  3. Connecting Gurux DLMS Python Using IP Address
Connecting Gurux DLMS python using IP Address
By kevin jose minj , 21 October, 2022
python main.py "-h", "xxx.xxx.x.x","-p", "4059" , "-c", "48", "-a", "High", "-P", "ABCDEFG",
"-C", "AuthenticationEncryption", "-T" ,"49534B3030303031", "-A", "000102030405060708090A0B0C0D0E0F",
"-B", "000102030405060708090A0B0C0D0E0F", "-D", "6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B" ,"-w", "1", "-f", "512",
"-o", "device.xml", "-g" ,"0.0.96.3.10.255:1;1.0.12.7.0.255:1;1.0.12.7.0.255:2"
I am passing this as argument it is not connecting to meter. How will I connect to the meter also in Gurux DLMS Director shall we get the IP address of the meter through optical probe?
3 years 11 months ago
If you can connect for the meter using an optical probe you can see the IP Address from IP4 Setup Object or IP6 Setup Object.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSIp4Setup
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSIp6Setup
