  3. Destination Addresses Do Not Match
Destination addresses do not match
By ozkee , 7 December, 2017
When I try to comment to the meter I get this error:
Destination addresses do not match. It is 18194. It should be 16.
Do you know what could be the cause of this error?
8 years 11 months ago
I believe that you try to make the connection to our example server. Select Gurux to the manufacturer and try again. Now you try to connect with wrong meter type.
ozkee
I am trying to connect to lgz meter.
I set manufacturer using `GXManufacturer man = items.findByIdentification('lgz');`
Is this error connected to `Invalid tag` or `Wrong CRC` error?
Thank
Change server address from 16 to 18194. Check four last digits.
I believe that those numbers are same as last digits of your meter serial number.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
