  3. T_APPL_DATA_LN_N1and T_APPL_DATA_LN_N4 - Cct Fail
T_APPL_DATA_LN_N1and T_APPL_DATA_LN_N4 - cct fail
By rajacms , 25 February, 2021
Dear Mikko
I based ctt fail for following test also Please give me solution
CTT tool version:
ctt 3.1 standard 64-bits release 107
T_APPL_DATA_LN_N1
0/0, ServerSAP = 1, ClientSAP = 16, LONG_NAMES, NO_SECURITY
Get-Request with errors FAILED(Unexpected negotiated conformance)
T_APPL_DATA_LN_N4
Unsupported service (LN) FAILED(Unexpected negotiated conformance)
T_APPL_REL_P1
1: Graceful release in HDLC profile FAILED(Unexpected negotiated conformance)
5 years 5 months ago
I believe that your _CTI configuration file is not correct. Check that you define correct conformance for each association. Some thing like;
Association [0] =
ConformanceBlock = [GET]
Association [1] =
ConformanceBlock = [GET, SET, etc...]
rajacms
_CTI configuration file setting this. Please check it where it is issue?
TestOptions =
CommunicationProfile = HDLC
ReferencingMethod = LONG_NAMES
MediaIdentifiers = [ABSTRACT, ELECTRICITY]
//SecurityPolicyMinimum = NO_SECURITY
//SecurityPolicyWritable = FALSE
ServerMaxReceivePduSize = 2048
LogicalDevice[0] =
Enabled = TRUE
Name = "\CMS Computers"
ServerSAP = 1
Association [0] =
Enabled = TRUE
ClientSAP = 0x10
ApplicationContextName = LONG_NAMES
AuthenticationMechanismName = NO_SECURITY
Association [1] =
Enabled = TRUE
ClientSAP = 0x20
AuthenticationMechanismName = LOW_LEVEL_SECURITY
ConformanceBlock = [GET,BLOCK_TRANSFER_WITH_GET_OR_READ,SELECTIVE_ACCESS]
Secret = "\CMS_DLMS_METER_3"
HDLCProfile =
PhysicalLayer =
OpeningMode = DIRECT_HDLC
HDLCBaud = 9600
DataLinkLayer =
AddressingSchemes = [ONE_BYTE_ADDRESSING,FOUR_BYTES_ADDRESSING]
ServerLowerMacAddress = 256
InactivityTimeout = 120000
InterFrameTimeout = 100
ResponseTimeout = 2000
DISCToNDMTimeout = 1000
Make the connection to the meter without authentication and check that only Get is in negotiated conformance.
https://www.gurux.fi/Gurux.DLMS.Conformance
rajacms
Dear Mikko,
Dear Mikko,
This three( T_APPL_DATA_LN_N1,T_APPL_DATA_LN_N4 ,T_APPL_REL_P1)CTT testing issue only based on negotiated conformance?. this issue fixed in new released version? Please update status
5 years 4 months ago
The error that you have posted:
Those tests should be passed if your settings are correct. Our clients have passed CTT tests when they are using our stack.
  • Thomasqto
  • Uka Ibe
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
