  3. How To Ignore AssociationView By Using Stored XML
How to ignore AssociationView by using stored XML
By ton.tanasin , 14 October, 2020
Gurux.Serial
My modem has a small CPU. It consumes a lot of time to process parseObject in GXDLMSReader.
I found the AssociationView has been stored when I use -o option and I wonder how can I use this output file to skip parseObject process in the next run.
Is it possible to do that? Please share the solution.
Many thanks in advance.
6 years ago
You don't need to read the association view if you know what you want to read. You can save this information to the EEPROM and skip association view read, and read only values that you need.
ton.tanasin
6 years ago
Many thanks, Mikko.
Many thanks, Mikko.
I'm new to HW programming. I'll try your suggestion.
BR.
Ton Tanasin
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
