  3. Unhandled Exception. MySql.Data.MySqlClient.MySqlException (0x80004005)
Unhandled exception. MySql.Data.MySqlClient.MySqlException (0x80004005)
Profile picture for user riahtu
By riahtu , 20 November, 2021
Known problems
I get an error like this when I change to use MySQL database, please.
Unhandled exception. MySql.Data.MySqlClient.MySqlException (0x80004005): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-db.GXSystemError' at line 1
at MySql.Data.MySqlClient.MySqlStream.ReadPacket()
at MySql.Data.MySqlClient.NativeDriver.GetResult(Int32& affectedRow, Int64& insertedId)
at MySql.Data.MySqlClient.Driver.GetResult(Int32 statementId, Int32& affectedRows, Int64& insertedId)
at MySql.Data.MySqlClient.Driver.NextResult(Int32 statementId, Boolean force)
at MySql.Data.MySqlClient.MySqlDataReader.NextResult()
at MySql.Data.MySqlClient.MySqlCommand.ExecuteReader(CommandBehavior behavior)
at MySql.Data.MySqlClient.MySqlCommand.ExecuteDbDataReader(CommandBehavior behavior)
at System.Data.Common.DbCommand.System.Data.IDbCommand.ExecuteReader()
at Gurux.Service.Orm.GXDbConnection.GetColumnsInteral(String tableName, DatabaseType type, DbConnection connection)
at Gurux.Service.Orm.GXDbConnection.GetColumns(String tableName)
at Gurux.Service.Orm.GXDbConnection.GetColumns(Type type)
at Gurux.Service.Orm.GXDbConnection.UpdateTable(Type type)
at Gurux.Service.Orm.GXDbConnection.UpdateTable[T]()
at Gurux.DLMS.AMI.Startup.ConfigureServices(IServiceCollection services) in /opt/Gurux.DLMS.AMI/Gurux.DLMS.AMI/Startup.cs:line 174
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor, Boolean wrapExceptions)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.InvokeCore(Object instance, IServiceCollection services)
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.<>c__DisplayClass9_0.<Invoke>g__Startup|0(IServiceCollection serviceCollection)
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.Invoke(Object instance, IServiceCollection services)
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.<>c__DisplayClass8_0.<Build>b__0(IServiceCollection services)
at Microsoft.AspNetCore.Hosting.GenericWebHostBuilder.UseStartup(Type startupType, HostBuilderContext context, IServiceCollection services)
at Microsoft.AspNetCore.Hosting.GenericWebHostBuilder.<>c__DisplayClass12_0.<UseStartup>b__0(HostBuilderContext context, IServiceCollection services)
at Microsoft.Extensions.Hosting.HostBuilder.CreateServiceProvider()
at Microsoft.Extensions.Hosting.HostBuilder.Build()
at Gurux.DLMS.AMI.Program.Main(String[] args) in /opt/Gurux.DLMS.AMI/Gurux.DLMS.AMI/Program.cs:line 46
Aborted
4 years 11 months ago
Is your database empty? Is this happening right away or are you doing something?
Please, don't add pics in the future. They are hard to read. Plain text is better.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
  • Nico_
