  3. How Can I Set InvokeIdAndPriority ?
How can I set InvokeIdAndPriority ?
By wikican , 23 November, 2018
Gurux.Net
I'm using meterdisconneciton command. Using Write a register.
like this :
var relay = new GXDLMSData("1.1.128.0.0.255");
relay.Value = 4;
//ralay.InvokeIdAndPriority ???
reader.Write(relay,2);
Bu I got Access Error, When I ask the manifacturer, I noticed there is a little bit difference from our command and their command.
There is only InvokeIdAndPriority difference. I think if I set this value, I can use it properly.
in Gurux we send a :
<HDLC len="29" >
<TargetAddress Value="16" />
<SourceAddress Value="18" />
<!--I frame.-->
<FrameType Value="32" />
<PDU>
<SetRequest>
<SetRequestNormal>
<InvokeIdAndPriority Value="193" />
<AttributeDescriptor>
<!--DATA-->
<ClassId Value="1" />
<!--1.1.128.0.0.255-->
<InstanceId Value="0101800000FF" />
<AttributeId Value="2" />
</AttributeDescriptor>
<Value>
<UInt8 Value="4" />
</Value>
</SetRequestNormal>
</SetRequest>
</PDU>
</HDLC>
But manifacturer program send :
<HDLC len="26" >
<!--I frame.-->
<PDU>
<SetRequest>
<SetRequestNormal>
<InvokeIdAndPriority Value="129" />
<!--DATA-->
<Value>
<UInt8 Value="1" />
</Value>
</SetRequestNormal>
</SetRequest>
</PDU>
</HDLC>
8 years ago
Invoke Id And Priority
Those values are set to the client.
cl.InvokeID = 1;
cl.Priority = Priority.High;
cl.ServiceClass = ServiceClass.UnConfirmed;
wikican
8 years ago
Thank you Mikko :) yes. while
Thank you Mikko :) yes. while trying I found it was UnConfirmed service class.
Have a nice work.
  • Victorian | WA 083148835648
