  3. NO Serial Port Error
By Piyush , 11 December, 2018
Gurux DLMS for Android
I want connect the L&T companies meter with the app but I am getting "No Serial Port Error".
Can you please help me out in this.
7 years 6 months ago
You don't have a serial port on your PC. Change media type to TCP/IP if you try to connect with TCP/IP connection.
Piyush
Actually I want to take reading using Android Phone.
So I connect the Probe to mobile
Can you share what probe you are using? Do you know the chipset?
You can get chipset if you select "Media settings".
Piyush
On cable "<dc> deepcab 04 CORE ROUND DATA CONTROL FR CABLE" is return but I don't not found the chipset related on the cable....
When I connect the cable to mobile, in Media Setting of App shows the chipset to NONE
If you select "Media settings" in the app you can see chipset settings.
Piyush
Yes sir I saw that there are total 5 types of chipsets. But how to check that which one is perfect for me??
What is chipset text?
Piyush
By default the chipset text is NONE,
and on click on that following are visible:
1) PROFILIC
2) CP21XX
3) CDC_ACM
4) FTDI
5) CH34X
OK. Your converter is using some other chipset. If you connect your converter to the Windows PC and select "Device management" and select your serial port from there. Select "Properties" and select "Details" tab. Then select second dropdown item. It's something like:
USB\VID_17A8&PID_0001\0001
Send this info to me and we'll add support for this chipset.
Send also a link if you know where you have order this Probe.
Piyush
PFB info of the Probe:
Device USB\VID_067B&PID_2303\5&15c311e1&0&5 was not migrated due to partial or ambiguous match.
Last Device Instance Id: USB\VID_2D95&PID_6003\16629ba0
Class Guid: {36fc9e60-c465-11cf-8056-444553540000}
Location Path: PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(5)
Migration Rank: 0xF000FFFFFFFF0033
Present: false
Status: 0xC0000719
Your chipset is Prolific. It should be selected. Are you using source codes or packet?
Have you made any changes? Select Prolific as chipset. Let me know if you have problems.
Piyush
I am using the source code as it is not make any changes in that.
I am just connecting the Probe with mobile by using OTG cable, is their any issue cause due to this?
But now when I am click on "Read" it gives me an error "Select serial port first"
We are also using OTG cable. I don't believe that it's an issue.
If you have source code, can you check what are vendor and product values?
Put breakpoint to isUsing-method in GXProfilic.java
Piyush
I am using "Gurux DLMS for Android" and in that GXProfilic.java is not present.
It is present in "Gurux.Serial.Android-master"....
Yes, GXProfilic.java is in Gurux.Serial.Android. Let me know if you have problems.
Piyush
But I am using the "Gurux DLMS for Android" for reading purpose.....
HI,
Yes, In your previous email you said that you have the source codes. Modify Gurux.Serial.Android reference for your local copy.
You can also start Gurux.Serial.Android and check vendor and product IDs in that.
Piyush
I attach the debugger to the method isUsing() but nothing happen.
I also log the value but it is not printing, simply that method is not executing at all.
Then I apply debugger to findPorts() as onClick "Refresh" button this method is executing. But serial.getPorts() method gives nothing. The Post size is zero...
Sometimes Android phone or tablet can't give enough power for the serial port.
Make sure that your serial port is available on the Android.
Piyush
7 years 5 months ago
But how to check that serial port is available on my Android device or not ??
If this is empty there are no USB devices connected.
UsbManager manager = (UsbManager) getSystemService(Context.USB_SERVICE);
manager.getAccessoryList();
