  3. GXDLMSLimiter
GXDLMSLimiter
By kevin jose minj , 20 December, 2022
what are the arguments I have to pass in this function ?
def setValue(self, settings, e):
and from where I invoke
3 years 10 months ago
setValue is reserved for internal use and you don't use it.
What do you want to do?
kevin jose minj
I want to set normal
I want to set normal threshold in meter using python how can I do?
Read the Threshold normal (Attribute index #4) from the meter.
Then modify it and make sure that the data type is the same and write it back.
If you know the data type, you don't need to read it. It's just to let you know the data type.
http://gurux.fi/Gurux.DLMS.Objects.GXDLMSLimiter
lim = GXDLMSLimiter("Logican name")
self.read(lim, 4)
#Modify limiter value.
self.write(lim, 4)
kevin jose minj
I tried this one it is
I tried this one it is returning access error
What is your authentication level? I believe that you need to change the authentication level to High.
Check also the data type. Read the value and try to write the same value back. If it succeeds, then
your data type is wrong.
kevin jose minj
Can you show the example to
Can you show the example to write the custom value in limiter syntactically?
Actually now I am getting this exception
raise Exception("Invalid parameter. In python value type must give.")
lim = GXDLMSLimiter('0.0.17.0.0.255')
#value = self.read(lim, 4)
# Modify limiter value.
lim.thresholdNormal= 0
value = self.write(lim, 4)
and this is my pytho code
You must use the correct type when writing. Something like this:
lim.thresholdNormal = GXUInt32(0)
#You need to change GXUInt32 to correct data type.
kevin jose minj
What is the correct datatype
What is the correct datatype for thresholdNormal ? I used GXUInt32,GXUInt64,GXInt32,GXInt64 all are throwing exception only
That depends on the target threshold. You can read the data type with GXDLMSDirector when you read the threshold normal.
kevin jose minj
In Gurux DLMS Director it is
In Gurux DLMS Director it is showing UInt32 and I tried the GXUInt32.Is anything wrong here?
Are you connecting with the High authentication level?
kevin jose minj
yes, High wtih
yes, High wtih AuthenticationEncryption
Can you change it with GXDLMSDirector?
kevin jose minj
Default it is that only .
Default it is that only . Changing it is possible?
It depends on the meter. If access rights are read/write you can change it.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
