  3. Event Notification Api For Java
Event notification api for java
By yatingarg168 , 17 July, 2017
Has event notification not been implemented for DLMS/COSEM? If not is there any other way to push events like Meter Power Failure, SAX SWELL etc to the client?
Yatin
9 years 4 months ago
You can send Push events using generatePushSetupMessages-method. You should check gurux.dlms.push.listener.example. In Push message you can send any COSEM object data you like.
yatingarg168
Thanks for your reply. generatePushSetupMessages method calls generateDataNotificationMessages method which uses DATA_NOTIFICATION(id=15) command. I want to send EVENT_NOTIFICATION(id = 194]) command which is not listed in Command class itself.
Yatin
yatingarg168
Any update on above?
Yatin
9 years 3 months ago
We have added Event notification and InformationReport services. We try to release it on this week.
yatingarg168
Great.. Thanks :)
