  3. SL7000 Scalers In Profile Generic
SL7000 scalers in profile generic
By marianotigre , 4 January, 2021
Gurux.Net
Hello, I'm using Gurux.Net for reading instant values and profile generic
On the profile generic 1, the first five channels are configured with 1 decimal place (10^-1) and the last 3 channels are configured with 3 decimal places (10^-3)
When the profile generic is read with Gurux.net, the values come without decimals
For example,
tension on phase 1 is configured 10^-1 and the value in ACPilot is 229.1 but DLMSDirector and Gurux.Net reads 2291 without decimals
current on phase 1 is configured 10^-3 and the value in ACPilot is 0.202 but DLMSDirector and Gurux.Net reads 202 without decimals
My C# code is as follows:
GXDLMSProfileGeneric oLoadProfile = new GXDLMSProfileGeneric("0.0.99.1.0.255");
Read(oLoadProfile, 3);
ReadRowsByRange(oLoadProfile, DateTime.Today.AddDays(-1), DateTime.Today);
List<object[]> oLista = oLoadProfile.Buffer;
for (int fila = 0; fila < oLista.Count; fila++ ) {
for (int col = 0; col < oLoadProfile.CaptureObjects.Count; col++ ) {
// parse data
With the Curux.Net library, i'm using
Client.Object.Save("template.xml",new GXXmlWriterSettings(){ UserMeterTime=true, IgnoreDefaultValues=false});
But I cannot find any "Scaler" atributes on the profile generic portion for "0.0.99.1.0.255"
- Gurux.Net supports the scaler in the profile generic of the SL7000 meter?
- Am I making a mistake in the code?
5 years 10 months ago
You need to update register scalers. You can read them from the meter (check GetScalersAndUnits -method from the client example) or set scalers manually like this.
//Now set the scalers. for capture objects.
((GXDLMSRegister)oLoadProfile.CaptureObjects[0].Key).Scaler = 0.1;
