  3. Failed To Read Data From Iskraemeco AM550
Failed to read data from Iskraemeco AM550
By mainzelM , 4 September, 2022
Hello!
I'm trying to read out data from an Iskraemeco AM550 using the IR interface via the Gurux python interface (on Raspberry PI). I followed the setup instructions but so far I'm unable to receive any data from the device:
root@raspberrypi:/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python# python3 main.py -S /dev/ttyUSB0 -t Verbose
gurux_dlms version: 1.0.135
gurux_net version: 1.0.19
gurux_serial version: 1.0.20
ClientAddress: 0x10
Standard: Standard.DLMS
TX: 17:05:42 7E A0 07 03 21 93 0F 01 7E
RX: 17:05:57
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/main.py", line 112, in main
My IR head claims to comply to ISO 62056-21 using an C2P2102N chip.
I also tried to use -S /dev/ttyUSB0:115200:8None1 , -S /dev/ttyUSB0:300:8None1, -S /dev/ttyUSB0:9600:8None1 without success.
In addition, I tried
# python3 main.py -S /dev/ttyUSB0:115200:8None1 -t Verbose -i HdlcWithModeE
ClientAddress: 0x10
TX: 17:07:44 /?!
Can you give me a hint on how to proceed?
Cheers
mainzelM
4 years ago
IEC 62056-21 is not DLMS. You can read more here:
You can try this:
python3 main.py -S /dev/ttyUSB0:300:7Even1 -t Verbose -i HdlcWithModeE
The default start baud rate for IEC is 300 when an optical probe is used.
mainzelM
4 years ago
Hi Mikko
Hi Mikko
Thanks for the fast response! Unfortunately, still no data can be read:
# python3 main.py -S /dev/ttyUSB0:300:7Even1 -t Verbose -i HdlcWithModeE
ClientAddress: 0x10
TX: 12:39:05 /?!
4 years ago
We don't have AM550 in the office so I can't check this.
It might be that the baud rate is changed. You can try with GXDLMSDirector and search for the correct parameters. Check this video.
https://youtu.be/BeaWKmyMwuE
The meter should reply something for "/?!" when the baud rate is correct and if your optical probe is working.
