  3. VERDICT: 1.logical_name R- FAILED(No Response)
VERDICT: 1.logical_name R- FAILED(No response)
By viswanath.gowd , 1 November, 2020
Hi Mr. Mike,
During testing of smart meter we are getting below errors:
Client System Title (Tx) = 4354543030303030
Server System Title (Rx) = 56504C3030303031
1. Dedicated Key = DED0D684941FBE416A7A7D6EAF37A940
Log:
13'46.248 READ attribute 1 of instance 0000600102FF of class Data
13'46.273 ENCRYPTION KEY: DED0D684941FBE416A7A7D6EAF37A940, IC: 59E7D3D1,
13'47.230 EXCEPTION (ENoResponse): No response
13'47.240 VERDICT: 1.logical_name R- FAILED(No response)
Tx: 7EA0230002040141FC6969E6E600D0122059E7D3D142E494DB4B5C726E189124C45225AD7E
Rx: 7EA0244100020401FC428AE6E700D482001120000003EA5F85CAB6EB1471BF0B3E14A225967E
2. Dedicated Key = DED0D684941FBE416A7A7D6EAF37A940
Log:
13'48.238 READ attribute 2 of instance 0100000402FF of class Data
13'48.252 ENCRYPTION KEY: DED0D684941FBE416A7A7D6EAF37A940, IC: 59E7D3CF
13'48.409 EXCEPTION (ENoResponse): No response
13'48.423 VERDICT: 2.value R- FAILED(No response)
Tx: 7EA0230002040141F84D2FE6E600D0122059E7D3CE10F5D9B2319E5ABB0C30CF2E4B3A597E
Rx: 7EA0244100020401B8628EE6E700D482001120000003E8F212808278BF6D12E4AFA5455F8F7E
Kindly help us in identifying the issue.
Regards
Viswanath Gowd
6 years ago
Hi Viswanath Gowd,
Hi Viswanath Gowd,
I believe that reason is that your meter is sending a response when there should be none or then there should be an error. I'm don't know what CTT test this is so I can't tell why the meter shouldn't reply.
You need to check that from the yellow book.
viswanath.gowd
6 years ago
Ok Mr. Mikko. We will explore
Ok Mr. Mikko. We will explore the issue.
Regards
Viswanath Gowd
  • JOBS Billiard (Jakarta Online Billiard Store) | WA 083148835648
  • Billiard Supplies | WA 083148835648
