  3. Creating Executable JAR
Creating executable JAR
By danilodesouzapereira , 5 July, 2016
I'm testing the java example with Eclipse. What projects must be opened together to run successfully?
Now, in order to create the JAR executable, what files do I need to include?
Thanks in advance,
Danilo.
10 years 4 months ago
If you have installed Maven it should download everything automatically for you. Otherwise you need gurux.common.java, gurux.dlms.java, gurux.net.java, gurux.serial.java and gurux.terminal.java.
I believe that best way to go is that you install maven if you have not already done it.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
