  3. Trying Readout At 9600 Not 300
Trying readout at 9600 not 300
By Virus , 16 February, 2018
Good day
I'm trying to do meter readout using 9600 Baud rate.
With 300 I just send .!?..
How do I do it at 9600?
I have tried 0x06 0x30 0x35 0x30 0x8d 0x0a
But when port is then set to 9600 I read all 0x00 0x00 0x00.
Is there a specific Readout Command for IEC before switching to DLMS?
Blessings
Herman
8 years 9 months ago
Readout
You need to ask meter to start using 9600. It's configured that default is 300. You can also try to change start baud rate.
If you start with IEC and want to use DLMS you ask meter to move IEC mode E. That is binary mode and DLMS uses that. You don't need to do any readout if you want to use DLMS. You can try with GXDLMSDirector and see how that is doing it.
