  3. Add Parameters To The Command Using Gurux
Add parameters to the command using gurux
By xerifehud , 8 October, 2021
Hello.
I need to do a GET reading on a meter.
I have the obis, it claims class 7, and I need to read attribute 2:
I am reading attribute 3 first and then I read attribute 2 using class GXDLMSProfileGeneric
To make the reading I need to send in the GET command one of the parameters below, to select what I want to read:
- 02 02 04 06 00 00 01 53 06 00 00 02 2d 12 00 00 12 00 00
- 02 02 04 06 00 00 01 52 06 00 00 02 2d 12 00 00 12 00 00
How would I add these parameters to the command, using gurux?
I’m using Java Link in the implementation.
Thanks!
4 years 11 months ago
You can read only one value at a time with correct implementation using -g parameter. You can add a new object and read it like this:
GXProfileGeneric pg = new GXProfileGeneric("Logical Name");
//Read columns,
read(pg, 2);
//Read data by start and end time.
readRowsByRange(pg, start_tiem, end_time);
xerifehud
4 years 10 months ago
I need to do a reading by
I need to do a reading by sending a command type GET I know the obis, class 7.
I’m reading attribute 3 first
However, to read the attribute 2 of this command I need to send an Accessselection. However, I don’t know how to add this to the get command.
Below how the manufacturer is sending the command:
7E A0 2C 03 03 32 49 EA E6 E6 00 C0 01 C1 00 07
00 00 63 63 00 FF 02 01 02 02 04 06 00 00 01 52
06 00 00 02 2D 12 00 00 12 00 00 F6 67 7E
<HDLC len="43" >
<TargetAddress Value="1" />
<SourceAddress Value="1" />
<!--I frame.-->
<FrameType Value="32" />
<PDU>
<GetRequest>
<GetRequestNormal>
<!--Priority: HIGH ServiceClass: CONFIRMED invokeID: 1-->
<InvokeIdAndPriority Value="193" />
<AttributeDescriptor>
<!--PROFILE_GENERIC-->
<ClassId Value="7" />
<!--0.0.99.99.0.255-->
<InstanceId Value="0000636300FF" />
<AttributeId Value="2" />
</AttributeDescriptor>
<AccessSelection>
<AccessSelector Value="2" />
<AccessParameters>
<Structure Qty="4" >
<UInt32 Value="338" />
<UInt32 Value="557" />
<UInt16 Value="0" />
</Structure>
</AccessParameters>
</AccessSelection>
</GetRequestNormal>
</GetRequest>
</PDU>
</HDLC>
I would like to know how can I add this:
<AccessSelection>
<AccessParameters>
</Structure>
</AccessParameters>
</AccessSelection>
Thanks.
You can use ReadByRange or ReadByEntry methods of the GXDLMSClient for reading only part of profile generic data.
xerifehud
Could you, please, give an
Could you, please, give an example of I can submit this struct: <AccessParameters>
How can I send that
Thanks.
You will use readRowsByEntry method to generate this method. Like this:
pg = GXDLMSProfileGeneric("0.0.99.99.0.255")
client.readRowsByEntry(pg, start_index, end_index)
Check the client example. It will do everything that you want to do.
xerifehud
Hello.
Hello.
Actually, I would like to know how to send the struct along with the get command, because I already know how to send the desired date limits.
Follows below the Structure I need to add:
</Structure>
Thanks!
readRowsByEntry will send get command where is structure as you describe.
client.readRowsByEntry(pg, 338, 557)
