  3. How To Authenticate Dynamic IP Meters With Different Authentication Key
How to authenticate dynamic IP meters with different authentication key
By Goutam , 18 October, 2017
I have multiple dynamic IP meters of different manufacturer.
That are using different authentication key.
Issue is that which authentication key will use when a dynamic IP meter connect.
Query: Is there any option to get the meter serial number before authenticate the connection of dynamic IP meter.
9 years 1 month ago
That is the solution. You need to know the meter you are talking to. Ask your meter Logical Device Name and map that to authentication key.
Goutam
9 years 1 month ago
In reply to How to authenticate dynamic IP meters with different authenticat by Kurumi
According to your solution, can you please suggest me how I going to read meter Logical Device Name before authentication?
9 years 1 month ago
Try to connect without authentication. Read your Logical Device Name:
GXDLMSData ldn = new GXDLMSData("0.0.42.0.0.255");
Close connection and make new connection with higher authentication level.
Goutam
9 years 1 month ago
Thank you.
