  3. Failed To Receive Answer From The Modem. Check Serial Port.
Failed to receive answer from the modem. Check serial port.
By prasad.k , 30 November, 2015
Gurux.Terminal
Meter manufacturer: Emco
Protocol: IEC62053-21
IEC62052-11
My setting
com port : com3 (USB to Serial optical port)
Braud Rate: 300
Databits: 7
Parity : none
Stop bit: one
After setting the properties, and pressed open
the following exception is thrown
java.lang.RuntimeException: Failed to receive answer from the modem. Check serial port.
at gurux.terminal.GXTerminal.sendCommand(GXTerminal.java:695)
at gurux.terminal.GXTerminal.open(GXTerminal.java:609)
at gurux.terminal.example.java.GuruxTerminalExampleJava.OpenBtnActionPerformed(GuruxTerminalExampleJava.java:351)
at gurux.terminal.example.java.GuruxTerminalExampleJava.access$000(GuruxTerminalExampleJava.java:57)
at gurux.terminal.example.java.GuruxTerminalExampleJava$1.actionPerformed(GuruxTerminalExampleJava.java:173)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6535)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6300)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4891)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4713)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Container.dispatchEventImpl(Container.java:2280)
at java.awt.Window.dispatchEventImpl(Window.java:2750)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
10 years 11 months ago
Your modem is not answering for AT commands. You should check your serial port settings. Try to change baudrate to 9600 and others 8 none 1.
ArchGeko
9 years 10 months ago
edit: wrong section
opened a new post http://www.gurux.fi/node/5856
