  3. Multiple Obis Object Request At Once
Multiple Obis Object Request at Once
By nick32 , 25 January, 2023
Is it possible make a request by two or more object at the same time?
For example, if I want recieve, Voltage Inst. value, with Logical Name 1.0.32.7.124.255, and Current Inst. value, with LogicalName 1.0.31.7.124.255.
Is it possible only in one request to the meter?
Thanks and Regards.
3 years 9 months ago
Hi, It's possible if the…
It's possible if the meter is supporting Multiple referencing.
https://www.gurux.fi/Gurux.DLMS.Conformance
You can use readList method to read the values you want. Check readScalerAndUnits method. It'll do exactly what you want to do.
https://github.com/Gurux/gurux.dlms.java/blob/08631c4b144158900b98364e3…
nick32
In reply to Hi, It's possible if the… by Kurumi
Thanks for answer, I was…
Thanks for answer,
I was able to implement it
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
