  3. Reading Obis Object Values
Reading Obis Object values
By ogtheterror , 29 April, 2022
Gurux.Net
Hi All
We trying to read DLMS meters.
We can successfully connect and create association views. We are now trying to read the values of the GXDLMSObject's but we are not able to identify the reading value in the reply object when doing a Read as per the example below:
Read attribute value.public object Read(GXDLMSObject it,int attributeIndex)
ReadDataBlock(Client.Read(it.Name, it.ObjectType, attributeIndex), reply);
return Client.UpdateValue(it, attributeIndex, reply.Value);
We are trying to Read OBIS Code: 1.1.32.7.0.255 Ch. 1 - L1 Voltage Inst. value
And receiving this reply object when sterilized to JSon:
{"DataType":9,"Value":"AQEgBwD/","ReadPosition":8,"PacketLength":23,"RawPdu":false,"Command":196,"CipheredCommand":0,"Data":{"Capacity":12,"Position":0,"Size":8,"Available":8,"Data":"CQYBASAHAP8gBwD/"},"IsComplete":true,"FrameId":82,"InvokeId":193,"Error":0,"EmptyResponses":0,"TotalCount":0,"CipherIndex":0,"Time":"0001-01-01T00:00:00","BlockNumber":0,"BlockNumberAck":0,"ClientAddress":18,"TargetAddress":18,"ServerAddress":16,"SourceAddress":16,"Gateway":null,"IsMoreData":false,"IsNotify":false,"MoreData":0,"ErrorMessage":"","Count":0,"Peek":false}
TX: 10:18:45 7E A0 19 21 25 32 8C 09 E6 E6 00 C0 01 C1 00 03 01 01 20 07 00 FF 01 00 38 36 7E
RX: 10:18:48 7E A0 18 25 21 52 30 72 E6 E7 00 C4 01 C1 00 09 06 01 01 20 07 00 FF 04 08 7E
BlockCipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
Authentication Key:D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
1: 7E A0 18 25 21 52 30 72 E6 E7 00 C4 01 C1 00 09 06 01 01 20 07 00 FF 04 08 7E
<HDLC len="17" >
<TargetAddress Value="12" />
<SourceAddress Value="10" />
<FrameType Value="52" />
<PDU>
<GetResponse>
<GetResponseNormal>
<!-- Priority: High, ServiceClass: Confirmed, Invoke ID: 1 -->
<Result>
<Data>
<!-- 1.1.32.7.0.255 -->
<OctetString Value="0101200700FF" />
</Data>
</Result>
</GetResponseNormal>
</GetResponse>
</PDU>
</HDLC>
Is the OctetString the meter reading and how do we translate the value?
If its not the reading where / how do we get it?
Please could you help with some insight.
Regards
Gavin
4 years 6 months ago
You have read the logical name of the object. It's in attribute index #1. Try to read index #2.
Try to read the meter with GXDLMSDirector first. It will help you to get an idea from DLMS meters.
ogtheterror
Thanks Mikko, we knew we
Thanks Mikko, we knew we where missing something small.
Gavin
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
