  3. Key Agreement Using Ephermal Keys
Key agreement using Ephermal keys
By Siemens-US , 5 April, 2018
We want to use key agreement feature of DLMS COSEM to exchange new keys with the meter. In this type we need to use ephermal key pair(for public key ) and a signing key pair(for private key). How these keys will be generated? Will these be provided to me by the manufacturer or will we randomly generate these?
Yatin
8 years 7 months ago
Key agreement using
You can generate those keys with the framework. It was a little surprise that Java does not support it.
There is an example how to generate certificate on unit test but I'll copy it here:
* Key agreement test.
@Test
public final void keyAgreementTest() throws Exception {
target.getCiphering().setSecurity(Security.AUTHENTICATION_ENCRYPTION);
target.getProposedConformance().add(Conformance.GENERAL_PROTECTION);
// Generate keys for the client.
target.getCiphering().setSigningKeyPair(getClientTestSigningKeyPair());
.setSystemTitle(GXCommon.hexToBytes("4D4D4D0000BC614E"));
target.getCiphering().setRecipientSystemTitle(
GXCommon.hexToBytes("4D4D4D0000000001"));
server = new TestServer(new GXDLMSAssociationLogicalName(),
InterfaceType.WRAPPER);
server.getCiphering()
.setSystemTitle(GXCommon.hexToBytes("4D4D4D0000000001"));
target.getCiphering().setInvocationCounter(0x0123456789012345L);
server.getCiphering().setInvocationCounter(0x0123456789012345L);
GXDLMSClock clock = new GXDLMSClock();
GXDLMSSecuritySetup ss = new GXDLMSSecuritySetup();
server.getItems().add(clock);
server.getItems().add(ss);
server.initialize();
GXReplyData info = new GXReplyData();
byte[] reply = server.handleRequest(target.aarqRequest()[0]);
info.clear();
target.getData(reply, info);
assertEquals(0, info.getError());
target.parseAareResponse(info.getData());
// Generate signing keys.
Date from = new Date();
Date to = new Date(from.getTime() + 365L * 24L * 60L * 60L * 1000L);
// Create client certificate for digital signature.
GXx509Certificate certificate =
GXx509Certificate.createSelfSignedCertificate(
target.getCiphering().getSigningKeyPair(), from, to,
target.getCiphering().getSystemTitle(),
"CN=Test, O=Gurux, L=Tampere, C=FI", KeyUsage.forValue(
(KeyUsage.DIGITAL_SIGNATURE.getValue())));
// Send client's digital signature to the server.
reply = server
.handleRequest(ss.importCertificate(target, certificate)[0]);
info.clear();
// Create server certificate and export it.
reply = server.handleRequest(ss.generateKeyPair(target,
CertificateType.DIGITAL_SIGNATURE)[0]);
info.clear();
// Note! This is not used. We are using signing key pair from Green Book
// C1.
server.getCiphering().setSigningKeyPair(getServerTestSigningKeyPair());
reply = server.handleRequest(ss.generateCertificate(target,
info.clear();
GXPkcs10 cert = new GXPkcs10((byte[]) info.getValue());
certificate = GXx509Certificate.createSelfSignedCertificate(
server.getCiphering().getSigningKeyPair(), from, to,
cert.getSubject(), "CN=Test, O=Gurux, L=Tampere, C=FI",
KeyUsage.forValue((KeyUsage.DIGITAL_SIGNATURE.getValue())));
// Send server's digital signature to the server.
reply = server
info.clear();
// Export server's certificate.
reply = server.handleRequest(target.getServerCertificate(ss,
info.clear();
certificate = new GXx509Certificate((byte[]) info.getValue());
// Disconnect.
reply = server.handleRequest(target.disconnectRequest());
info.clear();
// Change security suite 1 after signature is sent to the server.
target.setSecuritySuite(SecuritySuite.ECDH_ECDSA_AES_GCM_128_SHA_256);
// target.getCiphering().getPublicKeys()
// .add(new GXSimpleEntry<CertificateType, PublicKey>(
// CertificateType.DIGITAL_SIGNATURE,
// cert.getPublicKey()));
info.clear();
// Generate client's Ephemeral keys and send it to the server.
.setEphemeralKeyPair(getClientEphemeralKeyPairC1());
.setEphemeralKeyPair(getServerEphemeralKeyPairC1());
ss.keyAgreement(target, GlobalKeyType.UNICAST_ENCRYPTION)[0]);
info.clear();
target.getSharedSecret((byte[]) info.getValue(),
certificate.getPublicKey());
// Check shared secret.
byte[] z = GXCommon.hexToBytes(
"C1 CF 8F E7 89 1A EF 36 17 D7 19 07 95 E6 1F E6 C2 4E FC 3C CA 2E 08 46 9B AD 1A 22 5C E6 EA 08");
// Client generates shared secret.
KeyAgreement ka = KeyAgreement.getInstance("ECDH");
ka.init(target.getCiphering().getEphemeralKeyPair().getPrivate());
ka.doPhase(target.getSettings().getTargetEphemeralKey(), true);
byte[] actual = ka.generateSecret();
assertEquals(GXCommon.toHex(z), GXCommon.toHex(actual));
reply = server.handleRequest(target.read(clock, 2)[0]);
info.clear();
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
