  3. GXStructure
GXStructure
By Srinivasan , 22 June, 2020
Im trying to do write operation using Java.
Code:
GXStructure input = new GXStructure();
input.add(0, 400);
input.add(1, 1800);
input.add(2, 4);
input.add(3, new GXDateTime(2020, 10, 22, 0,0,0,0));
Above code generate the following PDU
<SetRequest>
<SetRequestNormal>
<Value>
<Structure Qty="04" >
<Int32 Value="400" />
<Int32 Value="1800" />
<Int32 Value="4" />
# 7/27/2020 9:55:00 PM
<Date Time Value="07E4071BFF0A3700FF014A00" />
</Structure>
</Value>
</SetRequestNormal>
</SetRequest>
But device report it as error like "Access Error : Device reports a unmatched type"
Expected behavior:
Meter expect the PDU exactly like
<Value>
<UInt32 Value="00000190" />
<UInt32 Value="00000708" />
<UInt8 Value="04" />
<OctetString Value="07E4071BFF0A3700FF014A00" />
</Structure>
</Value>
Please guide me to how to create above GXStructure using java code.
6 years 5 months ago
You can try with this.
input.add(0, new GXUInt32(400));
input.add(1, GXUInt32(1800));
input.add(2, GXUInt8(4));
Srinivasan
Thanks for your quick
Thanks for your quick response
As per your suggestion i got partial success :), see the below PDU
<Value>
# 10/22/2020 12:00:00 AM
<DateTime Value="07E40A1604000000FFFEB600" />
</Structure>
</Value>
</SetRequestNormal>
Only DateTime need to converted into OctetString type.
Please guide me on this.
I need to think about this a little bit. We have used XML to set values like this, but I'll think something.
Hi Srinivasan,
Hi Srinivasan,
We have added new class for date time octect string.
You can use it like this:
input.add(3, new GXDateTimeOS(2020, 10, 22, 0,0,0,0));
Now date-time is sent as an octet string.
Srinivasan
6 years 4 months ago
Sorry for the late response.
I Have followed the above code snippet, which is also not giving correct datatype. PFB for Request PDU:
<UInt32 Value="0000012C" />
# 09/07/20, 7:00 AM
<DateTime Value="07E407080314000000014A00" />
</Structure>
Expected:
# 09/07/20, 7:00 AM
<OctetString Value="07E407080314000000014A00" />
</Structure>
This is fixed. Update to the latest version (4.0.19).
