  3. LZQJ + Moxa + GSM Call
LZQJ + Moxa + GSM call
By bladyzamosc , 29 March, 2020
I am trying to connect to the meter via the Moxa modem dialing the concrete phone number. Unfortunately, I have no idea how I can proceed with the Gurux library. I am not even convinced it will be possible.
I saw the following topic, which in my opinion was the closest to my problem:
https://www.gurux.fi/node/6759
but I could find a way how to dial the number after I will be connected to the modem. I will be very grateful for any advice/material, which will indicate to me how to take the next step or tell me that I should provide the implementation without GURUX.
Thanks in advance
Blady
6 years 7 months ago
Hi Blady,
Hi Blady,
Make connection using GXDLMSDirector to your meter using optical probe or serial port and check is there Auto connect object.
If you find it, try to set correct parameters and press Connect button. Your meter will now try to call to the given phone number.
For the calling window you can set date-time when meter makes the connection to the server.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
