Rx METER-2 7E A0 1F 41 00 02 04 01 B8 AA 2E E6 E7 00 D4 0E 20 00 00 02 4C 6A D0 F5 01 80 AB 04 70 8F 9C 8E 7E
16 : 38 : 31 <====Rx METER-2 D4 0E 20 00 00 02 4C 6A D0 F5 01 80 AB 04 70 8F
16 : 38 : 31 <====Rx METER-2 D4 0E 20 00 00 02 4C C4 01 81 00 06 00 00 01 2C
16 : 38 : 31 ====>Tx METER-2 D0 12 20 00 00 02 4C C0 01 C1 00 47 00 00 11 00 80 FF 08 00
16 : 38 : 31 ====>Tx METER-2 D0 12 20 00 00 02 4C 94 AE 4C 8D 9F 0C 00 7F CA 11 ED EE 5D
16 : 38 : 31 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-128-255, IC = 71, ATTR: INDEX = 8
16 : 38 : 31 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 02 4C 94 AE 4C 8D 9F 0C 00 7F CA 11 ED EE 5D 63 AD 7E
16 : 38 : 31 <====Rx METER-2 7E A0 32 41 00 02 04 01 DA 72 23 E6 E7 00 D4 21 20 00 00 02 4D 7E 89 DE 07 B9 B9 F3 C0 A0 22 BA B7 1F FC 65 61 D7 C7 D1
67 85 6F BB F5 27 61 44 48 3C 3C 7E
16 : 38 : 31 <====Rx METER-2 D4 21 20 00 00 02 4D 7E 89 DE 07 B9 B9 F3 C0 A0 22 BA B7 1F FC 65 61 D7 C7 D1 67 85 6F BB F5 27 61 44 48
16 : 38 : 31 <====Rx METER-2 D4 21 20 00 00 02 4D C4 01 81 00 02 03 12 00 01 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 06 00 00 00 00
16 : 38 : 31 ====>Tx METER-2 D0 12 20 00 00 02 4D C0 01 C1 00 47 00 00 11 00 80 FF 09 00
16 : 38 : 31 ====>Tx METER-2 D0 12 20 00 00 02 4D 91 5A 09 CD F9 E7 7E 21 BD 66 A5 B2 B5
16 : 38 : 31 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-128-255, IC = 71, ATTR: INDEX = 9
16 : 38 : 31 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 02 4D 91 5A 09 CD F9 E7 7E 21 BD 66 A5 B2 B5 1E 88 7E
16 : 38 : 31 <====Rx METER-2 7E A0 1C 41 00 02 04 01 FC E4 82 E6 E7 00 D4 0B 20 00 00 02 4E 2A 54 55 BD 35 3A 35 56 7E
16 : 38 : 31 <====Rx METER-2 D4 0B 20 00 00 02 4E 2A 54 55 BD 35 3A
16 : 38 : 31 <====Rx METER-2 D4 0B 20 00 00 02 4E C4 01 81 00 01 00
16 : 38 : 32 ====>Tx METER-2 D0 12 20 00 00 02 4E C0 01 C1 00 47 00 00 11 00 80 FF 0A 00
16 : 38 : 32 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 32 ====>Tx METER-2 D0 12 20 00 00 02 4E 90 EC F5 EA CD 43 35 1C 81 79 9D BD D1
16 : 38 : 32 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-128-255, IC = 71, ATTR: INDEX = 10
16 : 38 : 32 METER-2 SENDING HDLC FRAME
16 : 38 : 32 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 02 4E 90 EC F5 EA CD 43 35 1C 81 79 9D BD D1 B6 F4 7E
16 : 38 : 32 METER-2 RECEIVED HDLC FRAME
16 : 38 : 32 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 02 4F 80 19 EC 11 6C 8B 1C 4F 7E
16 : 38 : 32 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 32 <====Rx METER-2 D4 0B 20 00 00 02 4F 80 19 EC 11 6C 8B
16 : 38 : 32 <====Rx METER-2 D4 0B 20 00 00 02 4F C4 01 81 00 03 00
16 : 38 : 32 METER-2 SERVICE = GET RESPONSE
16 : 38 : 32 ====>Tx METER-2 D0 12 20 00 00 02 4F C0 01 C1 00 47 00 00 11 00 80 FF 0B 00
16 : 38 : 32 ====>Tx METER-2 D0 12 20 00 00 02 4F 51 39 BA CF 77 5B CF FB 2C FE 2C 77 6A
16 : 38 : 32 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-17-0-128-255, IC = 71, ATTR: INDEX = 11
16 : 38 : 32 ====>Tx METER-2 7E A0 23 00 02 04 01 41 10 0B 44 E6 E6 00 D0 12 20 00 00 02 4F 51 39 BA CF 77 5B CF FB 2C FE 2C 77 6A B7 19 7E
16 : 38 : 32 <====Rx METER-2 7E A0 36 41 00 02 04 01 30 50 04 E6 E7 00 D4 25 20 00 00 02 50 C1 3E 43 45 DB 6D F7 B8 DC 80 E8 2C E4 96 D0 AD 11 0D C4
78 75 F5 07 0F 1E 7B 2C AF 74 41 F0 83 F6 01 7E
16 : 38 : 32 <====Rx METER-2 D4 25 20 00 00 02 50 C1 3E 43 45 DB 6D F7 B8 DC 80 E8 2C E4 96 D0 AD 11 0D C4 78 75 F5 07 0F 1E 7B 2C AF 74 41 F0 83
16 : 38 : 32 <====Rx METER-2 D4 25 20 00 00 02 50 C4 01 81 00 02 02 02 02 09 06 00 00 0A 00 6A FF 12 00 01 02 02 09 06 00 00 0A 00 6A FF 12 00 02
16 : 38 : 32 ====>Tx METER-2 D0 12 20 00 00 02 50 C0 01 C1 00 01 01 00 60 80 19 FF 02 00
16 : 38 : 32 ====>Tx METER-2 D0 12 20 00 00 02 50 B7 F3 52 EE 60 C1 B3 DC 22 7E 2B 20 1C
16 : 38 : 32 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-96-128-25-255, IC = 1, ATTR: INDEX = 2
16 : 38 : 32 ====>Tx METER-2 7E A0 23 00 02 04 01 41 32 1B 46 E6 E6 00 D0 12 20 00 00 02 50 B7 F3 52 EE 60 C1 B3 DC 22 7E 2B 20 1C A7 FC 7E
16 : 38 : 32 <====Rx METER-2 7E A0 28 41 00 02 04 01 52 AC 77 E6 E7 00 D4 17 20 00 00 02 51 11 42 49 7D 58 4C D3 4F C9 88 FA C1 96 FA 1B D6 90 8E E7
C1 7E
16 : 38 : 32 <====Rx METER-2 D4 17 20 00 00 02 51 11 42 49 7D 58 4C D3 4F C9 88 FA C1 96 FA 1B D6 90 8E
16 : 38 : 32 <====Rx METER-2 D4 17 20 00 00 02 51 C4 01 81 00 02 03 06 00 00 01 2C 06 00 00 07 08 11 04
16 : 38 : 32 ====>Tx METER-2 D0 12 20 00 00 02 51 C0 01 C1 00 01 01 00 60 80 1E FF 02 00
16 : 38 : 32 ====>Tx METER-2 D0 12 20 00 00 02 51 C6 F5 95 AB CC 95 A6 D4 DA 87 6D B2 D5
16 : 38 : 32 METER-2 SERVICE = GET REQUEST, OBIS = 1-0-96-128-30-255, IC = 1, ATTR: INDEX = 2
16 : 38 : 32 ====>Tx METER-2 7E A0 23 00 02 04 01 41 54 2B 40 E6 E6 00 D0 12 20 00 00 02 51 C6 F5 95 AB CC 95 A6 D4 DA 87 6D B2 D5 D1 EB 7E
16 : 38 : 32 <====Rx METER-2 7E A0 36 41 00 02 04 01 74 70 00 E6 E7 00 D4 25 20 00 00 02 52 ED 7D 40 51 86 B9 B9 39 A5 42 34 B6 0E 49 A1 FF 6F 5B 25
B2 7C 9B A6 BD 1A 47 D0 D8 7D 01 20 E3 86 8C 7E
16 : 38 : 33 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 33 <====Rx METER-2 D4 25 20 00 00 02 52 ED 7D 40 51 86 B9 B9 39 A5 42 34 B6 0E 49 A1 FF 6F 5B 25 B2 7C 9B A6 BD 1A 47 D0 D8 7D 01 20 E3
16 : 38 : 33 <====Rx METER-2 D4 25 20 00 00 02 52 C4 01 81 00 02 04 06 00 00 01 2C 06 00 00 07 08 11 04 09 0C FF FF FF FF FF FF FF FF FF FF FF FF
16 : 38 : 33 METER-2 SERVICE = GET RESPONSE
16 : 38 : 33 METER-2 COSEM OUT DATA
16 : 38 : 33 ====>Tx METER-2 D0 12 20 00 00 02 52 C0 01 C1 00 01 00 00 98 01 09 FF 02 00
16 : 38 : 33 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 33 ====>Tx METER-2 D0 12 20 00 00 02 52 36 85 A4 23 72 A9 98 41 D7 1C 14 5B 0A
16 : 38 : 33 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-152-1-9-255, IC = 1, ATTR: INDEX = 2
16 : 38 : 33 METER-2 SENDING HDLC FRAME
16 : 38 : 33 ====>Tx METER-2 7E A0 23 00 02 04 01 41 76 3B 42 E6 E6 00 D0 12 20 00 00 02 52 36 85 A4 23 72 A9 98 41 D7 1C 14 5B 0A CD DA 7E
16 : 38 : 33 METER-2 RECEIVED HDLC FRAME
16 : 38 : 33 <====Rx METER-2 7E A0 1F 41 00 02 04 01 96 D6 E6 E6 E7 00 D4 0E 20 00 00 02 53 63 9A 45 2F 52 5F 0A D9 72 7C C4 7E
16 : 38 : 33 <====Rx METER-2 D4 0E 20 00 00 02 53 63 9A 45 2F 52 5F 0A D9 72
16 : 38 : 33 <====Rx METER-2 D4 0E 20 00 00 02 53 C4 01 81 00 06 00 00 03 84
16 : 38 : 33 ====>Tx METER-2 D0 12 20 00 00 02 53 C0 01 C1 00 01 00 00 9B 01 01 FF 02 00
16 : 38 : 33 ====>Tx METER-2 D0 12 20 00 00 02 53 2E 23 A7 91 2C 00 E1 45 C7 D8 C7 28 24
16 : 38 : 33 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-155-1-1-255, IC = 1, ATTR: INDEX = 2
16 : 38 : 33 ====>Tx METER-2 7E A0 23 00 02 04 01 41 98 4B 4C E6 E6 00 D0 12 20 00 00 02 53 2E 23 A7 91 2C 00 E1 45 C7 D8 C7 28 24 EA F7 7E
16 : 38 : 33 <====Rx METER-2 7E A0 79 41 00 02 04 01 B8 E2 D2 E6 E7 00 D4 68 20 00 00 02 54 9F 9F ED 0C 34 FE 77 48 F4 72 AE 65 D8 5E E4 45 B3 77 6C
8D FB 02 53 4A 72 BB D7 AD 2C 71 32 75 1A 76 41 03 9D B8 01 83 97 0A 77 1E 4A 2F 9A 41 A5 28 29 1D E0 18 C2 E4 DF 72 AD
81 30 C7 37 D5 D8 03 3B 26 DF 47 71 19 23 CB E0 31 27 A8 26 D2 F1 18 DE 42 61 7B 83 B4 63 CB 07 CE 6C D3 3B E7 1A FE 94
38 54 7E
16 : 38 : 33 <====Rx METER-2 D4 68 20 00 00 02 54 9F 9F ED 0C 34 FE 77 48 F4 72 AE 65 D8 5E E4 45 B3 77 6C 8D FB 02 53 4A 72 BB D7 AD 2C 71 32 75 1A
76 41 03 9D B8 01 83 97 0A 77 1E 4A 2F 9A 41 A5 28 29 1D E0 18 C2 E4 DF 72 AD 81 30 C7 37 D5 D8 03 3B 26 DF 47 71 19 23
16 : 38 : 33 <====Rx METER-2 D4 68 20 00 00 02 54 C4 01 81 00 01 06 02 02 0A 03 41 50 4E 0A 13 6D 32 6D 2E 6D 65 74 65 72 69 70 76 36 2E 63 6F 2E 69
6E 02 02 0A 07 41 70 6E 55 73 65 72 0A 00 02 02 0A 06 41 70 6E 5F 50 57 0A 00 02 02 0A 05 49 50 34 2F 36 11 00 02 02 0A
07 54 43 50 2F 55 44 50 11 00 02 02 0A 09 48 65 61 72 74 62 65 61 74 12 03 84
16 : 38 : 33 ====>Tx METER-2 D0 12 20 00 00 02 54 C0 01 C1 00 01 00 00 9B 01 02 FF 02 00
16 : 38 : 33 ====>Tx METER-2 D0 12 20 00 00 02 54 A1 6B 09 97 9F 16 E5 CC DD 75 D0 17 95
16 : 38 : 33 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-155-1-2-255, IC = 1, ATTR: INDEX = 2
16 : 38 : 33 ====>Tx METER-2 7E A0 23 00 02 04 01 41 BA 5B 4E E6 E6 00 D0 12 20 00 00 02 54 A1 6B 09 97 9F 16 E5 CC DD 75 D0 17 95 47 A2 7E
16 : 38 : 33 <====Rx METER-2 7E A0 5A 41 00 02 04 01 DA 1B 59 E6 E7 00 D4 49 20 00 00 02 55 09 EF 26 A9 3F AE A0 ED 75 D3 0E 51 B3 BD 5F 44 36 18 85
D3 B1 D5 60 00 9B E1 0E A2 F4 4C 47 9D C6 79 83 8C C1 E4 FC 1C 9D EA 7F 17 CC 2B 66 F2 E5 4D 9D 76 B2 88 50 7E 2C 53 70
B9 11 EA 2E 8A D5 A5 09 36 EA F9 7E
16 : 38 : 33 <====Rx METER-2 D4 49 20 00 00 02 55 09 EF 26 A9 3F AE A0 ED 75 D3 0E 51 B3 BD 5F 44 36 18 85 D3 B1 D5 60 00 9B E1 0E A2 F4 4C 47 9D C6
79 83 8C C1 E4 FC 1C 9D EA 7F 17 CC 2B 66 F2 E5 4D 9D 76 B2 88 50 7E 2C 53 70 B9 11 EA 2E 8A D5 A5 09 36
16 : 38 : 33 <====Rx METER-2 D4 49 20 00 00 02 55 C4 01 81 00 01 06 0A 05 32 2E 30 31 36 0A 05 31 2E 30 30 31 0A 04 56 30 30 33 0A 10 38 36 31 33 36
35 30 34 30 34 37 39 38 38 38 00 09 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 04 02 BC 00 05
16 : 38 : 33 ====>Tx METER-2 D0 12 20 00 00 02 55 C0 01 C1 00 01 00 00 9B 01 03 FF 02 00
16 : 38 : 33 ====>Tx METER-2 D0 12 20 00 00 02 55 7C E0 97 C1 CC 1D CB 5E 12 C0 44 B4 DE
16 : 38 : 34 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-155-1-3-255, IC = 1, ATTR: INDEX = 2
16 : 38 : 34 METER-2 SENDING HDLC FRAME
16 : 38 : 34 ====>Tx METER-2 7E A0 23 00 02 04 01 41 DC 6B 48 E6 E6 00 D0 12 20 00 00 02 55 7C E0 97 C1 CC 1D CB 5E 12 C0 44 B4 DE 27 80 7E
16 : 38 : 34 METER-2 RECEIVED HDLC FRAME
16 : 38 : 34 <====Rx METER-2 7E A0 4D 41 00 02 04 01 FC FE 6F E6 E7 00 D4 3C 20 00 00 02 56 D2 60 75 1C EB 71 F2 85 02 FF B6 B0 7A 7F 25 29 43 F5 C5
CA BD 37 5A D1 9B D0 13 1E 74 D9 62 1A 25 6A DC DB 60 ED 2B 68 A2 26 CD 42 6C 4B 62 BD 69 FB 0E 46 1F D6 60 2D BB 7E
16 : 38 : 34 METER-2 RECEIVED APPLICATION LAYER FRAME - CIPHERED
16 : 38 : 34 <====Rx METER-2 D4 3C 20 00 00 02 56 D2 60 75 1C EB 71 F2 85 02 FF B6 B0 7A 7F 25 29 43 F5 C5 CA BD 37 5A D1 9B D0 13 1E 74 D9 62 1A 25
16 : 38 : 34 <====Rx METER-2 D4 3C 20 00 00 02 56 C4 01 81 00 01 03 02 02 0A 0C 4F 43 28 58 2E 78 25 49 6D 61 78 29 12 04 B0 02 02 0A 08 4F 56 28 58
25 55 6E 29 12 00 73 02 02 0A 08 4C 56 28 58 25 55 6E 29 12 00 50
16 : 38 : 34 METER-2 SERVICE = GET RESPONSE
16 : 38 : 34 METER-2 COSEM OUT DATA
16 : 38 : 34 ====>Tx METER-2 D0 12 20 00 00 02 56 C0 01 C1 00 01 00 00 9B 01 04 FF 02 00
16 : 38 : 34 METER-2 COSEM OUT DATA - CIPHERED
16 : 38 : 34 ====>Tx METER-2 D0 12 20 00 00 02 56 6C DD 3D 61 9E 89 82 04 F1 93 2A E7 54
16 : 38 : 34 METER-2 SERVICE = GET REQUEST, OBIS = 0-0-155-1-4-255, IC = 1, ATTR: INDEX = 2
16 : 38 : 34 ====>Tx METER-2 7E A0 23 00 02 04 01 41 FE 7B 4A E6 E6 00 D0 12 20 00 00 02 56 6C DD 3D 61 9E 89 82 04 F1 93 2A E7 54 47 6E 7E
16 : 38 : 34 <====Rx METER-2 7E A0 1C 41 00 02 04 01 1E F8 46 E6 E7 00 D4 0B 20 00 00 02 57 D8 C9 99 04 45 58 30 22 7E
16 : 38 : 34 <====Rx METER-2 D4 0B 20 00 00 02 57 D8 C9 99 04 45 58
16 : 38 : 34 <====Rx METER-2 D4 0B 20 00 00 02 57 C4 01 81 00 11 00
16 : 38 : 34 ====>Tx METER-2 7E A0 0A 00 02 04 01 41 53 2E 16 7E
16 : 38 : 34 <====Rx METER-2 7E A0 23 41 00 02 04 01 73 A5 31 81 80 14 05 02 00 FA 06 02 00 FA 07 04 00 00 00 01 08 04 00 00 00 01 1C 5A 7E
6 years 11 months ago
Thank you from this info. Yes, now I'm sure. Meter manufacturer's application is not call release at all. After get response it calls directly Disconnect.
http://www.gurux.fi/GuruxDLMSTranslator?translate=7EA00A0002040141532E1…
SO it seems that release service is not implemented for the meter at all.
KhushbuBadheka
Thanks for your quick reply. Can you please let us know that how we are able to disconnect directly bypassing release request from GURUX ? Or can you please update it and provide us to check.
Thanks & Regards.
The only way at the moment is to comment release from the source code.
Bhaumik
I have commented release request from source code.
Meter is disconnected, but when I am trying to reconnect it gives "Meter returns Service not allowed exception" error.
Following are the logs of GXDLMSDirector :
10:39:24 AM
7E A0 25 61 03 30 CD 80 E6 E7 00 CC 17 30 00 00 3E 8B CF 20 0F 34 D8 6F 3F D1 77 75 3C BE C7 93 ED B6 D0 BA 7C D8 7E
10:39:56 Disconnect request
10:39:56 AM Disconnect request
7E A0 07 03 61 53 65 81 7E
<HDLC len="9" >
<TargetAddress Value="1" />
<SourceAddress Value="30" />
<FrameType Value="53" />
<DisconnectRequest>
</DisconnectRequest>
</HDLC>
10:39:56 AM
7E A0 20 61 03 73 05 9E 81 80 14 05 02 00 FA 06 02 00 FA 07 04 00 00 00 01 08 04 00 00 00 01 1C 5A 7E
<HDLC len="1F" >
<TargetAddress Value="30" />
<SourceAddress Value="1" />
<FrameType Value="73" />
<PDU>
<Ua>
<MaxInfoTX Value="250" />
<MaxInfoRX Value="250" />
<WindowSizeTX Value="1" />
<WindowSizeRX Value="1" />
</Ua>
</PDU>
</HDLC>
10:40:13 Initializing serial connection.
10:40:14 AM Send SNRM request.
7E A0 07 03 61 93 69 47 7E
<HDLC len="9" >
<FrameType Value="93" />
<Snrm>
</Snrm>
</HDLC>
10:40:14 AM
<HDLC len="1F" >
<PDU>
<Ua>
</Ua>
</PDU>
</HDLC>
10:40:14 Parsing UA reply succeeded.
Encrypt settings: Security: AuthenticationEncryption Invocation Counter: 0 SystemTitle: 5A 45 4E 30 30 30 37 35 AuthenticationKey: 30 31 32 33 34 35 36 37 38 39 41 42 43 44 45 46 BlockCipherKey: 30 31 32 33 34 35 36 37 38 39 41 42 43 44 45 46
10:40:14 AM Send AARQ request.
7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 5A 45 4E 30 30 30 37 35 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 58 5B 41 27 1D 43 47 64 32 1A 4D 66 6F 22 29 3B BE 23 04 21 21 1F 30 00 00 00 00 4B 1F 34 0A 3B 6D FC 5F 3B 73 E2 16 D6 38 1F 56 84 79 D0 83 EE 18 83 9B DC C8 92 8E 7E
<HDLC len="6A" >
<FrameType Value="10" />
<PDU>
<AssociationRequest>
<CallingAPTitle Value="5A454E3030303735" />
<MechanismName Value="High" />
<CallingAuthentication Value="585B41271D434764321A4D666F22293B" />
<glo_InitiateRequest Value="30000000004B1F340A3B6DFC5F3B73E216D6381F568479D083EE18839BDCC8" />
</AssociationRequest>
</PDU>
</HDLC>
10:40:15 AM
7E A0 0F 61 03 30 30 D3 E6 E7 00 D8 01 06 83 37 7E
<HDLC len="E" >
<FrameType Value="30" />
<PDU>
<Data="0106" />
</PDU>
</HDLC>
Gurux.DLMS.GXDLMSException: Meter returns Service not allowed exception.
at GXDLMSDirector.GXDLMSDevice.InitializeConnection() in E:\design\SLS\DLMS\Document\DLMS_KB\DLMS\GXDLMSDirector-master\Development\GXDLMSDevice.cs:line 182
at GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters) in E:\design\SLS\DLMS\Document\DLMS_KB\DLMS\GXDLMSDirector-master\Development\MainForm.cs:line 1347
KhushbuBadheka
Mikko,
Mikko,
We are able to achieve what we wanted by updating the invocation counter.
Thanks for your help though.
Regards.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
