  3. Landis E650 Meter Reading Over DLMS
Landis E650 meter reading over DLMS
By sandy1991 , 17 November, 2026
This is regarding an LNG Meter Value over DLMS where data for certain OBIS codes is not available.
The LNG meter provides all its parameters as per the standard class attributes. However, the Voltage and Current parameters for all three phases are providing data through Attribute 11 which is not a valid attribute of Register class as per DLMS Blue Book.
We would like to confirm whether this behavior is intentional or a bug from LNG before proceeding with any implementation changes to address this issue.
3 days 8 hours ago
HI, This is against DLMS…
HI,
This is against DLMS standards. You should ask the meter manufacturer if there is a meter update available that fixes this.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSRegister
Miko
