  3. Creating a New Gurux DLMS Client
Creating a new Gurux DLMS client
By Samuseva Alena , 4 August, 2022
Good afternoon!
I am new to building a Gurux DLMS client. I need to connect to the counter and read the information. This connection must be made through an existing DLMS server. I used gurux.dlms.client.example.java for the example but my client is not connecting to the server. Have I chosen the right example to create a client?
3 years 11 months ago
gurux.dlms.client.example.java is the right project if you want to read your meter.
Different meter manufacturers have different settings. I believe that the best way to start is if you connect to your meter with GXDLMSDirector. It will help you to understand DLMS meters and what different COSEM objects can offer.
GXDLMSDirector will also show correct command line arguments for you.
Samuseva Alena
In reply to Hello, by Kurumi
Thanks, I immediately worked
Thanks, I immediately worked with GXDLMSDirector, and you were right about the settings.
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
  • LindanEt
  • annoyingconsultants
