  3. Fetch DLMS Data From Secure Apex 100
Fetch DLMS data from Secure Apex 100
By jimesh , 13 June, 2022
Gurux.Serial
I am trying to fetch data from Secure Apex 100 using RS485 port. From that port, It is connected with Moxa and from Moxa I have connected with System. COM port is COM1.
I am executing command: python main.py -S COM1 -a Low -s 16640 -d India -t Verbose
But, It is showing below result,
gurux_dlms version: 1.0.124
gurux_net version: 1.0.18
gurux_serial version: 1.0.19
ClientAddress: 0x10
ServerAddress: 0x4100
Standard: Standard.INDIA
TX: 17:38:32 7E A0 0A 00 02 04 01 21 93 77 B5 7E
RX: 17:38:47
Could you please help me on this regard?
4 years 1 month ago
If I remember right, the DLMS support is optional feature for Secure Apex 100. You need to verify from the meter vendor that your meter is supporting DLMS.
jimesh
4 years 1 month ago
Yes, It is supporting DLMS.
4 years 1 month ago
For me, it seems that the RS-485 port is for Modbus. You need to connect with RS-232 or Ethernet.
jimesh
4 years 1 month ago
I have tried to connect Ethernet port directly with system instead of moxa and tried to execute code but getting below error "OSError: [WinError 10049] The requested address is not valid in its context"
4 years 1 month ago
Hi Jimesh,
Hi Jimesh,
Your IP address or port TCP number is invalid.
jimesh
4 years 1 month ago
Getting same error for RS232
Getting same error for RS232 port as well.
ClientAddress: 0x10
TX: 19:34:39 7E A0 0A 00 02 04 01 21 93 77 B5 7E
RX: 19:34:54
4 years 1 month ago
Check your serial port settings. The default is 9600 8None1. Your meter might use other settings. Check also your server address.
  • brsRKNujhfnXWm…
  • TmncVuWXpMBjtlVn
  • suMPQCGuZJqlCP…
  • mohanad
  • LOYmPGKtLNYdKy…
