  3. Problems Getting Meaningful Responses From My ISKRAEMECO AM550.
Problems getting meaningful responses from my ISKRAEMECO AM550.
By aldiguru , 21 December, 2022
I am not using gurux, but tasmota to read out my ISKRAEMECO AM550.
You seem to know how to communicate with the smart meter. Because I did not find any manuals or resources on this online can you help me out?
I am getting something like this as a response:
09:32:20.360 : 7e a0 67 cf 02 23 13 fb f1 e6 e7 00 db 08 49 53 4b 68 74 99 f5 08 4f 20 00 1e 30 c4 74 eb 7a a7 3c 74 22 81 57 81 74
09:32:20.402 : b7 44 32 17 b1 5b 70 ec bb 7a 6f dc 78 de 2e 64 9f f4 e0 c1 d7 ac 19 1d 56 44 8e 96 d2 0c f7 19 cf f8 f0 a9 5a 59 7b e7
09:32:20.445 : 7f 6c 59 6b c7 b6 72 43 38 9b 61 da ad 01 09 06 60 73 3d 7c 40 f3 2d 39 8b 7e
09:32:23.429 : 12 fb 80 bf f6 65 65 b7 b4 cd 66 bb 0a 53 fc b5 96 18 a3 48 59 4e 8d 61 3e e7 c6 90 0c e3 ea 38 77 76 ad e9 89 79 a0 cf
09:32:23.471 : cc 33 4a 7e
09:32:24.349 : 7e a0 67 cf 02 23 13 fb f1 e6 e7 00 db 08 49 53 4b 68 74 99 f5 08 4f
09:32:24.392 : 20 00 1e 30 c8 6a 2e 27 45 2d 31 8c 86 5d e3 a9 41 d7 b0 63 2f fd e5 a5 f9 1b d9 88 32 c9 cc a7 85 ef 1e 6d b0 e7 17 4f 70
09:32:24.434 : 13 5b 07 5c bb f3 f1 86 b2 4e 60 ac 27 49 59 f8 05 a0 ab c0 a8 ea 26 53 49 42 e2 03 ed b5 15 c3 b4 d4 09 0e 2d 54 b2 ce 7e
09:32:25.332 : 7e a0 67 cf 02 23 13 fb f1 e6 e7 00
09:32:25.375 : db 08 49 53 4b 68 74 99 f5 08 4f 20 00 1e 30 c9 73 db b0 dd 59 03 64 87 46 d9 09 21 26 0c 46 42 73 0e 87 a0 30 9e b9 1d fb
09:32:25.417 : e6 7c 56 3a a7 f1 bc 34 f0 d3 9a 8b 72 34 78 94 89 fc be c9 a0 09 e4 72 fb 66 72 6f e4 8a 95 f1 41 b1 30 7d 13 ec 03 fa
09:32:25.461 : 02 31 c5 5d 4e 9e bf ff ee 61 f3 7e
09:32:27.436 : a1 5a ad 6c f7 58 2a 8a cd b9 cc 9e 46 18 80 a5 ec 2e 52 d8 2e 90 9b a3 b3 8e 62 b1 5c 16 5b e9 a0 63 77 6a db 84 7e
It should be AES encrypted, since i got a 32 bit key from my grid operator. But how do I apply it?
My settings are pretty basic:
>D
>B
->sensor53 r
>M 1
+1,3,r,0,9600,STROM
1,77070100010800ff@1000,Total consumption,KWh,Total_in,4
This means: First meter, Pin 3, Raw, 0 averaging, 9600 baud, Called it STROM
I also tried 300 baud, but there i got nothing back
3 years 7 months ago
ISKRAEMECO AM550 is sending push messages for the serial port. You can use Gurux listener as a base project to listen to those messages and then parse them.
https://github.com/Gurux/Gurux.DLMS.Python/tree/master/Gurux.DLMS.Push…
PDU is encrypted with GMAC, not AES.
aldiguru
Thanks for your reply.
I have no clue how to get gurux running on my ESP, that I am using to capture the IR signals. I also think this is way to much overhead.
Could you instead help me to understand, how I can process it directly on the ESP?
In this script (https://gist.github.com/pocki80/941fa090a8d6269a9b3b68c195f8750f) it uses "from Crypto.Cipher import AES" so I was assuming AES.
Can you point out where in the gurux code the decryption takes place, so I can compare it?
Can you receive data as described above using IR signals? If you share the schema we can build an example for ESP32-DEVKITC-S1ESPRESSIF.
DLMS is quite a complicated protocol, but because you are interested in only push messages and in Iskraemeco AM550 PDU is coming in one frame you can use that script to get the data.
  • Malcolmactig
  • mhliang
  • Kevinmug
  • mohanadalhweiti
  • dawnso11
