  3. Getting Error Java.lang.IllegalArgumentException: Change Type Failed. Not Enought Data.
Getting error java.lang.IllegalArgumentException: Change type failed. Not enought data.
By Mithun Tiruvedula , 27 February, 2021
Hi all,
I'm relatively new to DLMS and associated development. I'm trying to build a Tridium Niagara driver for DLMS.
I was able to run the server from https://github.com/Gurux/gurux.dlms.java/tree/master/gurux.dlms.server… , and am using the code from https://github.com/Gurux/gurux.dlms.java/tree/master/gurux.dlms.client… to read data.
I am able to read all data except for a few fields, as follows:
1. GXDLMSAutoConnect (0.0.2.1.0.255 Ch. 0 Auto connect) - Position 5
2. GXDLMSActivityCalendar (0.0.13.0.0.255 Ch. 0 Activity calendar #1) - Position 3
3. GXDLMSActivityCalendar (0.0.13.0.0.255 Ch. 0 Activity calendar #1) - Position 7
And here's the exception I get, originating at com.leanovate.dlmsDriver.GXDLMSReader.read from my code which is adapted from the method getReadOut() in https://github.com/Gurux/gurux.dlms.java/blob/master/gurux.dlms.client… (Line number 837).
gurux.dlms.client java.lang.IllegalArgumentException: Change type failed. Not "enought" data
Am I doing something wrong? Are these fields readable?
Thank you in advance!!
Mithun
5 years 8 months ago
I just try this and it worked like expected. Have you made changed to the source code?
Mithun Tiruvedula
Hi Mikko
Hi Mikko
No, I have not changed any source code.
The error stopped occurring and happens irregularly now. Weird!
if it happens again, I'll post the steps to reproduce.
Thanks and Regards,
Mithun
Thank you for this info.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
