  3. Obejcts Downloading
Obejcts Downloading
By bahubali , 2 June, 2017
Dear sir,
We have tested DLMS stack with GURUXDLMS director .
But our customer Read the DLMS meter using Kalkitech meter explorer tool ...Then it is not working means object downloading gets failed ...
why it happens?
Any changes required?
The failed log is as follows:
18 : 25 : 16 METER-1 SENDING HDLC FRAME
18 : 25 : 16 ====>Tx METER-1 7E A0 1C 00 02 BA A7 21 32 20 FA E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
18 : 25 : 16 METER-1 RECEIVED HDLC FRAME
18 : 25 : 16 <====Rx METER-1 7E A0 70 21 00 02 0E D3 32 C9 20 E6 E7 00 C4 02 C1 01 00 00 00 01 00 56 01 81 01 02 04 12 00 08 11 00 09 06 00 00 01 00
00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01
00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 00 DD 96 7E
9 years 5 months ago
Obects Downloading
Dear sir,
What programming language you are using (C++, Java, C#)?
CRC is count wrong.
I believe that you have made some modifications. Check that.
Framework handles CRC counting and you don't do anything.
bahubali
object downloading
I am using C language.
which modifications?
Obects Downloading
Dear sir,
I believe that you have made changes for Guru ANSI C framework.
If you are using ANSI C, create ticket for project management and it's handled there faster.
bahubali
object downloading
i dont getting what you are saying.
if it woks on our GURUXDirector and if we want it works on another tool...it require changes...am i right?
can you please elaborate which changes are required? or any other case?
  • Victorian | WA 083148835648
