  3. Hi Sir
Hi Sir
By erdeepakcs , 28 July, 2017
Gurux.Serial
I have off the RTS and DTR for communication in serial port, but when it is sending command on serial port it gets on.
gxSerial1.RtsEnable = gxSerial1.DtrEnable = false;
BR
9 years 1 month ago
RTS and DTR
If you are using C# version, RtsEnable and DtrEnable methods are only wrapper for .Net version component.
Check that you have latest version from serial port drivers. This usually helps.
erdeepakcs
9 years 1 month ago
In reply to RTS and DTR by Kurumi
hi sir
i didn't get your point sir, can you explain it.
What driver should i use for this ?
thanks
Deepak
9 years ago
RTS and DTR
Hi Deepak,
You should check that your serial port drivers for Windows are latest.
We don't make anything when you enable or disable RTS or DTR.
