  3. Error! Index: 2 Access Error : Unknown Error.
Error! Index: 2 Access Error : Unknown error.
By mansour , 17 February, 2023
I'm trying to capture COSEM registers from an iskra meter (IE.5) with gurux.dlms.simulator.java, here is the command I used :
"java -jar target/gurux.dlms.simulator.java-0.0.1-SNAPSHOT.jar -S COM4:9600:8NONE1 -c 1 -s 145 -a HighGMAC -P 12345678 -C AuthenticationEncryption -T ... -A ... -B ... -v 0.0.43.1.0.255 -o simulator_iskra_ie5.xml -t Verbose"
In the beginning of the trace, it seems to work fine but after that I got too many errors like this :
"Error! Index: 2 Access Error : Unknown error."
Sorry I cannot attach the trace.txt generated (extension not allowed only image files).
extract of the trace.txt :
RX: 10:05:34.386 7E A0 08 03 02 23 1F 35 5C 7E
TX: 10:05:34.387 7E A0 36 02 23 03 D8 80 3D E6 E6 00 DB 08 47 75 72 75 78 31 32 33 1E 30 00 00 12 0D 24 3C B0 34 1C 48 0C DC 2A A5 E2 3F 8D 3C F1 54 02 87 0D 6D 5E EC 0A 8D 43 64 DB 7E
RX: 10:05:34.461 7E A0 08 03 02 23 1F 35 5C 7E
TX: 10:05:34.463 7E A0 36 02 23 03 FA 90 3F E6 E6 00 DB 08 47 75 72 75 78 31 32 33 1E 30 00 00 12 0E 14 3F C9 43 0C CA 94 16 C9 E2 7A FA 6D 00 0E BC D2 7D B9 29 67 25 A0 1C 19 20 5C 7E
RX: 10:05:34.535 7E A0 08 03 02 23 1F 35 5C 7E
TX: 10:05:34.537 7E A0 36 02 23 03 1C A8 BD E6 E6 00 DB 08 47 75 72 75 78 31 32 33 1E 30 00 00 12 0F FD 26 2F 53 6A 58 AD 79 54 74 A2 47 0C E1 C2 9B F5 93 99 41 7D 4D 40 3B 51 9F 33 7E
RX: 10:05:34.610 7E A0 08 03 02 23 1F 35 5C 7E
TX: 10:05:34.612 7E A0 36 02 23 03 3E B8 BF E6 E6 00 DB 08 47 75 72 75 78 31 32 33 1E 30 00 00 12 10 84 5D 62 0C 09 9D 43 A1 53 03 26 EB B6 D4 1C 4E D6 49 F5 64 0D 4A 65 E9 0C F8 AE 7E
RX: 10:05:34.689 7E A0 08 03 02 23 1F 35 5C 7E
Profile Generic 0.0.21.0.0.255Columns:
TX: 10:05:34.692 7E A0 36 02 23 03 50 C0 35 E6 E6 00 DB 08 47 75 72 75 78 31 32 33 1E 30 00 00 12 11 FF DB 49 D7 6E 12 7A 8C 03 1D 0C 47 54 C9 BD 7F A8 97 94 B9 1A 0C 78 1F D9 43 CD 7E
RX: 10:05:34.766 7E A0 08 03 02 23 1F 35 5C 7E
Err! Failed to read columns:Access Error : Unknown error.
Profile Generic 0.0.21.0.1.255Columns:
TX: 10:05:34.772 7E A0 36 02 23 03 72 D0 37 E6 E6 00 DB 08 47 75 72 75 78 31 32 33 1E 30 00 00 12 12 1D 37 73 4B 2C E3 E0 5A 62 F2 DC 8E F1 8E AA C9 A4 23 CC E9 9A 39 BC F6 7A 0B 63 7E
RX: 10:05:34.845 7E A0 08 03 02 23 1F 35 5C 7E
Profile Generic 0.0.21.0.2.255Columns:
TX: 10:05:34.850 7E A0 36 02 23 03 94 E8 B5 E6 E6 00 DB 08 47 75 72 75 78 31 32 33 1E 30 00 00 12 13 04 82 89 80 C6 86 78 9B 0C E3 8D AA 6E 2F 6A 08 81 D4 07 B9 FC 0D 7F 0D 80 4E 5E 7E
RX: 10:05:34.925 7E A0 08 03 02 23 1F 35 5C 7E
Profile Generic 0.0.21.0.3.255Columns:
TX: 10:05:34.931 7E A0 36 02 23 03 B6 F8 B7 E6 E6 00 DB 08 47 75 72 75 78 31 32 33 1E 30 00 00 12 14 99 44 A5 D2 93 2A 0D CF 92 0E 39 E1 74 94 DF 57 A1 01 08 DA CB 30 C2 4C 32 69 C9 7E
RX: 10:05:35.007 7E A0 08 03 02 23 1F 35 5C 7E
Profile Generic 0.0.98.1.0.255Columns:
TX: 10:05:35.011 7E A0 36 02 23 03 D8 80 3D E6 E6 00 DB 08 47 75 72 75 78 31 32 33 1E 30 00 00 12 15 41 38 D4 9E E1 AB E8 AB F5 06 CE AB 34 5A FD 42 F4 61 3B BF 03 37 FD B1 B6 D8 40 7E
RX: 10:05:35.085 7E A0 08 03 02 23 1F 35 5C 7E
3 years 8 months ago
Hi, You can't read your…
You can't read your meter at all, but the meter doesn't return the exception. Check your block cipher and authentication keys.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
