  3. Info About GXDLMSReader.java Certificate Generator
Info about GXDLMSReader.java Certificate Generator
By scordedda , 1 September, 2022
Hi all,
I'm using GURUX DLMS for java, I'm able to use the library with no problem, but I found this link
https://certificates.gurux.fi/api/CertificateGenerator
in the class GXDLMSReader.java.
How those certificates are used? I can use this link in the my application or I have to change the certificates?
Thank you
4 years 2 months ago
Those certificates are in PEM format (txt). You don't need to change anything.
Note! There must be own certificate for each meter. There is a server system title on each certificate and it must match for the server system title.
Check this. It will download the certificate and save it for the file and it's used later.
https://github.com/Gurux/gurux.dlms.java/blob/250a86fda9ec481aabf485fca…
Check also this:
https://www.gurux.fi/PublicKeyCryptography
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
