  3. Request For Sample Source To MQTT With Java
Request for sample source to MQTT with Java
By pandigunasekaran , 23 May, 2022
Hi Team,
We can able to communicate gurux TCP protocol using java, we having the requirement to change from TCP to MQTT protocols using DLMS. I was find the some source gurux but it is based on the C#.
Please post if any example source are available for java to achieve it.
Requirement :
MQTT with DLMS compunction using java.
4 years 6 months ago
There is a java version available from the bridge.
https://github.com/Gurux/gurux.mqtt.java
Are you interested in the MQTT media component so you can implement a java reader using MQTT instead of TCP/IP?
pandigunasekaran
Thanks for updating.
Yes I have interested to implement sample exercise for MQTT with DLMS communication (to read the meter reading using MQTT instead of TCP).
I will try to configure the source shard by you. I will update the status asp. Thanks you..
Pandi G
pandigunasekaran
Dear Mikko,
Dear Mikko,
if any sample exercise available for complete MQTT development. it is available kindly share the source with configuration information. It is going to help us to complete our development using MQTT.
Thank You,
Pandi G
MQTT media component is not implemented for java at the moment. It's planned to add in the autumn.
Adonay Eshetu
3 years 11 months ago
HI Mikko,
HI Mikko,
Hope the holiday went well for you, I was actually waiting for the release of java MQTT media package too and autumn is almost over, What is the current status and when will it be released?
Thank you.
Sincerely,
Adonay Eshetu
Adonay Eshetu
3 years 10 months ago
Sorry for commenting the above question on your holiday break, but would you check that please, I am planning to include MQTT media in my DLMS client application and knowing if it is coming out sooner or if its coming out a little late helps me with my plan.
Thank you,
Sincerely,
Adonay Eshetu
Hi Adonay Eshetu,
Hi Adonay Eshetu,
That is done, but tests haven't started yet. Some of our clients wanted some other functionality and those features were implemented first.
If everything goes as planned, tests can be started the next week.
Adonay Eshetu
Thank you for the reply.
Sincerely,
Adonay Eshetu
MQTT media is released. You can use it from the DLMS client example by adding the broker address and topic.
Something like this:
-h iot.eclipse.org -q "273df25d-19f9-4771-bddb-2a5fbad3c4fe/1" -t Verbose
You also need to start the Bridge.
https://www.gurux.fi/Gurux.MQTT
Adonay Eshetu
Thank you for releasing it in time and for giving us the notice.
Thank you.
Adonay Eshetu
