  3. Facing Issue In Adding/Removing The Object In Profile Generic Class
Facing issue in Adding/Removing the Object in profile Generic Class
By husainmalkani@… , 27 October, 2020
I am testing the Profile Generic class using guruX software and in Load profile, I'm trying to add and remove the object. But It is showing an unacceptable frame Error. I have a total of 3 PC and from these three only one(PC -3) PC is able to add/remove the object.
Here are the configurations of the GuruX version and library version.
1) 1st setup : GuruX version: 8.1.2010.0901
In library version: .NET Framework 4.0 version 4.8.03752
2) 2nd setup: GuruX version: 8.2.2010.0901
3) 3rd setup : GuruX version: 8.2.2010.0901
In library version: .NET Framework 4.0 version 4.8.03752 and
.NET Framework 3.5 SP 1 version 3.5.30729.4926
If I use setup 3 then I am able to add and remove the objects from the Load profile. and for setup 1 and 2 unacceptable frame error is coming. please help me to solve/understand this issue.
5 years 10 months ago
Can you add a trace from the bytes so I can check the differences?
husainmalkani@…
Hi Micco,
Hi Micco,
Thank you for your Response,
I am sorry for the late reply. I was not able to give a response.
Here is the Log for Not working PC:
GXDLMSDirector 8.2.2010.0901
Log created 17:04:55
17:05:09 Writing object 1.0.99.1.0.255, interface ProfileGeneric
7E A8 89 03 C9 78 87 A6 E6 E6 00 E0 01 00 01 00 00 81 F9 C1 01 C1 00 07 01 00 63 01 00 FF 03 00 01 27 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 15 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 29 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 3D 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 16 08 00 90 5F 7E
17:05:09
7E A0 07 C9 03 B1 7C 6A 7E
7E A8 89 03 C9 7A 95 85 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 2A 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 3E 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 17 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 2B 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 3F 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 00 FF 0F AB EF 7E
17:05:09
7E A0 07 C9 03 D1 7A 09 7E
7E A0 0D 03 C9 7C 01 E5 02 12 00 00 D4 FE 7E
17:05:14 Data send failed. Try to resend 1/3
17:05:14
7E A0 07 C9 03 F1 78 28 7E
17:05:14 Writing object 1.0.99.1.0.255, interface ProfileGeneric
7E A8 89 03 C9 9E BF 24 E6 E6 00 E0 01 00 02 00 01 81 F9 02 04 12 00 03 09 06 01 00 18 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 2C 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 40 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 90 24 7E
17:05:14
7E A0 0C C9 03 97 5D EE 9E E6 08 14 67 7E
Gurux.DLMS.GXDLMSException: Unacceptable frame.
at GXDLMSDirector.GXDLMSCommunicator.Write(GXDLMSObject obj, Int32 index)
at GXDLMSDirector.MainForm.WriteMnu_Click(Object sender, EventArgs e)
and here is the Log of Working PC:- PC-3 (i.e.: able to Add/Remove)
GXDLMSDirector 8.2.2009.0801
Log created 17:12:42
17:13:10 Writing object 1.0.99.1.0.255, interface ProfileGeneric
7E A8 89 03 C9 5C A1 C1 E6 E6 00 C1 02 C1 00 07 01 00 63 01 00 FF 03 00 00 00 00 00 01 81 EC 01 30 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 15 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 29 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 3D 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 16 08 00 FF D6 05 7E
17:13:10
7E A8 89 03 C9 5E B3 E2 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 2A 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 3E 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 17 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 2B 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 3F 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 00 FF 0F 02 4F DB 7E
17:13:10
7E A0 07 C9 03 11 76 CF 7E
7E A0 0C 03 C9 50 D4 12 12 00 00 5A FF 7E
17:13:10
7E A0 13 C9 03 34 94 08 E6 E7 00 C5 02 C1 00 00 00 01 0F 03 7E
7E A8 89 03 C9 72 DD 09 E6 E6 00 C1 03 C1 00 00 00 00 02 81 F6 02 04 12 00 03 09 06 01 00 18 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 2C 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 40 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 E5 64 7E
17:13:10
7E A0 07 C9 03 51 72 8D 7E
7E A8 89 03 C9 74 EB 6C 01 00 01 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 05 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 06 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 07 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 08 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 EE 13 7E
17:13:11
7E A0 07 C9 03 71 70 AC 7E
17:13:11 Writing object 1.0.99.1.0.255, interface ProfileGeneric
7E A0 0C 03 C9 76 E0 56 02 08 02 1D 97 7E
17:13:11
7E A0 13 C9 03 96 8C 8E E6 E7 00 C5 02 C1 00 00 00 02 94 31 7E
7E A8 89 03 C9 98 89 41 E6 E6 00 C1 03 C1 00 00 00 00 03 81 F6 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 05 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 06 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 07 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 08 FF 0F 02 12 00 00 02 F0 25 7E
17:13:11
7E A8 89 03 C9 9A 9B 62 04 12 00 03 09 06 01 00 03 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 05 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 06 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 07 FF 0F 02 12 00 00 02 04 12 CB 0B 7E
17:13:11
7E A0 0C 03 C9 9C B4 1E 00 03 09 DE 78 7E
17:13:11
7E A0 13 C9 03 F8 F4 04 E6 E7 00 C5 02 C1 00 00 00 03 1D 20 7E
7E A8 89 03 C9 BE BD 05 E6 E6 00 C1 03 C1 01 00 00 00 04 81 8A 06 01 00 03 08 08 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 05 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 06 FF 8E 29 7E
17:13:11
7E A0 20 03 C9 B0 BD ED 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 07 FF 0F 02 12 00 00 6F 53 7E
17:13:11
7E A0 14 C9 03 3A CB B6 E6 E7 00 C5 03 C1 00 00 00 00 04 A5 C8 7E
17:13:11 Reading object 1.0.99.1.0.255, interface ProfileGeneric
7E A0 19 03 C9 D2 38 18 E6 E6 00 C0 01 C1 00 07 01 00 63 01 00 FF 03 00 8C 90 7E
17:13:12
7E A8 89 C9 03 5C 9B 8F E6 E7 00 C4 02 C1 00 00 00 00 01 00 81 EC 01 30 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 15 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 29 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 3D 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 16 08 00 FF 0F 02 12 00 00 02 04 12 00 10 76 7E
17:13:12 Get next frame.
17:13:12 Reading object 1.0.99.1.0.255, interface ProfileGeneric
7E A0 07 03 C9 F1 42 66 7E
17:13:12
7E A0 83 C9 03 5E 07 2A 03 09 06 01 00 2A 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 3E 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 17 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 2B 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 3F 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 00 FF 0F 02 12 00 00 81 9C 7E
17:13:12 Get Next Data block.
7E A0 13 03 C9 14 AC 67 E6 E6 00 C0 02 C1 00 00 00 01 51 BE 7E
17:13:12
7E A8 89 C9 03 70 F5 64 E6 E7 00 C4 02 C1 00 00 00 00 02 00 81 EA 02 04 12 00 03 09 06 01 00 18 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 2C 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 40 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 5D E2 7E
7E A0 07 03 C9 31 4E A0 7E
17:13:12
7E A0 81 C9 03 72 1F F8 06 01 00 01 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 05 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 06 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 07 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 08 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 01 FF 0F 02 12 00 00 D9 45 7E
7E A0 13 03 C9 56 BA 06 E6 E6 00 C0 02 C1 00 00 00 02 CA 8C 7E
17:13:12
7E A8 89 C9 03 94 DF C5 E6 E7 00 C4 02 C1 00 00 00 00 03 00 81 EA 02 04 12 00 03 09 06 01 00 02 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 05 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 06 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 07 FF 0F 02 12 00 00 02 04 12 00 03 09 2A 85 7E
7E A0 07 03 C9 71 4A E2 7E
17:13:12
7E A0 81 C9 03 96 35 59 06 01 00 02 08 08 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 05 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 06 FF 0F 02 12 00 00 A8 4C 7E
7E A0 13 03 C9 98 C8 29 E6 E6 00 C0 02 C1 00 00 00 03 43 9D 7E
17:13:13
7E A8 89 C9 03 B8 B1 2E E6 E7 00 C4 02 C1 01 00 00 00 04 00 81 A2 02 04 12 00 03 09 06 01 00 03 08 07 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 08 08 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 AE 6E 7E
17:13:13 Get next frame.
17:13:13 Reading object 1.0.99.1.0.255, interface ProfileGeneric
7E A0 07 03 C9 B1 46 24 7E
17:13:13
7E A0 39 C9 03 BA 1F 36 06 01 00 04 08 05 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 06 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 04 08 07 FF 0F 02 12 00 00 6E DE 7E
