  3. How To Read Data End Send Request. DTZY217 I Need Reed Parameters
how to read data end send request. DTZY217 i need reed parameters
By enhee88009932 , 17 September, 2020
Gurux.Serial
i need DTZY217 wire smart meters parameters. help me ?
DLMS / cosem compliant support .
address : 21
obis code : 21.11.1
serial port: com6
5 years 10 months ago
Download GXDLMSDirector and try to connect with that. You can select Gurux to the manufacturer and try to connect.
enhee88009932
i need c# example code.
i need c# example code. please
Read the meter first with GXDLMSDirector. When your settings are correct you can use client example to read it.
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Client.E…
  • brsRKNujhfnXWm…
  • TmncVuWXpMBjtlVn
  • suMPQCGuZJqlCP…
  • mohanad
  • LOYmPGKtLNYdKy…
