  3. Event
event
By atulsawant , 3 August, 2017
Dear sir,
which OBIS code used for kwh rollover event?
9 years 3 months ago
OBIS code
You should read your meter and check what OBIS code thay are using.
Standard OBIS codes you can found from here:
http://www.gurux.fi/GuruxDLMSTranslator
Select "OBIS code" tab.
  • Victorian | WA 083148835648
