  3. HPL 3 Phase Meter Reading a OBIS Code
By Goutam , 31 March, 2017
HPL 3 Phase meter return some value when i read the
following OBIS Codes
1) Register(0.0.0.1.2.255)
Attribute 3: Scaler: 1 Unit: NoUnit
Attribute 2: 07 E1 03 01 FF 00 00 00 00 01 4A 00
2) Data(0.0.42.0.0.255)
Attribute 2: 48 50 4C 43 54 30 35 58 58 58 30 32 20 20 20 20
Can you please tell me what the value(Attribute 2) stands for and how to convert to proper meaningful value.
9 years 7 months ago
That OBIS code should be "Ch. 0 Time stamp of the most recent billing period (1) closed".
Value is string ("HPLCT05XXX02 "). If you are using Java you can convert byte array to string like this:
new String((byte[]) data.getValue());
Goutam
In reply to HPL 3 Phase Meter Reading a OBIS Code by Kurumi
Using CSharp dot net.
ASCIIEncoding.ASCII.GetString((byte[]) data.Value);
  • Victorian | WA 083148835648
